[U-Boot] [PATCH 17/19] ColdFire: Add MCF5301x CPU header files
Signed-off-by: TsiChung Liew Tsi-Chung.Liew@freescale.com --- include/asm-m68k/immap.h | 32 +++ include/asm-m68k/immap_5301x.h | 324 +++++++++++++++++++++ include/asm-m68k/m5301x.h | 604 ++++++++++++++++++++++++++++++++++++++++ 3 files changed, 960 insertions(+), 0 deletions(-) create mode 100644 include/asm-m68k/immap_5301x.h create mode 100644 include/asm-m68k/m5301x.h
diff --git a/include/asm-m68k/immap.h b/include/asm-m68k/immap.h index ccd7c2b..93f730f 100644 --- a/include/asm-m68k/immap.h +++ b/include/asm-m68k/immap.h @@ -227,6 +227,38 @@ #endif #endif /* CONFIG_M5282 */
+#if defined(CONFIG_MCF5301x) +#include <asm/immap_5301x.h> +#include <asm/m5301x.h> + +#define CONFIG_SYS_FEC0_IOBASE (MMAP_FEC0) +#define CONFIG_SYS_FEC1_IOBASE (MMAP_FEC1) +#define CONFIG_SYS_UART_BASE (MMAP_UART0 + (CONFIG_SYS_UART_PORT * 0x4000)) + +#define CONFIG_SYS_MCFRTC_BASE (MMAP_RTC) + +/* Timer */ +#ifdef CONFIG_MCFTMR +#define CONFIG_SYS_UDELAY_BASE (MMAP_DTMR0) +#define CONFIG_SYS_TMR_BASE (MMAP_DTMR1) +#define CONFIG_SYS_TMRPND_REG (((volatile int0_t *)(CONFIG_SYS_INTR_BASE))->iprh0) +#define CONFIG_SYS_TMRINTR_NO (INT0_HI_DTMR1) +#define CONFIG_SYS_TMRINTR_MASK (INTC_IPRH_INT33) +#define CONFIG_SYS_TMRINTR_PEND (CONFIG_SYS_TMRINTR_MASK) +#define CONFIG_SYS_TMRINTR_PRI (6) +#define CONFIG_SYS_TIMER_PRESCALER (((gd->bus_clk / 1000000) - 1) << 8) +#endif + +#ifdef CONFIG_MCFPIT +#define CONFIG_SYS_UDELAY_BASE (MMAP_PIT0) +#define CONFIG_SYS_PIT_BASE (MMAP_PIT1) +#define CONFIG_SYS_PIT_PRESCALE (6) +#endif + +#define CONFIG_SYS_INTR_BASE (MMAP_INTC0) +#define CONFIG_SYS_NUM_IRQS (128) +#endif /* CONFIG_M5301x */ + #if defined(CONFIG_M5329) || defined(CONFIG_M5373) #include <asm/immap_5329.h> #include <asm/m5329.h> diff --git a/include/asm-m68k/immap_5301x.h b/include/asm-m68k/immap_5301x.h new file mode 100644 index 0000000..87ac770 --- /dev/null +++ b/include/asm-m68k/immap_5301x.h @@ -0,0 +1,324 @@ +/* + * MCF5301x Internal Memory Map + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __IMMAP_5301X__ +#define __IMMAP_5301X__ + +#define MMAP_SCM1 (CONFIG_SYS_MBAR + 0x00000000) +#define MMAP_XBS (CONFIG_SYS_MBAR + 0x00004000) +#define MMAP_FBCS (CONFIG_SYS_MBAR + 0x00008000) +#define MMAP_MPU (CONFIG_SYS_MBAR + 0x00014000) +#define MMAP_FEC0 (CONFIG_SYS_MBAR + 0x00030000) +#define MMAP_FEC1 (CONFIG_SYS_MBAR + 0x00034000) +#define MMAP_SCM2 (CONFIG_SYS_MBAR + 0x00040000) +#define MMAP_EDMA (CONFIG_SYS_MBAR + 0x00044000) +#define MMAP_INTC0 (CONFIG_SYS_MBAR + 0x00048000) +#define MMAP_INTC1 (CONFIG_SYS_MBAR + 0x0004C000) +#define MMAP_INTCACK (CONFIG_SYS_MBAR + 0x00054000) +#define MMAP_I2C (CONFIG_SYS_MBAR + 0x00058000) +#define MMAP_DSPI (CONFIG_SYS_MBAR + 0x0005C000) +#define MMAP_UART0 (CONFIG_SYS_MBAR + 0x00060000) +#define MMAP_UART1 (CONFIG_SYS_MBAR + 0x00064000) +#define MMAP_UART2 (CONFIG_SYS_MBAR + 0x00068000) +#define MMAP_DTMR0 (CONFIG_SYS_MBAR + 0x00070000) +#define MMAP_DTMR1 (CONFIG_SYS_MBAR + 0x00074000) +#define MMAP_DTMR2 (CONFIG_SYS_MBAR + 0x00078000) +#define MMAP_DTMR3 (CONFIG_SYS_MBAR + 0x0007C000) +#define MMAP_PIT0 (CONFIG_SYS_MBAR + 0x00080000) +#define MMAP_PIT1 (CONFIG_SYS_MBAR + 0x00084000) +#define MMAP_PIT2 (CONFIG_SYS_MBAR + 0x00088000) +#define MMAP_PIT3 (CONFIG_SYS_MBAR + 0x0008C000) +#define MMAP_EPORT0 (CONFIG_SYS_MBAR + 0x00090000) +#define MMAP_EPORT1 (CONFIG_SYS_MBAR + 0x00094000) +#define MMAP_VOICOD (CONFIG_SYS_MBAR + 0x0009C000) +#define MMAP_RCM (CONFIG_SYS_MBAR + 0x000A0000) +#define MMAP_CCM (CONFIG_SYS_MBAR + 0x000A0004) +#define MMAP_GPIO (CONFIG_SYS_MBAR + 0x000A4000) +#define MMAP_RTC (CONFIG_SYS_MBAR + 0x000A8000) +#define MMAP_SIM (CONFIG_SYS_MBAR + 0x000AC000) +#define MMAP_USBOTG (CONFIG_SYS_MBAR + 0x000B0000) +#define MMAP_USBH (CONFIG_SYS_MBAR + 0x000B4000) +#define MMAP_SDRAM (CONFIG_SYS_MBAR + 