[U-Boot] [PATCH v3 0/4] mpc8313: ids8313 board updates
- introduce CONFIG_IMAGE_FORMAT_LEGACY for enabling booting legacy image format. Disable this per default if CONFIG_FIT_SIGNATURE is defined. As the ids8313 board needs legacy image format and uses CONFIG_FIT_SIGNATURE, enable legacy image format for the ids8313 board
- add CONFIG_SYS_GENERIC_BOARD to the ids8313 board, therefore fdtdec_get_int() is moved out of lib/fdtdec.c as lib/fdtdec.c is only compiled if CONFIG_OF_CONTROL is defined, but defining this for the ids8313 board leads in conjunction with CONFIG_SYS_GENERIC_BOARD in booting error:
No valid FDT found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d <file.dtb>
So move the common used function fdtdec_get_int() out of lib/fdtdec.c into lib/fdtdec_common.c
Cc: Simon Glass sjg@chromium.org Cc: Kim Phillips kim.phillips@freescale.com Cc: Wolfgang Denk wd@denx.de Cc: Tom Rini trini@ti.com Cc: Michael Conrad Michael.Conrad@ids.de
Tested this patchset on the ids8313 board, MAKEALL for powerpc and arm adds no compiler errors/warnings.
While testing this patchset on the ids8313 board, I found, that current U-Boot compiles fine with eldk 5.5, but if erasing the sectors where U-Boot resists in the NOR flash, u-boot commands are not longer working :-(
$ powerpc-linux-gcc -v Using built-in specs. COLLECT_GCC=powerpc-linux-gcc COLLECT_LTO_WRAPPER=/opt/eldk-5.5/powerpc/sysroots/i686-eldk-linux/usr/libexec/powerpc-linux/gcc/powerpc-linux/4.8.1/lto-wrapper Target: powerpc-linux [...] Thread model: posix gcc version 4.8.1 (GCC) $
This problem does not pop up with eldk 5.4 or 5.3 !
Digged a little bit in it, and found that some (not all!) fmt strings are loaded from flash addresses not from ram addresses ...
gdb shows: Program received signal SIGTRAP, Trace/breakpoint trap. printf (fmt=0xfff5ad34 '\377' <repeats 200 times>..., fmt@entry=0x7fdad34 "parse_stream, end_trigger=%d\n") at /home/hs/ids/u-boot/common/console.c:479 ^^^^^^^^^^ addr in nor flash not in ram 479 { (gdb) bt #0 printf (fmt=0xfff5ad34 '\377' <repeats 200 times>..., fmt@entry=0x7fdad34 "parse_stream, end_trigger=%d\n") at /home/hs/ids/u-boot/common/console.c:479 #1 0x07f88c4c in parse_stream (end_trigger=10, input=0x775fe00, ctx=0x775fd60, dest=0x775fd7c) at /home/hs/ids/u-boot/common/hush.c:2942
this leads, if flash is erased, in a crash ... try to find out more ...
This problem seems a toolchain problem, as I tried older U-Boot versions with eldk 5.5 on this board, and all versions break ... I have no other mpc83xx board handy ... can somebody try this scenario on a mpc83xx based board? Kim?
Current U-Boot does work fine on a mpc52xx based board compiled with eldk 5.5, so it seems a mpc83xx specific problem?
Heiko Schocher (4): bootm: make use of legacy image format configurable mpc8313, signed fit: enable legacy image format on ids8313 board lib, fdt: move fdtdec_get_int() out of lib/fdtdec.c mpc8313: add CONFIG_SYS_GENERIC_BOARD to ids8313 board
README | 18 ++++++++++++++++++ common/cmd_bootm.c | 14 ++++++++++++++ common/cmd_disk.c | 4 ++++ common/cmd_fdc.c | 4 ++++ common/cmd_fpga.c | 2 ++ common/cmd_nand.c | 4 ++++ common/cmd_source.c | 4 ++++ common/cmd_ximg.c | 7 ++++++- common/image-fdt.c | 10 ++++++++-- common/image.c | 23 ++++++++++++++++------- doc/uImage.FIT/signature.txt | 3 +++ include/config_defaults.h | 8 ++++++++ include/configs/ids8313.h | 4 +++- include/configs/zynq-common.h | 1 + include/image.h | 2 ++ lib/Makefile | 1 + lib/fdtdec.c | 36 ------------------------------------ lib/fdtdec_common.c | 33 +++++++++++++++++++++++++++++++++ tools/fdtdec.c | 1 + 19 files changed, 132 insertions(+), 47 deletions(-) create mode 100644 lib/fdtdec_common.c
make the use of legacy image format configurable through the config define CONFIG_IMAGE_FORMAT_LEGACY.
