[PATCH v3 1/1] env: sf: single function env_sf_save()
Instead of implementing redundant environments in two very similar functions env_sf_save(), handle redundancy in one function, placing the few differences in appropriate pre-compiler sections depending on config option CONFIG_ENV_OFFSET_REDUND.
Additionally, several checkpatch complaints were addressed.
This patch is in preparation for adding support for env erase.
Signed-off-by: Harry Waschkeit Harry.Waschkeit@men.de Reviewed-by: Stefan Roese sr@denx.de --- Change in v3: - no change in patch, only added "reviewed-by" to commit log
Change in v2: - remove one more #ifdef, instead take advantage of compiler attribute __maybe_unused for one variable used only in case of redundant environments
env/sf.c | 130 ++++++++++++++++++------------------------------------- 1 file changed, 41 insertions(+), 89 deletions(-)
diff --git a/env/sf.c b/env/sf.c index 937778aa37..199114fd3b 100644 --- a/env/sf.c +++ b/env/sf.c @@ -66,13 +66,14 @@ static int setup_flash_device(void) return 0; }
-#if defined(CONFIG_ENV_OFFSET_REDUND) static int env_sf_save(void) { env_t env_new; - char *saved_buffer = NULL, flag = ENV_REDUND_OBSOLETE; + char *saved_buffer = NULL; u32 saved_size, saved_offset, sector; + ulong offset; int ret; + __maybe_unused char flag = ENV_REDUND_OBSOLETE;
ret = setup_flash_device(); if (ret) @@ -81,27 +82,33 @@ static int env_sf_save(void) ret = env_export(&env_new); if (ret) return -EIO; - env_new.flags = ENV_REDUND_ACTIVE;
- if (gd->env_valid == ENV_VALID) { - env_new_offset = CONFIG_ENV_OFFSET_REDUND; - env_offset = CONFIG_ENV_OFFSET; - } else { - env_new_offset = CONFIG_ENV_OFFSET; - env_offset = CONFIG_ENV_OFFSET_REDUND; - } +#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) + env_new.flags = ENV_REDUND_ACTIVE; + + if (gd->env_valid == ENV_VALID) { + env_new_offset = CONFIG_ENV_OFFSET_REDUND; + env_offset = CONFIG_ENV_OFFSET; + } else { + env_new_offset = CONFIG_ENV_OFFSET; + env_offset = CONFIG_ENV_OFFSET_REDUND; + } + offset = env_new_offset; +#else + offset = CONFIG_ENV_OFFSET; +#endif
/* Is the sector larger than the env (i.e. embedded) */ if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { saved_size = CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SIZE; - saved_offset = env_new_offset + CONFIG_ENV_SIZE; + saved_offset = offset + CONFIG_ENV_SIZE; saved_buffer = memalign(ARCH_DMA_MINALIGN, saved_size); if (!saved_buffer) { ret = -ENOMEM; goto done; } - ret = spi_flash_read(env_flash, saved_offset, - saved_size, saved_buffer); + ret = spi_flash_read(env_flash, saved_offset, saved_size, + saved_buffer); if (ret) goto done; } @@ -109,35 +116,39 @@ static int env_sf_save(void) sector = DIV_ROUND_UP(CONFIG_ENV_SIZE, CONFIG_ENV_SECT_SIZE);
puts("Erasing SPI flash..."); - ret = spi_flash_erase(env_flash, env_new_offset, - sector * CONFIG_ENV_SECT_SIZE); + ret = spi_flash_erase(env_flash, offset, + sector * CONFIG_ENV_SECT_SIZE); if (ret) goto done;
puts("Writing to SPI flash...");
- ret = spi_flash_write(env_flash, env_new_offset, - CONFIG_ENV_SIZE, &env_new); + ret = spi_flash_write(env_flash, offset, + CONFIG_ENV_SIZE, &env_new); if (ret) goto done;
if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { - ret = spi_flash_write(env_flash, saved_offset, - saved_size, saved_buffer); + ret = spi_flash_write(env_flash, saved_offset, saved_size, + saved_buffer); if (ret) goto done; }
- ret = spi_flash_write(env_flash, env_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag); - if (ret) - goto done; +#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) + ret = spi_flash_write(env_flash, env_offset + offsetof(env_t, flags), + sizeof(env_new.flags), &flag); + if (ret) + goto done;
