[U-Boot] [PATCH 0/3] Added SPL support
This patch series is submitted to add support for MMC/SD along with SPL support. Also, fixed incorrect register offset of ddr and timer registers.
The patches have been compile tested and run on AM335X EVM.
The patches depends on previous patch series which was submitted for supporting AM33xx platform.
The patches are applies on uboot v2011.09 baseline.
Chandan Nath (3): ARM:AM33XX: Fix ddr and timer register offset ARM:AM33XX: Add mmc/sd support ARM:AM33XX: Add SPL support for AM335X EVM
arch/arm/cpu/armv7/am33xx/board.c | 89 +++++++++++- arch/arm/cpu/armv7/am33xx/clock.c | 8 + arch/arm/cpu/armv7/am33xx/config.mk | 18 +++ arch/arm/cpu/armv7/am33xx/emif4.c | 2 +- arch/arm/cpu/armv7/am33xx/lowlevel_init.S | 24 +++- arch/arm/cpu/armv7/omap-common/spl.c | 11 ++- arch/arm/include/asm/arch-am33xx/common_def.h | 22 +++ arch/arm/include/asm/arch-am33xx/cpu.h | 44 +++--- arch/arm/include/asm/arch-am33xx/ddr_defs.h | 6 +- arch/arm/include/asm/arch-am33xx/hardware.h | 5 + arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 164 +++++++++++++++++++++++ arch/arm/include/asm/arch-am33xx/sys_proto.h | 8 +- arch/arm/include/asm/omap_common.h | 8 + board/ti/am335x/common_def.h | 24 ---- board/ti/am335x/evm.c | 2 +- board/ti/am335x/mux.c | 22 +++- drivers/mmc/omap_hsmmc.c | 1 + include/configs/am335x_evm.h | 60 +++++++-- spl/Makefile | 10 +- 19 files changed, 439 insertions(+), 89 deletions(-) create mode 100644 arch/arm/cpu/armv7/am33xx/config.mk create mode 100644 arch/arm/include/asm/arch-am33xx/common_def.h create mode 100644 arch/arm/include/asm/arch-am33xx/mmc_host_def.h delete mode 100644 board/ti/am335x/common_def.h
This patch is added to update incorrect ddr, pll and timer register offset along with some additional cleanup like removing unused code. Also, generic CONFIG_AM33XX symbol is added for AM33XX platform.
Signed-off-by: Chandan Nath chandan.nath@ti.com Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/board.c | 8 ++-- arch/arm/cpu/armv7/am33xx/clock.c | 3 ++ arch/arm/include/asm/arch-am33xx/cpu.h | 44 +++++++++++++------------ arch/arm/include/asm/arch-am33xx/ddr_defs.h | 6 ++-- arch/arm/include/asm/arch-am33xx/sys_proto.h | 7 ---- include/configs/am335x_evm.h | 12 ++----- 6 files changed, 37 insertions(+), 43 deletions(-)
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 2d6d359..78db3a5 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -26,7 +26,7 @@ DECLARE_GLOBAL_DATA_PTR;
struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; -struct timer_reg *timerreg = (struct timer_reg *)DM_TIMER2_BASE; +struct gptimer *timer_base = (struct gptimer *)CONFIG_SYS_TIMERBASE;
/* * early system init of muxing and clocks. @@ -55,12 +55,12 @@ void s_init(u32 in_ddr) void init_timer(void) { /* Reset the Timer */ - writel(0x2, (&timerreg->tsicrreg)); + writel(0x2, (&timer_base->tscir));
/* Wait until the reset is done */ - while (readl(&timerreg->tiocpcfgreg) & 1) + while (readl(&timer_base->tiocp_cfg) & 1) ;
/* Start the Timer */ - writel(0x1, (&timerreg->tclrreg)); + writel(0x1, (&timer_base->tclr)); } diff --git a/arch/arm/cpu/armv7/am33xx/clock.c b/arch/arm/cpu/armv7/am33xx/clock.c index 4ca6c45..7070e7d 100644 --- a/arch/arm/cpu/armv7/am33xx/clock.c +++ b/arch/arm/cpu/armv7/am33xx/clock.c @@ -101,6 +101,9 @@ static void enable_per_clocks(void) while (readl(&cmper->timer2clkctrl) != PRCM_MOD_EN) ;
+ /* Select the Master osc 24 MHZ as Timer2 clock source */ + writel(0x1, &cmdpll->clktimer2clk); + /* UART0 */ writel(PRCM_MOD_EN, &cmwkup->wkup_uart0ctrl); while (readl(&cmwkup->wkup_uart0ctrl) != PRCM_MOD_EN) diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index ad9156e..25558a2 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -51,7 +51,7 @@ | BIT(3) | BIT(4))