When relying on signed FIT images with required signature check the legacy image format should be disabled. Therefore introduce this new define and enable legacy image format if CONFIG_FIT_SIGNATURE is not set. If CONFIG_FIT_SIGNATURE is set disable per default the legacy image format.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Simon Glass sjg@chromium.org Cc: Lars Steubesand lars.steubesand@philips.com Cc: Mike Pearce mike@kaew.be Cc: Wolfgang Denk wd@denx.de Cc: Tom Rini trini@ti.com Cc: Michal Simek monstr@monstr.eu
--- - changes for v2: - make the legacy image format configurable through the define CONFIG_IMAGE_FORMAT_LEGACY.
Default: if not CONFIG_FIT_SIGNATURE is defined it is enabled, else disabled.
Disable it with CONFIG_DISABLE_IMAGE_LEGACY if CONFIG_FIT_SIGNATURE is not defined. - changes for v3: - enable legacy image format for zync as default, as Michak suggested. --- README | 18 ++++++++++++++++++ common/cmd_bootm.c | 14 ++++++++++++++ common/cmd_disk.c | 4 ++++ common/cmd_fdc.c | 4 ++++ common/cmd_fpga.c | 2 ++ common/cmd_nand.c | 4 ++++ common/cmd_source.c | 4 ++++ common/cmd_ximg.c | 7 ++++++- common/image-fdt.c | 10 ++++++++-- common/image.c | 23 ++++++++++++++++------- doc/uImage.FIT/signature.txt | 3 +++ include/config_defaults.h | 8 ++++++++ include/configs/zynq-common.h | 1 + include/image.h | 2 ++ 14 files changed, 94 insertions(+), 10 deletions(-)
diff --git a/README b/README index ace7091..795486d 100644 --- a/README +++ b/README @@ -3157,6 +3157,19 @@ FIT uImage format: -150 common/cmd_nand.c Incorrect FIT image format 151 common/cmd_nand.c FIT image format OK
+- legacy image format: + CONFIG_IMAGE_FORMAT_LEGACY + enables the legacy image format support in U-Boot. + + Default: + enabled if CONFIG_FIT_SIGNATURE is not defined. + + CONFIG_DISABLE_IMAGE_LEGACY + disable the legacy image format + + This define is introduced, as the legacy image format is + enabled per default for backward compatibility. + - FIT image support: CONFIG_FIT Enable support for the FIT uImage format. @@ -3173,6 +3186,11 @@ FIT uImage format: using a hash signed and verified using RSA. See doc/uImage.FIT/signature.txt for more details.
+ WARNING: When relying on signed FIT images with required + signature check the legacy image format is default + disabled. If a board need legacy image format support + enable this through CONFIG_IMAGE_FORMAT_LEGACY + - Standalone program support: CONFIG_STANDALONE_LOAD_ADDR
diff --git a/common/cmd_bootm.c b/common/cmd_bootm.c index e683af3..21d0234 100644 --- a/common/cmd_bootm.c +++ b/common/cmd_bootm.c @@ -233,6 +233,7 @@ static int bootm_find_os(cmd_tbl_t *cmdtp, int flag, int argc,
/* get image parameters */ switch (genimg_get_format(os_hdr)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: images.os.type = image_get_type(os_hdr); images.os.comp = image_get_comp(os_hdr); @@ -241,6 +242,7 @@ static int bootm_find_os(cmd_tbl_t *cmdtp, int flag, int argc, images.os.end = image_get_image_end(os_hdr); images.os.load = image_get_load(os_hdr); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: if (fit_image_get_type(images.fit_hdr_os, @@ -838,6 +840,7 @@ int bootm_maybe_autostart(cmd_tbl_t *cmdtp, const char *cmd) return 0; }
+#if defined(CONFIG_IMAGE_FORMAT_LEGACY) /** * image_get_kernel - verify legacy format kernel image * @img_addr: in RAM address of the legacy format image to be verified @@ -888,6 +891,7 @@ static image_header_t *image_get_kernel(ulong img_addr, int verify) } return hdr; } +#endif
/** * boot_get_kernel - find kernel image @@ -905,7 +909,9 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], bootm_headers_t *images, ulong *os_data, ulong *os_len) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) image_header_t *hdr; +#endif ulong img_addr; const void *buf; #if defined(CONFIG_FIT) @@ -943,6 +949,7 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, *os_data = *os_len = 0; buf = map_sysmem(img_addr, 0); switch (genimg_get_format(buf)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: printf("## Booting kernel from Legacy Image at %08lx ...\n", img_addr); @@ -985,6 +992,7 @@ static const void *boot_get_kernel(cmd_tbl_t *cmdtp, int flag, int argc, images->legacy_hdr_valid = 1; bootstage_mark(BOOTSTAGE_ID_DECOMP_IMAGE); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: os_noffset = fit_image_load(images, FIT_KERNEL_PROP, @@ -1114,6 +1122,7 @@ static int image_info(ulong addr) printf("\n## Checking Image at %08lx ...\n", addr);