- puts("done\n"); + puts("done\n");
- gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND; + gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND;
- printf("Valid environment: %d\n", (int)gd->env_valid); + printf("Valid environment: %d\n", (int)gd->env_valid); +#else + puts("done\n"); +#endif
done: if (saved_buffer) @@ -146,6 +157,7 @@ static int env_sf_save(void) return ret; }
+#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) static int env_sf_load(void) { int ret; @@ -183,66 +195,6 @@ out: return ret; } #else -static int env_sf_save(void) -{ - u32 saved_size, saved_offset, sector; - char *saved_buffer = NULL; - int ret = 1; - env_t env_new; - - ret = setup_flash_device(); - if (ret) - return ret; - - /* Is the sector larger than the env (i.e. embedded) */ - if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { - saved_size = CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SIZE; - saved_offset = CONFIG_ENV_OFFSET + CONFIG_ENV_SIZE; - saved_buffer = malloc(saved_size); - if (!saved_buffer) - goto done; - - ret = spi_flash_read(env_flash, saved_offset, - saved_size, saved_buffer); - if (ret) - goto done; - } - - ret = env_export(&env_new); - if (ret) - goto done; - - sector = DIV_ROUND_UP(CONFIG_ENV_SIZE, CONFIG_ENV_SECT_SIZE); - - puts("Erasing SPI flash..."); - ret = spi_flash_erase(env_flash, CONFIG_ENV_OFFSET, - sector * CONFIG_ENV_SECT_SIZE); - if (ret) - goto done; - - puts("Writing to SPI flash..."); - ret = spi_flash_write(env_flash, CONFIG_ENV_OFFSET, - CONFIG_ENV_SIZE, &env_new); - if (ret) - goto done; - - if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { - ret = spi_flash_write(env_flash, saved_offset, - saved_size, saved_buffer); - if (ret) - goto done; - } - - ret = 0; - puts("done\n"); - - done: - if (saved_buffer) - free(saved_buffer); - - return ret; -} - static int env_sf_load(void) { int ret; @@ -258,8 +210,8 @@ static int env_sf_load(void) if (ret) goto out;
- ret = spi_flash_read(env_flash, - CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, buf); + ret = spi_flash_read(env_flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + buf); if (ret) { env_set_default("spi_flash_read() failed", 0); goto err_read; @@ -292,7 +244,7 @@ static int env_sf_init(void) env_t *env_ptr = (env_t *)env_sf_get_env_addr();
if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { - gd->env_addr = (ulong)&(env_ptr->data); + gd->env_addr = (ulong)&env_ptr->data; gd->env_valid = 1; } else { gd->env_addr = (ulong)&default_environment[0];
Change in v3:
JFYI: No need to re-send this patch with this added RB tag, as I already did send a new RB to the last mail as reply. Patchwork collects these tags when sent to the list. So you only need to include them, if you send a new patch version.
Thanks, Stefan
Change in v2:
} else {
} else {
+#else
saved_buffer = memalign(ARCH_DMA_MINALIGN, saved_size); if (!saved_buffer) { ret = -ENOMEM; goto done; }saved_offset = offset + CONFIG_ENV_SIZE;
if (ret) goto done; }saved_buffer);
if (ret) goto done;
if (ret) goto done;
- if (ret)
goto done;
if (ret)
goto done;
- puts("done\n");
puts("done\n");
+#else
puts("done\n");
- int ret = 1;
- env_t env_new;
- if (ret)
return ret;
if (!saved_buffer)
goto done;
if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
if (ret)
goto done;
- ret = 0;
- puts("done\n");
- done:
- if (saved_buffer)
free(saved_buffer);
- return ret;
- ret = spi_flash_read(env_flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE,
if (ret) { env_set_default("spi_flash_read() failed", 0); goto err_read;buf);
gd->env_valid = 1; } else { gd->env_addr = (ulong)&default_environment[0];gd->env_addr = (ulong)&env_ptr->data;
Viele Grüße, Stefan
thanks for this hint, obviously I step into it all the time ...
