[PATCH v2 00/28] ARM: Add Rockchip RV1126 support
RV1126 is a high-performance vision processor SoC for IPC/CVR, especially for AI related application.
This patch series add basic core support for Rockchip RV1126 and boot from eMMC and SD.
Linux support is under review for the same [2] and v1 can be [3].
Tested RV1126 in Edgeble AI Edge Compute Module 0.
Anyone interested, please have a look on this repo [1]
Note: I was little late to push this MW due to some issues, hope these would land as soon as possible.
[1] https://github.com/edgeble/u-boot/commits/ecm0-v4 [2] https://patchwork.kernel.org/project/linux-arm-kernel/cover/20220818124132.1... [3] https://patchwork.ozlabs.org/project/uboot/cover/20220727174050.2214617-1-ja...
Any inputs? Jagan.
Jagan Teki (28): ram: Mark ram-uclass depend on TPL_DM or SPL_DM ram: rockchip: Add common ddr type configs tools: rkcommon: Correct SPL size for px30 ram: rockchip: Compute ddr capacity based on grf split ram: rockchip: Update high row detection for full bw ram: rockchip: Update ddr pctl regs for px30 ram: rockchip: Add rv1126 ddr3 support ram: rockchip: Add rv1126 ddr loader params ram: rockchip: Add rv1126 ddr driver support ram: rockchip: rv1126: Control ddr init prints via DEBUG ram: rockchip: Add rv1126 lpddr4 support pinctrl: rockchip: Add pinctrl route types pinctrl: rockchip: Add rv1126 support arch: rockchip: Add cru header for rv1126 dt-bindings: clk: Add dt-binding header for RV1126 clk: rockchip: Add rv1126 clk support dt-bindings: power: Add power-domain header for rv1126 arm: rockchip: Add grf header for rv1126 ARM: dts: rockchip: Add Rockchip RV1126 pinctrl ARM: dts: rockchip: Add Rockchip RV1126 SoC arm: rockchip: Add RV1126 arch core support arm: rockchip: rv1126: Set dram area unsecure for SPL configs: rockchip: Add rv1126 common config rockchip: mkimage: Add rv1126 support ARM: dts: rockchip: rv1126: Add Edgeble AI Edge Compute Module 0 ARM: dts: rockchip: rv1126: Add Edgeble AI Edge Compute Module 0 Carrier ARM: dts: rockchip: Add rv1126-u-boot.dtsi board: Add Edgeble AI Edge Compute Module 0 Carrier
arch/arm/dts/Makefile | 3 + .../rv1126-edgeble-ecm0-carrier-u-boot.dtsi | 10 + arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts | 38 + .../rv1126-edgeble-edge-compute-module-0.dtsi | 329 ++ arch/arm/dts/rv1126-pinctrl.dtsi | 302 ++ arch/arm/dts/rv1126-u-boot.dtsi | 62 + arch/arm/dts/rv1126.dtsi | 500 +++ .../include/asm/arch-rockchip/cru_rv1126.h | 459 +++ .../asm/arch-rockchip/dram_spec_timing.h | 452 +++ .../include/asm/arch-rockchip/grf_rv1126.h | 251 ++ .../include/asm/arch-rockchip/sdram_common.h | 216 +- .../include/asm/arch-rockchip/sdram_msch.h | 12 + .../asm/arch-rockchip/sdram_pctl_px30.h | 100 +- .../asm/arch-rockchip/sdram_phy_rv1126.h | 93 + .../include/asm/arch-rockchip/sdram_rv1126.h | 420 ++ arch/arm/include/asm/arch-rv1126/boot0.h | 11 + arch/arm/include/asm/arch-rv1126/gpio.h | 11 + arch/arm/mach-rockchip/Kconfig | 46 + arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/rv1126/Kconfig | 55 + arch/arm/mach-rockchip/rv1126/Makefile | 13 + arch/arm/mach-rockchip/rv1126/clk_rv1126.c | 33 + arch/arm/mach-rockchip/rv1126/rv1126.c | 75 + arch/arm/mach-rockchip/rv1126/syscon_rv1126.c | 47 + board/edgeble/edge-compute-module-0/Kconfig | 16 + .../edgeble/edge-compute-module-0/MAINTAINERS | 6 + board/edgeble/edge-compute-module-0/Makefile | 7 + board/edgeble/edge-compute-module-0/ecm0.c | 4 + board/engicam/px30_core/Kconfig | 2 +- common/spl/Kconfig.tpl | 2 +- configs/ecm0-carrier-rv1126_defconfig | 56 + configs/khadas-edge-captain-rk3399_defconfig | 2 +- configs/khadas-edge-rk3399_defconfig | 2 +- configs/khadas-edge-v-rk3399_defconfig | 2 +- configs/leez-rk3399_defconfig | 2 +- configs/nanopi-r4s-rk3399_defconfig | 2 +- configs/pinebook-pro-rk3399_defconfig | 2 +- configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rockpro64-rk3399_defconfig | 2 +- drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rv1126.c | 1889 +++++++++ drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl-px30.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3128.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk322x.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3308.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3328.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3399.c | 11 +- .../pinctrl/rockchip/pinctrl-rockchip-core.c | 45 +- drivers/pinctrl/rockchip/pinctrl-rockchip.h | 58 +- drivers/pinctrl/rockchip/pinctrl-rv1126.c | 416 ++ drivers/ram/Makefile | 2 +- drivers/ram/rockchip/Kconfig | 32 +- drivers/ram/rockchip/Makefile | 1 + .../sdram-rv1126-ddr3-detect-1056.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-328.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-396.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-528.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-664.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-784.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-924.inc | 72 + .../rockchip/sdram-rv1126-loader_params.inc | 198 + .../sdram-rv1126-lpddr4-detect-1056.inc | 78 + .../sdram-rv1126-lpddr4-detect-328.inc | 78 + .../sdram-rv1126-lpddr4-detect-396.inc | 78 + .../sdram-rv1126-lpddr4-detect-528.inc | 78 + .../sdram-rv1126-lpddr4-detect-664.inc | 78 + .../sdram-rv1126-lpddr4-detect-784.inc | 78 + .../sdram-rv1126-lpddr4-detect-924.inc | 78 + drivers/ram/rockchip/sdram_common.c | 62 +- drivers/ram/rockchip/sdram_pctl_px30.c | 6 +- drivers/ram/rockchip/sdram_px30.c | 10 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 8 +- drivers/ram/rockchip/sdram_rv1126.c | 3543 +++++++++++++++++ include/configs/edge-compute-module-0.h | 21 + include/configs/rv1126_common.h | 42 + .../dt-bindings/clock/rockchip,rv1126-cru.h | 632 +++ .../dt-bindings/power/rockchip,rv1126-power.h | 35 + tools/rkcommon.c | 3 +- 84 files changed, 11656 insertions(+), 132 deletions(-) create mode 100644 arch/arm/dts/rv1126-edgeble-ecm0-carrier-u-boot.dtsi create mode 100644 arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts create mode 100644 arch/arm/dts/rv1126-edgeble-edge-compute-module-0.dtsi create mode 100644 arch/arm/dts/rv1126-pinctrl.dtsi create mode 100644 arch/arm/dts/rv1126-u-boot.dtsi create mode 100644 arch/arm/dts/rv1126.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/dram_spec_timing.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rv1126.h create mode 100644 arch/arm/include/asm/arch-rv1126/boot0.h create mode 100644 arch/arm/include/asm/arch-rv1126/gpio.h create mode 100644 arch/arm/mach-rockchip/rv1126/Kconfig create mode 100644 arch/arm/mach-rockchip/rv1126/Makefile create mode 100644 arch/arm/mach-rockchip/rv1126/clk_rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/syscon_rv1126.c create mode 100644 board/edgeble/edge-compute-module-0/Kconfig create mode 100644 board/edgeble/edge-compute-module-0/MAINTAINERS create mode 100644 board/edgeble/edge-compute-module-0/Makefile create mode 100644 board/edgeble/edge-compute-module-0/ecm0.c create mode 100644 configs/ecm0-carrier-rv1126_defconfig create mode 100644 drivers/clk/rockchip/clk_rv1126.c create mode 100644 drivers/pinctrl/rockchip/pinctrl-rv1126.c create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-924.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-loader_params.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-924.inc create mode 100644 drivers/ram/rockchip/sdram_rv1126.c create mode 100644 include/configs/edge-compute-module-0.h create mode 100644 include/configs/rv1126_common.h create mode 100644 include/dt-bindings/clock/rockchip,rv1126-cru.h create mode 100644 include/dt-bindings/power/rockchip,rv1126-power.h
ram-uclass is building irrespective of whether TPL_DM or SPL_DM is enabled. So control the ram uclass build based on TPL/SPL_DM.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - none
drivers/ram/Makefile | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ram/Makefile b/drivers/ram/Makefile index 5a39611349..83948e2c43 100644 --- a/drivers/ram/Makefile +++ b/drivers/ram/Makefile @@ -3,7 +3,7 @@ # Copyright (c) 2015 Google, Inc # Wolfgang Denk, DENX Software Engineering, wd@denx.de. # -obj-$(CONFIG_RAM) += ram-uclass.o +obj-$(CONFIG_$(SPL_TPL_)DM) += ram-uclass.o obj-$(CONFIG_MPC83XX_SDRAM) += mpc83xx_sdram.o obj-$(CONFIG_SANDBOX) += sandbox_ram.o obj-$(CONFIG_STM32MP1_DDR) += stm32mp1/
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
We have common ddr types in rockchip or in general. So use the common ddr type names instead of per Rockchip SoC to avoid confusion.
The respective ddr type names will use on the associated ddr SoC driver as these drivers are built per SoC at a time.
board/engicam/px30_core/Kconfig | 2 +- configs/khadas-edge-captain-rk3399_defconfig | 2 +- configs/khadas-edge-rk3399_defconfig | 2 +- configs/khadas-edge-v-rk3399_defconfig | 2 +- configs/leez-rk3399_defconfig | 2 +- configs/nanopi-r4s-rk3399_defconfig | 2 +- configs/pinebook-pro-rk3399_defconfig | 2 +- configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rockpro64-rk3399_defconfig | 2 +- drivers/ram/rockchip/Kconfig | 32 +++++++++----------- drivers/ram/rockchip/sdram_px30.c | 6 ++-- drivers/ram/rockchip/sdram_rk3399.c | 6 ++-- 15 files changed, 33 insertions(+), 35 deletions(-)
diff --git a/board/engicam/px30_core/Kconfig b/board/engicam/px30_core/Kconfig index a03be78369..924c30f3e1 100644 --- a/board/engicam/px30_core/Kconfig +++ b/board/engicam/px30_core/Kconfig @@ -11,6 +11,6 @@ config SYS_CONFIG_NAME
config BOARD_SPECIFIC_OPTIONS # dummy def_bool y - select RAM_PX30_DDR4 + select RAM_ROCKCHIP_DDR4
endif diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index 9a0171e4a8..ddf11afaae 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -54,7 +54,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index 27f119931f..2881d7145b 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -53,7 +53,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index de2b625120..35f3812ae4 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -54,7 +54,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/leez-rk3399_defconfig b/configs/leez-rk3399_defconfig index 1e708ed3f9..e3db8ed2f5 100644 --- a/configs/leez-rk3399_defconfig +++ b/configs/leez-rk3399_defconfig @@ -49,7 +49,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index 917fd3fd8e..6816bf7575 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -50,7 +50,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 CONFIG_SYSRESET=y diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index 602bcb78cb..43f6bbda16 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -75,7 +75,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_DM_RESET=y CONFIG_DM_RNG=y CONFIG_RNG_ROCKCHIP=y diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index f537a605e1..2723d9a9ec 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -68,7 +68,7 @@ CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y # CONFIG_RAM_ROCKCHIP_DEBUG is not set -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index a502e549fb..7db4e3fc1e 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -65,7 +65,7 @@ CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y # CONFIG_RAM_ROCKCHIP_DEBUG is not set -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index cf2e9fbde3..384a10e522 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -59,7 +59,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index fd5b25d77b..f1c9391bff 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -59,7 +59,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_DM_RESET=y CONFIG_BAUDRATE=1500000 CONFIG_DEBUG_UART_SHIFT=2 diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 72a5b78d79..fab98e0ea3 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -72,7 +72,7 @@ CONFIG_PMIC_RK8XX=y CONFIG_REGULATOR_PWM=y CONFIG_REGULATOR_RK8XX=y CONFIG_PWM_ROCKCHIP=y -CONFIG_RAM_RK3399_LPDDR4=y +CONFIG_RAM_ROCKCHIP_LPDDR4=y CONFIG_DM_RESET=y CONFIG_DM_RNG=y CONFIG_RNG_ROCKCHIP=y diff --git a/drivers/ram/rockchip/Kconfig b/drivers/ram/rockchip/Kconfig index c459bbf5e2..d87671b42c 100644 --- a/drivers/ram/rockchip/Kconfig +++ b/drivers/ram/rockchip/Kconfig @@ -11,9 +11,10 @@ config ROCKCHIP_SDRAM_COMMON help This enable sdram common driver
+if RAM_ROCKCHIP + config RAM_ROCKCHIP_DEBUG bool "Rockchip ram drivers debugging" - depends on RAM_ROCKCHIP default y help This enables debugging ram driver API's for the platforms @@ -22,31 +23,28 @@ config RAM_ROCKCHIP_DEBUG This is an option for developers to understand the ram drivers initialization, configurations and etc.
-config RAM_PX30_DDR4 - bool "DDR3 support for Rockchip PX30" - depends on RAM_ROCKCHIP && ROCKCHIP_PX30 +config RAM_ROCKCHIP_DDR4 + bool "DDR3 support for Rockchip SoCs" help This enables DDR4 sdram support instead of the default DDR3 support - on Rockchip PC30 SoCs. + on Rockchip SoCs.
-config RAM_PX30_LPDDR2 - bool "LPDDR2 support for Rockchip PX30" - depends on RAM_ROCKCHIP && ROCKCHIP_PX30 +config RAM_ROCKCHIP_LPDDR2 + bool "LPDDR2 support for Rockchip SoCs" help This enables LPDDR2 sdram support instead of the default DDR3 support - on Rockchip PC30 SoCs. + on Rockchip SoCs.
-config RAM_PX30_LPDDR3 - bool "LPDDR3 support for Rockchip PX30" - depends on RAM_ROCKCHIP && ROCKCHIP_PX30 +config RAM_ROCKCHIP_LPDDR3 + bool "LPDDR3 support for Rockchip SoCs" help This enables LPDDR3 sdram support instead of the default DDR3 support - on Rockchip PC30 SoCs. + on Rockchip SoCs.
-config RAM_RK3399_LPDDR4 - bool "LPDDR4 support for Rockchip RK3399" - depends on RAM_ROCKCHIP && ROCKCHIP_RK3399 +config RAM_ROCKCHIP_LPDDR4 + bool "LPDDR4 support for Rockchip SoCs" help This enables LPDDR4 sdram code support for the platforms based - on Rockchip RK3399 SoC. + on Rockchip SoCs.
+endif # RAM_ROCKCHIP diff --git a/drivers/ram/rockchip/sdram_px30.c b/drivers/ram/rockchip/sdram_px30.c index c024a0cd63..357fe2432a 100644 --- a/drivers/ram/rockchip/sdram_px30.c +++ b/drivers/ram/rockchip/sdram_px30.c @@ -125,11 +125,11 @@ u32 addrmap[][8] = { struct dram_info dram_info;
struct px30_sdram_params sdram_configs[] = { -#if defined(CONFIG_RAM_PX30_DDR4) +#if defined(CONFIG_RAM_ROCKCHIP_DDR4) #include "sdram-px30-ddr4-detect-333.inc" -#elif defined(CONFIG_RAM_PX30_LPDDR2) +#elif defined(CONFIG_RAM_ROCKCHIP_LPDDR2) #include "sdram-px30-lpddr2-detect-333.inc" -#elif defined(CONFIG_RAM_PX30_LPDDR3) +#elif defined(CONFIG_RAM_ROCKCHIP_LPDDR3) #include "sdram-px30-lpddr3-detect-333.inc" #else #include "sdram-px30-ddr3-detect-333.inc" diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index c0a06dcaed..0a88ee9f93 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -1625,7 +1625,7 @@ static void set_ddr_stride(struct rk3399_pmusgrf_regs *pmusgrf, u32 stride) rk_clrsetreg(&pmusgrf->soc_con4, 0x1f << 10, stride << 10); }
-#if !defined(CONFIG_RAM_RK3399_LPDDR4) +#if !defined(CONFIG_RAM_ROCKCHIP_LPDDR4) static int data_training_first(struct dram_info *dram, u32 channel, u8 rank, struct rk3399_sdram_params *params) { @@ -2559,7 +2559,7 @@ static int lpddr4_set_rate(struct dram_info *dram,
return 0; } -#endif /* CONFIG_RAM_RK3399_LPDDR4 */ +#endif /* CONFIG_RAM_ROCKCHIP_LPDDR4 */
/* CS0,n=1 * CS1,n=2 @@ -3051,7 +3051,7 @@ static int conv_of_plat(struct udevice *dev) #endif
static const struct sdram_rk3399_ops rk3399_ops = { -#if !defined(CONFIG_RAM_RK3399_LPDDR4) +#if !defined(CONFIG_RAM_ROCKCHIP_LPDDR4) .data_training_first = data_training_first, .set_rate_index = switch_to_phy_index1, .modify_param = modify_param,
Thanks, - Kever
Changes for v2:
none
endif
+if RAM_ROCKCHIP
- config RAM_ROCKCHIP_DEBUG bool "Rockchip ram drivers debugging"
- bool "DDR3 support for Rockchip SoCs" help This enables DDR4 sdram support instead of the default DDR3 support
on Rockchip SoCs.
- bool "LPDDR2 support for Rockchip SoCs" help This enables LPDDR2 sdram support instead of the default DDR3 support
on Rockchip SoCs.
- bool "LPDDR3 support for Rockchip SoCs" help This enables LPDDR3 sdram support instead of the default DDR3 support
on Rockchip SoCs.
- bool "LPDDR4 support for Rockchip SoCs" help This enables LPDDR4 sdram code support for the platforms based
on Rockchip SoCs.
/* CS0,n=1
- CS1,n=2
Rockchip PX30 has 16KB sram, bootrom reserved 4KB as stack.
Correct it.
tools/rkcommon.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 0db45c2d41..1325aa83cb 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -121,7 +121,7 @@ struct spl_info { };
static struct spl_info spl_infos[] = { - { "px30", "RK33", 0x2800, false, RK_HEADER_V1 }, + { "px30", "RK33", 0x4000 - 0x1000, false, RK_HEADER_V1 }, { "rk3036", "RK30", 0x1000, false, RK_HEADER_V1 }, { "rk3066", "RK30", 0x8000 - 0x800, true, RK_HEADER_V1 }, { "rk3128", "RK31", 0x1800, false, RK_HEADER_V1 },
NAK, the origin code is correct, do not modify this.
Thanks, - Kever
Correct it.
Changes for v2:
none
- { "px30", "RK33", 0x4000 - 0x1000, false, RK_HEADER_V1 }, { "rk3036", "RK30", 0x1000, false, RK_HEADER_V1 }, { "rk3066", "RK30", 0x8000 - 0x800, true, RK_HEADER_V1 }, { "rk3128", "RK31", 0x1800, false, RK_HEADER_V1 },
SPL size increment due to updating high row detection code - so patch indeed that correction to use 16KB SRAM.
MKIMAGE u-boot.img MKIMAGE u-boot-dtb.img ./"arch/arm/mach-rockchip/make_fit_atf.py" \ arch/arm/dts/px30-evb.dtb > u-boot.its MKIMAGE u-boot.itb MKIMAGE tpl/u-boot-tpl-rockchip.bin Error: SPL image is too large (size 0x3000 than 0x2800) Error: Bad parameters for image type Usage: ./tools/mkimage [-T type] -l image
Hi Jagan,
Rockchip px30 ddr binary size is 10000(0x2710).
When the secure boot is enabled, the SRAM only have 10KB available for ddr init,
so you'd better to make the TPL size smaller.
Thanks,
- Kever
DDR chip capacity is computed based on GRF split in some Rockchip SoC's like PX30 and RV1126.
Add split argument in ddr print info so-that the respective ddr driver will pass the grf split.
Signed-off-by: YouMin Chen cym@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - none
arch/arm/include/asm/arch-rockchip/sdram_common.h | 2 +- drivers/ram/rockchip/sdram_common.c | 6 ++++-- drivers/ram/rockchip/sdram_px30.c | 2 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 2 +- 5 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index 5efa6e9445..a14b37cbc5 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -116,7 +116,7 @@ struct sdram_base_params {
void sdram_print_dram_type(unsigned char dramtype); void sdram_print_ddr_info(struct sdram_cap_info *cap_info, - struct sdram_base_params *base); + struct sdram_base_params *base, u32 split); void sdram_print_stride(unsigned int stride);
void sdram_org_config(struct sdram_cap_info *cap_info, diff --git a/drivers/ram/rockchip/sdram_common.c b/drivers/ram/rockchip/sdram_common.c index b3e7421d08..1c3236746a 100644 --- a/drivers/ram/rockchip/sdram_common.c +++ b/drivers/ram/rockchip/sdram_common.c @@ -36,7 +36,7 @@ void sdram_print_dram_type(unsigned char dramtype) }
void sdram_print_ddr_info(struct sdram_cap_info *cap_info, - struct sdram_base_params *base) + struct sdram_base_params *base, u32 split) { u64 cap; u32 bg; @@ -83,6 +83,8 @@ void sdram_print_ddr_info(struct sdram_cap_info *cap_info, cap = sdram_get_cs_cap(cap_info, 3, base->dramtype); if (cap_info->row_3_4) cap = cap * 3 / 4; + else if (split) + cap = cap / 2 + (split << 24) / 2;
printascii(" Size="); printdec(cap >> 20); @@ -123,7 +125,7 @@ inline void sdram_print_dram_type(unsigned char dramtype) }
inline void sdram_print_ddr_info(struct sdram_cap_info *cap_info, - struct sdram_base_params *base) + struct sdram_base_params *base, u32 split) { }
diff --git a/drivers/ram/rockchip/sdram_px30.c b/drivers/ram/rockchip/sdram_px30.c index 357fe2432a..a003893538 100644 --- a/drivers/ram/rockchip/sdram_px30.c +++ b/drivers/ram/rockchip/sdram_px30.c @@ -711,7 +711,7 @@ int sdram_init(void) if (ret) goto error;
- sdram_print_ddr_info(&sdram_params->ch.cap_info, &sdram_params->base); + sdram_print_ddr_info(&sdram_params->ch.cap_info, &sdram_params->base, 0);
printascii("out\n"); return ret; diff --git a/drivers/ram/rockchip/sdram_rk3328.c b/drivers/ram/rockchip/sdram_rk3328.c index 9c6798f816..efe0049ead 100644 --- a/drivers/ram/rockchip/sdram_rk3328.c +++ b/drivers/ram/rockchip/sdram_rk3328.c @@ -506,7 +506,7 @@ static int sdram_init_detect(struct dram_info *dram, writel(sys_reg3, &dram->grf->os_reg[3]); }
return 0; } diff --git a/drivers/ram/rockchip/sdram_rk3399.c b/drivers/ram/rockchip/sdram_rk3399.c index 0a88ee9f93..86f5c06583 100644 --- a/drivers/ram/rockchip/sdram_rk3399.c +++ b/drivers/ram/rockchip/sdram_rk3399.c @@ -2983,7 +2983,7 @@ static int sdram_init(struct dram_info *dram, continue; }
- sdram_print_ddr_info(cap_info, ¶ms->base); + sdram_print_ddr_info(cap_info, ¶ms->base, 0); set_memory_map(chan, channel, params); cap_info->ddrconfig = calculate_ddrconfig(params, channel);
Thanks, - Kever
Changes for v2:
none
{ u64 cap; u32 bg;struct sdram_base_params *base, u32 split)
else if (split)
{ }struct sdram_base_params *base, u32 split)
return 0; }
set_memory_map(chan, channel, params); cap_info->ddrconfig = calculate_ddrconfig(params, channel);sdram_print_ddr_info(cap_info, ¶ms->base, 0);
High row detection for non-8bit bw requires axi split.
So, update the existing high row detection code in order to support full bw chips.
.../include/asm/arch-rockchip/sdram_common.h | 2 +- drivers/ram/rockchip/sdram_common.c | 56 ++++++++++++++++++- drivers/ram/rockchip/sdram_px30.c | 2 +- 3 files changed, 55 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index a14b37cbc5..dd316f771a 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -136,7 +136,7 @@ int sdram_detect_row(struct sdram_cap_info *cap_info, u32 coltmp, u32 bktmp, u32 rowtmp); int sdram_detect_row_3_4(struct sdram_cap_info *cap_info, u32 coltmp, u32 bktmp); -int sdram_detect_high_row(struct sdram_cap_info *cap_info); +int sdram_detect_high_row(struct sdram_cap_info *cap_info, u32 dramtype); int sdram_detect_cs1_row(struct sdram_cap_info *cap_info, u32 dram_type); u64 sdram_get_cs_cap(struct sdram_cap_info *cap_info, u32 cs, u32 dram_type); void sdram_copy_to_reg(u32 *dest, const u32 *src, u32 n); diff --git a/drivers/ram/rockchip/sdram_common.c b/drivers/ram/rockchip/sdram_common.c index 1c3236746a..17d0096dfd 100644 --- a/drivers/ram/rockchip/sdram_common.c +++ b/drivers/ram/rockchip/sdram_common.c @@ -381,10 +381,60 @@ int sdram_detect_row_3_4(struct sdram_cap_info *cap_info, return 0; }
-int sdram_detect_high_row(struct sdram_cap_info *cap_info) +int sdram_detect_high_row(struct sdram_cap_info *cap_info, u32 dramtype) { - cap_info->cs0_high16bit_row = cap_info->cs0_row; - cap_info->cs1_high16bit_row = cap_info->cs1_row; + unsigned long base_addr; + u32 cs0_high_row, cs1_high_row, cs; + u64 cap = 0, cs0_cap = 0; + u32 i; + void __iomem *test_addr, *test_addr1; + + cs = cap_info->rank; + /* 8bit bandwidth no enable axi split*/ + if (!cap_info->bw) { + cs0_high_row = cap_info->cs0_row; + cs1_high_row = cap_info->cs1_row; + goto out; + } + + cs0_cap = sdram_get_cs_cap(cap_info, 0, dramtype); + if (cs == 2) { + base_addr = CONFIG_SYS_SDRAM_BASE + cs0_cap; + cap = sdram_get_cs_cap(cap_info, 1, dramtype); + } else { + base_addr = CONFIG_SYS_SDRAM_BASE; + cap = cs0_cap; + } + /* detect full bandwidth size */ + for (i = 0; i < 4; i++) { + test_addr = (void __iomem *)base_addr; + test_addr1 = (void __iomem *)(base_addr + + (unsigned long)(cap / (1ul << (i + 1)))); + writel(0x0, test_addr); + writel(PATTERN, test_addr1); + if ((readl(test_addr) == 0x0) && + (readl(test_addr1) == PATTERN)) + break; + } + if (i == 4 && cs == 1) { + printascii("can't support this cap\n"); + return -1; + } + + if (cs == 2) { + cs0_high_row = cap_info->cs0_row; + if (i == 4) + cs1_high_row = 0; + else + cs1_high_row = cap_info->cs1_row - i; + } else { + cs0_high_row = cap_info->cs0_row - i; + cs1_high_row = 0; + } + +out: + cap_info->cs0_high16bit_row = cs0_high_row; + cap_info->cs1_high16bit_row = cs1_high_row;
return 0; } diff --git a/drivers/ram/rockchip/sdram_px30.c b/drivers/ram/rockchip/sdram_px30.c index a003893538..6b700f5ce5 100644 --- a/drivers/ram/rockchip/sdram_px30.c +++ b/drivers/ram/rockchip/sdram_px30.c @@ -677,7 +677,7 @@ static int sdram_init_detect(struct dram_info *dram, writel(sys_reg3, &dram->pmugrf->os_reg[3]); }
- ret = sdram_detect_high_row(cap_info); + ret = sdram_detect_high_row(cap_info, sdram_params->base.dramtype);
out: return ret;
Thanks, - Kever
Changes for v2:
none
- unsigned long base_addr;
- u32 cs0_high_row, cs1_high_row, cs;
- u64 cap = 0, cs0_cap = 0;
- u32 i;
- void __iomem *test_addr, *test_addr1;
- cs = cap_info->rank;
- /* 8bit bandwidth no enable axi split*/
- if (!cap_info->bw) {
goto out;
- cs0_cap = sdram_get_cs_cap(cap_info, 0, dramtype);
- if (cs == 2) {
- } else {
cap = cs0_cap;
- /* detect full bandwidth size */
- for (i = 0; i < 4; i++) {
break;
- if (i == 4 && cs == 1) {
return -1;
- if (cs == 2) {
if (i == 4)
cs1_high_row = 0;
else
- } else {
cs1_high_row = 0;
+out:
return 0; }
out: return ret;
Add full ddr pctl registers and bit masks for px30.
.../asm/arch-rockchip/sdram_pctl_px30.h | 100 +++++++++++++++++- drivers/ram/rockchip/sdram_pctl_px30.c | 6 +- 2 files changed, 101 insertions(+), 5 deletions(-)
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h b/arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h index 3a3657789f..3780dc6ea5 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_pctl_px30.h @@ -12,7 +12,7 @@ #endif
struct ddr_pctl_regs { - u32 pctl[30][2]; + u32 pctl[35][2]; };
/* ddr pctl registers define */ @@ -25,6 +25,7 @@ struct ddr_pctl_regs { #define DDR_PCTL2_MRCTRL2 0x1c #define DDR_PCTL2_DERATEEN 0x20 #define DDR_PCTL2_DERATEINT 0x24 +#define DDR_PCTL2_MSTR2 0x28 #define DDR_PCTL2_PWRCTL 0x30 #define DDR_PCTL2_PWRTMG 0x34 #define DDR_PCTL2_HWLPCTL 0x38 @@ -122,8 +123,103 @@ struct ddr_pctl_regs { #define DDR_PCTL2_PCFGW_n 0x408 #define DDR_PCTL2_PCTRL_n 0x490
+#define UMCTL2_REGS_FREQ(n) \ + ((0x1000 * (n) + (((n) > 0) ? 0x1000 : 0))) + +/* PCTL2_MSTR */ +#define PCTL2_FREQUENCY_MODE_MASK (1) +#define PCTL2_FREQUENCY_MODE_SHIFT (29) +#define PCTL2_DLL_OFF_MODE BIT(15) +/* PCTL2_STAT */ +#define PCTL2_SELFREF_TYPE_MASK (3 << 4) +#define PCTL2_SELFREF_TYPE_SR_NOT_AUTO (2 << 4) +#define PCTL2_OPERATING_MODE_MASK (7) +#define PCTL2_OPERATING_MODE_INIT (0) +#define PCTL2_OPERATING_MODE_NORMAL (1) +#define PCTL2_OPERATING_MODE_PD (2) +#define PCTL2_OPERATING_MODE_SR (3) +/* PCTL2_MRCTRL0 */ +#define PCTL2_MR_WR BIT(31) +#define PCTL2_MR_ADDR_SHIFT (12) +#define PCTL2_MR_RANK_SHIFT (4) +#define PCTL2_MR_TYPE_WR (0) +#define PCTL2_MR_TYPE_RD (1) +/* PCTL2_MRCTRL1 */ +#define PCTL2_MR_ADDRESS_SHIFT (8) +#define PCTL2_MR_DATA_MASK (0xff) /* PCTL2_MRSTAT */ -#define MR_WR_BUSY BIT(0) +#define PCTL2_MR_WR_BUSY BIT(0) +/* PCTL2_DERATEEN */ +#define PCTL2_DERATE_ENABLE (1) +/* PCTL2_PWRCTL */ +#define PCTL2_SELFREF_SW BIT(5) +#define PCTL2_POWERDOWN_EN BIT(1) +#define PCTL2_SELFREF_EN (1) +/* PCTL2_PWRTMG */ +#define PCTL2_SELFREF_TO_X32_MASK (0xFF) +#define PCTL2_SELFREF_TO_X32_SHIFT (16) +#define PCTL2_POWERDOWN_TO_X32_MASK (0x1F) +/* PCTL2_INIT3 */ +#define PCTL2_DDR34_MR0_SHIFT (16) +#define PCTL2_LPDDR234_MR1_SHIFT (16) +#define PCTL2_DDR34_MR1_SHIFT (0) +#define PCTL2_LPDDR234_MR2_SHIFT (0) +/* PCTL2_INIT4 */ +#define PCTL2_DDR34_MR2_SHIFT (16) +#define PCTL2_LPDDR234_MR3_SHIFT (16) +#define PCTL2_DDR34_MR3_SHIFT (0) +#define PCTL2_LPDDR4_MR13_SHIFT (0) + +/* PCTL2_INIT6 */ +#define PCTL2_DDR4_MR4_SHIFT (16) +#define PCTL2_LPDDR4_MR11_SHIFT (16) +#define PCTL2_DDR4_MR5_SHIFT (0) +#define PCTL2_LPDDR4_MR12_SHIFT (0) + +/* PCTL2_INIT7 */ +#define PCTL2_LPDDR4_MR22_SHIFT (16) +#define PCTL2_DDR4_MR6_SHIFT (0) +#define PCTL2_LPDDR4_MR14_SHIFT (0) + +#define PCTL2_MR_MASK (0xffff) + +/* PCTL2_RFSHCTL3 */ +#define PCTL2_DIS_AUTO_REFRESH (1) +/* PCTL2_ZQCTL0 */ +#define PCTL2_DIS_AUTO_ZQ BIT(31) +#define PCTL2_DIS_SRX_ZQCL BIT(30) +/* PCTL2_DFILPCFG0 */ +#define PCTL2_DFI_LP_EN_SR BIT(8) +#define PCTL2_DFI_LP_EN_SR_MASK BIT(8) +#define PCTL2_DFI_LP_EN_SR_SHIFT (8) +/* PCTL2_DFIMISC */ +#define PCTL2_DFI_INIT_COMPLETE_EN (1) +/* PCTL2_DFISTAT */ +#define PCTL2_DFI_LP_ACK BIT(1) +#define PCTL2_DFI_INIT_COMPLETE (1) +/* PCTL2_DBG1 */ +#define PCTL2_DIS_HIF BIT(1) +/* PCTL2_DBGCAM */ +#define PCTL2_DBG_WR_Q_EMPTY BIT(26) +#define PCTL2_DBG_RD_Q_EMPTY BIT(25) +#define PCTL2_DBG_LPR_Q_DEPTH_MASK (0xffff << 8) +#define PCTL2_DBG_LPR_Q_DEPTH_EMPTY (0x0 << 8) +/* PCTL2_DBGCMD */ +#define PCTL2_RANK1_REFRESH BIT(1) +#define PCTL2_RANK0_REFRESH (1) +/* PCTL2_DBGSTAT */ +#define PCTL2_RANK1_REFRESH_BUSY BIT(1) +#define PCTL2_RANK0_REFRESH_BUSY (1) +/* PCTL2_SWCTL */ +#define PCTL2_SW_DONE (1) +#define PCTL2_SW_DONE_CLEAR (0) +/* PCTL2_SWSTAT */ +#define PCTL2_SW_DONE_ACK (1) +/* PCTL2_PSTAT */ +#define PCTL2_WR_PORT_BUSY_0 BIT(16) +#define PCTL2_RD_PORT_BUSY_0 (1) +/* PCTL2_PCTRLn */ +#define PCTL2_PORT_EN (1)
void pctl_read_mr(void __iomem *pctl_base, u32 rank, u32 mr_num); int pctl_write_mr(void __iomem *pctl_base, u32 rank, u32 mr_num, u32 arg, diff --git a/drivers/ram/rockchip/sdram_pctl_px30.c b/drivers/ram/rockchip/sdram_pctl_px30.c index 331d85fba2..e5c80fb83b 100644 --- a/drivers/ram/rockchip/sdram_pctl_px30.c +++ b/drivers/ram/rockchip/sdram_pctl_px30.c @@ -21,7 +21,7 @@ void pctl_read_mr(void __iomem *pctl_base, u32 rank, u32 mr_num) setbits_le32(pctl_base + DDR_PCTL2_MRCTRL0, 1u << 31); while (readl(pctl_base + DDR_PCTL2_MRCTRL0) & (1u << 31)) continue; - while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) + while (readl(pctl_base + DDR_PCTL2_MRSTAT) & PCTL2_MR_WR_BUSY) continue; }
@@ -33,7 +33,7 @@ void pctl_read_mr(void __iomem *pctl_base, u32 rank, u32 mr_num) int pctl_write_mr(void __iomem *pctl_base, u32 rank, u32 mr_num, u32 arg, u32 dramtype) { - while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) + while (readl(pctl_base + DDR_PCTL2_MRSTAT) & PCTL2_MR_WR_BUSY) continue; if (dramtype == DDR3 || dramtype == DDR4) { writel((mr_num << 12) | (rank << 4) | (0 << 0), @@ -49,7 +49,7 @@ int pctl_write_mr(void __iomem *pctl_base, u32 rank, u32 mr_num, u32 arg, setbits_le32(pctl_base + DDR_PCTL2_MRCTRL0, 1u << 31); while (readl(pctl_base + DDR_PCTL2_MRCTRL0) & (1u << 31)) continue; - while (readl(pctl_base + DDR_PCTL2_MRSTAT) & MR_WR_BUSY) + while (readl(pctl_base + DDR_PCTL2_MRSTAT) & PCTL2_MR_WR_BUSY) continue;
Thanks, - Kever
Changes for v2:
none
- u32 pctl[30][2];
u32 pctl[35][2]; };
- ((0x1000 * (n) + (((n) > 0) ? 0x1000 : 0)))
- while (readl(pctl_base + DDR_PCTL2_MRSTAT) & PCTL2_MR_WR_BUSY) continue; }
- while (readl(pctl_base + DDR_PCTL2_MRSTAT) & PCTL2_MR_WR_BUSY) continue; if (dramtype == DDR3 || dramtype == DDR4) { writel((mr_num << 12) | (rank << 4) | (0 << 0),
Add DDR3 detection timings for Rockchip RV1126 SoC.