/* Reset control */ -#ifdef CONFIG_AM335X +#ifdef CONFIG_AM33XX #define PRM_RSTCTRL 0x44E00F00 #endif #define PRM_RSTCTRL_RESET 0x01 @@ -108,22 +108,36 @@ struct cm_perpll { unsigned int l3sclkstctrl; /* offset 0x04 */ unsigned int l4fwclkstctrl; /* offset 0x08 */ unsigned int l3clkstctrl; /* offset 0x0c */ - unsigned int resv1[6]; + unsigned int resv1; + unsigned int cpgmac0clkctrl; /* offset 0x14 */ + unsigned int resv2[4]; unsigned int emifclkctrl; /* offset 0x28 */ unsigned int ocmcramclkctrl; /* offset 0x2c */ - unsigned int resv2[12]; + unsigned int gpmcclkctrl; /* offset 0x30 */ + unsigned int resv3[2]; + unsigned int mmc0clkctrl; /* offset 0x3C */ + unsigned int elmclkctrl; /* offset 0x40 */ + unsigned int i2c2clkctrl; /* offset 0x44 */ + unsigned int i2c1clkctrl; /* offset 0x48 */ + unsigned int spi0clkctrl; /* offset 0x4C */ + unsigned int spi1clkctrl; /* offset 0x50 */ + unsigned int resv4[3]; unsigned int l4lsclkctrl; /* offset 0x60 */ unsigned int l4fwclkctrl; /* offset 0x64 */ - unsigned int resv3[6]; + unsigned int resv5[6]; unsigned int timer2clkctrl; /* offset 0x80 */ - unsigned int resv4[19]; + unsigned int resv6[11]; + unsigned int gpio2clkctrl; /* offset 0xB0 */ + unsigned int resv7[7]; unsigned int emiffwclkctrl; /* offset 0xD0 */ - unsigned int resv5[2]; + unsigned int resv8[2]; unsigned int l3instrclkctrl; /* offset 0xDC */ unsigned int l3clkctrl; /* Offset 0xE0 */ - unsigned int resv6[14]; + unsigned int resv9[14]; unsigned int l4hsclkstctrl; /* offset 0x11C */ unsigned int l4hsclkctrl; /* offset 0x120 */ + unsigned int resv10[8]; + unsigned int cpswclkctrl; /* offset 0x144 */ };
/* Encapsulating Display pll registers */ @@ -158,24 +172,12 @@ struct wd_timer { unsigned int wdt_unfr; /* offset 0x100 */ };
-/* Timer Registers */ -struct timer_reg { - unsigned int resv1[4]; - unsigned int tiocpcfgreg; /* offset 0x10 */ - unsigned int resv2[9]; - unsigned int tclrreg; /* offset 0x38 */ - unsigned int tcrrreg; /* offset 0x3C */ - unsigned int tldrreg; /* offset 0x40 */ - unsigned int resv3[4]; - unsigned int tsicrreg; /* offset 0x54 */ -}; - /* Timer 32 bit registers */ struct gptimer { unsigned int tidr; /* offset 0x00 */ - unsigned int res1[0xc]; + unsigned char res1[12]; unsigned int tiocp_cfg; /* offset 0x10 */ - unsigned int res2[0xc]; + unsigned char res2[12]; unsigned int tier; /* offset 0x20 */ unsigned int tistatr; /* offset 0x24 */ unsigned int tistat; /* offset 0x28 */ diff --git a/arch/arm/include/asm/arch-am33xx/ddr_defs.h b/arch/arm/include/asm/arch-am33xx/ddr_defs.h index 9638b4c..ba6b59b 100644 --- a/arch/arm/include/asm/arch-am33xx/ddr_defs.h +++ b/arch/arm/include/asm/arch-am33xx/ddr_defs.h @@ -76,7 +76,7 @@ struct emif_regs { unsigned int sdrmcsr; /* offset 0x3C */ unsigned int res2[8]; unsigned int sdritr; /* offset 0x60 */ - unsigned int res3[20]; + unsigned int res3[32]; unsigned int ddrphycr; /* offset 0xE4 */ unsigned int ddrphycsr; /* offset 0xE8 */ unsigned int ddrphycr2; /* offset 0xEC */ @@ -161,10 +161,10 @@ struct ddr_regs { unsigned int dt0wiratio1; /* offset 0x0F4 */ unsigned int dt0giratio0; /* offset 0x0FC */ unsigned int dt0giratio1; /* offset 0x100 */ - unsigned int resv6[2]; + unsigned int resv6[1]; unsigned int dt0fwsratio0; /* offset 0x108 */ unsigned int dt0fwsratio1; /* offset 0x10C */ - unsigned int resv7[5]; + unsigned int resv7[4]; unsigned int dt0wrsratio0; /* offset 0x120 */ unsigned int dt0wrsratio1; /* offset 0x124 */ unsigned int resv8[3]; diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index 1e265c6..09ed650 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -20,13 +20,6 @@ #define _SYS_PROTO_H_
#define BOARD_REV_ID 0x0 -struct { - u32 board_type_v1; - u32 board_type_v2; - u32 mtype; - char *board_string; - char *nand_string; -} board_sysinfo;
u32 get_cpu_rev(void); u32 get_sysboot_value(void); diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index b471c9b..2a61ef0 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -17,6 +17,7 @@ #define __CONFIG_AM335X_EVM_H
#define CONFIG_AM335X +#define CONFIG_AM33XX #define CONFIG_CMD_MEMORY /* for mtest */ #undef CONFIG_GZIP #undef CONFIG_ZLIB @@ -30,7 +31,7 @@ #define CONFIG_AM335X_CONFIG_DDR #define CONFIG_ENV_SIZE 0x400 #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (8 * 1024)) -#define CONFIG_SYS_PROMPT "AM335X# " +#define CONFIG_SYS_PROMPT "U-Boot# " #define CONFIG_SYS_NO_FLASH #define CONFIG_MACH_TYPE MACH_TYPE_TIAM335EVM
@@ -47,14 +48,12 @@