Ok, lesson learnt, let's see what I can do wrong next time ... ;-/
Back on topic: I guess that was all I needed to do so that the patch will get merged when its time comes.
If not, please let me know.
Thanks, Harry
Thanks, Stefan
diff --git a/env/sf.c b/env/sf.c index 937778aa37..199114fd3b 100644 --- a/env/sf.c +++ b/env/sf.c @@ -66,13 +66,14 @@ static int setup_flash_device(void) return 0; } -#if defined(CONFIG_ENV_OFFSET_REDUND) static int env_sf_save(void) { env_t env_new; - char *saved_buffer = NULL, flag = ENV_REDUND_OBSOLETE; + char *saved_buffer = NULL; u32 saved_size, saved_offset, sector; + ulong offset; int ret; + __maybe_unused char flag = ENV_REDUND_OBSOLETE; ret = setup_flash_device(); if (ret) @@ -81,27 +82,33 @@ static int env_sf_save(void) ret = env_export(&env_new); if (ret) return -EIO; - env_new.flags = ENV_REDUND_ACTIVE; - if (gd->env_valid == ENV_VALID) { - env_new_offset = CONFIG_ENV_OFFSET_REDUND; - env_offset = CONFIG_ENV_OFFSET; - } else { - env_new_offset = CONFIG_ENV_OFFSET; - env_offset = CONFIG_ENV_OFFSET_REDUND; - } +#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) + env_new.flags = ENV_REDUND_ACTIVE;
+ if (gd->env_valid == ENV_VALID) { + env_new_offset = CONFIG_ENV_OFFSET_REDUND; + env_offset = CONFIG_ENV_OFFSET; + } else { + env_new_offset = CONFIG_ENV_OFFSET; + env_offset = CONFIG_ENV_OFFSET_REDUND; + } + offset = env_new_offset; +#else + offset = CONFIG_ENV_OFFSET; +#endif /* Is the sector larger than the env (i.e. embedded) */ if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { saved_size = CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SIZE; - saved_offset = env_new_offset + CONFIG_ENV_SIZE; + saved_offset = offset + CONFIG_ENV_SIZE; saved_buffer = memalign(ARCH_DMA_MINALIGN, saved_size); if (!saved_buffer) { ret = -ENOMEM; goto done; } - ret = spi_flash_read(env_flash, saved_offset, - saved_size, saved_buffer); + ret = spi_flash_read(env_flash, saved_offset, saved_size, + saved_buffer); if (ret) goto done; } @@ -109,35 +116,39 @@ static int env_sf_save(void) sector = DIV_ROUND_UP(CONFIG_ENV_SIZE, CONFIG_ENV_SECT_SIZE); puts("Erasing SPI flash..."); - ret = spi_flash_erase(env_flash, env_new_offset, - sector * CONFIG_ENV_SECT_SIZE); + ret = spi_flash_erase(env_flash, offset, + sector * CONFIG_ENV_SECT_SIZE); if (ret) goto done; puts("Writing to SPI flash..."); - ret = spi_flash_write(env_flash, env_new_offset, - CONFIG_ENV_SIZE, &env_new); + ret = spi_flash_write(env_flash, offset, + CONFIG_ENV_SIZE, &env_new); if (ret) goto done; if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { - ret = spi_flash_write(env_flash, saved_offset, - saved_size, saved_buffer); + ret = spi_flash_write(env_flash, saved_offset, saved_size, + saved_buffer); if (ret) goto done; } - ret = spi_flash_write(env_flash, env_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag); - if (ret) - goto done; +#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) + ret = spi_flash_write(env_flash, env_offset + offsetof(env_t, flags), + sizeof(env_new.flags), &flag); + if (ret) + goto done; - puts("done\n"); + puts("done\n"); - gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND; + gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND; - printf("Valid