[U-Boot] [PATCH v2 1/2] armv8/kconfig: Align boards of same family at one place
Align boards belonging to LS1012A, LS2080A SoC at one place
Signed-off-by: Bhaskar Upadhaya Bhaskar.Upadhaya@nxp.com --- arch/arm/cpu/armv8/Kconfig | 5 +++-- 1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 12aba9d..51f48e1 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -85,11 +85,12 @@ endmenu config PSCI_RESET bool "Use PSCI for reset and shutdown" default y - depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && !TARGET_LS2080A_EMU && \ + depends on !ARCH_EXYNOS7 && !ARCH_BCM283X && \ !TARGET_LS2080A_SIMU && !TARGET_LS2080AQDS && \ - !TARGET_LS2080ARDB && !TARGET_LS1012AQDS && \ + !TARGET_LS2080ARDB && !TARGET_LS2080A_EMU && \ !TARGET_LS1088ARDB && !TARGET_LS1088AQDS && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ + !TARGET_LS1012AQDS && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ !TARGET_LS2081ARDB && \
LS1012A-2G5RDB belongs to LS1012A family with features 2 2.5G SGMII PFE MAC, SATA, USB 2.0/3.0, WiFi DDR, eMMC, QuadSPI, UART
Signed-off-by: Bhaskar Upadhaya Bhaskar.Upadhaya@nxp.com --- changes for v2: - LS1012A-2G5RDB patches are made independent of PFE patches - Remove CONFIG_CMD_DHCP, CONFIG_CMD_MII, CONFIG_FSL_PFE. CONFIG_DM_MMC_OPS - created ls1012a2g5rdb_qspi_defconfig after running savedefconfig
arch/arm/Kconfig | 12 ++++ arch/arm/cpu/armv8/Kconfig | 2 +- arch/arm/dts/Makefile | 1 + arch/arm/dts/fsl-ls1012a-2g5rdb.dts | 43 +++++++++++ board/freescale/ls1012ardb/Kconfig | 18 +++++ board/freescale/ls1012ardb/MAINTAINERS | 7 ++ board/freescale/ls1012ardb/README | 43 +++++++++++ board/freescale/ls1012ardb/ls1012ardb.c | 7 +- configs/ls1012a2g5rdb_qspi_defconfig | 40 +++++++++++ include/configs/ls1012a2g5rdb.h | 122 ++++++++++++++++++++++++++++++++ 10 files changed, 293 insertions(+), 2 deletions(-) create mode 100644 arch/arm/dts/fsl-ls1012a-2g5rdb.dts create mode 100644 configs/ls1012a2g5rdb_qspi_defconfig create mode 100644 include/configs/ls1012a2g5rdb.h
diff --git a/arch/arm/Kconfig b/arch/arm/Kconfig index 91ad5e8..d77bc6e 100644 --- a/arch/arm/Kconfig +++ b/arch/arm/Kconfig @@ -918,6 +918,18 @@ config TARGET_LS1012ARDB development platform that supports the QorIQ LS1012A Layerscape Architecture processor.
+config TARGET_LS1012A2G5RDB + bool "Support ls1012a2g5rdb" + select ARCH_LS1012A + select ARM64 + select BOARD_LATE_INIT + imply SCSI + help + Support for Freescale LS1012A2G5RDB platform. + The LS1012A 2G5 Reference design board (RDB) is a high-performance + development platform that supports the QorIQ LS1012A + Layerscape Architecture processor. + config TARGET_LS1012AFRDM bool "Support ls1012afrdm" select ARCH_LS1012A diff --git a/arch/arm/cpu/armv8/Kconfig b/arch/arm/cpu/armv8/Kconfig index 51f48e1..3a0e129 100644 --- a/arch/arm/cpu/armv8/Kconfig +++ b/arch/arm/cpu/armv8/Kconfig @@ -90,7 +90,7 @@ config PSCI_RESET !TARGET_LS2080ARDB && !TARGET_LS2080A_EMU && \ !TARGET_LS1088ARDB && !TARGET_LS1088AQDS && \ !TARGET_LS1012ARDB && !TARGET_LS1012AFRDM && \ - !TARGET_LS1012AQDS && \ + !TARGET_LS1012A2G5RDB && !TARGET_LS1012AQDS && \ !TARGET_LS1043ARDB && !TARGET_LS1043AQDS && \ !TARGET_LS1046ARDB && !TARGET_LS1046AQDS && \ !TARGET_LS2081ARDB && \ diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 6db64f91..9e49b7d 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -200,6 +200,7 @@ dtb-$(CONFIG_FSL_LSCH2) += fsl-ls1043a-qds-duart.dtb \ fsl-ls1046a-rdb.dtb \ fsl-ls1012a-qds.dtb \ fsl-ls1012a-rdb.dtb \ + fsl-ls1012a-2g5rdb.dtb \ fsl-ls1012a-frdm.dtb