/* Clock Defines */ #define V_OSCK 24000000 /* Clock output from T2 */ -#define V_SCLK (V_OSCK >> 1) +#define V_SCLK (V_OSCK)
-#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for - initial data */ #define CONFIG_CMD_ECHO
/* max number of command args */ -#define CONFIG_SYS_MAXARGS 32 +#define CONFIG_SYS_MAXARGS 16
/* Console I/O Buffer Size */ #define CONFIG_SYS_CBSIZE 512 @@ -74,7 +73,6 @@ #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_MEMTEST_START \ + (8 * 1024 * 1024))
-#undef CONFIG_SYS_CLKS_IN_HZ /* everything, incl board info, in Hz */ #define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ #define CONFIG_SYS_HZ 1000 /* 1ms clock */
@@ -88,7 +86,6 @@ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_SDRAM_BASE + 0x1000 - \ GENERATED_GBL_DATA_SIZE) /* Platform/Board specific defs */ -#define CONFIG_SYS_CLK_FREQ 24000000 #define CONFIG_SYS_TIMERBASE 0x48040000 /* Use Timer2 */ #define CONFIG_SYS_PTV 2 /* Divisor: 2^(PTV+1) => 8 */ #define CONFIG_SYS_HZ 1000 @@ -99,7 +96,6 @@ #define CONFIG_SYS_NS16550_REG_SIZE (-4) #define CONFIG_SYS_NS16550_CLK (48000000) #define CONFIG_SYS_NS16550_COM1 0x44e09000 /* Base EVM has UART0 */ -#define CONFIG_SYS_NS16550_COM4 0x481A6000 /* UART3 on IA BOard */
#define CONFIG_BAUDRATE 115200 #define CONFIG_SYS_BAUDRATE_TABLE { 110, 300, 600, 1200, 2400, \
[snip]
Note that the intention is that CONFIG_AM335X goes away (and we can evaluate the right symbol breakdown once a non am335x am33xx part arrives.
This patch add supports for mmc/sd driver on AM335X platform. PLL and pinmux configurations for mmc/sd are configured in this patch.
Signed-off-by: Chandan Nath chandan.nath@ti.com Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/board.c | 7 + arch/arm/cpu/armv7/am33xx/clock.c | 5 + arch/arm/include/asm/arch-am33xx/mmc_host_def.h | 164 +++++++++++++++++++++++ board/ti/am335x/mux.c | 20 +++ drivers/mmc/omap_hsmmc.c | 1 + include/configs/am335x_evm.h | 9 ++ 6 files changed, 206 insertions(+), 0 deletions(-) create mode 100644 arch/arm/include/asm/arch-am33xx/mmc_host_def.h
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 78db3a5..312643c 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -64,3 +64,10 @@ void init_timer(void) /* Start the Timer */ writel(0x1, (&timer_base->tclr)); } + +#if defined(CONFIG_OMAP_HSMMC) && !defined(CONFIG_SPL_BUILD) +int board_mmc_init(bd_t *bis) +{ + return omap_mmc_init(0); +} +#endif diff --git a/arch/arm/cpu/armv7/am33xx/clock.c b/arch/arm/cpu/armv7/am33xx/clock.c index 7070e7d..98cfd93 100644 --- a/arch/arm/cpu/armv7/am33xx/clock.c +++ b/arch/arm/cpu/armv7/am33xx/clock.c @@ -108,6 +108,11 @@ static void enable_per_clocks(void) writel(PRCM_MOD_EN, &cmwkup->wkup_uart0ctrl); while (readl(&cmwkup->wkup_uart0ctrl) != PRCM_MOD_EN) ; + + /* MMC0*/ + writel(PRCM_MOD_EN, &cmper->mmc0clkctrl); + while (readl(&cmper->mmc0clkctrl) != PRCM_MOD_EN) + ; }
static void mpu_pll_config(void) diff --git a/arch/arm/include/asm/arch-am33xx/mmc_host_def.h b/arch/arm/include/asm/arch-am33xx/mmc_host_def.h new file mode 100644 index 0000000..e56c018 --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/mmc_host_def.h @@ -0,0 +1,164 @@ +/* + * mmc_host_def.h + * + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef MMC_HOST_DEF_H +#define MMC_HOST_DEF_H + +/* + * OMAP HSMMC register definitions + */ +#define OMAP_HSMMC1_BASE 0x48060100 +#define OMAP_HSMMC2_BASE 0x481D8000 +#define OMAP_HSMMC3_BASE 0x47C24000 + +typedef struct hsmmc { + unsigned char res1[0x10]; + unsigned int sysconfig; /* 0x10 */ + unsigned int sysstatus; /* 0x14 */ + unsigned char res2[0x14]; + unsigned int con; /* 0x2C */ + unsigned char res3[0xD4]; + unsigned int blk; /* 0x104 */ + unsigned int arg; /* 0x108 */ + unsigned int cmd; /* 0x10C */ + unsigned int rsp10; /* 0x110 */ + unsigned int rsp32; /* 0x114 */ + unsigned int rsp54; /* 0x118 */ + unsigned int rsp76; /* 0x11C */ + unsigned int data; /* 0x120 */ + unsigned int pstate; /* 0x124 */ + unsigned int hctl; /* 0x128 */ + unsigned int sysctl; /* 0x12C */ + unsigned int stat; /* 0x130 */ + unsigned int ie; /* 0x134 */ + unsigned char res4[0x8]; + unsigned int