[U-Boot] [PATCH] eb_cpux9k2: add ram target configuration
* add ram target for EB+CPUx9k2 board (eb_cpux9k2_ram_config)
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de --- boards.cfg | 3 ++- include/configs/eb_cpux9k2.h | 5 +++++ 2 files changed, 7 insertions(+), 1 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 3cf75c3..efca4fc 100644 --- a/boards.cfg +++ b/boards.cfg @@ -54,7 +54,8 @@ integratorcp_cm920t arm arm920t integrator armltd a320evb arm arm920t - faraday a320 at91rm9200ek arm arm920t at91rm9200ek atmel at91 at91rm9200ek at91rm9200ek_ram arm arm920t at91rm9200ek atmel at91 at91rm9200ek:RAMBOOT -eb_cpux9k2 arm arm920t - BuS at91 +eb_cpux9k2 arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2 +eb_cpux9k2_ram arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2:RAMBOOT cpuat91 arm arm920t cpuat91 eukrea at91 cpuat91 cpuat91_ram arm arm920t cpuat91 eukrea at91 cpuat91:RAMBOOT mx1ads arm arm920t - - imx diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index eb05e2a..d7b6b57 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -44,7 +44,12 @@ #define MACH_TYPE_EB_CPUX9K2 1977 #define CONFIG_MACH_TYPE MACH_TYPE_EB_CPUX9K2 /*--------------------------------------------------------------------------*/ +#ifndef CONFIG_RAMBOOT #define CONFIG_SYS_TEXT_BASE 0x00000000 +#else +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SYS_TEXT_BASE 0x21f00000 +#endif #define CONFIG_SYS_LOAD_ADDR 0x21000000 /* default load address */
#define CONFIG_SYS_BOOT_SIZE 0x00 /* 0 KBytes */
Dear Andreas Bießmann,
Please could you also apply this open patch. I've just tested this against the current atmel and master tree.
Thanks
best regards
Jens Scharsig
Am 2012-04-29 20:01, schrieb Jens Scharsig:
- add ram target for EB+CPUx9k2 board (eb_cpux9k2_ram_config)
Dear Jens Scharsig,
sorry, this one slipped through. Please add some at91/atmel to the subject line next time to get my attention.
Ok, but this one seems to have style problems, please fix.
---8<--- WARNING: please, no space before tabs #47: FILE: include/configs/eb_cpux9k2.h:51: +#define CONFIG_SYS_TEXT_BASE ^I^I0x21f00000$
total: 0 errors, 1 warnings, 21 lines checked
NOTE: Ignored message types: COMPLEX_MACRO CONSIDER_KSTRTO MINMAX MULTISTATEMENT_MACRO_USE_DO_WHILE
U-Boot-eb_cpux9k2-add-ram-target-configuration.patch has style problems, please review. --->8---
Best regards
Andreas Bießmann
Signed-off-by: Jens Scharsig js_at_ng@scharsoft.de Signed-off-by: Jens Scharsig (BuS Elektronik) esw@bus-elektronik.de --- fix code styling
boards.cfg | 3 ++- include/configs/eb_cpux9k2.h | 7 ++++++- 2 files changed, 8 insertions(+), 2 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 72e7803..613d6b2 100644 --- a/boards.cfg +++ b/boards.cfg @@ -60,7 +60,8 @@ integratorcp_cm920t arm arm920t integrator armltd a320evb arm arm920t - faraday a320 at91rm9200ek arm arm920t at91rm9200ek atmel at91 at91rm9200ek at91rm9200ek_ram arm arm920t at91rm9200ek atmel at91 at91rm9200ek:RAMBOOT -eb_cpux9k2 arm arm920t - BuS at91 +eb_cpux9k2 arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2 +eb_cpux9k2_ram arm arm920t eb_cpux9k2 BuS at91 eb_cpux9k2:RAMBOOT cpuat91 arm arm920t cpuat91 eukrea at91 cpuat91 cpuat91_ram arm arm920t cpuat91 eukrea at91 cpuat91:RAMBOOT mx1ads arm arm920t - - imx diff --git a/include/configs/eb_cpux9k2.h b/include/configs/eb_cpux9k2.h index d4104de..9371ec3 100644 --- a/include/configs/eb_cpux9k2.h +++ b/include/configs/eb_cpux9k2.h @@ -44,7 +44,12 @@ #define MACH_TYPE_EB_CPUX9K2 1977 #define CONFIG_MACH_TYPE MACH_TYPE_EB_CPUX9K2 /*--------------------------------------------------------------------------*/ -#define CONFIG_SYS_TEXT_BASE 0x00000000 +#ifndef CONFIG_RAMBOOT +#define CONFIG_SYS_TEXT_BASE 0x00000000 +#else +#define CONFIG_SKIP_LOWLEVEL_INIT +#define CONFIG_SYS_TEXT_BASE 0x21f00000 +#endif #define CONFIG_SYS_LOAD_ADDR 0x21000000 /* default load address */
Dear Jens Scharsig,
applied to u-boot-atmel/master, thnaks!
Best regards
Andreas Bießmann
Andreas Bießmann
Jens Scharsig
Jens Scharsig
