[PATCH v2 1/6] rock-pi-4: Enable USB3 Host
Enable USB3.0 Host support for RockPI-4 boards.
Note that the Upper USB3.0 port is marked as otg and lower USB3.0 port marked as host, so this below log capture when USB3.0 mass storage plug in at lower USB 3.0 port.
Log: Bus usb@fe380000: USB EHCI 1.00 Bus usb@fe3c0000: USB EHCI 1.00 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3: usb maximum-speed not found Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus usb@fe380000 for devices... 1 USB Device(s) found scanning bus usb@fe3c0000 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... 1 USB Device(s) found scanning bus dwc3 for devices... cannot reset port 1!? 2 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found => usb tree USB device tree: 1 Hub (480 Mb/s, 0mA) u-boot EHCI Host Controller
1 Hub (5 Gb/s, 0mA) U-Boot XHCI Host Controller
1 Hub (5 Gb/s, 0mA) | U-Boot XHCI Host Controller | +-2 Mass Storage (5 Gb/s, 224mA) SanDisk Dual Drive 040130e3ee554b7078843f4eb331646
Cc: Tom Cubie tom@radxa.com Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Changes for v2: - rebase on master
configs/rock-pi-4-rk3399_defconfig | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 0d86fdc895..2487872219 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -35,11 +36,14 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y +CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y @@ -48,6 +52,8 @@ CONFIG_USB_XHCI_HCD=y CONFIG_USB_XHCI_DWC3=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC3=y +CONFIG_USB_DWC3_GENERIC=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y
Enable PCI/NVME for M.2 Slot on RockPI-4 boards.
=> nvme info Device 0: Vendor: 0x144d Rev: 2B2QEXM7 Prod: S4EUNG0MC10012Y Type: Hard Disk Capacity: 238475.1 MB = 232.8 GB (488397168 x 512)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 0d86fdc895..2487872219 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -35,11 +36,14 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y configs/rock-pi-4-rk3399_defconfig | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 2487872219..f3eeef0293 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -18,6 +18,7 @@ CONFIG_TPL=y CONFIG_CMD_BOOTZ=y CONFIG_CMD_GPT=y CONFIG_CMD_MMC=y +CONFIG_CMD_PCI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y @@ -36,6 +37,8 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_NVME=y +CONFIG_PCI=y CONFIG_PHY_ROCKCHIP_INNO_USB2=y CONFIG_PHY_ROCKCHIP_TYPEC=y CONFIG_PMIC_RK8XX=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
rebase on master
Enable USB gadget for rock-pi-4 boards.
This would help to use fastboot by default.
Note: Connect the Host USB cable (Port A or C) to rock-pi-4 Upper USB 3.0 port.
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 0d86fdc895..2487872219 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -35,11 +36,14 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y configs/rock-pi-4-rk3399_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index f3eeef0293..a4b322074c 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -8,6 +8,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_DEBUG_UART_BASE=0xFF1A0000 CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-rock-pi-4.dtb" CONFIG_MISC_INIT_R=y CONFIG_DISPLAY_BOARDINFO_LATE=y @@ -57,6 +58,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y
Thanks, - Kever
Changes for v2:
rebase on master
Enable config options to get HDMI output on RockPI-4 boards.
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 0d86fdc895..2487872219 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -35,11 +36,14 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y configs/rock-pi-4-rk3399_defconfig | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index a4b322074c..98f71a50a5 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -58,6 +58,7 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_USB_KEYBOARD=y CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y @@ -65,5 +66,9 @@ CONFIG_USB_ETHER_ASIX88179=y CONFIG_USB_ETHER_MCS7830=y CONFIG_USB_ETHER_RTL8152=y CONFIG_USB_ETHER_SMSC95XX=y +CONFIG_DM_VIDEO=y +CONFIG_DISPLAY=y +CONFIG_VIDEO_ROCKCHIP=y +CONFIG_DISPLAY_ROCKCHIP_HDMI=y CONFIG_SPL_TINY_MEMSET=y CONFIG_ERRNO_STR=y
Changes for v2:
rebase on master
This is not for HDMI.
Enable DWC3 core, gadget for roc-rk3399-pc board.
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 0d86fdc895..2487872219 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -35,11 +36,14 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y configs/roc-pc-mezzanine-rk3399_defconfig | 3 +++ configs/roc-pc-rk3399_defconfig | 3 +++ 2 files changed, 6 insertions(+)
diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index fd1b85c1e4..7906948374 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc-mezzanine.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set @@ -64,7 +65,9 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 80e7001481..046fb73858 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -12,6 +12,7 @@ CONFIG_DEBUG_UART_CLOCK=24000000 CONFIG_SPL_SPI_FLASH_SUPPORT=y CONFIG_SPL_SPI_SUPPORT=y CONFIG_DEBUG_UART=y +# CONFIG_ANDROID_BOOT_IMAGE is not set CONFIG_DEFAULT_FDT_FILE="rockchip/rk3399-roc-pc.dtb" CONFIG_DISPLAY_BOARDINFO_LATE=y # CONFIG_SPL_RAW_IMAGE_SUPPORT is not set @@ -61,7 +62,9 @@ CONFIG_USB_EHCI_HCD=y CONFIG_USB_EHCI_GENERIC=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_GENERIC=y +CONFIG_ROCKCHIP_USB2_PHY=y CONFIG_USB_KEYBOARD=y +CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_ASIX=y CONFIG_USB_ETHER_ASIX88179=y
Thanks, - Kever
Changes for v2:
rebase on master
Adjust the ENV offset, size to fit into all images on 16MB flash.
diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index 0d86fdc895..2487872219 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -28,6 +28,7 @@ CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ROCKCHIP_GPIO=y CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y CONFIG_MMC_DW=y CONFIG_MMC_DW_ROCKCHIP=y CONFIG_MMC_SDHCI=y @@ -35,11 +36,14 @@ CONFIG_MMC_SDHCI_ROCKCHIP=y CONFIG_DM_ETH=y CONFIG_ETH_DESIGNWARE=y CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY_ROCKCHIP_INNO_USB2=y configs/roc-pc-mezzanine-rk3399_defconfig | 4 ++-- configs/roc-pc-rk3399_defconfig | 4 ++-- 2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index 7906948374..595f052cb7 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -1,8 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 -CONFIG_ENV_SIZE=0x6000 -CONFIG_ENV_OFFSET=0x460000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROC_PC_RK3399=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index 046fb73858..1c4db3443f 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -1,8 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_ROCKCHIP=y CONFIG_SYS_TEXT_BASE=0x00200000 -CONFIG_ENV_SIZE=0x6000 -CONFIG_ENV_OFFSET=0x460000 +CONFIG_ENV_SIZE=0x8000 +CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROC_PC_RK3399=y
Changes for v2:
rebase on master
This is not for ENV.
Thanks,
- Kever
Thanks, - Kever
Changes for v2:
rebase on master
Jagan Teki
Kever Yang
