[PATCH V3 0/4] imx: imx8m: enable DM SERIAL
V3: Add missed Signed-off-by Rebased to only add CONFIG_DM_SERIAL, not touch other config change in defconfig
V2: Include imx8mq-evk in this patchset. For i.MX8MN/M/P, drop board level uart pinmux settings, move preloader_console_init after driver probe.
Tested on all four boards. Note i.MX8MQ-EVK not have SPL_DM, so pinmux for uart still there for spl usage.
Peng Fan (4): imx: imx8mp_evk: enable CONFIG_DM_SERIAL imx: imx8mm_evk: enable CONFIG_DM_SERIAL imx: imx8mn_evk: enable CONFIG_DM_SERIAL imx: imx8mq-evk: enable CONFIG_DM_SERIAL
arch/arm/dts/imx8mq-evk-u-boot.dtsi | 32 +++++++++++++++++++++++++ board/freescale/imx8mm_evk/spl.c | 12 ++-------- board/freescale/imx8mn_evk/spl.c | 12 ++-------- board/freescale/imx8mp_evk/imx8mp_evk.c | 8 ------- configs/imx8mm_evk_defconfig | 1 + configs/imx8mn_ddr4_evk_defconfig | 1 + configs/imx8mn_evk_defconfig | 1 + configs/imx8mp_evk_defconfig | 1 + configs/imx8mq_evk_defconfig | 1 + 9 files changed, 41 insertions(+), 28 deletions(-)
Enable CONFIG_DM_SERIAL. uart2 and its pinmux was already marked with u-boot,dm-spl.
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mp_evk/imx8mp_evk.c | 8 -------- configs/imx8mp_evk_defconfig | 1 + 2 files changed, 1 insertion(+), 8 deletions(-)
diff --git a/board/freescale/imx8mp_evk/imx8mp_evk.c b/board/freescale/imx8mp_evk/imx8mp_evk.c index 62096c24fb7..fb6c61c39e7 100644 --- a/board/freescale/imx8mp_evk/imx8mp_evk.c +++ b/board/freescale/imx8mp_evk/imx8mp_evk.c @@ -20,14 +20,8 @@
DECLARE_GLOBAL_DATA_PTR;
-#define UART_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_FSEL1) #define WDOG_PAD_CTRL (PAD_CTL_DSE6 | PAD_CTL_ODE | PAD_CTL_PUE | PAD_CTL_PE)
-static iomux_v3_cfg_t const uart_pads[] = { - MX8MP_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - MX8MP_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { MX8MP_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -40,8 +34,6 @@ int board_early_init_f(void)
set_wdog_reset(wdog);
- imx_iomux_v3_setup_multiple_pads(uart_pads, ARRAY_SIZE(uart_pads)); - return 0; }
diff --git a/configs/imx8mp_evk_defconfig b/configs/imx8mp_evk_defconfig index c64b699e105..01240e543af 100644 --- a/configs/imx8mp_evk_defconfig +++ b/configs/imx8mp_evk_defconfig @@ -91,6 +91,7 @@ CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPL_POWER_I2C=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mm_evk/spl.c | 12 ++---------- configs/imx8mm_evk_defconfig | 1 + 2 files changed, 3 insertions(+), 10 deletions(-)
diff --git a/board/freescale/imx8mm_evk/spl.c b/board/freescale/imx8mm_evk/spl.c index 4ef7f6f1806..e65dc2194ea 100644 --- a/board/freescale/imx8mm_evk/spl.c +++ b/board/freescale/imx8mm_evk/spl.c @@ -64,14 +64,8 @@ int board_fit_config_name_match(const char *name) } #endif
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MM_PAD_UART2_RXD_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MM_PAD_UART2_TXD_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MM_PAD_GPIO1_IO02_WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -84,8 +78,6 @@ int board_early_init_f(void)
@@ -139,8 +131,6 @@ void board_init_f(ulong dummy)
timer_init();
- preloader_console_init(); - /* Clear the BSS. */ memset(__bss_start, 0, __bss_end - __bss_start);
@@ -158,6 +148,8 @@ void board_init_f(ulong dummy) hang(); }
+ preloader_console_init(); + enable_tzc380();
power_init_board(); diff --git a/configs/imx8mm_evk_defconfig b/configs/imx8mm_evk_defconfig index 81268788fa1..cc5f2801b15 100644 --- a/configs/imx8mm_evk_defconfig +++ b/configs/imx8mm_evk_defconfig @@ -78,6 +78,7 @@ CONFIG_SPL_DM_PMIC_PCA9450=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y
Signed-off-by: Peng Fan peng.fan@nxp.com --- board/freescale/imx8mn_evk/spl.c | 12 ++---------- configs/imx8mn_ddr4_evk_defconfig | 1 + configs/imx8mn_evk_defconfig | 1 + 3 files changed, 4 insertions(+), 10 deletions(-)
diff --git a/board/freescale/imx8mn_evk/spl.c b/board/freescale/imx8mn_evk/spl.c index 03f2a56e805..8708c93fa34 100644 --- a/board/freescale/imx8mn_evk/spl.c +++ b/board/freescale/imx8mn_evk/spl.c @@ -110,14 +110,8 @@ int board_fit_config_name_match(const char *name) } #endif
