[PATCH] rockchip: board: Add minimal generic RK3588S/RK3588 board
Add a minimal generic RK3588S/RK3588 board that only have eMMC and SDMMC enabled. This defconfig can be used to boot from eMMC or SD-card on most RK3588S/RK3588 boards that follow reference board design.
Also fix the alphabetical order of RK3588 boards listed in Makefile and documentation.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- This patch depend on the series "rockchip: rk35xx: Sync device tree with linux v6.8-rc1" [1].
[1] https://patchwork.ozlabs.org/cover/1891669/ --- arch/arm/dts/Makefile | 5 +- arch/arm/dts/rk3588-generic-u-boot.dtsi | 3 ++ arch/arm/dts/rk3588-generic.dts | 44 ++++++++++++++++ board/rockchip/evb_rk3588/MAINTAINERS | 7 +++ configs/generic-rk3588_defconfig | 68 +++++++++++++++++++++++++ doc/board/rockchip/rockchip.rst | 3 +- 6 files changed, 127 insertions(+), 3 deletions(-) create mode 100644 arch/arm/dts/rk3588-generic-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-generic.dts create mode 100644 configs/generic-rk3588_defconfig
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 0fcae77cefe3..6361bc5abc37 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -193,13 +193,14 @@ dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588-edgeble-neu6a-io.dtb \ rk3588-edgeble-neu6b-io.dtb \ rk3588-evb1-v10.dtb \ + rk3588-generic.dtb \ rk3588-nanopc-t6.dtb \ rk3588s-orangepi-5.dtb \ rk3588-orangepi-5-plus.dtb \ rk3588-quartzpro64.dtb \ - rk3588-turing-rk1.dtb \ rk3588s-rock-5a.dtb \ - rk3588-rock-5b.dtb + rk3588-rock-5b.dtb \ + rk3588-turing-rk1.dtb
dtb-$(CONFIG_ROCKCHIP_RV1108) += \ rv1108-elgin-r1.dtb \ diff --git a/arch/arm/dts/rk3588-generic-u-boot.dtsi b/arch/arm/dts/rk3588-generic-u-boot.dtsi new file mode 100644 index 000000000000..853ed58cfe58 --- /dev/null +++ b/arch/arm/dts/rk3588-generic-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk3588s-u-boot.dtsi" diff --git a/arch/arm/dts/rk3588-generic.dts b/arch/arm/dts/rk3588-generic.dts new file mode 100644 index 000000000000..e4721d97a87d --- /dev/null +++ b/arch/arm/dts/rk3588-generic.dts @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Minimal generic DT for RK3588S/RK3588 with eMMC and SD-card enabled + */ + +/dts-v1/; +#include "rk3588s.dtsi" + +/ { + model = "Generic RK3588S/RK3588"; + compatible = "rockchip,rk3588"; + + aliases { + mmc0 = &sdhci; + mmc1 = &sdmmc; + }; + + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&sdhci { + bus-width = <8>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + no-sd; + no-sdio; + non-removable; + status = "okay"; +}; + +&sdmmc { + bus-width = <4>; + cap-sd-highspeed; + disable-wp; + no-mmc; + no-sdio; + status = "okay"; +}; + +&uart2 { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3588/MAINTAINERS b/board/rockchip/evb_rk3588/MAINTAINERS index 2bd44bc58728..eb771da7b7a0 100644 --- a/board/rockchip/evb_rk3588/MAINTAINERS +++ b/board/rockchip/evb_rk3588/MAINTAINERS @@ -7,6 +7,13 @@ F: configs/evb-rk3588_defconfig F: arch/arm/dts/rk3588-evb1-v10.dts F: arch/arm/dts/rk3588-evb1-v10-u-boot.dtsi
+GENERIC-RK3588 +M: Jonas Karlman jonas@kwiboo.se +S: Maintained +F: configs/generic-rk3588_defconfig +F: arch/arm/dts/rk3588-generic.dts +F: arch/arm/dts/rk3588-generic-u-boot.dtsi + ORANGEPI-5-RK3588 M: Jonas Karlman jonas@kwiboo.se S: Maintained diff --git a/configs/generic-rk3588_defconfig b/configs/generic-rk3588_defconfig new file mode 100644 index 000000000000..4755b27c1dea --- /dev/null +++ b/configs/generic-rk3588_defconfig @@ -0,0 +1,68 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00a00000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc00000 +CONFIG_DEFAULT_DEVICE_TREE="rk3588-generic" +CONFIG_ROCKCHIP_RK3588=y +CONFIG_SPL_ROCKCHIP_COMMON_BOARD=y +CONFIG_SPL_SERIAL=y +CONFIG_SPL_STACK_R_ADDR=0x600000 +CONFIG_TARGET_EVB_RK3588=y +CONFIG_SPL_STACK=0x400000 +CONFIG_DEBUG_UART_BASE=0xFEB50000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SPL_FIT_SIGNATURE=y +CONFIG_SPL_LOAD_FIT=y +CONFIG_LEGACY_IMAGE_FORMAT=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3588-generic.