[PATCH] ARM: zynq: Add nand controller node in zynq-ces-nand dt
Add memory-controller@e000e000 node in zynq-ces-nand.dts as zynq_nand driver utilizes flash@e1000000 node. Without this dt node mini nand u-boot does not probe.
Signed-off-by: T Karthik Reddy t.karthik.reddy@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynq-cse-nand.dts | 15 +++++++++++++++ 1 file changed, 15 insertions(+)
diff --git a/arch/arm/dts/zynq-cse-nand.dts b/arch/arm/dts/zynq-cse-nand.dts index 1e16d7fab97d..32cb3bffcb94 100644 --- a/arch/arm/dts/zynq-cse-nand.dts +++ b/arch/arm/dts/zynq-cse-nand.dts @@ -38,6 +38,21 @@ #size-cells = <1>; ranges;
+ smcc: memory-controller@e000e000 { + #address-cells = <1>; + #size-cells = <1>; + clock-names = "memclk", "apb_pclk"; + clocks = <&clkc 11>, <&clkc 44>; + compatible = "arm,pl353-smc-r2p1", "arm,primecell"; + ranges; + reg = <0xe000e000 0x1000>; + + nand0: flash@e1000000 { + compatible = "arm,pl353-nand-r2p1"; + reg = <0xe1000000 0x1000000>; + }; + }; + slcr: slcr@f8000000 { u-boot,dm-pre-reloc; #address-cells = <1>;
čt 16. 4. 2020 v 14:22 odesílatel Michal Simek michal.simek@xilinx.com napsal:
#size-cells = <1>;
ranges;
-- 2.26.0
Applied. M
Michal Simek
Michal Simek