0x000B8000) +#define MMAP_SSI (CONFIG_SYS_MBAR + 0x000BC000) +#define MMAP_PLL (CONFIG_SYS_MBAR + 0x000C0000) +#define MMAP_RNG (CONFIG_SYS_MBAR + 0x000C4000) +#define MMAP_IIM (CONFIG_SYS_MBAR + 0x000C8000) +#define MMAP_ESDHC (CONFIG_SYS_MBAR + 0x000CC000) + +#include <asm/coldfire/crossbar.h> +#include <asm/coldfire/dspi.h> +#include <asm/coldfire/edma.h> +#include <asm/coldfire/eport.h> +#include <asm/coldfire/flexbus.h> +#include <asm/coldfire/intctrl.h> +#include <asm/coldfire/ssi.h> +#include <asm/coldfire/rng.h> +#include <asm/rtc.h> + +/* System Controller Module */ +typedef struct scm1 { + u32 mpr; /* 0x00 Master Privilege */ + u32 rsvd1[7]; + u32 pacra; /* 0x20 Peripheral Access Ctrl A */ + u32 pacrb; /* 0x24 Peripheral Access Ctrl B */ + u32 pacrc; /* 0x28 Peripheral Access Ctrl C */ + u32 pacrd; /* 0x2C Peripheral Access Ctrl D */ + u32 rsvd2[4]; + u32 pacre; /* 0x40 Peripheral Access Ctrl E */ + u32 pacrf; /* 0x44 Peripheral Access Ctrl F */ + u32 pacrg; /* 0x48 Peripheral Access Ctrl G */ +} scm1_t; + +typedef struct scm2 { + u8 rsvd1[19]; /* 0x00 - 0x12 */ + u8 wcr; /* 0x13 */ + u16 rsvd2; /* 0x14 - 0x15 */ + u16 cwcr; /* 0x16 */ + u8 rsvd3[3]; /* 0x18 - 0x1A */ + u8 cwsr; /* 0x1B */ + u8 rsvd4[3]; /* 0x1C - 0x1E */ + u8 scmisr; /* 0x1F */ + u32 rsvd5; /* 0x20 - 0x23 */ + u8 bcr; /* 0x24 */ + u8 rsvd6[74]; /* 0x25 - 0x6F */ + u32 cfadr; /* 0x70 */ + u8 rsvd7; /* 0x74 */ + u8 cfier; /* 0x75 */ + u8 cfloc; /* 0x76 */ + u8 cfatr; /* 0x77 */ + u32 rsvd8; /* 0x78 - 0x7B */ + u32 cfdtr; /* 0x7C */ +} scm2_t; + +/* PWM module */ +typedef struct pwm_ctrl { + u8 en; /* 0x00 PWM Enable */ + u8 pol; /* 0x01 Polarity */ + u8 clk; /* 0x02 Clock Select */ + u8 prclk; /* 0x03 Prescale Clock Select */ + u8 cae; /* 0x04 Center Align Enable */ + u8 ctl; /* 0x05 Ctrl */ + u8 res1[2]; /* 0x06 - 0x07 */ + u8 scla; /* 0x08 Scale A */ + u8 sclb; /* 0x09 Scale B */ + u8 res2[2]; /* 0x0A - 0x0B */ + u8 cnt0; /* 0x0C Channel 0 Counter */ + u8 cnt1; /* 0x0D Channel 1 Counter */ + u8 cnt2; /* 0x0E Channel 2 Counter */ + u8 cnt3; /* 0x0F Channel 3 Counter */ + u8 cnt4; /* 0x10 Channel 4 Counter */ + u8 cnt5; /* 0x11 Channel 5 Counter */ + u8 cnt6; /* 0x12 Channel 6 Counter */ + u8 cnt7; /* 0x13 Channel 7 Counter */ + u8 per0; /* 0x14 Channel 0 Period */ + u8 per1; /* 0x15 Channel 1 Period */ + u8 per2; /* 0x16 Channel 2 Period */ + u8 per3; /* 0x17 Channel 3 Period */ + u8 per4; /* 0x18 Channel 4 Period */ + u8 per5; /* 0x19 Channel 5 Period */ + u8 per6; /* 0x1A Channel 6 Period */ + u8 per7; /* 0x1B Channel 7 Period */ + u8 dty0; /* 0x1C Channel 0 Duty */ + u8 dty1; /* 0x1D Channel 1 Duty */ + u8 dty2; /* 0x1E Channel 2 Duty */ + u8 dty3; /* 0x1F Channel 3 Duty */ + u8 dty4; /* 0x20 Channel 4 Duty */ + u8 dty5; /* 0x21 Channel 5 Duty */ + u8 dty6; /* 0x22 Channel 6 Duty */ + u8 dty7; /* 0x23 Channel 7 Duty */ + u8 sdn; /* 0x24 Shutdown */ + u8 res3[3]; /* 0x25 - 0x27 */ +} pwm_t; + +/* Chip configuration module */ +typedef struct rcm { + u8 rcr; + u8 rsr; +} rcm_t; + +typedef struct ccm_ctrl { + u16 ccr; /* 0x00 Chip Cfg */ + u16 res1; /* 0x02 */ + u16 rcon; /* 0x04 Reset Cfg */ + u16 cir; /* 0x06 Chip ID */ + u32 res2; /* 0x08 */ + u16 misccr; /* 0x0A Misc Ctrl */ + u16 cdr; /* 0x0C Clock divider */ + u16 uhcsr; /* 0x10 USB Host status */ + u16 uocsr; /* 0x12 USB On-the-Go Status */ + u16 res3; /* 0x14 */ + u16 codeccr; /* 0x16 Codec Control */ + u16 misccr2; /* 0x18 Misc2 Ctrl */ +} ccm_t; + +/* GPIO port */ +typedef struct gpio_ctrl { + /* Port Output Data */ + u8 podr_fbctl; /* 0x00 */ + u8 podr_be; /* 0x01 */ + u8 podr_cs; /* 0x02 */ + u8 podr_dspi; /* 0x03 */ + u8 res01; /* 0x04 */ + u8 podr_fec0; /* 0x05 */ + u8 podr_feci2c; /* 0x06 */ + u8 res02[2]; /* 0x07 - 0x08 */ + u8 podr_simp1; /* 0x09 */ + u8 podr_simp0; /* 0x0A */ + u8 podr_timer; /* 0x0B */ + u8 podr_uart; /* 0x0C */ + u8 podr_debug; /* 0x0D */ + u8 