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_SPL_MAX_SIZE=0x40000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x4000000 +CONFIG_SPL_BSS_MAX_SIZE=0x4000 +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK_R=y +CONFIG_SPL_ATF=y +CONFIG_CMD_GPIO=y +CONFIG_CMD_GPT=y +CONFIG_CMD_MMC=y +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SPL_DM_SEQ_ALIAS=y +CONFIG_SPL_REGMAP=y +CONFIG_SPL_SYSCON=y +CONFIG_SPL_CLK=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_MISC=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_HS200_SUPPORT=y +CONFIG_SPL_MMC_HS200_SUPPORT=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_MMC_SDHCI=y +CONFIG_MMC_SDHCI_SDMA=y +CONFIG_MMC_SDHCI_ROCKCHIP=y +CONFIG_SPL_PINCTRL=y +CONFIG_SPL_RAM=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_ERRNO_STR=y diff --git a/doc/board/rockchip/rockchip.rst b/doc/board/rockchip/rockchip.rst index 9fe69fc9422f..393c84a1309c 100644 --- a/doc/board/rockchip/rockchip.rst +++ b/doc/board/rockchip/rockchip.rst @@ -116,10 +116,11 @@ List of mainline supported Rockchip boards: - Edgeble Neural Compute Module 6A SoM - Neu6a (neu6a-io-rk3588) - Edgeble Neural Compute Module 6B SoM - Neu6b (neu6b-io-rk3588) - FriendlyElec NanoPC-T6 (nanopc-t6-rk3588) + - Generic RK3588S/RK3588 (generic-rk3588) - Pine64 QuartzPro64 (quartzpro64-rk3588) - - Turing Machines RK1 (turing-rk1-rk3588) - Radxa ROCK 5A (rock5a-rk3588s) - Radxa ROCK 5B (rock5b-rk3588) + - Turing Machines RK1 (turing-rk1-rk3588) - Xunlong Orange Pi 5 (orangepi-5-rk3588s) - Xunlong Orange Pi 5 Plus (orangepi-5-plus-rk3588)
Hi Jonas,
For rk3399, the evb-rk3399 is used as generic board because almost all the boards which
follow the rockchip reference design can boot with evb-rk3399_defconfig.
For rk3588, I think we can still use evb-rk3588 as generic board instead of a new generic-rk3588?
Since the board level dts will have to relate to IO, regulator, key and so on, a virtual board
may not able to decide which IO/Hardware to use.
Thanks,
- Kever
- rk3588-generic.dtb \ rk3588-nanopc-t6.dtb \ rk3588s-orangepi-5.dtb \ rk3588-orangepi-5-plus.dtb \ rk3588-quartzpro64.dtb \
- Minimal generic DT for RK3588S/RK3588 with eMMC and SD-card enabled
- model = "Generic RK3588S/RK3588";
- compatible = "rockchip,rk3588";
- aliases {
mmc0 = &sdhci;
mmc1 = &sdmmc;
- chosen {
+&sdhci {
- bus-width = <8>;
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
- no-sd;
- no-sdio;
- non-removable;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- no-mmc;
- no-sdio;
- status = "okay";
+&uart2 {
- status = "okay";
- ORANGEPI-5-RK3588 M: Jonas Karlman jonas@kwiboo.se S: Maintained
Since rk356x already have a generic board, rk3588 can also have one.
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- aliases {
mmc0 = &sdhci;
mmc1 = &sdmmc;
- chosen {
+&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- no-sd;
- no-sdio;
- non-removable;
- status = "okay";
+&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- no-mmc;
- no-sdio;
- status = "okay";
+&uart2 {
- status = "okay";
Hi Kever,
Thanks, I will send a v2 with an updated defconfig to take advantage of the new ROCKCHIP_COMMON_STACK_ADDR bss and stack addresses.
Regards, Jonas
Thanks,
- Kever
[snip]
Hi Jonas,
On 2024/3/14 15:04, Jonas Karlman wrote:
Hi Kever,
I have fix this and also other new boards defconfig, so you don't need to do this.
Thanks,
- Kever
Regards, Jonas
Thanks,
- Kever
[snip]
Hi Kever,
On 2024-03-14 08:33, Kever Yang wrote:
Hi Jonas,
Hi Kever,
Great, thanks!
Regards, Jonas
Thanks,
- Kever
Regards, Jonas
Thanks,
- Kever
[snip]
Jonas Karlman
Kever Yang