capa; /* 0x140 */ +} hsmmc_t; + +/* + * OMAP HS MMC Bit definitions + */ +#define MMC_SOFTRESET (0x1 << 1) +#define RESETDONE (0x1 << 0) +#define NOOPENDRAIN (0x0 << 0) +#define OPENDRAIN (0x1 << 0) +#define OD (0x1 << 0) +#define INIT_NOINIT (0x0 << 1) +#define INIT_INITSTREAM (0x1 << 1) +#define HR_NOHOSTRESP (0x0 << 2) +#define STR_BLOCK (0x0 << 3) +#define MODE_FUNC (0x0 << 4) +#define DW8_1_4BITMODE (0x0 << 5) +#define MIT_CTO (0x0 << 6) +#define CDP_ACTIVEHIGH (0x0 << 7) +#define WPP_ACTIVEHIGH (0x0 << 8) +#define RESERVED_MASK (0x3 << 9) +#define CTPL_MMC_SD (0x0 << 11) +#define BLEN_512BYTESLEN (0x200 << 0) +#define NBLK_STPCNT (0x0 << 16) +#define DE_DISABLE (0x0 << 0) +#define BCE_DISABLE (0x0 << 1) +#define BCE_ENABLE (0x1 << 1) +#define ACEN_DISABLE (0x0 << 2) +#define DDIR_OFFSET (4) +#define DDIR_MASK (0x1 << 4) +#define DDIR_WRITE (0x0 << 4) +#define DDIR_READ (0x1 << 4) +#define MSBS_SGLEBLK (0x0 << 5) +#define MSBS_MULTIBLK (0x1 << 5) +#define RSP_TYPE_OFFSET (16) +#define RSP_TYPE_MASK (0x3 << 16) +#define RSP_TYPE_NORSP (0x0 << 16) +#define RSP_TYPE_LGHT136 (0x1 << 16) +#define RSP_TYPE_LGHT48 (0x2 << 16) +#define RSP_TYPE_LGHT48B (0x3 << 16) +#define CCCE_NOCHECK (0x0 << 19) +#define CCCE_CHECK (0x1 << 19) +#define CICE_NOCHECK (0x0 << 20) +#define CICE_CHECK (0x1 << 20) +#define DP_OFFSET (21) +#define DP_MASK (0x1 << 21) +#define DP_NO_DATA (0x0 << 21) +#define DP_DATA (0x1 << 21) +#define CMD_TYPE_NORMAL (0x0 << 22) +#define INDEX_OFFSET (24) +#define INDEX_MASK (0x3f << 24) +#define INDEX(i) (i << 24) +#define DATI_MASK (0x1 << 1) +#define DATI_CMDDIS (0x1 << 1) +#define DTW_1_BITMODE (0x0 << 1) +#define DTW_4_BITMODE (0x1 << 1) +#define DTW_8_BITMODE (0x1 << 5) /* CON[DW8]*/ +#define SDBP_PWROFF (0x0 << 8) +#define SDBP_PWRON (0x1 << 8) +#define SDVS_1V8 (0x5 << 9) +#define SDVS_3V0 (0x6 << 9) +#define ICE_MASK (0x1 << 0) +#define ICE_STOP (0x0 << 0) +#define ICS_MASK (0x1 << 1) +#define ICS_NOTREADY (0x0 << 1) +#define ICE_OSCILLATE (0x1 << 0) +#define CEN_MASK (0x1 << 2) +#define CEN_DISABLE (0x0 << 2) +#define CEN_ENABLE (0x1 << 2) +#define CLKD_OFFSET (6) +#define CLKD_MASK (0x3FF << 6) +#define DTO_MASK (0xF << 16) +#define DTO_15THDTO (0xE << 16) +#define SOFTRESETALL (0x1 << 24) +#define CC_MASK (0x1 << 0) +#define TC_MASK (0x1 << 1) +#define BWR_MASK (0x1 << 4) +#define BRR_MASK (0x1 << 5) +#define ERRI_MASK (0x1 << 15) +#define IE_CC (0x01 << 0) +#define IE_TC (0x01 << 1) +#define IE_BWR (0x01 << 4) +#define IE_BRR (0x01 << 5) +#define IE_CTO (0x01 << 16) +#define IE_CCRC (0x01 << 17) +#define IE_CEB (0x01 << 18) +#define IE_CIE (0x01 << 19) +#define IE_DTO (0x01 << 20) +#define IE_DCRC (0x01 << 21) +#define IE_DEB (0x01 << 22) +#define IE_CERR (0x01 << 28) +#define IE_BADA (0x01 << 29) + +#define VS30_3V0SUP (1 << 25) +#define VS18_1V8SUP (1 << 26) + +/* Driver definitions */ +#define MMCSD_SECTOR_SIZE 512 +#define MMC_CARD 0 +#define SD_CARD 1 +#define BYTE_MODE 0 +#define SECTOR_MODE 1 +#define CLK_INITSEQ 0 +#define CLK_400KHZ 1 +#define CLK_MISC 2 + +#define RSP_TYPE_NONE (RSP_TYPE_NORSP | CCCE_NOCHECK | CICE_NOCHECK) +#define MMC_CMD0 (INDEX(0) | RSP_TYPE_NONE | DP_NO_DATA | DDIR_WRITE) + +/* Clock Configurations and Macros */ +#define MMC_CLOCK_REFERENCE 96 /* MHz */ + +#define mmc_reg_out(addr, mask, val)\ + writel((readl(addr) & (~(mask))) | ((val) & (mask)), (addr)) + +int omap_mmc_init(int dev_index); + +#endif /* MMC_HOST_DEF_H */ diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index 8f27409..df11752 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -258,6 +258,20 @@ static struct module_pin_mux uart0_pin_mux[] = { {-1}, };