.../sdram-rv1126-ddr3-detect-1056.inc | 72 +++++++++++++++++++ .../rockchip/sdram-rv1126-ddr3-detect-328.inc | 72 +++++++++++++++++++ .../rockchip/sdram-rv1126-ddr3-detect-396.inc | 72 +++++++++++++++++++ .../rockchip/sdram-rv1126-ddr3-detect-528.inc | 72 +++++++++++++++++++ .../rockchip/sdram-rv1126-ddr3-detect-664.inc | 72 +++++++++++++++++++ .../rockchip/sdram-rv1126-ddr3-detect-784.inc | 72 +++++++++++++++++++ .../rockchip/sdram-rv1126-ddr3-detect-924.inc | 72 +++++++++++++++++++ 7 files changed, 504 insertions(+) create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-924.inc
diff --git a/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc new file mode 100644 index 0000000000..4cde21565b --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x0, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0 + }, + { + {0x351b1019}, + {0x12030903}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 1056, /* clock rate(MHz) */ + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x43042001}, /* MSTR */ + {0x00000064, 0x008000b9}, /* RFSHTMG */ + {0x000000d0, 0x00020103}, /* INIT0 */ + {0x000000d4, 0x00690000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x01240040}, /* INIT3 */ + {0x000000e0, 0x00280000}, /* INIT4 */ + {0x000000e4, 0x000c0000}, /* INIT5 */ + {0x000000f4, 0x000f011f}, /* RANKCTL */ + {0x00000100, 0x0f132414}, /* DRAMTMG0 */ + {0x00000104, 0x000d0419}, /* DRAMTMG1 */ + {0x00000108, 0x0507050b}, /* DRAMTMG2 */ + {0x0000010c, 0x00202008}, /* DRAMTMG3 */ + {0x00000110, 0x07020408}, /* DRAMTMG4 */ + {0x00000114, 0x06060404}, /* DRAMTMG5 */ + {0x00000120, 0x00000907}, /* DRAMTMG8 */ + {0x00000180, 0x00a9002b}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07050003}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x06000610}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008a}, /* PHYREG01 */ + {0x00000014, 0x0000000e}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x0000000a}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-328.inc b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-328.inc new file mode 100644 index 0000000000..eef61ab500 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-328.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x0, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0 + }, + { + {0x270a0509}, + {0x08020401}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 328, /* clock rate(MHz) */ + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 0 + }, + { + { + {0x00000000, 0x43042001}, /* MSTR */ + {0x00000064, 0x0027003a}, /* RFSHTMG */ + {0x000000d0, 0x00020052}, /* INIT0 */ + {0x000000d4, 0x00220000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x03100000}, /* INIT3 */ + {0x000000e0, 0x00000000}, /* INIT4 */ + {0x000000e4, 0x00090000}, /* INIT5 */ + {0x000000f4, 0x000f011f}, /* RANKCTL */ + {0x00000100, 0x07090b06}, /* DRAMTMG0 */ + {0x00000104, 0x00050209}, /* DRAMTMG1 */ + {0x00000108, 0x03030307}, /* DRAMTMG2 */ + {0x0000010c, 0x00202006}, /* DRAMTMG3 */ + {0x00000110, 0x03020203}, /* DRAMTMG4 */ + {0x00000114, 0x03030202}, /* DRAMTMG5 */ + {0x00000120, 0x00000903}, /* DRAMTMG8 */ + {0x00000180, 0x00800020}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07010001}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x06000600}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008a}, /* PHYREG01 */ + {0x00000014, 0x00000005}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000005}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-396.inc b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-396.inc new file mode 100644 index 0000000000..39a8271815 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-396.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x0, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0 + }, + { + {0x290b060a}, + {0x0a020401}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 396, /* clock rate(MHz) */ + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 0 + }, + { + { + {0x00000000, 0x43042001}, /* MSTR */ + {0x00000064, 0x00300046}, /* RFSHTMG */ + {0x000000d0, 0x00020062}, /* INIT0 */ + {0x000000d4, 0x00280000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x05200000}, /* INIT3 */ + {0x000000e0, 0x00000000}, /* INIT4 */ + {0x000000e4, 0x00090000}, /* INIT5 */ + {0x000000f4, 0x000f011f}, /* RANKCTL */ + {0x00000100, 0x070a0d07}, /* DRAMTMG0 */ + {0x00000104, 0x0005020b}, /* DRAMTMG1 */ + {0x00000108, 0x03030407}, /* DRAMTMG2 */ + {0x0000010c, 0x00202006}, /* DRAMTMG3 */ + {0x00000110, 0x03020204}, /* DRAMTMG4 */ + {0x00000114, 0x03030202}, /* DRAMTMG5 */ + {0x00000120, 0x00000904}, /* DRAMTMG8 */ + {0x00000180, 0x00800020}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07010001}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x06000604}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008a}, /* PHYREG01 */ + {0x00000014, 0x00000006}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000005}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-528.inc b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-528.inc new file mode 100644 index 0000000000..9dbbb1aa9e --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-528.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x0, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0 + }, + { + {0x2c0f080e}, + {0x0d030502}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 528, /* clock rate(MHz) */ + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 0 + }, + { + { + {0x00000000, 0x43042001}, /* MSTR */ + {0x00000064, 0x0040005d}, /* RFSHTMG */ + {0x000000d0, 0x00020082}, /* INIT0 */ + {0x000000d4, 0x00350000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x09400000}, /* INIT3 */ + {0x000000e0, 0x00080000}, /* INIT4 */ + {0x000000e4, 0x00090000}, /* INIT5 */ + {0x000000f4, 0x000f011f}, /* RANKCTL */ + {0x00000100, 0x090e120a}, /* DRAMTMG0 */ + {0x00000104, 0x0007020e}, /* DRAMTMG1 */ + {0x00000108, 0x03040407}, /* DRAMTMG2 */ + {0x0000010c, 0x00202006}, /* DRAMTMG3 */ + {0x00000110, 0x04020305}, /* DRAMTMG4 */ + {0x00000114, 0x03030302}, /* DRAMTMG5 */ + {0x00000120, 0x00000904}, /* DRAMTMG8 */ + {0x00000180, 0x00800020}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07020001}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x06000608}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008a}, /* PHYREG01 */ + {0x00000014, 0x00000008}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000006}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-664.inc b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-664.inc new file mode 100644 index 0000000000..2b57132794 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-664.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x0, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0 + }, + { + {0x2f120a11}, + {0x0f020602}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 664, /* clock rate(MHz) */ + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x43042001}, /* MSTR */ + {0x00000064, 0x00500075}, /* RFSHTMG */ + {0x000000d0, 0x000200a4}, /* INIT0 */ + {0x000000d4, 0x00420000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x0b600040}, /* INIT3 */ + {0x000000e0, 0x00100000}, /* INIT4 */ + {0x000000e4, 0x00090000}, /* INIT5 */ + {0x000000f4, 0x000f011f}, /* RANKCTL */ + {0x00000100, 0x0a0f160c}, /* DRAMTMG0 */ + {0x00000104, 0x00080211}, /* DRAMTMG1 */ + {0x00000108, 0x04050508}, /* DRAMTMG2 */ + {0x0000010c, 0x00202006}, /* DRAMTMG3 */ + {0x00000110, 0x05020306}, /* DRAMTMG4 */ + {0x00000114, 0x04040302}, /* DRAMTMG5 */ + {0x00000120, 0x00000905}, /* DRAMTMG8 */ + {0x00000180, 0x00800020}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07030002}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0600060c}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008a}, /* PHYREG01 */ + {0x00000014, 0x0000000a}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000007}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-784.inc b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-784.inc new file mode 100644 index 0000000000..8ad22727fc --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-784.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x0, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0 + }, + { + {0x30150c13}, + {0x10030702}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 784, /* clock rate(MHz) */ + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x43042001}, /* MSTR */ + {0x00000064, 0x005f008a}, /* RFSHTMG */ + {0x000000d0, 0x000200c1}, /* INIT0 */ + {0x000000d4, 0x004e0000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x0d700040}, /* INIT3 */ + {0x000000e0, 0x00180000}, /* INIT4 */ + {0x000000e4, 0x00090000}, /* INIT5 */ + {0x000000f4, 0x000f011f}, /* RANKCTL */ + {0x00000100, 0x0c101a0f}, /* DRAMTMG0 */ + {0x00000104, 0x000a0314}, /* DRAMTMG1 */ + {0x00000108, 0x04060509}, /* DRAMTMG2 */ + {0x0000010c, 0x00202006}, /* DRAMTMG3 */ + {0x00000110, 0x06020306}, /* DRAMTMG4 */ + {0x00000114, 0x04040303}, /* DRAMTMG5 */ + {0x00000120, 0x00000906}, /* DRAMTMG8 */ + {0x00000180, 0x00800020}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07040002}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0600060c}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008a}, /* PHYREG01 */ + {0x00000014, 0x0000000b}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000008}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-924.inc b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-924.inc new file mode 100644 index 0000000000..4cc36b05d2 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-ddr3-detect-924.inc @@ -0,0 +1,72 @@ +{ + { + { + .rank = 0x1, + .col = 0xC, + .bk = 0x3, + .bw = 0x0, + .dbw = 0x0, + .row_3_4 = 0x0, + .cs0_row = 0x10, + .cs1_row = 0x10, + .cs0_high16bit_row = 0x10, + .cs1_high16bit_row = 0x10, + .ddrconfig = 0 + }, + { + {0x33180e16}, + {0x10030803}, + {0x00000002}, + {0x00001111}, + {0x0000000c}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 924, /* clock rate(MHz) */ + .dramtype = DDR3, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x43042001}, /* MSTR */ + {0x00000064, 0x007000a2}, /* RFSHTMG */ + {0x000000d0, 0x000200e3}, /* INIT0 */ + {0x000000d4, 0x005c0000}, /* INIT1 */ + {0x000000d8, 0x00000100}, /* INIT2 */ + {0x000000dc, 0x0f140040}, /* INIT3 */ + {0x000000e0, 0x00200000}, /* INIT4 */ + {0x000000e4, 0x000b0000}, /* INIT5 */ + {0x000000f4, 0x000f011f}, /* RANKCTL */ + {0x00000100, 0x0d111f11}, /* DRAMTMG0 */ + {0x00000104, 0x000c0317}, /* DRAMTMG1 */ + {0x00000108, 0x0507050a}, /* DRAMTMG2 */ + {0x0000010c, 0x00202007}, /* DRAMTMG3 */ + {0x00000110, 0x07020307}, /* DRAMTMG4 */ + {0x00000114, 0x05050403}, /* DRAMTMG5 */ + {0x00000120, 0x00000907}, /* DRAMTMG8 */ + {0x00000180, 0x00940025}, /* ZQCTL0 */ + {0x00000184, 0x00000000}, /* ZQCTL1 */ + {0x00000190, 0x07050003}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x06000610}, /* ODTCFG */ + {0x00000244, 0x00000201}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008a}, /* PHYREG01 */ + {0x00000014, 0x0000000d}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000009}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +},
Thanks, - Kever
Changes for v2:
none
.rank = 0x1,
.col = 0xC,
.bk = 0x3,
.bw = 0x0,
.dbw = 0x0,
.row_3_4 = 0x0,
.cs0_row = 0x10,
.cs1_row = 0x10,
.ddrconfig = 0
{0x351b1019},
{0x12030903},
{0x00000002},
{0x00001111},
{0x0000000c},
{0x00000000},
0x000000ff
.dramtype = DDR3,
.num_channels = 1,
.stride = 0,
.odt = 1
.rank = 0x1,
.col = 0xC,
.bk = 0x3,
.bw = 0x0,
.dbw = 0x0,
.row_3_4 = 0x0,
.cs0_row = 0x10,
.cs1_row = 0x10,
.ddrconfig = 0
{0x270a0509},
{0x08020401},
{0x00000002},
{0x00001111},
{0x0000000c},
{0x00000000},
0x000000ff
.dramtype = DDR3,
.num_channels = 1,
.stride = 0,
.odt = 0
.rank = 0x1,
.col = 0xC,
.bk = 0x3,
.bw = 0x0,
.dbw = 0x0,
.row_3_4 = 0x0,
.cs0_row = 0x10,
.cs1_row = 0x10,
.ddrconfig = 0
{0x290b060a},
{0x0a020401},
{0x00000002},
{0x00001111},
{0x0000000c},
{0x00000000},
0x000000ff
.dramtype = DDR3,
.num_channels = 1,
.stride = 0,
.odt = 0
.rank = 0x1,
.col = 0xC,
.bk = 0x3,
.bw = 0x0,
.dbw = 0x0,
.row_3_4 = 0x0,
.cs0_row = 0x10,
.cs1_row = 0x10,
.ddrconfig = 0
{0x2c0f080e},
{0x0d030502},
{0x00000002},
{0x00001111},
{0x0000000c},
{0x00000000},
0x000000ff
.dramtype = DDR3,
.num_channels = 1,
.stride = 0,
.odt = 0
.rank = 0x1,
.col = 0xC,
.bk = 0x3,
.bw = 0x0,
.dbw = 0x0,
.row_3_4 = 0x0,
.cs0_row = 0x10,
.cs1_row = 0x10,
.ddrconfig = 0
{0x2f120a11},
{0x0f020602},
{0x00000002},
{0x00001111},
{0x0000000c},
{0x00000000},
0x000000ff
.dramtype = DDR3,
.num_channels = 1,
.stride = 0,
.odt = 1
.rank = 0x1,
.col = 0xC,
.bk = 0x3,
.bw = 0x0,
.dbw = 0x0,
.row_3_4 = 0x0,
.cs0_row = 0x10,
.cs1_row = 0x10,
.ddrconfig = 0
{0x30150c13},
{0x10030702},
{0x00000002},
{0x00001111},
{0x0000000c},
{0x00000000},
0x000000ff
.dramtype = DDR3,
.num_channels = 1,
.stride = 0,
.odt = 1
.rank = 0x1,
.col = 0xC,
.bk = 0x3,
.bw = 0x0,
.dbw = 0x0,
.row_3_4 = 0x0,
.cs0_row = 0x10,
.cs1_row = 0x10,
.ddrconfig = 0
{0x33180e16},
{0x10030803},
{0x00000002},
{0x00001111},
{0x0000000c},
{0x00000000},
0x000000ff
.dramtype = DDR3,
.num_channels = 1,
.stride = 0,
.odt = 1
Add DDR loader parameters for Rockchip RV1126 SoC.
.../rockchip/sdram-rv1126-loader_params.inc | 198 ++++++++++++++++++ 1 file changed, 198 insertions(+) create mode 100644 drivers/ram/rockchip/sdram-rv1126-loader_params.inc
diff --git a/drivers/ram/rockchip/sdram-rv1126-loader_params.inc b/drivers/ram/rockchip/sdram-rv1126-loader_params.inc new file mode 100644 index 0000000000..4b75f166d3 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-loader_params.inc @@ -0,0 +1,198 @@ +0x12345678, +2,/* version */ +(0 << 0) | (1 << 8) | (9 << 16) | (8 << 24),/* cpu_gen,global index */ +(0 << 0) | (9 << 8) | (17 << 16) | (9 << 24),/* d2,d3 index */ +(26 << 0) | (9 << 8) | (0 << 16) | (0 << 24),/* d4,d5 index */ +(0 << 0) | (9 << 8) | (35 << 16) | (9 << 24),/* lp2,lp3 index */ +(44 << 0) | (13 << 8) | (0 << 16) | (0 << 24),/* lp4,lp5 index */ +(0 << 0) | (0 << 8) | (57 << 16) | (8 << 24),/* skew index, dq_map index */ +(65 << 0) | (13 << 8) | (0 << 16) | (0 << 24), /*lp4x index*/ +/* global info */ +0, +(93 << 16) | 13,/* sr_idle << 16 | pd_idle */ +0,/* channel info */ +1,/* 2t info */ +0, 0, 0, 0,/* reserved */ + +/* ddr3 */ +(924 << DDR_FREQ_F0_SHIFT) | (328 << DDR_FREQ_F1_SHIFT), +(528 << DDR_FREQ_F2_SHIFT) | (784 << DDR_FREQ_F3_SHIFT), +(0 << DDR_FREQ_F4_SHIFT) | (0 << DDR_FREQ_F5_SHIFT), +/* drv when odt on */ +(30 << PHY_DQ_DRV_SHIFT) | (41 << PHY_CA_DRV_SHIFT) | + (38 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT), +/* drv when odt off */ +(30 << PHY_DQ_DRV_SHIFT) | (30 << PHY_CA_DRV_SHIFT) | + (38 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT), +/* odt info */ +(120 << DRAM_ODT_SHIFT) | (141 << PHY_ODT_SHIFT) | + (1 << PHY_ODT_PUUP_EN_SHIFT) | + (0 << PHY_ODT_PUDN_EN_SHIFT), +/* odt enable freq */ +(333 << DRAM_ODT_EN_FREQ_SHIFT) | (333 << PHY_ODT_EN_FREQ_SHIFT), +/* slew rate when odt enable */ +(0x1f << PHY_DQ_SR_SHIFT) | (0x1f << PHY_CA_SR_SHIFT) | + (0x1f << PHY_CLK_SR_SHIFT), +/* slew ratee when odt disable */ +(0x1f << PHY_DQ_SR_SHIFT) | (0x1f << PHY_CA_SR_SHIFT) | + (0x1f << PHY_CLK_SR_SHIFT), + +/* ddr4 */ +(924 << DDR_FREQ_F0_SHIFT) | (328 << DDR_FREQ_F1_SHIFT), +(528 << DDR_FREQ_F2_SHIFT) | (784 << DDR_FREQ_F3_SHIFT), +(0 << DDR_FREQ_F4_SHIFT) | (0 << DDR_FREQ_F5_SHIFT), +/* drv when odt on */ +(37 << PHY_DQ_DRV_SHIFT) | (44 << PHY_CA_DRV_SHIFT) | + (37 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT), +/* drv when odt off */ +(37 << PHY_DQ_DRV_SHIFT) | (44 << PHY_CA_DRV_SHIFT) | + (37 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT), +/* odt info */ +(120 << DRAM_ODT_SHIFT) | (148 << PHY_ODT_SHIFT) | + (1 << PHY_ODT_PUUP_EN_SHIFT) | (1 << PHY_ODT_PUDN_EN_SHIFT), +/* odt enable freq */ +(625 << DRAM_ODT_EN_FREQ_SHIFT) | (625 << PHY_ODT_EN_FREQ_SHIFT), +/* slew rate when odt enable */ +(0xe << PHY_DQ_SR_SHIFT) | (0x3 << PHY_CA_SR_SHIFT) | + (0x3 << PHY_CLK_SR_SHIFT), +/* slew ratee when odt disable */ +(0xe << PHY_DQ_SR_SHIFT) | (0x3 << PHY_CA_SR_SHIFT) | + (0x3 << PHY_CLK_SR_SHIFT), + +/* lpddr3 */ +(924 << DDR_FREQ_F0_SHIFT) | (328 << DDR_FREQ_F1_SHIFT), +(528 << DDR_FREQ_F2_SHIFT) | (784 << DDR_FREQ_F3_SHIFT), +(0 << DDR_FREQ_F4_SHIFT) | (0 << DDR_FREQ_F5_SHIFT), +/* drv when odt on */ +(28 << PHY_DQ_DRV_SHIFT) | (37 << PHY_CA_DRV_SHIFT) | + (34 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT), +/* drv when odt off */ +(28 << PHY_DQ_DRV_SHIFT) | (37 << PHY_CA_DRV_SHIFT) | + (34 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT), +/* odt info */ +(120 << DRAM_ODT_SHIFT) | (148 << PHY_ODT_SHIFT) | + (1 << PHY_ODT_PUUP_EN_SHIFT) | (1 << PHY_ODT_PUDN_EN_SHIFT), +/* odt enable freq */ +(333 << DRAM_ODT_EN_FREQ_SHIFT) | (333 << PHY_ODT_EN_FREQ_SHIFT), + +/* slew rate when odt enable */ +(0xe << PHY_DQ_SR_SHIFT) | (0x0 << PHY_CA_SR_SHIFT) | + (0x0 << PHY_CLK_SR_SHIFT), +/* slew ratee when odt disable */ +(0xe << PHY_DQ_SR_SHIFT) | (0x0 << PHY_CA_SR_SHIFT) | + (0x0 << PHY_CLK_SR_SHIFT), + +/* lpddr4 */ +(924 << DDR_FREQ_F0_SHIFT) | (328 << DDR_FREQ_F1_SHIFT), +(528 << DDR_FREQ_F2_SHIFT) | (784 << DDR_FREQ_F3_SHIFT), +(0 << DDR_FREQ_F4_SHIFT) | (0 << DDR_FREQ_F5_SHIFT), + +/* drv when odt on */ +(38 << PHY_DQ_DRV_SHIFT) | (46 << PHY_CA_DRV_SHIFT) | + (38 << PHY_CLK_DRV_SHIFT) | (40 << DRAM_DQ_DRV_SHIFT), +/* drv when odt off */ +(38 << PHY_DQ_DRV_SHIFT) | (46 << PHY_CA_DRV_SHIFT) | + (38 << PHY_CLK_DRV_SHIFT) | (40 << DRAM_DQ_DRV_SHIFT), +/* odt info and PU-cal info */ +(240 << DRAM_ODT_SHIFT) | (80 << PHY_ODT_SHIFT) | + (0 << LP4_CA_ODT_SHIFT) | + (LPDDR4_VDDQ_2_5 << LP4_DRV_PU_CAL_ODTEN_SHIFT) | + (LPDDR4_VDDQ_2_5 << LP4_DRV_PU_CAL_ODTOFF_SHIFT) | + (0 << PHY_LP4_DRV_PULLDOWN_EN_ODTEN_SHIFT) | + (0 << PHY_LP4_DRV_PULLDOWN_EN_ODTOFF_SHIFT), +/* odt enable freq */ +(333 << PHY_LP4_ODT_EN_FREQ_SHIFT) | (333 << LP4_DQ_ODT_EN_FREQ_SHIFT), +/* slew rate when odt enable */ +(0xf << PHY_DQ_SR_SHIFT) | (0xf << PHY_CA_SR_SHIFT) | + (0xf << PHY_CLK_SR_SHIFT), +/* slew ratee when odt disable */ +(0xf << PHY_DQ_SR_SHIFT) | (0xf << PHY_CA_SR_SHIFT) | + (0xf << PHY_CLK_SR_SHIFT), +/* ca odt en freq */ +(333 << LP4_CA_ODT_EN_FREQ_SHIFT), +/* cs drv info and ca odt info */ +(0 << PHY_LP4_CS_DRV_ODTEN_SHIFT) | + (0 << PHY_LP4_CS_DRV_ODTOFF_SHIFT) | + (0 << LP4_ODTE_CK_SHIFT) | (0 << LP4_ODTE_CS_EN_SHIFT) | + (0 << LP4_ODTD_CA_EN_SHIFT), +/* vref info when odt enable */ +(200 << PHY_LP4_DQ_VREF_SHIFT) | (420 << LP4_DQ_VREF_SHIFT) | + (420 << LP4_CA_VREF_SHIFT), +/* vref info when odt disable */ +(420 << PHY_LP4_DQ_VREF_SHIFT) | (420 << LP4_DQ_VREF_SHIFT) | + (420 << LP4_CA_VREF_SHIFT), +/* ddr4 map << 0 | ddr3 map << 24 */ +((0x2 << 6) | (0x1 << 4) | (0x3 << 2) | (0x0 << 0)) | + (0 << 8) | (0 << 16) | + (((0x2 << 6) | (0x1 << 4) | (0x3 << 2) | (0x0 << 0)) << 24), +/* lp3 map << 16 | lp4 map << 24 */ +/* lp4 should equal to 0xc9 */ +(((0x3 << 6) | (0x2 << 4) | (0x1 << 2) | (0x0 << 0)) << 16) | + (((0x3 << 6) | (0x0 << 4) | (0x2 << 2) | (0x1 << 0)) << 24), +/* lp3 dq0-7 map */ +(2 << 0) | (6 << 4) | (4 << 8) | (0 << 12) | (3 << 16) | (7 << 20) | + ( 5 << 24) | (1 << 28), +/* lp2 dq0-7 map */ +0, +/* ddr4 dq map */ +/* cs0 dq0-15 */ + ((2 << 0 | 0 << 2 | 3 << 4 | 1 << 6) << 0) | + ((0 << 0 | 2 << 2 | 3 << 4 | 1 << 6) << 8) | + ((2 << 0 | 2 << 2 | 1 << 4 | 3 << 6) << 16) | + ((1 << 0 | 3 << 2 | 0 << 4 | 0 << 6) << 24), +/* cs0 dq16-31 */ + ((2 << 0 | 0 << 2 | 2 << 4 | 0 << 6) << 0) | + ((1 << 0 | 3 << 2 | 3 << 4 | 1 << 6) << 8) | + ((0 << 0 | 0 << 2 | 1 << 4 | 3 << 6) << 16) | + ((1 << 0 | 3 << 2 | 2 << 4 | 2 << 6) << 24), +/* cs1 dq0-15 */ + ((2 << 0 | 0 << 2 | 3 << 4 | 1 << 6) << 0) | + ((0 << 0 | 2 << 2 | 3 << 4 | 1 << 6) << 8) | + ((2 << 0 | 2 << 2 | 1 << 4 | 3 << 6) << 16) | + ((1 << 0 | 3 << 2 | 0 << 4 | 0 << 6) << 24), +/* cs1 dq16-31 */ + ((2 << 0 | 0 << 2 | 2 << 4 | 0 << 6) << 0) | + ((1 << 0 | 3 << 2 | 3 << 4 | 1 << 6) << 8) | + ((0 << 0 | 0 << 2 | 1 << 4 | 3 << 6) << 16) | + ((1 << 0 | 3 << 2 | 2 << 4 | 2 << 6) << 24), + +/* lpddr4x */ +(1056 << DDR_FREQ_F0_SHIFT) | (328 << DDR_FREQ_F1_SHIFT), +(528 << DDR_FREQ_F2_SHIFT) | (784 << DDR_FREQ_F3_SHIFT), +(0 << DDR_FREQ_F4_SHIFT) | (0 << DDR_FREQ_F5_SHIFT), + +/* drv when odt on */ +(38 << PHY_DQ_DRV_SHIFT) | (38 << PHY_CA_DRV_SHIFT) | + (38 << PHY_CLK_DRV_SHIFT) | (40 << DRAM_DQ_DRV_SHIFT), +/* drv when odt off */ +(38 << PHY_DQ_DRV_SHIFT) | (38 << PHY_CA_DRV_SHIFT) | + (38 << PHY_CLK_DRV_SHIFT) | (40 << DRAM_DQ_DRV_SHIFT), +/* odt info and PU-cal info */ +(48 << DRAM_ODT_SHIFT) | (60 << PHY_ODT_SHIFT) | + (120 << LP4_CA_ODT_SHIFT) | + (LPDDR4X_VDDQ_0_6 << LP4_DRV_PU_CAL_ODTEN_SHIFT) | + (LPDDR4X_VDDQ_0_6 << LP4_DRV_PU_CAL_ODTOFF_SHIFT) | + (0 << PHY_LP4_DRV_PULLDOWN_EN_ODTEN_SHIFT) | + (0 << PHY_LP4_DRV_PULLDOWN_EN_ODTOFF_SHIFT), +/* odt enable freq */ +(0 << PHY_LP4_ODT_EN_FREQ_SHIFT) | (0 << LP4_DQ_ODT_EN_FREQ_SHIFT), +/* slew rate when odt enable */ +(0xf << PHY_DQ_SR_SHIFT) | (0xf << PHY_CA_SR_SHIFT) | + (0xf << PHY_CLK_SR_SHIFT), +/* slew ratee when odt disable */ +(0xf << PHY_DQ_SR_SHIFT) | (0xf << PHY_CA_SR_SHIFT) | + (0xf << PHY_CLK_SR_SHIFT), +/* ca odt en freq */ +(333 << LP4_CA_ODT_EN_FREQ_SHIFT), +/* cs drv info and ca odt info */ +(0 << PHY_LP4_CS_DRV_ODTEN_SHIFT) | + (0 << PHY_LP4_CS_DRV_ODTOFF_SHIFT) | + (0 << LP4_ODTE_CK_SHIFT) | (0 << LP4_ODTE_CS_EN_SHIFT) | + (0 << LP4_ODTD_CA_EN_SHIFT), +/* vref info when odt enable, phy vddq=1.1V, lp4x vddq=0.6V */ +(153 << PHY_LP4_DQ_VREF_SHIFT) | (515 << LP4_DQ_VREF_SHIFT) | + (629 << LP4_CA_VREF_SHIFT), +/* vref info when odt disable */ +(153 << PHY_LP4_DQ_VREF_SHIFT) | (629 << LP4_DQ_VREF_SHIFT) | + (629 << LP4_CA_VREF_SHIFT), +
Thanks, - Kever
Changes for v2:
none
- (38 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT),
- (1 << PHY_ODT_PUUP_EN_SHIFT) |
- (0 << PHY_ODT_PUDN_EN_SHIFT),
- (0x1f << PHY_CLK_SR_SHIFT),
- (37 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT),
- (1 << PHY_ODT_PUUP_EN_SHIFT) | (1 << PHY_ODT_PUDN_EN_SHIFT),
- (0x3 << PHY_CLK_SR_SHIFT),
- (34 << PHY_CLK_DRV_SHIFT) | (34 << DRAM_DQ_DRV_SHIFT),
- (0x0 << PHY_CLK_SR_SHIFT),
- (38 << PHY_CLK_DRV_SHIFT) | (40 << DRAM_DQ_DRV_SHIFT),
- (0 << LP4_CA_ODT_SHIFT) |
- (LPDDR4_VDDQ_2_5 << LP4_DRV_PU_CAL_ODTEN_SHIFT) |
- (LPDDR4_VDDQ_2_5 << LP4_DRV_PU_CAL_ODTOFF_SHIFT) |
- (0 << PHY_LP4_DRV_PULLDOWN_EN_ODTEN_SHIFT) |
- (0 << PHY_LP4_DRV_PULLDOWN_EN_ODTOFF_SHIFT),
- (0xf << PHY_CLK_SR_SHIFT),
- (0 << PHY_LP4_CS_DRV_ODTOFF_SHIFT) |
- (0 << LP4_ODTE_CK_SHIFT) | (0 << LP4_ODTE_CS_EN_SHIFT) |
- (0 << LP4_ODTD_CA_EN_SHIFT),
- (420 << LP4_CA_VREF_SHIFT),
- (0 << 8) | (0 << 16) |
- (((0x2 << 6) | (0x1 << 4) | (0x3 << 2) | (0x0 << 0)) << 24),
- (((0x3 << 6) | (0x0 << 4) | (0x2 << 2) | (0x1 << 0)) << 24),
- ( 5 << 24) | (1 << 28),
- ((2 << 0 | 0 << 2 | 3 << 4 | 1 << 6) << 0) |
- ((0 << 0 | 2 << 2 | 3 << 4 | 1 << 6) << 8) |
- ((2 << 0 | 2 << 2 | 1 << 4 | 3 << 6) << 16) |
- ((1 << 0 | 3 << 2 | 0 << 4 | 0 << 6) << 24),
+/* cs0 dq16-31 */
- ((2 << 0 | 0 << 2 | 2 << 4 | 0 << 6) << 0) |
- ((1 << 0 | 3 << 2 | 3 << 4 | 1 << 6) << 8) |
- ((0 << 0 | 0 << 2 | 1 << 4 | 3 << 6) << 16) |
- ((1 << 0 | 3 << 2 | 2 << 4 | 2 << 6) << 24),
+/* cs1 dq0-15 */
+/* cs1 dq16-31 */
- (120 << LP4_CA_ODT_SHIFT) |
- (LPDDR4X_VDDQ_0_6 << LP4_DRV_PU_CAL_ODTEN_SHIFT) |
- (LPDDR4X_VDDQ_0_6 << LP4_DRV_PU_CAL_ODTOFF_SHIFT) |
- (629 << LP4_CA_VREF_SHIFT),
Add DDR driver for Rockchip RV1126 SoC.
.../asm/arch-rockchip/dram_spec_timing.h | 452 +++ .../include/asm/arch-rockchip/sdram_common.h | 212 + .../include/asm/arch-rockchip/sdram_msch.h | 12 + .../asm/arch-rockchip/sdram_phy_rv1126.h | 93 + .../include/asm/arch-rockchip/sdram_rv1126.h | 420 ++ drivers/ram/rockchip/Makefile | 1 + drivers/ram/rockchip/sdram_rv1126.c | 3521 +++++++++++++++++ 7 files changed, 4711 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/dram_spec_timing.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rv1126.h create mode 100644 drivers/ram/rockchip/sdram_rv1126.c
diff --git a/arch/arm/include/asm/arch-rockchip/dram_spec_timing.h b/arch/arm/include/asm/arch-rockchip/dram_spec_timing.h new file mode 100644 index 0000000000..a691e97a8b --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/dram_spec_timing.h @@ -0,0 +1,452 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Rockchip Electronics Co., Ltd + */ + +#ifndef __ROCKCHIP_DRAM_SPEC_TIMING_H__ +#define __ROCKCHIP_DRAM_SPEC_TIMING_H__ + +enum ddr3_speed_rate { + /* 5-5-5 */ + DDR3_800D = 0, + /* 6-6-6 */ + DDR3_800E = 1, + /* 6-6-6 */ + DDR3_1066E = 2, + /* 7-7-7 */ + DDR3_1066F = 3, + /* 8-8-8 */ + DDR3_1066G = 4, + /* 7-7-7 */ + DDR3_1333F = 5, + /* 8-8-8 */ + DDR3_1333G = 6, + /* 9-9-9 */ + DDR3_1333H = 7, + /* 10-10-10 */ + DDR3_1333J = 8, + /* 8-8-8 */ + DDR3_1600G = 9, + /* 9-9-9 */ + DDR3_1600H = 10, + /* 10-10-10 */ + DDR3_1600J = 11, + /* 11-11-11 */ + DDR3_1600K = 12, + /* 10-10-10 */ + DDR3_1866J = 13, + /* 11-11-11 */ + DDR3_1866K = 14, + /* 12-12-12 */ + DDR3_1866L = 15, + /* 13-13-13 */ + DDR3_1866M = 16, + /* 11-11-11 */ + DDR3_2133K = 17, + /* 12-12-12 */ + DDR3_2133L = 18, + /* 13-13-13 */ + DDR3_2133M = 19, + /* 14-14-14 */ + DDR3_2133N = 20, + DDR3_DEFAULT = 21, +}; + +enum ddr4_speed_rate { + /* DDR4_1600J (10-10-10) */ + DDR4_1600J = 0, + /* DDR4_1600K (11-11-11) */ + DDR4_1600K = 1, + /* DDR4_1600L (12-12-12) */ + DDR4_1600L = 2, + /* DDR4_1800L (12-12-12) */ + DDR4_1866L = 3, + /* DDR4_1800M (13-13-13) */ + DDR4_1866M = 4, + /* DDR4_1800N (14-14-14) */ + DDR4_1866N = 5, + /* DDR4_2133N (14-14-14) */ + DDR4_2133N = 6, + /* DDR4_2133P (15-15-15) */ + DDR4_2133P = 7, + /* DDR4_2133R (16-16-16) */ + DDR4_2133R = 8, + /* DDR4_2400P (15-15-15) */ + DDR4_2400P = 9, + /* DDR4_2400R (16-16-16) */ + DDR4_2400R = 10, + /* DDR4_2400U (18-18-18) */ + DDR4_2400U = 11, + /* DEFAULT */ + DDR4_DEFAULT = 12, +}; + +/* mr0 for ddr3 */ +#define DDR3_BL8 (0) +#define DDR3_BC4_8 (1) +#define DDR3_BC4 (2) +#define DDR3_CL(n) (((((n) - 4) & 0x7) << 4)\ + | ((((n) - 4) & 0x8) >> 1)) +#define DDR3_WR(n) (((n) & 0x7) << 9) +#define DDR3_DLL_RESET (1 << 8) +#define DDR3_DLL_DERESET (0 << 8) + +/* mr1 for ddr3 */ +#define DDR3_DLL_ENABLE (0) +#define DDR3_DLL_DISABLE (1) +#define DDR3_MR1_AL(n) (((n) & 0x3) << 3) + +#define DDR3_DS_40 (0) +#define DDR3_DS_34 BIT(1) +#define DDR3_DS_MASK ((1 << 1) | (1 << 5)) +#define DDR3_RTT_NOM_MASK ((1 << 2) | (1 << 6) | (1 << 9)) +#define DDR3_RTT_NOM_DIS (0) +#define DDR3_RTT_NOM_60 BIT(2) +#define DDR3_RTT_NOM_120 BIT(6) +#define DDR3_RTT_NOM_40 ((1 << 2) | (1 << 6)) +#define DDR3_TDQS BIT(11) + +/* mr2 for ddr3 */ +#define DDR3_MR2_CWL(n) ((((n) - 5) & 0x7) << 3) +#define DDR3_RTT_WR_DIS (0) +#define DDR3_RTT_WR_60 (1 << 9) +#define DDR3_RTT_WR_120 (2 << 9) + +/* + * MR0 (Device Information) + * 0:DAI complete, 1:DAI still in progress + */ +#define LPDDR2_DAI (0x1) +/* 0:S2 or S4 SDRAM, 1:NVM */ +#define LPDDR2_DI (0x1 << 1) +/* 0:DNV not supported, 1:DNV supported */ +#define LPDDR2_DNVI (0x1 << 2) +#define LPDDR2_RZQI (0x3 << 3) + +/* + * 00:RZQ self test not supported, + * 01:ZQ-pin may connect to VDDCA or float + * 10:ZQ-pin may short to GND. + * 11:ZQ-pin self test completed, no error condition detected. + */ + +/* MR1 (Device Feature) */ +#define LPDDR2_BL4 (0x2) +#define LPDDR2_BL8 (0x3) +#define LPDDR2_BL16 (0x4) +#define LPDDR2_N_WR(n) (((n) - 2) << 5) + +/* MR2 (Device Feature 2) */ +#define LPDDR2_RL3_WL1 (0x1) +#define LPDDR2_RL4_WL2 (0x2) +#define LPDDR2_RL5_WL2 (0x3) +#define LPDDR2_RL6_WL3 (0x4) +#define LPDDR2_RL7_WL4 (0x5) +#define LPDDR2_RL8_WL4 (0x6) + +/* MR3 (IO Configuration 1) */ +#define LPDDR2_DS_34 (0x1) +#define LPDDR2_DS_40 (0x2) +#define LPDDR2_DS_48 (0x3) +#define LPDDR2_DS_60 (0x4) +#define LPDDR2_DS_80 (0x6) +/* optional */ +#define LPDDR2_DS_120 (0x7) + +/* MR4 (Device Temperature) */ +#define LPDDR2_TREF_MASK (0x7) +#define LPDDR2_4_TREF (0x1) +#define LPDDR2_2_TREF (0x2) +#define LPDDR2_1_TREF (0x3) +#define LPDDR2_025_TREF (0x5) +#define LPDDR2_025_TREF_DERATE (0x6) + +#define LPDDR2_TUF (0x1 << 7) + +/* MR8 (Basic configuration 4) */ +#define LPDDR2_S4 (0x0) +#define LPDDR2_S2 (0x1) +#define LPDDR2_N (0x2) +/* Unit:MB */ +#define LPDDR2_DENSITY(mr8) (8 << (((mr8) >> 2) & 0xf)) +#define LPDDR2_IO_WIDTH(mr8) (32 >> (((mr8) >> 6) & 0x3)) + +/* MR10 (Calibration) */ +#define LPDDR2_ZQINIT (0xff) +#define LPDDR2_ZQCL (0xab) +#define LPDDR2_ZQCS (0x56) +#define LPDDR2_ZQRESET (0xc3) + +/* MR16 (PASR Bank Mask), S2 SDRAM Only */ +#define LPDDR2_PASR_FULL (0x0) +#define LPDDR2_PASR_1_2 (0x1) +#define LPDDR2_PASR_1_4 (0x2) +#define LPDDR2_PASR_1_8 (0x3) + +/* + * MR0 (Device Information) + * 0:DAI complete, + * 1:DAI still in progress + */ +#define LPDDR3_DAI (0x1) +/* + * 00:RZQ self test not supported, + * 01:ZQ-pin may connect to VDDCA or float + * 10:ZQ-pin may short to GND. + * 11:ZQ-pin self test completed, no error condition detected. + */ +#define LPDDR3_RZQI (0x3 << 3) +/* + * 0:DRAM does not support WL(Set B), + * 1:DRAM support WL(Set B) + */ +#define LPDDR3_WL_SUPOT BIT(6) +/* + * 0:DRAM does not support RL=3,nWR=3,WL=1; + * 1:DRAM supports RL=3,nWR=3,WL=1 for frequencies <=166 + */ +#define LPDDR3_RL3_SUPOT BIT(7) + +/* MR1 (Device Feature) */ +#define LPDDR3_BL8 (0x3) +#define LPDDR3_N_WR(n) ((n) << 5) + +/* MR2 (Device Feature 2), WL Set A,default */ +/* <=166MHz,optional*/ +#define LPDDR3_RL3_WL1 (0x1) +/* <=400MHz*/ +#define LPDDR3_RL6_WL3 (0x4) +/* <=533MHz*/ +#define LPDDR3_RL8_WL4 (0x6) +/* <=600MHz*/ +#define LPDDR3_RL9_WL5 (0x7) +/* <=667MHz,default*/ +#define LPDDR3_RL10_WL6 (0x8) +/* <=733MHz*/ +#define LPDDR3_RL11_WL6 (0x9) +/* <=800MHz*/ +#define LPDDR3_RL12_WL6 (0xa) +/* <=933MHz*/ +#define LPDDR3_RL14_WL8 (0xc) +/* <=1066MHz*/ +#define LPDDR3_RL16_WL8 (0xe) + +/* WL Set B, optional */ +/* <=667MHz,default*/ +#define LPDDR3_RL10_WL8 (0x8) +/* <=733MHz*/ +#define LPDDR3_RL11_WL9 (0x9) +/* <=800MHz*/ +#define LPDDR3_RL12_WL9 (0xa) +/* <=933MHz*/ +#define LPDDR3_RL14_WL11 (0xc) +/* <=1066MHz*/ +#define LPDDR3_RL16_WL13 (0xe) + +/* 1:enable nWR programming > 9(default)*/ +#define LPDDR3_N_WRE BIT(4) +/* 1:Select WL Set B*/ +#define LPDDR3_WL_S BIT(6) +/* 1:enable*/ +#define LPDDR3_WR_LEVEL BIT(7) + +/* MR3 (IO Configuration 1) */ +#define LPDDR3_DS_34 (0x1) +#define LPDDR3_DS_40 (0x2) +#define LPDDR3_DS_48 (0x3) +#define LPDDR3_DS_60 (0x4) +#define LPDDR3_DS_80 (0x6) +#define LPDDR3_DS_34D_40U (0x9) +#define LPDDR3_DS_40D_48U (0xa) +#define LPDDR3_DS_34D_48U (0xb) + +/* MR4 (Device Temperature) */ +#define LPDDR3_TREF_MASK (0x7) +/* SDRAM Low temperature operating limit exceeded */ +#define LPDDR3_LT_EXED (0x0) +#define LPDDR3_4_TREF (0x1) +#define LPDDR3_2_TREF (0x2) +#define LPDDR3_1_TREF (0x3) +#define LPDDR3_05_TREF (0x4) +#define LPDDR3_025_TREF (0x5) +#define LPDDR3_025_TREF_DERATE (0x6) +/* SDRAM High temperature operating limit exceeded */ +#define LPDDR3_HT_EXED (0x7) + +/* 1:value has changed since last read of MR4 */ +#define LPDDR3_TUF (0x1 << 7) + +/* MR8 (Basic configuration 4) */ +#define LPDDR3_S8 (0x3) +#define LPDDR3_DENSITY(mr8) (8 << (((mr8) >> 2) & 0xf)) +#define LPDDR3_IO_WIDTH(mr8) (32 >> (((mr8) >> 6) & 0x3)) + +/* MR10 (Calibration) */ +#define LPDDR3_ZQINIT (0xff) +#define LPDDR3_ZQCL (0xab) +#define LPDDR3_ZQCS (0x56) +#define LPDDR3_ZQRESET (0xc3) + +/* MR11 (ODT Control) */ +#define LPDDR3_ODT_60 (1) +#define LPDDR3_ODT_120 (2) +#define LPDDR3_ODT_240 (3) +#define LPDDR3_ODT_DIS (0) + +/* MR2 (Device Feature 2) */ +/* RL & nRTP for DBI-RD Disabled */ +#define LPDDR4_RL6_NRTP8 (0x0) +#define LPDDR4_RL10_NRTP8 (0x1) +#define LPDDR4_RL14_NRTP8 (0x2) +#define