[v3 0/2] Refactor AST2500 reset control
This patch series refactors the reset method to use the System Control Unit (SCU) reset control for simplicity.
In addition, the naming of reset driver and Kconfig option is also refined for future consistency.
v3: - Fix Makefile to adapt to the renamed reset driver file
v2: - Rebase patches to fix conflict
Chia-Wei, Wang (2): reset: ast2500: Use SCU for reset control cosmetic: reset: ast2500: Rename driver and configs
arch/arm/dts/ast2500-u-boot.dtsi | 7 +- drivers/reset/Kconfig | 11 +-- drivers/reset/Makefile | 2 +- drivers/reset/ast2500-reset.c | 104 --------------------- drivers/reset/reset-ast2500.c | 109 ++++++++++++++++++++++ include/dt-bindings/reset/ast2500-reset.h | 73 ++++++++------- 6 files changed, 157 insertions(+), 149 deletions(-) delete mode 100644 drivers/reset/ast2500-reset.c create mode 100644 drivers/reset/reset-ast2500.c
The System Control Unit (SCU) controller of Aspeed SoCs provides the reset control for each peripheral.
This patch refactors the reset method to leverage the SCU reset control. Thus the driver dependency on watchdog including dedicated WDT API and reset flag encoding can be eliminated.
The Kconfig description is also updated accordingly.
Signed-off-by: Chia-Wei, Wang chiawei_wang@aspeedtech.com Reviewed-by: Ryan Chen ryan_chen@aspeedtech.com --- arch/arm/dts/ast2500-u-boot.dtsi | 7 +- drivers/reset/Kconfig | 9 +-- drivers/reset/ast2500-reset.c | 97 ++++++++++++----------- include/dt-bindings/reset/ast2500-reset.h | 73 +++++++++-------- 4 files changed, 97 insertions(+), 89 deletions(-)
diff --git a/arch/arm/dts/ast2500-u-boot.dtsi b/arch/arm/dts/ast2500-u-boot.dtsi index 51a5244766..ea60e4c8db 100644 --- a/arch/arm/dts/ast2500-u-boot.dtsi +++ b/arch/arm/dts/ast2500-u-boot.dtsi @@ -16,7 +16,6 @@ rst: reset-controller { u-boot,dm-pre-reloc; compatible = "aspeed,ast2500-reset"; - aspeed,wdt = <&wdt1>; #reset-cells = <1>; };
@@ -27,7 +26,7 @@ 0x1e6e0200 0x1d4 >; #reset-cells = <1>; clocks = <&scu ASPEED_CLK_MPLL>; - resets = <&rst AST_RESET_SDRAM>; + resets = <&rst ASPEED_RESET_SDRAM>; };
ahb { @@ -41,7 +40,7 @@ reg = <0x1e740100>; #reset-cells = <1>; clocks = <&scu ASPEED_CLK_SDIO>; - resets = <&rst AST_RESET_SDIO>; + resets = <&rst ASPEED_RESET_SDIO>; };
sdhci1: sdhci@1e740200 { @@ -49,7 +48,7 @@ reg = <0x1e740200>; #reset-cells = <1>; clocks = <&scu ASPEED_CLK_SDIO>; - resets = <&rst AST_RESET_SDIO>; + resets = <&rst ASPEED_RESET_SDIO>; }; };
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index b60e11f98b..8b243fdcc6 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -74,13 +74,12 @@ config RESET_UNIPHIER
config AST2500_RESET bool "Reset controller driver for AST2500 SoCs" - depends on DM_RESET && WDT_ASPEED + depends on DM_RESET default y if ASPEED_AST2500 help - Support for reset controller on AST2500 SoC. This controller uses - watchdog to reset different peripherals and thus only supports - resets that are supported by watchdog. The main limitation though - is that some reset signals, like I2C or MISC reset multiple devices. + Support for reset controller on AST2500 SoC. + Say Y if you want to control reset signals of different peripherals + through System Control Unit (SCU).