switch (genimg_get_format(hdr)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: puts(" Legacy image found\n"); if (!image_check_magic(hdr)) { @@ -1135,6 +1144,7 @@ static int image_info(ulong addr) } puts("OK\n"); return 0; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: puts(" FIT image found\n"); @@ -1194,6 +1204,7 @@ static int do_imls_nor(void) goto next_sector;
switch (genimg_get_format(hdr)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: if (!image_check_hcrc(hdr)) goto next_sector; @@ -1208,6 +1219,7 @@ static int do_imls_nor(void) puts("OK\n"); } break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: if (!fit_check_format(hdr)) @@ -1342,12 +1354,14 @@ static int do_imls_nand(void) }
switch (genimg_get_format(buffer)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: header = (const image_header_t *)buffer;
len = image_get_image_size(header); nand_imls_legacyimage(nand, nand_dev, off, len); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: len = fit_get_size(buffer); diff --git a/common/cmd_disk.c b/common/cmd_disk.c index 3e457f6..8a1fda9 100644 --- a/common/cmd_disk.c +++ b/common/cmd_disk.c @@ -17,7 +17,9 @@ int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc, ulong addr = CONFIG_SYS_LOAD_ADDR; ulong cnt; disk_partition_t info; +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) image_header_t *hdr; +#endif block_dev_desc_t *dev_desc;
#if defined(CONFIG_FIT) @@ -62,6 +64,7 @@ int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc, bootstage_mark(BOOTSTAGE_ID_IDE_PART_READ);
switch (genimg_get_format((void *) addr)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: hdr = (image_header_t *) addr;
@@ -78,6 +81,7 @@ int common_diskboot(cmd_tbl_t *cmdtp, const char *intf, int argc,
cnt = image_get_image_size(hdr); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: fit_hdr = (const void *) addr; diff --git a/common/cmd_fdc.c b/common/cmd_fdc.c index 1cfb656..5766b56 100644 --- a/common/cmd_fdc.c +++ b/common/cmd_fdc.c @@ -635,7 +635,9 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) FD_GEO_STRUCT *pFG = (FD_GEO_STRUCT *)floppy_type; FDC_COMMAND_STRUCT *pCMD = &cmd; unsigned long addr,imsize; +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) image_header_t *hdr; /* used for fdc boot */ +#endif unsigned char boot_drive; int i,nrofblk; #if defined(CONFIG_FIT) @@ -689,12 +691,14 @@ int do_fdcboot (cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) }
switch (genimg_get_format ((void *)addr)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: hdr = (image_header_t *)addr; image_print_contents (hdr);
imsize = image_get_image_size (hdr); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: fit_hdr = (const void *)addr; diff --git a/common/cmd_fpga.c b/common/cmd_fpga.c index 010cd24..f8c5e10 100644 --- a/common/cmd_fpga.c +++ b/common/cmd_fpga.c @@ -155,6 +155,7 @@ int do_fpga(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[])
case FPGA_LOADMK: switch (genimg_get_format(fpga_data)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: { image_header_t *hdr = @@ -182,6 +183,7 @@ int do_fpga(cmd_tbl_t *cmdtp, int flag, int argc, char *const argv[]) rc = fpga_load(dev, (void *)data, data_size); } break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: { diff --git a/common/cmd_nand.c b/common/cmd_nand.c index 04ab0f1..5c3ad12 100644 --- a/common/cmd_nand.c +++ b/common/cmd_nand.c @@ -904,7 +904,9 @@ static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand, int r; char *s; size_t cnt; +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) image_header_t *hdr; +#endif #if defined(CONFIG_FIT) const void *fit_hdr = NULL; #endif @@ -930,6 +932,7 @@ static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand, bootstage_mark(BOOTSTAGE_ID_NAND_HDR_READ);