res03; /* 0x0E */ + u8 podr_sdhc; /* 0x0F */ + u8 podr_ssi; /* 0x10 */ + u8 res04[3]; /* 0x11 - 0x13 */ + + /* Port Data Direction */ + u8 pddr_fbctl; /* 0x14 */ + u8 pddr_be; /* 0x15 */ + u8 pddr_cs; /* 0x16 */ + u8 pddr_dspi; /* 0x17 */ + u8 res05; /* 0x18 */ + u8 pddr_fec0; /* 0x19 */ + u8 pddr_feci2c; /* 0x1A */ + u8 res06[2]; /* 0x1B - 0x1C */ + u8 pddr_simp1; /* 0x1D */ + u8 pddr_simp0; /* 0x1E */ + u8 pddr_timer; /* 0x1F */ + u8 pddr_uart; /* 0x20 */ + u8 pddr_debug; /* 0x21 */ + u8 res07; /* 0x22 */ + u8 pddr_sdhc; /* 0x23 */ + u8 pddr_ssi; /* 0x24 */ + u8 res08[3]; /* 0x25 - 0x27 */ + + /* Port Data Direction */ + u8 ppdr_fbctl; /* 0x28 */ + u8 ppdr_be; /* 0x29 */ + u8 ppdr_cs; /* 0x2A */ + u8 ppdr_dspi; /* 0x2B */ + u8 res09; /* 0x2C */ + u8 ppdr_fec0; /* 0x2D */ + u8 ppdr_feci2c; /* 0x2E */ + u8 res10[2]; /* 0x2F - 0x30 */ + u8 ppdr_simp1; /* 0x31 */ + u8 ppdr_simp0; /* 0x32 */ + u8 ppdr_timer; /* 0x33 */ + u8 ppdr_uart; /* 0x34 */ + u8 ppdr_debug; /* 0x35 */ + u8 res11; /* 0x36 */ + u8 ppdr_sdhc; /* 0x37 */ + u8 ppdr_ssi; /* 0x38 */ + u8 res12[3]; /* 0x39 - 0x3B */ + + /* Port Clear Output Data */ + u8 pclrr_fbctl; /* 0x3C */ + u8 pclrr_be; /* 0x3D */ + u8 pclrr_cs; /* 0x3E */ + u8 pclrr_dspi; /* 0x3F */ + u8 res13; /* 0x40 */ + u8 pclrr_fec0; /* 0x41 */ + u8 pclrr_feci2c; /* 0x42 */ + u8 res14[2]; /* 0x43 - 0x44 */ + u8 pclrr_simp1; /* 0x45 */ + u8 pclrr_simp0; /* 0x46 */ + u8 pclrr_timer; /* 0x47 */ + u8 pclrr_uart; /* 0x48 */ + u8 pclrr_debug; /* 0x49 */ + u8 res15; /* 0x4A */ + u8 pclrr_sdhc; /* 0x4B */ + u8 pclrr_ssi; /* 0x4C */ + u8 res16[3]; /* 0x4D - 0x4F */ + + /* Pin Assignment */ + u8 par_fbctl; /* 0x50 */ + u8 par_be; /* 0x51 */ + u8 par_cs; /* 0x52 */ + u8 res17; /* 0x53 */ + u8 par_dspih; /* 0x54 */ + u8 par_dspil; /* 0x55 */ + u8 par_fec; /* 0x56 */ + u8 par_feci2c; /* 0x57 */ + u8 par_irq0h; /* 0x58 */ + u8 par_irq0l; /* 0x59 */ + u8 par_irq1h; /* 0x5A */ + u8 par_irq1l; /* 0x5B */ + u8 par_simp1h; /* 0x5C */ + u8 par_simp1l; /* 0x5D */ + u8 par_simp0; /* 0x5E */ + u8 par_timer; /* 0x5F */ + u8 par_uart; /* 0x60 */ + u8 res18; /* 0x61 */ + u8 par_debug; /* 0x62 */ + u8 par_sdhc; /* 0x63 */ + u8 par_ssih; /* 0x64 */ + u8 par_ssil; /* 0x65 */ + u8 res19[2]; /* 0x66 - 0x67 */ + + /* Mode Select Control */ + /* Drive Strength Control */ + u8 mscr_mscr1; /* 0x68 */ + u8 mscr_mscr2; /* 0x69 */ + u8 mscr_mscr3; /* 0x6A */ + u8 mscr_mscr45; /* 0x6B */ + u8 srcr_dspi; /* 0x6C */ + u8 dscr_fec; /* 0x6D */ + u8 srcr_i2c; /* 0x6E */ + u8 srcr_irq; /* 0x6F */ + + u8 srcr_sim; /* 0x70 */ + u8 srcr_timer; /* 0x71 */ + u8 srcr_uart; /* 0x72 */ + u8 res20; /* 0x73 */ + u8 srcr_sdhc; /* 0x74 */ + u8 srcr_ssi; /* 0x75 */ + u8 res21[2]; /* 0x76 - 0x77 */ + u8 pcr_pcrh; /* 0x78 */ + u8 pcr_pcrl; /* 0x79 */ +} gpio_t; + +/* SDRAM controller */ +typedef struct sdram_ctrl { + u32 mode; /* 0x00 Mode/Extended Mode */ + u32 ctrl; /* 0x04 Ctrl */ + u32 cfg1; /* 0x08 Cfg 1 */ + u32 cfg2; /* 0x0C Cfg 2 */ + u32 res1[64]; /* 0x10 - 0x10F */ + u32 cs0; /* 0x110 Chip Select 0 Cfg */ + u32 cs1; /* 0x114 Chip Select 1 Cfg */ +} sdram_t; + +/* Clock Module */ +typedef struct pll_ctrl { + u32 pcr; /* 0x00 Ctrl */ + u32 pdr; /* 0x04 Divider */ + u32 psr; /* 0x08 Status */ +} pll_t; + +typedef struct rtcex { + u32 rsvd1[3]; + u32 gocu; + u32 gocl; +} rtcex_t; +#endif /* __IMMAP_5301X__ */ diff --git a/include/asm-m68k/m5301x.h b/include/asm-m68k/m5301x.h new file mode 100644 index 0000000..52bbb87 --- /dev/null +++ b/include/asm-m68k/m5301x.h @@ -0,0 +1,604 @@ +/* + * m5301x.h -- Definitions for Freescale Coldfire 5301x + * + * Copyright (C) 2004-2008 Freescale Semiconductor, Inc. + * TsiChung Liew (Tsi-Chung.Liew@freescale.com) + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef m5301x_h +#define m5301x_h + +/* *** System Control Module (SCM) *** */ +#define SCM_MPR_MPROT0(x) (((x) & 0x0F) << 28) +#define