[U-Boot] [PATCH] ARM: dts: Turn Salvator-X into Multi-DTB config
Bundle DTBs for R8A7795, R8A7796, R8A77965 Salvator-X variants into the single U-Boot build and let U-Boot choose between them based on the CPU model.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- board/renesas/salvator-x/salvator-x.c | 22 ++++++++++++++++++++++ configs/r8a7795_salvator-x_defconfig | 2 ++ configs/r8a77965_salvator-x_defconfig | 2 ++ configs/r8a7796_salvator-x_defconfig | 2 ++ 4 files changed, 28 insertions(+)
diff --git a/board/renesas/salvator-x/salvator-x.c b/board/renesas/salvator-x/salvator-x.c index 8b15267d7b..9b37c34d66 100644 --- a/board/renesas/salvator-x/salvator-x.c +++ b/board/renesas/salvator-x/salvator-x.c @@ -100,3 +100,25 @@ void reset_cpu(ulong addr) writel(RST_CODE, RST_CA57RESCNT); #endif } + +#ifdef CONFIG_MULTI_DTB_FIT +int board_fit_config_name_match(const char *name) +{ + /* PRR driver is not available yet */ + u32 cpu_type = rmobile_get_cpu_type(); + + if ((cpu_type == RMOBILE_CPU_TYPE_R8A7795) && + !strcmp(name, "r8a7795-salvator-x-u-boot")) + return 0; + + if ((cpu_type == RMOBILE_CPU_TYPE_R8A7796) && + !strcmp(name, "r8a7796-salvator-x-u-boot")) + return 0; + + if ((cpu_type == RMOBILE_CPU_TYPE_R8A77965) && + !strcmp(name, "r8a77965-salvator-x-u-boot")) + return 0; + + return -1; +} +#endif diff --git a/configs/r8a7795_salvator-x_defconfig b/configs/r8a7795_salvator-x_defconfig index 0899de16b4..823688f0b1 100644 --- a/configs/r8a7795_salvator-x_defconfig +++ b/configs/r8a7795_salvator-x_defconfig @@ -33,6 +33,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7795-salvator-x-u-boot" +CONFIG_OF_LIST="r8a7795-salvator-x-u-boot r8a7796-salvator-x-u-boot r8a77965-salvator-x-u-boot" +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/r8a77965_salvator-x_defconfig b/configs/r8a77965_salvator-x_defconfig index 4af3960c14..1753f03ea2 100644 --- a/configs/r8a77965_salvator-x_defconfig +++ b/configs/r8a77965_salvator-x_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a77965-salvator-x-u-boot" +CONFIG_OF_LIST="r8a7795-salvator-x-u-boot r8a7796-salvator-x-u-boot r8a77965-salvator-x-u-boot" +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y diff --git a/configs/r8a7796_salvator-x_defconfig b/configs/r8a7796_salvator-x_defconfig index 8d6763a944..84a87f6a59 100644 --- a/configs/r8a7796_salvator-x_defconfig +++ b/configs/r8a7796_salvator-x_defconfig @@ -34,6 +34,8 @@ CONFIG_CMD_FAT=y CONFIG_CMD_FS_GENERIC=y CONFIG_OF_CONTROL=y CONFIG_DEFAULT_DEVICE_TREE="r8a7796-salvator-x-u-boot" +CONFIG_OF_LIST="r8a7795-salvator-x-u-boot r8a7796-salvator-x-u-boot r8a77965-salvator-x-u-boot" +CONFIG_MULTI_DTB_FIT=y CONFIG_ENV_IS_IN_MMC=y CONFIG_REGMAP=y CONFIG_SYSCON=y