@@ -938,6 +941,7 @@ static int nand_load_image(cmd_tbl_t *cmdtp, nand_info_t *nand,
cnt = image_get_image_size (hdr); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: fit_hdr = (const void *)addr; diff --git a/common/cmd_source.c b/common/cmd_source.c index 54ffd16..f3e9e60 100644 --- a/common/cmd_source.c +++ b/common/cmd_source.c @@ -29,7 +29,9 @@ int source (ulong addr, const char *fit_uname) { ulong len; +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) const image_header_t *hdr; +#endif ulong *data; int verify; void *buf; @@ -44,6 +46,7 @@ source (ulong addr, const char *fit_uname)
buf = map_sysmem(addr, 0); switch (genimg_get_format(buf)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: hdr = buf;
@@ -84,6 +87,7 @@ source (ulong addr, const char *fit_uname) */ while (*data++); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: if (fit_uname == NULL) { diff --git a/common/cmd_ximg.c b/common/cmd_ximg.c index 65a8319..813543a 100644 --- a/common/cmd_ximg.c +++ b/common/cmd_ximg.c @@ -32,10 +32,13 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) { ulong addr = load_addr; ulong dest = 0; - ulong data, len, count; + ulong data, len; int verify; int part = 0; +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) + ulong count; image_header_t *hdr = NULL; +#endif #if defined(CONFIG_FIT) const char *uname = NULL; const void* fit_hdr; @@ -64,6 +67,7 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[]) }
switch (genimg_get_format((void *)addr)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY:
printf("## Copying part %d from legacy image " @@ -114,6 +118,7 @@ do_imgextract(cmd_tbl_t * cmdtp, int flag, int argc, char * const argv[])
image_multi_getimg(hdr, part, &data, &len); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: if (uname == NULL) { diff --git a/common/image-fdt.c b/common/image-fdt.c index 5d64009..ac4563f 100644 --- a/common/image-fdt.c +++ b/common/image-fdt.c @@ -29,6 +29,7 @@ static void fdt_error(const char *msg) puts(" - must RESET the board to recover.\n"); }
+#if defined(CONFIG_IMAGE_FORMAT_LEGACY) static const image_header_t *image_get_fdt(ulong fdt_addr) { const image_header_t *fdt_hdr = map_sysmem(fdt_addr, 0); @@ -61,6 +62,7 @@ static const image_header_t *image_get_fdt(ulong fdt_addr) } return fdt_hdr; } +#endif
/** * boot_fdt_add_mem_rsv_regions - Mark the memreserve sections as unusable @@ -220,11 +222,13 @@ error: int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, bootm_headers_t *images, char **of_flat_tree, ulong *of_size) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) const image_header_t *fdt_hdr; + ulong load, load_end; + ulong image_start, image_data, image_end; +#endif ulong fdt_addr; char *fdt_blob = NULL; - ulong image_start, image_data, image_end; - ulong load, load_end; void *buf; #if defined(CONFIG_FIT) const char *fit_uname_config = images->fit_uname_cfg; @@ -298,6 +302,7 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch, */ buf = map_sysmem(fdt_addr, 0); switch (genimg_get_format(buf)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: /* verify fdt_addr points to a valid image header */ printf("## Flattened Device Tree from Legacy Image at %08lx\n", @@ -337,6 +342,7 @@ int boot_get_fdt(int flag, int argc, char * const argv[], uint8_t arch,
fdt_addr = load; break; +#endif case IMAGE_FORMAT_FIT: /* * This case will catch both: new uImage format diff --git a/common/image.c b/common/image.c index fcc5a9c..79dafdf 100644 --- a/common/image.c +++ b/common/image.c @@ -44,8 +44,10 @@ extern int do_bdinfo(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]);
DECLARE_GLOBAL_DATA_PTR;
+#if defined(CONFIG_IMAGE_FORMAT_LEGACY) static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch, int verify); +#endif #else #include "mkimage.h" #include <u-boot/md5.h> @@ -329,6 +331,7 @@ void image_print_contents(const void *ptr)
#ifndef USE_HOSTCC +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) /** * image_get_ramdisk - get and verify ramdisk image * @rd_addr: ramdisk image start address @@ -390,6 +393,7 @@ static const image_header_t *image_get_ramdisk(ulong rd_addr, uint8_t arch,