dtb-$(CONFIG_ARCH_SNAPDRAGON) += dragonboard410c.dtb diff --git a/arch/arm/dts/fsl-ls1012a-2g5rdb.dts b/arch/arm/dts/fsl-ls1012a-2g5rdb.dts new file mode 100644 index 0000000..dbe01dd --- /dev/null +++ b/arch/arm/dts/fsl-ls1012a-2g5rdb.dts @@ -0,0 +1,43 @@ +/* + * NXP ls1012a 2G5RDB board device tree source + * + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/dts-v1/; +#include "fsl-ls1012a.dtsi" + +/ { + model = "LS1012A 2G5RDB Board"; + + aliases { + spi0 = &qspi; + }; + + chosen { + stdout-path = &duart0; + }; +}; + +&qspi { + bus-num = <0>; + status = "okay"; + + qflash0: s25fl128s@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "spi-flash"; + spi-max-frequency = <20000000>; + reg = <0>; + }; +}; + +&i2c0 { + status = "okay"; +}; + +&duart0 { + status = "okay"; +}; diff --git a/board/freescale/ls1012ardb/Kconfig b/board/freescale/ls1012ardb/Kconfig index 98231f9..d13b08e 100644 --- a/board/freescale/ls1012ardb/Kconfig +++ b/board/freescale/ls1012ardb/Kconfig @@ -15,3 +15,21 @@ config SYS_CONFIG_NAME source "board/freescale/common/Kconfig"
endif + +if TARGET_LS1012A2G5RDB + +config SYS_BOARD + default "ls1012ardb" + +config SYS_VENDOR + default "freescale" + +config SYS_SOC + default "fsl-layerscape" + +config SYS_CONFIG_NAME + default "ls1012a2g5rdb" + +source "board/freescale/common/Kconfig" + +endif diff --git a/board/freescale/ls1012ardb/MAINTAINERS b/board/freescale/ls1012ardb/MAINTAINERS index 2cb38e7..a0a0d8d 100644 --- a/board/freescale/ls1012ardb/MAINTAINERS +++ b/board/freescale/ls1012ardb/MAINTAINERS @@ -8,3 +8,10 @@ F: configs/ls1012ardb_qspi_defconfig M: Sumit Garg sumit.garg@nxp.com S: Maintained F: configs/ls1012ardb_qspi_SECURE_BOOT_defconfig + +LS1012A2G5RDB BOARD +M: Bhaskar Upadhaya bhaskar.upadhaya@nxp.com +S: Maintained +F: board/freescale/ls1012ardb/ +F: include/configs/ls1012a2g5rdb.h +F: configs/ls1012a2g5rdb_qspi_defconfig diff --git a/board/freescale/ls1012ardb/README b/board/freescale/ls1012ardb/README index 453b432..572fd8c 100644 --- a/board/freescale/ls1012ardb/README +++ b/board/freescale/ls1012ardb/README @@ -52,3 +52,46 @@ U-boot | 1MB | 0x4010_0000 U-boot Env | 1MB | 0x4020_0000 PPA FIT image | 2MB | 0x4050_0000 Linux ITB | ~53MB | 0x40A0_0000 + +LS1012A2G5RDB board Overview +----------------------- + - SERDES Connections, 3 lanes supporting: + - SGMII, SGMII 2.5 + - SATA 3.0 + - DDR Controller + - 16-bit, 1 GB DDR3L SDRAM memory, running at data rates up to 1 GT/s + -QSPI: A dual 1:3 switch, NX3L4357GM,115 (U35) drives the QSPI chip-select + signals to + - QSPI NOR flash memory + - USB 3.0 + - one high-speed USB 2.0/3.0 port. + - SDIO WiFi, SPI + - 2 I2C controllers + - One SATA onboard connectors + - UART + - The LS1012A processor consists of two UART controllers, + out of which only UART1 is used on 2G5RDB. + - ARM JTAG support + +Major Difference between LS1012ARDB and LS1012A-2G5RDB +------------------------------------------------------ +1. LS1012A-2G5RDB has Type C USB connector unlike USB Type A/B of LS1012ARDB +2. LS1012A-2G5RDB