config RESET_ROCKCHIP bool "Reset controller driver for Rockchip SoCs" diff --git a/drivers/reset/ast2500-reset.c b/drivers/reset/ast2500-reset.c index beb5cd8fa8..e7b5c7deca 100644 --- a/drivers/reset/ast2500-reset.c +++ b/drivers/reset/ast2500-reset.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0 /* * Copyright 2017 Google, Inc + * Copyright 2020 ASPEED Technology Inc. */
#include <common.h> @@ -9,28 +10,26 @@ #include <misc.h> #include <reset.h> #include <reset-uclass.h> -#include <wdt.h> +#include <linux/err.h> #include <asm/io.h> #include <asm/arch/scu_ast2500.h> -#include <asm/arch/wdt.h>
struct ast2500_reset_priv { - /* WDT used to perform resets. */ - struct udevice *wdt; struct ast2500_scu *scu; };
-static int ast2500_ofdata_to_platdata(struct udevice *dev) +static int ast2500_reset_request(struct reset_ctl *reset_ctl) { - struct ast2500_reset_priv *priv = dev_get_priv(dev); - int ret; + debug("%s(reset_ctl=%p) (dev=%p, id=%lu)\n", __func__, reset_ctl, + reset_ctl->dev, reset_ctl->id);
- ret = uclass_get_device_by_phandle(UCLASS_WDT, dev, "aspeed,wdt", - &priv->wdt); - if (ret) { - debug("%s: can't find WDT for reset controller", __func__); - return ret; - } + return 0; +} + +static int ast2500_reset_free(struct reset_ctl *reset_ctl) +{ + debug("%s(reset_ctl=%p) (dev=%p, id=%lu)\n", __func__, reset_ctl, + reset_ctl->dev, reset_ctl->id);
return 0; } @@ -38,47 +37,52 @@ static int ast2500_ofdata_to_platdata(struct udevice *dev) static int ast2500_reset_assert(struct reset_ctl *reset_ctl) { struct ast2500_reset_priv *priv = dev_get_priv(reset_ctl->dev); - u32 reset_mode, reset_mask; - bool reset_sdram; - int ret; - - /* - * To reset SDRAM, a specifal flag in SYSRESET register - * needs to be enabled first - */ - reset_mode = ast_reset_mode_from_flags(reset_ctl->id); - reset_mask = ast_reset_mask_from_flags(reset_ctl->id); - reset_sdram = reset_mode == WDT_CTRL_RESET_SOC && - (reset_mask & WDT_RESET_SDRAM); - - if (reset_sdram) { - ast_scu_unlock(priv->scu); - setbits_le32(&priv->scu->sysreset_ctrl1, - SCU_SYSRESET_SDRAM_WDT); - ret = wdt_expire_now(priv->wdt, reset_ctl->id); - clrbits_le32(&priv->scu->sysreset_ctrl1, - SCU_SYSRESET_SDRAM_WDT); - ast_scu_lock(priv->scu); - } else { - ret = wdt_expire_now(priv->wdt, reset_ctl->id); - } + struct ast2500_scu *scu = priv->scu; + + debug("%s: reset_ctl->id: %lu\n", __func__, reset_ctl->id);
- return ret; + if (reset_ctl->id < 32) + setbits_le32(&scu->sysreset_ctrl1, BIT(reset_ctl->id)); + else + setbits_le32(&scu->sysreset_ctrl2, BIT(reset_ctl->id - 32)); + + return 0; }
-static int ast2500_reset_request(struct reset_ctl *reset_ctl) +static int ast2500_reset_deassert(struct reset_ctl *reset_ctl) { - debug("%s(reset_ctl=%p) (dev=%p, id=%lu)\n", __func__, reset_ctl, - reset_ctl->dev, reset_ctl->id); + struct ast2500_reset_priv *priv = dev_get_priv(reset_ctl->dev); + struct ast2500_scu *scu = priv->scu; + + debug("%s: reset_ctl->id: %lu\n", __func__, reset_ctl->id); + + if (reset_ctl->id < 32) + clrbits_le32(&scu->sysreset_ctrl1, BIT(reset_ctl->id)); + else + clrbits_le32(&scu->sysreset_ctrl2, BIT(reset_ctl->id - 32));
return 0; }