return rd_hdr; } +#endif #endif /* !USE_HOSTCC */
/*****************************************************************************/ @@ -653,20 +657,19 @@ int genimg_get_comp_id(const char *name) */ int genimg_get_format(const void *img_addr) { - ulong format = IMAGE_FORMAT_INVALID; +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) const image_header_t *hdr;
hdr = (const image_header_t *)img_addr; if (image_check_magic(hdr)) - format = IMAGE_FORMAT_LEGACY; + return IMAGE_FORMAT_LEGACY; +#endif #if defined(CONFIG_FIT) || defined(CONFIG_OF_LIBFDT) - else { - if (fdt_check_header(img_addr) == 0) - format = IMAGE_FORMAT_FIT; - } + if (fdt_check_header(img_addr) == 0) + return IMAGE_FORMAT_FIT; #endif
- return format; + return IMAGE_FORMAT_INVALID; }
/** @@ -708,12 +711,14 @@ ulong genimg_get_image(ulong img_addr)
/* get data size */ switch (genimg_get_format(buf)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: d_size = image_get_data_size(buf); debug(" Legacy format image found at 0x%08lx, " "size 0x%08lx\n", ram_addr, d_size); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: d_size = fit_get_size(buf) - h_size; @@ -789,7 +794,9 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, { ulong rd_addr, rd_load; ulong rd_data, rd_len; +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) const image_header_t *rd_hdr; +#endif void *buf; #ifdef CONFIG_SUPPORT_RAW_INITRD char *end; @@ -872,6 +879,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, */ buf = map_sysmem(rd_addr, 0); switch (genimg_get_format(buf)) { +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) case IMAGE_FORMAT_LEGACY: printf("## Loading init Ramdisk from Legacy " "Image at %08lx ...\n", rd_addr); @@ -887,6 +895,7 @@ int boot_get_ramdisk(int argc, char * const argv[], bootm_headers_t *images, rd_len = image_get_data_size(rd_hdr); rd_load = image_get_load(rd_hdr); break; +#endif #if defined(CONFIG_FIT) case IMAGE_FORMAT_FIT: rd_noffset = fit_image_load(images, FIT_RAMDISK_PROP, diff --git a/doc/uImage.FIT/signature.txt b/doc/uImage.FIT/signature.txt index 9502037..672dc35 100644 --- a/doc/uImage.FIT/signature.txt +++ b/doc/uImage.FIT/signature.txt @@ -328,6 +328,9 @@ be enabled: CONFIG_FIT_SIGNATURE - enable signing and verfication in FITs CONFIG_RSA - enable RSA algorithm for signing
+WARNING: When relying on signed FIT images with required signature check +the legacy image format is default disabled by not defining +CONFIG_IMAGE_FORMAT_LEGACY
Testing ------- diff --git a/include/config_defaults.h b/include/config_defaults.h index ad08c1d..fbe0743 100644 --- a/include/config_defaults.h +++ b/include/config_defaults.h @@ -20,4 +20,12 @@ #define CONFIG_ZLIB 1 #define CONFIG_PARTITIONS 1
+#ifndef CONFIG_FIT_SIGNATURE +#define CONFIG_IMAGE_FORMAT_LEGACY +#endif + +#ifdef CONFIG_DISABLE_IMAGE_LEGACY +#undef CONFIG_IMAGE_FORMAT_LEGACY +#endif + #endif diff --git a/include/configs/zynq-common.h b/include/configs/zynq-common.h index 731e69b..0631947 100644 --- a/include/configs/zynq-common.h +++ b/include/configs/zynq-common.h @@ -198,6 +198,7 @@ /* FIT support */ #define CONFIG_FIT #define CONFIG_FIT_VERBOSE 1 /* enable fit_format_{error,warning}() */ +#define CONFIG_IMAGE_FORMAT_LEGACY /* enable also legacy image format */
/* FDT support */ #define CONFIG_OF_CONTROL diff --git a/include/image.h b/include/image.h index b278778..cde58a6 100644 --- a/include/image.h +++ b/include/image.h @@ -411,7 +411,9 @@ enum fit_load_op { #ifndef USE_HOSTCC /* Image format types, returned by _get_format() routine */ #define IMAGE_FORMAT_INVALID 0x00 +#if defined(CONFIG_IMAGE_FORMAT_LEGACY) #define IMAGE_FORMAT_LEGACY 0x01 /* legacy image_header based format */ +#endif #define IMAGE_FORMAT_FIT 0x02 /* new, libfdt based format */
int genimg_get_format(const void *img_addr);
Hi Heiko,
[snip]
[snip]
#endif
[snip]
it appears that the config changes in config_defaults.h have actually not the desired effect since the board specific config file is evaluated after the config_defaults.h. A proper change most likely needs to be applied to config_fallbacks.h.