LPDDR4_RL20_NRTP8 (0x3) +#define LPDDR4_RL24_NRTP10 (0x4) +#define LPDDR4_RL28_NRTP12 (0x5) +#define LPDDR4_RL32_NRTP14 (0x6) +#define LPDDR4_RL36_NRTP16 (0x7) +/* RL & nRTP for DBI-RD Disabled */ +#define LPDDR4_RL12_NRTP8 (0x1) +#define LPDDR4_RL16_NRTP8 (0x2) +#define LPDDR4_RL22_NRTP8 (0x3) +#define LPDDR4_RL28_NRTP10 (0x4) +#define LPDDR4_RL32_NRTP12 (0x5) +#define LPDDR4_RL36_NRTP14 (0x6) +#define LPDDR4_RL40_NRTP16 (0x7) +/* WL Set A,default */ +#define LPDDR4_A_WL4 (0x0 << 3) +#define LPDDR4_A_WL6 (0x1 << 3) +#define LPDDR4_A_WL8 (0x2 << 3) +#define LPDDR4_A_WL10 (0x3 << 3) +#define LPDDR4_A_WL12 (0x4 << 3) +#define LPDDR4_A_WL14 (0x5 << 3) +#define LPDDR4_A_WL16 (0x6 << 3) +#define LPDDR4_A_WL18 (0x7 << 3) +/* WL Set B, optional */ +#define LPDDR4_B_WL4 (0x0 << 3) +#define LPDDR4_B_WL8 (0x1 << 3) +#define LPDDR4_B_WL12 (0x2 << 3) +#define LPDDR4_B_WL18 (0x3 << 3) +#define LPDDR4_B_WL22 (0x4 << 3) +#define LPDDR4_B_WL26 (0x5 << 3) +#define LPDDR4_B_WL30 (0x6 << 3) +#define LPDDR4_B_WL34 (0x7 << 3) +/* 1:Select WL Set B*/ +#define LPDDR4_WL_B BIT(6) +/* 1:enable*/ +#define LPDDR4_WR_LEVEL BIT(7) + +/* MR3 */ +#define LPDDR4_VDDQ_2_5 (0) +#define LPDDR4_VDDQ_3 (1) +#define LPDDR4_PU_CAL_MASK (1) +#define LPDDR4_WRPST_0_5_TCK (0 << 1) +#define LPDDR4_WRPST_1_5_TCK (1 << 1) +#define LPDDR4_PPR_EN (1 << 2) +/* PDDS */ +#define LPDDR4_PDDS_MASK (0x7 << 3) +#define LPDDR4_PDDS_SHIFT (3) +#define LPDDR4_PDDS_240 (0x1 << 3) +#define LPDDR4_PDDS_120 (0x2 << 3) +#define LPDDR4_PDDS_80 (0x3 << 3) +#define LPDDR4_PDDS_60 (0x4 << 3) +#define LPDDR4_PDDS_48 (0x5 << 3) +#define LPDDR4_PDDS_40 (0x6 << 3) +#define LPDDR4_DBI_RD_EN BIT(6) +#define LPDDR4_DBI_WR_EN BIT(7) + +/* MR11 (ODT Control) */ +#define LPDDR4_DQODT_MASK (0x7) +#define LPDDR4_DQODT_SHIFT (0x0) +#define LPDDR4_DQODT_240 (1) +#define LPDDR4_DQODT_120 (2) +#define LPDDR4_DQODT_80 (3) +#define LPDDR4_DQODT_60 (4) +#define LPDDR4_DQODT_48 (5) +#define LPDDR4_DQODT_40 (6) +#define LPDDR4_DQODT_DIS (0) +#define LPDDR4_CAODT_MASK (0x7 << 4) +#define LPDDR4_CAODT_SHIFT (4) +#define LPDDR4_CAODT_240 (1 << 4) +#define LPDDR4_CAODT_120 (2 << 4) +#define LPDDR4_CAODT_80 (3 << 4) +#define LPDDR4_CAODT_60 (4 << 4) +#define LPDDR4_CAODT_48 (5 << 4) +#define LPDDR4_CAODT_40 (6 << 4) +#define LPDDR4_CAODT_DIS (0 << 4) + +/* MR22 */ +#define LPDDR4_ODTE_CK_SHIFT (3) +#define LPDDR4_ODTE_CS_SHIFT (4) +#define LPDDR4_ODTD_CA_SHIFT (5) +#define LPDDR4_SOC_ODT_MASK (0x7) +#define LPDDR4_SOC_ODT_SHIFT (0) +#define LPDDR4_SOC_ODT_240 (1) +#define LPDDR4_SOC_ODT_120 (2) +#define LPDDR4_SOC_ODT_80 (3) +#define LPDDR4_SOC_ODT_60 (4) +#define LPDDR4_SOC_ODT_48 (5) +#define LPDDR4_SOC_ODT_40 (6) +#define LPDDR4_SOC_ODT_DIS (0) + +/* LPDDR4x */ +/* MR3 */ +#define LPDDR4X_VDDQ_0_6 (0) +#define LPDDR4X_VDDQ_0_5 (1) + +/* mr0 for ddr4 */ +#define DDR4_BL8 (0) +#define DDR4_BC4_8 (1) +#define DDR4_BC4 (2) +#define DDR4_WR_RTP(n) ((n) << 9) +#define DDR4_CL(n) ((((n) & 0xe) << 3) | ((n) & 1) << 2) +#define DDR4_DLL_RESET(n) ((n) << 8) +#define DDR4_DLL_ON BIT(0) +#define DDR4_DLL_OFF (0 << 0) + +/* mr1 for ddr4 */ +#define DDR4_AL ((n) << 3) +#define DDR4_DS_34 (0) +#define DDR4_DS_48 BIT(1) +#define DDR4_DS_MASK (0x3 << 1) +#define DDR4_RTT_NOM_MASK (0x7 << 8) +#define DDR4_RTT_NOM_DIS (0) +#define DDR4_RTT_NOM_60 BIT(8) +#define DDR4_RTT_NOM_120 (2 << 8) +#define DDR4_RTT_NOM_40 (0x3 << 8) +#define DDR4_RTT_NOM_240 (0x4 << 8) +#define DDR4_RTT_NOM_48 (0x5 << 8) +#define DDR4_RTT_NOM_80 (0x6 << 8) +#define DDR4_RTT_NOM_34 (0x7 << 8) + +/* mr2 for ddr4 */ +#define DDR4_MR2_CWL(n) ((n) << 3) +#define DDR4_RTT_WR_DIS (0) +#define DDR4_RTT_WR_120 BIT(9) +#define DDR4_RTT_WR_240 (2 << 9) + +/* mr4 for ddr4 */ +#define DDR4_READ_PREAMBLE(n) ((n) << 11) +#define DDR4_WRITE_PREAMBLE(n) ((n) << 12) +#define DDR4_READ_PREAMBLE_TRAIN(n) ((n) << 10) + +/* mr5 for ddr4 */ +#define DDR4_RD_DBI(n) ((n) << 12) +#define DDR4_WR_DBI(n) ((n) << 11) +#define DDR4_DM(n) ((n) << 10) +#define DDR4_RTT_PARK_DIS (0 << 6) +#define DDR4_RTT_PARK_60 (1 << 6) +#define DDR4_RTT_PARK_120 (2 << 6) +#define DDR4_RTT_PARK_40 (3 << 6) +#define DDR4_RTT_PARK_240 (4 << 6) +#define DDR4_RTT_PARK_48 (5 << 6) +#define DDR4_RTT_PARK_80 (6 << 6) +#define DDR4_RTT_PARK_34 (7 << 6) +#define DIS_ODT_PD (1 << 5) +#define EN_ODT_PD (0 << 5) + +/* mr6 for ddr4 */ +#define DDR4_TCCD_L(n) (((n) - 4) << 10) + +#define PS_2_CLK(freq, ps) (((uint64_t)(ps) / 100 * (uint64_t)(freq) +\ + 9999) / 10000) + +#endif /* __ROCKCHIP_DRAM_SPEC_TIMING_H__ */ diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index dd316f771a..8eb221276a 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -15,6 +15,210 @@ #define MIN(a, b) (((a) > (b)) ? (b) : (a)) #define MAX(a, b) (((a) > (b)) ? (a) : (b))
+/* get head info for initial */ +#define DDR_FREQ_F0_SHIFT (0) +#define DDR_FREQ_F1_SHIFT (12) +#define DDR_FREQ_F2_SHIFT (0) +#define DDR_FREQ_F3_SHIFT (12) +#define DDR_FREQ_F4_SHIFT (0) +#define DDR_FREQ_F5_SHIFT (12) +#define DDR_FREQ_MASK (0xfff) + +#define UART_INFO_ID_SHIFT (28) +#define UART_INFO_IOMUX_SHIFT (24) +#define UART_INFO_BAUD_SHIFT (0) +#define UART_INFO_ID(n) (((n) >> 28) & 0xf) +#define UART_INFO_IOMUX(n) (((n) >> 24) & 0xf) +#define UART_INFO_BAUD(n) ((n) & 0xffffff) + +/* g_ch_info[15:0]: g_stdby_idle */ +#define STANDBY_IDLE(n) ((n) & 0xffff) + +#define SR_INFO(n) (((n) >> 16) & 0xffff) +#define PD_INFO(n) ((n) & 0xffff) + +#define FIRST_SCAN_CH(n) (((n) >> 28) & 0xf) +#define CHANNEL_MASK(n) (((n) >> 24) & 0xf) +#define STRIDE_TYPE(n) (((n) >> 16) & 0xff) + +#define DDR_2T_INFO(n) ((n) & 1) +#define PLL_SSMOD_SPREAD(n) (((n) >> 1) & 0xff) +#define PLL_SSMOD_DIV(n) (((n) >> 9) & 0xff) +#define PLL_SSMOD_DOWNSPREAD(n) (((n) >> 17) & 0x3) + +/* sdram_head_info_v2 define */ +/* for *_drv_odten and *_drv_odtoff */ +#define PHY_DQ_DRV_SHIFT 0 +#define PHY_CA_DRV_SHIFT 8 +#define PHY_CLK_DRV_SHIFT 16 +#define DRAM_DQ_DRV_SHIFT 24 +#define DRV_INFO_PHY_DQ_DRV(n) ((n) & 0xff) +#define DRV_INFO_PHY_CA_DRV(n) (((n) >> PHY_CA_DRV_SHIFT) & 0xff) +#define DRV_INFO_PHY_CLK_DRV(n) (((n) >> PHY_CLK_DRV_SHIFT) & 0xff) +#define DRV_INFO_DRAM_DQ_DRV(n) (((n) >> DRAM_DQ_DRV_SHIFT) & 0xff) + +/* for *_odt_info */ +#define DRAM_ODT_SHIFT 0 +#define PHY_ODT_SHIFT 8 +#define PHY_ODT_PUUP_EN_SHIFT 18 +#define PHY_ODT_PUDN_EN_SHIFT 19 +#define ODT_INFO_DRAM_ODT(n) (((n) >> DRAM_ODT_SHIFT) & 0xff) +#define ODT_INFO_PHY_ODT(n) (((n) >> PHY_ODT_SHIFT) & 0x3ff) +#define ODT_INFO_PULLUP_EN(n) (((n) >> PHY_ODT_PUUP_EN_SHIFT) & 1) +#define ODT_INFO_PULLDOWN_EN(n) (((n) >> PHY_ODT_PUDN_EN_SHIFT) & 1) + +/* for *odt_en_freq; */ +#define DRAM_ODT_EN_FREQ_SHIFT 0 +#define PHY_ODT_EN_FREQ_SHIFT 12 +#define DRAMODT_EN_FREQ(n) (((n) >> DRAM_ODT_EN_FREQ_SHIFT) & \ + 0xfff) +#define PHYODT_EN_FREQ(n) (((n) >> PHY_ODT_EN_FREQ_SHIFT) & 0xfff) + +#define PHY_DQ_SR_SHIFT 0 +#define PHY_CA_SR_SHIFT 8 +#define PHY_CLK_SR_SHIFT 16 +#define DQ_SR_INFO(n) (((n) >> PHY_DQ_SR_SHIFT) & 0xff) +#define CA_SR_INFO(n) (((n) >> PHY_CA_SR_SHIFT) & 0xff) +#define CLK_SR_INFO(n) (((n) >> PHY_CLK_SR_SHIFT) & 0xff) + +/* LP4 */ +#define LP4_CA_ODT_SHIFT (18) +#define LP4_DRV_PU_CAL_ODTEN_SHIFT (26) +#define LP4_DRV_PU_CAL_ODTOFF_SHIFT (27) +#define PHY_LP4_DRV_PULLDOWN_EN_ODTEN_SHIFT (28) +#define PHY_LP4_DRV_PULLDOWN_EN_ODTOFF_SHIFT (29) +#define ODT_INFO_LP4_CA_ODT(n) (((n) >> LP4_CA_ODT_SHIFT) & \ + 0xff) +#define LP4_DRV_PU_CAL_ODTEN(n) \ + (((n) >> LP4_DRV_PU_CAL_ODTEN_SHIFT) & 1) +#define LP4_DRV_PU_CAL_ODTOFF(n) \ + (((n) >> LP4_DRV_PU_CAL_ODTOFF_SHIFT) & 1) +#define PHY_LP4_DRV_PULLDOWN_EN_ODTEN(n) \ + (((n) >> PHY_LP4_DRV_PULLDOWN_EN_ODTEN_SHIFT) & 1) +#define PHY_LP4_DRV_PULLDOWN_EN_ODTOFF(n) \ + (((n) >> PHY_LP4_DRV_PULLDOWN_EN_ODTOFF_SHIFT) & 1) + +#define PHY_LP4_CS_DRV_ODTEN_SHIFT (0) +#define PHY_LP4_CS_DRV_ODTOFF_SHIFT (8) +#define LP4_ODTE_CK_SHIFT (16) +#define LP4_ODTE_CS_EN_SHIFT (17) +#define LP4_ODTD_CA_EN_SHIFT (18) +#define PHY_LP4_CS_DRV_ODTEN(n) \ + (((n) >> PHY_LP4_CS_DRV_ODTEN_SHIFT) & 0xff) +#define PHY_LP4_CS_DRV_ODTOFF(n) \ + (((n) >> PHY_LP4_CS_DRV_ODTOFF_SHIFT) & 0xff) +#define LP4_ODTE_CK_EN(n) (((n) >> LP4_ODTE_CK_SHIFT) & 1) +#define LP4_ODTE_CS_EN(n) (((n) >> LP4_ODTE_CS_EN_SHIFT) & 1) +#define LP4_ODTD_CA_EN(n) (((n) >> LP4_ODTD_CA_EN_SHIFT) & 1) + +#define PHY_LP4_DQ_VREF_SHIFT (0) +#define LP4_DQ_VREF_SHIFT (10) +#define LP4_CA_VREF_SHIFT (20) + +#define PHY_LP4_DQ_VREF(n) \ + (((n) >> PHY_LP4_DQ_VREF_SHIFT) & 0x3ff) +#define LP4_DQ_VREF(n) (((n) >> LP4_DQ_VREF_SHIFT) & 0x3ff) +#define LP4_CA_VREF(n) (((n) >> LP4_CA_VREF_SHIFT) & 0x3ff) + +#define LP4_DQ_ODT_EN_FREQ_SHIFT (0) +#define PHY_LP4_ODT_EN_FREQ_SHIFT (12) +#define LP4_CA_ODT_EN_FREQ_SHIFT (0) +#define PHY_LP4_ODT_EN_FREQ(n) \ + (((n) >> PHY_LP4_ODT_EN_FREQ_SHIFT) & 0xfff) +#define LP4_DQ_ODT_EN_FREQ(n) \ + (((n) >> LP4_DQ_ODT_EN_FREQ_SHIFT) & 0xfff) +#define LP4_CA_ODT_EN_FREQ(n) \ + (((n) >> LP4_CA_ODT_EN_FREQ_SHIFT) & 0xfff) + +struct sdram_head_info_v0 { + u32 start_tag; + u32 version_info; + u32 gcpu_gen_freq; + u32 g_d2_lp2_freq; + u32 g_d3_lp3_freq; + u32 g_d4_lp4_freq; + u32 g_uart_info; + u32 g_sr_pd_idle; + u32 g_ch_info; + u32 g_2t_info; + u32 reserved11; + u32 reserved12; + u32 reserved13; +}; + +struct index_info { + u8 offset; + u8 size; +}; + +struct sdram_head_info_index_v2 { + u32 start_tag; + u32 version_info; + struct index_info cpu_gen_index; + struct index_info global_index; + + struct index_info ddr2_index; + struct index_info ddr3_index; + + struct index_info ddr4_index; + struct index_info ddr5_index; + + struct index_info lp2_index; + struct index_info lp3_index; + + struct index_info lp4_index; + struct index_info lp5_index; + + struct index_info skew_index; + struct index_info dq_map_index; + + struct index_info lp4x_index; + struct index_info reserved; +}; + +struct global_info { + u32 uart_info; + u32 sr_pd_info; + u32 ch_info; + u32 info_2t; + u32 reserved[4]; +}; + +struct ddr2_3_4_lp2_3_info { + u32 ddr_freq0_1; + u32 ddr_freq2_3; + u32 ddr_freq4_5; + u32 drv_when_odten; + u32 drv_when_odtoff; + u32 odt_info; + u32 odten_freq; + u32 sr_when_odten; + u32 sr_when_odtoff; +}; + +struct lp4_info { + u32 ddr_freq0_1; + u32 ddr_freq2_3; + u32 ddr_freq4_5; + u32 drv_when_odten; + u32 drv_when_odtoff; + u32 odt_info; + u32 dq_odten_freq; + u32 sr_when_odten; + u32 sr_when_odtoff; + u32 ca_odten_freq; + u32 cs_drv_ca_odt_info; + u32 vref_when_odten; + u32 vref_when_odtoff; +}; + +struct dq_map_info { + u32 byte_map[2]; + u32 lp3_dq0_7_map; + u32 lp2_dq0_7_map; + u32 ddr4_dq_map[4]; +}; + struct sdram_cap_info { unsigned int rank; /* dram column number, 0 means this channel is invalid */ @@ -46,6 +250,14 @@ struct sdram_base_params { };
#define DDR_SYS_REG_VERSION (0x2) +/* for modify tRFC and related timing */ +#define DIE_CAP_512MBIT 64 +#define DIE_CAP_1GBIT 128 +#define DIE_CAP_2GBIT 256 +#define DIE_CAP_4GBIT 512 +#define DIE_CAP_8GBIT 1024 +#define DIE_CAP_16GBIT 2048 +#define DIE_CAP_32GBIT 4096 /* * sys_reg2 bitfield struct * [31] row_3_4_ch1 diff --git a/arch/arm/include/asm/arch-rockchip/sdram_msch.h b/arch/arm/include/asm/arch-rockchip/sdram_msch.h index cfb3d9cc86..d1926f4bf2 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_msch.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_msch.h @@ -57,6 +57,18 @@ union noc_devtodev0 { } b; };
+union noc_devtodev_rv1126 { + u32 d32; + struct { + unsigned busrdtord : 3; + unsigned reserved0 : 1; + unsigned busrdtowr : 4; + unsigned buswrtord : 4; + unsigned buswrtowr : 3; + unsigned reserved2 : 17; + } b; +}; + union noc_ddrmode { u32 d32; struct { diff --git a/arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h b/arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h new file mode 100644 index 0000000000..5b64ec3352 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h @@ -0,0 +1,93 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_RK1126_PHY_H +#define _ASM_ARCH_SDRAM_RK1126_PHY_H + +/* PHY_REG0 */ +#define DIGITAL_DERESET BIT(3) +#define ANALOG_DERESET BIT(2) +#define DIGITAL_RESET (0 << 3) +#define ANALOG_RESET (0 << 2) + +/* PHY_REG1 */ +#define PHY_DDR2 (0) +#define PHY_LPDDR2 (1) +#define PHY_DDR3 (2) +#define PHY_LPDDR3 (3) +#define PHY_DDR4 (4) +#define PHY_DDR5 (5) +#define PHY_BL_4 (0 << 3) +#define PHY_BL_8_OR_16 BIT(3) + +/* PHY_REG2 */ +#define PHY_DTT_EN BIT(0) +#define PHY_DTT_DISB (0 << 0) +#define PHY_WRITE_LEVELING_EN BIT(2) +#define PHY_WRITE_LEVELING_DISB (0 << 2) +#define PHY_SELECT_CS0 (2) +#define PHY_SELECT_CS1 (1) +#define PHY_SELECT_CS0_1 (0) +#define PHY_WRITE_LEVELING_SELECTCS(n) ((n) << 6) +#define PHY_DATA_TRAINING_SELECTCS(n) ((n) << 4) + +/* PHY_REGf */ +#define PHY_DQ_WIDTH_MASK (0xf) + +/* PHY_REG51 */ +#define PHY_PBDIV_BIT9_MASK BIT(0) +#define PHY_PBDIV_BIT9_SHIFT (0) +#define PHY_POSTDIV_EN_MASK BIT(7) +#define PHY_POSTDIV_EN_SHIFT (7) + +/* PHY_REG52 */ +#define PHY_PREDIV_MASK (0x1F) +#define PHY_PREDIV_SHIFT (0) + +/* PHY_REG53*/ +#define PHY_POSTDIV_MASK (0x7) +#define PHY_POSTDIV_SHIFT (5) +#define PHY_PD_DISB BIT(3) + +/* PHY_REG90 */ +#define PHY_PLL_LOCK BIT(2) + +struct ca_skew { + u32 a0_a3_a3_cke1_a_de_skew; + u32 a1_ba1_null_cke0_b_de_skew; + u32 a2_a9_a9_a4_a_de_skew; + u32 a3_a15_null_a5_b_de_skew; + u32 a4_a6_a6_ck_a_de_skew; + u32 a5_a12_null_odt0_b_de_skew; + u32 a6_ba2_null_a0_a_de_skew; + u32 a7_a4_a4_odt0_a_de_skew; + u32 a8_a1_a1_cke0_a_de_skew; + u32 a9_a5_a5_a5_a_de_skew; + u32 a10_a8_a8_clkb_a_de_skew; + u32 a11_a7_a7_ca2_a_de_skew; + u32 a12_rasn_null_ca1_a_de_skew; + u32 a13_a13_null_ca3_a_de_skew; + u32 a14_a14_null_csb1_b_de_skew; + u32 a15_a10_null_ca0_b_de_skew; + u32 a16_a11_null_csb0_b_de_skew; + u32 a17_null_null_null_de_skew; + u32 ba0_csb1_csb1_csb0_a_de_skew; + u32 ba1_wen_null_cke1_b_de_skew; + u32 bg0_odt1_odt1_csb1_a_de_skew; + u32 bg1_a2_a2_odt1_a_de_skew; + u32 cke0_casb_null_ca1_b_de_skew; + u32 ck_ck_ck_ck_b_de_skew; + u32 ckb_ckb_ckb_ckb_b_de_skew; + u32 csb0_odt0_odt0_ca2_b_de_skew; + u32 odt0_csb0_csb0_ca4_b_de_skew; + u32 resetn_resetn_null_resetn_de_skew; + u32 actn_cke_cke_ca3_b_de_skew; + u32 null_null_null_null_de_skew; + u32 csb1_ba0_null_null_de_skew; + u32 odt1_a0_a0_odt1_b_de_skew; +}; + +#define PHY_REG(base, n) ((base) + 4 * (n)) +#endif /* _ASM_ARCH_SDRAM_RK1126_PHY_H */ diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rv1126.h b/arch/arm/include/asm/arch-rockchip/sdram_rv1126.h new file mode 100644 index 0000000000..6a07436059 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_rv1126.h @@ -0,0 +1,420 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2020 Rockchip Electronics Co., Ltd + */ + +#ifndef _ASM_ARCH_SDRAM_RK1126_H +#define _ASM_ARCH_SDRAM_RK1126_H + +#include <asm/arch-rockchip/dram_spec_timing.h> +#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_msch.h> +#include <asm/arch-rockchip/sdram_pctl_px30.h> +#include <asm/arch-rockchip/sdram_phy_rv1126.h> + +#define AGINGX0_VAL (4) +#define AGING_CPU_VAL (0xff) +#define AGING_NPU_VAL (0xff) +#define AGING_OTHER_VAL (0x33) + +#define PATTERN (0x5aa5f00f) + +#define PHY_DDR3_RON_DISABLE (0) +#define PHY_DDR3_RON_455ohm (1) +#define PHY_DDR3_RON_230ohm (2) +#define PHY_DDR3_RON_153ohm (3) +#define PHY_DDR3_RON_115ohm (4) +#define PHY_DDR3_RON_91ohm (5) +#define PHY_DDR3_RON_76ohm (6) +#define PHY_DDR3_RON_65ohm (7) +#define PHY_DDR3_RON_57ohm (16) +#define PHY_DDR3_RON_51ohm (17) +#define PHY_DDR3_RON_46ohm (18) +#define PHY_DDR3_RON_41ohm (19) +#define PHY_DDR3_RON_38ohm (20) +#define PHY_DDR3_RON_35ohm (21) +#define PHY_DDR3_RON_32ohm (22) +#define PHY_DDR3_RON_30ohm (23) +#define PHY_DDR3_RON_28ohm (24) +#define PHY_DDR3_RON_27ohm (25) +#define PHY_DDR3_RON_25ohm (26) +#define PHY_DDR3_RON_24ohm (27) +#define PHY_DDR3_RON_23ohm (28) +#define PHY_DDR3_RON_22ohm (29) +#define PHY_DDR3_RON_21ohm (30) +#define PHY_DDR3_RON_20ohm (31) + +#define PHY_DDR3_RTT_DISABLE (0) +#define PHY_DDR3_RTT_561ohm (1) +#define PHY_DDR3_RTT_282ohm (2) +#define PHY_DDR3_RTT_188ohm (3) +#define PHY_DDR3_RTT_141ohm (4) +#define PHY_DDR3_RTT_113ohm (5) +#define PHY_DDR3_RTT_94ohm (6) +#define PHY_DDR3_RTT_81ohm (7) +#define PHY_DDR3_RTT_72ohm (16) +#define PHY_DDR3_RTT_64ohm (17) +#define PHY_DDR3_RTT_58ohm (18) +#define PHY_DDR3_RTT_52ohm (19) +#define PHY_DDR3_RTT_48ohm (20) +#define PHY_DDR3_RTT_44ohm (21) +#define PHY_DDR3_RTT_41ohm (22) +#define PHY_DDR3_RTT_38ohm (23) +#define PHY_DDR3_RTT_37ohm (24) +#define PHY_DDR3_RTT_34ohm (25) +#define PHY_DDR3_RTT_32ohm (26) +#define PHY_DDR3_RTT_31ohm (27) +#define PHY_DDR3_RTT_29ohm (28) +#define PHY_DDR3_RTT_28ohm (29) +#define PHY_DDR3_RTT_27ohm (30) +#define PHY_DDR3_RTT_25ohm (31) + +#define PHY_DDR4_LPDDR3_RON_DISABLE (0) +#define PHY_DDR4_LPDDR3_RON_482ohm (1) +#define PHY_DDR4_LPDDR3_RON_244ohm (2) +#define PHY_DDR4_LPDDR3_RON_162ohm (3) +#define PHY_DDR4_LPDDR3_RON_122ohm (4) +#define PHY_DDR4_LPDDR3_RON_97ohm (5) +#define PHY_DDR4_LPDDR3_RON_81ohm (6) +#define PHY_DDR4_LPDDR3_RON_69ohm (7) +#define PHY_DDR4_LPDDR3_RON_61ohm (16) +#define PHY_DDR4_LPDDR3_RON_54ohm (17) +#define PHY_DDR4_LPDDR3_RON_48ohm (18) +#define PHY_DDR4_LPDDR3_RON_44ohm (19) +#define PHY_DDR4_LPDDR3_RON_40ohm (20) +#define PHY_DDR4_LPDDR3_RON_37ohm (21) +#define PHY_DDR4_LPDDR3_RON_34ohm (22) +#define PHY_DDR4_LPDDR3_RON_32ohm (23) +#define PHY_DDR4_LPDDR3_RON_30ohm (24) +#define PHY_DDR4_LPDDR3_RON_28ohm (25) +#define PHY_DDR4_LPDDR3_RON_27ohm (26) +#define PHY_DDR4_LPDDR3_RON_25ohm (27) +#define PHY_DDR4_LPDDR3_RON_24ohm (28) +#define PHY_DDR4_LPDDR3_RON_23ohm (29) +#define PHY_DDR4_LPDDR3_RON_22ohm (30) +#define PHY_DDR4_LPDDR3_RON_21ohm (31) + +#define PHY_DDR4_LPDDR3_RTT_DISABLE (0) +#define PHY_DDR4_LPDDR3_RTT_586ohm (1) +#define PHY_DDR4_LPDDR3_RTT_294ohm (2) +#define PHY_DDR4_LPDDR3_RTT_196ohm (3) +#define PHY_DDR4_LPDDR3_RTT_148ohm (4) +#define PHY_DDR4_LPDDR3_RTT_118ohm (5) +#define PHY_DDR4_LPDDR3_RTT_99ohm (6) +#define PHY_DDR4_LPDDR3_RTT_85ohm (7) +#define PHY_DDR4_LPDDR3_RTT_76ohm (16) +#define PHY_DDR4_LPDDR3_RTT_67ohm (17) +#define PHY_DDR4_LPDDR3_RTT_60ohm (18) +#define PHY_DDR4_LPDDR3_RTT_55ohm (19) +#define PHY_DDR4_LPDDR3_RTT_50ohm (20) +#define PHY_DDR4_LPDDR3_RTT_46ohm (21) +#define PHY_DDR4_LPDDR3_RTT_43ohm (22) +#define PHY_DDR4_LPDDR3_RTT_40ohm (23) +#define PHY_DDR4_LPDDR3_RTT_38ohm (24) +#define PHY_DDR4_LPDDR3_RTT_36ohm (25) +#define PHY_DDR4_LPDDR3_RTT_34ohm (26) +#define PHY_DDR4_LPDDR3_RTT_32ohm (27) +#define PHY_DDR4_LPDDR3_RTT_31ohm (28) +#define PHY_DDR4_LPDDR3_RTT_29ohm (29) +#define PHY_DDR4_LPDDR3_RTT_28ohm (30) +#define PHY_DDR4_LPDDR3_RTT_27ohm (31) + +#define PHY_LPDDR4_RON_DISABLE (0) +#define PHY_LPDDR4_RON_501ohm (1) +#define PHY_LPDDR4_RON_253ohm (2) +#define PHY_LPDDR4_RON_168ohm (3) +#define PHY_LPDDR4_RON_126ohm (4) +#define PHY_LPDDR4_RON_101ohm (5) +#define PHY_LPDDR4_RON_84ohm (6) +#define PHY_LPDDR4_RON_72ohm (7) +#define PHY_LPDDR4_RON_63ohm (16) +#define PHY_LPDDR4_RON_56ohm (17) +#define PHY_LPDDR4_RON_50ohm (18) +#define PHY_LPDDR4_RON_46ohm (19) +#define PHY_LPDDR4_RON_42ohm (20) +#define PHY_LPDDR4_RON_38ohm (21) +#define PHY_LPDDR4_RON_36ohm (22) +#define PHY_LPDDR4_RON_33ohm (23) +#define PHY_LPDDR4_RON_31ohm (24) +#define PHY_LPDDR4_RON_29ohm (25) +#define PHY_LPDDR4_RON_28ohm (26) +#define PHY_LPDDR4_RON_26ohm (27) +#define PHY_LPDDR4_RON_25ohm (28) +#define PHY_LPDDR4_RON_24ohm (29) +#define PHY_LPDDR4_RON_23ohm (30) +#define PHY_LPDDR4_RON_22ohm (31) + +#define PHY_LPDDR4_RTT_DISABLE (0) +#define PHY_LPDDR4_RTT_604ohm (1) +#define PHY_LPDDR4_RTT_303ohm (2) +#define PHY_LPDDR4_RTT_202ohm (3) +#define PHY_LPDDR4_RTT_152ohm (4) +#define PHY_LPDDR4_RTT_122ohm (5) +#define PHY_LPDDR4_RTT_101ohm (6) +#define PHY_LPDDR4_RTT_87ohm (7) +#define PHY_LPDDR4_RTT_78ohm (16) +#define PHY_LPDDR4_RTT_69ohm (17) +#define PHY_LPDDR4_RTT_62ohm (18) +#define PHY_LPDDR4_RTT_56ohm (19) +#define PHY_LPDDR4_RTT_52ohm (20) +#define PHY_LPDDR4_RTT_48ohm (21) +#define PHY_LPDDR4_RTT_44ohm (22) +#define PHY_LPDDR4_RTT_41ohm (23) +#define PHY_LPDDR4_RTT_39ohm (24) +#define PHY_LPDDR4_RTT_37ohm (25) +#define PHY_LPDDR4_RTT_35ohm (26) +#define PHY_LPDDR4_RTT_33ohm (27) +#define PHY_LPDDR4_RTT_32ohm (28) +#define PHY_LPDDR4_RTT_30ohm (29) +#define PHY_LPDDR4_RTT_29ohm (30) +#define PHY_LPDDR4_RTT_27ohm (31) + +#define ADD_CMD_CA (0x150) +#define ADD_GROUP_CS0_A (0x170) +#define ADD_GROUP_CS0_B (0x1d0) +#define ADD_GROUP_CS1_A (0x1a0) +#define ADD_GROUP_CS1_B (0x200) + +/* PMUGRF */ +#define PMUGRF_OS_REG0 (0x200) +#define PMUGRF_OS_REG(n) (PMUGRF_OS_REG0 + (n) * 4) +#define PMUGRF_CON_DDRPHY_BUFFEREN_MASK (0x3 << (12 + 16)) +#define PMUGRF_CON_DDRPHY_BUFFEREN_EN (0x1 << 12) +#define PMUGRF_CON_DDRPHY_BUFFEREN_DIS (0x2 << 12) + +/* DDR GRF */ +#define DDR_GRF_CON(n) (0 + (n) * 4) +#define DDR_GRF_STATUS_BASE (0X100) +#define DDR_GRF_STATUS(n) (DDR_GRF_STATUS_BASE + (n) * 4) +#define DDR_GRF_LP_CON (0x20) + +#define SPLIT_MODE_32_L16_VALID (0) +#define SPLIT_MODE_32_H16_VALID (1) +#define SPLIT_MODE_16_L8_VALID (2) +#define SPLIT_MODE_16_H8_VALID (3) + +#define DDR_GRF_SPLIT_CON (0x10) +#define SPLIT_MODE_MASK (0x3) +#define SPLIT_MODE_OFFSET (9) +#define SPLIT_BYPASS_MASK (1) +#define SPLIT_BYPASS_OFFSET (8) +#define SPLIT_SIZE_MASK (0xff) +#define SPLIT_SIZE_OFFSET (0) + +/* SGRF SOC_CON13 */ +#define UPCTL2_ASRSTN_REQ(n) (((0x1 << 0) << 16) | ((n) << 0)) +#define UPCTL2_PSRSTN_REQ(n) (((0x1 << 1) << 16) | ((n) << 1)) +#define UPCTL2_SRSTN_REQ(n) (((0x1 << 2) << 16) | ((n) << 2)) + +/* CRU define */ +/* CRU_PLL_CON0 */ +#define PB(n) ((0x1 << (15 + 16)) | ((n) << 15)) +#define POSTDIV1(n) ((0x7 << (12 + 16)) | ((n) << 12)) +#define FBDIV(n) ((0xFFF << 16) | (n)) + +/* CRU_PLL_CON1 */ +#define RSTMODE(n) ((0x1 << (15 + 16)) | ((n) << 15)) +#define RST(n) ((0x1 << (14 + 16)) | ((n) << 14)) +#define PD(n) ((0x1 << (13 + 16)) | ((n) << 13)) +#define DSMPD(n) ((0x1 << (12 + 16)) | ((n) << 12)) +#define LOCK(n) (((n) >> 10) & 0x1) +#define POSTDIV2(n) ((0x7 << (6 + 16)) | ((n) << 6)) +#define REFDIV(n) ((0x3F << 16) | (n)) + +/* CRU_PLL_CON3 */ +#define SSMOD_SPREAD(n) ((0x1f << (8 + 16)) | ((n) << 8)) +#define SSMOD_DIVVAL(n) ((0xf << (4 + 16)) | ((n) << 4)) +#define SSMOD_DOWNSPREAD(n) ((0x1 << (3 + 16)) | ((n) << 3)) +#define SSMOD_RESET(n) ((0x1 << (2 + 16)) | ((n) << 2)) +#define SSMOD_DIS_SSCG(n) ((0x1 << (1 + 16)) | ((n) << 1)) +#define SSMOD_BP(n) ((0x1 << (0 + 16)) | ((n) << 0)) + +/* CRU_MODE */ +#define CLOCK_FROM_XIN_OSC (0) +#define CLOCK_FROM_PLL (1) +#define CLOCK_FROM_RTC_32K (2) +#define DPLL_MODE(n) ((0x3 << (2 + 16)) | ((n) << 2)) + +/* CRU_SOFTRESET_CON1 */ +#define DDRPHY_PSRSTN_REQ(n) (((0x1 << 14) << 16) | ((n) << 14)) +#define DDRPHY_SRSTN_REQ(n) (((0x1 << 15) << 16) | ((n) << 15)) +/* CRU_CLKGATE_CON2 */ +#define DDR_MSCH_EN_MASK ((0x1 << 10) << 16) +#define DDR_MSCH_EN_SHIFT (10) + +/* CRU register */ +#define CRU_PLL_CON(pll_id, n) ((pll_id) * 0x20 + (n) * 4) +#define CRU_MODE (0xa0) +#define CRU_GLB_CNT_TH (0xb0) +#define CRU_CLKSEL_CON_BASE 0x100 +#define CRU_CLKSELS_CON(i) (CRU_CLKSEL_CON_BASE + ((i) * 4)) +#define CRU_CLKGATE_CON_BASE 0x230 +#define CRU_CLKGATE_CON(i) (CRU_CLKGATE_CON_BASE + ((i) * 4)) +#define CRU_CLKSFTRST_CON_BASE 0x300 +#define CRU_CLKSFTRST_CON(i) (CRU_CLKSFTRST_CON_BASE + ((i) * 4)) + +/* SGRF_SOC_CON2 */ +#define MSCH_AXI_BYPASS_ALL_MASK (1) +#define MSCH_AXI_BYPASS_ALL_SHIFT (15) + +/* SGRF_SOC_CON12 */ +#define CLK_DDR_UPCTL_EN_MASK ((0x1 << 2) << 16) +#define CLK_DDR_UPCTL_EN_SHIFT (2) +#define ACLK_DDR_UPCTL_EN_MASK ((0x1 << 0) << 16) +#define ACLK_DDR_UPCTL_EN_SHIFT (0) + +/* DDRGRF DDR CON2 */ +#define DFI_FREQ_CHANGE_ACK BIT(10) +/* DDRGRF status8 */ +#define DFI_FREQ_CHANGE_REQ BIT(19) + +struct rv1126_ddrgrf { + u32 ddr_grf_con[4]; + u32 grf_ddrsplit_con; + u32 reserved1[(0x20 - 0x10) / 4 - 1]; + u32 ddr_grf_lp_con; + u32 reserved2[(0x40 - 0x20) / 4 - 1]; + u32 grf_ddrphy_con[6]; + u32 reserved3[(0x100 - 0x54) / 4 - 1]; + u32 ddr_grf_status[18]; + u32 reserved4[(0x150 - 0x144) / 4 - 1]; + u32 grf_ddrhold_status; + u32 reserved5[(0x160 - 0x150) / 4 - 1]; + u32 grf_ddrphy_status[2]; +}; + +struct rv1126_ddr_phy_regs { + u32 phy[8][2]; +}; + +struct msch_regs { + u32 coreid; + u32 revisionid; + u32 deviceconf; + u32 devicesize; + u32 ddrtiminga0; + u32 ddrtimingb0; + u32 ddrtimingc0; + u32 devtodev0; + u32 reserved1[(0x110 - 0x20) / 4]; + u32 ddrmode; + u32 ddr4timing; + u32 reserved2[(0x1000 - 0x118) / 4]; + u32 agingx0; + u32 reserved3[(0x1040 - 0x1004) / 4]; + u32 aging0; + u32 aging1; + u32 aging2; + u32 aging3; +}; + +struct sdram_msch_timings { + union noc_ddrtiminga0 ddrtiminga0; + union noc_ddrtimingb0 ddrtimingb0; + union noc_ddrtimingc0 ddrtimingc0; + union noc_devtodev_rv1126 devtodev0; + union noc_ddrmode ddrmode; + union noc_ddr4timing ddr4timing; + u32 agingx0; + u32 aging0; + u32 aging1; + u32 aging2; + u32 aging3; +}; + +struct rv1126_sdram_channel { + struct sdram_cap_info cap_info; + struct sdram_msch_timings noc_timings; +}; + +struct rv1126_sdram_params { + struct rv1126_sdram_channel ch; + struct sdram_base_params base; + struct ddr_pctl_regs pctl_regs; + struct rv1126_ddr_phy_regs phy_regs; +}; + +struct rv1126_fsp_param { + u32 flag; + u32 freq_mhz; + + /* dram size */ + u32 dq_odt; + u32 ca_odt; + u32 ds_pdds; + u32 vref_ca[2]; + u32 vref_dq[2]; + + /* phy side */ + u32 wr_dq_drv; + u32 wr_ca_drv; + u32 wr_ckcs_drv; + u32 rd_odt; + u32 rd_odt_up_en; + u32 rd_odt_down_en; + u32 vref_inner; + u32 vref_out; + u32 lp4_drv_pd_en; + + struct sdram_msch_timings noc_timings; +}; + +#define MAX_IDX (4) +#define FSP_FLAG (0xfead0001) +#define SHARE_MEM_BASE (0x100000) +/* + * Borrow share memory space to temporarily store FSP parame. + * In the stage of DDR init write FSP parame to this space. + * In the stage of trust init move FSP parame to SRAM space + * from share memory space. + */ +#define FSP_PARAM_STORE_ADDR (SHARE_MEM_BASE) + +/* store result of read and write training, for ddr_dq_eye tool in u-boot */ +#define RW_TRN_RESULT_ADDR (0x2000000 + 0x8000) /* 32M + 32k */ +#define PRINT_STEP 1 + +#undef FSP_NUM +#undef CS_NUM +#undef BYTE_NUM + +#define FSP_NUM 4 +#define CS_NUM 2 +#define BYTE_NUM 4 +#define RD_DESKEW_NUM 64 +#define WR_DESKEW_NUM 64 + +#define LP4_WIDTH_REF_MHZ_H 1056 +#define LP4_RD_WIDTH_REF_H 12 +#define LP4_WR_WIDTH_REF_H 13 + +#define LP4_WIDTH_REF_MHZ_L 924 +#define LP4_RD_WIDTH_REF_L 15 +#define LP4_WR_WIDTH_REF_L 15 + +#define DDR4_WIDTH_REF_MHZ_H 1056 +#define DDR4_RD_WIDTH_REF_H 13 +#define DDR4_WR_WIDTH_REF_H 9 + +#define DDR4_WIDTH_REF_MHZ_L 924 +#define DDR4_RD_WIDTH_REF_L 15 +#define DDR4_WR_WIDTH_REF_L 11 + +#define LP3_WIDTH_REF_MHZ_H 1056 +#define LP3_RD_WIDTH_REF_H 15 +#define LP3_WR_WIDTH_REF_H 13 + +#define LP3_WIDTH_REF_MHZ_L 924 +#define LP3_RD_WIDTH_REF_L 16 +#define LP3_WR_WIDTH_REF_L 15 + +#define DDR3_WIDTH_REF_MHZ_H 1056 +#define DDR3_RD_WIDTH_REF_H 14 +#define DDR3_WR_WIDTH_REF_H 14 + +#define DDR3_WIDTH_REF_MHZ_L 924 +#define DDR3_RD_WIDTH_REF_L 17 +#define DDR3_WR_WIDTH_REF_L 17 + +#endif /* _ASM_ARCH_SDRAM_RK1126_H */ diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 6d530c29af..98839ad6a6 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -14,4 +14,5 @@ obj-$(CONFIG_ROCKCHIP_RK3308) = sdram_rk3308.o obj-$(CONFIG_ROCKCHIP_RK3328) = sdram_rk3328.o sdram_pctl_px30.o sdram_phy_px30.o obj-$(CONFIG_ROCKCHIP_RK3399) += sdram_rk3399.o obj-$(CONFIG_ROCKCHIP_RK3568) += sdram_rk3568.o +obj-$(CONFIG_ROCKCHIP_RV1126) += sdram_rv1126.o sdram_pctl_px30.o obj-$(CONFIG_ROCKCHIP_SDRAM_COMMON) += sdram_common.o diff --git a/drivers/ram/rockchip/sdram_rv1126.c b/drivers/ram/rockchip/sdram_rv1126.c new file mode 100644 index 0000000000..9b1c34391e --- /dev/null +++ b/drivers/ram/rockchip/sdram_rv1126.c @@ -0,0 +1,3521 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * (C) Copyright 2020 Rockchip Electronics Co., Ltd. + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/cru_rv1126.h> +#include <asm/arch-rockchip/grf_rv1126.h> +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_rv1126.h> +#include <linux/delay.h> + +/* define training flag */ +#define CA_TRAINING (0x1 << 0) +#define READ_GATE_TRAINING (0x1 << 1) +#define WRITE_LEVELING (0x1 << 2) +#define WRITE_TRAINING (0x1 << 3) +#define READ_TRAINING (0x1 << 4) +#define FULL_TRAINING (0xff) + +#define SKEW_RX_SIGNAL (0) +#define SKEW_TX_SIGNAL (1) +#define SKEW_CA_SIGNAL (2) + +#define DESKEW_MDF_ABS_VAL (0) +#define DESKEW_MDF_DIFF_VAL (1) + +struct dram_info { +#if defined(CONFIG_TPL_BUILD) || \ + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + void __iomem *pctl; + void __iomem *phy; + struct rv1126_cru *cru; + struct msch_regs *msch; + struct rv1126_ddrgrf *ddrgrf; + struct rv1126_grf *grf; + u32 sr_idle; + u32 pd_idle; +#endif + struct ram_info info; + struct rv1126_pmugrf *pmugrf; +}; + +#if defined(CONFIG_TPL_BUILD) || \ + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + +#define GRF_BASE_ADDR 0xfe000000 +#define PMU_GRF_BASE_ADDR 0xfe020000 +#define DDR_GRF_BASE_ADDR 0xfe030000 +#define BUS_SGRF_BASE_ADDR 0xfe0a0000 +#define SERVER_MSCH_BASE_ADDR 0xfe800000 +#define CRU_BASE_ADDR 0xff490000 +#define DDR_PHY_BASE_ADDR 0xff4a0000 +#define UPCTL2_BASE_ADDR 0xffa50000 + +#define SGRF_SOC_CON2 0x8 +#define SGRF_SOC_CON12 0x30 +#define SGRF_SOC_CON13 0x34 + +struct dram_info dram_info; + +struct rv1126_sdram_params sdram_configs[] = { +# include "sdram-rv1126-ddr3-detect-328.inc" +# include "sdram-rv1126-ddr3-detect-396.inc" +# include "sdram-rv1126-ddr3-detect-528.inc" +# include "sdram-rv1126-ddr3-detect-664.inc" +# include "sdram-rv1126-ddr3-detect-784.inc" +# include "sdram-rv1126-ddr3-detect-924.inc" +# include "sdram-rv1126-ddr3-detect-1056.inc" +}; + +u32 common_info[] = { +#include "sdram-rv1126-loader_params.inc" +}; + +#if defined(CONFIG_CMD_DDR_TEST_TOOL) +static struct rw_trn_result rw_trn_result; +#endif + +static struct rv1126_fsp_param fsp_param[MAX_IDX]; + +static u8 lp3_odt_value; + +static s8 wrlvl_result[2][4]; + +/* DDR configuration 0-9 */ +u16 ddr_cfg_2_rbc[] = { + ((0 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 3), /* 0 */ + ((1 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 2), /* 1 */ + ((1 << 8) | (2 << 5) | (0 << 4) | (1 << 3) | 3), /* 2 */ + ((1 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 1), /* 3 */ + ((0 << 8) | (2 << 5) | (0 << 4) | (1 << 3) | 4), /* 4 */ + ((0 << 8) | (3 << 5) | (1 << 4) | (1 << 3) | 1), /* 5 */ + ((0 << 8) | (3 << 5) | (1 << 4) | (1 << 3) | 2), /* 6 */ + ((0 << 8) | (2 << 5) | (1 << 4) | (1 << 3) | 3), /* 7 */ + ((1 << 8) | (3 << 5) | (0 << 4) | (0 << 3) | 2), /* 8 */ + ((1 << 8) | (2 << 5) | (0 << 4) | (1 << 3) | 2) /* 9 */ +}; + +/* DDR configuration 10-21 */ +u8 ddr4_cfg_2_rbc[] = { + ((0 << 7) | (3 << 4) | (0 << 3) | (2 << 1) | 0), /* 10 */ + ((1 << 7) | (2 << 4) | (0 << 3) | (2 << 1) | 0), /* 11 */ + ((0 << 7) | (4 << 4) | (0 << 3) | (1 << 1) | 0), /* 12 */ + ((1 << 7) | (3 << 4) | (0 << 3) | (1 << 1) | 0), /* 13 */ + ((0 << 7) | (4 << 4) | (0 << 3) | (2 << 1) | 1), /* 14 */ + ((1 << 7) | (3 << 4) | (0 << 3) | (2 << 1) | 1), /* 15 */ + ((1 << 7) | (4 << 4) | (0 << 3) | (1 << 1) | 1), /* 16 */ + ((0 << 7) | (2 << 4) | (1 << 3) | (2 << 1) | 0), /* 17 */ + ((0 << 7) | (3 << 4) | (1 << 3) | (1 << 1) | 0), /* 18 */ + ((0 << 7) | (3 << 4) | (1 << 3) | (2 << 1) | 1), /* 19 */ + ((0 << 7) | (4 << 4) | (1 << 3) | (1 << 1) | 1), /* 20 */ + ((1 << 7) | (4 << 4) | (0 << 3) | (0 << 1) | 0) /* 21 */ +}; + +/* DDR configuration 22-28 */ +u16 ddr_cfg_2_rbc_p2[] = { + ((1 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 0), /* 22 */ + ((0 << 8) | (4 << 5) | (0 << 4) | (1 << 3) | 2), /* 