[U-Boot] [PATCH 7/8] powerpc/85xx: do not initialize QE if QE's firmware is in nand flash
For some board which doesn't have NOR flash and the QE's firmware(ucode) is saved in its NAND flash, we don't want call qe_init in cpu_init_r, but will call it later after nand is initialized.
Signed-off-by: Haiying Wang Haiying.Wang@freescale.com --- arch/powerpc/cpu/mpc85xx/cpu_init.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/cpu_init.c b/arch/powerpc/cpu/mpc85xx/cpu_init.c index 4b8faa5..eb34378 100644 --- a/arch/powerpc/cpu/mpc85xx/cpu_init.c +++ b/arch/powerpc/cpu/mpc85xx/cpu_init.c @@ -369,7 +369,7 @@ int cpu_init_r(void)
enable_cpc();
-#ifdef CONFIG_QE +#if defined(CONFIG_QE) && !defined(CONFIG_SYS_QE_FW_IN_NAND) uint qe_base = CONFIG_SYS_IMMR + 0x00080000; /* QE immr base */ qe_init(qe_base); qe_reset();
On Dec 1, 2010, at 9:50 AM, Haiying.Wang@freescale.com Haiying.Wang@freescale.com wrote:
enable_cpc();
-#ifdef CONFIG_QE +#if defined(CONFIG_QE) && !defined(CONFIG_SYS_QE_FW_IN_NAND) uint qe_base = CONFIG_SYS_IMMR + 0x00080000; /* QE immr base */ qe_init(qe_base); qe_reset(); -- 1.7.3.1.50.g1e633
Any reason to just not move QE init for everyone?
- k
enable_cpc();
That was based on Wolfgang's comment: http://lists.denx.de/pipermail/u-boot/2010-August/075657.html
Haiying
enable_cpc();
Haiying
I think wolfgang's gripe is about putting the code into generic board_init_r().
I think we could move it so its in misc_init_r.
- k
Haiying
So we should move qe_init out from cpu_init_r, and to a misc_init_r? should misc_init_r be defined also in 83xx/85xx's cpu_init.c file? You may see my 8/8 patch in which I defined misc_init_r for P1021 in it's board c file. I just did not want to touch the existing qe_init routines for 83xx/85xx.
Haiying
Haiying Wang
Kumar Gala
