RE: [U-Boot-Users] [PATCH] Correction to previous patch of 26th Sept which broke other boards
wd@denx.de wrote:
My understanding is that 4292 obsoletes 4278 anyway, but how is the rest (4292, 4300, 5542) related yto your latest patch?
Sorry for the confusion.
The patch
CHANGELOG
- Ensure Integrator boards call platformsetup() rather than
lowlevel_init()
- Patch by Peter Pearse 29 Sept 2005
is to be applied to the latest U-Boot code which already contains the required contents of
4278 04/11 "Peter Pearse" [U-Boot-Users] [Patch]
- Patch by Peter Pearse, 11 Apr 2005
- add core module targets for integratorap, integratorcp
- add ARM946E cpu support
- remap SSRAM memory to 0x00000000
4292 04/11 "Peter Pearse" [U-Boot-Users] [Patch] Multicore patch for ARM supplied development boards. * Patch by Peter Pearse, 12 Apr 2005 - add core module targets for integratorap, integratorcp - add ARM946E cpu support - remap SSRAM memory to 0x00000000
It does not make them obsolete but assumes 4292 been applied. I assume you have applied them previously, or patches submitted by others, had the same code.
The patch
5542 06/30 "Peter Pearse" [U-Boot-Users] [PATCH] Differing gcc version ARM options * Patch by Peter Pearse, 30th June 2005
- Import cc-option shell function from kernel
- Use it to get the correct ARM gcc options for individual cpus
remains unapplied and viable, should you accept it.
(I have just applied it successfully to the code from the latest GITHead, it is already appplied in the branch I use and has caused no problems with my overnight MAKEALL arm builds using arm-linux-gcc 3.4.2).
The patch
4300 04/12 "Peter Pearse" [U-Boot-Users] [Patch] CFI flash for ARM supplied & supported development boards * Patch by Peter Pearse, 12 Apr 2005 Changes all ARM supplied development boards, supported by ARM, to use CFI flash. Adds CFI support for the Versatile/AB926EJ-S.
should be withdrawn, because the tree has changed a lot since it's submission.
I am working on a new patch against the current GIT head to replace it.
Summary ======= 4278 Obsolete - replaced by 4292 4292 code (or equivalent) is in the GIT head from http://source.denx.net/git/u-boot.git/ 4300 Obsolete - to be replaced. 5542 Still valid - submitted for approval.
Hope this helps
Regards
Peter Pearse
Peter Pearse