Thanks, Lars
________________________________ The information contained in this message may be confidential and legally protected under applicable law. The message is intended solely for the addressee(s). If you are not the intended recipient, you are hereby notified that any use, forwarding, dissemination, or reproduction of this message is strictly prohibited and may be unlawful. If you are not the intended recipient, please contact the sender by return e-mail and destroy all copies of the original message.
Hello Lars,
Am 19.05.2014 16:11, schrieb Steubesand, Lars:
Hi Heiko,
[snip]
[snip]
- #endif
[snip]
Yep, you are completely right! good catch!
I prepared a v4 for this issue, and just compiling a MAKEALL for arm and powerpc with the above change.
bye, Heiko
Enable legacy image format with CONFIG_IMAGE_FORMAT_LEGACY on the ids8313 board, as it uses signed FIT images for booting Linux and need the legacy image format.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Simon Glass sjg@chromium.org Cc: Kim Phillips kim.phillips@freescale.com Cc: Michael Conrad Michael.Conrad@ids.de
--- - changes for v2: - enable (not disable) the legacy image format for this board --- include/configs/ids8313.h | 1 + 1 file changed, 1 insertion(+)
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index c1b3b63..1de5750 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -576,6 +576,7 @@
#define CONFIG_FIT #define CONFIG_FIT_SIGNATURE +#define CONFIG_IMAGE_FORMAT_LEGACY #define CONFIG_CMD_FDT #define CONFIG_CMD_HASH #define CONFIG_RSA
move fdtdec_get_int() out of lib/fdtdec.c into lib/fdtdec_common.c as this function is also used, if CONFIG_OF_CONTROL is not used. Poped up on the ids8313 board using signed FIT images, and activating CONFIG_SYS_GENERIC_BOARD. Without this patch it shows on boot:
With this patch, it boots again with CONFIG_SYS_GENERIC_BOARD enabled.
Signed-off-by: Heiko Schocher hs@denx.de Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@ti.com
--- - changes for v2: - remove fdtdec_get_int() in lib/fdtdec.c - only one fdtdec_get_int() implementation Tested on the ids8313 board (on host and target side) - changes for v3: use fdt_getprop() instead fdt_getprop_w() so we avoid a cast as Simon suggested. --- lib/Makefile | 1 + lib/fdtdec.c | 36 ------------------------------------ lib/fdtdec_common.c | 33 +++++++++++++++++++++++++++++++++ tools/fdtdec.c | 1 + 4 files changed, 35 insertions(+), 36 deletions(-) create mode 100644 lib/fdtdec_common.c
diff --git a/lib/Makefile b/lib/Makefile index a4999e2..d3135c9 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -23,6 +23,7 @@ obj-$(CONFIG_USB_TTY) += circbuf.o obj-y += crc7.o obj-y += crc8.o obj-y += crc16.o +obj-y += fdtdec_common.o obj-$(CONFIG_OF_CONTROL) += fdtdec.o obj-$(CONFIG_TEST_FDTDEC) += fdtdec_test.o obj-$(CONFIG_GZIP) += gunzip.o diff --git a/lib/fdtdec.c b/lib/fdtdec.c index 8ecb80f..21d5e85 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -109,24 +109,6 @@ fdt_addr_t fdtdec_get_addr(const void *blob, int node, return fdtdec_get_addr_size(blob, node, prop_name, NULL); }