static int ast2500_reset_probe(struct udevice *dev) { + int rc; struct ast2500_reset_priv *priv = dev_get_priv(dev); + struct udevice *scu_dev; + + /* get SCU base from clock device */ + rc = uclass_get_device_by_driver(UCLASS_CLK, + DM_GET_DRIVER(aspeed_ast2500_scu), &scu_dev); + if (rc) { + debug("%s: clock device not found, rc=%d\n", __func__, rc); + return rc; + }
- priv->scu = ast_get_scu(); + priv->scu = devfdt_get_addr_ptr(scu_dev); + if (IS_ERR_OR_NULL(priv->scu)) { + debug("%s: invalid SCU base pointer\n", __func__); + return PTR_ERR(priv->scu); + }
return 0; } @@ -89,16 +93,17 @@ static const struct udevice_id ast2500_reset_ids[] = { };
struct reset_ops ast2500_reset_ops = { - .rst_assert = ast2500_reset_assert, .request = ast2500_reset_request, + .rfree = ast2500_reset_free, + .rst_assert = ast2500_reset_assert, + .rst_deassert = ast2500_reset_deassert, };
U_BOOT_DRIVER(ast2500_reset) = { - .name = "ast2500_reset", - .id = UCLASS_RESET, + .name = "ast2500_reset", + .id = UCLASS_RESET, .of_match = ast2500_reset_ids, .probe = ast2500_reset_probe, .ops = &ast2500_reset_ops, - .ofdata_to_platdata = ast2500_ofdata_to_platdata, .priv_auto_alloc_size = sizeof(struct ast2500_reset_priv), }; diff --git a/include/dt-bindings/reset/ast2500-reset.h b/include/dt-bindings/reset/ast2500-reset.h index d1b6b23fc1..cc85a31edf 100644 --- a/include/dt-bindings/reset/ast2500-reset.h +++ b/include/dt-bindings/reset/ast2500-reset.h @@ -1,44 +1,49 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2017 Google, Inc + * Copyright 2020 ASPEED Technology Inc. */
#ifndef _ABI_MACH_ASPEED_AST2500_RESET_H_ #define _ABI_MACH_ASPEED_AST2500_RESET_H_
-/* - * The values are intentionally layed out as flags in - * WDT reset parameter. - */ - -#define AST_RESET_SOC 0 -#define AST_RESET_CHIP 1 -#define AST_RESET_CPU (1 << 1) -#define AST_RESET_ARM (1 << 2) -#define AST_RESET_COPROC (1 << 3) -#define AST_RESET_SDRAM (1 << 4) -#define AST_RESET_AHB (1 << 5) -#define AST_RESET_I2C (1 << 6) -#define AST_RESET_MAC1 (1 << 7) -#define AST_RESET_MAC2 (1 << 8) -#define AST_RESET_GCRT (1 << 9) -#define AST_RESET_USB20 (1 << 10) -#define AST_RESET_USB11_HOST (1 << 11) -#define AST_RESET_USB11_HID (1 << 12) -#define AST_RESET_VIDEO (1 << 13) -#define AST_RESET_HAC (1 << 14) -#define AST_RESET_LPC (1 << 15) -#define AST_RESET_SDIO (1 << 16) -#define AST_RESET_MIC (1 << 17) -#define AST_RESET_CRT2D (1 << 18) -#define AST_RESET_PWM (1 << 19) -#define AST_RESET_PECI (1 << 20) -#define AST_RESET_JTAG (1 << 21) -#define AST_RESET_ADC (1 << 22) -#define AST_RESET_GPIO (1 << 23) -#define AST_RESET_MCTP (1 << 24) -#define AST_RESET_XDMA (1 << 25) -#define AST_RESET_SPI (1 << 26) -#define AST_RESET_MISC (1 << 27) +#define ASPEED_RESET_CRT1 (37) +#define ASPEED_RESET_RESERVED36 (36) +#define ASPEED_RESET_RESERVED35 (35) +#define ASPEED_RESET_RESERVED34 (34) +#define ASPEED_RESET_RESERVED33 (33) +#define ASPEED_RESET_RESERVED32 (32) +#define ASPEED_RESET_RESERVED31 (31) +#define ASPEED_RESET_RESERVED30 (30) +#define ASPEED_RESET_RESERVED29 (29) +#define ASPEED_RESET_RESERVED28 (28) +#define ASPEED_RESET_RESERVED27 (27) +#define ASPEED_RESET_RESERVED26 (26) +#define ASPEED_RESET_XDMA (25) +#define