[bug?] SiFive Unmatched default boot script update?
Good morning!
Mainline Haiku is now getting into the kernel on the SiFive Unmatched board!
Our current boot process involves running the following from u-boot to boot Haiku from a USB drive:
pci enum ; usb start ; run bootcmd_usb0
I feel like "pci enum; usb start;" should be default things to do on the unmatched board if they're not already? If you don't run the commands above, u-boot finds our EFI bootloader, but the the USB drives don't show up in our EFI bootloader.
Given the mmc card on the Unmatched is kind of slow, a model of having u-boot on the mmc card, and booting from usb drives / nvme feels like a good one.
Thanks!
-- Alex
August 15, 2021 9:59 AM, "Alexander von Gluck IV" kallisti5@unixzen.com wrote:
Good morning!
Digging into this slightly; it looks like the following is needed?
diff --git a/configs/sifive_unmatched_defconfig b/configs/sifive_unmatched_defconfig index 38b7acd536..0e02d46f72 100644 --- a/configs/sifive_unmatched_defconfig +++ b/configs/sifive_unmatched_defconfig @@ -11,6 +11,7 @@ CONFIG_TARGET_SIFIVE_UNMATCHED=y CONFIG_ARCH_RV64I=y CONFIG_RISCV_SMODE=y # CONFIG_SPL_USE_ARCH_MEMMOVE is not set +CONFIG_PREBOOT="pci enum; usb start;" CONFIG_DISTRO_DEFAULTS=y CONFIG_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x84000000
That's the same thing the Raspberry Pi 4 does.
-- Alex
