[U-Boot] can't update U-boot when booting with BDI2000
Hi
Im new to U-boot and need help. I am using U-boot-2009.10 and a MPC8548 board with 512MB DDR and 128Mb nor Flash(using cfi)
I am booting the board using a BDI2000 by loading my u-boot.bin file to the bootregion in my memory map (FFF80000) and running from the reset vector. Uboot starts up and works fine. I am able to unprotected the flash ( confirmed with flinfo) and can erase sectors other than the bootsector. I have placed the output below.
UBoot=> protect off all Un-Protect Flash Bank # 1 UBoot=> erase fff80000 ffffffff .. done Erased 2 sectors UBoot=>
When I look at the erased memory using md the u-boot image that was loaded into memory by the bdi is shown at the bootsector address fff80000 UBoot=> md fff80000 fff80000: 00300030 552d426f 6f742032 3030392e .0.0U-Boot 2009. fff80010: 30312d30 30323236 2d673663 36653034 01-00226-g6c6e04
if i reboot the board not using the BDI the bootregion shows the old uboot image and was not erased.
I think the sram is mapped over the flash boot region and when i try to erase and cp to the bootreagion the commands and date gets lost. Can anyone help me find the problem? thanks Hendrik
Dear hendrik,
Fix your BDI2000 config file. Try and not map SRAM at all. Or simply start the board using "reset run" so the init statements are not executed.
Wolfgang Denk wrote:
Dear hendrik,
What happens is that booting with the BDI2000 your cpu's cache is used as SRAM into witch the BDI loads your u-boot image. The old uboot used to return this mapped SRAM to normal L2 cache, but in the new U-boot the L2 cache is not set to back to cache due to an if statement which checks if cache is enabled but does not check to see if the L2 cache is used as SRAM or cache( cpu_init_r()) .( I would like to know the reason for this ?)
An easy workaround to unmap the SRAM and gain access to your flash is to write a u-boot script or simply do the following:
find the addres of your relocated CCSRBAR , in my case: 0xe000 0000 get the offset for L2 Control Register L2CTL from data sheet: 0x0002 0000 (mpc8548) now simply write 0x20000000 to CCSRBAR + L2CTL(offset):
mw 0xe0020000 0x20000000 this unmappes the SRAM making your flash available and sets up the L2 cache
hendrik
Pieter