environment: %d\n", (int)gd->env_valid); + printf("Valid environment: %d\n", (int)gd->env_valid); +#else + puts("done\n"); +#endif done: if (saved_buffer) @@ -146,6 +157,7 @@ static int env_sf_save(void) return ret; } +#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) static int env_sf_load(void) { int ret; @@ -183,66 +195,6 @@ out: return ret; } #else -static int env_sf_save(void) -{ - u32 saved_size, saved_offset, sector; - char *saved_buffer = NULL; - int ret = 1; - env_t env_new;
- done:
- return ret; -}
static int env_sf_load(void) { int ret; @@ -258,8 +210,8 @@ static int env_sf_load(void) if (ret) goto out; - ret = spi_flash_read(env_flash, - CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, buf); + ret = spi_flash_read(env_flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, + buf); if (ret) { env_set_default("spi_flash_read() failed", 0); goto err_read; @@ -292,7 +244,7 @@ static int env_sf_init(void) env_t *env_ptr = (env_t *)env_sf_get_env_addr(); if (crc32(0, env_ptr->data, ENV_SIZE) == env_ptr->crc) { - gd->env_addr = (ulong)&(env_ptr->data); + gd->env_addr = (ulong)&env_ptr->data; gd->env_valid = 1; } else { gd->env_addr = (ulong)&default_environment[0];
Viele Grüße, Stefan
Yes, now we (you) need a bit of patience, so that other people might review this patch as well. And usually it will get handled after some time (depending on the development stage of U-Boot, merge window open or shortly before release etc).
It does not hurt of course to check this from time to time and "trigger" the maintainer of the subsystem or the custodian this patch is delegated to nothing is happening here for a too long time (like more than 1 month).
Thanks, Stefan
Thanks, Harry
Thanks, Stefan
- done:
- return ret; -}
Viele Grüße, Stefan
Viele Grüße, Stefan
Ok, no problem with that.
That also means that I should wait with submission of the other patch (adding "env erase" support) until this one is merged. Otherwise the patch would need to be significantly different ...
Hmm, I guess it would have been better to not send that patch standalone but instead as a first one in a two-patch series where the second one adds the new functionality on top of the clean-up. Anyway, something to keep in mind for next time :-)
Alright, good to know :-)
Thanks, Harry
Thanks, Stefan
Thanks, Harry
Thanks, Stefan
- done:
- return ret; -}
Viele Grüße, Stefan
Viele Grüße, Stefan
No, you don't have to wait. This would be counter-productive. Please just add the dependancy to this patch in the commit text of the new one to make this clear. Best would be below the "---" line so that it will not be included in the git history.
Yep, that would have been even better. ;)
Thanks, Stefan
Thanks, Harry
Thanks, Stefan
Thanks, Harry
Thanks, Stefan
- done:
- return ret; -}
Viele Grüße, Stefan
Viele Grüße, Stefan
Viele Grüße, Stefan
Hi again,
gentle ping for that patch, also in view of subsequently sent patch ...
https://lists.denx.de/pipermail/u-boot/2021-February/439797.html
... which saw a competing patch by Patrick Delaunay a week later:
https://lists.denx.de/pipermail/u-boot/2021-February/440769.html
However, the latter doesn't seem to take embedded environments into account.