SCM_MPR_MPROT1(x) (((x) & 0x0F) << 24) +#define SCM_MPR_MPROT2(x) (((x) & 0x0F) << 20) +#define SCM_MPR_MPROT4(x) (((x) & 0x0F) << 12) +#define SCM_MPR_MPROT5(x) (((x) & 0x0F) << 8) +#define SCM_MPR_MPROT6(x) (((x) & 0x0F) << 4) +#define MPROT_MTR 4 +#define MPROT_MTW 2 +#define MPROT_MPL 1 + +#define SCM_PACRA_PACR0(x) (((x) & 0x0F) << 28) +#define SCM_PACRA_PACR1(x) (((x) & 0x0F) << 24) +#define SCM_PACRA_PACR2(x) (((x) & 0x0F) << 20) +#define SCM_PACRA_PACR5(x) (((x) & 0x0F) << 8) + +#define SCM_PACRB_PACR12(x) (((x) & 0x0F) << 12) +#define SCM_PACRB_PACR13(x) (((x) & 0x0F) << 8) + +#define SCM_PACRC_PACR16(x) (((x) & 0x0F) << 28) +#define SCM_PACRC_PACR17(x) (((x) & 0x0F) << 24) +#define SCM_PACRC_PACR18(x) (((x) & 0x0F) << 20) +#define SCM_PACRC_PACR19(x) (((x) & 0x0F) << 16) +#define SCM_PACRC_PACR21(x) (((x) & 0x0F) << 8) +#define SCM_PACRC_PACR22(x) (((x) & 0x0F) << 4) +#define SCM_PACRC_PACR23(x) ((x) & 0x0F) + +#define SCM_PACRD_PACR24(x) (((x) & 0x0F) << 28) +#define SCM_PACRD_PACR25(x) (((x) & 0x0F) << 24) +#define SCM_PACRD_PACR26(x) (((x) & 0x0F) << 20) +#define SCM_PACRD_PACR28(x) (((x) & 0x0F) << 12) +#define SCM_PACRD_PACR29(x) (((x) & 0x0F) << 8) +#define SCM_PACRD_PACR30(x) (((x) & 0x0F) << 4) +#define SCM_PACRD_PACR31(x) ((x) & 0x0F) + +#define SCM_PACRE_PACR32(x) (((x) & 0x0F) << 28) +#define SCM_PACRE_PACR33(x) (((x) & 0x0F) << 24) +#define SCM_PACRE_PACR34(x) (((x) & 0x0F) << 20) +#define SCM_PACRE_PACR35(x) (((x) & 0x0F) << 16) +#define SCM_PACRE_PACR36(x) (((x) & 0x0F) << 12) +#define SCM_PACRE_PACR37(x) (((x) & 0x0F) << 8) +#define SCM_PACRE_PACR39(x) ((x) & 0x0F) + +#define SCM_PACRF_PACR40(x) (((x) & 0x0F) << 28) +#define SCM_PACRF_PACR41(x) (((x) & 0x0F) << 24) +#define SCM_PACRF_PACR42(x) (((x) & 0x0F) << 20) +#define SCM_PACRF_PACR43(x) (((x) & 0x0F) << 16) +#define SCM_PACRF_PACR44(x) (((x) & 0x0F) << 12) +#define SCM_PACRF_PACR45(x) (((x) & 0x0F) << 8) +#define SCM_PACRF_PACR46(x) (((x) & 0x0F) << 4) +#define SCM_PACRF_PACR47(x) ((x) & 0x0F) + +#define SCM_PACRG_PACR48(x) (((x) & 0x0F) << 28) +#define SCM_PACRG_PACR49(x) (((x) & 0x0F) << 24) +#define SCM_PACRG_PACR50(x) (((x) & 0x0F) << 20) +#define SCM_PACRG_PACR51(x) (((x) & 0x0F) << 16) + +#define PACR_SP 4 +#define PACR_WP 2 +#define PACR_TP 1 + +#define SCM_CWCR_RO (0x8000) +#define SCM_CWCR_CWR_WH (0x0100) +#define SCM_CWCR_CWE (0x0080) +#define SCM_CWCR_CWRI_WINDOW (0x0060) +#define SCM_CWCR_CWRI_RESET (0x0040) +#define SCM_CWCR_CWRI_INT_RESET (0x0020) +#define SCM_CWCR_CWRI_INT (0x0000) +#define SCM_CWCR_CWT(x) (((x) & 0x001F)) + +#define SCM_ISR_CFEI (0x02) +#define SCM_ISR_CWIC (0x01) + +#define BCR_GBR (0x00000200) +#define BCR_GBW (0x00000100) +#define BCR_S7 (0x00000080) +#define BCR_S6 (0x00000040) +#define BCR_S4 (0x00000010) +#define BCR_S1 (0x00000002) + +#define SCM_CFIER_ECFEI (0x01) + +#define SCM_CFLOC_LOC (0x80) + +#define SCM_CFATR_WRITE (0x80) +#define SCM_CFATR_SZ32 (0x20) +#define SCM_CFATR_SZ16 (0x10) +#define SCM_CFATR_SZ08 (0x00) +#define SCM_CFATR_CACHE (0x08) +#define SCM_CFATR_MODE (0x02) +#define SCM_CFATR_TYPE (0x01) + +/* *** Interrupt Controller (INTC) *** */ +#define INT0_LO_RSVD0 (0) +#define INT0_LO_EPORT1 (1) +#define INT0_LO_EPORT2 (2) +#define INT0_LO_EPORT3 (3) +#define INT0_LO_EPORT4 (4) +#define INT0_LO_EPORT5 (5) +#define INT0_LO_EPORT6 (6) +#define INT0_LO_EPORT7 (7) +#define INT0_LO_EDMA_00 (8) +#define INT0_LO_EDMA_01 (9) +#define INT0_LO_EDMA_02 (10) +#define INT0_LO_EDMA_03 (11) +#define INT0_LO_EDMA_04 (12) +#define INT0_LO_EDMA_05 (13) +#define INT0_LO_EDMA_06 (14) +#define INT0_LO_EDMA_07 (15) +#define INT0_LO_EDMA_08 (16) +#define INT0_LO_EDMA_09 (17) +#define INT0_LO_EDMA_10 (18) +#define INT0_LO_EDMA_11 (19) +#define INT0_LO_EDMA_12 (20) +#define INT0_LO_EDMA_13 (21) +#define INT0_LO_EDMA_14 (22) +#define INT0_LO_EDMA_15 (23) +#define INT0_LO_EDMA_ERR (24) +#define