That's most probably a typo, because driver model design documents seem to be from 2012 and there is no 2010.01 release.
Fixes: 282ed24fb3ca ("dm: MIGRATION: Add migration plan for CONFIG_DM") Signed-off-by: Alexander Dahl ada@thorsis.com --- doc/develop/driver-model/migration.rst | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/doc/develop/driver-model/migration.rst b/doc/develop/driver-model/migration.rst index 5a60436925..cee38a56d0 100644 --- a/doc/develop/driver-model/migration.rst +++ b/doc/develop/driver-model/migration.rst @@ -13,7 +13,7 @@ CONFIG_DM * Status: In progress * Deadline: 2020.01
-Starting with the 2010.01 release CONFIG_DM will be enabled for all boards. +Starting with the 2020.01 release CONFIG_DM will be enabled for all boards. This does not concern CONFIG_DM_SPL and CONFIG_DM_TPL. The conversion date for these configuration items still needs to be defined.
base-commit: 0ba282e0eeaf29fd78f021fd2f95f7bc3109868d
- Status: In progress
- Deadline: 2020.01
Thanks for pointing at the typo.
This migration is completed. Should we remove the entry from the list?
Best regards
Heinrich
- Deadline: 2020.01
Should do a world build where the Makefile check is fatal first, and go from there.
- Deadline: 2020.01
OK, so I set up that kind of build on current master and it passes: https://source.denx.de/u-boot/u-boot/-/pipelines/13433
Please do a patch to remove this section from doc/develop/driver-model/migration.rst and drop the test in the Makefile for CONFIG_DM being set as well. Thanks!
- Deadline: 2020.01
Should we change CONFIG_DM to be non-editable:
config DM - bool "Enable Driver Model" - help - This config option enables Driver Model. This brings in the core - support, including scanning of platform data on start-up. If - CONFIG_OF_CONTROL is enabled, the device tree will be scanned also - when available. + bool + default y
And in the next step remove the symbol completely?
Best regards
Heinrich
- Deadline: 2020.01
config DM
help
when available.
bool
default y
I wouldn't delete the help, but yes, it should also be def_bool y.
Alexander Dahl