23 */ + ((1 << 8) | (3 << 5) | (0 << 4) | (0 << 3) | 3), /* 24 */ + ((0 << 8) | (3 << 5) | (1 << 4) | (0 << 3) | 3), /* 25 */ + ((0 << 8) | (4 << 5) | (1 << 4) | (0 << 3) | 2), /* 26 */ + ((1 << 8) | (4 << 5) | (0 << 4) | (0 << 3) | 2), /* 27 */ + ((0 << 8) | (4 << 5) | (0 << 4) | (0 << 3) | 3) /* 28 */ +}; + +u8 d4_rbc_2_d3_rbc[][2] = { + {10, 0}, + {11, 2}, + {12, 23}, + {13, 1}, + {14, 28}, + {15, 24}, + {16, 27}, + {17, 7}, + {18, 6}, + {19, 25}, + {20, 26}, + {21, 3} +}; + +u32 addrmap[29][9] = { + {24, 0x00090909, 0x00000000, 0x00000000, 0x00001f00, 0x08080808, + 0x08080808, 0x00000f0f, 0x3f3f}, /* 0 */ + {23, 0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f0f, 0x3f3f}, /* 1 */ + {23, 0x00090909, 0x00000000, 0x00000000, 0x00001f00, 0x08080808, + 0x0f080808, 0x00000f0f, 0x3f3f}, /* 2 */ + {22, 0x00070707, 0x00000000, 0x1f000000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000f0f, 0x3f3f}, /* 3 */ + {24, 0x000a0a0a, 0x00000000, 0x00000000, 0x00000000, 0x09090909, + 0x0f090909, 0x00000f0f, 0x3f3f}, /* 4 */ + {6, 0x00070707, 0x00000000, 0x1f000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f0f, 0x3f3f}, /* 5 */ + {7, 0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x08080808, + 0x08080808, 0x00000f0f, 0x3f3f}, /* 6 */ + {8, 0x00090909, 0x00000000, 0x00000000, 0x00001f00, 0x09090909, + 0x0f090909, 0x00000f0f, 0x3f3f}, /* 7 */ + {22, 0x001f0808, 0x00000000, 0x00000000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000f0f, 0x3f3f}, /* 8 */ + {23, 0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707, + 0x0f070707, 0x00000f0f, 0x3f3f}, /* 9 */ + + {24, 0x003f0a0a, 0x01010100, 0x01010101, 0x00001f1f, 0x08080808, + 0x08080808, 0x00000f0f, 0x0801}, /* 10 */ + {23, 0x003f0a0a, 0x01010100, 0x01010101, 0x00001f1f, 0x08080808, + 0x0f080808, 0x00000f0f, 0x0801}, /* 11 */ + {24, 0x003f0909, 0x00000007, 0x1f000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x0700}, /* 12 */ + {23, 0x003f0909, 0x00000007, 0x1f000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f0f, 0x0700}, /* 13 */ + {24, 0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x3f01}, /* 14 */ + {23, 0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f0f, 0x3f01}, /* 15 */ + {23, 0x003f0808, 0x00000007, 0x1f000000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000f06, 0x3f00}, /* 16 */ + {8, 0x003f0a0a, 0x01010100, 0x01010101, 0x00001f1f, 0x09090909, + 0x0f090909, 0x00000f0f, 0x0801}, /* 17 */ + {7, 0x003f0909, 0x00000007, 0x1f000000, 0x00001f1f, 0x08080808, + 0x08080808, 0x00000f0f, 0x0700}, /* 18 */ + {7, 0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x08080808, + 0x08080808, 0x00000f0f, 0x3f01}, /* 19 */ + + {6, 0x003f0808, 0x00000007, 0x1f000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x3f00}, /* 20 */ + {23, 0x003f0909, 0x00000006, 0x1f1f0000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000f06, 0x0600}, /* 21 */ + {21, 0x00060606, 0x00000000, 0x1f1f0000, 0x00001f1f, 0x05050505, + 0x05050505, 0x00000f0f, 0x3f3f}, /* 22 */ + + {24, 0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x3f3f}, /* 23 */ + {23, 0x003f0909, 0x00000000, 0x00000000, 0x00001f00, 0x07070707, + 0x07070707, 0x00000f0f, 0x3f3f}, /* 24 */ + {7, 0x003f0909, 0x00000000, 0x00000000, 0x00001f00, 0x08080808, + 0x08080808, 0x00000f0f, 0x3f3f}, /* 25 */ + {6, 0x003f0808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707, + 0x07070707, 0x00000f07, 0x3f3f}, /* 26 */ + {23, 0x003f0808, 0x00000000, 0x00000000, 0x00001f1f, 0x06060606, + 0x06060606, 0x00000f06, 0x3f3f}, /* 27 */ + {24, 0x003f0909, 0x00000000, 0x00000000, 0x00001f00, 0x07070707, + 0x07070707, 0x00000f07, 0x3f3f} /* 28 */ +}; + +static u8 dq_sel[22][3] = { + {0x0, 0x17, 0x22}, + {0x1, 0x18, 0x23}, + {0x2, 0x19, 0x24}, + {0x3, 0x1a, 0x25}, + {0x4, 0x1b, 0x26}, + {0x5, 0x1c, 0x27}, + {0x6, 0x1d, 0x28}, + {0x7, 0x1e, 0x29}, + {0x8, 0x16, 0x21}, + {0x9, 0x1f, 0x2a}, + {0xa, 0x20, 0x2b}, + {0x10, 0x1, 0xc}, + {0x11, 0x2, 0xd}, + {0x12, 0x3, 0xe}, + {0x13, 0x4, 0xf}, + {0x14, 0x5, 0x10}, + {0x15, 0x6, 0x11}, + {0x16, 0x7, 0x12}, + {0x17, 0x8, 0x13}, + {0x18, 0x0, 0xb}, + {0x19, 0x9, 0x14}, + {0x1a, 0xa, 0x15} +}; + +static u16 grp_addr[4] = { + ADD_GROUP_CS0_A, + ADD_GROUP_CS0_B, + ADD_GROUP_CS1_A, + ADD_GROUP_CS1_B +}; + +static u8 wrlvl_result_offset[2][4] = { + {0xa0 + 0x26, 0xa0 + 0x27, 0xd0 + 0x26, 0xd0 + 0x27}, + {0xa0 + 0x28, 0xa0 + 0x29, 0xd0 + 0x28, 0xd0 + 0x29}, +}; + +static u16 dqs_dq_skew_adr[16] = { + 0x170 + 0, /* SKEW_UPDATE_RX_CS0_DQS0 */ + 0x170 + 0xb, /* SKEW_UPDATE_RX_CS0_DQS1 */ + 0x1d0 + 0, /* SKEW_UPDATE_RX_CS0_DQS2 */ + 0x1d0 + 0xb, /* SKEW_UPDATE_RX_CS0_DQS3 */ + 0x1a0 + 0, /* SKEW_UPDATE_RX_CS1_DQS0 */ + 0x1a0 + 0xb, /* SKEW_UPDATE_RX_CS1_DQS1 */ + 0x200 + 0, /* SKEW_UPDATE_RX_CS1_DQS2 */ + 0x200 + 0xb, /* SKEW_UPDATE_RX_CS1_DQS3 */ + 0x170 + 0x16, /* SKEW_UPDATE_TX_CS0_DQS0 */ + 0x170 + 0x21, /* SKEW_UPDATE_TX_CS0_DQS1 */ + 0x1d0 + 0x16, /* SKEW_UPDATE_TX_CS0_DQS2 */ + 0x1d0 + 0x21, /* SKEW_UPDATE_TX_CS0_DQS3 */ + 0x1a0 + 0x16, /* SKEW_UPDATE_TX_CS1_DQS0 */ + 0x1a0 + 0x21, /* SKEW_UPDATE_TX_CS1_DQS1 */ + 0x200 + 0x16, /* SKEW_UPDATE_TX_CS1_DQS2 */ + 0x200 + 0x21, /* SKEW_UPDATE_TX_CS1_DQS3 */ +}; + +static void rkclk_ddr_reset(struct dram_info *dram, + u32 ctl_srstn, u32 ctl_psrstn, + u32 phy_srstn, u32 phy_psrstn) +{ + writel(UPCTL2_SRSTN_REQ(ctl_srstn) | UPCTL2_PSRSTN_REQ(ctl_psrstn) | + UPCTL2_ASRSTN_REQ(ctl_srstn), + BUS_SGRF_BASE_ADDR + SGRF_SOC_CON13); + + writel(DDRPHY_SRSTN_REQ(phy_srstn) | DDRPHY_PSRSTN_REQ(phy_psrstn), + &dram->cru->softrst_con[12]); +} + +static void rkclk_set_dpll(struct dram_info *dram, unsigned int hz) +{ + unsigned int refdiv, postdiv1, postdiv2, fbdiv; + int delay = 1000; + u32 mhz = hz / MHz; + struct global_info *gbl_info; + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + u32 ssmod_info; + u32 dsmpd = 1; + + gbl_info = (struct global_info *)((void *)common_info + + index->global_index.offset * 4); + ssmod_info = gbl_info->info_2t; + refdiv = 1; + if (mhz <= 100) { + postdiv1 = 6; + postdiv2 = 4; + } else if (mhz <= 150) { + postdiv1 = 4; + postdiv2 = 4; + } else if (mhz <= 200) { + postdiv1 = 6; + postdiv2 = 2; + } else if (mhz <= 300) { + postdiv1 = 4; + postdiv2 = 2; + } else if (mhz <= 400) { + postdiv1 = 6; + postdiv2 = 1; + } else { + postdiv1 = 4; + postdiv2 = 1; + } + fbdiv = (mhz * refdiv * postdiv1 * postdiv2) / 24; + + writel(DPLL_MODE(CLOCK_FROM_XIN_OSC), &dram->cru->mode); + + writel(0x1f000000, &dram->cru->clksel_con[64]); + writel(POSTDIV1(postdiv1) | FBDIV(fbdiv), &dram->cru->pll[1].con0); + /* enable ssmod */ + if (PLL_SSMOD_SPREAD(ssmod_info)) { + dsmpd = 0; + clrsetbits_le32(&dram->cru->pll[1].con2, + 0xffffff << 0, 0x0 << 0); + writel(SSMOD_SPREAD(PLL_SSMOD_SPREAD(ssmod_info)) | + SSMOD_DIVVAL(PLL_SSMOD_DIV(ssmod_info)) | + SSMOD_DOWNSPREAD(PLL_SSMOD_DOWNSPREAD(ssmod_info)) | + SSMOD_RESET(0) | + SSMOD_DIS_SSCG(0) | + SSMOD_BP(0), + &dram->cru->pll[1].con3); + } + writel(DSMPD(dsmpd) | POSTDIV2(postdiv2) | REFDIV(refdiv), + &dram->cru->pll[1].con1); + + while (delay > 0) { + udelay(1); + if (LOCK(readl(&dram->cru->pll[1].con1))) + break; + delay--; + } + + writel(DPLL_MODE(CLOCK_FROM_PLL), &dram->cru->mode); +} + +static void rkclk_configure_ddr(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + /* for inno ddr phy need freq / 2 */ + rkclk_set_dpll(dram, sdram_params->base.ddr_freq * MHZ / 2); +} + +static unsigned int + calculate_ddrconfig(struct rv1126_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 cs, bw, die_bw, col, row, bank; + u32 cs1_row; + u32 i, tmp; + u32 ddrconf = -1; + u32 row_3_4; + + cs = cap_info->rank; + bw = cap_info->bw; + die_bw = cap_info->dbw; + col = cap_info->col; + row = cap_info->cs0_row; + cs1_row = cap_info->cs1_row; + bank = cap_info->bk; + row_3_4 = cap_info->row_3_4; + + if (sdram_params->base.dramtype == DDR4) { + if (cs == 2 && row == cs1_row && !row_3_4) { + tmp = ((row - 13) << 4) | (1 << 3) | (bw << 1) | + die_bw; + for (i = 17; i < 21; i++) { + if (((tmp & 0xf) == + (ddr4_cfg_2_rbc[i - 10] & 0xf)) && + ((tmp & 0x70) <= + (ddr4_cfg_2_rbc[i - 10] & 0x70))) { + ddrconf = i; + goto out; + } + } + } + + tmp = ((cs - 1) << 7) | ((row - 13) << 4) | (bw << 1) | die_bw; + for (i = 10; i < 21; i++) { + if (((tmp & 0xf) == (ddr4_cfg_2_rbc[i - 10] & 0xf)) && + ((tmp & 0x70) <= (ddr4_cfg_2_rbc[i - 10] & 0x70)) && + ((tmp & 0x80) <= (ddr4_cfg_2_rbc[i - 10] & 0x80))) { + ddrconf = i; + goto out; + } + } + } else { + if (cs == 2 && row == cs1_row && bank == 3) { + for (i = 5; i < 8; i++) { + if (((bw + col - 10) == (ddr_cfg_2_rbc[i] & + 0x7)) && + ((row - 13) << 5) <= (ddr_cfg_2_rbc[i] & + (0x7 << 5))) { + ddrconf = i; + goto out; + } + } + } + + tmp = ((cs - 1) << 8) | ((row - 13) << 5) | + ((bw + col - 10) << 0); + if (bank == 3) + tmp |= (1 << 3); + + for (i = 0; i < 9; i++) + if (((tmp & 0x1f) == (ddr_cfg_2_rbc[i] & 0x1f)) && + ((tmp & (7 << 5)) <= + (ddr_cfg_2_rbc[i] & (7 << 5))) && + ((tmp & (1 << 8)) <= + (ddr_cfg_2_rbc[i] & (1 << 8)))) { + ddrconf = i; + goto out; + } + + for (i = 0; i < 7; i++) + if (((tmp & 0x1f) == (ddr_cfg_2_rbc_p2[i] & 0x1f)) && + ((tmp & (7 << 5)) <= + (ddr_cfg_2_rbc_p2[i] & (7 << 5))) && + ((tmp & (1 << 8)) <= + (ddr_cfg_2_rbc_p2[i] & (1 << 8)))) { + ddrconf = i + 22; + goto out; + } + + if (cs == 1 && bank == 3 && row <= 17 && + (col + bw) == 12) + ddrconf = 23; + } + +out: + if (ddrconf > 28) + printascii("calculate ddrconfig error\n"); + + if (sdram_params->base.dramtype == DDR4) { + for (i = 0; i < ARRAY_SIZE(d4_rbc_2_d3_rbc) ; i++) { + if (ddrconf == d4_rbc_2_d3_rbc[i][0]) { + if (ddrconf == 21 && row > 16) + printascii("warn:ddrconf21 row > 16\n"); + else + ddrconf = d4_rbc_2_d3_rbc[i][1]; + break; + } + } + } + + return ddrconf; +} + +static void sw_set_req(struct dram_info *dram) +{ + void __iomem *pctl_base = dram->pctl; + + /* clear sw_done=0 */ + writel(PCTL2_SW_DONE_CLEAR, pctl_base + DDR_PCTL2_SWCTL); +} + +static void sw_set_ack(struct dram_info *dram) +{ + void __iomem *pctl_base = dram->pctl; + + /* set sw_done=1 */ + writel(PCTL2_SW_DONE, pctl_base + DDR_PCTL2_SWCTL); + while (1) { + /* wait programming done */ + if (readl(pctl_base + DDR_PCTL2_SWSTAT) & + PCTL2_SW_DONE_ACK) + break; + } +} + +static void set_ctl_address_map(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + void __iomem *pctl_base = dram->pctl; + u32 ddrconf = cap_info->ddrconfig; + u32 i, row; + + row = cap_info->cs0_row; + if (sdram_params->base.dramtype == DDR4) { + for (i = 0; i < ARRAY_SIZE(d4_rbc_2_d3_rbc) ; i++) { + if (ddrconf == d4_rbc_2_d3_rbc[i][1]) { + ddrconf = d4_rbc_2_d3_rbc[i][0]; + break; + } + } + } + + if (ddrconf >= ARRAY_SIZE(addrmap)) { + printascii("set ctl address map fail\n"); + return; + } + + sdram_copy_to_reg((u32 *)(pctl_base + DDR_PCTL2_ADDRMAP0), + &addrmap[ddrconf][0], ARRAY_SIZE(addrmap[ddrconf]) * 4); + + /* unused row set to 0xf */ + for (i = 17; i >= row; i--) + setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6 + + ((i - 12) * 8 / 32) * 4, + 0xf << ((i - 12) * 8 % 32)); + + if (sdram_params->base.dramtype == LPDDR3 && cap_info->row_3_4) + setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6, 1 << 31); + if (sdram_params->base.dramtype == DDR4 && cap_info->bw == 0x1) + setbits_le32(pctl_base + DDR_PCTL2_PCCFG, 1 << 8); + + if (cap_info->rank == 1) + clrsetbits_le32(pctl_base + DDR_PCTL2_ADDRMAP0, 0x1f, 0x1f); +} + +static void phy_pll_set(struct dram_info *dram, u32 freq, u32 wait) +{ + void __iomem *phy_base = dram->phy; + u32 fbdiv, prediv, postdiv, postdiv_en; + + if (wait) { + clrbits_le32(PHY_REG(phy_base, 0x53), PHY_PD_DISB); + while (!(readl(PHY_REG(phy_base, 0x90)) & PHY_PLL_LOCK)) + continue; + } else { + freq /= MHz; + prediv = 1; + if (freq <= 200) { + fbdiv = 16; + postdiv = 2; + postdiv_en = 1; + } else if (freq <= 456) { + fbdiv = 8; + postdiv = 1; + postdiv_en = 1; + } else { + fbdiv = 4; + postdiv = 0; + postdiv_en = 0; + } + writel(fbdiv & 0xff, PHY_REG(phy_base, 0x50)); + clrsetbits_le32(PHY_REG(phy_base, 0x51), PHY_PBDIV_BIT9_MASK, + (fbdiv >> 8) & 1); + clrsetbits_le32(PHY_REG(phy_base, 0x51), PHY_POSTDIV_EN_MASK, + postdiv_en << PHY_POSTDIV_EN_SHIFT); + + clrsetbits_le32(PHY_REG(phy_base, 0x52), + PHY_PREDIV_MASK << PHY_PREDIV_SHIFT, prediv); + clrsetbits_le32(PHY_REG(phy_base, 0x53), + PHY_POSTDIV_MASK << PHY_POSTDIV_SHIFT, + postdiv << PHY_POSTDIV_SHIFT); + } +} + +static const u16 d3_phy_drv_2_ohm[][2] = { + {PHY_DDR3_RON_455ohm, 455}, + {PHY_DDR3_RON_230ohm, 230}, + {PHY_DDR3_RON_153ohm, 153}, + {PHY_DDR3_RON_115ohm, 115}, + {PHY_DDR3_RON_91ohm, 91}, + {PHY_DDR3_RON_76ohm, 76}, + {PHY_DDR3_RON_65ohm, 65}, + {PHY_DDR3_RON_57ohm, 57}, + {PHY_DDR3_RON_51ohm, 51}, + {PHY_DDR3_RON_46ohm, 46}, + {PHY_DDR3_RON_41ohm, 41}, + {PHY_DDR3_RON_38ohm, 38}, + {PHY_DDR3_RON_35ohm, 35}, + {PHY_DDR3_RON_32ohm, 32}, + {PHY_DDR3_RON_30ohm, 30}, + {PHY_DDR3_RON_28ohm, 28}, + {PHY_DDR3_RON_27ohm, 27}, + {PHY_DDR3_RON_25ohm, 25}, + {PHY_DDR3_RON_24ohm, 24}, + {PHY_DDR3_RON_23ohm, 23}, + {PHY_DDR3_RON_22ohm, 22}, + {PHY_DDR3_RON_21ohm, 21}, + {PHY_DDR3_RON_20ohm, 20} +}; + +static u16 d3_phy_odt_2_ohm[][2] = { + {PHY_DDR3_RTT_DISABLE, 0}, + {PHY_DDR3_RTT_561ohm, 561}, + {PHY_DDR3_RTT_282ohm, 282}, + {PHY_DDR3_RTT_188ohm, 188}, + {PHY_DDR3_RTT_141ohm, 141}, + {PHY_DDR3_RTT_113ohm, 113}, + {PHY_DDR3_RTT_94ohm, 94}, + {PHY_DDR3_RTT_81ohm, 81}, + {PHY_DDR3_RTT_72ohm, 72}, + {PHY_DDR3_RTT_64ohm, 64}, + {PHY_DDR3_RTT_58ohm, 58}, + {PHY_DDR3_RTT_52ohm, 52}, + {PHY_DDR3_RTT_48ohm, 48}, + {PHY_DDR3_RTT_44ohm, 44}, + {PHY_DDR3_RTT_41ohm, 41}, + {PHY_DDR3_RTT_38ohm, 38}, + {PHY_DDR3_RTT_37ohm, 37}, + {PHY_DDR3_RTT_34ohm, 34}, + {PHY_DDR3_RTT_32ohm, 32}, + {PHY_DDR3_RTT_31ohm, 31}, + {PHY_DDR3_RTT_29ohm, 29}, + {PHY_DDR3_RTT_28ohm, 28}, + {PHY_DDR3_RTT_27ohm, 27}, + {PHY_DDR3_RTT_25ohm, 25} +}; + +static u16 d4lp3_phy_drv_2_ohm[][2] = { + {PHY_DDR4_LPDDR3_RON_482ohm, 482}, + {PHY_DDR4_LPDDR3_RON_244ohm, 244}, + {PHY_DDR4_LPDDR3_RON_162ohm, 162}, + {PHY_DDR4_LPDDR3_RON_122ohm, 122}, + {PHY_DDR4_LPDDR3_RON_97ohm, 97}, + {PHY_DDR4_LPDDR3_RON_81ohm, 81}, + {PHY_DDR4_LPDDR3_RON_69ohm, 69}, + {PHY_DDR4_LPDDR3_RON_61ohm, 61}, + {PHY_DDR4_LPDDR3_RON_54ohm, 54}, + {PHY_DDR4_LPDDR3_RON_48ohm, 48}, + {PHY_DDR4_LPDDR3_RON_44ohm, 44}, + {PHY_DDR4_LPDDR3_RON_40ohm, 40}, + {PHY_DDR4_LPDDR3_RON_37ohm, 37}, + {PHY_DDR4_LPDDR3_RON_34ohm, 34}, + {PHY_DDR4_LPDDR3_RON_32ohm, 32}, + {PHY_DDR4_LPDDR3_RON_30ohm, 30}, + {PHY_DDR4_LPDDR3_RON_28ohm, 28}, + {PHY_DDR4_LPDDR3_RON_27ohm, 27}, + {PHY_DDR4_LPDDR3_RON_25ohm, 25}, + {PHY_DDR4_LPDDR3_RON_24ohm, 24}, + {PHY_DDR4_LPDDR3_RON_23ohm, 23}, + {PHY_DDR4_LPDDR3_RON_22ohm, 22}, + {PHY_DDR4_LPDDR3_RON_21ohm, 21} +}; + +static u16 d4lp3_phy_odt_2_ohm[][2] = { + {PHY_DDR4_LPDDR3_RTT_DISABLE, 0}, + {PHY_DDR4_LPDDR3_RTT_586ohm, 586}, + {PHY_DDR4_LPDDR3_RTT_294ohm, 294}, + {PHY_DDR4_LPDDR3_RTT_196ohm, 196}, + {PHY_DDR4_LPDDR3_RTT_148ohm, 148}, + {PHY_DDR4_LPDDR3_RTT_118ohm, 118}, + {PHY_DDR4_LPDDR3_RTT_99ohm, 99}, + {PHY_DDR4_LPDDR3_RTT_85ohm, 58}, + {PHY_DDR4_LPDDR3_RTT_76ohm, 76}, + {PHY_DDR4_LPDDR3_RTT_67ohm, 67}, + {PHY_DDR4_LPDDR3_RTT_60ohm, 60}, + {PHY_DDR4_LPDDR3_RTT_55ohm, 55}, + {PHY_DDR4_LPDDR3_RTT_50ohm, 50}, + {PHY_DDR4_LPDDR3_RTT_46ohm, 46}, + {PHY_DDR4_LPDDR3_RTT_43ohm, 43}, + {PHY_DDR4_LPDDR3_RTT_40ohm, 40}, + {PHY_DDR4_LPDDR3_RTT_38ohm, 38}, + {PHY_DDR4_LPDDR3_RTT_36ohm, 36}, + {PHY_DDR4_LPDDR3_RTT_34ohm, 34}, + {PHY_DDR4_LPDDR3_RTT_32ohm, 32}, + {PHY_DDR4_LPDDR3_RTT_31ohm, 31}, + {PHY_DDR4_LPDDR3_RTT_29ohm, 29}, + {PHY_DDR4_LPDDR3_RTT_28ohm, 28}, + {PHY_DDR4_LPDDR3_RTT_27ohm, 27} +}; + +static u16 lp4_phy_drv_2_ohm[][2] = { + {PHY_LPDDR4_RON_501ohm, 501}, + {PHY_LPDDR4_RON_253ohm, 253}, + {PHY_LPDDR4_RON_168ohm, 168}, + {PHY_LPDDR4_RON_126ohm, 126}, + {PHY_LPDDR4_RON_101ohm, 101}, + {PHY_LPDDR4_RON_84ohm, 84}, + {PHY_LPDDR4_RON_72ohm, 72}, + {PHY_LPDDR4_RON_63ohm, 63}, + {PHY_LPDDR4_RON_56ohm, 56}, + {PHY_LPDDR4_RON_50ohm, 50}, + {PHY_LPDDR4_RON_46ohm, 46}, + {PHY_LPDDR4_RON_42ohm, 42}, + {PHY_LPDDR4_RON_38ohm, 38}, + {PHY_LPDDR4_RON_36ohm, 36}, + {PHY_LPDDR4_RON_33ohm, 33}, + {PHY_LPDDR4_RON_31ohm, 31}, + {PHY_LPDDR4_RON_29ohm, 29}, + {PHY_LPDDR4_RON_28ohm, 28}, + {PHY_LPDDR4_RON_26ohm, 26}, + {PHY_LPDDR4_RON_25ohm, 25}, + {PHY_LPDDR4_RON_24ohm, 24}, + {PHY_LPDDR4_RON_23ohm, 23}, + {PHY_LPDDR4_RON_22ohm, 22} +}; + +static u16 lp4_phy_odt_2_ohm[][2] = { + {PHY_LPDDR4_RTT_DISABLE, 0}, + {PHY_LPDDR4_RTT_604ohm, 604}, + {PHY_LPDDR4_RTT_303ohm, 303}, + {PHY_LPDDR4_RTT_202ohm, 202}, + {PHY_LPDDR4_RTT_152ohm, 152}, + {PHY_LPDDR4_RTT_122ohm, 122}, + {PHY_LPDDR4_RTT_101ohm, 101}, + {PHY_LPDDR4_RTT_87ohm, 87}, + {PHY_LPDDR4_RTT_78ohm, 78}, + {PHY_LPDDR4_RTT_69ohm, 69}, + {PHY_LPDDR4_RTT_62ohm, 62}, + {PHY_LPDDR4_RTT_56ohm, 56}, + {PHY_LPDDR4_RTT_52ohm, 52}, + {PHY_LPDDR4_RTT_48ohm, 48}, + {PHY_LPDDR4_RTT_44ohm, 44}, + {PHY_LPDDR4_RTT_41ohm, 41}, + {PHY_LPDDR4_RTT_39ohm, 39}, + {PHY_LPDDR4_RTT_37ohm, 37}, + {PHY_LPDDR4_RTT_35ohm, 35}, + {PHY_LPDDR4_RTT_33ohm, 33}, + {PHY_LPDDR4_RTT_32ohm, 32}, + {PHY_LPDDR4_RTT_30ohm, 30}, + {PHY_LPDDR4_RTT_29ohm, 29}, + {PHY_LPDDR4_RTT_27ohm, 27} +}; + +static u32 lp4_odt_calc(u32 odt_ohm) +{ + u32 odt; + + if (odt_ohm == 0) + odt = LPDDR4_DQODT_DIS; + else if (odt_ohm <= 40) + odt = LPDDR4_DQODT_40; + else if (odt_ohm <= 48) + odt = LPDDR4_DQODT_48; + else if (odt_ohm <= 60) + odt = LPDDR4_DQODT_60; + else if (odt_ohm <= 80) + odt = LPDDR4_DQODT_80; + else if (odt_ohm <= 120) + odt = LPDDR4_DQODT_120; + else + odt = LPDDR4_DQODT_240; + + return odt; +} + +static void *get_ddr_drv_odt_info(u32 dramtype) +{ + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + void *ddr_info = 0; + + if (dramtype == DDR4) + ddr_info = (void *)common_info + index->ddr4_index.offset * 4; + else if (dramtype == DDR3) + ddr_info = (void *)common_info + index->ddr3_index.offset * 4; + else if (dramtype == LPDDR3) + ddr_info = (void *)common_info + index->lp3_index.offset * 4; + else if (dramtype == LPDDR4) + ddr_info = (void *)common_info + index->lp4_index.offset * 4; + else + printascii("unsupported dram type\n"); + return ddr_info; +} + +static void set_lp4_vref(struct dram_info *dram, struct lp4_info *lp4_info, + u32 freq_mhz, u32 dst_fsp, u32 dramtype) +{ + void __iomem *pctl_base = dram->pctl; + u32 ca_vref, dq_vref; + + if (freq_mhz <= LP4_CA_ODT_EN_FREQ(lp4_info->ca_odten_freq)) + ca_vref = LP4_CA_VREF(lp4_info->vref_when_odtoff); + else + ca_vref = LP4_CA_VREF(lp4_info->vref_when_odten); + + if (freq_mhz <= LP4_DQ_ODT_EN_FREQ(lp4_info->dq_odten_freq)) + dq_vref = LP4_DQ_VREF(lp4_info->vref_when_odtoff); + else + dq_vref = LP4_DQ_VREF(lp4_info->vref_when_odten); + + if (dramtype == LPDDR4) { + if (ca_vref < 100) + ca_vref = 100; + if (ca_vref > 420) + ca_vref = 420; + + if (ca_vref <= 300) + ca_vref = (0 << 6) | (ca_vref - 100) / 4; + else + ca_vref = (1 << 6) | (ca_vref - 220) / 4; + + if (dq_vref < 100) + dq_vref = 100; + if (dq_vref > 420) + dq_vref = 420; + + if (dq_vref <= 300) + dq_vref = (0 << 6) | (dq_vref - 100) / 4; + else + dq_vref = (1 << 6) | (dq_vref - 220) / 4; + } else { + ca_vref = ca_vref * 11 / 6; + if (ca_vref < 150) + ca_vref = 150; + if (ca_vref > 629) + ca_vref = 629; + + if (ca_vref <= 449) + ca_vref = (0 << 6) | (ca_vref - 150) / 4; + else + ca_vref = (1 << 6) | (ca_vref - 329) / 4; + + if (dq_vref < 150) + dq_vref = 150; + if (dq_vref > 629) + dq_vref = 629; + + if (dq_vref <= 449) + dq_vref = (0 << 6) | (dq_vref - 150) / 6; + else + dq_vref = (1 << 6) | (dq_vref - 329) / 6; + } + sw_set_req(dram); + clrsetbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT6, + PCTL2_MR_MASK << PCTL2_LPDDR4_MR12_SHIFT, + ca_vref << PCTL2_LPDDR4_MR12_SHIFT); + + clrsetbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT7, + PCTL2_MR_MASK << PCTL2_LPDDR4_MR14_SHIFT, + dq_vref << PCTL2_LPDDR4_MR14_SHIFT); + sw_set_ack(dram); +} + +static void set_ds_odt(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params, u32 dst_fsp) +{ + void __iomem *phy_base = dram->phy; + void __iomem *pctl_base = dram->pctl; + u32 dramtype = sdram_params->base.dramtype; + struct ddr2_3_4_lp2_3_info *ddr_info; + struct lp4_info *lp4_info; + u32 i, j, tmp; + const u16 (*p_drv)[2]; + const u16 (*p_odt)[2]; + u32 drv_info, sr_info; + u32 phy_dq_drv_ohm, phy_clk_drv_ohm, phy_ca_drv_ohm, dram_drv_ohm; + u32 phy_odt_ohm, dram_odt_ohm; + u32 lp4_pu_cal, phy_lp4_drv_pd_en; + u32 phy_odt_up_en, phy_odt_dn_en; + u32 sr_dq, sr_clk; + u32 freq = sdram_params->base.ddr_freq; + u32 mr1_mr3, mr11, mr22, vref_out, vref_inner; + u32 phy_clk_drv = 0, phy_odt = 0, phy_ca_drv = 0, dram_caodt_ohm = 0; + u32 phy_dq_drv = 0; + u32 phy_odt_up = 0, phy_odt_dn = 0; + + ddr_info = get_ddr_drv_odt_info(dramtype); + lp4_info = (void *)ddr_info; + + if (!ddr_info) + return; + + /* dram odt en freq control phy drv, dram odt and phy sr */ + if (freq <= DRAMODT_EN_FREQ(ddr_info->odten_freq)) { + drv_info = ddr_info->drv_when_odtoff; + dram_odt_ohm = 0; + sr_info = ddr_info->sr_when_odtoff; + phy_lp4_drv_pd_en = + PHY_LP4_DRV_PULLDOWN_EN_ODTOFF(lp4_info->odt_info); + } else { + drv_info = ddr_info->drv_when_odten; + dram_odt_ohm = ODT_INFO_DRAM_ODT(ddr_info->odt_info); + sr_info = ddr_info->sr_when_odten; + phy_lp4_drv_pd_en = + PHY_LP4_DRV_PULLDOWN_EN_ODTEN(lp4_info->odt_info); + } + phy_dq_drv_ohm = + DRV_INFO_PHY_DQ_DRV(drv_info); + phy_clk_drv_ohm = + DRV_INFO_PHY_CLK_DRV(drv_info); + phy_ca_drv_ohm = + DRV_INFO_PHY_CA_DRV(drv_info); + + sr_dq = DQ_SR_INFO(sr_info); + sr_clk = CLK_SR_INFO(sr_info); + + /* phy odt en freq control dram drv and phy odt */ + if (freq <= PHYODT_EN_FREQ(ddr_info->odten_freq)) { + dram_drv_ohm = DRV_INFO_DRAM_DQ_DRV(ddr_info->drv_when_odtoff); + lp4_pu_cal = LP4_DRV_PU_CAL_ODTOFF(lp4_info->odt_info); + phy_odt_ohm = 0; + phy_odt_up_en = 0; + phy_odt_dn_en = 0; + } else { + dram_drv_ohm = + DRV_INFO_DRAM_DQ_DRV(ddr_info->drv_when_odten); + phy_odt_ohm = ODT_INFO_PHY_ODT(ddr_info->odt_info); + phy_odt_up_en = + ODT_INFO_PULLUP_EN(ddr_info->odt_info); + phy_odt_dn_en = + ODT_INFO_PULLDOWN_EN(ddr_info->odt_info); + lp4_pu_cal = LP4_DRV_PU_CAL_ODTEN(lp4_info->odt_info); + } + + if (dramtype == LPDDR4) { + if (phy_odt_ohm) { + phy_odt_up_en = 0; + phy_odt_dn_en = 1; + } + if (freq <= LP4_CA_ODT_EN_FREQ(lp4_info->ca_odten_freq)) + dram_caodt_ohm = 0; + else + dram_caodt_ohm = + ODT_INFO_LP4_CA_ODT(lp4_info->odt_info); + } + + if (dramtype == DDR3) { + p_drv = d3_phy_drv_2_ohm; + p_odt = d3_phy_odt_2_ohm; + } else if (dramtype == LPDDR4) { + p_drv = lp4_phy_drv_2_ohm; + p_odt = lp4_phy_odt_2_ohm; + } else { + p_drv = d4lp3_phy_drv_2_ohm; + p_odt = d4lp3_phy_odt_2_ohm; + } + + for (i = ARRAY_SIZE(d3_phy_drv_2_ohm) - 1; ; i--) { + if (phy_dq_drv_ohm <= *(*(p_drv + i) + 1)) { + phy_dq_drv = **(p_drv + i); + break; + } + if (i == 0) + break; + } + for (i = ARRAY_SIZE(d3_phy_drv_2_ohm) - 1; ; i--) { + if (phy_clk_drv_ohm <= *(*(p_drv + i) + 1)) { + phy_clk_drv = **(p_drv + i); + break; + } + if (i == 0) + break; + } + for (i = ARRAY_SIZE(d3_phy_drv_2_ohm) - 1; ; i--) { + if (phy_ca_drv_ohm <= *(*(p_drv + i) + 1)) { + phy_ca_drv = **(p_drv + i); + break; + } + if (i == 0) + break; + } + if (!phy_odt_ohm) + phy_odt = 0; + else + for (i = ARRAY_SIZE(d4lp3_phy_odt_2_ohm) - 1; ; i--) { + if (phy_odt_ohm <= *(*(p_odt + i) + 1)) { + phy_odt = **(p_odt + i); + break; + } + if (i == 0) + break; + } + + if (dramtype != LPDDR4) { + if (!phy_odt_ohm || (phy_odt_up_en && phy_odt_dn_en)) + vref_inner = 0x80; + else if (phy_odt_up_en) + vref_inner = (2 * dram_drv_ohm + phy_odt_ohm) * 128 / + (dram_drv_ohm + phy_odt_ohm); + else + vref_inner = phy_odt_ohm * 128 / + (phy_odt_ohm + dram_drv_ohm); + + if (dramtype != DDR3 && dram_odt_ohm) + vref_out = (2 * phy_dq_drv_ohm + dram_odt_ohm) * 128 / + (phy_dq_drv_ohm + dram_odt_ohm); + else + vref_out = 0x80; + } else { + /* for lp4 and lp4x*/ + if (phy_odt_ohm) + vref_inner = + (PHY_LP4_DQ_VREF(lp4_info->vref_when_odten) * + 256) / 1000; + else + vref_inner = + (PHY_LP4_DQ_VREF(lp4_info->vref_when_odtoff) * + 256) / 1000; + + vref_out = 0x80; + } + + /* default ZQCALIB bypass mode */ + clrsetbits_le32(PHY_REG(phy_base, 0x100), 0x1f, phy_ca_drv); + clrsetbits_le32(PHY_REG(phy_base, 0x101), 0x1f, phy_ca_drv); + clrsetbits_le32(PHY_REG(phy_base, 0x102), 0x1f, phy_clk_drv); + clrsetbits_le32(PHY_REG(phy_base, 0x103), 0x1f, phy_clk_drv); + if (dramtype == LPDDR4) { + clrsetbits_le32(PHY_REG(phy_base, 0x107), 0x1f, phy_clk_drv); + clrsetbits_le32(PHY_REG(phy_base, 0x108), 0x1f, phy_clk_drv); + } else { + clrsetbits_le32(PHY_REG(phy_base, 0x107), 0x1f, phy_ca_drv); + clrsetbits_le32(PHY_REG(phy_base, 0x108), 0x1f, phy_ca_drv); + } + /* clk / cmd slew rate */ + clrsetbits_le32(PHY_REG(phy_base, 0x106), 0x1f, sr_clk); + + phy_lp4_drv_pd_en = (~phy_lp4_drv_pd_en) & 1; + if (phy_odt_up_en) + phy_odt_up = phy_odt; + if (phy_odt_dn_en) + phy_odt_dn = phy_odt; + + for (i = 0; i < 4; i++) { + j = 0x110 + i * 0x10; + clrsetbits_le32(PHY_REG(phy_base, j + 1), 0x1f, phy_odt_up); + clrsetbits_le32(PHY_REG(phy_base, j), 0x1f, phy_odt_dn); + clrsetbits_le32(PHY_REG(phy_base, j + 2), 0x1f, phy_dq_drv); + clrsetbits_le32(PHY_REG(phy_base, j + 3), 0x1f, phy_dq_drv); + writel(vref_inner, PHY_REG(phy_base, 0x118 + i * 0x10)); + + clrsetbits_le32(PHY_REG(phy_base, 0x114 + i * 0x10), + 1 << 3, phy_lp4_drv_pd_en << 3); + if (dramtype == LPDDR4) + clrbits_le32(PHY_REG(phy_base, 0x114 + i * 0x10), BIT(5)); + /* dq slew rate */ + clrsetbits_le32(PHY_REG(phy_base, 0x117 + i * 0x10), + 0x1f, sr_dq); + } + + /* reg_rx_vref_value_update */ + setbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + clrbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + + /* RAM VREF */ + writel(vref_out, PHY_REG(phy_base, 0x105)); + if (dramtype == LPDDR3) + udelay(100); + + if (dramtype == LPDDR4) + set_lp4_vref(dram, lp4_info, freq, dst_fsp, dramtype); + + if (dramtype == DDR3 || dramtype == DDR4) { + mr1_mr3 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT3); + mr1_mr3 = mr1_mr3 >> PCTL2_DDR34_MR1_SHIFT & PCTL2_MR_MASK; + } else { + mr1_mr3 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT4); + mr1_mr3 = mr1_mr3 >> PCTL2_LPDDR234_MR3_SHIFT & PCTL2_MR_MASK; + } + + if (dramtype == DDR3) { + mr1_mr3 &= ~(DDR3_DS_MASK | DDR3_RTT_NOM_MASK); + if (dram_drv_ohm == 34) + mr1_mr3 |= DDR3_DS_34; + + if (dram_odt_ohm == 0) + mr1_mr3 |= DDR3_RTT_NOM_DIS; + else if (dram_odt_ohm <= 40) + mr1_mr3 |= DDR3_RTT_NOM_40; + else if (dram_odt_ohm <= 60) + mr1_mr3 |= DDR3_RTT_NOM_60; + else + mr1_mr3 |= DDR3_RTT_NOM_120; + + } else if (dramtype == DDR4) { + mr1_mr3 &= ~(DDR4_DS_MASK | DDR4_RTT_NOM_MASK); + if (dram_drv_ohm == 48) + mr1_mr3 |= DDR4_DS_48; + + if (dram_odt_ohm == 0) + mr1_mr3 |= DDR4_RTT_NOM_DIS; + else if (dram_odt_ohm <= 34) + mr1_mr3 |= DDR4_RTT_NOM_34; + else if (dram_odt_ohm <= 40) + mr1_mr3 |= DDR4_RTT_NOM_40; + else if (dram_odt_ohm <= 48) + mr1_mr3 |= DDR4_RTT_NOM_48; + else if (dram_odt_ohm <= 60) + mr1_mr3 |= DDR4_RTT_NOM_60; + else + mr1_mr3 |= DDR4_RTT_NOM_120; + + } else if (dramtype == LPDDR3) { + if (dram_drv_ohm <= 34) + mr1_mr3 |= LPDDR3_DS_34; + else if (dram_drv_ohm <= 40) + mr1_mr3 |= LPDDR3_DS_40; + else if (dram_drv_ohm <= 48) + mr1_mr3 |= LPDDR3_DS_48; + else if (dram_drv_ohm <= 60) + mr1_mr3 |= LPDDR3_DS_60; + else if (dram_drv_ohm <= 80) + mr1_mr3 |= LPDDR3_DS_80; + + if (dram_odt_ohm == 0) + lp3_odt_value = LPDDR3_ODT_DIS; + else if (dram_odt_ohm <= 60) + lp3_odt_value = LPDDR3_ODT_60; + else if (dram_odt_ohm <= 120) + lp3_odt_value = LPDDR3_ODT_120; + else + lp3_odt_value = LPDDR3_ODT_240; + } else {/* for lpddr4 and lpddr4x */ + /* MR3 for lp4 PU-CAL and PDDS */ + mr1_mr3 &= ~(LPDDR4_PDDS_MASK | LPDDR4_PU_CAL_MASK); + mr1_mr3 |= lp4_pu_cal; + + tmp = lp4_odt_calc(dram_drv_ohm); + if (!tmp) + tmp = LPDDR4_PDDS_240; + mr1_mr3 |= (tmp << LPDDR4_PDDS_SHIFT); + + /* MR11 for lp4 ca odt, dq odt set */ + mr11 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT6); + mr11 = mr11 >> PCTL2_LPDDR4_MR11_SHIFT & PCTL2_MR_MASK; + + mr11 &= ~(LPDDR4_DQODT_MASK | LPDDR4_CAODT_MASK); + + tmp = lp4_odt_calc(dram_odt_ohm); + mr11 |= (tmp << LPDDR4_DQODT_SHIFT); + + tmp = lp4_odt_calc(dram_caodt_ohm); + mr11 |= (tmp << LPDDR4_CAODT_SHIFT); + sw_set_req(dram); + clrsetbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT6, + PCTL2_MR_MASK << PCTL2_LPDDR4_MR11_SHIFT, + mr11 << PCTL2_LPDDR4_MR11_SHIFT); + sw_set_ack(dram); + + /* MR22 for soc odt/odt-ck/odt-cs/odt-ca */ + mr22 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT7); + mr22 = mr22 >> PCTL2_LPDDR4_MR22_SHIFT & PCTL2_MR_MASK; + mr22 &= ~LPDDR4_SOC_ODT_MASK; + + tmp = lp4_odt_calc(phy_odt_ohm); + mr22 |= tmp; + mr22 = mr22 | + (LP4_ODTE_CK_EN(lp4_info->cs_drv_ca_odt_info) << + LPDDR4_ODTE_CK_SHIFT) | + (LP4_ODTE_CS_EN(lp4_info->cs_drv_ca_odt_info) << + LPDDR4_ODTE_CS_SHIFT) | + (LP4_ODTD_CA_EN(lp4_info->cs_drv_ca_odt_info) << + LPDDR4_ODTD_CA_SHIFT); + + sw_set_req(dram); + clrsetbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT7, + PCTL2_MR_MASK << PCTL2_LPDDR4_MR22_SHIFT, + mr22 << PCTL2_LPDDR4_MR22_SHIFT); + sw_set_ack(dram); + } + + if (dramtype == DDR4 || dramtype == DDR3) { + sw_set_req(dram); + clrsetbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT3, + PCTL2_MR_MASK << PCTL2_DDR34_MR1_SHIFT, + mr1_mr3 << PCTL2_DDR34_MR1_SHIFT); + sw_set_ack(dram); + } else { + sw_set_req(dram); + clrsetbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT4, + PCTL2_MR_MASK << PCTL2_LPDDR234_MR3_SHIFT, + mr1_mr3 << PCTL2_LPDDR234_MR3_SHIFT); + sw_set_ack(dram); + } +} + +static int sdram_cmd_dq_path_remap(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + void __iomem *phy_base = dram->phy; + u32 dramtype = sdram_params->base.dramtype; + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + struct dq_map_info *map_info; + + map_info = (struct dq_map_info *)((void *)common_info + + index->dq_map_index.offset * 4); + + if (dramtype <= LPDDR4) + writel((map_info->byte_map[dramtype / 4] >> + ((dramtype % 4) * 8)) & 0xff, + PHY_REG(phy_base, 0x4f)); + + return 0; +} + +static void phy_cfg(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + void __iomem *phy_base = dram->phy; + u32 i, dq_map, tmp; + u32 byte1 = 0, byte0 = 0; + + sdram_cmd_dq_path_remap(dram, sdram_params); + + phy_pll_set(dram, sdram_params->base.ddr_freq * MHZ, 0); + for (i = 0; sdram_params->phy_regs.phy[i][0] != 0xFFFFFFFF; i++) { + writel(sdram_params->phy_regs.phy[i][1], + phy_base + sdram_params->phy_regs.phy[i][0]); + } + + clrbits_le32(PHY_REG(phy_base, 0x62), BIT(5)); + dq_map = readl(PHY_REG(phy_base, 0x4f)); + for (i = 0; i < 4; i++) { + if (((dq_map >> (i * 2)) & 0x3) == 0) + byte0 = i; + if (((dq_map >> (i * 2)) & 0x3) == 1) + byte1 = i; + } + + tmp = readl(PHY_REG(phy_base, 0xf)) & (~PHY_DQ_WIDTH_MASK); + if (cap_info->bw == 2) + tmp |= 0xf; + else if (cap_info->bw == 1) + tmp |= ((1 << byte0) | (1 << byte1)); + else + tmp |= (1 << byte0); + + writel(tmp, PHY_REG(phy_base, 0xf)); + + /* lpddr4 odt control by phy, enable cs0 odt */ + if (sdram_params->base.dramtype == LPDDR4) + clrsetbits_le32(PHY_REG(phy_base, 0x20), 0x7 << 4, + (1 << 6) | (1 << 4)); + /* for ca training ca vref choose range1 */ + setbits_le32(PHY_REG(phy_base, 0x1e), BIT(6)); + setbits_le32(PHY_REG(phy_base, 0x1f), BIT(6)); + /* for wr training PHY_0x7c[5], choose range0 */ + clrbits_le32(PHY_REG(phy_base, 0x7c), BIT(5)); +} + +static int update_refresh_reg(struct dram_info *dram) +{ + void __iomem *pctl_base = dram->pctl; + u32 ret; + + ret = readl(pctl_base + DDR_PCTL2_RFSHCTL3) ^ (1 << 1); + writel(ret, pctl_base + DDR_PCTL2_RFSHCTL3); + + return 0; +} + +/* + * rank = 1: cs0 + * rank = 2: cs1 + */ +int read_mr(struct dram_info *dram, u32 rank, u32 mr_num, u32 dramtype) +{ + u32 ret; + u32 i, temp; + u32 dqmap; + + void __iomem *pctl_base = dram->pctl; + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + struct dq_map_info *map_info; + + map_info = (struct dq_map_info *)((void *)common_info + + index->dq_map_index.offset * 4); + + if (dramtype == LPDDR2) + dqmap = map_info->lp2_dq0_7_map; + else + dqmap = map_info->lp3_dq0_7_map; + + pctl_read_mr(pctl_base, rank, mr_num); + + ret = (readl(&dram->ddrgrf->ddr_grf_status[0]) & 0xff); + + if (dramtype != LPDDR4) { + temp = 0; + for (i = 0; i < 8; i++) { + temp = temp | (((ret >> i) & 0x1) << + ((dqmap >> (i * 4)) & 0xf)); + } + } else { + temp = (readl(&dram->ddrgrf->ddr_grf_status[1]) & 0xff); + } + + return temp; +} + +/* before call this function autorefresh should be disabled */ +void send_a_refresh(struct dram_info *dram) +{ + void __iomem *pctl_base = dram->pctl; + + while (readl(pctl_base + DDR_PCTL2_DBGSTAT) & 0x3) + continue; + writel(0x3, pctl_base + DDR_PCTL2_DBGCMD); +} + +static void enter_sr(struct dram_info *dram, u32 en) +{ + void __iomem *pctl_base = dram->pctl; + + if (en) { + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, PCTL2_SELFREF_SW); + while (1) { + if (((readl(pctl_base + DDR_PCTL2_STAT) & + PCTL2_SELFREF_TYPE_MASK) == + PCTL2_SELFREF_TYPE_SR_NOT_AUTO) && + ((readl(pctl_base + DDR_PCTL2_STAT) & + PCTL2_OPERATING_MODE_MASK) == + PCTL2_OPERATING_MODE_SR)) + break; + } + } else { + clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, PCTL2_SELFREF_SW); + while ((readl(pctl_base + DDR_PCTL2_STAT) & + PCTL2_OPERATING_MODE_MASK) == PCTL2_OPERATING_MODE_SR) + continue; + } +} + +void record_dq_prebit(struct dram_info *dram) +{ + u32 group, i, tmp; + void __iomem *phy_base = dram->phy; + + for (group = 0; group < 4; group++) { + for (i = 0; i < ARRAY_SIZE(dq_sel); i++) { + /* l_loop_invdelaysel */ + writel(dq_sel[i][0], PHY_REG(phy_base, + grp_addr[group] + 0x2c)); + tmp = readl(PHY_REG(phy_base, grp_addr[group] + 0x2e)); + writel(tmp, PHY_REG(phy_base, + grp_addr[group] + dq_sel[i][1])); + + /* r_loop_invdelaysel */ + writel(dq_sel[i][0], PHY_REG(phy_base, + grp_addr[group] + 0x2d)); + tmp = readl(PHY_REG(phy_base, grp_addr[group] + 0x2f)); + writel(tmp, PHY_REG(phy_base, + grp_addr[group] + dq_sel[i][2])); + } + } +} + +static void update_dq_rx_prebit(struct dram_info *dram) +{ + void __iomem *phy_base = dram->phy; + + clrsetbits_le32(PHY_REG(phy_base, 0x70), BIT(1) | BIT(6) | BIT(4), + BIT(4)); + udelay(1); + clrbits_le32(PHY_REG(phy_base, 0x70), BIT(4)); +} + +static void update_dq_tx_prebit(struct dram_info *dram) +{ + void __iomem *phy_base = dram->phy; + + clrbits_le32(PHY_REG(phy_base, 0x7a), BIT(1)); + setbits_le32(PHY_REG(phy_base, 0x2), BIT(3)); + setbits_le32(PHY_REG(phy_base, 0xc), BIT(6)); + udelay(1); + clrbits_le32(PHY_REG(phy_base, 0xc), BIT(6)); +} + +static void update_ca_prebit(struct dram_info *dram) +{ + void __iomem *phy_base = dram->phy; + + clrbits_le32(PHY_REG(phy_base, 0x25), BIT(2)); + setbits_le32(PHY_REG(phy_base, 0x22), BIT(6)); + udelay(1); + clrbits_le32(PHY_REG(phy_base, 0x22), BIT(6)); +} + +/* + * dir: 0: de-skew = delta_* + * 1: de-skew = reg val - delta_* + * delta_dir: value for differential signal: clk/ + * delta_sig: value for single signal: ca/cmd + */ +static void modify_ca_deskew(struct dram_info *dram, u32 dir, int delta_dif, + int delta_sig, u32 cs, u32 dramtype) +{ + void __iomem *phy_base = dram->phy; + u32 i, cs_en, tmp; + u32 dfi_lp_stat = 0; + + if (cs == 0) + cs_en = 1; + else if (cs == 2) + cs_en = 2; + else + cs_en = 3; + + if (dramtype == LPDDR4 && + ((readl(PHY_REG(phy_base, 0x60)) & BIT(5)) == 0)) { + dfi_lp_stat = 1; + setbits_le32(PHY_REG(phy_base, 0x60), BIT(5)); + } + enter_sr(dram, 1); + + for (i = 0; i < 0x20; i++) { + if (dir == DESKEW_MDF_ABS_VAL) + tmp = delta_sig; + else + tmp = readl(PHY_REG(phy_base, 0x150 + i)) + + delta_sig; + writel(tmp, PHY_REG(phy_base, 0x150 + i)); + } + + if (dir == DESKEW_MDF_ABS_VAL) + tmp = delta_dif; + else + tmp = readl(PHY_REG(phy_base, 0x150 + 0x17)) - + delta_sig + delta_dif; + writel(tmp, PHY_REG(phy_base, 0x150 + 0x17)); + writel(tmp, PHY_REG(phy_base, 0x150 + 0x18)); + if (dramtype == LPDDR4) { + writel(tmp, PHY_REG(phy_base, 0x150 + 0x4)); + writel(tmp, PHY_REG(phy_base, 0x150 + 0xa)); + + clrbits_le32(PHY_REG(phy_base, 0x10), cs_en << 6); + update_ca_prebit(dram); + } + enter_sr(dram, 0); + + if (dfi_lp_stat) + clrbits_le32(PHY_REG(phy_base, 0x60), BIT(5)); +} + +static u32 get_min_value(struct dram_info *dram, u32 signal, u32 rank) +{ + u32 i, j, offset = 0; + u32 min = 0x3f; + void __iomem *phy_base = dram->phy; + u32 byte_en; + + if (signal == SKEW_TX_SIGNAL) + offset = 8; + + if (signal == SKEW_CA_SIGNAL) { + for (i = 0; i < 0x20; i++) + min = MIN(min, readl(PHY_REG(phy_base, 0x150 + i))); + } else { + byte_en = readl(PHY_REG(phy_base, 0xf)) & 0xf; + for (j = offset; j < offset + rank * 4; j++) { + if (!((byte_en >> (j % 4)) & 1)) + continue; + for (i = 0; i < 11; i++) + min = MIN(min, + readl(PHY_REG(phy_base, + dqs_dq_skew_adr[j] + + i))); + } + } + + return min; +} + +static u32 low_power_update(struct dram_info *dram, u32 en) +{ + void __iomem *pctl_base = dram->pctl; + u32 lp_stat = 0; + + if (en) { + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, en & 0xf); + } else { + lp_stat = readl(pctl_base + DDR_PCTL2_PWRCTL) & 0xf; + clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 0xf); + } + + return lp_stat; +} + +/* + * signal: + * dir: 0: de-skew = delta_* + * 1: de-skew = reg val - delta_* + * delta_dir: value for differential signal: dqs + * delta_sig: value for single signal: dq/dm + */ +static void modify_dq_deskew(struct dram_info *dram, u32 signal, u32 dir, + int delta_dif, int delta_sig, u32 rank) +{ + void __iomem *phy_base = dram->phy; + u32 i, j, tmp, offset; + u32 byte_en; + + byte_en = readl(PHY_REG(phy_base, 0xf)) & 0xf; + + if (signal == SKEW_RX_SIGNAL) + offset = 0; + else + offset = 8; + + for (j = offset; j < (offset + rank * 4); j++) { + if (!((byte_en >> (j % 4)) & 1)) + continue; + for (i = 0; i < 0x9; i++) { + if (dir == DESKEW_MDF_ABS_VAL) + tmp = delta_sig; + else + tmp = delta_sig + readl(PHY_REG(phy_base, + dqs_dq_skew_adr[j] + + i)); + writel(tmp, PHY_REG(phy_base, dqs_dq_skew_adr[j] + i)); + } + if (dir == DESKEW_MDF_ABS_VAL) + tmp = delta_dif; + else + tmp = delta_dif + readl(PHY_REG(phy_base, + dqs_dq_skew_adr[j] + 9)); + writel(tmp, PHY_REG(phy_base, dqs_dq_skew_adr[j] + 9)); + writel(tmp, PHY_REG(phy_base, dqs_dq_skew_adr[j] + 0xa)); + } + if (signal == SKEW_RX_SIGNAL) + update_dq_rx_prebit(dram); + else + update_dq_tx_prebit(dram); +} + +static int data_training_rg(struct dram_info *dram, u32 cs, u32 dramtype) +{ + void __iomem *phy_base = dram->phy; + u32 ret; + u32 dis_auto_zq = 0; + u32 odt_val_up, odt_val_dn; + u32 i, j; + + odt_val_dn = readl(PHY_REG(phy_base, 0x110)); + odt_val_up = readl(PHY_REG(phy_base, 0x111)); + + if (dramtype != LPDDR4) { + for (i = 0; i < 4; i++) { + j = 0x110 + i * 0x10; + writel(PHY_DDR4_LPDDR3_RTT_294ohm, + PHY_REG(phy_base, j)); + writel(PHY_DDR4_LPDDR3_RTT_DISABLE, + PHY_REG(phy_base, j + 0x1)); + } + } + dis_auto_zq = pctl_dis_zqcs_aref(dram->pctl); + /* use normal read mode for data training */ + clrbits_le32(PHY_REG(phy_base, 0xc), BIT(1)); + + if (dramtype == DDR4) + setbits_le32(PHY_REG(phy_base, 0xc), BIT(1)); + + /* choose training cs */ + clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs)); + /* enable gate training */ + clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 1); + udelay(50); + ret = readl(PHY_REG(phy_base, 0x91)); + /* disable gate training */ + clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 0); + clrbits_le32(PHY_REG(phy_base, 2), 0x30); + pctl_rest_zqcs_aref(dram->pctl, dis_auto_zq); + + ret = (ret & 0x2f) ^ (readl(PHY_REG(phy_base, 0xf)) & 0xf); + + if (dramtype != LPDDR4) { + for (i = 0; i < 4; i++) { + j = 0x110 + i * 0x10; + writel(odt_val_dn, PHY_REG(phy_base, j)); + writel(odt_val_up, PHY_REG(phy_base, j + 0x1)); + } + } + return ret; +} + +static int data_training_wl(struct dram_info *dram, u32 cs, u32 dramtype, + u32 rank) +{ + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + u32 dis_auto_zq = 0; + u32 tmp; + u32 cur_fsp; + u32 timeout_us = 1000; + + dis_auto_zq = pctl_dis_zqcs_aref(dram->pctl); + + clrbits_le32(PHY_REG(phy_base, 0x7a), 0x1); + + cur_fsp = readl(pctl_base + DDR_PCTL2_MSTR2) & 0x3; + tmp = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + DDR_PCTL2_INIT3) & + 0xffff; + writel(tmp & 0xff, PHY_REG(phy_base, 0x3)); + + /* disable another cs's output */ + if ((dramtype == DDR3 || dramtype == DDR4) && rank == 2) + pctl_write_mr(dram->pctl, (cs + 1) & 1, 1, tmp | (1 << 12), + dramtype); + if (dramtype == DDR3 || dramtype == DDR4) + writel(0x40 | ((tmp >> 8) & 0x3f), PHY_REG(phy_base, 0x4)); + else + writel(0x80 | ((tmp >> 8) & 0x3f), PHY_REG(phy_base, 0x4)); + + /* choose cs */ + clrsetbits_le32(PHY_REG(phy_base, 2), (0x3 << 6) | (0x3 << 2), + ((0x2 >> cs) << 6) | (0 << 2)); + /* enable write leveling */ + clrsetbits_le32(PHY_REG(phy_base, 2), (0x3 << 6) | (0x3 << 2), + ((0x2 >> cs) << 6) | (1 << 2)); + + while (1) { + if ((readl(PHY_REG(phy_base, 0x92)) & 0xf) == + (readl(PHY_REG(phy_base, 0xf)) & 0xf)) + break; + + udelay(1); + if (timeout_us-- == 0) { + printascii("error: write leveling timeout\n"); + while (1) + ; + } + } + + /* disable write leveling */ + clrsetbits_le32(PHY_REG(phy_base, 2), (0x3 << 6) | (0x3 << 2), + ((0x2 >> cs) << 6) | (0 << 2)); + clrsetbits_le32(PHY_REG(phy_base, 2), 0x3 << 6, 0 << 6); + + /* enable another cs's output */ + if ((dramtype == DDR3 || dramtype == DDR4) && rank == 2) + pctl_write_mr(dram->pctl, (cs + 1) & 1, 1, tmp & ~(1 << 12), + dramtype); + + pctl_rest_zqcs_aref(dram->pctl, dis_auto_zq); + + return 0; +} + +char pattern[32] = { + 0xaa, 0x55, 0xaa, 0x55, 0x55, 0xaa, 0x55, 0xaa, + 0x55, 0xaa, 0x55, 0xaa, 0xaa, 0x55, 0xaa, 0x55, + 0x55, 0x55, 0xaa, 0xaa, 0xaa, 0xaa, 0x55, 0x55, + 0xaa, 0xaa, 0x55, 0x55, 0x55, 0x55, 0xaa, 0xaa +}; + +static int data_training_rd(struct dram_info *dram, u32 cs, u32 dramtype, + u32 mhz) +{ + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + u32 trefi_1x, trfc_1x; + u32 dis_auto_zq = 0; + u32 timeout_us = 1000; + u32 dqs_default; + u32 cur_fsp; + u32 vref_inner; + u32 i; + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + struct dq_map_info *map_info; + + vref_inner = readl(PHY_REG(phy_base, 0x128)) & 0xff; + if (dramtype == DDR3 && vref_inner == 0x80) { + for (i = 0; i < 4; i++) + writel(vref_inner - 0xa, + PHY_REG(phy_base, 0x118 + i * 0x10)); + + /* reg_rx_vref_value_update */ + setbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + clrbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + } + + map_info = (struct dq_map_info *)((void *)common_info + + index->dq_map_index.offset * 4); + /* only 1cs a time, 0:cs0 1 cs1 */ + if (cs > 1) + return -1; + + dqs_default = 0xf; + dis_auto_zq = pctl_dis_zqcs_aref(dram->pctl); + + cur_fsp = readl(pctl_base + DDR_PCTL2_MSTR2) & 0x3; + /* config refresh timing */ + trefi_1x = ((readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + + DDR_PCTL2_RFSHTMG) >> 16) & 0xfff) * 32; + trfc_1x = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + + DDR_PCTL2_RFSHTMG) & 0x3ff; + /* reg_phy_trefi[7:0] and reg_phy_trefi[13:8] */ + clrsetbits_le32(PHY_REG(phy_base, 0x6e), 0xff, trefi_1x & 0xff); + clrsetbits_le32(PHY_REG(phy_base, 0x6f), 0x3f, (trefi_1x >> 8) & 0x3f); + /* reg_phy_trfc */ + clrsetbits_le32(PHY_REG(phy_base, 0x57), 0xff, trfc_1x); + /* reg_max_refi_cnt */ + clrsetbits_le32(PHY_REG(phy_base, 0x61), 0xf << 4, 0x8 << 4); + + /* choose training cs */ + clrsetbits_le32(PHY_REG(phy_base, 0x71), 0x3 << 6, (0x2 >> cs) << 6); + + /* set dq map for ddr4 */ + if (dramtype == DDR4) { + setbits_le32(PHY_REG(phy_base, 0x70), BIT(7)); + for (i = 0; i < 4; i++) { + writel((map_info->ddr4_dq_map[cs * 2] >> + ((i % 4) * 8)) & 0xff, + PHY_REG(phy_base, 0x238 + i)); + writel((map_info->ddr4_dq_map[cs * 2 + 1] >> + ((i % 4) * 8)) & 0xff, + PHY_REG(phy_base, 0x2b8 + i)); + } + } + + /* cha_l reg_l_rd_train_dqs_default[5:0] */ + clrsetbits_le32(PHY_REG(phy_base, 0x230), 0x3f, dqs_default); + /* cha_h reg_h_rd_train_dqs_default[5:0] */ + clrsetbits_le32(PHY_REG(phy_base, 0x234), 0x3f, dqs_default); + /* chb_l reg_l_rd_train_dqs_default[5:0] */ + clrsetbits_le32(PHY_REG(phy_base, 0x2b0), 0x3f, dqs_default); + /* chb_h reg_h_rd_train_dqs_default[5:0] */ + clrsetbits_le32(PHY_REG(phy_base, 0x2b4), 0x3f, dqs_default); + + /* Choose the read train auto mode */ + clrsetbits_le32(PHY_REG(phy_base, 0x70), 0x3, 0x1); + /* Enable the auto train of the read train */ + clrsetbits_le32(PHY_REG(phy_base, 0x70), 0x3, 0x3); + + /* Wait the train done. */ + while (1) { + if ((readl(PHY_REG(phy_base, 0x93)) >> 7) & 0x1) + break; + + udelay(1); + if (timeout_us-- == 0) { + printascii("error: read training timeout\n"); + return -1; + } + } + + /* Check the read train state */ + if ((readl(PHY_REG(phy_base, 0x240)) & 0x3) || + (readl(PHY_REG(phy_base, 0x2c0)) & 0x3)) { + printascii("error: read training error\n"); + return -1; + } + + /* Exit the Read Training by setting */ + clrbits_le32(PHY_REG(phy_base, 0x70), BIT(1)); + + pctl_rest_zqcs_aref(dram->pctl, dis_auto_zq); + + if (dramtype == DDR3 && vref_inner == 0x80) { + for (i = 0; i < 4; i++) + writel(vref_inner, + PHY_REG(phy_base, 0x118 + i * 0x10)); + + /* reg_rx_vref_value_update */ + setbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + clrbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + } + + return 0; +} + +static int data_training_wr(struct dram_info *dram, u32 cs, u32 dramtype, + u32 mhz, u32 dst_fsp) +{ + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + u32 trefi_1x, trfc_1x; + u32 dis_auto_zq = 0; + u32 timeout_us = 1000; + u32 cur_fsp; + u32 mr_tmp, cl, cwl, phy_fsp, offset = 0; + + if (dramtype == LPDDR3 && mhz <= 400) { + phy_fsp = (readl(PHY_REG(phy_base, 0xc)) >> 0x2) & 0x3; + offset = (phy_fsp == 0) ? 0x5 : 0x387 + (phy_fsp - 1) * 3; + cl = readl(PHY_REG(phy_base, offset)); + cwl = readl(PHY_REG(phy_base, offset + 2)); + + clrsetbits_le32(PHY_REG(phy_base, offset), 0x1f, 0x8); + clrsetbits_le32(PHY_REG(phy_base, offset + 2), 0x1f, 0x4); + pctl_write_mr(dram->pctl, 3, 2, 0x6, dramtype); + } + + dis_auto_zq = pctl_dis_zqcs_aref(dram->pctl); + + /* PHY_0x7b[7:0] reg_train_col_addr[7:0] */ + clrsetbits_le32(PHY_REG(phy_base, 0x7b), 0xff, 0x0); + /* PHY_0x7c[4:2] reg_train_ba_addr[2:0] */ + clrsetbits_le32(PHY_REG(phy_base, 0x7c), 0x7 << 2, 0x0 << 2); + /* PHY_0x7c[1:0] reg_train_col_addr[9:8] */ + clrsetbits_le32(PHY_REG(phy_base, 0x7c), 0x3, 0x0); + /* PHY_0x7d[7:0] reg_train_row_addr[7:0] */ + clrsetbits_le32(PHY_REG(phy_base, 0x7d), 0xff, 0x0); + /* PHY_0x7e[7:0] reg_train_row_addr[15:8] */ + clrsetbits_le32(PHY_REG(phy_base, 0x7e), 0xff, 0x0); + + /* PHY_0x71[3] wrtrain_check_data_value_random_gen */ + clrbits_le32(PHY_REG(phy_base, 0x71), BIT(3)); + + /* config refresh timing */ + cur_fsp = readl(pctl_base + DDR_PCTL2_MSTR2) & 0x3; + trefi_1x = ((readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + + DDR_PCTL2_RFSHTMG) >> 16) & 0xfff) * 32; + trfc_1x = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + + DDR_PCTL2_RFSHTMG) & 0x3ff; + /* reg_phy_trefi[7:0] and reg_phy_trefi[13:8] */ + clrsetbits_le32(PHY_REG(phy_base, 0x6e), 0xff, trefi_1x & 0xff); + clrsetbits_le32(PHY_REG(phy_base, 0x6f), 0x3f, (trefi_1x >> 8) & 0x3f); + /* reg_phy_trfc */ + clrsetbits_le32(PHY_REG(phy_base, 0x57), 0xff, trfc_1x); + /* reg_max_refi_cnt */ + clrsetbits_le32(PHY_REG(phy_base, 0x61), 0xf << 4, 0x8 << 4); + + /* choose training cs */ + clrsetbits_le32(PHY_REG(phy_base, 0x7c), 0x3 << 6, (0x2 >> cs) << 6); + + /* PHY_0x7a [4] reg_wr_train_dqs_default_bypass */ + /* 0: Use the write-leveling value. */ + /* 1: use reg0x233 0x237 0x2b3 0x2b7 */ + setbits_le32(PHY_REG(phy_base, 0x7a), BIT(4)); + + /* PHY_0x7a [0] reg_dq_wr_train_auto */ + setbits_le32(PHY_REG(phy_base, 0x7a), 0x1); + + /* PHY_0x7a [1] reg_dq_wr_train_en */ + setbits_le32(PHY_REG(phy_base, 0x7a), BIT(1)); + + send_a_refresh(dram); + + while (1) { + if ((readl(PHY_REG(phy_base, 0x92)) >> 7) & 0x1) + break; + + udelay(1); + if (timeout_us-- == 0) { + printascii("error: write training timeout\n"); + while (1) + ; + } + } + + /* Check the write train state */ + if ((readl(PHY_REG(phy_base, 0x90)) >> 5) & 0x7) { + printascii("error: write training error\n"); + return -1; + } + + /* PHY_0x7a [1] reg_dq_wr_train_en */ + clrbits_le32(PHY_REG(phy_base, 0x7a), BIT(1)); + + pctl_rest_zqcs_aref(dram->pctl, dis_auto_zq); + + /* save LPDDR4 write vref to fsp_param for dfs */ + if (dramtype == LPDDR4) { + fsp_param[dst_fsp].vref_dq[cs] = + ((readl(PHY_REG(phy_base, 0x384)) & 0x3f) + + (readl(PHY_REG(phy_base, 0x385)) & 0x3f)) / 2; + /* add range info */ + fsp_param[dst_fsp].vref_dq[cs] |= + ((readl(PHY_REG(phy_base, 0x7c)) & BIT(5)) << 1); + } + + if (dramtype == LPDDR3 && mhz <= 400) { + clrsetbits_le32(PHY_REG(phy_base, offset), 0x1f, cl); + clrsetbits_le32(PHY_REG(phy_base, offset + 2), 0x1f, cwl); + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + + DDR_PCTL2_INIT3); + pctl_write_mr(dram->pctl, 3, 2, mr_tmp & PCTL2_MR_MASK, + dramtype); + } + + return 0; +} + +static int data_training(struct dram_info *dram, u32 cs, + struct rv1126_sdram_params *sdram_params, u32 dst_fsp, + u32 training_flag) +{ + u32 ret = 0; + + if (training_flag == FULL_TRAINING) + training_flag = READ_GATE_TRAINING | WRITE_LEVELING | + WRITE_TRAINING | READ_TRAINING; + + if ((training_flag & WRITE_LEVELING) == WRITE_LEVELING) { + ret = data_training_wl(dram, cs, + sdram_params->base.dramtype, + sdram_params->ch.cap_info.rank); + if (ret != 0) + goto out; + } + + if ((training_flag & READ_GATE_TRAINING) == READ_GATE_TRAINING) { + ret = data_training_rg(dram, cs, + sdram_params->base.dramtype); + if (ret != 0) + goto out; + } + + if ((training_flag & READ_TRAINING) == READ_TRAINING) { + ret = data_training_rd(dram, cs, + sdram_params->base.dramtype, + sdram_params->base.ddr_freq); + if (ret != 0) + goto out; + } + + if ((training_flag & WRITE_TRAINING) == WRITE_TRAINING) { + ret = data_training_wr(dram, cs, + sdram_params->base.dramtype, + sdram_params->base.ddr_freq, dst_fsp); + if (ret != 0) + goto out; + } + +out: + return ret; +} + +static int get_wrlvl_val(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + int i, j, clk_skew; + void __iomem *phy_base = dram->phy; + u32 lp_stat; + int ret; + + lp_stat = low_power_update(dram, 0); + + clk_skew = 0x1f; + modify_ca_deskew(dram, DESKEW_MDF_ABS_VAL, clk_skew, clk_skew, 3, + sdram_params->base.dramtype); + + ret = data_training(dram, 0, sdram_params, 0, WRITE_LEVELING); + if (sdram_params->ch.cap_info.rank == 2) + ret |= data_training(dram, 1, sdram_params, 0, WRITE_LEVELING); + + for (j = 0; j < 2; j++) + for (i = 0; i < 4; i++) + wrlvl_result[j][i] = + (readl(PHY_REG(phy_base, wrlvl_result_offset[j][i])) & 0x3f) - + clk_skew; + + low_power_update(dram, lp_stat); + + return ret; +} + +#if defined(CONFIG_CMD_DDR_TEST_TOOL) +static void init_rw_trn_result_struct(struct rw_trn_result *result, + void __iomem *phy_base, u8 cs_num) +{ + int i; + + result->cs_num = cs_num; + result->byte_en = readb(PHY_REG(dram_info.phy, 0xf)) & + PHY_DQ_WIDTH_MASK; + for (i = 0; i < FSP_NUM; i++) + result->fsp_mhz[i] = 0; +} + +static void save_rw_trn_min_max(void __iomem *phy_base, + struct cs_rw_trn_result *rd_result, + struct cs_rw_trn_result *wr_result, + u8 byte_en) +{ + u16 phy_ofs; + u8 dqs; + u8 dq; + + for (dqs = 0; dqs < BYTE_NUM; dqs++) { + if ((byte_en & BIT(dqs)) == 0) + continue; + + /* Channel A or B (low or high 16 bit) */ + phy_ofs = dqs < 2 ? 0x230 : 0x2b0; + /* low or high 8 bit */ + phy_ofs += (dqs & 0x1) == 0 ? 0 : 0x9; + for (dq = 0; dq < 8; dq++) { + rd_result->dqs[dqs].dq_min[dq] = + readb(PHY_REG(phy_base, phy_ofs + 0x15 + dq)); + rd_result->dqs[dqs].dq_max[dq] = + readb(PHY_REG(phy_base, phy_ofs + 0x27 + dq)); + wr_result->dqs[dqs].dq_min[dq] = + readb(PHY_REG(phy_base, phy_ofs + 0x3d + dq)); + wr_result->dqs[dqs].dq_max[dq] = + readb(PHY_REG(phy_base, phy_ofs + 0x4f + dq)); + } + } +} + +static void save_rw_trn_deskew(void __iomem *phy_base, + struct fsp_rw_trn_result *result, u8 cs_num, + int min_val, bool rw) +{ + u16 phy_ofs; + u8 cs; + u8 dq; + + result->min_val = min_val; + + for (cs = 0; cs < cs_num; cs++) { + phy_ofs = cs == 0 ? 0x170 : 0x1a0; + phy_ofs += rw == SKEW_RX_SIGNAL ? 0x1 : 0x17; + for (dq = 0; dq < 8; dq++) { + result->cs[cs].dqs[0].dq_deskew[dq] = + readb(PHY_REG(phy_base, phy_ofs + dq)); + result->cs[cs].dqs[1].dq_deskew[dq] = + readb(PHY_REG(phy_base, phy_ofs + 0xb + dq)); + result->cs[cs].dqs[2].dq_deskew[dq] = + readb(PHY_REG(phy_base, phy_ofs + 0x60 + dq)); + result->cs[cs].dqs[3].dq_deskew[dq] = + readb(PHY_REG(phy_base, phy_ofs + 0x60 + 0xb + dq)); + } + + result->cs[cs].dqs[0].dqs_deskew = + readb(PHY_REG(phy_base, phy_ofs + 0x8)); + result->cs[cs].dqs[1].dqs_deskew = + readb(PHY_REG(phy_base, phy_ofs + 0xb + 0x8)); + result->cs[cs].dqs[2].dqs_deskew = + readb(PHY_REG(phy_base, phy_ofs + 0x60 + 0x8)); + result->cs[cs].dqs[3].dqs_deskew = + readb(PHY_REG(phy_base, phy_ofs + 0x60 + 0xb + 0x8)); + } +} + +static void save_rw_trn_result_to_ddr(struct rw_trn_result *result) +{ + result->flag = DDR_DQ_EYE_FLAG; + memcpy((void *)(RW_TRN_RESULT_ADDR), result, sizeof(*result)); +} +#endif + +static int high_freq_training(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params, + u32 fsp) +{ + u32 i, j; + void __iomem *phy_base = dram->phy; + u32 dramtype = sdram_params->base.dramtype; + int min_val; + int dqs_skew, clk_skew, ca_skew; + u8 byte_en; + int ret; + + byte_en = readl(PHY_REG(phy_base, 0xf)) & PHY_DQ_WIDTH_MASK; + dqs_skew = 0; + for (j = 0; j < sdram_params->ch.cap_info.rank; j++) { + for (i = 0; i < ARRAY_SIZE(wrlvl_result[0]); i++) { + if ((byte_en & BIT(i)) != 0) + dqs_skew += wrlvl_result[j][i]; + } + } + dqs_skew = dqs_skew / + (int)(sdram_params->ch.cap_info.rank * (1 << sdram_params->ch.cap_info.bw)); + + clk_skew = 0x20 - dqs_skew; + dqs_skew = 0x20; + + if (dramtype == LPDDR4) { + min_val = 0xff; + for (j = 0; j < sdram_params->ch.cap_info.rank; j++) + for (i = 0; i < sdram_params->ch.cap_info.bw; i++) + min_val = MIN(wrlvl_result[j][i], min_val); + + if (min_val < 0) { + clk_skew = -min_val; + ca_skew = -min_val; + } else { + clk_skew = 0; + ca_skew = 0; + } + } else if (dramtype == LPDDR3) { + ca_skew = clk_skew - 4; + } else { + ca_skew = clk_skew; + } + modify_ca_deskew(dram, DESKEW_MDF_ABS_VAL, clk_skew, ca_skew, 3, + dramtype); + + writel(wrlvl_result[0][0] + clk_skew, PHY_REG(phy_base, 0x233)); + writel(wrlvl_result[0][1] + clk_skew, PHY_REG(phy_base, 0x237)); + writel(wrlvl_result[0][2] + clk_skew, PHY_REG(phy_base, 0x2b3)); + writel(wrlvl_result[0][3] + clk_skew, PHY_REG(phy_base, 0x2b7)); + ret = data_training(dram, 0, sdram_params, fsp, READ_GATE_TRAINING | + READ_TRAINING | WRITE_TRAINING); +#if defined(CONFIG_CMD_DDR_TEST_TOOL) + rw_trn_result.fsp_mhz[fsp] = (u16)sdram_params->base.ddr_freq; + save_rw_trn_min_max(phy_base, &rw_trn_result.rd_fsp[fsp].cs[0], + &rw_trn_result.wr_fsp[fsp].cs[0], + rw_trn_result.byte_en); +#endif + if (sdram_params->ch.cap_info.rank == 2) { + writel(wrlvl_result[1][0] + clk_skew, PHY_REG(phy_base, 0x233)); + writel(wrlvl_result[1][1] + clk_skew, PHY_REG(phy_base, 0x237)); + writel(wrlvl_result[1][2] + clk_skew, PHY_REG(phy_base, 0x2b3)); + writel(wrlvl_result[1][3] + clk_skew, PHY_REG(phy_base, 0x2b7)); + ret |= data_training(dram, 1, sdram_params, fsp, + READ_GATE_TRAINING | READ_TRAINING | + WRITE_TRAINING); +#if defined(CONFIG_CMD_DDR_TEST_TOOL) + save_rw_trn_min_max(phy_base, &rw_trn_result.rd_fsp[fsp].cs[1], + &rw_trn_result.wr_fsp[fsp].cs[1], + rw_trn_result.byte_en); +#endif + } + if (ret) + goto out; + + record_dq_prebit(dram); + + min_val = get_min_value(dram, SKEW_RX_SIGNAL, + sdram_params->ch.cap_info.rank) * -1; + modify_dq_deskew(dram, SKEW_RX_SIGNAL, DESKEW_MDF_DIFF_VAL, + min_val, min_val, sdram_params->ch.cap_info.rank); +#if defined(CONFIG_CMD_DDR_TEST_TOOL) + save_rw_trn_deskew(phy_base, &rw_trn_result.rd_fsp[fsp], + rw_trn_result.cs_num, (u8)(min_val * (-1)), + SKEW_RX_SIGNAL); +#endif + + min_val = MIN(get_min_value(dram, SKEW_TX_SIGNAL, + sdram_params->ch.cap_info.rank), + get_min_value(dram, SKEW_CA_SIGNAL, + sdram_params->ch.cap_info.rank)) * -1; + + /* clk = 0, rx all skew -7, tx - min_value */ + modify_ca_deskew(dram, DESKEW_MDF_DIFF_VAL, min_val, min_val, 3, + dramtype); + + modify_dq_deskew(dram, SKEW_TX_SIGNAL, DESKEW_MDF_DIFF_VAL, + min_val, min_val, sdram_params->ch.cap_info.rank); +#if defined(CONFIG_CMD_DDR_TEST_TOOL) + save_rw_trn_deskew(phy_base, &rw_trn_result.wr_fsp[fsp], + rw_trn_result.cs_num, (u8)(min_val * (-1)), + SKEW_TX_SIGNAL); +#endif + + ret = data_training(dram, 0, sdram_params, 0, READ_GATE_TRAINING); + if (sdram_params->ch.cap_info.rank == 2) + ret |= data_training(dram, 1, sdram_params, 0, + READ_GATE_TRAINING); +out: + return ret; +} + +static void set_ddrconfig(struct dram_info *dram, u32 ddrconfig) +{ + writel(ddrconfig, &dram->msch->deviceconf); + clrsetbits_le32(&dram->grf->noc_con0, 0x3 << 0, 0 << 0); +} + +static void update_noc_timing(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + void __iomem *pctl_base = dram->pctl; + u32 bw, bl; + + bw = 8 << sdram_params->ch.cap_info.bw; + bl = ((readl(pctl_base + DDR_PCTL2_MSTR) >> 16) & 0xf) * 2; + + /* update the noc timing related to data bus width */ + if ((bw / 8 * bl) <= 16) + sdram_params->ch.noc_timings.ddrmode.b.burstsize = 0; + else if ((bw / 8 * bl) == 32) + sdram_params->ch.noc_timings.ddrmode.b.burstsize = 1; + else if ((bw / 8 * bl) == 64) + sdram_params->ch.noc_timings.ddrmode.b.burstsize = 2; + else + sdram_params->ch.noc_timings.ddrmode.b.burstsize = 3; + + sdram_params->ch.noc_timings.ddrtimingc0.b.burstpenalty = + (bl * bw / 8) > 16 ? (bl / 4) : (16 / (bl * bw / 8)) * bl / 4; + + if (sdram_params->base.dramtype == LPDDR4) { + sdram_params->ch.noc_timings.ddrmode.b.mwrsize = + (bw == 16) ? 0x1 : 0x2; + sdram_params->ch.noc_timings.ddrtimingc0.b.wrtomwr = + 3 * sdram_params->ch.noc_timings.ddrtimingc0.b.burstpenalty; + } + + writel(sdram_params->ch.noc_timings.ddrtiminga0.d32, + &dram->msch->ddrtiminga0); + writel(sdram_params->ch.noc_timings.ddrtimingb0.d32, + &dram->msch->ddrtimingb0); + writel(sdram_params->ch.noc_timings.ddrtimingc0.d32, + &dram->msch->ddrtimingc0); + writel(sdram_params->ch.noc_timings.devtodev0.d32, + &dram->msch->devtodev0); + writel(sdram_params->ch.noc_timings.ddrmode.d32, &dram->msch->ddrmode); + writel(sdram_params->ch.noc_timings.ddr4timing.d32, + &dram->msch->ddr4timing); +} + +static int split_setup(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 dramtype = sdram_params->base.dramtype; + u32 split_size, split_mode; + u64 cs_cap[2], cap; + + cs_cap[0] = sdram_get_cs_cap(cap_info, 0, dramtype); + cs_cap[1] = sdram_get_cs_cap(cap_info, 1, dramtype); + /* only support the larger cap is in low 16bit */ + if (cap_info->cs0_high16bit_row < cap_info->cs0_row) { + cap = cs_cap[0] / (1 << (cap_info->cs0_row - + cap_info->cs0_high16bit_row)); + } else if ((cap_info->cs1_high16bit_row < cap_info->cs1_row) && + (cap_info->rank == 2)) { + if (!cap_info->cs1_high16bit_row) + cap = cs_cap[0]; + else + cap = cs_cap[0] + cs_cap[1] / (1 << (cap_info->cs1_row - + cap_info->cs1_high16bit_row)); + } else { + goto out; + } + split_size = (u32)(cap >> 24) & SPLIT_SIZE_MASK; + if (cap_info->bw == 2) + split_mode = SPLIT_MODE_32_L16_VALID; + else + split_mode = SPLIT_MODE_16_L8_VALID; + + rk_clrsetreg(&dram->ddrgrf->grf_ddrsplit_con, + (SPLIT_MODE_MASK << SPLIT_MODE_OFFSET) | + (SPLIT_BYPASS_MASK << SPLIT_BYPASS_OFFSET) | + (SPLIT_SIZE_MASK << SPLIT_SIZE_OFFSET), + (split_mode << SPLIT_MODE_OFFSET) | + (0x0 << SPLIT_BYPASS_OFFSET) | + (split_size << SPLIT_SIZE_OFFSET)); + + rk_clrsetreg(BUS_SGRF_BASE_ADDR + SGRF_SOC_CON2, + MSCH_AXI_BYPASS_ALL_MASK << MSCH_AXI_BYPASS_ALL_SHIFT, + 0x0 << MSCH_AXI_BYPASS_ALL_SHIFT); + +out: + return 0; +} + +static void split_bypass(struct dram_info *dram) +{ + if ((readl(&dram->ddrgrf->grf_ddrsplit_con) & + (1 << SPLIT_BYPASS_OFFSET)) != 0) + return; + + /* bypass split */ + rk_clrsetreg(&dram->ddrgrf->grf_ddrsplit_con, + (SPLIT_BYPASS_MASK << SPLIT_BYPASS_OFFSET) | + (SPLIT_SIZE_MASK << SPLIT_SIZE_OFFSET), + (0x1 << SPLIT_BYPASS_OFFSET) | + (0x0 << SPLIT_SIZE_OFFSET)); +} + +static void dram_all_config(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 dram_type = sdram_params->base.dramtype; + void __iomem *pctl_base = dram->pctl; + u32 sys_reg2 = 0; + u32 sys_reg3 = 0; + u64 cs_cap[2]; + u32 cs_pst; + + set_ddrconfig(dram, cap_info->ddrconfig); + sdram_org_config(cap_info, &sdram_params->base, &sys_reg2, + &sys_reg3, 0); + writel(sys_reg2, &dram->pmugrf->os_reg[2]); + writel(sys_reg3, &dram->pmugrf->os_reg[3]); + + cs_cap[0] = sdram_get_cs_cap(cap_info, 0, dram_type); + cs_cap[1] = sdram_get_cs_cap(cap_info, 1, dram_type); + + if (cap_info->rank == 2) { + cs_pst = (readl(pctl_base + DDR_PCTL2_ADDRMAP0) & 0x1f) + + 6 + 2; + if (cs_pst > 28) + cs_cap[0] = 1llu << cs_pst; + } + + writel(((((cs_cap[1] >> 20) / 64) & 0xff) << 8) | + (((cs_cap[0] >> 20) / 64) & 0xff), + &dram->msch->devicesize); + update_noc_timing(dram, sdram_params); +} + +static void enable_low_power(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + void __iomem *pctl_base = dram->pctl; + u32 grf_lp_con; + + writel(0x1f1f0617, &dram->ddrgrf->ddr_grf_con[1]); + + if (sdram_params->base.dramtype == DDR4) + grf_lp_con = (0x7 << 16) | (1 << 1); + else if (sdram_params->base.dramtype == DDR3) + grf_lp_con = (0x7 << 16) | (1 << 0); + else + grf_lp_con = (0x7 << 16) | (1 << 2); + + /* en lpckdis_en */ + grf_lp_con = grf_lp_con | (0x1 << (9 + 16)) | (0x1 << 9); + writel(grf_lp_con, &dram->ddrgrf->ddr_grf_lp_con); + + /* enable sr, pd */ + if (dram->pd_idle == 0) + clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 1)); + else + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 1)); + if (dram->sr_idle == 0) + clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 1); + else + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 1); + setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 3)); +} + +static void print_ddr_info(struct rv1126_sdram_params *sdram_params) +{ + u32 split; + + if ((readl(DDR_GRF_BASE_ADDR + DDR_GRF_SPLIT_CON) & + (1 << SPLIT_BYPASS_OFFSET)) != 0) + split = 0; + else + split = readl(DDR_GRF_BASE_ADDR + DDR_GRF_SPLIT_CON) & + SPLIT_SIZE_MASK; + + sdram_print_ddr_info(&sdram_params->ch.cap_info, + &sdram_params->base, split); +} + +static int sdram_init_(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params, u32 post_init) +{ + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + u32 ddr4_vref; + u32 mr_tmp; + + rkclk_configure_ddr(dram, sdram_params); + + rkclk_ddr_reset(dram, 1, 1, 1, 1); + udelay(10); + + rkclk_ddr_reset(dram, 1, 1, 1, 0); + phy_cfg(dram, sdram_params); + + rkclk_ddr_reset(dram, 1, 1, 0, 0); + phy_pll_set(dram, sdram_params->base.ddr_freq * MHZ, 1); + + rkclk_ddr_reset(dram, 1, 0, 0, 0); + pctl_cfg(dram->pctl, &sdram_params->pctl_regs, + dram->sr_idle, dram->pd_idle); + + if (sdram_params->ch.cap_info.bw == 2) { + /* 32bit interface use pageclose */ + setbits_le32(pctl_base + DDR_PCTL2_SCHED, 1 << 2); + /* pageclose = 1, pageclose_timer = 0 will err in lp4 328MHz */ + clrsetbits_le32(pctl_base + DDR_PCTL2_SCHED1, 0xff, 0x1 << 0); + } else { + clrbits_le32(pctl_base + DDR_PCTL2_SCHED, 1 << 2); + } + +#ifdef CONFIG_ROCKCHIP_DRAM_EXTENDED_TEMP_SUPPORT + u32 tmp, trefi; + + tmp = readl(pctl_base + DDR_PCTL2_RFSHTMG); + trefi = (tmp >> 16) & 0xfff; + writel((tmp & 0xf000ffff) | (trefi / 2) << 16, + pctl_base + DDR_PCTL2_RFSHTMG); +#endif + + /* set frequency_mode */ + setbits_le32(pctl_base + DDR_PCTL2_MSTR, 0x1 << 29); + /* set target_frequency to Frequency 0 */ + clrsetbits_le32(pctl_base + DDR_PCTL2_MSTR2, 0x3, 0); + + set_ds_odt(dram, sdram_params, 0); + sdram_params->ch.cap_info.ddrconfig = calculate_ddrconfig(sdram_params); + set_ctl_address_map(dram, sdram_params); + + setbits_le32(pctl_base + DDR_PCTL2_DFIMISC, (1 << 5) | (1 << 4)); + + rkclk_ddr_reset(dram, 0, 0, 0, 0); + + while ((readl(pctl_base + DDR_PCTL2_STAT) & 0x7) == 0) + continue; + + if (sdram_params->base.dramtype == LPDDR3) { + pctl_write_mr(dram->pctl, 3, 11, lp3_odt_value, LPDDR3); + } else if (sdram_params->base.dramtype == LPDDR4) { + mr_tmp = readl(pctl_base + DDR_PCTL2_INIT6); + /* MR11 */ + pctl_write_mr(dram->pctl, 3, 11, + mr_tmp >> PCTL2_LPDDR4_MR11_SHIFT & PCTL2_MR_MASK, + LPDDR4); + /* MR12 */ + pctl_write_mr(dram->pctl, 3, 12, + mr_tmp >> PCTL2_LPDDR4_MR12_SHIFT & PCTL2_MR_MASK, + LPDDR4); + + mr_tmp = readl(pctl_base + DDR_PCTL2_INIT7); + /* MR22 */ + pctl_write_mr(dram->pctl, 3, 22, + mr_tmp >> PCTL2_LPDDR4_MR22_SHIFT & PCTL2_MR_MASK, + LPDDR4); + } + + if (data_training(dram, 0, sdram_params, 0, READ_GATE_TRAINING) != 0) { + if (post_init != 0) + printascii("DTT cs0 error\n"); + return -1; + } + + if (sdram_params->base.dramtype == LPDDR4) { + mr_tmp = read_mr(dram, 1, 14, LPDDR4); + + if (mr_tmp != 0x4d) + return -1; + } + + if (sdram_params->base.dramtype == LPDDR4) { + mr_tmp = readl(pctl_base + DDR_PCTL2_INIT7); + /* MR14 */ + pctl_write_mr(dram->pctl, 3, 14, + mr_tmp >> PCTL2_LPDDR4_MR14_SHIFT & PCTL2_MR_MASK, + LPDDR4); + } + if (post_init != 0 && sdram_params->ch.cap_info.rank == 2) { + if (data_training(dram, 1, sdram_params, 0, + READ_GATE_TRAINING) != 0) { + printascii("DTT cs1 error\n"); + return -1; + } + } + + if (sdram_params->base.dramtype == DDR4) { + ddr4_vref = readl(PHY_REG(phy_base, 0x105)) * 39; + pctl_write_vrefdq(dram->pctl, 0x3, ddr4_vref, + sdram_params->base.dramtype); + } + + dram_all_config(dram, sdram_params); + enable_low_power(dram, sdram_params); + + return 0; +} + +static u64 dram_detect_cap(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params, + unsigned char channel) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + u32 mr8; + + u32 bktmp; + u32 coltmp; + u32 rowtmp; + u32 cs; + u32 dram_type = sdram_params->base.dramtype; + u32 pwrctl; + u32 i, dq_map; + u32 byte1 = 0, byte0 = 0; + u32 tmp, byte; + struct sdram_head_info_index_v2 *index = (struct sdram_head_info_index_v2 *)common_info; + struct dq_map_info *map_info = (struct dq_map_info *) + ((void *)common_info + index->dq_map_index.offset * 4); + + cap_info->bw = dram_type == DDR3 ? 