INT0_LO_SCM_CWIC (25) +#define INT0_LO_UART0 (26) +#define INT0_LO_UART1 (27) +#define INT0_LO_UART2 (28) +#define INT0_LO_RSVD1 (29) +#define INT0_LO_I2C (30) +#define INT0_LO_DSPI (31) +#define INT0_HI_DTMR0 (32) +#define INT0_HI_DTMR1 (33) +#define INT0_HI_DTMR2 (34) +#define INT0_HI_DTMR3 (35) +#define INT0_HI_FEC0_TXF (36) +#define INT0_HI_FEC0_TXB (37) +#define INT0_HI_FEC0_UN (38) +#define INT0_HI_FEC0_RL (39) +#define INT0_HI_FEC0_RXF (40) +#define INT0_HI_FEC0_RXB (41) +#define INT0_HI_FEC0_MII (42) +#define INT0_HI_FEC0_LC (43) +#define INT0_HI_FEC0_HBERR (44) +#define INT0_HI_FEC0_GRA (45) +#define INT0_HI_FEC0_EBERR (46) +#define INT0_HI_FEC0_BABT (47) +#define INT0_HI_FEC0_BABR (48) +#define INT0_HI_FEC1_TXF (49) +#define INT0_HI_FEC1_TXB (50) +#define INT0_HI_FEC1_UN (51) +#define INT0_HI_FEC1_RL (52) +#define INT0_HI_FEC1_RXF (53) +#define INT0_HI_FEC1_RXB (54) +#define INT0_HI_FEC1_MII (55) +#define INT0_HI_FEC1_LC (56) +#define INT0_HI_FEC1_HBERR (57) +#define INT0_HI_FEC1_GRA (58) +#define INT0_HI_FEC1_EBERR (59) +#define INT0_HI_FEC1_BABT (60) +#define INT0_HI_FEC1_BABR (61) +#define INT0_HI_SCM_CFEI (62) + +/* 0 - 24 reserved */ +#define INT1_LO_EPORT1_FLAG0 (25) +#define INT1_LO_EPORT1_FLAG1 (26) +#define INT1_LO_EPORT1_FLAG2 (27) +#define INT1_LO_EPORT1_FLAG3 (28) +#define INT1_LO_EPORT1_FLAG4 (29) +#define INT1_LO_EPORT1_FLAG5 (30) +#define INT1_LO_EPORT1_FLAG6 (31) +#define INT1_LO_EPORT1_FLAG7 (32) +#define INT1_HI_DSPI_EOQF (33) +#define INT1_HI_DSPI_TFFF (34) +#define INT1_HI_DSPI_TCF (35) +#define INT1_HI_DSPI_TFUF (36) +#define INT1_HI_DSPI_RFDF (37) +#define INT1_HI_DSPI_RFOF (38) +#define INT1_HI_DSPI_RFOF_TFUF (39) +#define INT1_HI_RNG_EI (40) +#define INT1_HI_PLL_LOCF (41) +#define INT1_HI_PLL_LOLF (42) +#define INT1_HI_PIT0 (43) +#define INT1_HI_PIT1 (44) +#define INT1_HI_PIT2 (45) +#define INT1_HI_PIT3 (46) +#define INT1_HI_USBOTG_STS (47) +#define INT1_HI_USBHOST_STS (48) +#define INT1_HI_SSI (49) +/* 50 - 51 reserved */ +#define INT1_HI_RTC (52) +#define INT1_HI_CCM_USBSTAT (53) +#define INT1_HI_CODEC_OR (54) +#define INT1_HI_CODEC_RF_TE (55) +#define INT1_HI_CODEC_ROE (56) +#define INT1_HI_CODEC_TUE (57) +/* 58 reserved */ +#define INT1_HI_SIM1_DATA (59) +#define INT1_HI_SIM1_GENERAL (60) +/* 61 - 62 reserved */ +#define INT1_HI_SDHC (63) + +/* *** Reset Controller Module (RCM) *** */ +#define RCM_RCR_SOFTRST (0x80) +#define RCM_RCR_FRCRSTOUT (0x40) + +#define RCM_RSR_SOFT (0x20) +#define RCM_RSR_LOC (0x10) +#define RCM_RSR_POR (0x08) +#define RCM_RSR_EXT (0x04) +#define RCM_RSR_WDR_CORE (0x02) +#define RCM_RSR_LOL (0x01) + +/* *** Chip Configuration Module (CCM) *** */ +#define CCM_CCR_CSC (0x0020) +#define CCM_CCR_BOOTPS (0x0010) +#define CCM_CCR_LOAD (0x0008) +#define CCM_CCR_OSC_MODE (0x0004) +#define CCM_CCR_SDR_MODE (0x0002) +#define CCM_CCR_RESERVED (0x0001) + +#define CCM_RCON_SDR_32BIT_UNIFIED (0x0012) +#define CCM_RCON_DDR_8BIT_SPLIT (0x0010) +#define CCM_RCON_SDR_16BIT_UNIFIED (0x0002) +#define CCM_RCON_DDR_16BIT_SPLIT (0x0000) + +#define CCM_CIR_PIN(x) (((x) & 0x03FF) << 6) +#define CCM_CIR_PRN(x) ((x) & 0x003F) + +#define CCM_MISCCR_FECM (0x8000) +#define CCM_MISCCR_CDCSRC (0x4000) +#define CCM_MISCCR_PLL_LOCK (0x2000) +#define CCM_MISCCR_LIMP (0x1000) +#define CCM_MISCCR_BME (0x8000) +#define CCM_MISCCR_BMT_MASK (0xF8FF) +#define CCM_MISCCR_BMT(x) (((x) & 0x0007) << 8) +#define CCM_MISCCR_BMT_512 (0x0700) +#define CCM_MISCCR_BMT_1024 (0x0600) +#define CCM_MISCCR_BMT_2048 (0x0500) +#define CCM_MISCCR_BMT_4096 (0x0400) +#define CCM_MISCCR_BMT_8192 (0x0300) +#define CCM_MISCCR_BMT_16384 (0x0200) +#define CCM_MISCCR_BMT_32768 (0x0100) +#define CCM_MISCCR_BMT_65536 (0x0000) +#define CCM_MISCCR_TIM_DMA (0x0020) +#define CCM_MISCCR_SSI_SRC (0x0010) +#define CCM_MISCCR_USBH_OC (0x0008) +#define CCM_MISCCR_USBO_OC (0x0004) +#define CCM_MISCCR_USB_PUE (0x0002) +#define