[U-Boot-Users] [PATCH] PPC4xx: Memory Queue Optimizations for PPC460EX/GT
Set PL44 Arbiter Read pipeline depth to 4 Optimize Memory Queue Configuration registers for PPC460EX/GT
Signed-off-by: Prodyut Hazarika phazarika@amcc.com --- board/amcc/canyonlands/canyonlands.c | 9 +++ cpu/ppc4xx/44x_spd_ddr2.c | 4 + include/ppc440.h | 101 ++++++++++++++++++---------------- 3 files changed, 66 insertions(+), 48 deletions(-)
diff --git a/board/amcc/canyonlands/canyonlands.c b/board/amcc/canyonlands/canyonlands.c index e9eba49..dd285bc 100644 --- a/board/amcc/canyonlands/canyonlands.c +++ b/board/amcc/canyonlands/canyonlands.c @@ -113,6 +113,15 @@ int board_early_init_f(void) mtdcr(AHB_TOP, 0x8000004B); mtdcr(AHB_BOT, 0x8000004B);
+ mtdcr(plb0_acr, plb0_acr_ppm_fair | + plb0_acr_hbu_enabled | + plb0_acr_rdp_4deep | + plb0_acr_wrp_2deep); + mtdcr(plb1_acr, plb1_acr_ppm_fair | + plb1_acr_hbu_enabled | + plb1_acr_rdp_4deep | + plb1_acr_wrp_2deep); + if ((pvr == PVR_460EX_RA) || (pvr == PVR_460EX_SE_RA)) { /* * Configure USB-STP pins as alternate and not GPIO diff --git a/cpu/ppc4xx/44x_spd_ddr2.c b/cpu/ppc4xx/44x_spd_ddr2.c index e9940e8..c222507 100644 --- a/cpu/ppc4xx/44x_spd_ddr2.c +++ b/cpu/ppc4xx/44x_spd_ddr2.c @@ -2251,6 +2251,10 @@ static void program_memory_queue(unsigned long *dimm_populated, */ mtdcr(SDRAM_PLBADDULL, 0x00000000); /* MQ0_BAUL */ mtdcr(SDRAM_PLBADDUHB, 0x00000008); /* MQ0_BAUH */ + + mtdcr(SDRAM_CONF1HB, 0x80001c80); + mtdcr(SDRAM_CONF1LL, 0x80001c80); + mtdcr(SDRAM_CONFPATHB, 0x18a68000); #endif }
diff --git a/include/ppc440.h b/include/ppc440.h index c581f1b..650ee4f 100644 --- a/include/ppc440.h +++ b/include/ppc440.h @@ -422,53 +422,6 @@
#define PLB4_ACR_WRP (0x80000000 >> 7)
-/* Nebula PLB4 Arbiter - PowerPC440EP */ -#define PLB_ARBITER_BASE 0x80 - -#define plb0_revid (PLB_ARBITER_BASE+ 0x00) -#define plb0_acr (PLB_ARBITER_BASE+ 0x01) -#define plb0_acr_ppm_mask 0xF0000000 -#define plb0_acr_ppm_fixed 0x00000000 -#define plb0_acr_ppm_fair 0xD0000000 -#define plb0_acr_hbu_mask 0x08000000 -#define plb0_acr_hbu_disabled 0x00000000 -#define plb0_acr_hbu_enabled 0x08000000 -#define plb0_acr_rdp_mask 0x06000000 -#define plb0_acr_rdp_disabled 0x00000000 -#define plb0_acr_rdp_2deep 0x02000000 -#define plb0_acr_rdp_3deep 0x04000000 -#define plb0_acr_rdp_4deep 0x06000000 -#define plb0_acr_wrp_mask 0x01000000 -#define plb0_acr_wrp_disabled 0x00000000 -#define plb0_acr_wrp_2deep 0x01000000 - -#define plb0_besrl (PLB_ARBITER_BASE+ 0x02) -#define plb0_besrh (PLB_ARBITER_BASE+ 0x03) -#define plb0_bearl (PLB_ARBITER_BASE+ 0x04) -#define plb0_bearh (PLB_ARBITER_BASE+ 0x05) -#define plb0_ccr (PLB_ARBITER_BASE+ 0x08) - -#define plb1_acr (PLB_ARBITER_BASE+ 0x09) -#define plb1_acr_ppm_mask 0xF0000000 -#define plb1_acr_ppm_fixed 0x00000000 -#define plb1_acr_ppm_fair 0xD0000000 -#define plb1_acr_hbu_mask 0x08000000 -#define plb1_acr_hbu_disabled 0x00000000 -#define plb1_acr_hbu_enabled 0x08000000 -#define plb1_acr_rdp_mask 0x06000000 -#define plb1_acr_rdp_disabled 0x00000000 -#define plb1_acr_rdp_2deep 0x02000000 -#define plb1_acr_rdp_3deep 0x04000000 -#define plb1_acr_rdp_4deep 0x06000000 -#define plb1_acr_wrp_mask 0x01000000 -#define plb1_acr_wrp_disabled 0x00000000 -#define plb1_acr_wrp_2deep 0x01000000 - -#define plb1_besrl (PLB_ARBITER_BASE+ 0x0A) -#define plb1_besrh (PLB_ARBITER_BASE+ 0x0B) -#define plb1_bearl (PLB_ARBITER_BASE+ 0x0C) -#define plb1_bearh (PLB_ARBITER_BASE+ 0x0D) - /* Pin Function Control Register 1 */ #define SDR0_PFC1 0x4101 #define SDR0_PFC1_U1ME_MASK 0x02000000 /* UART1 Mode Enable */ @@ -742,7 +695,59 @@ #define SDR0_PFC1_PLB_PME_PLB4_SEL 0x00001000 /* PLB3 Performance Monitor Enable */ #define SDR0_PFC1_GFGGI_MASK 0x0000000F /* GPT Frequency Generation Gated In */