0 : 1; + if (dram_type != LPDDR4) { + if (dram_type != DDR4) { + coltmp = 12; + bktmp = 3; + if (dram_type == LPDDR2) + rowtmp = 15; + else + rowtmp = 16; + + if (sdram_detect_col(cap_info, coltmp) != 0) + goto cap_err; + + sdram_detect_bank(cap_info, coltmp, bktmp); + if (dram_type != LPDDR3) + sdram_detect_dbw(cap_info, dram_type); + } else { + coltmp = 10; + bktmp = 4; + rowtmp = 17; + + cap_info->col = 10; + cap_info->bk = 2; + sdram_detect_bg(cap_info, coltmp); + } + + if (sdram_detect_row(cap_info, coltmp, bktmp, rowtmp) != 0) + goto cap_err; + + sdram_detect_row_3_4(cap_info, coltmp, bktmp); + } else { + cap_info->col = 10; + cap_info->bk = 3; + mr8 = read_mr(dram, 1, 8, dram_type); + cap_info->dbw = ((mr8 >> 6) & 0x3) == 0 ? 1 : 0; + mr8 = (mr8 >> 2) & 0xf; + if (mr8 >= 0 && mr8 <= 6) { + cap_info->cs0_row = 14 + (mr8 + 1) / 2; + } else if (mr8 == 0xc) { + cap_info->cs0_row = 13; + } else { + printascii("Cap ERR: Fail to get cap of LPDDR4/X from MR8\n"); + goto cap_err; + } + if (cap_info->dbw == 0) + cap_info->cs0_row++; + cap_info->row_3_4 = mr8 % 2 == 1 ? 1 : 0; + if (cap_info->cs0_row >= 17) { + printascii("Cap ERR: "); + printascii("RV1126 LPDDR4/X cannot support row >= 17\n"); + goto cap_err; + // cap_info->cs0_row = 16; + // cap_info->row_3_4 = 0; + } + } + + pwrctl = readl(pctl_base + DDR_PCTL2_PWRCTL); + writel(0, pctl_base + DDR_PCTL2_PWRCTL); + + if (data_training(dram, 1, sdram_params, 0, READ_GATE_TRAINING) == 0) + cs = 1; + else + cs = 0; + cap_info->rank = cs + 1; + + setbits_le32(PHY_REG(phy_base, 0xf), 0xf); + + tmp = data_training_rg(dram, 0, dram_type) & 0xf; + + if (tmp == 0) { + cap_info->bw = 2; + } else { + if (dram_type == DDR3 || dram_type == DDR4) { + dq_map = 0; + byte = 0; + for (i = 0; i < 4; i++) { + if ((tmp & BIT(i)) == 0) { + dq_map |= byte << (i * 2); + byte++; + } + } + cap_info->bw = byte / 2; + for (i = 0; i < 4; i++) { + if ((tmp & BIT(i)) != 0) { + dq_map |= byte << (i * 2); + byte++; + } + } + clrsetbits_le32(&map_info->byte_map[0], 0xff << 24, dq_map << 24); + } else { + dq_map = readl(PHY_REG(phy_base, 0x4f)); + for (i = 0; i < 4; i++) { + if (((dq_map >> (i * 2)) & 0x3) == 0) + byte0 = i; + if (((dq_map >> (i * 2)) & 0x3) == 1) + byte1 = i; + } + clrsetbits_le32(PHY_REG(phy_base, 0xf), PHY_DQ_WIDTH_MASK, + BIT(byte0) | BIT(byte1)); + if (data_training(dram, 0, sdram_params, 0, READ_GATE_TRAINING) == 0) + cap_info->bw = 1; + else + cap_info->bw = 0; + } + } + if (cap_info->bw > 0) + cap_info->dbw = 1; + + writel(pwrctl, pctl_base + DDR_PCTL2_PWRCTL); + + cap_info->cs0_high16bit_row = cap_info->cs0_row; + if (cs) { + cap_info->cs1_row = cap_info->cs0_row; + cap_info->cs1_high16bit_row = cap_info->cs0_row; + } else { + cap_info->cs1_row = 0; + cap_info->cs1_high16bit_row = 0; + } + + if (dram_type == LPDDR3) + sdram_detect_dbw(cap_info, dram_type); + + return 0; +cap_err: + return -1; +} + +static int dram_detect_cs1_row(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params, + unsigned char channel) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + void __iomem *pctl_base = dram->pctl; + u32 ret = 0; + void __iomem *test_addr; + u32 row, bktmp, coltmp, bw; + u64 cs0_cap; + u32 byte_mask; + u32 cs_pst; + u32 cs_add = 0; + u32 max_row; + + if (cap_info->rank == 2) { + cs_pst = (readl(pctl_base + DDR_PCTL2_ADDRMAP0) & 0x1f) + + 6 + 2; + if (cs_pst < 28) + cs_add = 1; + + cs0_cap = 1 << cs_pst; + + if (sdram_params->base.dramtype == DDR4) { + if (cap_info->dbw == 0) + bktmp = cap_info->bk + 2; + else + bktmp = cap_info->bk + 1; + } else { + bktmp = cap_info->bk; + } + bw = cap_info->bw; + coltmp = cap_info->col; + + if (bw == 2) + byte_mask = 0xFFFF; + else + byte_mask = 0xFF; + + max_row = (cs_pst == 31) ? 30 : 31; + + max_row = max_row - bktmp - coltmp - bw - cs_add + 1; + + row = (cap_info->cs0_row > max_row) ? max_row : + cap_info->cs0_row; + + for (; row > 12; row--) { + test_addr = (void __iomem *)(CONFIG_SYS_SDRAM_BASE + + (u32)cs0_cap + + (1ul << (row + bktmp + coltmp + + cs_add + bw - 1ul))); + + writel(0, CONFIG_SYS_SDRAM_BASE + (u32)cs0_cap); + writel(PATTERN, test_addr); + + if (((readl(test_addr) & byte_mask) == + (PATTERN & byte_mask)) && + ((readl(CONFIG_SYS_SDRAM_BASE + (u32)cs0_cap) & + byte_mask) == 0)) { + ret = row; + break; + } + } + } + + return ret; +} + +/* return: 0 = success, other = fail */ +static int sdram_init_detect(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info; + u32 ret; + u32 sys_reg = 0; + u32 sys_reg3 = 0; + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + struct dq_map_info *map_info; + + map_info = (struct dq_map_info *)((void *)common_info + + index->dq_map_index.offset * 4); + + if (sdram_init_(dram, sdram_params, 0)) { + if (sdram_params->base.dramtype == DDR3) { + clrsetbits_le32(&map_info->byte_map[0], 0xff << 24, + ((0x1 << 6) | (0x3 << 4) | (0x2 << 2) | + (0x0 << 0)) << 24); + if (sdram_init_(dram, sdram_params, 0)) + return -1; + } else { + return -1; + } + } + + if (sdram_params->base.dramtype == DDR3) { + writel(PATTERN, CONFIG_SYS_SDRAM_BASE); + if (readl(CONFIG_SYS_SDRAM_BASE) != PATTERN) + return -1; + } + + split_bypass(dram); + if (dram_detect_cap(dram, sdram_params, 0) != 0) + return -1; + + pctl_remodify_sdram_params(&sdram_params->pctl_regs, cap_info, + sdram_params->base.dramtype); + ret = sdram_init_(dram, sdram_params, 1); + if (ret != 0) + goto out; + + cap_info->cs1_row = + dram_detect_cs1_row(dram, sdram_params, 0); + if (cap_info->cs1_row) { + sys_reg = readl(&dram->pmugrf->os_reg[2]); + sys_reg3 = readl(&dram->pmugrf->os_reg[3]); + SYS_REG_ENC_CS1_ROW(cap_info->cs1_row, + sys_reg, sys_reg3, 0); + writel(sys_reg, &dram->pmugrf->os_reg[2]); + writel(sys_reg3, &dram->pmugrf->os_reg[3]); + } + + sdram_detect_high_row(cap_info, sdram_params->base.dramtype); + split_setup(dram, sdram_params); +out: + return ret; +} + +struct rv1126_sdram_params *get_default_sdram_config(u32 freq_mhz) +{ + u32 i; + u32 offset = 0; + struct ddr2_3_4_lp2_3_info *ddr_info; + + if (!freq_mhz) { + ddr_info = get_ddr_drv_odt_info(sdram_configs[0].base.dramtype); + if (ddr_info) + freq_mhz = + (ddr_info->ddr_freq0_1 >> DDR_FREQ_F0_SHIFT) & + DDR_FREQ_MASK; + else + freq_mhz = 0; + } + + for (i = 0; i < ARRAY_SIZE(sdram_configs); i++) { + if (sdram_configs[i].base.ddr_freq == 0 || + freq_mhz < sdram_configs[i].base.ddr_freq) + break; + } + offset = i == 0 ? 0 : i - 1; + + return &sdram_configs[offset]; +} + +static const u16 pctl_need_update_reg[] = { + DDR_PCTL2_RFSHTMG, + DDR_PCTL2_INIT3, + DDR_PCTL2_INIT4, + DDR_PCTL2_INIT6, + DDR_PCTL2_INIT7, + DDR_PCTL2_DRAMTMG0, + DDR_PCTL2_DRAMTMG1, + DDR_PCTL2_DRAMTMG2, + DDR_PCTL2_DRAMTMG3, + DDR_PCTL2_DRAMTMG4, + DDR_PCTL2_DRAMTMG5, + DDR_PCTL2_DRAMTMG6, + DDR_PCTL2_DRAMTMG7, + DDR_PCTL2_DRAMTMG8, + DDR_PCTL2_DRAMTMG9, + DDR_PCTL2_DRAMTMG12, + DDR_PCTL2_DRAMTMG13, + DDR_PCTL2_DRAMTMG14, + DDR_PCTL2_ZQCTL0, + DDR_PCTL2_DFITMG0, + DDR_PCTL2_ODTCFG +}; + +static const u16 phy_need_update_reg[] = { + 0x14, + 0x18, + 0x1c +}; + +static void pre_set_rate(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params, + u32 dst_fsp, u32 dst_fsp_lp4) +{ + u32 i, j, find; + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + u32 phy_offset; + u32 mr_tmp; + u32 dramtype = sdram_params->base.dramtype; + + sw_set_req(dram); + /* pctl timing update */ + for (i = 0, find = 0; i < ARRAY_SIZE(pctl_need_update_reg); i++) { + for (j = find; sdram_params->pctl_regs.pctl[j][0] != 0xFFFFFFFF; + j++) { + if (sdram_params->pctl_regs.pctl[j][0] == + pctl_need_update_reg[i]) { + writel(sdram_params->pctl_regs.pctl[j][1], + pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + pctl_need_update_reg[i]); + find = j; + break; + } + } + } + +#ifdef CONFIG_ROCKCHIP_DRAM_EXTENDED_TEMP_SUPPORT + u32 tmp, trefi; + + tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + DDR_PCTL2_RFSHTMG); + trefi = (tmp >> 16) & 0xfff; + writel((tmp & 0xf000ffff) | (trefi / 2) << 16, + pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + DDR_PCTL2_RFSHTMG); +#endif + + sw_set_ack(dram); + + /* phy timing update */ + if (dst_fsp == 0) + phy_offset = 0; + else + phy_offset = PHY_REG(0, 0x387 - 5 + (dst_fsp - 1) * 3); + /* cl cwl al update */ + for (i = 0, find = 0; i < ARRAY_SIZE(phy_need_update_reg); i++) { + for (j = find; sdram_params->phy_regs.phy[j][0] != 0xFFFFFFFF; + j++) { + if (sdram_params->phy_regs.phy[j][0] == + phy_need_update_reg[i]) { + writel(sdram_params->phy_regs.phy[j][1], + phy_base + phy_offset + + phy_need_update_reg[i]); + find = j; + break; + } + } + } + + set_ds_odt(dram, sdram_params, dst_fsp); + if (dramtype == LPDDR4) { + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT4); + /* MR13 */ + pctl_write_mr(dram->pctl, 3, 13, + ((mr_tmp >> PCTL2_LPDDR4_MR13_SHIFT & + PCTL2_MR_MASK) & (~(BIT(7) | BIT(6)))) | + ((0x2 << 6) >> dst_fsp_lp4), dramtype); + writel(((mr_tmp >> PCTL2_LPDDR4_MR13_SHIFT & + PCTL2_MR_MASK) & (~(BIT(7) | BIT(6)))) | + ((0x2 << 6) >> dst_fsp_lp4), + PHY_REG(phy_base, 0x1b)); + /* MR3 */ + pctl_write_mr(dram->pctl, 3, 3, + mr_tmp >> PCTL2_LPDDR234_MR3_SHIFT & + PCTL2_MR_MASK, + dramtype); + writel(mr_tmp >> PCTL2_LPDDR234_MR3_SHIFT & PCTL2_MR_MASK, + PHY_REG(phy_base, 0x19)); + + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT3); + /* MR1 */ + pctl_write_mr(dram->pctl, 3, 1, + mr_tmp >> PCTL2_LPDDR234_MR1_SHIFT & + PCTL2_MR_MASK, + dramtype); + writel(mr_tmp >> PCTL2_LPDDR234_MR1_SHIFT & PCTL2_MR_MASK, + PHY_REG(phy_base, 0x17)); + /* MR2 */ + pctl_write_mr(dram->pctl, 3, 2, mr_tmp & PCTL2_MR_MASK, + dramtype); + writel(mr_tmp & PCTL2_MR_MASK, + PHY_REG(phy_base, 0x18)); + + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT6); + /* MR11 */ + pctl_write_mr(dram->pctl, 3, 11, + mr_tmp >> PCTL2_LPDDR4_MR11_SHIFT & PCTL2_MR_MASK, + dramtype); + writel(mr_tmp >> PCTL2_LPDDR4_MR11_SHIFT & PCTL2_MR_MASK, + PHY_REG(phy_base, 0x1a)); + /* MR12 */ + pctl_write_mr(dram->pctl, 3, 12, + mr_tmp >> PCTL2_LPDDR4_MR12_SHIFT & PCTL2_MR_MASK, + dramtype); + + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT7); + /* MR22 */ + pctl_write_mr(dram->pctl, 3, 22, + mr_tmp >> PCTL2_LPDDR4_MR22_SHIFT & PCTL2_MR_MASK, + dramtype); + writel(mr_tmp >> PCTL2_LPDDR4_MR22_SHIFT & PCTL2_MR_MASK, + PHY_REG(phy_base, 0x1d)); + /* MR14 */ + pctl_write_mr(dram->pctl, 3, 14, + mr_tmp >> PCTL2_LPDDR4_MR14_SHIFT & PCTL2_MR_MASK, + dramtype); + writel(mr_tmp >> PCTL2_LPDDR4_MR14_SHIFT & PCTL2_MR_MASK, + PHY_REG(phy_base, 0x1c)); + } + + update_noc_timing(dram, sdram_params); +} + +static void save_fsp_param(struct dram_info *dram, u32 dst_fsp, + struct rv1126_sdram_params *sdram_params) +{ + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + struct rv1126_fsp_param *p_fsp_param = &fsp_param[dst_fsp]; + u32 temp, temp1; + struct ddr2_3_4_lp2_3_info *ddr_info; + + ddr_info = get_ddr_drv_odt_info(sdram_params->base.dramtype); + + p_fsp_param->freq_mhz = sdram_params->base.ddr_freq; + + if (sdram_params->base.dramtype == LPDDR4) { + p_fsp_param->rd_odt_up_en = 0; + p_fsp_param->rd_odt_down_en = 1; + } else { + p_fsp_param->rd_odt_up_en = + ODT_INFO_PULLUP_EN(ddr_info->odt_info); + p_fsp_param->rd_odt_down_en = + ODT_INFO_PULLDOWN_EN(ddr_info->odt_info); + } + + if (p_fsp_param->rd_odt_up_en) + p_fsp_param->rd_odt = readl(PHY_REG(phy_base, 0x111)); + else if (p_fsp_param->rd_odt_down_en) + p_fsp_param->rd_odt = readl(PHY_REG(phy_base, 0x110)); + else + p_fsp_param->rd_odt = 0; + p_fsp_param->wr_dq_drv = readl(PHY_REG(phy_base, 0x112)); + p_fsp_param->wr_ca_drv = readl(PHY_REG(phy_base, 0x100)); + p_fsp_param->wr_ckcs_drv = readl(PHY_REG(phy_base, 0x102)); + p_fsp_param->vref_inner = readl(PHY_REG(phy_base, 0x128)); + p_fsp_param->vref_out = readl(PHY_REG(phy_base, 0x105)); + + if (sdram_params->base.dramtype == DDR3) { + temp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT3); + temp = (temp >> PCTL2_DDR34_MR1_SHIFT) & PCTL2_MR_MASK; + p_fsp_param->ds_pdds = temp & DDR3_DS_MASK; + p_fsp_param->dq_odt = temp & DDR3_RTT_NOM_MASK; + p_fsp_param->ca_odt = p_fsp_param->dq_odt; + } else if (sdram_params->base.dramtype == DDR4) { + temp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT3); + temp = (temp >> PCTL2_DDR34_MR1_SHIFT) & PCTL2_MR_MASK; + p_fsp_param->ds_pdds = temp & DDR4_DS_MASK; + p_fsp_param->dq_odt = temp & DDR4_RTT_NOM_MASK; + p_fsp_param->ca_odt = p_fsp_param->dq_odt; + } else if (sdram_params->base.dramtype == LPDDR3) { + temp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT4); + temp = (temp >> PCTL2_LPDDR234_MR3_SHIFT) & PCTL2_MR_MASK; + p_fsp_param->ds_pdds = temp & 0xf; + + p_fsp_param->dq_odt = lp3_odt_value; + p_fsp_param->ca_odt = p_fsp_param->dq_odt; + } else if (sdram_params->base.dramtype == LPDDR4) { + temp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT4); + temp = (temp >> PCTL2_LPDDR234_MR3_SHIFT) & PCTL2_MR_MASK; + p_fsp_param->ds_pdds = temp & LPDDR4_PDDS_MASK; + + temp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT6); + temp = (temp >> PCTL2_LPDDR4_MR11_SHIFT) & PCTL2_MR_MASK; + p_fsp_param->dq_odt = temp & LPDDR4_DQODT_MASK; + p_fsp_param->ca_odt = temp & LPDDR4_CAODT_MASK; + + temp = MAX(readl(PHY_REG(phy_base, 0x3ae)), + readl(PHY_REG(phy_base, 0x3ce))); + temp1 = MIN(readl(PHY_REG(phy_base, 0x3be)), + readl(PHY_REG(phy_base, 0x3de))); + p_fsp_param->vref_ca[0] = (temp + temp1) / 2; + temp = MAX(readl(PHY_REG(phy_base, 0x3af)), + readl(PHY_REG(phy_base, 0x3cf))); + temp1 = MIN(readl(PHY_REG(phy_base, 0x3bf)), + readl(PHY_REG(phy_base, 0x3df))); + p_fsp_param->vref_ca[1] = (temp + temp1) / 2; + p_fsp_param->vref_ca[0] |= + (readl(PHY_REG(phy_base, 0x1e)) & BIT(6)); + p_fsp_param->vref_ca[1] |= + (readl(PHY_REG(phy_base, 0x1e)) & BIT(6)); + + p_fsp_param->lp4_drv_pd_en = (readl(PHY_REG(phy_base, 0x114)) >> + 3) & 0x1; + } + + p_fsp_param->noc_timings.ddrtiminga0 = + sdram_params->ch.noc_timings.ddrtiminga0; + p_fsp_param->noc_timings.ddrtimingb0 = + sdram_params->ch.noc_timings.ddrtimingb0; + p_fsp_param->noc_timings.ddrtimingc0 = + sdram_params->ch.noc_timings.ddrtimingc0; + p_fsp_param->noc_timings.devtodev0 = + sdram_params->ch.noc_timings.devtodev0; + p_fsp_param->noc_timings.ddrmode = + sdram_params->ch.noc_timings.ddrmode; + p_fsp_param->noc_timings.ddr4timing = + sdram_params->ch.noc_timings.ddr4timing; + p_fsp_param->noc_timings.agingx0 = + sdram_params->ch.noc_timings.agingx0; + p_fsp_param->noc_timings.aging0 = + sdram_params->ch.noc_timings.aging0; + p_fsp_param->noc_timings.aging1 = + sdram_params->ch.noc_timings.aging1; + p_fsp_param->noc_timings.aging2 = + sdram_params->ch.noc_timings.aging2; + p_fsp_param->noc_timings.aging3 = + sdram_params->ch.noc_timings.aging3; + + p_fsp_param->flag = FSP_FLAG; +} + +static void copy_fsp_param_to_ddr(void) +{ + memcpy((void *)FSP_PARAM_STORE_ADDR, (void *)&fsp_param, + sizeof(fsp_param)); +} + +static void pctl_modify_trfc(struct ddr_pctl_regs *pctl_regs, + struct sdram_cap_info *cap_info, u32 dram_type, + u32 freq) +{ + u64 cs0_cap; + u32 die_cap; + u32 trfc_ns, trfc4_ns; + u32 trfc, txsnr; + u32 txs_abort_fast = 0; + u32 tmp; + + cs0_cap = sdram_get_cs_cap(cap_info, 0, dram_type); + die_cap = (u32)(cs0_cap >> (20 + (cap_info->bw - cap_info->dbw))); + + switch (dram_type) { + case DDR3: + if (die_cap <= DIE_CAP_512MBIT) + trfc_ns = 90; + else if (die_cap <= DIE_CAP_1GBIT) + trfc_ns = 110; + else if (die_cap <= DIE_CAP_2GBIT) + trfc_ns = 160; + else if (die_cap <= DIE_CAP_4GBIT) + trfc_ns = 260; + else + trfc_ns = 350; + txsnr = MAX(5, ((trfc_ns + 10) * freq + 999) / 1000); + break; + + case DDR4: + if (die_cap <= DIE_CAP_2GBIT) { + trfc_ns = 160; + trfc4_ns = 90; + } else if (die_cap <= DIE_CAP_4GBIT) { + trfc_ns = 260; + trfc4_ns = 110; + } else if (die_cap <= DIE_CAP_8GBIT) { + trfc_ns = 350; + trfc4_ns = 160; + } else { + trfc_ns = 550; + trfc4_ns = 260; + } + txsnr = ((trfc_ns + 10) * freq + 999) / 1000; + txs_abort_fast = ((trfc4_ns + 10) * freq + 999) / 1000; + break; + + case LPDDR3: + if (die_cap <= DIE_CAP_4GBIT) + trfc_ns = 130; + else + trfc_ns = 210; + txsnr = MAX(2, ((trfc_ns + 10) * freq + 999) / 1000); + break; + + case LPDDR4: + if (die_cap <= DIE_CAP_2GBIT) + trfc_ns = 130; + else if (die_cap <= DIE_CAP_4GBIT) + trfc_ns = 180; + else if (die_cap <= DIE_CAP_8GBIT) + trfc_ns = 280; + else + trfc_ns = 380; + txsnr = MAX(2, ((trfc_ns + 10) * freq + 999) / 1000); + break; + + default: + return; + } + trfc = (trfc_ns * freq + 999) / 1000; + + for (int i = 0; pctl_regs->pctl[i][0] != 0xffffffff; i++) { + switch (pctl_regs->pctl[i][0]) { + case DDR_PCTL2_RFSHTMG: + tmp = pctl_regs->pctl[i][1]; + /* t_rfc_min */ + tmp &= ~((u32)0x3ff); + tmp |= ((trfc + 1) / 2) & 0x3ff; + pctl_regs->pctl[i][1] = tmp; + break; + + case DDR_PCTL2_DRAMTMG8: + if (dram_type == DDR3 || dram_type == DDR4) { + tmp = pctl_regs->pctl[i][1]; + /* t_xs_x32 */ + tmp &= ~((u32)0x7f); + tmp |= ((txsnr + 63) / 64) & 0x7f; + + if (dram_type == DDR4) { + /* t_xs_abort_x32 */ + tmp &= ~((u32)(0x7f << 16)); + tmp |= (((txs_abort_fast + 63) / 64) & 0x7f) << 16; + /* t_xs_fast_x32 */ + tmp &= ~((u32)(0x7f << 24)); + tmp |= (((txs_abort_fast + 63) / 64) & 0x7f) << 24; + } + + pctl_regs->pctl[i][1] = tmp; + } + break; + + case DDR_PCTL2_DRAMTMG14: + if (dram_type == LPDDR3 || + dram_type == LPDDR4) { + tmp = pctl_regs->pctl[i][1]; + /* t_xsr */ + tmp &= ~((u32)0xfff); + tmp |= ((txsnr + 1) / 2) & 0xfff; + pctl_regs->pctl[i][1] = tmp; + } + break; + + default: + break; + } + } +} + +void ddr_set_rate(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params, + u32 freq, u32 cur_freq, u32 dst_fsp, + u32 dst_fsp_lp4, u32 training_en) +{ + u32 dest_dll_off, cur_init3, dst_init3, cur_fsp, cur_dll_off; + u32 mr_tmp; + u32 lp_stat; + u32 dramtype = sdram_params->base.dramtype; + struct rv1126_sdram_params *sdram_params_new; + void __iomem *pctl_base = dram->pctl; + void __iomem *phy_base = dram->phy; + + lp_stat = low_power_update(dram, 0); + sdram_params_new = get_default_sdram_config(freq); + sdram_params_new->ch.cap_info.rank = sdram_params->ch.cap_info.rank; + sdram_params_new->ch.cap_info.bw = sdram_params->ch.cap_info.bw; + + pctl_modify_trfc(&sdram_params_new->pctl_regs, + &sdram_params->ch.cap_info, dramtype, freq); + pre_set_rate(dram, sdram_params_new, dst_fsp, dst_fsp_lp4); + + while ((readl(pctl_base + DDR_PCTL2_STAT) & + PCTL2_OPERATING_MODE_MASK) == + PCTL2_OPERATING_MODE_SR) + continue; + + dest_dll_off = 0; + dst_init3 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT3); + if ((dramtype == DDR3 && (dst_init3 & 1)) || + (dramtype == DDR4 && !(dst_init3 & 1))) + dest_dll_off = 1; + + cur_fsp = readl(pctl_base + DDR_PCTL2_MSTR2) & 0x3; + cur_init3 = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + + DDR_PCTL2_INIT3); + cur_init3 &= PCTL2_MR_MASK; + cur_dll_off = 1; + if ((dramtype == DDR3 && !(cur_init3 & 1)) || + (dramtype == DDR4 && (cur_init3 & 1))) + cur_dll_off = 0; + + if (!cur_dll_off) { + if (dramtype == DDR3) + cur_init3 |= 1; + else + cur_init3 &= ~1; + pctl_write_mr(dram->pctl, 2, 1, cur_init3, dramtype); + } + + setbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, + PCTL2_DIS_AUTO_REFRESH); + update_refresh_reg(dram); + + enter_sr(dram, 1); + + writel(PMUGRF_CON_DDRPHY_BUFFEREN_MASK | + PMUGRF_CON_DDRPHY_BUFFEREN_EN, + &dram->pmugrf->soc_con[0]); + sw_set_req(dram); + clrbits_le32(pctl_base + DDR_PCTL2_DFIMISC, + PCTL2_DFI_INIT_COMPLETE_EN); + sw_set_ack(dram); + + sw_set_req(dram); + if ((dramtype == DDR3 || dramtype == DDR4) && dest_dll_off) + setbits_le32(pctl_base + DDR_PCTL2_MSTR, PCTL2_DLL_OFF_MODE); + else + clrbits_le32(pctl_base + DDR_PCTL2_MSTR, PCTL2_DLL_OFF_MODE); + + setbits_le32(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + DDR_PCTL2_ZQCTL0, + PCTL2_DIS_SRX_ZQCL); + setbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + DDR_PCTL2_ZQCTL0, + PCTL2_DIS_SRX_ZQCL); + sw_set_ack(dram); + + writel(DDR_MSCH_EN_MASK | (0x1 << DDR_MSCH_EN_SHIFT), + &dram->cru->clkgate_con[21]); + writel(CLK_DDR_UPCTL_EN_MASK | ACLK_DDR_UPCTL_EN_MASK | + (0x1 << CLK_DDR_UPCTL_EN_SHIFT) | + (0x1 << ACLK_DDR_UPCTL_EN_SHIFT), + BUS_SGRF_BASE_ADDR + SGRF_SOC_CON12); + + clrbits_le32(PHY_REG(phy_base, 0), ANALOG_DERESET | DIGITAL_DERESET); + rkclk_set_dpll(dram, freq * MHz / 2); + phy_pll_set(dram, freq * MHz, 0); + phy_pll_set(dram, freq * MHz, 1); + setbits_le32(PHY_REG(phy_base, 0), ANALOG_DERESET | DIGITAL_DERESET); + + writel(PMUGRF_CON_DDRPHY_BUFFEREN_MASK | + PMUGRF_CON_DDRPHY_BUFFEREN_DIS, + &dram->pmugrf->soc_con[0]); + writel(DDR_MSCH_EN_MASK | (0x0 << DDR_MSCH_EN_SHIFT), + &dram->cru->clkgate_con[21]); + writel(CLK_DDR_UPCTL_EN_MASK | ACLK_DDR_UPCTL_EN_MASK | + (0x0 << CLK_DDR_UPCTL_EN_SHIFT) | + (0x0 << ACLK_DDR_UPCTL_EN_SHIFT), + BUS_SGRF_BASE_ADDR + SGRF_SOC_CON12); + while ((readl(pctl_base + DDR_PCTL2_DFISTAT) & + PCTL2_DFI_INIT_COMPLETE) != PCTL2_DFI_INIT_COMPLETE) + continue; + + sw_set_req(dram); + setbits_le32(pctl_base + DDR_PCTL2_MSTR, 0x1 << 29); + clrsetbits_le32(pctl_base + DDR_PCTL2_MSTR2, 0x3, dst_fsp); + sw_set_ack(dram); + update_refresh_reg(dram); + clrsetbits_le32(PHY_REG(phy_base, 0xc), 0x3 << 2, dst_fsp << 2); + + enter_sr(dram, 0); + + setbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + clrbits_le32(PHY_REG(phy_base, 0x71), 1 << 5); + + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + DDR_PCTL2_INIT4); + if (dramtype == LPDDR3) { + pctl_write_mr(dram->pctl, 3, 1, + (dst_init3 >> PCTL2_LPDDR234_MR1_SHIFT) & + PCTL2_MR_MASK, + dramtype); + pctl_write_mr(dram->pctl, 3, 2, dst_init3 & PCTL2_MR_MASK, + dramtype); + pctl_write_mr(dram->pctl, 3, 3, + (mr_tmp >> PCTL2_LPDDR234_MR3_SHIFT) & + PCTL2_MR_MASK, + dramtype); + pctl_write_mr(dram->pctl, 3, 11, lp3_odt_value, dramtype); + } else if ((dramtype == DDR3) || (dramtype == DDR4)) { + pctl_write_mr(dram->pctl, 3, 1, dst_init3 & PCTL2_MR_MASK, + dramtype); + if (!dest_dll_off) { + pctl_write_mr(dram->pctl, 3, 0, + ((dst_init3 >> PCTL2_DDR34_MR0_SHIFT) & + PCTL2_MR_MASK) | DDR3_DLL_RESET, + dramtype); + udelay(2); + } + pctl_write_mr(dram->pctl, 3, 0, + (dst_init3 >> PCTL2_DDR34_MR0_SHIFT & + PCTL2_MR_MASK) & (~DDR3_DLL_RESET), + dramtype); + pctl_write_mr(dram->pctl, 3, 2, + ((mr_tmp >> PCTL2_DDR34_MR2_SHIFT) & + PCTL2_MR_MASK), dramtype); + if (dramtype == DDR4) { + pctl_write_mr(dram->pctl, 3, 3, mr_tmp & PCTL2_MR_MASK, + dramtype); + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT6); + pctl_write_mr(dram->pctl, 3, 4, + (mr_tmp >> PCTL2_DDR4_MR4_SHIFT) & + PCTL2_MR_MASK, + dramtype); + pctl_write_mr(dram->pctl, 3, 5, + mr_tmp >> PCTL2_DDR4_MR5_SHIFT & + PCTL2_MR_MASK, + dramtype); + + mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + + DDR_PCTL2_INIT7); + pctl_write_mr(dram->pctl, 3, 6, + mr_tmp >> PCTL2_DDR4_MR6_SHIFT & + PCTL2_MR_MASK, + dramtype); + } + } else if (dramtype == LPDDR4) { + pctl_write_mr(dram->pctl, 3, 13, + ((mr_tmp >> PCTL2_LPDDR4_MR13_SHIFT & + PCTL2_MR_MASK) & (~(BIT(7)))) | + dst_fsp_lp4 << 7, dramtype); + } + clrbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3, + PCTL2_DIS_AUTO_REFRESH); + update_refresh_reg(dram); + + /* training */ + high_freq_training(dram, sdram_params_new, dst_fsp); + low_power_update(dram, lp_stat); + + save_fsp_param(dram, dst_fsp, sdram_params_new); +} + +static void ddr_set_rate_for_fsp(struct dram_info *dram, + struct rv1126_sdram_params *sdram_params) +{ + struct ddr2_3_4_lp2_3_info *ddr_info; + u32 f0; + u32 dramtype = sdram_params->base.dramtype; + u32 f1, f2, f3; + + ddr_info = get_ddr_drv_odt_info(dramtype); + if (!ddr_info) + return; + + f0 = (ddr_info->ddr_freq0_1 >> DDR_FREQ_F0_SHIFT) & + DDR_FREQ_MASK; + + memset((void *)FSP_PARAM_STORE_ADDR, 0, sizeof(fsp_param)); + memset((void *)&fsp_param, 0, sizeof(fsp_param)); + + f1 = (ddr_info->ddr_freq0_1 >> DDR_FREQ_F1_SHIFT) & + DDR_FREQ_MASK; + f2 = (ddr_info->ddr_freq2_3 >> DDR_FREQ_F2_SHIFT) & + DDR_FREQ_MASK; + f3 = (ddr_info->ddr_freq2_3 >> DDR_FREQ_F3_SHIFT) & + DDR_FREQ_MASK; + + if (get_wrlvl_val(dram, sdram_params)) + printascii("get wrlvl value fail\n"); + + printascii("change to: "); + printdec(f1); + printascii("MHz\n"); + ddr_set_rate(&dram_info, sdram_params, f1, + sdram_params->base.ddr_freq, 1, 1, 1); + printascii("change to: "); + printdec(f2); + printascii("MHz\n"); + ddr_set_rate(&dram_info, sdram_params, f2, f1, 2, 0, 1); + printascii("change to: "); + printdec(f3); + printascii("MHz\n"); + ddr_set_rate(&dram_info, sdram_params, f3, f2, 3, 1, 1); + printascii("change to: "); + printdec(f0); + printascii("MHz(final freq)\n"); + ddr_set_rate(&dram_info, sdram_params, f0, f3, 0, 0, 1); +} + +int get_uart_config(void) +{ + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + struct global_info *gbl_info; + + gbl_info = (struct global_info *)((void *)common_info + + index->global_index.offset * 4); + + return gbl_info->uart_info; +} + +/* return: 0 = success, other = fail */ +static int rv1126_dmc_init(struct udevice *dev) +{ + struct rv1126_sdram_params *sdram_params; + int ret = 0; + struct sdram_head_info_index_v2 *index = + (struct sdram_head_info_index_v2 *)common_info; + struct global_info *gbl_info; + + dram_info.phy = (void *)DDR_PHY_BASE_ADDR; + dram_info.pctl = (void *)UPCTL2_BASE_ADDR; + dram_info.grf = (void *)GRF_BASE_ADDR; + dram_info.cru = (void *)CRU_BASE_ADDR; + dram_info.msch = (void *)SERVER_MSCH_BASE_ADDR; + dram_info.ddrgrf = (void *)DDR_GRF_BASE_ADDR; + dram_info.pmugrf = (void *)PMU_GRF_BASE_ADDR; + +#ifdef CONFIG_ROCKCHIP_DRAM_EXTENDED_TEMP_SUPPORT + printascii("extended temp support\n"); +#endif + if (index->version_info != 2 || + (index->global_index.size != sizeof(struct global_info) / 4) || + (index->ddr3_index.size != + sizeof(struct ddr2_3_4_lp2_3_info) / 4) || + (index->ddr4_index.size != + sizeof(struct ddr2_3_4_lp2_3_info) / 4) || + (index->lp3_index.size != + sizeof(struct ddr2_3_4_lp2_3_info) / 4) || + (index->lp4_index.size != (sizeof(struct lp4_info) / 4)) || + (index->lp4x_index.size != (sizeof(struct lp4_info) / 4)) || + index->global_index.offset == 0 || + index->ddr3_index.offset == 0 || + index->ddr4_index.offset == 0 || + index->lp3_index.offset == 0 || + index->lp4_index.offset == 0 || + index->lp4x_index.offset == 0) { + printascii("common info error\n"); + goto error; + } + + gbl_info = (struct global_info *)((void *)common_info + + index->global_index.offset * 4); + + dram_info.sr_idle = SR_INFO(gbl_info->sr_pd_info); + dram_info.pd_idle = PD_INFO(gbl_info->sr_pd_info); + + sdram_params = &sdram_configs[0]; + if (sdram_params->base.dramtype == DDR3 || + sdram_params->base.dramtype == DDR4) { + if (DDR_2T_INFO(gbl_info->info_2t)) + sdram_params->pctl_regs.pctl[0][1] |= 0x1 << 10; + else + sdram_params->pctl_regs.pctl[0][1] &= + ~(0x1 << 10); + } + ret = sdram_init_detect(&dram_info, sdram_params); + if (ret) { + sdram_print_dram_type(sdram_params->base.dramtype); + printascii(", "); + printdec(sdram_params->base.ddr_freq); + printascii("MHz\n"); + goto error; + } + print_ddr_info(sdram_params); +#if defined(CONFIG_CMD_DDR_TEST_TOOL) + init_rw_trn_result_struct(&rw_trn_result, dram_info.phy, + (u8)sdram_params->ch.cap_info.rank); +#endif + + ddr_set_rate_for_fsp(&dram_info, sdram_params); + copy_fsp_param_to_ddr(); + +#if defined(CONFIG_CMD_DDR_TEST_TOOL) + save_rw_trn_result_to_ddr(&rw_trn_result); +#endif + + printascii("out\n"); + + return ret; +error: + printascii("error\n"); + return (-1); +} + +#endif + +static int rv1126_dmc_probe(struct udevice *dev) +{ +#if defined(CONFIG_TPL_BUILD) || \ + (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD)) + if (rv1126_dmc_init(dev)) + return 0; +#else + struct dram_info *priv = dev_get_priv(dev); + + priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF); + debug("%s: grf=%p\n", __func__, priv->pmugrf); + priv->info.base = CONFIG_SYS_SDRAM_BASE; + priv->info.size = + rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg[2]); +#endif + return 0; +} + +static int rv1126_dmc_get_info(struct udevice *dev, struct ram_info *info) +{ + struct dram_info *priv = dev_get_priv(dev); + + *info = priv->info; + + return 0; +} + +static struct ram_ops rv1126_dmc_ops = { + .get_info = rv1126_dmc_get_info, +}; + +static const struct udevice_id rv1126_dmc_ids[] = { + { .compatible = "rockchip,rv1126-dmc" }, + { } +}; + +U_BOOT_DRIVER(dmc_rv1126) = { + .name = "rockchip_rv1126_dmc", + .id = UCLASS_RAM, + .of_match = rv1126_dmc_ids, + .ops = &rv1126_dmc_ops, + .probe = rv1126_dmc_probe, + .priv_auto = sizeof(struct dram_info), +};
On 2022/8/18 22:52, Jagan Teki wrote:
Add DDR driver for Rockchip RV1126 SoC.