+#ifdef CONFIG_MMC +static struct module_pin_mux mmc0_pin_mux[] = { + {OFFSET(mmc0_dat3), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT3 */ + {OFFSET(mmc0_dat2), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT2 */ + {OFFSET(mmc0_dat1), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT1 */ + {OFFSET(mmc0_dat0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_DAT0 */ + {OFFSET(mmc0_clk), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CLK */ + {OFFSET(mmc0_cmd), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* MMC0_CMD */ + {OFFSET(mcasp0_aclkr), (MODE(4) | RXACTIVE)}, /* MMC0_WP */ + {OFFSET(spi0_cs1), (MODE(5) | RXACTIVE | PULLUP_EN)}, /* MMC0_CD */ + {-1}, +}; +#endif + /* * Configure the pin mux for the module */ @@ -276,3 +290,9 @@ void enable_uart0_pin_mux(void) { configure_module_pin_mux(uart0_pin_mux); } + + +void enable_mmc0_pin_mux(void) +{ + configure_module_pin_mux(mmc0_pin_mux); +} diff --git a/drivers/mmc/omap_hsmmc.c b/drivers/mmc/omap_hsmmc.c index ef12ecd..6603501 100644 --- a/drivers/mmc/omap_hsmmc.c +++ b/drivers/mmc/omap_hsmmc.c @@ -28,6 +28,7 @@ #include <part.h> #include <i2c.h> #include <twl4030.h> +#include <linux/compiler.h> #include <asm/io.h> #include <asm/arch/mmc_host_def.h> #include <asm/arch/sys_proto.h> diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 2a61ef0..086d4ef 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -76,6 +76,15 @@ #define CONFIG_SYS_LOAD_ADDR 0x81000000 /* Default load address */ #define CONFIG_SYS_HZ 1000 /* 1ms clock */
+#define CONFIG_MMC +#define CONFIG_AM335X_HSMMC_BASE 0x48060100 +#define CONFIG_GENERIC_MMC +#define CONFIG_OMAP_HSMMC +#define CONFIG_CMD_MMC +#define CONFIG_DOS_PARTITION +#define CONFIG_CMD_FAT +#define CONFIG_CMD_EXT2 + /* Physical Memory Map */ #define CONFIG_NR_DRAM_BANKS 1 /* 1 bank of DRAM */ #define PHYS_DRAM_1 0x80000000 /* DRAM Bank #1 */
The omap_hsmmc.c part isn't needed (I had added that when playing with an idea and didn't remove from the WIP patch I sent you).
This patch is added to support SPL feature on AM335X platform. In this patch, MMC1 is configured as boot device for SPL and support for other devices will be added in the next patch series.
Signed-off-by: Chandan Nath chandan.nath@ti.com Signed-off-by: Tom Rini trini@ti.com --- arch/arm/cpu/armv7/am33xx/board.c | 74 +++++++++++++++++++++++- arch/arm/cpu/armv7/am33xx/config.mk | 18 ++++++ arch/arm/cpu/armv7/am33xx/emif4.c | 2 +- arch/arm/cpu/armv7/am33xx/lowlevel_init.S | 24 ++++++-- arch/arm/cpu/armv7/omap-common/spl.c | 11 +++- arch/arm/include/asm/arch-am33xx/common_def.h | 22 +++++++ arch/arm/include/asm/arch-am33xx/hardware.h | 5 ++ arch/arm/include/asm/arch-am33xx/sys_proto.h | 1 + arch/arm/include/asm/omap_common.h | 8 +++ board/ti/am335x/common_def.h | 24 -------- board/ti/am335x/evm.c | 2 +- board/ti/am335x/mux.c | 2 +- include/configs/am335x_evm.h | 39 ++++++++++++- spl/Makefile | 10 ++- 14 files changed, 196 insertions(+), 46 deletions(-) create mode 100644 arch/arm/cpu/armv7/am33xx/config.mk create mode 100644 arch/arm/include/asm/arch-am33xx/common_def.h delete mode 100644 board/ti/am335x/common_def.h
diff --git a/arch/arm/cpu/armv7/am33xx/board.c b/arch/arm/cpu/armv7/am33xx/board.c index 312643c..647edaa 100644 --- a/arch/arm/cpu/armv7/am33xx/board.c +++ b/arch/arm/cpu/armv7/am33xx/board.c @@ -21,17 +21,52 @@ #include <asm/arch/hardware.h> #include <asm/arch/ddr_defs.h> #include <asm/arch/clock.h> +#include <asm/arch/mmc_host_def.h> +#include <asm/arch/common_def.h> #include <asm/io.h> +#include <asm/omap_common.h>
struct wd_timer *wdtimer = (struct wd_timer *)WDT_BASE; struct gptimer *timer_base = (struct gptimer *)CONFIG_SYS_TIMERBASE; +struct uart_sys *uart_base = (struct uart_sys *)DEFAULT_UART_BASE; + +#ifdef CONFIG_SPL_BUILD +u32 am33xx_boot_device = BOOT_DEVICE_MMC1; + +u32 omap_boot_device(void) +{ + return am33xx_boot_device; +} + +u32 omap_boot_mode(void) +{ + switch (omap_boot_device()) { + case BOOT_DEVICE_MMC2: + return MMCSD_MODE_RAW; + case BOOT_DEVICE_MMC1: + return MMCSD_MODE_FAT; + break; + case BOOT_DEVICE_NAND: + return NAND_MODE_HW_ECC; + break; + default: + puts("spl: ERROR: unknown device - can't select boot mode\n"); + hang(); + } +} + +/* UART Defines */ +#define UART_RESET (0x1 << 1) +#define UART_CLK_RUNNING_MASK 0x1 +#define UART_SMART_IDLE_EN (0x1 << 0x3) +#endif
/* * early system init of muxing and clocks. */ -void s_init(u32 in_ddr) +void s_init(void) { /* WDT1 is already running when the bootloader gets control * Disable it to avoid "random" resets @@ -43,12 +78,37 @@ void s_init(u32 in_ddr) while (readl(&wdtimer->wdtwwps) != 0x0) ;