-#endif /* 440EP || 440GR || 440EPX || 440GRX */ +#endif /* 440EP || 440GR || 440EPX || 440GRX */ + +#if defined(CONFIG_440EP) || defined(CONFIG_440GR) || \ + defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \ + defined(CONFIG_460EX) || defined(CONFIG_460GT) + +#define PLB_ARBITER_BASE 0x80 + +#define plb0_revid (PLB_ARBITER_BASE+ 0x00) +#define plb0_acr (PLB_ARBITER_BASE+ 0x01) +#define plb0_acr_ppm_mask 0xF0000000 +#define plb0_acr_ppm_fixed 0x00000000 +#define plb0_acr_ppm_fair 0xD0000000 +#define plb0_acr_hbu_mask 0x08000000 +#define plb0_acr_hbu_disabled 0x00000000 +#define plb0_acr_hbu_enabled 0x08000000 +#define plb0_acr_rdp_mask 0x06000000 +#define plb0_acr_rdp_disabled 0x00000000 +#define plb0_acr_rdp_2deep 0x02000000 +#define plb0_acr_rdp_3deep 0x04000000 +#define plb0_acr_rdp_4deep 0x06000000 +#define plb0_acr_wrp_mask 0x01000000 +#define plb0_acr_wrp_disabled 0x00000000 +#define plb0_acr_wrp_2deep 0x01000000 + +#define plb0_besrl (PLB_ARBITER_BASE+ 0x02) +#define plb0_besrh (PLB_ARBITER_BASE+ 0x03) +#define plb0_bearl (PLB_ARBITER_BASE+ 0x04) +#define plb0_bearh (PLB_ARBITER_BASE+ 0x05) +#define plb0_ccr (PLB_ARBITER_BASE+ 0x08) + +#define plb1_acr (PLB_ARBITER_BASE+ 0x09) +#define plb1_acr_ppm_mask 0xF0000000 +#define plb1_acr_ppm_fixed 0x00000000 +#define plb1_acr_ppm_fair 0xD0000000 +#define plb1_acr_hbu_mask 0x08000000 +#define plb1_acr_hbu_disabled 0x00000000 +#define plb1_acr_hbu_enabled 0x08000000 +#define plb1_acr_rdp_mask 0x06000000 +#define plb1_acr_rdp_disabled 0x00000000 +#define plb1_acr_rdp_2deep 0x02000000 +#define plb1_acr_rdp_3deep 0x04000000 +#define plb1_acr_rdp_4deep 0x06000000 +#define plb1_acr_wrp_mask 0x01000000 +#define plb1_acr_wrp_disabled 0x00000000 +#define plb1_acr_wrp_2deep 0x01000000 + +#define plb1_besrl (PLB_ARBITER_BASE+ 0x0A) +#define plb1_besrh (PLB_ARBITER_BASE+ 0x0B) +#define plb1_bearl (PLB_ARBITER_BASE+ 0x0C) +#define plb1_bearh (PLB_ARBITER_BASE+ 0x0D) + +#endif /* 440EP || 440GR || 440EPX || 440GR || 460EX || 460GT */
/*----------------------------------------------------------------------------- | L2 Cache
Thanks. Please find some comments below.
- mtdcr(plb0_acr, plb0_acr_ppm_fair |
- mtdcr(plb1_acr, plb1_acr_ppm_fair |
Is this PLB0_ACR tuning Canyonlands specific? Or will all 460EX/GT boards profit from this configuration? Or even other 4xx PPC variants as well?
If this is the case then I suggest to move this code to a common place, perhaps in cpu_init_f(). What do you think?
- mtdcr(SDRAM_CONF1HB, 0x80001c80);
- mtdcr(SDRAM_CONF1LL, 0x80001c80);
- mtdcr(SDRAM_CONFPATHB, 0x18a68000);
Could you please add a comment what exactly is configured with these "magic numbers"?
#endif }
- defined(CONFIG_440EPX) || defined(CONFIG_440GRX) || \
- defined(CONFIG_460EX) || defined(CONFIG_460GT)
Are the PLBx_ACR register really identical on all those PPC's? Just checking.
Please fix if necessary and resubmit. And please keep me on CC on 4xx related patches.
Thanks.
Best regards, Stefan
Thanks Stefan for your comments. Please see reply below.
The PLB Arbiter register configuration are definitely common to PPC460EX/GT boards. I am working with PowerPC hardware architects to find out whether we can put the same changes for other PPC4xx variants
I will add C defines corresponding to those register bits and resubmit
They seem to be so. I will double-check the user manuals for all these processors.
I will try to put out the modified patch latest by tommorow.
Best Regards, Prodyut Hazarika
================================ Staff S/W Engineer AMCC ================================
Prodyut Hazarika
Stefan Roese
