[U-Boot] __fsl_ddr_set_lawbar: ERROR (ctrl #0, intrlv=0)
Dear Kumar,
I'm seeing the following problem on a MPC8555 board:
Power-on reset works fine:
... I2C: ready DRAM: 256 MiB (DDR1, 64-bit, CL=2, ECC off) Flash: 64 MiB L2: 256 KB enabled ...
But a soft-reset results in this:
=> reset ... I2C: ready DRAM: __fsl_ddr_set_lawbar: ERROR (ctrl #0, intrlv=0) 256 MiB (DDR1, 64-bit, CL=2, ECC off) Flash: 64 MiB L2: 256 KB already enabled ...
Do you have any idea what this means and how to fix it?
On Jul 25, 2011, at 3:18 AM, Wolfgang Denk wrote:
Dear Kumar,
On this board what is 'reset' really doing? I have a theory but would be helpful to understand what's happening.
Can you also send me the full boot log (i'm looking at another bug that might show up on this board).
- k
Dear Kumar Gala,
In message AA4FD7C8-6BE0-4847-9332-3AD9521C0C65@kernel.crashing.org you wrote:
DRAM: __fsl_ddr_set_lawbar: ERROR (ctrl #0, intrlv=3D0) 256 MiB (DDR1, 64-bit, CL=3D2, ECC off)
This is a MPC8555 based board:
CPU: 8555E, Version: 1.1, (0x80790011) Core: Unknown, Version: 2.0, (0x80200020)
THe do_reset() code is supposed to be the one from "arch/powerpc/cpu/mpc85xx/cpu.c"
Side note: rebooting Linux doesn't work either - it just hangs the board in Linux v3.0 and any earlier version I can still compile with my Fedora15 based host, i.e. down to around 2.6.32 or so.
Will do as PM.
Thanks.
Dear Kumar,
The same (both the "Core: Unknown" and the "__fsl_ddr_set_lawbar: ERROR" issues) happens on the same board equipped with a MPC8541 processor:
CPU: 8541E, Version: 1.1, (0x807a0011) Core: Unknown, Version: 2.0, (0x80200020)
Note that old versions of U-Boot (like 1.3.0-rc2-g72e55d03 :-) used to print here:
CPU: 8541, Version: 1.1, (0x807a0011) Core: E500, Version: 2.0, (0x80200020)
On Jul 25, 2011, at 2:28 PM, Wolfgang Denk wrote:
Dear Kumar,
Yeah, the 'unknown' issue was the other bug I was looking at ;)
- k
On Jul 25, 2011, at 12:57 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
Will do as PM.
Do you know if this board has any real reset on a FPGA or CPLD or something like that.
The problem on the 8555/8541 is the reset you are trigger is just a core reset and not one of the full SoC. If there is a board level means I would suggest trying to utilize it instead. If not this might be painful & problematic as you'll have to slowly make sure we are 'resetting' each SoC block properly.
- k
Dear Kumar Gala,
In message FC7A4DAE-B05C-49F3-9201-1B5BB559FF47@kernel.crashing.org you wrote:
There is no such faeature on that board, nor on any of a number of other 85xx boards I have access to.
Is this also the cause why the Linux reboot ommand does not work?
If so, I wonder what has changed, because this used to be working in older versions of the kernel? I did not attampt a full git bisect, but from some old images I still found it appears it must have been broken between 2.6.16 ("reboot" in Linux works fine) and 2.6.27 ("reboot" does not work any more) - so probably this was part of the arch/ppc => arch/powerpc rework.
Is there any specific reason we don't use the good old approach of triggering an unhandled machine check exception?
On Jul 26, 2011, at 4:23 AM, Wolfgang Denk wrote:
Dear Kumar Gala,
Probably.
Possible, its a pretty fragile reset solution so one (or a thousand) of a million things could be the issue.
Hmm, when did we do that? I've got no issues with it if it causes HRESET_REQ to be signaled on the older devices. On MPC8548 and greater we provided a means for software to causes HRESET_REQ to be asserted. So if an unhandled mcheck will do this sounds good to me.
- k
Dear Kumar Gala,
In message 17E34909-A735-4920-9980-059D95535774@kernel.crashing.org you wrote:
For example for PQ2 Linux does this (in arch/powerpc/platforms/82xx/pq2.c):
26 void pq2_restart(char *cmd) 27 { 28 local_irq_disable(); 29 setbits32(&cpm2_immr->im_clkrst.car_rmr, RMR_CSRE); 30 31 /* Clear the ME,EE,IR & DR bits in MSR to cause checkstop */ 32 mtmsr(mfmsr() & ~(MSR_ME | MSR_EE | MSR_IR | MSR_DR)); 33 in_8(&cpm2_immr->im_clkrst.res[0]); 34 35 panic("Restart failed\n"); 36 }
So we set the Checkstop Reset enable, and then reference a known bad address.
Should we try and do the same here, too?
Kumar Gala