+#ifdef CONFIG_SPL_BUILD /* Setup the PLLs and the clocks for the peripherals */ -#ifdef CONFIG_SETUP_PLL pll_init(); + + /* UART softreset */ + u32 regVal; + + enable_uart0_pin_mux(); + + regVal = readl(&uart_base->uartsyscfg); + regVal |= UART_RESET; + writel(regVal, &uart_base->uartsyscfg); + while ((readl(&uart_base->uartsyssts) & + UART_CLK_RUNNING_MASK) != UART_CLK_RUNNING_MASK) + ; + + /* Disable smart idle */ + regVal = readl(&uart_base->uartsyscfg); + regVal |= UART_SMART_IDLE_EN; + writel(regVal, &uart_base->uartsyscfg); + + /* Initialize the Timer */ + init_timer(); + + preloader_console_init(); + + config_ddr(); #endif - if (!in_ddr) - config_ddr(); + + /* Enable MMC0 */ + enable_mmc0_pin_mux(); }
/* Initialize timer */ @@ -71,3 +131,9 @@ int board_mmc_init(bd_t *bis) return omap_mmc_init(0); } #endif + +void setup_clocks_for_console(void) +{ + /* Not yet implemented */ + return; +} diff --git a/arch/arm/cpu/armv7/am33xx/config.mk b/arch/arm/cpu/armv7/am33xx/config.mk new file mode 100644 index 0000000..5750bbd --- /dev/null +++ b/arch/arm/cpu/armv7/am33xx/config.mk @@ -0,0 +1,18 @@ +# +# Copyright (C) 2011, Texas Instruments, Incorporated - http://www.ti.com/ +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed "as is" WITHOUT ANY WARRANTY of any +# kind, whether express or implied; without even the implied warranty +# of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +ifdef CONFIG_SPL_BUILD +ALL-y += $(OBJTREE)/MLO +else +ALL-y += $(obj)u-boot.img +endif diff --git a/arch/arm/cpu/armv7/am33xx/emif4.c b/arch/arm/cpu/armv7/am33xx/emif4.c index 1318365..2f4164d 100644 --- a/arch/arm/cpu/armv7/am33xx/emif4.c +++ b/arch/arm/cpu/armv7/am33xx/emif4.c @@ -46,7 +46,7 @@ void dram_init_banksize(void) }
-#ifdef CONFIG_AM335X_CONFIG_DDR +#ifdef CONFIG_SPL_BUILD static void data_macro_config(int dataMacroNum) { struct ddr_data data; diff --git a/arch/arm/cpu/armv7/am33xx/lowlevel_init.S b/arch/arm/cpu/armv7/am33xx/lowlevel_init.S index 17c962f..1d3f0d5 100644 --- a/arch/arm/cpu/armv7/am33xx/lowlevel_init.S +++ b/arch/arm/cpu/armv7/am33xx/lowlevel_init.S @@ -22,16 +22,19 @@ #include <config.h> #include <asm/arch/hardware.h>
-_mark1: - .word mark1 -_lowlevel_init1: - .word lowlevel_init -_s_init_start: - .word s_init_start - _TEXT_BASE: .word CONFIG_SYS_TEXT_BASE /* sdram load addr from config.mk */
+.global save_boot_params +save_boot_params: +#ifdef CONFIG_SPL_BUILD + ldr r4, =am33xx_boot_device + ldr r5, [r0, #BOOT_DEVICE_OFFSET] + and r5, r5, #BOOT_DEVICE_MASK + str r5, [r4] +#endif + bx lr + /***************************************************************************** * lowlevel_init: - Platform low level init. ****************************************************************************/ @@ -70,3 +73,10 @@ s_init_start: SRAM_STACK: /* Place stack at the top */ .word LOW_LEVEL_SRAM_STACK + +_mark1: + .word mark1 +_lowlevel_init1: + .word lowlevel_init +_s_init_start: + .word s_init_start diff --git a/arch/arm/cpu/armv7/omap-common/spl.c b/arch/arm/cpu/armv7/omap-common/spl.c index d177652..62688eb 100644 --- a/arch/arm/cpu/armv7/omap-common/spl.c +++ b/arch/arm/cpu/armv7/omap-common/spl.c @@ -223,8 +223,9 @@ void board_init_r(gd_t *id, ulong dummy) debug(">>spl:board_init_r()\n");
timer_init(); +#ifdef CONFIG_I2C i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); - +#endif boot_device = omap_boot_device(); debug("boot device - %d\n", boot_device); switch (boot_device) { @@ -249,6 +250,14 @@ void board_init_r(gd_t *id, ulong dummy) } }