CCM_MISCCR_USB_SRC (0x0001) + +#define CCM_CDR_LPDIV(x) (((x) & 0x0F) << 8) +#define CCM_CDR_SSIDIV(x) ((x) & 0xFF) + +#define CCM_UOCSR_DPPD (0x2000) +#define CCM_UOCSR_DMPD (0x1000) +#define CCM_UOCSR_DRV_VBUS (0x0800) +#define CCM_UOCSR_CRG_VBUS (0x0400) +#define CCM_UOCSR_DCR_VBUS (0x0200) +#define CCM_UOCSR_DPPU (0x0100) +#define CCM_UOCSR_AVLD (0x0080) +#define CCM_UOCSR_BVLD (0x0040) +#define CCM_UOCSR_VVLD (0x0020) +#define CCM_UOCSR_SEND (0x0010) +#define CCM_UOCSR_PWRFLT (0x0008) +#define CCM_UOCSR_WKUP (0x0004) +#define CCM_UOCSR_UOMIE (0x0002) +#define CCM_UOCSR_XPDE (0x0001) + +#define CCM_UHCSR_PORTIND(x) (((x) & 0x0003) << 14) +#define CCM_UHCSR_DRV_VBUS (0x0010) +#define CCM_UHCSR_PWRFLT (0x0008) +#define CCM_UHCSR_WKUP (0x0004) +#define CCM_UHCSR_UHMIE (0x0002) +#define CCM_UHCSR_XPDE (0x0001) + +#define CCM_CODCR_BGREN (0x8000) +#define CCM_CODCR_REGEN (0x0080) + +#define CCM_MISC2_IGNLL (0x0008) +#define CCM_MISC2_DPS (0x0001) + +/* *** General Purpose I/O (GPIO) *** */ +#define GPIO_PDR_FBCTL ((x) & 0x0F) +#define GPIO_PDR_BE ((x) & 0x0F) +#define GPIO_PDR_CS32 (((x) & 0x03) << 4) +#define GPIO_PDR_CS10 (((x) & 0x03) << 4) +#define GPIO_PDR_DSPI ((x) & 0x7F) +#define GPIO_PDR_FEC0 ((x) & 0x7F) +#define GPIO_PDR_FECI2C ((x) & 0x3F) +#define GPIO_PDR_SIMP1 ((x) & 0x1F) +#define GPIO_PDR_SIMP0 ((x) & 0x1F) +#define GPIO_PDR_TIMER ((x) & 0x0F) +#define GPIO_PDR_UART ((x) & 0x3F) +#define GPIO_PDR_DEBUG (0x01) +#define GPIO_PDR_SDHC ((x) & 0x3F) +#define GPIO_PDR_SSI ((x) & 0x1F) + +#define GPIO_PAR_FBCTL_OE (0x80) +#define GPIO_PAR_FBCTL_TA (0x40) +#define GPIO_PAR_FBCTL_RWB (0x20) +#define GPIO_PAR_FBCTL_TS (0x18) + +#define GPIO_PAR_BE3 (0x40) +#define GPIO_PAR_BE2 (0x10) +#define GPIO_PAR_BE1 (0x04) +#define GPIO_PAR_BE0 (0x01) + +#define GPIO_PAR_CS5 (0x40) +#define GPIO_PAR_CS4 (0x10) +#define GPIO_PAR_CS1_MASK (0xF3) +#define GPIO_PAR_CS1_CS1 (0x0C) +#define GPIO_PAR_CS1_SDCS1 (0x08) +#define GPIO_PAR_CS0_MASK (0xFC) +#define GPIO_PAR_CS0_CS0 (0x03) +#define GPIO_PAR_CS0_CS4 (0x02) + +#define GPIO_PAR_DSPIH_SIN_MASK (0x3F) +#define GPIO_PAR_DSPIH_SIN (0xC0) +#define GPIO_PAR_DSPIH_SIN_U2RXD (0x80) +#define GPIO_PAR_DSPIH_SOUT_MASK (0xCF) +#define GPIO_PAR_DSPIH_SOUT (0x30) +#define GPIO_PAR_DSPIH_SOUT_U2TXD (0x20) +#define GPIO_PAR_DSPIH_SCK_MASK (0xF3) +#define GPIO_PAR_DSPIH_SCK (0x0C) +#define GPIO_PAR_DSPIH_SCK_U2CTS (0x08) +#define GPIO_PAR_DSPIH_PCS0_MASK (0xFC) +#define GPIO_PAR_DSPIH_PCS0 (0x03) +#define GPIO_PAR_DSPIH_PCS0_U2RTS (0x02) + +#define GPIO_PAR_DSPIL_PCS1_MASK (0x3F) +#define GPIO_PAR_DSPIL_PCS1 (0xC0) +#define GPIO_PAR_DSPIL_PCS2_MASK (0xCF) +#define GPIO_PAR_DSPIL_PCS2 (0x30) +#define GPIO_PAR_DSPIL_PCS2_USBH_OC (0x20) +#define GPIO_PAR_DSPIL_PCS3_MASK (0xF3) +#define GPIO_PAR_DSPIL_PCS3 (0x0C) +#define GPIO_PAR_DSPIL_PCS3_USBH_EN (0x08) + +#define GPIO_PAR_FEC1_7W_FEC (0x40) +#define GPIO_PAR_FEC1_RMII_FEC (0x10) +#define GPIO_PAR_FEC0_7W_FEC (0x04) +#define GPIO_PAR_FEC0_RMII_FEC (0x01) + +/* GPIO_PAR_FECI2C */ +#define GPIO_PAR_FECI2C_RMII0_MASK (0x3F) +#define GPIO_PAR_FECI2C_MDC0 (0x80) +#define GPIO_PAR_FECI2C_MDIO0 (0x40) +#define GPIO_PAR_FECI2C_RMII1_MASK (0xCF) +#define GPIO_PAR_FECI2C_MDC1 (0x20) +#define GPIO_PAR_FECI2C_MDIO1 (0x10) +#define GPIO_PAR_FECI2C_SDA_MASK (0xF3) +#define GPIO_PAR_FECI2C_SDA(x) (((x) & 0x03) << 2) +#define GPIO_PAR_FECI2C_SDA_SDA (0x0C) +#define GPIO_PAR_FECI2C_SDA_U2TXD (0x08) +#define GPIO_PAR_FECI2C_SDA_MDIO1 (0x04) +#define GPIO_PAR_FECI2C_SCL_MASK (0xFC) +#define GPIO_PAR_FECI2C_SCL(x) ((x) & 0x03) +#define GPIO_PAR_FECI2C_SCL_SCL (0x03) +#define GPIO_PAR_FECI2C_SCL_U2RXD (0x02) +#define GPIO_PAR_FECI2C_SCL_MDC1 (0x01) + +#define GPIO_PAR_IRQ0H_IRQ07_MASK (0x3F) +#define GPIO_PAR_IRQ0H_IRQ06_MASK (0xCF) +#define GPIO_PAR_IRQ0H_IRQ06_USBCLKIN (0x10) +#define GPIO_PAR_IRQ0H_IRQ04_MASK (0xFC) +#define GPIO_PAR_IRQ0H_IRQ04_DREQ0 (0x02) + +#define GPIO_PAR_IRQ0L_IRQ01_MASK (0xF3) +#define GPIO_PAR_IRQ0L_IRQ01_DREQ1 (0x08) + +#define GPIO_PAR_IRQ1H_IRQ17_DDATA3 (0x40) +#define GPIO_PAR_IRQ1H_IRQ16_DDATA2 (0x10) +#define GPIO_PAR_IRQ1H_IRQ15_DDATA1 (0x04) +#define GPIO_PAR_IRQ1H_IRQ14_DDATA0 (0x01) + +#define GPIO_PAR_IRQ1L_IRQ13_PST3 (0x40) +#define GPIO_PAR_IRQ1L_IRQ12_PST2 (0x10) +#define GPIO_PAR_IRQ1L_IRQ11_PST1 (0x04) +#define GPIO_PAR_IRQ1L_IRQ10_PST0 (0x01) + +#define GPIO_PAR_SIMP1H_DATA1_MASK (0x3F) +#define GPIO_PAR_SIMP1H_DATA1_SIMDATA1 (0xC0) +#define GPIO_PAR_SIMP1H_DATA1_SSITXD (0x80) +#define GPIO_PAR_SIMP1H_DATA1_U1TXD (0x40) +#define GPIO_PAR_SIMP1H_VEN1_MASK (0xCF) +#define GPIO_PAR_SIMP1H_VEN1_SIMVEN1 (0x30) +#define GPIO_PAR_SIMP1H_VEN1_SSIRXD (0x20) +#define GPIO_PAR_SIMP1H_VEN1_U1RXD (0x10) +#define GPIO_PAR_SIMP1H_RST1_MASK (0xF3) +#define GPIO_PAR_SIMP1H_RST1_SIMRST1 (0x0C) +#define GPIO_PAR_SIMP1H_RST1_SSIFS (0x08) +#define GPIO_PAR_SIMP1H_RST1_U1RTS (0x04) +#define GPIO_PAR_SIMP1H_PD1_MASK (0xFC) +#define GPIO_PAR_SIMP1H_PD1_SIMPD1 (0x03) +#define GPIO_PAR_SIMP1H_PD1_SSIBCLK (0x02) +#define GPIO_PAR_SIMP1H_PD1_U1CTS (0x01) + +#define GPIO_PAR_SIMP1L_CLK_MASK (0x3F) +#define GPIO_PAR_SIMP1L_CLK_CLK1 (0xC0) +#define GPIO_PAR_SIMP1L_CLK_SSIMCLK (0x80) + +#define GPIO_PAR_SIMP0_DATA0 (0x10) +#define GPIO_PAR_SIMP0_VEN0 (0x08) +#define GPIO_PAR_SIMP0_RST0 (0x04) +#define GPIO_PAR_SIMP0_PD0 (0x02) +#define GPIO_PAR_SIMP0_CLK0 (0x01) + +#define GPIO_PAR_TIN3(x) (((x) & 0x03) << 6) +#define GPIO_PAR_TIN2(x) (((x) & 0x03) << 4) +#define GPIO_PAR_TIN1(x) (((x) & 0x03) << 2) +#define GPIO_PAR_TIN0(x) ((x) & 0x03) +#define GPIO_PAR_TIN3_MASK (0x3F) +#define GPIO_PAR_TIN3_TIN3 (0xC0) +#define GPIO_PAR_TIN3_TOUT3 (0x80) +#define GPIO_PAR_TIN3_IRQ03 (0x40) +#define GPIO_PAR_TIN2_MASK (0xCF) +#define GPIO_PAR_TIN2_TIN2 (0x30) +#define GPIO_PAR_TIN2_TOUT2 (0x20) +#define GPIO_PAR_TIN2_IRQ02 (0x10) +#define GPIO_PAR_TIN1_MASK (0xF3) +#define GPIO_PAR_TIN1_TIN1 (0x0C) +#define GPIO_PAR_TIN1_TOUT1 (0x08) +#define GPIO_PAR_TIN1_DACK1 (0x04) +#define GPIO_PAR_TIN0_MASK (0xFC) +#define GPIO_PAR_TIN0_TIN0 (0x03) +#define GPIO_PAR_TIN0_TOUT0 (0x02) +#define GPIO_PAR_TIN0_CODEC_ALTCLK (0x01) + +#define GPIO_PAR_UART_U2TXD (0x80) +#define GPIO_PAR_UART_U2RXD (0x40) +#define GPIO_PAR_UART_U0TXD (0x20) +#define GPIO_PAR_UART_U0RXD (0x10) +#define GPIO_PAR_UART_RTS0(x) (((x) & 0x03) << 2) +#define GPIO_PAR_UART_CTS0(x) ((x) & 0x03) +#define GPIO_PAR_UART_RTS0_MASK (0xF3) +#define GPIO_PAR_UART_RTS0_U0RTS (0x0C) +#define GPIO_PAR_UART_RTS0_USBO_VBOC (0x08) +#define GPIO_PAR_UART_CTS0_MASK (0xFC) +#define GPIO_PAR_UART_CTS0_U0CTS (0x03) +#define GPIO_PAR_UART_CTS0_USB0_VBEN (0x02) +#define GPIO_PAR_UART_CTS0_USB_PULLUP (0x01) + +#define GPIO_PAR_DEBUG_ALLPST (0x80) + +#define GPIO_PAR_SDHC_DATA3 (0x20) +#define GPIO_PAR_SDHC_DATA2 (0x10) +#define GPIO_PAR_SDHC_DATA1 (0x08) +#define GPIO_PAR_SDHC_DATA0 (0x04) +#define GPIO_PAR_SDHC_CMD (0x02) +#define GPIO_PAR_SDHC_CLK (0x01) + +#define GPIO_PAR_SSIH_RXD(x) (((x) & 0x03) << 6) +#define GPIO_PAR_SSIH_TXD(x) (((x) & 0x03) << 4) +#define GPIO_PAR_SSIH_FS(x) (((x) & 0x03) << 2) +#define GPIO_PAR_SSIH_MCLK(x) ((x) & 0x03) +#define GPIO_PAR_SSIH_RXD_MASK (0x3F) +#define GPIO_PAR_SSIH_RXD_SSIRXD (0xC0) +#define GPIO_PAR_SSIH_RXD_U1RXD (0x40) +#define GPIO_PAR_SSIH_TXD_MASK (0xCF) +#define GPIO_PAR_SSIH_TXD_SSIRXD (0x30) +#define GPIO_PAR_SSIH_TXD_U1TXD (0x10) +#define GPIO_PAR_SSIH_FS_MASK (0xF3) +#define GPIO_PAR_SSIH_FS_SSIFS (0x0C) +#define GPIO_PAR_SSIH_FS_U1RTS (0x04) +#define GPIO_PAR_SSIH_MCLK_MASK (0xFC) +#define GPIO_PAR_SSIH_MCLK_SSIMCLK (0x03) +#define GPIO_PAR_SSIH_MCLK_SSICLKIN (0x01) + +#define GPIO_PAR_SSIL_MASK (0x3F) +#define GPIO_PAR_SSIL_BCLK (0xC0) +#define GPIO_PAR_SSIL_U1CTS (0x40) + +#define GPIO_MSCR_MSCR1(x) (((x) & 0x07) << 5) +#define GPIO_MSCR_MSCR2(x) (((x) & 