ASPEED_RESET_MCTP (24) +#define ASPEED_RESET_ADC (23) +#define ASPEED_RESET_JTAG_MASTER (22) +#define ASPEED_RESET_RESERVED21 (21) +#define ASPEED_RESET_RESERVED20 (20) +#define ASPEED_RESET_RESERVED19 (19) +#define ASPEED_RESET_MIC (18) +#define ASPEED_RESET_RESERVED17 (17) +#define ASPEED_RESET_SDIO (16) +#define ASPEED_RESET_UHCI (15) +#define ASPEED_RESET_EHCI_P1 (14) +#define ASPEED_RESET_CRT (13) +#define ASPEED_RESET_MAC2 (12) +#define ASPEED_RESET_MAC1 (11) +#define ASPEED_RESET_PECI (10) +#define ASPEED_RESET_PWM (9) +#define ASPEED_RESET_PCI_VGA (8) +#define ASPEED_RESET_2D (7) +#define ASPEED_RESET_VIDEO (6) +#define ASPEED_RESET_LPC_ESPI (5) +#define ASPEED_RESET_HACE (4) +#define ASPEED_RESET_EHCI_P2 (3) +#define ASPEED_RESET_I2C (2) +#define ASPEED_RESET_AHB (1) +#define ASPEED_RESET_SDRAM (0)
#endif /* _ABI_MACH_ASPEED_AST2500_RESET_H_ */
1. Rename AST2500 reset driver from ast2500-reset.c to reset-ast2500.c 2. Rename AST2500 reset kconfig option from AST2500_RESET to RESET_AST2500
Signed-off-by: Chia-Wei, Wang chiawei_wang@aspeedtech.com Reviewed-by: Ryan Chen ryan_chen@aspeedtech.com --- drivers/reset/Kconfig | 2 +- drivers/reset/Makefile | 2 +- drivers/reset/{ast2500-reset.c => reset-ast2500.c} | 0 3 files changed, 2 insertions(+), 2 deletions(-) rename drivers/reset/{ast2500-reset.c => reset-ast2500.c} (100%)
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 8b243fdcc6..33c2736554 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -72,7 +72,7 @@ config RESET_UNIPHIER Say Y if you want to control reset signals provided by System Control block, Media I/O block, Peripheral Block.
-config AST2500_RESET +config RESET_AST2500 bool "Reset controller driver for AST2500 SoCs" depends on DM_RESET default y if ASPEED_AST2500 diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 10a7973f82..fa52aa3329 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -14,7 +14,7 @@ obj-$(CONFIG_RESET_TI_SCI) += reset-ti-sci.o obj-$(CONFIG_RESET_HSDK) += reset-hsdk.o obj-$(CONFIG_RESET_BCM6345) += reset-bcm6345.o obj-$(CONFIG_RESET_UNIPHIER) += reset-uniphier.o -obj-$(CONFIG_AST2500_RESET) += ast2500-reset.o +obj-$(CONFIG_RESET_AST2500) += reset-ast2500.o obj-$(CONFIG_RESET_ROCKCHIP) += reset-rockchip.o obj-$(CONFIG_RESET_MESON) += reset-meson.o obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o diff --git a/drivers/reset/ast2500-reset.c b/drivers/reset/reset-ast2500.c similarity index 100% rename from drivers/reset/ast2500-reset.c rename to drivers/reset/reset-ast2500.c
On Thu, Oct 15, 2020 at 10:25:14AM +0800, Chia-Wei, Wang wrote:
- Rename AST2500 reset driver from ast2500-reset.c to reset-ast2500.c
- Rename AST2500 reset kconfig option from AST2500_RESET to RESET_AST2500
Hi Tom,
The patches has been rebased onto the up-to-date U-Boot master. A makefile error is also fixed in the revised version and verified with an AST2500 EVB.
Thanks, Chiawei
-----Original Message----- From: ChiaWei Wang chiawei_wang@aspeedtech.com Sent: Thursday, October 15, 2020 10:25 AM To: trini@konsulko.com; u-boot@lists.denx.de; maxims@google.com Subject: [v3 0/2] Refactor AST2500 reset control
v3:
v2:
-- 2.17.1
Chia-Wei, Wang
ChiaWei Wang
