[PULL] u-boot-usb/master
The following changes since commit 608a31bdec6284ad6f821226e4c62c9cd3052874:
Merge patch series "Introduce the lwIP network stack" (2024-10-16 11:11:57 -0600)
git://source.denx.de/u-boot-usb.git master
for you to fetch changes up to 6852a2c82e695c418c744b0fcb4298bc0e759842:
MAINTAINERS: add TCPM section (2024-10-17 03:12:47 +0200)
---------------------------------------------------------------- Sebastian Reichel (6): usb: tcpm: add core framework usb: tcpm: fusb302: add driver board: rock5b-rk3588: enable USB-C in operating system rockchip: rk3588-rock-5b: Add USB-C controller to u-boot.dtsi rockchip: rock5b-rk3588: Enable USB-C PD support MAINTAINERS: add TCPM section
MAINTAINERS | 9 + Makefile | 1 + arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 28 + board/radxa/rock5b-rk3588/Makefile | 6 + board/radxa/rock5b-rk3588/rock5b-rk3588.c | 16 + cmd/Kconfig | 7 + cmd/Makefile | 1 + cmd/tcpm.c | 136 ++ configs/rock5b-rk3588_defconfig | 4 + doc/usage/cmd/tcpm.rst | 66 + doc/usage/index.rst | 1 + drivers/usb/Kconfig | 2 + drivers/usb/tcpm/Kconfig | 16 + drivers/usb/tcpm/Makefile | 4 + drivers/usb/tcpm/fusb302.c | 1323 +++++++++++++++++ drivers/usb/tcpm/fusb302_reg.h | 177 +++ drivers/usb/tcpm/tcpm-internal.h | 173 +++ drivers/usb/tcpm/tcpm-uclass.c | 149 ++ drivers/usb/tcpm/tcpm.c | 2288 +++++++++++++++++++++++++++++ include/dm/uclass-id.h | 1 + include/usb/pd.h | 516 +++++++ include/usb/tcpm.h | 99 ++ 22 files changed, 5023 insertions(+) create mode 100644 board/radxa/rock5b-rk3588/Makefile create mode 100644 board/radxa/rock5b-rk3588/rock5b-rk3588.c create mode 100644 cmd/tcpm.c create mode 100644 doc/usage/cmd/tcpm.rst create mode 100644 drivers/usb/tcpm/Kconfig create mode 100644 drivers/usb/tcpm/Makefile create mode 100644 drivers/usb/tcpm/fusb302.c create mode 100644 drivers/usb/tcpm/fusb302_reg.h create mode 100644 drivers/usb/tcpm/tcpm-internal.h create mode 100644 drivers/usb/tcpm/tcpm-uclass.c create mode 100644 drivers/usb/tcpm/tcpm.c create mode 100644 include/usb/pd.h create mode 100644 include/usb/tcpm.h