+void __omap_rev_string(char *str) +{ + sprintf(str, "Revision detection unimplemented"); +} + +void omap_rev_string(char *str) + __attribute__((weak, alias("__omap_rev_string"))); + void preloader_console_init(void) { const char *u_boot_rev = U_BOOT_VERSION; diff --git a/arch/arm/include/asm/arch-am33xx/common_def.h b/arch/arm/include/asm/arch-am33xx/common_def.h new file mode 100644 index 0000000..767932d --- /dev/null +++ b/arch/arm/include/asm/arch-am33xx/common_def.h @@ -0,0 +1,22 @@ +/* + * common_def.h + * + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation version 2. + * + * This program is distributed "as is" WITHOUT ANY WARRANTY of any + * kind, whether express or implied; without even the implied warranty + * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#ifndef __COMMON_DEF_H__ +#define __COMMON_DEF_H__ + +extern void enable_uart0_pin_mux(void); +extern void enable_mmc0_pin_mux(void); + +#endif/*__COMMON_DEF_H__ */ diff --git a/arch/arm/include/asm/arch-am33xx/hardware.h b/arch/arm/include/asm/arch-am33xx/hardware.h index 0ec22eb..aac2e48 100644 --- a/arch/arm/include/asm/arch-am33xx/hardware.h +++ b/arch/arm/include/asm/arch-am33xx/hardware.h @@ -78,4 +78,9 @@ #define DDRPHY_0_CONFIG_BASE (CTRL_BASE + 0x1400) #define DDRPHY_CONFIG_BASE DDRPHY_0_CONFIG_BASE
+/* ROM code defines */ +/* Boot device */ +#define BOOT_DEVICE_MASK 0xFF +#define BOOT_DEVICE_OFFSET 0x8 + #endif /* __AM33XX_HARDWARE_H */ diff --git a/arch/arm/include/asm/arch-am33xx/sys_proto.h b/arch/arm/include/asm/arch-am33xx/sys_proto.h index 09ed650..6c58f1b 100644 --- a/arch/arm/include/asm/arch-am33xx/sys_proto.h +++ b/arch/arm/include/asm/arch-am33xx/sys_proto.h @@ -29,4 +29,5 @@ int print_cpuinfo(void); #endif
u32 get_device_type(void); +void setup_clocks_for_console(void); #endif diff --git a/arch/arm/include/asm/omap_common.h b/arch/arm/include/asm/omap_common.h index d3cb857..ef19d13 100644 --- a/arch/arm/include/asm/omap_common.h +++ b/arch/arm/include/asm/omap_common.h @@ -39,16 +39,24 @@ void preloader_console_init(void); /* Boot device */ #define BOOT_DEVICE_NONE 0 #define BOOT_DEVICE_XIP 1 +#if defined(CONFIG_OMAP54XX) || defined(CONFIG_OMAP44XX) #define BOOT_DEVICE_XIPWAIT 2 #define BOOT_DEVICE_NAND 3 #define BOOT_DEVICE_ONE_NAND 4 #define BOOT_DEVICE_MMC1 5 #define BOOT_DEVICE_MMC2 6 +#elif defined(CONFIG_AM33XX) /* AM33XX */ +#define BOOT_DEVICE_NAND 5 +#define BOOT_DEVICE_MMC1 8 +#define BOOT_DEVICE_MMC2 0 /* eMMC, TODO */ +#define BOOT_DEVICE_UART 65 +#endif
/* Boot type */ #define MMCSD_MODE_UNDEFINED 0 #define MMCSD_MODE_RAW 1 #define MMCSD_MODE_FAT 2 +#define NAND_MODE_HW_ECC 3
u32 omap_boot_device(void); u32 omap_boot_mode(void); diff --git a/board/ti/am335x/common_def.h b/board/ti/am335x/common_def.h deleted file mode 100644 index 1696d60..0000000 --- a/board/ti/am335x/common_def.h +++ /dev/null @@ -1,24 +0,0 @@ -/* - * common_def.h - * - * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation version 2. - * - * This program is distributed "as is" WITHOUT ANY WARRANTY of any - * kind, whether express or implied; without even the implied warranty - * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - */ - -#ifndef __COMMON_DEF_H__ -#define __COMMON_DEF_H__ - -extern void enable_uart0_pin_mux(void); -extern void configure_evm_pin_mux(unsigned char daughter_board_id, - unsigned short daughter_board_profile, - unsigned char daughter_board_flag); - -#endif/*__COMMON_DEF_H__ */ diff --git a/board/ti/am335x/evm.c b/board/ti/am335x/evm.c index b4eddd8..6a9f788 100644 --- a/board/ti/am335x/evm.c +++ b/board/ti/am335x/evm.c @@ -16,7 +16,7 @@ #include <common.h> #include <asm/arch/cpu.h> #include <asm/arch/hardware.h> -#include "common_def.h" +#include <asm/arch/common_def.h> #include <serial.h>
DECLARE_GLOBAL_DATA_PTR; diff --git a/board/ti/am335x/mux.c b/board/ti/am335x/mux.c index df11752..c2a61bd 100644 --- a/board/ti/am335x/mux.c +++ b/board/ti/am335x/mux.c @@ -14,7 +14,7 @@ */
#include <config.h> -#include "common_def.h" +#include <asm/arch/common_def.h> #include <asm/arch/hardware.h> #include <asm/io.h>
diff --git a/include/configs/am335x_evm.h b/include/configs/am335x_evm.h index 086d4ef..020278c 100644 --- a/include/configs/am335x_evm.h +++ b/include/configs/am335x_evm.h @@ -27,8 +27,6 @@ #include <asm/arch/cpu.h> #include <asm/arch/hardware.h>
-#define CONFIG_SETUP_PLL -#define CONFIG_AM335X_CONFIG_DDR #define CONFIG_ENV_SIZE 0x400 #define CONFIG_SYS_MALLOC_LEN (CONFIG_ENV_SIZE + (8 * 1024)) #define CONFIG_SYS_PROMPT "U-Boot# " @@ -119,7 +117,42 @@
#define CONFIG_ENV_IS_NOWHERE