Best regards, Harry
Change in v3:
Change in v2:
} else {
} else {
+#else
if (ret) goto done;
if (ret) goto done;
- if (ret)
goto done;
if (ret)
goto done;
- puts("done\n");
puts("done\n");
+#else
puts("done\n");
- int ret = 1;
- env_t env_new;
- if (ret)
return ret;
if (!saved_buffer)
goto done;
if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
if (ret)
goto done;
- ret = 0;
- puts("done\n");
- done:
- if (saved_buffer)
free(saved_buffer);
- return ret;
On 3/1/21 11:39 AM, Harry Waschkeit wrote:
Hi again,
Can you give an example of where your patch would work while Patrick's wouldn't?
Thanks.
--Sean
Best regards, Harry
Change in v3:
Change in v2:
- char *saved_buffer = NULL; u32 saved_size, saved_offset, sector;
- ulong offset; int ret;
- __maybe_unused char flag = ENV_REDUND_OBSOLETE; ret = setup_flash_device(); if (ret)
- } else {
} else {
+#else
- ret = spi_flash_erase(env_flash, offset,
- ret = spi_flash_write(env_flash, offset,
- if (ret)
goto done;
if (ret)
goto done;
- puts("done\n");
puts("done\n");
+#else
puts("done\n");
- int ret = 1;
- env_t env_new;
- if (ret)
return ret;
if (!saved_buffer)
goto done;
if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
if (ret)
goto done;
- ret = 0;
- puts("done\n");
- done:
- if (saved_buffer)
free(saved_buffer);
- return ret;
Hello Sean,
Hi again,
I didn't dig too deep into Patrick's patch and maybe I simply miss something important, but I don't even see an spi_flash_erase() in his code, so I'm wondering how it could work at all.
What I do see in his code is spi_flash_write() with a CONFIG_ENV_SIZE worth of zeroes to the environment environment offset, but this can only work for an erased flash as far as I know.
And erasing the flash part where the environment is stored should take an environment sizes below sector size into account; the rest of the environment sector could be used otherwise, i.e. CONFIG_ENV_SIZE < CONFIG_ENV_SECT_SIZE.
Function env_sf_save() takes care of all of that, so does the env_sf_erase() in my patch, Patrick's version of env_sf_erase() does not.
(side note: using more than a flash sector for environment and sharing the last one with different data isn't handled at all at the moment, probably because it was never needed)
Best regards, Harry
Thanks.
--Sean
Best regards, Harry
- done:
- return ret; -}
On 3/2/21 1:09 PM, Harry Waschkeit wrote:
Hello Sean,
Hi again,
Writing to SPI flash can only set bits to 0. To set bits to 1 you must erase them. Conceptually, write(buf) does
flash[i] &= buf[i];
And erase() does
flash[i] = -1;
So writing 0s always succeeds, and we are certain to invalidate the environment (as long as our hash has a non-zero value for an all-zero input).
env_sf_save always erases the environment before flashing. So your patch effectively erases env twice before writing to it.
Right, but typically we have a write granularity of one byte for SPI flashes. So you can clear only the environment, and let enf_sf_save deal with other data in the sector.
--Sean
Best regards, Harry
Thanks.
--Sean
Best regards, Harry
Change in v3:
Change in v2:
- } else {
} else {
+#else
- if (ret)
goto done;
if (ret)
goto done;
- puts("done\n");
puts("done\n");
+#else
puts("done\n");
- int ret = 1;
- env_t env_new;
- if (ret)
return ret;
if (!saved_buffer)
goto done;
if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
- if (ret)
goto done;
if (ret)
goto done;
- ret = 0;
- puts("done\n");
- done:
- if (saved_buffer)
free(saved_buffer);
- return ret;
Hello Sean,
Hi again,
flash[i] &= buf[i];
And erase() does
flash[i] = -1;
Sure.
So it's only the name that is confusing because there's no erase happening at all in env_sf_erase(), a real flash erase is necessary afterwards if you want to write data to environment space. I think it would be worth a comment in the function then, maybe also others get confused what a function called something with erase actually does with flash data ;-)
Yeah, you're right, it was made under the false assumption that the erase function actually should erase something ... ;-/
Correct.