Signed-off-by: YouMin Chen cym@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
.../asm/arch-rockchip/dram_spec_timing.h | 452 +++ .../include/asm/arch-rockchip/sdram_common.h | 212 + .../include/asm/arch-rockchip/sdram_msch.h | 12 + .../asm/arch-rockchip/sdram_phy_rv1126.h | 93 + .../include/asm/arch-rockchip/sdram_rv1126.h | 420 ++ drivers/ram/rockchip/Makefile | 1 + drivers/ram/rockchip/sdram_rv1126.c | 3521 +++++++++++++++++ 7 files changed, 4711 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/dram_spec_timing.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rv1126.h create mode 100644 drivers/ram/rockchip/sdram_rv1126.c
diff --git a/arch/arm/include/asm/arch-rockchip/dram_spec_timing.h b/arch/arm/include/asm/arch-rockchip/dram_spec_timing.h new file mode 100644 index 0000000000..a691e97a8b --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/dram_spec_timing.h @@ -0,0 +1,452 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
- Copyright (C) 2020 Rockchip Electronics Co., Ltd
+#ifndef __ROCKCHIP_DRAM_SPEC_TIMING_H__ +#define __ROCKCHIP_DRAM_SPEC_TIMING_H__
+enum ddr3_speed_rate {
- /* 5-5-5 */
- DDR3_800D = 0,
- /* 6-6-6 */
- DDR3_800E = 1,
- /* 6-6-6 */
- DDR3_1066E = 2,
- /* 7-7-7 */
- DDR3_1066F = 3,
- /* 8-8-8 */
- DDR3_1066G = 4,
- /* 7-7-7 */
- DDR3_1333F = 5,
- /* 8-8-8 */
- DDR3_1333G = 6,
- /* 9-9-9 */
- DDR3_1333H = 7,
- /* 10-10-10 */
- DDR3_1333J = 8,
- /* 8-8-8 */
- DDR3_1600G = 9,
- /* 9-9-9 */
- DDR3_1600H = 10,
- /* 10-10-10 */
- DDR3_1600J = 11,
- /* 11-11-11 */
- DDR3_1600K = 12,
- /* 10-10-10 */
- DDR3_1866J = 13,
- /* 11-11-11 */
- DDR3_1866K = 14,
- /* 12-12-12 */
- DDR3_1866L = 15,
- /* 13-13-13 */
- DDR3_1866M = 16,
- /* 11-11-11 */
- DDR3_2133K = 17,
- /* 12-12-12 */
- DDR3_2133L = 18,
- /* 13-13-13 */
- DDR3_2133M = 19,
- /* 14-14-14 */
- DDR3_2133N = 20,
- DDR3_DEFAULT = 21,
+enum ddr4_speed_rate {
- /* DDR4_1600J (10-10-10) */
- DDR4_1600J = 0,
- /* DDR4_1600K (11-11-11) */
- DDR4_1600K = 1,
- /* DDR4_1600L (12-12-12) */
- DDR4_1600L = 2,
- /* DDR4_1800L (12-12-12) */
- DDR4_1866L = 3,
- /* DDR4_1800M (13-13-13) */
- DDR4_1866M = 4,
- /* DDR4_1800N (14-14-14) */
- DDR4_1866N = 5,
- /* DDR4_2133N (14-14-14) */
- DDR4_2133N = 6,
- /* DDR4_2133P (15-15-15) */
- DDR4_2133P = 7,
- /* DDR4_2133R (16-16-16) */
- DDR4_2133R = 8,
- /* DDR4_2400P (15-15-15) */
- DDR4_2400P = 9,
- /* DDR4_2400R (16-16-16) */
- DDR4_2400R = 10,
- /* DDR4_2400U (18-18-18) */
- DDR4_2400U = 11,
- /* DEFAULT */
- DDR4_DEFAULT = 12,
+/* mr0 for ddr3 */ +#define DDR3_BL8 (0) +#define DDR3_BC4_8 (1) +#define DDR3_BC4 (2) +#define DDR3_CL(n) (((((n) - 4) & 0x7) << 4)\
| ((((n) - 4) & 0x8) >> 1))
+#define DDR3_WR(n) (((n) & 0x7) << 9) +#define DDR3_DLL_RESET (1 << 8) +#define DDR3_DLL_DERESET (0 << 8)
+/* mr1 for ddr3 */ +#define DDR3_DLL_ENABLE (0) +#define DDR3_DLL_DISABLE (1) +#define DDR3_MR1_AL(n) (((n) & 0x3) << 3)
+#define DDR3_DS_40 (0) +#define DDR3_DS_34 BIT(1) +#define DDR3_DS_MASK ((1 << 1) | (1 << 5)) +#define DDR3_RTT_NOM_MASK ((1 << 2) | (1 << 6) | (1 << 9)) +#define DDR3_RTT_NOM_DIS (0) +#define DDR3_RTT_NOM_60 BIT(2) +#define DDR3_RTT_NOM_120 BIT(6) +#define DDR3_RTT_NOM_40 ((1 << 2) | (1 << 6)) +#define DDR3_TDQS BIT(11)
+/* mr2 for ddr3 */ +#define DDR3_MR2_CWL(n) ((((n) - 5) & 0x7) << 3) +#define DDR3_RTT_WR_DIS (0) +#define DDR3_RTT_WR_60 (1 << 9) +#define DDR3_RTT_WR_120 (2 << 9)
- MR0 (Device Information)
- 0:DAI complete, 1:DAI still in progress
+#define LPDDR2_DAI (0x1) +/* 0:S2 or S4 SDRAM, 1:NVM */ +#define LPDDR2_DI (0x1 << 1) +/* 0:DNV not supported, 1:DNV supported */ +#define LPDDR2_DNVI (0x1 << 2) +#define LPDDR2_RZQI (0x3 << 3)
- 00:RZQ self test not supported,
- 01:ZQ-pin may connect to VDDCA or float
- 10:ZQ-pin may short to GND.
- 11:ZQ-pin self test completed, no error condition detected.
+/* MR1 (Device Feature) */ +#define LPDDR2_BL4 (0x2) +#define LPDDR2_BL8 (0x3) +#define LPDDR2_BL16 (0x4) +#define LPDDR2_N_WR(n) (((n) - 2) << 5)
+/* MR2 (Device Feature 2) */ +#define LPDDR2_RL3_WL1 (0x1) +#define LPDDR2_RL4_WL2 (0x2) +#define LPDDR2_RL5_WL2 (0x3) +#define LPDDR2_RL6_WL3 (0x4) +#define LPDDR2_RL7_WL4 (0x5) +#define LPDDR2_RL8_WL4 (0x6)
+/* MR3 (IO Configuration 1) */ +#define LPDDR2_DS_34 (0x1) +#define LPDDR2_DS_40 (0x2) +#define LPDDR2_DS_48 (0x3) +#define LPDDR2_DS_60 (0x4) +#define LPDDR2_DS_80 (0x6) +/* optional */ +#define LPDDR2_DS_120 (0x7)
+/* MR4 (Device Temperature) */ +#define LPDDR2_TREF_MASK (0x7) +#define LPDDR2_4_TREF (0x1) +#define LPDDR2_2_TREF (0x2) +#define LPDDR2_1_TREF (0x3) +#define LPDDR2_025_TREF (0x5) +#define LPDDR2_025_TREF_DERATE (0x6)
+#define LPDDR2_TUF (0x1 << 7)
+/* MR8 (Basic configuration 4) */ +#define LPDDR2_S4 (0x0) +#define LPDDR2_S2 (0x1) +#define LPDDR2_N (0x2) +/* Unit:MB */ +#define LPDDR2_DENSITY(mr8) (8 << (((mr8) >> 2) & 0xf)) +#define LPDDR2_IO_WIDTH(mr8) (32 >> (((mr8) >> 6) & 0x3))
+/* MR10 (Calibration) */ +#define LPDDR2_ZQINIT (0xff) +#define LPDDR2_ZQCL (0xab) +#define LPDDR2_ZQCS (0x56) +#define LPDDR2_ZQRESET (0xc3)
+/* MR16 (PASR Bank Mask), S2 SDRAM Only */ +#define LPDDR2_PASR_FULL (0x0) +#define LPDDR2_PASR_1_2 (0x1) +#define LPDDR2_PASR_1_4 (0x2) +#define LPDDR2_PASR_1_8 (0x3)
- 0:DAI complete,
- 1:DAI still in progress
+#define LPDDR3_DAI (0x1) +/*
+#define LPDDR3_RZQI (0x3 << 3) +/*
- 0:DRAM does not support WL(Set B),
- 1:DRAM support WL(Set B)
+#define LPDDR3_WL_SUPOT BIT(6) +/*
- 0:DRAM does not support RL=3,nWR=3,WL=1;
- 1:DRAM supports RL=3,nWR=3,WL=1 for frequencies <=166
+#define LPDDR3_RL3_SUPOT BIT(7)
+/* MR1 (Device Feature) */ +#define LPDDR3_BL8 (0x3) +#define LPDDR3_N_WR(n) ((n) << 5)
+/* MR2 (Device Feature 2), WL Set A,default */ +/* <=166MHz,optional*/ +#define LPDDR3_RL3_WL1 (0x1) +/* <=400MHz*/ +#define LPDDR3_RL6_WL3 (0x4) +/* <=533MHz*/ +#define LPDDR3_RL8_WL4 (0x6) +/* <=600MHz*/ +#define LPDDR3_RL9_WL5 (0x7) +/* <=667MHz,default*/ +#define LPDDR3_RL10_WL6 (0x8) +/* <=733MHz*/ +#define LPDDR3_RL11_WL6 (0x9) +/* <=800MHz*/ +#define LPDDR3_RL12_WL6 (0xa) +/* <=933MHz*/ +#define LPDDR3_RL14_WL8 (0xc) +/* <=1066MHz*/ +#define LPDDR3_RL16_WL8 (0xe)
+/* WL Set B, optional */ +/* <=667MHz,default*/ +#define LPDDR3_RL10_WL8 (0x8) +/* <=733MHz*/ +#define LPDDR3_RL11_WL9 (0x9) +/* <=800MHz*/ +#define LPDDR3_RL12_WL9 (0xa) +/* <=933MHz*/ +#define LPDDR3_RL14_WL11 (0xc) +/* <=1066MHz*/ +#define LPDDR3_RL16_WL13 (0xe)
+/* 1:enable nWR programming > 9(default)*/ +#define LPDDR3_N_WRE BIT(4) +/* 1:Select WL Set B*/ +#define LPDDR3_WL_S BIT(6) +/* 1:enable*/ +#define LPDDR3_WR_LEVEL BIT(7)
+/* MR3 (IO Configuration 1) */ +#define LPDDR3_DS_34 (0x1) +#define LPDDR3_DS_40 (0x2) +#define LPDDR3_DS_48 (0x3) +#define LPDDR3_DS_60 (0x4) +#define LPDDR3_DS_80 (0x6) +#define LPDDR3_DS_34D_40U (0x9) +#define LPDDR3_DS_40D_48U (0xa) +#define LPDDR3_DS_34D_48U (0xb)
+/* MR4 (Device Temperature) */ +#define LPDDR3_TREF_MASK (0x7) +/* SDRAM Low temperature operating limit exceeded */ +#define LPDDR3_LT_EXED (0x0) +#define LPDDR3_4_TREF (0x1) +#define LPDDR3_2_TREF (0x2) +#define LPDDR3_1_TREF (0x3) +#define LPDDR3_05_TREF (0x4) +#define LPDDR3_025_TREF (0x5) +#define LPDDR3_025_TREF_DERATE (0x6) +/* SDRAM High temperature operating limit exceeded */ +#define LPDDR3_HT_EXED (0x7)
+/* 1:value has changed since last read of MR4 */ +#define LPDDR3_TUF (0x1 << 7)
+/* MR8 (Basic configuration 4) */ +#define LPDDR3_S8 (0x3) +#define LPDDR3_DENSITY(mr8) (8 << (((mr8) >> 2) & 0xf)) +#define LPDDR3_IO_WIDTH(mr8) (32 >> (((mr8) >> 6) & 0x3))
+/* MR10 (Calibration) */ +#define LPDDR3_ZQINIT (0xff) +#define LPDDR3_ZQCL (0xab) +#define LPDDR3_ZQCS (0x56) +#define LPDDR3_ZQRESET (0xc3)
+/* MR11 (ODT Control) */ +#define LPDDR3_ODT_60 (1) +#define LPDDR3_ODT_120 (2) +#define LPDDR3_ODT_240 (3) +#define LPDDR3_ODT_DIS (0)
+/* MR2 (Device Feature 2) */ +/* RL & nRTP for DBI-RD Disabled */ +#define LPDDR4_RL6_NRTP8 (0x0) +#define LPDDR4_RL10_NRTP8 (0x1) +#define LPDDR4_RL14_NRTP8 (0x2) +#define LPDDR4_RL20_NRTP8 (0x3) +#define LPDDR4_RL24_NRTP10 (0x4) +#define LPDDR4_RL28_NRTP12 (0x5) +#define LPDDR4_RL32_NRTP14 (0x6) +#define LPDDR4_RL36_NRTP16 (0x7) +/* RL & nRTP for DBI-RD Disabled */ +#define LPDDR4_RL12_NRTP8 (0x1) +#define LPDDR4_RL16_NRTP8 (0x2) +#define LPDDR4_RL22_NRTP8 (0x3) +#define LPDDR4_RL28_NRTP10 (0x4) +#define LPDDR4_RL32_NRTP12 (0x5) +#define LPDDR4_RL36_NRTP14 (0x6) +#define LPDDR4_RL40_NRTP16 (0x7) +/* WL Set A,default */ +#define LPDDR4_A_WL4 (0x0 << 3) +#define LPDDR4_A_WL6 (0x1 << 3) +#define LPDDR4_A_WL8 (0x2 << 3) +#define LPDDR4_A_WL10 (0x3 << 3) +#define LPDDR4_A_WL12 (0x4 << 3) +#define LPDDR4_A_WL14 (0x5 << 3) +#define LPDDR4_A_WL16 (0x6 << 3) +#define LPDDR4_A_WL18 (0x7 << 3) +/* WL Set B, optional */ +#define LPDDR4_B_WL4 (0x0 << 3) +#define LPDDR4_B_WL8 (0x1 << 3) +#define LPDDR4_B_WL12 (0x2 << 3) +#define LPDDR4_B_WL18 (0x3 << 3) +#define LPDDR4_B_WL22 (0x4 << 3) +#define LPDDR4_B_WL26 (0x5 << 3) +#define LPDDR4_B_WL30 (0x6 << 3) +#define LPDDR4_B_WL34 (0x7 << 3) +/* 1:Select WL Set B*/ +#define LPDDR4_WL_B BIT(6) +/* 1:enable*/ +#define LPDDR4_WR_LEVEL BIT(7)
+/* MR3 */ +#define LPDDR4_VDDQ_2_5 (0) +#define LPDDR4_VDDQ_3 (1) +#define LPDDR4_PU_CAL_MASK (1) +#define LPDDR4_WRPST_0_5_TCK (0 << 1) +#define LPDDR4_WRPST_1_5_TCK (1 << 1) +#define LPDDR4_PPR_EN (1 << 2) +/* PDDS */ +#define LPDDR4_PDDS_MASK (0x7 << 3) +#define LPDDR4_PDDS_SHIFT (3) +#define LPDDR4_PDDS_240 (0x1 << 3) +#define LPDDR4_PDDS_120 (0x2 << 3) +#define LPDDR4_PDDS_80 (0x3 << 3) +#define LPDDR4_PDDS_60 (0x4 << 3) +#define LPDDR4_PDDS_48 (0x5 << 3) +#define LPDDR4_PDDS_40 (0x6 << 3) +#define LPDDR4_DBI_RD_EN BIT(6) +#define LPDDR4_DBI_WR_EN BIT(7)
+/* MR11 (ODT Control) */ +#define LPDDR4_DQODT_MASK (0x7) +#define LPDDR4_DQODT_SHIFT (0x0) +#define LPDDR4_DQODT_240 (1) +#define LPDDR4_DQODT_120 (2) +#define LPDDR4_DQODT_80 (3) +#define LPDDR4_DQODT_60 (4) +#define LPDDR4_DQODT_48 (5) +#define LPDDR4_DQODT_40 (6) +#define LPDDR4_DQODT_DIS (0) +#define LPDDR4_CAODT_MASK (0x7 << 4) +#define LPDDR4_CAODT_SHIFT (4) +#define LPDDR4_CAODT_240 (1 << 4) +#define LPDDR4_CAODT_120 (2 << 4) +#define LPDDR4_CAODT_80 (3 << 4) +#define LPDDR4_CAODT_60 (4 << 4) +#define LPDDR4_CAODT_48 (5 << 4) +#define LPDDR4_CAODT_40 (6 << 4) +#define LPDDR4_CAODT_DIS (0 << 4)
+/* MR22 */ +#define LPDDR4_ODTE_CK_SHIFT (3) +#define LPDDR4_ODTE_CS_SHIFT (4) +#define LPDDR4_ODTD_CA_SHIFT (5) +#define LPDDR4_SOC_ODT_MASK (0x7) +#define LPDDR4_SOC_ODT_SHIFT (0) +#define LPDDR4_SOC_ODT_240 (1) +#define LPDDR4_SOC_ODT_120 (2) +#define LPDDR4_SOC_ODT_80 (3) +#define LPDDR4_SOC_ODT_60 (4) +#define LPDDR4_SOC_ODT_48 (5) +#define LPDDR4_SOC_ODT_40 (6) +#define LPDDR4_SOC_ODT_DIS (0)
+/* LPDDR4x */ +/* MR3 */ +#define LPDDR4X_VDDQ_0_6 (0) +#define LPDDR4X_VDDQ_0_5 (1)
+/* mr0 for ddr4 */ +#define DDR4_BL8 (0) +#define DDR4_BC4_8 (1) +#define DDR4_BC4 (2) +#define DDR4_WR_RTP(n) ((n) << 9) +#define DDR4_CL(n) ((((n) & 0xe) << 3) | ((n) & 1) << 2) +#define DDR4_DLL_RESET(n) ((n) << 8) +#define DDR4_DLL_ON BIT(0) +#define DDR4_DLL_OFF (0 << 0)
+/* mr1 for ddr4 */ +#define DDR4_AL ((n) << 3) +#define DDR4_DS_34 (0) +#define DDR4_DS_48 BIT(1) +#define DDR4_DS_MASK (0x3 << 1) +#define DDR4_RTT_NOM_MASK (0x7 << 8) +#define DDR4_RTT_NOM_DIS (0) +#define DDR4_RTT_NOM_60 BIT(8) +#define DDR4_RTT_NOM_120 (2 << 8) +#define DDR4_RTT_NOM_40 (0x3 << 8) +#define DDR4_RTT_NOM_240 (0x4 << 8) +#define DDR4_RTT_NOM_48 (0x5 << 8) +#define DDR4_RTT_NOM_80 (0x6 << 8) +#define DDR4_RTT_NOM_34 (0x7 << 8)
+/* mr2 for ddr4 */ +#define DDR4_MR2_CWL(n) ((n) << 3) +#define DDR4_RTT_WR_DIS (0) +#define DDR4_RTT_WR_120 BIT(9) +#define DDR4_RTT_WR_240 (2 << 9)
+/* mr4 for ddr4 */ +#define DDR4_READ_PREAMBLE(n) ((n) << 11) +#define DDR4_WRITE_PREAMBLE(n) ((n) << 12) +#define DDR4_READ_PREAMBLE_TRAIN(n) ((n) << 10)
+/* mr5 for ddr4 */ +#define DDR4_RD_DBI(n) ((n) << 12) +#define DDR4_WR_DBI(n) ((n) << 11) +#define DDR4_DM(n) ((n) << 10) +#define DDR4_RTT_PARK_DIS (0 << 6) +#define DDR4_RTT_PARK_60 (1 << 6) +#define DDR4_RTT_PARK_120 (2 << 6) +#define DDR4_RTT_PARK_40 (3 << 6) +#define DDR4_RTT_PARK_240 (4 << 6) +#define DDR4_RTT_PARK_48 (5 << 6) +#define DDR4_RTT_PARK_80 (6 << 6) +#define DDR4_RTT_PARK_34 (7 << 6) +#define DIS_ODT_PD (1 << 5) +#define EN_ODT_PD (0 << 5)
+/* mr6 for ddr4 */ +#define DDR4_TCCD_L(n) (((n) - 4) << 10)
+#define PS_2_CLK(freq, ps) (((uint64_t)(ps) / 100 * (uint64_t)(freq) +\
9999) / 10000)
+#endif /* __ROCKCHIP_DRAM_SPEC_TIMING_H__ */ diff --git a/arch/arm/include/asm/arch-rockchip/sdram_common.h b/arch/arm/include/asm/arch-rockchip/sdram_common.h index dd316f771a..8eb221276a 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_common.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_common.h @@ -15,6 +15,210 @@ #define MIN(a, b) (((a) > (b)) ? (b) : (a)) #define MAX(a, b) (((a) > (b)) ? (a) : (b))
+/* get head info for initial */ +#define DDR_FREQ_F0_SHIFT (0) +#define DDR_FREQ_F1_SHIFT (12) +#define DDR_FREQ_F2_SHIFT (0) +#define DDR_FREQ_F3_SHIFT (12) +#define DDR_FREQ_F4_SHIFT (0) +#define DDR_FREQ_F5_SHIFT (12) +#define DDR_FREQ_MASK (0xfff)
+#define UART_INFO_ID_SHIFT (28) +#define UART_INFO_IOMUX_SHIFT (24) +#define UART_INFO_BAUD_SHIFT (0) +#define UART_INFO_ID(n) (((n) >> 28) & 0xf) +#define UART_INFO_IOMUX(n) (((n) >> 24) & 0xf) +#define UART_INFO_BAUD(n) ((n) & 0xffffff)
+/* g_ch_info[15:0]: g_stdby_idle */ +#define STANDBY_IDLE(n) ((n) & 0xffff)
+#define SR_INFO(n) (((n) >> 16) & 0xffff) +#define PD_INFO(n) ((n) & 0xffff)
+#define FIRST_SCAN_CH(n) (((n) >> 28) & 0xf) +#define CHANNEL_MASK(n) (((n) >> 24) & 0xf) +#define STRIDE_TYPE(n) (((n) >> 16) & 0xff)
+#define DDR_2T_INFO(n) ((n) & 1) +#define PLL_SSMOD_SPREAD(n) (((n) >> 1) & 0xff) +#define PLL_SSMOD_DIV(n) (((n) >> 9) & 0xff) +#define PLL_SSMOD_DOWNSPREAD(n) (((n) >> 17) & 0x3)
+/* sdram_head_info_v2 define */ +/* for *_drv_odten and *_drv_odtoff */ +#define PHY_DQ_DRV_SHIFT 0 +#define PHY_CA_DRV_SHIFT 8 +#define PHY_CLK_DRV_SHIFT 16 +#define DRAM_DQ_DRV_SHIFT 24 +#define DRV_INFO_PHY_DQ_DRV(n) ((n) & 0xff) +#define DRV_INFO_PHY_CA_DRV(n) (((n) >> PHY_CA_DRV_SHIFT) & 0xff) +#define DRV_INFO_PHY_CLK_DRV(n) (((n) >> PHY_CLK_DRV_SHIFT) & 0xff) +#define DRV_INFO_DRAM_DQ_DRV(n) (((n) >> DRAM_DQ_DRV_SHIFT) & 0xff)
+/* for *_odt_info */ +#define DRAM_ODT_SHIFT 0 +#define PHY_ODT_SHIFT 8 +#define PHY_ODT_PUUP_EN_SHIFT 18 +#define PHY_ODT_PUDN_EN_SHIFT 19 +#define ODT_INFO_DRAM_ODT(n) (((n) >> DRAM_ODT_SHIFT) & 0xff) +#define ODT_INFO_PHY_ODT(n) (((n) >> PHY_ODT_SHIFT) & 0x3ff) +#define ODT_INFO_PULLUP_EN(n) (((n) >> PHY_ODT_PUUP_EN_SHIFT) & 1) +#define ODT_INFO_PULLDOWN_EN(n) (((n) >> PHY_ODT_PUDN_EN_SHIFT) & 1)
+/* for *odt_en_freq; */ +#define DRAM_ODT_EN_FREQ_SHIFT 0 +#define PHY_ODT_EN_FREQ_SHIFT 12 +#define DRAMODT_EN_FREQ(n) (((n) >> DRAM_ODT_EN_FREQ_SHIFT) & \
0xfff)
+#define PHYODT_EN_FREQ(n) (((n) >> PHY_ODT_EN_FREQ_SHIFT) & 0xfff)
+#define PHY_DQ_SR_SHIFT 0 +#define PHY_CA_SR_SHIFT 8 +#define PHY_CLK_SR_SHIFT 16 +#define DQ_SR_INFO(n) (((n) >> PHY_DQ_SR_SHIFT) & 0xff) +#define CA_SR_INFO(n) (((n) >> PHY_CA_SR_SHIFT) & 0xff) +#define CLK_SR_INFO(n) (((n) >> PHY_CLK_SR_SHIFT) & 0xff)
+/* LP4 */ +#define LP4_CA_ODT_SHIFT (18) +#define LP4_DRV_PU_CAL_ODTEN_SHIFT (26) +#define LP4_DRV_PU_CAL_ODTOFF_SHIFT (27) +#define PHY_LP4_DRV_PULLDOWN_EN_ODTEN_SHIFT (28) +#define PHY_LP4_DRV_PULLDOWN_EN_ODTOFF_SHIFT (29) +#define ODT_INFO_LP4_CA_ODT(n) (((n) >> LP4_CA_ODT_SHIFT) & \
0xff)
+#define LP4_DRV_PU_CAL_ODTEN(n) \
- (((n) >> LP4_DRV_PU_CAL_ODTEN_SHIFT) & 1)
+#define LP4_DRV_PU_CAL_ODTOFF(n) \
- (((n) >> LP4_DRV_PU_CAL_ODTOFF_SHIFT) & 1)
+#define PHY_LP4_DRV_PULLDOWN_EN_ODTEN(n) \
- (((n) >> PHY_LP4_DRV_PULLDOWN_EN_ODTEN_SHIFT) & 1)
+#define PHY_LP4_DRV_PULLDOWN_EN_ODTOFF(n) \
- (((n) >> PHY_LP4_DRV_PULLDOWN_EN_ODTOFF_SHIFT) & 1)
+#define PHY_LP4_CS_DRV_ODTEN_SHIFT (0) +#define PHY_LP4_CS_DRV_ODTOFF_SHIFT (8) +#define LP4_ODTE_CK_SHIFT (16) +#define LP4_ODTE_CS_EN_SHIFT (17) +#define LP4_ODTD_CA_EN_SHIFT (18) +#define PHY_LP4_CS_DRV_ODTEN(n) \
- (((n) >> PHY_LP4_CS_DRV_ODTEN_SHIFT) & 0xff)
+#define PHY_LP4_CS_DRV_ODTOFF(n) \
- (((n) >> PHY_LP4_CS_DRV_ODTOFF_SHIFT) & 0xff)
+#define LP4_ODTE_CK_EN(n) (((n) >> LP4_ODTE_CK_SHIFT) & 1) +#define LP4_ODTE_CS_EN(n) (((n) >> LP4_ODTE_CS_EN_SHIFT) & 1) +#define LP4_ODTD_CA_EN(n) (((n) >> LP4_ODTD_CA_EN_SHIFT) & 1)
+#define PHY_LP4_DQ_VREF_SHIFT (0) +#define LP4_DQ_VREF_SHIFT (10) +#define LP4_CA_VREF_SHIFT (20)
+#define PHY_LP4_DQ_VREF(n) \
- (((n) >> PHY_LP4_DQ_VREF_SHIFT) & 0x3ff)
+#define LP4_DQ_VREF(n) (((n) >> LP4_DQ_VREF_SHIFT) & 0x3ff) +#define LP4_CA_VREF(n) (((n) >> LP4_CA_VREF_SHIFT) & 0x3ff)
+#define LP4_DQ_ODT_EN_FREQ_SHIFT (0) +#define PHY_LP4_ODT_EN_FREQ_SHIFT (12) +#define LP4_CA_ODT_EN_FREQ_SHIFT (0) +#define PHY_LP4_ODT_EN_FREQ(n) \
- (((n) >> PHY_LP4_ODT_EN_FREQ_SHIFT) & 0xfff)
+#define LP4_DQ_ODT_EN_FREQ(n) \
- (((n) >> LP4_DQ_ODT_EN_FREQ_SHIFT) & 0xfff)
+#define LP4_CA_ODT_EN_FREQ(n) \
- (((n) >> LP4_CA_ODT_EN_FREQ_SHIFT) & 0xfff)
+struct sdram_head_info_v0 {
- u32 start_tag;
- u32 version_info;
- u32 gcpu_gen_freq;
- u32 g_d2_lp2_freq;
- u32 g_d3_lp3_freq;
- u32 g_d4_lp4_freq;
- u32 g_uart_info;
- u32 g_sr_pd_idle;
- u32 g_ch_info;
- u32 g_2t_info;
- u32 reserved11;
- u32 reserved12;
- u32 reserved13;
+struct index_info {
- u8 offset;
- u8 size;
+struct sdram_head_info_index_v2 {
- u32 start_tag;
- u32 version_info;
- struct index_info cpu_gen_index;
- struct index_info global_index;
- struct index_info ddr2_index;
- struct index_info ddr3_index;
- struct index_info ddr4_index;
- struct index_info ddr5_index;
- struct index_info lp2_index;
- struct index_info lp3_index;
- struct index_info lp4_index;
- struct index_info lp5_index;
- struct index_info skew_index;
- struct index_info dq_map_index;
- struct index_info lp4x_index;
- struct index_info reserved;
+struct global_info {
- u32 uart_info;
- u32 sr_pd_info;
- u32 ch_info;
- u32 info_2t;
- u32 reserved[4];
+struct ddr2_3_4_lp2_3_info {
- u32 ddr_freq0_1;
- u32 ddr_freq2_3;
- u32 ddr_freq4_5;
- u32 drv_when_odten;
- u32 drv_when_odtoff;
- u32 odt_info;
- u32 odten_freq;
- u32 sr_when_odten;
- u32 sr_when_odtoff;
+struct lp4_info {
- u32 ddr_freq0_1;
- u32 ddr_freq2_3;
- u32 ddr_freq4_5;
- u32 odt_info;
- u32 dq_odten_freq;
- u32 ca_odten_freq;
- u32 cs_drv_ca_odt_info;
- u32 vref_when_odten;
- u32 vref_when_odtoff;
+struct dq_map_info {
- u32 byte_map[2];
- u32 lp3_dq0_7_map;
- u32 lp2_dq0_7_map;
- u32 ddr4_dq_map[4];
- struct sdram_cap_info { unsigned int rank; /* dram column number, 0 means this channel is invalid */
@@ -46,6 +250,14 @@ struct sdram_base_params { };
#define DDR_SYS_REG_VERSION (0x2) +/* for modify tRFC and related timing */ +#define DIE_CAP_512MBIT 64 +#define DIE_CAP_1GBIT 128 +#define DIE_CAP_2GBIT 256 +#define DIE_CAP_4GBIT 512 +#define DIE_CAP_8GBIT 1024 +#define DIE_CAP_16GBIT 2048 +#define DIE_CAP_32GBIT 4096 /*
- sys_reg2 bitfield struct
- [31] row_3_4_ch1
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_msch.h b/arch/arm/include/asm/arch-rockchip/sdram_msch.h index cfb3d9cc86..d1926f4bf2 100644 --- a/arch/arm/include/asm/arch-rockchip/sdram_msch.h +++ b/arch/arm/include/asm/arch-rockchip/sdram_msch.h @@ -57,6 +57,18 @@ union noc_devtodev0 { } b; };
+union noc_devtodev_rv1126 {
- u32 d32;
- struct {
unsigned busrdtord : 3;
unsigned reserved0 : 1;
unsigned busrdtowr : 4;
unsigned buswrtord : 4;
unsigned buswrtowr : 3;
unsigned reserved2 : 17;
- } b;
- union noc_ddrmode { u32 d32; struct {
diff --git a/arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h b/arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h new file mode 100644 index 0000000000..5b64ec3352 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h @@ -0,0 +1,93 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef _ASM_ARCH_SDRAM_RK1126_PHY_H +#define _ASM_ARCH_SDRAM_RK1126_PHY_H
+/* PHY_REG0 */ +#define DIGITAL_DERESET BIT(3) +#define ANALOG_DERESET BIT(2) +#define DIGITAL_RESET (0 << 3) +#define ANALOG_RESET (0 << 2)
+/* PHY_REG1 */ +#define PHY_DDR2 (0) +#define PHY_LPDDR2 (1) +#define PHY_DDR3 (2) +#define PHY_LPDDR3 (3) +#define PHY_DDR4 (4) +#define PHY_DDR5 (5) +#define PHY_BL_4 (0 << 3) +#define PHY_BL_8_OR_16 BIT(3)
+/* PHY_REG2 */ +#define PHY_DTT_EN BIT(0) +#define PHY_DTT_DISB (0 << 0) +#define PHY_WRITE_LEVELING_EN BIT(2) +#define PHY_WRITE_LEVELING_DISB (0 << 2) +#define PHY_SELECT_CS0 (2) +#define PHY_SELECT_CS1 (1) +#define PHY_SELECT_CS0_1 (0) +#define PHY_WRITE_LEVELING_SELECTCS(n) ((n) << 6) +#define PHY_DATA_TRAINING_SELECTCS(n) ((n) << 4)
+/* PHY_REGf */ +#define PHY_DQ_WIDTH_MASK (0xf)
+/* PHY_REG51 */ +#define PHY_PBDIV_BIT9_MASK BIT(0) +#define PHY_PBDIV_BIT9_SHIFT (0) +#define PHY_POSTDIV_EN_MASK BIT(7) +#define PHY_POSTDIV_EN_SHIFT (7)
+/* PHY_REG52 */ +#define PHY_PREDIV_MASK (0x1F) +#define PHY_PREDIV_SHIFT (0)
+/* PHY_REG53*/ +#define PHY_POSTDIV_MASK (0x7) +#define PHY_POSTDIV_SHIFT (5) +#define PHY_PD_DISB BIT(3)
+/* PHY_REG90 */ +#define PHY_PLL_LOCK BIT(2)
+struct ca_skew {
- u32 a0_a3_a3_cke1_a_de_skew;
- u32 a1_ba1_null_cke0_b_de_skew;
- u32 a2_a9_a9_a4_a_de_skew;
- u32 a3_a15_null_a5_b_de_skew;
- u32 a4_a6_a6_ck_a_de_skew;
- u32 a5_a12_null_odt0_b_de_skew;
- u32 a6_ba2_null_a0_a_de_skew;
- u32 a7_a4_a4_odt0_a_de_skew;
- u32 a8_a1_a1_cke0_a_de_skew;
- u32 a9_a5_a5_a5_a_de_skew;
- u32 a10_a8_a8_clkb_a_de_skew;
- u32 a11_a7_a7_ca2_a_de_skew;
- u32 a12_rasn_null_ca1_a_de_skew;
- u32 a13_a13_null_ca3_a_de_skew;
- u32 a14_a14_null_csb1_b_de_skew;
- u32 a15_a10_null_ca0_b_de_skew;
- u32 a16_a11_null_csb0_b_de_skew;
- u32 a17_null_null_null_de_skew;
- u32 ba0_csb1_csb1_csb0_a_de_skew;
- u32 ba1_wen_null_cke1_b_de_skew;
- u32 bg0_odt1_odt1_csb1_a_de_skew;
- u32 bg1_a2_a2_odt1_a_de_skew;
- u32 cke0_casb_null_ca1_b_de_skew;
- u32 ck_ck_ck_ck_b_de_skew;
- u32 ckb_ckb_ckb_ckb_b_de_skew;
- u32 csb0_odt0_odt0_ca2_b_de_skew;
- u32 odt0_csb0_csb0_ca4_b_de_skew;
- u32 resetn_resetn_null_resetn_de_skew;
- u32 actn_cke_cke_ca3_b_de_skew;
- u32 null_null_null_null_de_skew;
- u32 csb1_ba0_null_null_de_skew;
- u32 odt1_a0_a0_odt1_b_de_skew;
+#define PHY_REG(base, n) ((base) + 4 * (n)) +#endif /* _ASM_ARCH_SDRAM_RK1126_PHY_H */ diff --git a/arch/arm/include/asm/arch-rockchip/sdram_rv1126.h b/arch/arm/include/asm/arch-rockchip/sdram_rv1126.h new file mode 100644 index 0000000000..6a07436059 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/sdram_rv1126.h @@ -0,0 +1,420 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/*
+#ifndef _ASM_ARCH_SDRAM_RK1126_H +#define _ASM_ARCH_SDRAM_RK1126_H
+#include <asm/arch-rockchip/dram_spec_timing.h> +#include <asm/arch-rockchip/sdram.h> +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_msch.h> +#include <asm/arch-rockchip/sdram_pctl_px30.h> +#include <asm/arch-rockchip/sdram_phy_rv1126.h>
+#define AGINGX0_VAL (4) +#define AGING_CPU_VAL (0xff) +#define AGING_NPU_VAL (0xff) +#define AGING_OTHER_VAL (0x33)
+#define PATTERN (0x5aa5f00f)
+#define PHY_DDR3_RON_DISABLE (0) +#define PHY_DDR3_RON_455ohm (1) +#define PHY_DDR3_RON_230ohm (2) +#define PHY_DDR3_RON_153ohm (3) +#define PHY_DDR3_RON_115ohm (4) +#define PHY_DDR3_RON_91ohm (5) +#define PHY_DDR3_RON_76ohm (6) +#define PHY_DDR3_RON_65ohm (7) +#define PHY_DDR3_RON_57ohm (16) +#define PHY_DDR3_RON_51ohm (17) +#define PHY_DDR3_RON_46ohm (18) +#define PHY_DDR3_RON_41ohm (19) +#define PHY_DDR3_RON_38ohm (20) +#define PHY_DDR3_RON_35ohm (21) +#define PHY_DDR3_RON_32ohm (22) +#define PHY_DDR3_RON_30ohm (23) +#define PHY_DDR3_RON_28ohm (24) +#define PHY_DDR3_RON_27ohm (25) +#define PHY_DDR3_RON_25ohm (26) +#define PHY_DDR3_RON_24ohm (27) +#define PHY_DDR3_RON_23ohm (28) +#define PHY_DDR3_RON_22ohm (29) +#define PHY_DDR3_RON_21ohm (30) +#define PHY_DDR3_RON_20ohm (31)
+#define PHY_DDR3_RTT_DISABLE (0) +#define PHY_DDR3_RTT_561ohm (1) +#define PHY_DDR3_RTT_282ohm (2) +#define PHY_DDR3_RTT_188ohm (3) +#define PHY_DDR3_RTT_141ohm (4) +#define PHY_DDR3_RTT_113ohm (5) +#define PHY_DDR3_RTT_94ohm (6) +#define PHY_DDR3_RTT_81ohm (7) +#define PHY_DDR3_RTT_72ohm (16) +#define PHY_DDR3_RTT_64ohm (17) +#define PHY_DDR3_RTT_58ohm (18) +#define PHY_DDR3_RTT_52ohm (19) +#define PHY_DDR3_RTT_48ohm (20) +#define PHY_DDR3_RTT_44ohm (21) +#define PHY_DDR3_RTT_41ohm (22) +#define PHY_DDR3_RTT_38ohm (23) +#define PHY_DDR3_RTT_37ohm (24) +#define PHY_DDR3_RTT_34ohm (25) +#define PHY_DDR3_RTT_32ohm (26) +#define PHY_DDR3_RTT_31ohm (27) +#define PHY_DDR3_RTT_29ohm (28) +#define PHY_DDR3_RTT_28ohm (29) +#define PHY_DDR3_RTT_27ohm (30) +#define PHY_DDR3_RTT_25ohm (31)
+#define PHY_DDR4_LPDDR3_RON_DISABLE (0) +#define PHY_DDR4_LPDDR3_RON_482ohm (1) +#define PHY_DDR4_LPDDR3_RON_244ohm (2) +#define PHY_DDR4_LPDDR3_RON_162ohm (3) +#define PHY_DDR4_LPDDR3_RON_122ohm (4) +#define PHY_DDR4_LPDDR3_RON_97ohm (5) +#define PHY_DDR4_LPDDR3_RON_81ohm (6) +#define PHY_DDR4_LPDDR3_RON_69ohm (7) +#define PHY_DDR4_LPDDR3_RON_61ohm (16) +#define PHY_DDR4_LPDDR3_RON_54ohm (17) +#define PHY_DDR4_LPDDR3_RON_48ohm (18) +#define PHY_DDR4_LPDDR3_RON_44ohm (19) +#define PHY_DDR4_LPDDR3_RON_40ohm (20) +#define PHY_DDR4_LPDDR3_RON_37ohm (21) +#define PHY_DDR4_LPDDR3_RON_34ohm (22) +#define PHY_DDR4_LPDDR3_RON_32ohm (23) +#define PHY_DDR4_LPDDR3_RON_30ohm (24) +#define PHY_DDR4_LPDDR3_RON_28ohm (25) +#define PHY_DDR4_LPDDR3_RON_27ohm (26) +#define PHY_DDR4_LPDDR3_RON_25ohm (27) +#define PHY_DDR4_LPDDR3_RON_24ohm (28) +#define PHY_DDR4_LPDDR3_RON_23ohm (29) +#define PHY_DDR4_LPDDR3_RON_22ohm (30) +#define PHY_DDR4_LPDDR3_RON_21ohm (31)
+#define PHY_DDR4_LPDDR3_RTT_DISABLE (0) +#define PHY_DDR4_LPDDR3_RTT_586ohm (1) +#define PHY_DDR4_LPDDR3_RTT_294ohm (2) +#define PHY_DDR4_LPDDR3_RTT_196ohm (3) +#define PHY_DDR4_LPDDR3_RTT_148ohm (4) +#define PHY_DDR4_LPDDR3_RTT_118ohm (5) +#define PHY_DDR4_LPDDR3_RTT_99ohm (6) +#define PHY_DDR4_LPDDR3_RTT_85ohm (7) +#define PHY_DDR4_LPDDR3_RTT_76ohm (16) +#define PHY_DDR4_LPDDR3_RTT_67ohm (17) +#define PHY_DDR4_LPDDR3_RTT_60ohm (18) +#define PHY_DDR4_LPDDR3_RTT_55ohm (19) +#define PHY_DDR4_LPDDR3_RTT_50ohm (20) +#define PHY_DDR4_LPDDR3_RTT_46ohm (21) +#define PHY_DDR4_LPDDR3_RTT_43ohm (22) +#define PHY_DDR4_LPDDR3_RTT_40ohm (23) +#define PHY_DDR4_LPDDR3_RTT_38ohm (24) +#define PHY_DDR4_LPDDR3_RTT_36ohm (25) +#define PHY_DDR4_LPDDR3_RTT_34ohm (26) +#define PHY_DDR4_LPDDR3_RTT_32ohm (27) +#define PHY_DDR4_LPDDR3_RTT_31ohm (28) +#define PHY_DDR4_LPDDR3_RTT_29ohm (29) +#define PHY_DDR4_LPDDR3_RTT_28ohm (30) +#define PHY_DDR4_LPDDR3_RTT_27ohm (31)
+#define PHY_LPDDR4_RON_DISABLE (0) +#define PHY_LPDDR4_RON_501ohm (1) +#define PHY_LPDDR4_RON_253ohm (2) +#define PHY_LPDDR4_RON_168ohm (3) +#define PHY_LPDDR4_RON_126ohm (4) +#define PHY_LPDDR4_RON_101ohm (5) +#define PHY_LPDDR4_RON_84ohm (6) +#define PHY_LPDDR4_RON_72ohm (7) +#define PHY_LPDDR4_RON_63ohm (16) +#define PHY_LPDDR4_RON_56ohm (17) +#define PHY_LPDDR4_RON_50ohm (18) +#define PHY_LPDDR4_RON_46ohm (19) +#define PHY_LPDDR4_RON_42ohm (20) +#define PHY_LPDDR4_RON_38ohm (21) +#define PHY_LPDDR4_RON_36ohm (22) +#define PHY_LPDDR4_RON_33ohm (23) +#define PHY_LPDDR4_RON_31ohm (24) +#define PHY_LPDDR4_RON_29ohm (25) +#define PHY_LPDDR4_RON_28ohm (26) +#define PHY_LPDDR4_RON_26ohm (27) +#define PHY_LPDDR4_RON_25ohm (28) +#define PHY_LPDDR4_RON_24ohm (29) +#define PHY_LPDDR4_RON_23ohm (30) +#define PHY_LPDDR4_RON_22ohm (31)
+#define PHY_LPDDR4_RTT_DISABLE (0) +#define PHY_LPDDR4_RTT_604ohm (1) +#define PHY_LPDDR4_RTT_303ohm (2) +#define PHY_LPDDR4_RTT_202ohm (3) +#define PHY_LPDDR4_RTT_152ohm (4) +#define PHY_LPDDR4_RTT_122ohm (5) +#define PHY_LPDDR4_RTT_101ohm (6) +#define PHY_LPDDR4_RTT_87ohm (7) +#define PHY_LPDDR4_RTT_78ohm (16) +#define PHY_LPDDR4_RTT_69ohm (17) +#define PHY_LPDDR4_RTT_62ohm (18) +#define PHY_LPDDR4_RTT_56ohm (19) +#define PHY_LPDDR4_RTT_52ohm (20) +#define PHY_LPDDR4_RTT_48ohm (21) +#define PHY_LPDDR4_RTT_44ohm (22) +#define PHY_LPDDR4_RTT_41ohm (23) +#define PHY_LPDDR4_RTT_39ohm (24) +#define PHY_LPDDR4_RTT_37ohm (25) +#define PHY_LPDDR4_RTT_35ohm (26) +#define PHY_LPDDR4_RTT_33ohm (27) +#define PHY_LPDDR4_RTT_32ohm (28) +#define PHY_LPDDR4_RTT_30ohm (29) +#define PHY_LPDDR4_RTT_29ohm (30) +#define PHY_LPDDR4_RTT_27ohm (31)
+#define ADD_CMD_CA (0x150) +#define ADD_GROUP_CS0_A (0x170) +#define ADD_GROUP_CS0_B (0x1d0) +#define ADD_GROUP_CS1_A (0x1a0) +#define ADD_GROUP_CS1_B (0x200)
+/* PMUGRF */ +#define PMUGRF_OS_REG0 (0x200) +#define PMUGRF_OS_REG(n) (PMUGRF_OS_REG0 + (n) * 4) +#define PMUGRF_CON_DDRPHY_BUFFEREN_MASK (0x3 << (12 + 16)) +#define PMUGRF_CON_DDRPHY_BUFFEREN_EN (0x1 << 12) +#define PMUGRF_CON_DDRPHY_BUFFEREN_DIS (0x2 << 12)
+/* DDR GRF */ +#define DDR_GRF_CON(n) (0 + (n) * 4) +#define DDR_GRF_STATUS_BASE (0X100) +#define DDR_GRF_STATUS(n) (DDR_GRF_STATUS_BASE + (n) * 4) +#define DDR_GRF_LP_CON (0x20)
+#define SPLIT_MODE_32_L16_VALID (0) +#define SPLIT_MODE_32_H16_VALID (1) +#define SPLIT_MODE_16_L8_VALID (2) +#define SPLIT_MODE_16_H8_VALID (3)
+#define DDR_GRF_SPLIT_CON (0x10) +#define SPLIT_MODE_MASK (0x3) +#define SPLIT_MODE_OFFSET (9) +#define SPLIT_BYPASS_MASK (1) +#define SPLIT_BYPASS_OFFSET (8) +#define SPLIT_SIZE_MASK (0xff) +#define SPLIT_SIZE_OFFSET (0)
+/* SGRF SOC_CON13 */ +#define UPCTL2_ASRSTN_REQ(n) (((0x1 << 0) << 16) | ((n) << 0)) +#define UPCTL2_PSRSTN_REQ(n) (((0x1 << 1) << 16) | ((n) << 1)) +#define UPCTL2_SRSTN_REQ(n) (((0x1 << 2) << 16) | ((n) << 2))
+/* CRU define */ +/* CRU_PLL_CON0 */ +#define PB(n) ((0x1 << (15 + 16)) | ((n) << 15)) +#define POSTDIV1(n) ((0x7 << (12 + 16)) | ((n) << 12)) +#define FBDIV(n) ((0xFFF << 16) | (n))
+/* CRU_PLL_CON1 */ +#define RSTMODE(n) ((0x1 << (15 + 16)) | ((n) << 15)) +#define RST(n) ((0x1 << (14 + 16)) | ((n) << 14)) +#define PD(n) ((0x1 << (13 + 16)) | ((n) << 13)) +#define DSMPD(n) ((0x1 << (12 + 16)) | ((n) << 12)) +#define LOCK(n) (((n) >> 10) & 0x1) +#define POSTDIV2(n) ((0x7 << (6 + 16)) | ((n) << 6)) +#define REFDIV(n) ((0x3F << 16) | (n))
+/* CRU_PLL_CON3 */ +#define SSMOD_SPREAD(n) ((0x1f << (8 + 16)) | ((n) << 8)) +#define SSMOD_DIVVAL(n) ((0xf << (4 + 16)) | ((n) << 4)) +#define SSMOD_DOWNSPREAD(n) ((0x1 << (3 + 16)) | ((n) << 3)) +#define SSMOD_RESET(n) ((0x1 << (2 + 16)) | ((n) << 2)) +#define SSMOD_DIS_SSCG(n) ((0x1 << (1 + 16)) | ((n) << 1)) +#define SSMOD_BP(n) ((0x1 << (0 + 16)) | ((n) << 0))
+/* CRU_MODE */ +#define CLOCK_FROM_XIN_OSC (0) +#define CLOCK_FROM_PLL (1) +#define CLOCK_FROM_RTC_32K (2) +#define DPLL_MODE(n) ((0x3 << (2 + 16)) | ((n) << 2))
+/* CRU_SOFTRESET_CON1 */ +#define DDRPHY_PSRSTN_REQ(n) (((0x1 << 14) << 16) | ((n) << 14)) +#define DDRPHY_SRSTN_REQ(n) (((0x1 << 15) << 16) | ((n) << 15)) +/* CRU_CLKGATE_CON2 */ +#define DDR_MSCH_EN_MASK ((0x1 << 10) << 16) +#define DDR_MSCH_EN_SHIFT (10)
+/* CRU register */ +#define CRU_PLL_CON(pll_id, n) ((pll_id) * 0x20 + (n) * 4) +#define CRU_MODE (0xa0) +#define CRU_GLB_CNT_TH (0xb0) +#define CRU_CLKSEL_CON_BASE 0x100 +#define CRU_CLKSELS_CON(i) (CRU_CLKSEL_CON_BASE + ((i) * 4)) +#define CRU_CLKGATE_CON_BASE 0x230 +#define CRU_CLKGATE_CON(i) (CRU_CLKGATE_CON_BASE + ((i) * 4)) +#define CRU_CLKSFTRST_CON_BASE 0x300 +#define CRU_CLKSFTRST_CON(i) (CRU_CLKSFTRST_CON_BASE + ((i) * 4))
+/* SGRF_SOC_CON2 */ +#define MSCH_AXI_BYPASS_ALL_MASK (1) +#define MSCH_AXI_BYPASS_ALL_SHIFT (15)
+/* SGRF_SOC_CON12 */ +#define CLK_DDR_UPCTL_EN_MASK ((0x1 << 2) << 16) +#define CLK_DDR_UPCTL_EN_SHIFT (2) +#define ACLK_DDR_UPCTL_EN_MASK ((0x1 << 0) << 16) +#define ACLK_DDR_UPCTL_EN_SHIFT (0)
+/* DDRGRF DDR CON2 */ +#define DFI_FREQ_CHANGE_ACK BIT(10) +/* DDRGRF status8 */ +#define DFI_FREQ_CHANGE_REQ BIT(19)
+struct rv1126_ddrgrf {
- u32 ddr_grf_con[4];
- u32 grf_ddrsplit_con;
- u32 reserved1[(0x20 - 0x10) / 4 - 1];
- u32 ddr_grf_lp_con;
- u32 reserved2[(0x40 - 0x20) / 4 - 1];
- u32 grf_ddrphy_con[6];
- u32 reserved3[(0x100 - 0x54) / 4 - 1];
- u32 ddr_grf_status[18];
- u32 reserved4[(0x150 - 0x144) / 4 - 1];
- u32 grf_ddrhold_status;
- u32 reserved5[(0x160 - 0x150) / 4 - 1];
- u32 grf_ddrphy_status[2];
+struct rv1126_ddr_phy_regs {
- u32 phy[8][2];
+struct msch_regs {
- u32 coreid;
- u32 revisionid;
- u32 deviceconf;
- u32 devicesize;
- u32 ddrtiminga0;
- u32 ddrtimingb0;
- u32 ddrtimingc0;
- u32 devtodev0;
- u32 reserved1[(0x110 - 0x20) / 4];
- u32 ddrmode;
- u32 ddr4timing;
- u32 reserved2[(0x1000 - 0x118) / 4];
- u32 agingx0;
- u32 reserved3[(0x1040 - 0x1004) / 4];
- u32 aging0;
- u32 aging1;
- u32 aging2;
- u32 aging3;
+struct sdram_msch_timings {
- union noc_ddrtiminga0 ddrtiminga0;
- union noc_ddrtimingb0 ddrtimingb0;
- union noc_ddrtimingc0 ddrtimingc0;
- union noc_devtodev_rv1126 devtodev0;
- union noc_ddrmode ddrmode;
- union noc_ddr4timing ddr4timing;
- u32 agingx0;
- u32 aging0;
- u32 aging1;
- u32 aging2;
- u32 aging3;
+struct rv1126_sdram_channel {
- struct sdram_cap_info cap_info;
- struct sdram_msch_timings noc_timings;
+struct rv1126_sdram_params {
- struct rv1126_sdram_channel ch;
- struct sdram_base_params base;
- struct ddr_pctl_regs pctl_regs;
- struct rv1126_ddr_phy_regs phy_regs;
+struct rv1126_fsp_param {
- u32 flag;
- u32 freq_mhz;
- /* dram size */
- u32 dq_odt;
- u32 ca_odt;
- u32 ds_pdds;
- u32 vref_ca[2];
- u32 vref_dq[2];
- /* phy side */
- u32 wr_dq_drv;
- u32 wr_ca_drv;
- u32 wr_ckcs_drv;
- u32 rd_odt;
- u32 rd_odt_up_en;
- u32 rd_odt_down_en;
- u32 vref_inner;
- u32 vref_out;
- u32 lp4_drv_pd_en;
+#define MAX_IDX (4) +#define FSP_FLAG (0xfead0001) +#define SHARE_MEM_BASE (0x100000) +/*
- Borrow share memory space to temporarily store FSP parame.