-static iomux_v3_cfg_t const uart_pads[] = { - IMX8MN_PAD_UART2_RXD__UART2_DCE_RX | MUX_PAD_CTRL(UART_PAD_CTRL), - IMX8MN_PAD_UART2_TXD__UART2_DCE_TX | MUX_PAD_CTRL(UART_PAD_CTRL), -}; - static iomux_v3_cfg_t const wdog_pads[] = { IMX8MN_PAD_GPIO1_IO02__WDOG1_WDOG_B | MUX_PAD_CTRL(WDOG_PAD_CTRL), }; @@ -130,8 +124,6 @@ int board_early_init_f(void)
@@ -147,8 +139,6 @@ void board_init_f(ulong dummy)
timer_init();
/* DDR initialization */ diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index 917cdb5aa9d..474d9cfa4d2 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -76,6 +76,7 @@ CONFIG_PINCTRL_IMX8M=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 7749ebe537e..5bc175154ba 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -83,6 +83,7 @@ CONFIG_DM_REGULATOR=y CONFIG_SPL_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y
timer_init();
enable_tzc380(); /* DDR initialization */
diff --git a/configs/imx8mn_ddr4_evk_defconfig b/configs/imx8mn_ddr4_evk_defconfig index 917cdb5aa9d..474d9cfa4d2 100644 --- a/configs/imx8mn_ddr4_evk_defconfig +++ b/configs/imx8mn_ddr4_evk_defconfig @@ -76,6 +76,7 @@ CONFIG_PINCTRL_IMX8M=y CONFIG_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y diff --git a/configs/imx8mn_evk_defconfig b/configs/imx8mn_evk_defconfig index 7749ebe537e..5bc175154ba 100644 --- a/configs/imx8mn_evk_defconfig +++ b/configs/imx8mn_evk_defconfig @@ -83,6 +83,7 @@ CONFIG_DM_REGULATOR=y CONFIG_SPL_DM_REGULATOR=y CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_SYSRESET=y CONFIG_SPL_SYSRESET=y -- 2.35.1
Peng,
I see you've been able to get SPL DM_SERIAL to work on IMX8M. This patch won't apply by the way due to commit ff1c7961d813 ("ARM: imx: imx8mn-evk: enable DM_SERIAL") so I think you need to rebase.
I have not been able to get SPL DM_SERIAL to work on IMX8MM/IMX8MN... it hangs my board. Is this due to moving preloader_console_init() perhaps? Moving it didn't work for me.
Please explain the move of preloader_console_init() and please let me know if you have tested this on imx/master. Fabio, perhaps you can test?
Best Regards,
Tim
timer_init();
Peng,
Peng,
I see my mistake now... the preloader_console_init() must come after spl_early_init().
You still need to rebase on imx/master and you should also add a comment to the commit such as: "move the preloader_console_init() call after spl_early_init() to avoid board hang" or perhaps you can come up with a reason for why the board hangs otherwise. Is it that spl_early_init() does the relocation and we need to be after that?
Best Regards,
Tim
Marked related nodes as u-boot,dm-spl for serial driver model Enable CONFIG_DM_SERIAL
Signed-off-by: Peng Fan peng.fan@nxp.com --- arch/arm/dts/imx8mq-evk-u-boot.dtsi | 32 +++++++++++++++++++++++++++++ configs/imx8mq_evk_defconfig | 1 + 2 files changed, 33 insertions(+)
diff --git a/arch/arm/dts/imx8mq-evk-u-boot.dtsi b/arch/arm/dts/imx8mq-evk-u-boot.dtsi index 6f9c81462ea..919c1f66d38 100644 --- a/arch/arm/dts/imx8mq-evk-u-boot.dtsi +++ b/arch/arm/dts/imx8mq-evk-u-boot.dtsi @@ -2,6 +2,34 @@
#include "imx8mq-u-boot.dtsi"
+&{/soc@0} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30000000} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30400000} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@30800000} { + u-boot,dm-spl; +}; + +&{/soc@0/bus@32c00000} { + u-boot,dm-spl; +}; + +&iomuxc { + u-boot,dm-spl; +}; + +&pinctrl_uart1 { + u-boot,dm-spl; +}; + &usdhc1 { mmc-hs400-1_8v; }; @@ -10,3 +38,7 @@ sd-uhs-sdr104; sd-uhs-ddr50; }; + +&uart1 { + u-boot,dm-spl; +}; diff --git a/configs/imx8mq_evk_defconfig b/configs/imx8mq_evk_defconfig index df7a259f35a..780f93103c7 100644 --- a/configs/imx8mq_evk_defconfig +++ b/configs/imx8mq_evk_defconfig @@ -80,6 +80,7 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_SPL_POWER_I2C=y CONFIG_DM_RESET=y +CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y CONFIG_DM_THERMAL=y CONFIG_USB=y
Peng Fan (OSS)
Tim Harvey