So my patches are actually worthless ... interesting that Patrick came up with his patches only right after my attempts to add that functionality, but not discussing my approach.
I'd loved to make a small contribution to U-Boot, maybe I've more luck next time ... ;-)
Best regards, Harry
--Sean
Best regards, Harry
Thanks.
--Sean
Best regards, Harry
+ if (gd->env_valid == ENV_VALID) { + env_new_offset = CONFIG_ENV_OFFSET_REDUND; + env_offset = CONFIG_ENV_OFFSET; + } else { + env_new_offset = CONFIG_ENV_OFFSET; + env_offset = CONFIG_ENV_OFFSET_REDUND; + } + offset = env_new_offset; +#else + offset = CONFIG_ENV_OFFSET; +#endif /* Is the sector larger than the env (i.e. embedded) */ if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { saved_size =CONFIG_ENV_SECT_SIZE - CONFIG_ENV_SIZE; - saved_offset = env_new_offset + CONFIG_ENV_SIZE; + saved_offset = offset +CONFIG_ENV_SIZE; saved_buffer = memalign(ARCH_DMA_MINALIGN, saved_size); if (!saved_buffer) { ret = -ENOMEM; goto done; } - ret = spi_flash_read(env_flash, saved_offset, - saved_size, saved_buffer); + ret = spi_flash_read(env_flash, saved_offset, saved_size, + saved_buffer); if (ret) goto done; } @@ -109,35 +116,39 @@ static int env_sf_save(void) sector = DIV_ROUND_UP(CONFIG_ENV_SIZE, CONFIG_ENV_SECT_SIZE); puts("Erasing SPI flash..."); - ret = spi_flash_erase(env_flash, env_new_offset, - sector * CONFIG_ENV_SECT_SIZE); + ret = spi_flash_erase(env_flash, offset, + sector * CONFIG_ENV_SECT_SIZE); if (ret) goto done; puts("Writing to SPI flash..."); - ret = spi_flash_write(env_flash, env_new_offset, - CONFIG_ENV_SIZE, &env_new); + ret = spi_flash_write(env_flash, offset, + CONFIG_ENV_SIZE, &env_new); if (ret) goto done; if (CONFIG_ENV_SECT_SIZE > CONFIG_ENV_SIZE) { - ret = spi_flash_write(env_flash, saved_offset, - saved_size, saved_buffer); + ret = spi_flash_write(env_flash, saved_offset, saved_size, + saved_buffer); if (ret) goto done; } - ret = spi_flash_write(env_flash, env_offset + offsetof(env_t, flags), - sizeof(env_new.flags), &flag); - if (ret) - goto done; +#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) + ret = spi_flash_write(env_flash, env_offset + offsetof(env_t, flags), + sizeof(env_new.flags), &flag); + if (ret) + goto done; - puts("done\n"); + puts("done\n"); - gd->env_valid = gd->env_valid == ENV_REDUND? ENV_VALID : ENV_REDUND; + gd->env_valid = gd->env_valid == ENV_REDUND ? ENV_VALID : ENV_REDUND; - printf("Valid environment: %d\n", (int)gd->env_valid); + printf("Valid environment: %d\n", (int)gd->env_valid); +#else + puts("done\n"); +#endif done: if (saved_buffer) @@ -146,6 +157,7 @@ static int env_sf_save(void) return ret; } +#if CONFIG_IS_ENABLED(SYS_REDUNDAND_ENVIRONMENT) static int env_sf_load(void) { int ret; @@ -183,66 +195,6 @@ out: return ret; } #else -static int env_sf_save(void) -{ - u32 saved_size, saved_offset, sector; - char *saved_buffer = NULL; - int ret = 1; - env_t env_new;
- done:
- return ret; -}
Harry Waschkeit
Harry Waschkeit
Sean Anderson
Stefan Roese