has 2 2.5G AQR PHY unlike 2 1G Realtek RTL8211FS PHYs + of LS1012ARDB +3. LS1012A-2G5RDB is not having Arduino header +4. LS1012A-2G5RDB doesn't have PCI slot + +Booting Options +--------------- +QSPI Flash + +QSPI flash map +-------------- +Images | Size |QSPI Flash Address +------------------------------------------ +RCW + PBI | 1MB | 0x4000_0000 +U-boot | 1MB | 0x4010_0000 +U-boot Env | 1MB | 0x4030_0000 +PPA FIT image | 2MB | 0x4040_0000 +PFE firmware | 20K | 0x00a0_0000 +Linux ITB | ~53MB | 0x4100_0000 diff --git a/board/freescale/ls1012ardb/ls1012ardb.c b/board/freescale/ls1012ardb/ls1012ardb.c index 286f9d8..c9557bb 100644 --- a/board/freescale/ls1012ardb/ls1012ardb.c +++ b/board/freescale/ls1012ardb/ls1012ardb.c @@ -28,6 +28,7 @@ DECLARE_GLOBAL_DATA_PTR;
int checkboard(void) { +#ifdef CONFIG_TARGET_LS1012ARDB u8 in1;
puts("Board: LS1012ARDB "); @@ -77,7 +78,10 @@ int checkboard(void) puts(": bank2\n"); else puts("unknown\n"); +#else
+ puts("Board: LS1012A2G5RDB "); +#endif return 0; }
@@ -150,6 +154,7 @@ int board_init(void) return 0; }
+#ifdef CONFIG_TARGET_LS1012ARDB int esdhc_status_fixup(void *blob, const char *compat) { char esdhc1_path[] = "/soc/esdhc@1580000"; @@ -193,7 +198,6 @@ int esdhc_status_fixup(void *blob, const char *compat) if (mux_sdhc2 == 2 || mux_sdhc2 == 0) sdhc2_en = true; } - if (sdhc2_en) do_fixup_by_path(blob, esdhc1_path, "status", "okay", sizeof("okay"), 1); @@ -202,6 +206,7 @@ int esdhc_status_fixup(void *blob, const char *compat) sizeof("disabled"), 1); return 0; } +#endif
int ft_board_setup(void *blob, bd_t *bd) { diff --git a/configs/ls1012a2g5rdb_qspi_defconfig b/configs/ls1012a2g5rdb_qspi_defconfig new file mode 100644 index 0000000..140a4e1 --- /dev/null +++ b/configs/ls1012a2g5rdb_qspi_defconfig @@ -0,0 +1,40 @@ +CONFIG_ARM=y +CONFIG_TARGET_LS1012A2G5RDB=y +CONFIG_FSL_LS_PPA=y +CONFIG_QSPI_AHB_INIT=y +CONFIG_DEFAULT_DEVICE_TREE="fsl-ls1012a-2g5rdb" +CONFIG_DISTRO_DEFAULTS=y +# CONFIG_SYS_MALLOC_F is not set +CONFIG_FIT_VERBOSE=y +CONFIG_OF_BOARD_SETUP=y +CONFIG_OF_STDOUT_VIA_ALIAS=y +CONFIG_SYS_EXTRA_OPTIONS="QSPI_BOOT" +CONFIG_QSPI_BOOT=y +CONFIG_BOOTDELAY=10 +CONFIG_USE_BOOTARGS=y +CONFIG_BOOTARGS="console=ttyS0,115200 root=/dev/ram0 earlycon=uart8250,mmio,0x21c0500 quiet lpj=250000" +# CONFIG_DISPLAY_BOARDINFO is not set +CONFIG_CMD_GREPENV=y +CONFIG_CMD_GPT=y +CONFIG_CMD_I2C=y +CONFIG_CMD_MMC=y +CONFIG_CMD_SF=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_CACHE=y +CONFIG_OF_CONTROL=y +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_NET_RANDOM_ETHADDR=y +CONFIG_DM=y +# CONFIG_BLK is not set +CONFIG_DM_MMC=y +CONFIG_DM_SPI_FLASH=y +CONFIG_SPI_FLASH=y +CONFIG_NETDEVICES=y +CONFIG_SYS_NS16550=y +CONFIG_DM_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_XHCI_HCD=y +CONFIG_USB_XHCI_DWC3=y +CONFIG_USB_STORAGE=y diff --git a/include/configs/ls1012a2g5rdb.h b/include/configs/ls1012a2g5rdb.h new file mode 100644 index 0000000..25df103 --- /dev/null +++ b/include/configs/ls1012a2g5rdb.h @@ -0,0 +1,122 @@ +/* + * Copyright 2017 NXP + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __LS1012A2G5RDB_H__ +#define __LS1012A2G5RDB_H__ + +#include "ls1012a_common.h" + +/* PFE Ethernet */ +#ifdef CONFIG_FSL_PFE +#define EMAC1_PHY_ADDR 0x2 +#define EMAC2_PHY_ADDR 0x1 +#define