0x07) << 5) +#define GPIO_MSCR_MSCR3(x) (((x) & 0x07) << 5) +#define GPIO_MSCR_MSCR4(x) (((x) & 0x07) << 5) +#define GPIO_MSCR_MSCRn_MASK (0x1F) +#define GPIO_MSCR_MSCRn_SDR (0xE0) +#define GPIO_MSCR_MSCRn_25VDDR (0x60) +#define GPIO_MSCR_MSCRn_18VDDR_FULL (0x20) +#define GPIO_MSCR_MSCRn_18VDDR_HALF (0x00) + +#define GPIO_MSCR_MSCR5(x) (((x) & 0x07) << 2) +#define GPIO_MSCR_MSCR5_MASK (0xE3) +#define GPIO_MSCR_MSCR5_SDR (0x1C) +#define GPIO_MSCR_MSCR5_25VDDR (0x0C) +#define GPIO_MSCR_MSCR5_18VDDR_FULL (0x04) +#define GPIO_MSCR_MSCR5_18VDDR_HALF (0x00) + +#define GPIO_SRCR_DSPI_MASK (0xFC) +#define GPIO_SRCR_DSPI(x) ((x) & 0x03) +#define GPIO_SRCR_I2C_MASK (0xFC) +#define GPIO_SRCR_I2C(x) ((x) & 0x03) +#define GPIO_SRCR_IRQ_IRQ0_MASK (0xF3) +#define GPIO_SRCR_IRQ_IRQ0(x) (((x) & 0x03) << 2) +#define GPIO_SRCR_IRQ_IRQ1DBG_MASK (0xFC) +#define GPIO_SRCR_IRQ_IRQ1DBG(x) ((x) & 0x03) +#define GPIO_SRCR_SIM_SIMP0_MASK (0xF3) +#define GPIO_SRCR_SIM_SIMP0(x) (((x) & 0x03) << 2) +#define GPIO_SRCR_SIM_SIMP1_MASK (0xFC) +#define GPIO_SRCR_SIM_SIMP1(x) ((x) & 0x03) +#define GPIO_SRCR_TIMER_MASK (0xFC) +#define GPIO_SRCR_TIMER(x) ((x) & 0x03) +#define GPIO_SRCR_UART2_MASK (0xF3) +#define GPIO_SRCR_UART2(x) (((x) & 0x03) << 2) +#define GPIO_SRCR_UART0_MASK (0xFC) +#define GPIO_SRCR_UART0(x) ((x) & 0x03) +#define GPIO_SRCR_SDHC_MASK (0xFC) +#define GPIO_SRCR_SDHC(x) ((x) & 0x03) +#define GPIO_SRCR_SSI_MASK (0xFC) +#define GPIO_SRCR_SSI(x) ((x) & 0x03) + +#define SRCR_HIGHEST (0x03) +#define SRCR_HIGH (0x02) +#define SRCR_LOW (0x01) +#define SRCR_LOWEST (0x00) + +#define GPIO_DSCR_FEC_RMIICLK_MASK (0xCF) +#define GPIO_DSCR_FEC_RMIICLK(x) (((x) & 0x03) << 4) +#define GPIO_DSCR_FEC_RMII0_MASK (0xF3) +#define GPIO_DSCR_FEC_RMII0(x) (((x) & 0x03) << 2) +#define GPIO_DSCR_FEC_RMII1_MASK (0xFC) +#define GPIO_DSCR_FEC_RMII1(x) ((x) & 0x03) + +#define DSCR_50PF (0x03) +#define DSCR_30PF (0x02) +#define DSCR_20PF (0x01) +#define DSCR_10PF (0x00) + +#define GPIO_PCRH_DSPI_PCS0_PULLUP_EN (0x80) +#define GPIO_PCRH_SIM_VEN1_PULLUP_EN (0x40) +#define GPIO_PCRH_SIM_VEN1_PULLUP (0x20) +#define GPIO_PCRH_SIM_DATA1_PULLUP_EN (0x10) +#define GPIO_PCRH_SIM_DATA1_PULLUP (0x08) +#define GPIO_PCRH_SSI_PULLUP_EN (0x02) +#define GPIO_PCRH_SSI_PULLUP (0x01) + +#define GPIO_PCRL_SDHC_DATA3_PULLUP_EN (0x80) +#define GPIO_PCRL_SDHC_DATA3_PULLUP (0x40) +#define GPIO_PCRL_SDHC_DATA2_PULLUP_EN (0x20) +#define GPIO_PCRL_SDHC_DATA1_PULLUP_EN (0x10) +#define GPIO_PCRL_SDHC_DATA0_PULLUP_EN (0x08) +#define GPIO_PCRL_SDHC_CMD_PULLUP_EN (0x04) + +/* *** Phase Locked Loop (PLL) *** */ +#define PLL_PCR_LOC_IRQ (0x00040000) +#define PLL_PCR_LOC_RE (0x00020000) +#define PLL_PCR_LOC_EN (0x00010000) +#define PLL_PCR_LOL_IRQ (0x00004000) +#define PLL_PCR_LOL_RE (0x00002000) +#define PLL_PCR_LOL_EN (0x00001000) +#define PLL_PCR_REFDIV_MASK (0xFFFFF8FF) +#define PLL_PCR_REFDIV(x) (((x) & 0x07) << 8) +#define PLL_PCR_FBDIV_MASK (0xFFFFFFC0) +#define PLL_PCR_FBDIV(x) ((x) & 0x3F) + +#define PLL_PDR_OUTDIV4_MASK (0x0FFF) +#define PLL_PDR_OUTDIV4(x) (((x) & 0x0000000F) << 12) +#define PLL_PDR_OUTDIV3_MASK (0xF0FF) +#define PLL_PDR_OUTDIV3(x) (((x) & 0x0000000F) << 8) +#define PLL_PDR_OUTDIV2_MASK (0xFF0F) +#define PLL_PDR_OUTDIV2(x) (((x) & 0x0000000F) << 4) +#define PLL_PDR_OUTDIV1_MASK (0xFFF0) +#define PLL_PDR_OUTDIV1(x) ((x) & 0x0000000F) +#define PLL_PDR_USB(x) PLL_PDR_OUTDIV4(x) +#define PLL_PDR_SDRAM(x) PLL_PDR_OUTDIV3(x) +#define PLL_PDR_FB(x) PLL_PDR_OUTDIV2(x) +#define PLL_PDR_CPU(x) PLL_PDR_OUTDIV1(x) + +#define PLL_PSR_LOCF (0x00000200) +#define PLL_PSR_LOC (0x00000100) +#define PLL_PSR_LOLF (0x00000040) +#define PLL_PSR_LOCKS (0x00000020) +#define PLL_PSR_LOCK (0x00000010) +#define PLL_PSR_MODE(x) ((x) & 0x07) + +/* *** Real Time Clock *** */ +#define RTC_OCEN_OSCBYP (0x00000010) +#define RTC_OCEN_CLKEN (0x00000008) + +#endif /* m5301x_h */
Tsi-Chung Liew