-#define CONFIG_SYS_TEXT_BASE 0x402f0400 +/* Defines for SPL */ +#define CONFIG_SPL +#define CONFIG_SPL_TEXT_BASE 0x402F0400 +#define CONFIG_SPL_MAX_SIZE (46 * 1024) +#define CONFIG_SPL_STACK LOW_LEVEL_SRAM_STACK + +#define CONFIG_SPL_BSS_START_ADDR 0x80000000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x80000 /* 512 KB */ + +#define CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR 0x300 /* address 0x60000 */ +#define CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORS 0x200 /* 256 KB */ +#define CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION 1 +#define CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME "u-boot.img" +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_FAT_SUPPORT + +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_LIBDISK_SUPPORT +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_LDSCRIPT "$(CPUDIR)/omap-common/u-boot-spl.lds" + +/* + * 1MB into the SDRAM to allow for SPL's bss at the beginning of SDRAM + * 64 bytes before this address should be set aside for u-boot.img's + * header. That is 0x800FFFC0--0x80100000 should not be used for any + * other needs. + */ +#define CONFIG_SYS_TEXT_BASE 0x80800000 +#define CONFIG_SYS_SPL_MALLOC_START 0x80208000 +#define CONFIG_SYS_SPL_MALLOC_SIZE 0x100000 + +/* Since SPL did all of this for us, we don't need to do it twice. */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_SKIP_LOWLEVEL_INIT +#endif
/* Unsupported features */ #undef CONFIG_USE_IRQ diff --git a/spl/Makefile b/spl/Makefile index 95ecce1..e3668ea 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -47,10 +47,7 @@ LIBS-$(CONFIG_SPL_SPI_SUPPORT) += drivers/spi/libspi.o LIBS-$(CONFIG_SPL_FAT_SUPPORT) += fs/fat/libfat.o LIBS-$(CONFIG_SPL_LIBGENERIC_SUPPORT) += lib/libgeneric.o
-ifeq ($(SOC),omap3) -LIBS-y += $(CPUDIR)/omap-common/libomap-common.o -endif -ifeq ($(SOC),omap4) +ifneq ($(CONFIG_AM335X)$(CONFIG_OMAP34XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX),) LIBS-y += $(CPUDIR)/omap-common/libomap-common.o endif
@@ -90,6 +87,11 @@ $(OBJTREE)/MLO: $(obj)u-boot-spl.bin $(OBJTREE)/tools/mkimage -T omapimage \ -a $(CONFIG_SPL_TEXT_BASE) -d $< $@ endif +ifdef CONFIG_AM33XX +$(OBJTREE)/MLO: $(obj)u-boot-spl.bin + $(OBJTREE)/tools/mkimage -T omapimage \ + -a $(CONFIG_SPL_TEXT_BASE) -d $< $@ +endif
ALL-y += $(obj)u-boot-spl.bin
[snip]
Please see the Overo SPL thread where Wolfgang mentions the right way to init this to 0 and have it be in the data section, followed by me saying I'd see if <linux/compiler.h> had a shortcut.
Something I wanted to see, but hadn't had a chance to look into was if we could use the OMAP4/5 code for boot_mode as well, can you please check?
[snip]
Not that it's a huge deal but you didn't update lowlevel_init.S to not pass in a param when calling s_init.
Stuff either belongs in arch-am33xx/sys_proto.h or we need to re-think where we're going with the pinmux code. I know things will get more complicated once we add i2c and can detect board revs and all of that.
On Wednesday 21 December 2011 09:16 PM, Tom Rini wrote:
[snip]
Please see the Overo SPL thread where Wolfgang mentions the right way to init this to 0 and have it be in the data section, followed by me saying I'd see if<linux/compiler.h> had a shortcut.
But here looks like he doesn't intend to initialize it to 0?
OMAP4/5 code parses ROM code structures (using a pointer passed by ROM code). If those structures and their layout are exactly same in AM33XX, it may work, otherwise it won't.
br, Aneesh
[snip]
I intended to before going "oh, that's right, it ends up in the BSS not the data section, lemme set it to a value".
Yes, I think we share enough ROM code that it should work. We're using the OMAP4/5 code for boot device already (and it works for a number of modes, we just don't have all the supporting code in submittable state).
In the future please send things vs either top of tree mainline or top of tree u-boot/next, depending on what's required (in this case, just top of tree mainline would be fine). The defines for which boot devices aren't at all what I sent you along (which tries to make this a bit less of a mess for whatever comes along next) because 2011.09 doesn't have OMAP5. Thanks.
Aneesh V
Chandan Nath