CONFIG_PHYLIB +#define CONFIG_PHYLIB_10G +#define CONFIG_PHY_AQUANTIA +#endif + +/* DDR */ +#define CONFIG_DIMM_SLOTS_PER_CTLR 1 +#define CONFIG_CHIP_SELECTS_PER_CTRL 1 +#define CONFIG_NR_DRAM_BANKS 2 +#define CONFIG_SYS_SDRAM_SIZE 0x40000000 +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff + +/* MMC */ +#ifdef CONFIG_MMC +#define CONFIG_FSL_ESDHC +#define CONFIG_SYS_FSL_MMC_HAS_CAPBLT_VS33 +#endif + +/* SATA */ +#define CONFIG_LIBATA +#define CONFIG_SCSI_AHCI +#define CONFIG_SCSI_AHCI_PLAT + +#define CONFIG_SYS_SATA AHCI_BASE_ADDR + +#define CONFIG_SYS_SCSI_MAX_SCSI_ID 1 +#define CONFIG_SYS_SCSI_MAX_LUN 1 +#define CONFIG_SYS_SCSI_MAX_DEVICE (CONFIG_SYS_SCSI_MAX_SCSI_ID * \ + CONFIG_SYS_SCSI_MAX_LUN) +#define CONFIG_NET_MULTI + +#define CONFIG_CMD_MEMINFO +#define CONFIG_CMD_MEMTEST +#define CONFIG_SYS_MEMTEST_START 0x80000000 +#define CONFIG_SYS_MEMTEST_END 0x9fffffff + +#undef CONFIG_EXTRA_ENV_SETTINGS +#define CONFIG_EXTRA_ENV_SETTINGS \ + "verify=no\0" \ + "fdt_high=0xffffffffffffffff\0" \ + "initrd_high=0xffffffffffffffff\0" \ + "fdt_addr=0x00f00000\0" \ + "kernel_addr=0x01000000\0" \ + "kernelheader_addr=0x800000\0" \ + "scriptaddr=0x80000000\0" \ + "scripthdraddr=0x80080000\0" \ + "fdtheader_addr_r=0x80100000\0" \ + "kernelheader_addr_r=0x80200000\0" \ + "kernel_addr_r=0x81000000\0" \ + "fdt_addr_r=0x90000000\0" \ + "load_addr=0xa0000000\0" \ + "kernel_size=0x2800000\0" \ + "kernelheader_size=0x40000\0" \ + "console=ttyS0,115200\0" \ + BOOTENV \ + "boot_scripts=ls1012ardb_boot.scr\0" \ + "boot_script_hdr=hdr_ls1012ardb_bs.out\0" \ + "scan_dev_for_boot_part=" \ + "part list ${devtype} ${devnum} devplist; " \ + "env exists devplist || setenv devplist 1; " \ + "for distro_bootpart in ${devplist}; do " \ + "if fstype ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "bootfstype; then " \ + "run scan_dev_for_boot; " \ + "fi; " \ + "done\0" \ + "scan_dev_for_boot=" \ + "echo Scanning ${devtype} " \ + "${devnum}:${distro_bootpart}...; " \ + "for prefix in ${boot_prefixes}; do " \ + "run scan_dev_for_scripts; " \ + "done;" \ + "\0" \ + "boot_a_script=" \ + "load ${devtype} ${devnum}:${distro_bootpart} " \ + "${scriptaddr} ${prefix}${script}; " \ + "env exists secureboot && load ${devtype} " \ + "${devnum}:${distro_bootpart} " \ + "${scripthdraddr} ${prefix}${boot_script_hdr} " \ + "&& esbc_validate ${scripthdraddr};" \ + "source ${scriptaddr}\0" \ + "installer=load mmc 0:2 $load_addr " \ + "/flex_installer_arm64.itb; " \ + "bootm $load_addr#$board\0" \ + "qspi_bootcmd=echo Trying load from qspi..;" \ + "sf probe && sf read $load_addr " \ + "$kernel_addr $kernel_size; env exists secureboot " \ + "&& sf read $kernelheader_addr_r $kernelheader_addr " \ + "$kernelheader_size && esbc_validate ${kernelheader_addr_r}; " \ + "bootm $load_addr#$board\0" + +#undef CONFIG_BOOTCOMMAND +#if defined(CONFIG_QSPI_BOOT) || defined(CONFIG_SD_BOOT_QSPI) +#define CONFIG_BOOTCOMMAND "run distro_bootcmd; run qspi_bootcmd; " \ + "env exists secureboot && esbc_halt;" +#endif + +#define DEFAULT_PFE_MDIO_NAME "PFE_MDIO" +#define DEFAULT_PFE_MDIO1_NAME "PFE_MDIO1" + +#include <asm/fsl_secure_boot.h> + +#endif /* __LS1012A2G5RDB_H__ */
changes for v2:
Minor change to commit message. Applied to fsl-qoriq master. Thanks.
York
York
Bhaskar Upadhaya
York Sun