-s32 fdtdec_get_int(const void *blob, int node, const char *prop_name, - s32 default_val) -{ - const s32 *cell; - int len; - - debug("%s: %s: ", __func__, prop_name); - cell = fdt_getprop(blob, node, prop_name, &len); - if (cell && len >= sizeof(s32)) { - s32 val = fdt32_to_cpu(cell[0]); - - debug("%#x (%d)\n", val, val); - return val; - } - debug("(not found)\n"); - return default_val; -} - uint64_t fdtdec_get_uint64(const void *blob, int node, const char *prop_name, uint64_t default_val) { @@ -646,22 +628,4 @@ int fdtdec_read_fmap_entry(const void *blob, int node, const char *name,
return 0; } -#else -#include "libfdt.h" -#include "fdt_support.h" - -int fdtdec_get_int(const void *blob, int node, const char *prop_name, - int default_val) -{ - const int *cell; - int len; - - cell = fdt_getprop_w((void *)blob, node, prop_name, &len); - if (cell && len >= sizeof(int)) { - int val = fdt32_to_cpu(cell[0]); - - return val; - } - return default_val; -} #endif diff --git a/lib/fdtdec_common.c b/lib/fdtdec_common.c new file mode 100644 index 0000000..bca787b --- /dev/null +++ b/lib/fdtdec_common.c @@ -0,0 +1,33 @@ +/* + * Copyright (c) 2014 + * Heiko Schocher, DENX Software Engineering, hs@denx.de. + * + * Based on lib/fdtdec.c: + * Copyright (c) 2011 The Chromium OS Authors. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef USE_HOSTCC +#include <common.h> +#include <libfdt.h> +#include <fdtdec.h> +#else +#include "libfdt.h" +#include "fdt_support.h" +#endif + +int fdtdec_get_int(const void *blob, int node, const char *prop_name, + int default_val) +{ + const int *cell; + int len; + + cell = fdt_getprop(blob, node, prop_name, &len); + if (cell && len >= sizeof(int)) { + int val = fdt32_to_cpu(cell[0]); + + return val; + } + return default_val; +} diff --git a/tools/fdtdec.c b/tools/fdtdec.c index f1c2256..9987f83 100644 --- a/tools/fdtdec.c +++ b/tools/fdtdec.c @@ -1 +1,2 @@ +#include "../lib/fdtdec_common.c" #include "../lib/fdtdec.c"
Hi Heiko,
But I wonder if it might be possible to keep the debug() statement for the non-host side?
Hello Simon,
Am 24.05.2014 02:10, schrieb Simon Glass:
Hi Heiko,
No valid FDT found - please append one to U-Boot binary, use u-boot-dtb.bin or define CONFIG_OF_EMBED. For sandbox, use -d<file.dtb>
Signed-off-by: Heiko Schocherhs@denx.de Cc: Simon Glasssjg@chromium.org Cc: Tom Rinitrini@ti.com
Acked-by: Simon Glasssjg@chromium.org
I try it, but as I am on holiday, it might take some days ...
bye, Heiko
- add CONFIG_SYS_GENERIC_BOARD - remove CONFIG_OF_CONTROL to boot again
Signed-off-by: Heiko Schocher hs@denx.de Acked-by: Kim Phillips kim.phillips@freescale.com Cc: Simon Glass sjg@chromium.org
--- - changes for v2: - added acked-by from Kim --- include/configs/ids8313.h | 3 ++- 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/include/configs/ids8313.h b/include/configs/ids8313.h index 1de5750..3e55247 100644 --- a/include/configs/ids8313.h +++ b/include/configs/ids8313.h @@ -19,6 +19,8 @@ #define CONFIG_MPC8313 #define CONFIG_IDS8313
+#define CONFIG_SYS_GENERIC_BOARD + #define CONFIG_FSL_ELBC
#define CONFIG_MISC_INIT_R @@ -582,6 +584,5 @@ #define CONFIG_RSA #define CONFIG_SHA1 #define CONFIG_SHA256 -#define CONFIG_OF_CONTROL
#endif /* __CONFIG_H */
Heiko Schocher
Steubesand, Lars