- In the stage of DDR init write FSP parame to this space.
- In the stage of trust init move FSP parame to SRAM space
- from share memory space.
+#define FSP_PARAM_STORE_ADDR (SHARE_MEM_BASE)
+/* store result of read and write training, for ddr_dq_eye tool in u-boot */ +#define RW_TRN_RESULT_ADDR (0x2000000 + 0x8000) /* 32M + 32k */ +#define PRINT_STEP 1
+#undef FSP_NUM +#undef CS_NUM +#undef BYTE_NUM
+#define FSP_NUM 4 +#define CS_NUM 2 +#define BYTE_NUM 4 +#define RD_DESKEW_NUM 64 +#define WR_DESKEW_NUM 64
+#define LP4_WIDTH_REF_MHZ_H 1056 +#define LP4_RD_WIDTH_REF_H 12 +#define LP4_WR_WIDTH_REF_H 13
+#define LP4_WIDTH_REF_MHZ_L 924 +#define LP4_RD_WIDTH_REF_L 15 +#define LP4_WR_WIDTH_REF_L 15
+#define DDR4_WIDTH_REF_MHZ_H 1056 +#define DDR4_RD_WIDTH_REF_H 13 +#define DDR4_WR_WIDTH_REF_H 9
+#define DDR4_WIDTH_REF_MHZ_L 924 +#define DDR4_RD_WIDTH_REF_L 15 +#define DDR4_WR_WIDTH_REF_L 11
+#define LP3_WIDTH_REF_MHZ_H 1056 +#define LP3_RD_WIDTH_REF_H 15 +#define LP3_WR_WIDTH_REF_H 13
+#define LP3_WIDTH_REF_MHZ_L 924 +#define LP3_RD_WIDTH_REF_L 16 +#define LP3_WR_WIDTH_REF_L 15
+#define DDR3_WIDTH_REF_MHZ_H 1056 +#define DDR3_RD_WIDTH_REF_H 14 +#define DDR3_WR_WIDTH_REF_H 14
+#define DDR3_WIDTH_REF_MHZ_L 924 +#define DDR3_RD_WIDTH_REF_L 17 +#define DDR3_WR_WIDTH_REF_L 17
+#endif /* _ASM_ARCH_SDRAM_RK1126_H */ diff --git a/drivers/ram/rockchip/Makefile b/drivers/ram/rockchip/Makefile index 6d530c29af..98839ad6a6 100644 --- a/drivers/ram/rockchip/Makefile +++ b/drivers/ram/rockchip/Makefile @@ -14,4 +14,5 @@ obj-$(CONFIG_ROCKCHIP_RK3308) = sdram_rk3308.o obj-$(CONFIG_ROCKCHIP_RK3328) = sdram_rk3328.o sdram_pctl_px30.o sdram_phy_px30.o obj-$(CONFIG_ROCKCHIP_RK3399) += sdram_rk3399.o obj-$(CONFIG_ROCKCHIP_RK3568) += sdram_rk3568.o +obj-$(CONFIG_ROCKCHIP_RV1126) += sdram_rv1126.o sdram_pctl_px30.o obj-$(CONFIG_ROCKCHIP_SDRAM_COMMON) += sdram_common.o diff --git a/drivers/ram/rockchip/sdram_rv1126.c b/drivers/ram/rockchip/sdram_rv1126.c new file mode 100644 index 0000000000..9b1c34391e --- /dev/null +++ b/drivers/ram/rockchip/sdram_rv1126.c @@ -0,0 +1,3521 @@ +// SPDX-License-Identifier: GPL-2.0 +/*
- (C) Copyright 2020 Rockchip Electronics Co., Ltd.
- Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd.
+#include <common.h> +#include <debug_uart.h> +#include <dm.h> +#include <ram.h> +#include <syscon.h> +#include <asm/io.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/cru_rv1126.h> +#include <asm/arch-rockchip/grf_rv1126.h> +#include <asm/arch-rockchip/sdram_common.h> +#include <asm/arch-rockchip/sdram_rv1126.h> +#include <linux/delay.h>
+/* define training flag */ +#define CA_TRAINING (0x1 << 0) +#define READ_GATE_TRAINING (0x1 << 1) +#define WRITE_LEVELING (0x1 << 2) +#define WRITE_TRAINING (0x1 << 3) +#define READ_TRAINING (0x1 << 4) +#define FULL_TRAINING (0xff)
+#define SKEW_RX_SIGNAL (0) +#define SKEW_TX_SIGNAL (1) +#define SKEW_CA_SIGNAL (2)
+#define DESKEW_MDF_ABS_VAL (0) +#define DESKEW_MDF_DIFF_VAL (1)
+struct dram_info { +#if defined(CONFIG_TPL_BUILD) || \
- (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD))
- void __iomem *pctl;
- void __iomem *phy;
- struct rv1126_cru *cru;
- struct msch_regs *msch;
- struct rv1126_ddrgrf *ddrgrf;
- struct rv1126_grf *grf;
- u32 sr_idle;
- u32 pd_idle;
- struct ram_info info;
- struct rv1126_pmugrf *pmugrf;
+#define GRF_BASE_ADDR 0xfe000000 +#define PMU_GRF_BASE_ADDR 0xfe020000 +#define DDR_GRF_BASE_ADDR 0xfe030000 +#define BUS_SGRF_BASE_ADDR 0xfe0a0000 +#define SERVER_MSCH_BASE_ADDR 0xfe800000 +#define CRU_BASE_ADDR 0xff490000 +#define DDR_PHY_BASE_ADDR 0xff4a0000 +#define UPCTL2_BASE_ADDR 0xffa50000
+#define SGRF_SOC_CON2 0x8 +#define SGRF_SOC_CON12 0x30 +#define SGRF_SOC_CON13 0x34
+struct dram_info dram_info;
+struct rv1126_sdram_params sdram_configs[] = { +# include "sdram-rv1126-ddr3-detect-328.inc" +# include "sdram-rv1126-ddr3-detect-396.inc" +# include "sdram-rv1126-ddr3-detect-528.inc" +# include "sdram-rv1126-ddr3-detect-664.inc" +# include "sdram-rv1126-ddr3-detect-784.inc" +# include "sdram-rv1126-ddr3-detect-924.inc" +# include "sdram-rv1126-ddr3-detect-1056.inc" +};
+u32 common_info[] = { +#include "sdram-rv1126-loader_params.inc" +};
+#if defined(CONFIG_CMD_DDR_TEST_TOOL) +static struct rw_trn_result rw_trn_result; +#endif
+static struct rv1126_fsp_param fsp_param[MAX_IDX];
+static u8 lp3_odt_value;
+static s8 wrlvl_result[2][4];
+/* DDR configuration 0-9 */ +u16 ddr_cfg_2_rbc[] = {
- ((0 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 3), /* 0 */
- ((1 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 2), /* 1 */
- ((1 << 8) | (2 << 5) | (0 << 4) | (1 << 3) | 3), /* 2 */
- ((1 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 1), /* 3 */
- ((0 << 8) | (2 << 5) | (0 << 4) | (1 << 3) | 4), /* 4 */
- ((0 << 8) | (3 << 5) | (1 << 4) | (1 << 3) | 1), /* 5 */
- ((0 << 8) | (3 << 5) | (1 << 4) | (1 << 3) | 2), /* 6 */
- ((0 << 8) | (2 << 5) | (1 << 4) | (1 << 3) | 3), /* 7 */
- ((1 << 8) | (3 << 5) | (0 << 4) | (0 << 3) | 2), /* 8 */
- ((1 << 8) | (2 << 5) | (0 << 4) | (1 << 3) | 2) /* 9 */
+/* DDR configuration 10-21 */ +u8 ddr4_cfg_2_rbc[] = {
- ((0 << 7) | (3 << 4) | (0 << 3) | (2 << 1) | 0), /* 10 */
- ((1 << 7) | (2 << 4) | (0 << 3) | (2 << 1) | 0), /* 11 */
- ((0 << 7) | (4 << 4) | (0 << 3) | (1 << 1) | 0), /* 12 */
- ((1 << 7) | (3 << 4) | (0 << 3) | (1 << 1) | 0), /* 13 */
- ((0 << 7) | (4 << 4) | (0 << 3) | (2 << 1) | 1), /* 14 */
- ((1 << 7) | (3 << 4) | (0 << 3) | (2 << 1) | 1), /* 15 */
- ((1 << 7) | (4 << 4) | (0 << 3) | (1 << 1) | 1), /* 16 */
- ((0 << 7) | (2 << 4) | (1 << 3) | (2 << 1) | 0), /* 17 */
- ((0 << 7) | (3 << 4) | (1 << 3) | (1 << 1) | 0), /* 18 */
- ((0 << 7) | (3 << 4) | (1 << 3) | (2 << 1) | 1), /* 19 */
- ((0 << 7) | (4 << 4) | (1 << 3) | (1 << 1) | 1), /* 20 */
- ((1 << 7) | (4 << 4) | (0 << 3) | (0 << 1) | 0) /* 21 */
+/* DDR configuration 22-28 */ +u16 ddr_cfg_2_rbc_p2[] = {
- ((1 << 8) | (3 << 5) | (0 << 4) | (1 << 3) | 0), /* 22 */
- ((0 << 8) | (4 << 5) | (0 << 4) | (1 << 3) | 2), /* 23 */
- ((1 << 8) | (3 << 5) | (0 << 4) | (0 << 3) | 3), /* 24 */
- ((0 << 8) | (3 << 5) | (1 << 4) | (0 << 3) | 3), /* 25 */
- ((0 << 8) | (4 << 5) | (1 << 4) | (0 << 3) | 2), /* 26 */
- ((1 << 8) | (4 << 5) | (0 << 4) | (0 << 3) | 2), /* 27 */
- ((0 << 8) | (4 << 5) | (0 << 4) | (0 << 3) | 3) /* 28 */
+u8 d4_rbc_2_d3_rbc[][2] = {
- {10, 0},
- {11, 2},
- {12, 23},
- {13, 1},
- {14, 28},
- {15, 24},
- {16, 27},
- {17, 7},
- {18, 6},
- {19, 25},
- {20, 26},
- {21, 3}
+u32 addrmap[29][9] = {
- {24, 0x00090909, 0x00000000, 0x00000000, 0x00001f00, 0x08080808,
0x08080808, 0x00000f0f, 0x3f3f}, /* 0 */
- {23, 0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f0f, 0x3f3f}, /* 1 */
- {23, 0x00090909, 0x00000000, 0x00000000, 0x00001f00, 0x08080808,
0x0f080808, 0x00000f0f, 0x3f3f}, /* 2 */
- {22, 0x00070707, 0x00000000, 0x1f000000, 0x00001f1f, 0x06060606,
0x06060606, 0x00000f0f, 0x3f3f}, /* 3 */
- {24, 0x000a0a0a, 0x00000000, 0x00000000, 0x00000000, 0x09090909,
0x0f090909, 0x00000f0f, 0x3f3f}, /* 4 */
- {6, 0x00070707, 0x00000000, 0x1f000000, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f0f, 0x3f3f}, /* 5 */
- {7, 0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x08080808,
0x08080808, 0x00000f0f, 0x3f3f}, /* 6 */
- {8, 0x00090909, 0x00000000, 0x00000000, 0x00001f00, 0x09090909,
0x0f090909, 0x00000f0f, 0x3f3f}, /* 7 */
- {22, 0x001f0808, 0x00000000, 0x00000000, 0x00001f1f, 0x06060606,
0x06060606, 0x00000f0f, 0x3f3f}, /* 8 */
0x0f070707, 0x00000f0f, 0x3f3f}, /* 9 */
- {24, 0x003f0a0a, 0x01010100, 0x01010101, 0x00001f1f, 0x08080808,
0x08080808, 0x00000f0f, 0x0801}, /* 10 */
- {23, 0x003f0a0a, 0x01010100, 0x01010101, 0x00001f1f, 0x08080808,
0x0f080808, 0x00000f0f, 0x0801}, /* 11 */
- {24, 0x003f0909, 0x00000007, 0x1f000000, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f07, 0x0700}, /* 12 */
- {23, 0x003f0909, 0x00000007, 0x1f000000, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f0f, 0x0700}, /* 13 */
- {24, 0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f07, 0x3f01}, /* 14 */
- {23, 0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f0f, 0x3f01}, /* 15 */
- {23, 0x003f0808, 0x00000007, 0x1f000000, 0x00001f1f, 0x06060606,
0x06060606, 0x00000f06, 0x3f00}, /* 16 */
- {8, 0x003f0a0a, 0x01010100, 0x01010101, 0x00001f1f, 0x09090909,
0x0f090909, 0x00000f0f, 0x0801}, /* 17 */
- {7, 0x003f0909, 0x00000007, 0x1f000000, 0x00001f1f, 0x08080808,
0x08080808, 0x00000f0f, 0x0700}, /* 18 */
- {7, 0x003f0909, 0x01010100, 0x01010101, 0x00001f1f, 0x08080808,
0x08080808, 0x00000f0f, 0x3f01}, /* 19 */
- {6, 0x003f0808, 0x00000007, 0x1f000000, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f07, 0x3f00}, /* 20 */
- {23, 0x003f0909, 0x00000006, 0x1f1f0000, 0x00001f1f, 0x06060606,
0x06060606, 0x00000f06, 0x0600}, /* 21 */
- {21, 0x00060606, 0x00000000, 0x1f1f0000, 0x00001f1f, 0x05050505,
0x05050505, 0x00000f0f, 0x3f3f}, /* 22 */
- {24, 0x00080808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f07, 0x3f3f}, /* 23 */
- {23, 0x003f0909, 0x00000000, 0x00000000, 0x00001f00, 0x07070707,
0x07070707, 0x00000f0f, 0x3f3f}, /* 24 */
- {7, 0x003f0909, 0x00000000, 0x00000000, 0x00001f00, 0x08080808,
0x08080808, 0x00000f0f, 0x3f3f}, /* 25 */
- {6, 0x003f0808, 0x00000000, 0x00000000, 0x00001f1f, 0x07070707,
0x07070707, 0x00000f07, 0x3f3f}, /* 26 */
- {23, 0x003f0808, 0x00000000, 0x00000000, 0x00001f1f, 0x06060606,
0x06060606, 0x00000f06, 0x3f3f}, /* 27 */
- {24, 0x003f0909, 0x00000000, 0x00000000, 0x00001f00, 0x07070707,
0x07070707, 0x00000f07, 0x3f3f} /* 28 */
+static u8 dq_sel[22][3] = {
- {0x0, 0x17, 0x22},
- {0x1, 0x18, 0x23},
- {0x2, 0x19, 0x24},
- {0x3, 0x1a, 0x25},
- {0x4, 0x1b, 0x26},
- {0x5, 0x1c, 0x27},
- {0x6, 0x1d, 0x28},
- {0x7, 0x1e, 0x29},
- {0x8, 0x16, 0x21},
- {0x9, 0x1f, 0x2a},
- {0xa, 0x20, 0x2b},
- {0x10, 0x1, 0xc},
- {0x11, 0x2, 0xd},
- {0x12, 0x3, 0xe},
- {0x13, 0x4, 0xf},
- {0x14, 0x5, 0x10},
- {0x15, 0x6, 0x11},
- {0x16, 0x7, 0x12},
- {0x17, 0x8, 0x13},
- {0x18, 0x0, 0xb},
- {0x19, 0x9, 0x14},
- {0x1a, 0xa, 0x15}
+static u16 grp_addr[4] = {
- ADD_GROUP_CS0_A,
- ADD_GROUP_CS0_B,
- ADD_GROUP_CS1_A,
- ADD_GROUP_CS1_B
+static u8 wrlvl_result_offset[2][4] = {
- {0xa0 + 0x26, 0xa0 + 0x27, 0xd0 + 0x26, 0xd0 + 0x27},
- {0xa0 + 0x28, 0xa0 + 0x29, 0xd0 + 0x28, 0xd0 + 0x29},
+static u16 dqs_dq_skew_adr[16] = {
- 0x170 + 0, /* SKEW_UPDATE_RX_CS0_DQS0 */
- 0x170 + 0xb, /* SKEW_UPDATE_RX_CS0_DQS1 */
- 0x1d0 + 0, /* SKEW_UPDATE_RX_CS0_DQS2 */
- 0x1d0 + 0xb, /* SKEW_UPDATE_RX_CS0_DQS3 */
- 0x1a0 + 0, /* SKEW_UPDATE_RX_CS1_DQS0 */
- 0x1a0 + 0xb, /* SKEW_UPDATE_RX_CS1_DQS1 */
- 0x200 + 0, /* SKEW_UPDATE_RX_CS1_DQS2 */
- 0x200 + 0xb, /* SKEW_UPDATE_RX_CS1_DQS3 */
- 0x170 + 0x16, /* SKEW_UPDATE_TX_CS0_DQS0 */
- 0x170 + 0x21, /* SKEW_UPDATE_TX_CS0_DQS1 */
- 0x1d0 + 0x16, /* SKEW_UPDATE_TX_CS0_DQS2 */
- 0x1d0 + 0x21, /* SKEW_UPDATE_TX_CS0_DQS3 */
- 0x1a0 + 0x16, /* SKEW_UPDATE_TX_CS1_DQS0 */
- 0x1a0 + 0x21, /* SKEW_UPDATE_TX_CS1_DQS1 */
- 0x200 + 0x16, /* SKEW_UPDATE_TX_CS1_DQS2 */
- 0x200 + 0x21, /* SKEW_UPDATE_TX_CS1_DQS3 */
+static void rkclk_ddr_reset(struct dram_info *dram,
u32 ctl_srstn, u32 ctl_psrstn,
u32 phy_srstn, u32 phy_psrstn)
- writel(UPCTL2_SRSTN_REQ(ctl_srstn) | UPCTL2_PSRSTN_REQ(ctl_psrstn) |
UPCTL2_ASRSTN_REQ(ctl_srstn),
BUS_SGRF_BASE_ADDR + SGRF_SOC_CON13);
- writel(DDRPHY_SRSTN_REQ(phy_srstn) | DDRPHY_PSRSTN_REQ(phy_psrstn),
&dram->cru->softrst_con[12]);
+static void rkclk_set_dpll(struct dram_info *dram, unsigned int hz) +{
- unsigned int refdiv, postdiv1, postdiv2, fbdiv;
- int delay = 1000;
- u32 mhz = hz / MHz;
- struct global_info *gbl_info;
- struct sdram_head_info_index_v2 *index =
- u32 ssmod_info;
- u32 dsmpd = 1;
- gbl_info = (struct global_info *)((void *)common_info +
- ssmod_info = gbl_info->info_2t;
- refdiv = 1;
- if (mhz <= 100) {
postdiv1 = 6;
postdiv2 = 4;
- } else if (mhz <= 150) {
postdiv1 = 4;
postdiv2 = 4;
- } else if (mhz <= 200) {
postdiv1 = 6;
postdiv2 = 2;
- } else if (mhz <= 300) {
postdiv1 = 4;
postdiv2 = 2;
- } else if (mhz <= 400) {
postdiv1 = 6;
postdiv2 = 1;
- } else {
postdiv1 = 4;
postdiv2 = 1;
- fbdiv = (mhz * refdiv * postdiv1 * postdiv2) / 24;
- writel(DPLL_MODE(CLOCK_FROM_XIN_OSC), &dram->cru->mode);
- writel(0x1f000000, &dram->cru->clksel_con[64]);
- writel(POSTDIV1(postdiv1) | FBDIV(fbdiv), &dram->cru->pll[1].con0);
- /* enable ssmod */
- if (PLL_SSMOD_SPREAD(ssmod_info)) {
dsmpd = 0;
clrsetbits_le32(&dram->cru->pll[1].con2,
0xffffff << 0, 0x0 << 0);
writel(SSMOD_SPREAD(PLL_SSMOD_SPREAD(ssmod_info)) |
SSMOD_DIVVAL(PLL_SSMOD_DIV(ssmod_info)) |
SSMOD_DOWNSPREAD(PLL_SSMOD_DOWNSPREAD(ssmod_info)) |
SSMOD_RESET(0) |
SSMOD_DIS_SSCG(0) |
SSMOD_BP(0),
&dram->cru->pll[1].con3);
- writel(DSMPD(dsmpd) | POSTDIV2(postdiv2) | REFDIV(refdiv),
&dram->cru->pll[1].con1);
- while (delay > 0) {
udelay(1);
if (LOCK(readl(&dram->cru->pll[1].con1)))
break;
delay--;
- writel(DPLL_MODE(CLOCK_FROM_PLL), &dram->cru->mode);
+static void rkclk_configure_ddr(struct dram_info *dram,
- /* for inno ddr phy need freq / 2 */
- rkclk_set_dpll(dram, sdram_params->base.ddr_freq * MHZ / 2);
+static unsigned int
- calculate_ddrconfig(struct rv1126_sdram_params *sdram_params)
- struct sdram_cap_info *cap_info = &sdram_params->ch.cap_info;
- u32 cs, bw, die_bw, col, row, bank;
- u32 cs1_row;
- u32 i, tmp;
- u32 ddrconf = -1;
- u32 row_3_4;
- cs = cap_info->rank;
- bw = cap_info->bw;
- die_bw = cap_info->dbw;
- col = cap_info->col;
- row = cap_info->cs0_row;
- cs1_row = cap_info->cs1_row;
- bank = cap_info->bk;
- row_3_4 = cap_info->row_3_4;
- if (sdram_params->base.dramtype == DDR4) {
if (cs == 2 && row == cs1_row && !row_3_4) {
tmp = ((row - 13) << 4) | (1 << 3) | (bw << 1) |
die_bw;
for (i = 17; i < 21; i++) {
if (((tmp & 0xf) ==
(ddr4_cfg_2_rbc[i - 10] & 0xf)) &&
((tmp & 0x70) <=
(ddr4_cfg_2_rbc[i - 10] & 0x70))) {
ddrconf = i;
goto out;
tmp = ((cs - 1) << 7) | ((row - 13) << 4) | (bw << 1) | die_bw;
for (i = 10; i < 21; i++) {
if (((tmp & 0xf) == (ddr4_cfg_2_rbc[i - 10] & 0xf)) &&
((tmp & 0x70) <= (ddr4_cfg_2_rbc[i - 10] & 0x70)) &&
((tmp & 0x80) <= (ddr4_cfg_2_rbc[i - 10] & 0x80))) {
ddrconf = i;
goto out;
- } else {
if (cs == 2 && row == cs1_row && bank == 3) {
for (i = 5; i < 8; i++) {
if (((bw + col - 10) == (ddr_cfg_2_rbc[i] &
0x7)) &&
((row - 13) << 5) <= (ddr_cfg_2_rbc[i] &
(0x7 << 5))) {
ddrconf = i;
goto out;
tmp = ((cs - 1) << 8) | ((row - 13) << 5) |
((bw + col - 10) << 0);
if (bank == 3)
tmp |= (1 << 3);
for (i = 0; i < 9; i++)
if (((tmp & 0x1f) == (ddr_cfg_2_rbc[i] & 0x1f)) &&
((tmp & (7 << 5)) <=
(ddr_cfg_2_rbc[i] & (7 << 5))) &&
((tmp & (1 << 8)) <=
(ddr_cfg_2_rbc[i] & (1 << 8)))) {
ddrconf = i;
goto out;
for (i = 0; i < 7; i++)
if (((tmp & 0x1f) == (ddr_cfg_2_rbc_p2[i] & 0x1f)) &&
(ddr_cfg_2_rbc_p2[i] & (7 << 5))) &&
(ddr_cfg_2_rbc_p2[i] & (1 << 8)))) {
ddrconf = i + 22;
goto out;
if (cs == 1 && bank == 3 && row <= 17 &&
(col + bw) == 12)
ddrconf = 23;
+out:
- if (ddrconf > 28)
printascii("calculate ddrconfig error\n");
for (i = 0; i < ARRAY_SIZE(d4_rbc_2_d3_rbc) ; i++) {
if (ddrconf == d4_rbc_2_d3_rbc[i][0]) {
if (ddrconf == 21 && row > 16)
printascii("warn:ddrconf21 row > 16\n");
else
ddrconf = d4_rbc_2_d3_rbc[i][1];
break;
- return ddrconf;
+static void sw_set_req(struct dram_info *dram) +{
- void __iomem *pctl_base = dram->pctl;
- /* clear sw_done=0 */
- writel(PCTL2_SW_DONE_CLEAR, pctl_base + DDR_PCTL2_SWCTL);
+static void sw_set_ack(struct dram_info *dram) +{
- /* set sw_done=1 */
- writel(PCTL2_SW_DONE, pctl_base + DDR_PCTL2_SWCTL);
- while (1) {
/* wait programming done */
if (readl(pctl_base + DDR_PCTL2_SWSTAT) &
PCTL2_SW_DONE_ACK)
break;
+static void set_ctl_address_map(struct dram_info *dram,
- u32 ddrconf = cap_info->ddrconfig;
- u32 i, row;
if (ddrconf == d4_rbc_2_d3_rbc[i][1]) {
ddrconf = d4_rbc_2_d3_rbc[i][0];
break;
- if (ddrconf >= ARRAY_SIZE(addrmap)) {
printascii("set ctl address map fail\n");
return;
- sdram_copy_to_reg((u32 *)(pctl_base + DDR_PCTL2_ADDRMAP0),
&addrmap[ddrconf][0], ARRAY_SIZE(addrmap[ddrconf]) * 4);
- /* unused row set to 0xf */
- for (i = 17; i >= row; i--)
setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6 +
((i - 12) * 8 / 32) * 4,
0xf << ((i - 12) * 8 % 32));
- if (sdram_params->base.dramtype == LPDDR3 && cap_info->row_3_4)
setbits_le32(pctl_base + DDR_PCTL2_ADDRMAP6, 1 << 31);
- if (sdram_params->base.dramtype == DDR4 && cap_info->bw == 0x1)
setbits_le32(pctl_base + DDR_PCTL2_PCCFG, 1 << 8);
- if (cap_info->rank == 1)
clrsetbits_le32(pctl_base + DDR_PCTL2_ADDRMAP0, 0x1f, 0x1f);
+static void phy_pll_set(struct dram_info *dram, u32 freq, u32 wait) +{
- void __iomem *phy_base = dram->phy;
- u32 fbdiv, prediv, postdiv, postdiv_en;
- if (wait) {
clrbits_le32(PHY_REG(phy_base, 0x53), PHY_PD_DISB);
while (!(readl(PHY_REG(phy_base, 0x90)) & PHY_PLL_LOCK))
continue;
- } else {
freq /= MHz;
prediv = 1;
if (freq <= 200) {
fbdiv = 16;
postdiv = 2;
postdiv_en = 1;
} else if (freq <= 456) {
fbdiv = 8;
postdiv = 1;
postdiv_en = 1;
} else {
fbdiv = 4;
postdiv = 0;
postdiv_en = 0;
writel(fbdiv & 0xff, PHY_REG(phy_base, 0x50));
clrsetbits_le32(PHY_REG(phy_base, 0x51), PHY_PBDIV_BIT9_MASK,
(fbdiv >> 8) & 1);
clrsetbits_le32(PHY_REG(phy_base, 0x51), PHY_POSTDIV_EN_MASK,
postdiv_en << PHY_POSTDIV_EN_SHIFT);
clrsetbits_le32(PHY_REG(phy_base, 0x52),
PHY_PREDIV_MASK << PHY_PREDIV_SHIFT, prediv);
clrsetbits_le32(PHY_REG(phy_base, 0x53),
PHY_POSTDIV_MASK << PHY_POSTDIV_SHIFT,
postdiv << PHY_POSTDIV_SHIFT);
+static const u16 d3_phy_drv_2_ohm[][2] = {
- {PHY_DDR3_RON_455ohm, 455},
- {PHY_DDR3_RON_230ohm, 230},
- {PHY_DDR3_RON_153ohm, 153},
- {PHY_DDR3_RON_115ohm, 115},
- {PHY_DDR3_RON_91ohm, 91},
- {PHY_DDR3_RON_76ohm, 76},
- {PHY_DDR3_RON_65ohm, 65},
- {PHY_DDR3_RON_57ohm, 57},
- {PHY_DDR3_RON_51ohm, 51},
- {PHY_DDR3_RON_46ohm, 46},
- {PHY_DDR3_RON_41ohm, 41},
- {PHY_DDR3_RON_38ohm, 38},
- {PHY_DDR3_RON_35ohm, 35},
- {PHY_DDR3_RON_32ohm, 32},
- {PHY_DDR3_RON_30ohm, 30},
- {PHY_DDR3_RON_28ohm, 28},
- {PHY_DDR3_RON_27ohm, 27},
- {PHY_DDR3_RON_25ohm, 25},
- {PHY_DDR3_RON_24ohm, 24},
- {PHY_DDR3_RON_23ohm, 23},
- {PHY_DDR3_RON_22ohm, 22},
- {PHY_DDR3_RON_21ohm, 21},
- {PHY_DDR3_RON_20ohm, 20}
+static u16 d3_phy_odt_2_ohm[][2] = {
- {PHY_DDR3_RTT_DISABLE, 0},
- {PHY_DDR3_RTT_561ohm, 561},
- {PHY_DDR3_RTT_282ohm, 282},
- {PHY_DDR3_RTT_188ohm, 188},
- {PHY_DDR3_RTT_141ohm, 141},
- {PHY_DDR3_RTT_113ohm, 113},
- {PHY_DDR3_RTT_94ohm, 94},
- {PHY_DDR3_RTT_81ohm, 81},
- {PHY_DDR3_RTT_72ohm, 72},
- {PHY_DDR3_RTT_64ohm, 64},
- {PHY_DDR3_RTT_58ohm, 58},
- {PHY_DDR3_RTT_52ohm, 52},
- {PHY_DDR3_RTT_48ohm, 48},
- {PHY_DDR3_RTT_44ohm, 44},
- {PHY_DDR3_RTT_41ohm, 41},
- {PHY_DDR3_RTT_38ohm, 38},
- {PHY_DDR3_RTT_37ohm, 37},
- {PHY_DDR3_RTT_34ohm, 34},
- {PHY_DDR3_RTT_32ohm, 32},
- {PHY_DDR3_RTT_31ohm, 31},
- {PHY_DDR3_RTT_29ohm, 29},
- {PHY_DDR3_RTT_28ohm, 28},
- {PHY_DDR3_RTT_27ohm, 27},
- {PHY_DDR3_RTT_25ohm, 25}
+static u16 d4lp3_phy_drv_2_ohm[][2] = {
- {PHY_DDR4_LPDDR3_RON_482ohm, 482},
- {PHY_DDR4_LPDDR3_RON_244ohm, 244},
- {PHY_DDR4_LPDDR3_RON_162ohm, 162},
- {PHY_DDR4_LPDDR3_RON_122ohm, 122},
- {PHY_DDR4_LPDDR3_RON_97ohm, 97},
- {PHY_DDR4_LPDDR3_RON_81ohm, 81},
- {PHY_DDR4_LPDDR3_RON_69ohm, 69},
- {PHY_DDR4_LPDDR3_RON_61ohm, 61},
- {PHY_DDR4_LPDDR3_RON_54ohm, 54},
- {PHY_DDR4_LPDDR3_RON_48ohm, 48},
- {PHY_DDR4_LPDDR3_RON_44ohm, 44},
- {PHY_DDR4_LPDDR3_RON_40ohm, 40},
- {PHY_DDR4_LPDDR3_RON_37ohm, 37},
- {PHY_DDR4_LPDDR3_RON_34ohm, 34},
- {PHY_DDR4_LPDDR3_RON_32ohm, 32},
- {PHY_DDR4_LPDDR3_RON_30ohm, 30},
- {PHY_DDR4_LPDDR3_RON_28ohm, 28},
- {PHY_DDR4_LPDDR3_RON_27ohm, 27},
- {PHY_DDR4_LPDDR3_RON_25ohm, 25},
- {PHY_DDR4_LPDDR3_RON_24ohm, 24},
- {PHY_DDR4_LPDDR3_RON_23ohm, 23},
- {PHY_DDR4_LPDDR3_RON_22ohm, 22},
- {PHY_DDR4_LPDDR3_RON_21ohm, 21}
+static u16 d4lp3_phy_odt_2_ohm[][2] = {
- {PHY_DDR4_LPDDR3_RTT_DISABLE, 0},
- {PHY_DDR4_LPDDR3_RTT_586ohm, 586},
- {PHY_DDR4_LPDDR3_RTT_294ohm, 294},
- {PHY_DDR4_LPDDR3_RTT_196ohm, 196},
- {PHY_DDR4_LPDDR3_RTT_148ohm, 148},
- {PHY_DDR4_LPDDR3_RTT_118ohm, 118},
- {PHY_DDR4_LPDDR3_RTT_99ohm, 99},
- {PHY_DDR4_LPDDR3_RTT_85ohm, 58},
- {PHY_DDR4_LPDDR3_RTT_76ohm, 76},
- {PHY_DDR4_LPDDR3_RTT_67ohm, 67},
- {PHY_DDR4_LPDDR3_RTT_60ohm, 60},
- {PHY_DDR4_LPDDR3_RTT_55ohm, 55},
- {PHY_DDR4_LPDDR3_RTT_50ohm, 50},
- {PHY_DDR4_LPDDR3_RTT_46ohm, 46},
- {PHY_DDR4_LPDDR3_RTT_43ohm, 43},
- {PHY_DDR4_LPDDR3_RTT_40ohm, 40},
- {PHY_DDR4_LPDDR3_RTT_38ohm, 38},
- {PHY_DDR4_LPDDR3_RTT_36ohm, 36},
- {PHY_DDR4_LPDDR3_RTT_34ohm, 34},
- {PHY_DDR4_LPDDR3_RTT_32ohm, 32},
- {PHY_DDR4_LPDDR3_RTT_31ohm, 31},
- {PHY_DDR4_LPDDR3_RTT_29ohm, 29},
- {PHY_DDR4_LPDDR3_RTT_28ohm, 28},
- {PHY_DDR4_LPDDR3_RTT_27ohm, 27}
+static u16 lp4_phy_drv_2_ohm[][2] = {
- {PHY_LPDDR4_RON_501ohm, 501},
- {PHY_LPDDR4_RON_253ohm, 253},
- {PHY_LPDDR4_RON_168ohm, 168},
- {PHY_LPDDR4_RON_126ohm, 126},
- {PHY_LPDDR4_RON_101ohm, 101},
- {PHY_LPDDR4_RON_84ohm, 84},
- {PHY_LPDDR4_RON_72ohm, 72},
- {PHY_LPDDR4_RON_63ohm, 63},
- {PHY_LPDDR4_RON_56ohm, 56},
- {PHY_LPDDR4_RON_50ohm, 50},
- {PHY_LPDDR4_RON_46ohm, 46},
- {PHY_LPDDR4_RON_42ohm, 42},
- {PHY_LPDDR4_RON_38ohm, 38},
- {PHY_LPDDR4_RON_36ohm, 36},
- {PHY_LPDDR4_RON_33ohm, 33},
- {PHY_LPDDR4_RON_31ohm, 31},
- {PHY_LPDDR4_RON_29ohm, 29},
- {PHY_LPDDR4_RON_28ohm, 28},
- {PHY_LPDDR4_RON_26ohm, 26},
- {PHY_LPDDR4_RON_25ohm, 25},
- {PHY_LPDDR4_RON_24ohm, 24},
- {PHY_LPDDR4_RON_23ohm, 23},
- {PHY_LPDDR4_RON_22ohm, 22}
+static u16 lp4_phy_odt_2_ohm[][2] = {
- {PHY_LPDDR4_RTT_DISABLE, 0},
- {PHY_LPDDR4_RTT_604ohm, 604},
- {PHY_LPDDR4_RTT_303ohm, 303},
- {PHY_LPDDR4_RTT_202ohm, 202},
- {PHY_LPDDR4_RTT_152ohm, 152},
- {PHY_LPDDR4_RTT_122ohm, 122},
- {PHY_LPDDR4_RTT_101ohm, 101},
- {PHY_LPDDR4_RTT_87ohm, 87},
- {PHY_LPDDR4_RTT_78ohm, 78},
- {PHY_LPDDR4_RTT_69ohm, 69},
- {PHY_LPDDR4_RTT_62ohm, 62},
- {PHY_LPDDR4_RTT_56ohm, 56},
- {PHY_LPDDR4_RTT_52ohm, 52},
- {PHY_LPDDR4_RTT_48ohm, 48},
- {PHY_LPDDR4_RTT_44ohm, 44},
- {PHY_LPDDR4_RTT_41ohm, 41},
- {PHY_LPDDR4_RTT_39ohm, 39},
- {PHY_LPDDR4_RTT_37ohm, 37},
- {PHY_LPDDR4_RTT_35ohm, 35},
- {PHY_LPDDR4_RTT_33ohm, 33},
- {PHY_LPDDR4_RTT_32ohm, 32},
- {PHY_LPDDR4_RTT_30ohm, 30},
- {PHY_LPDDR4_RTT_29ohm, 29},
- {PHY_LPDDR4_RTT_27ohm, 27}
+static u32 lp4_odt_calc(u32 odt_ohm) +{
- u32 odt;
- if (odt_ohm == 0)
odt = LPDDR4_DQODT_DIS;
- else if (odt_ohm <= 40)
odt = LPDDR4_DQODT_40;
- else if (odt_ohm <= 48)
odt = LPDDR4_DQODT_48;
- else if (odt_ohm <= 60)
odt = LPDDR4_DQODT_60;
- else if (odt_ohm <= 80)
odt = LPDDR4_DQODT_80;
- else if (odt_ohm <= 120)
odt = LPDDR4_DQODT_120;
- else
odt = LPDDR4_DQODT_240;
- return odt;
+static void *get_ddr_drv_odt_info(u32 dramtype) +{
- void *ddr_info = 0;
- if (dramtype == DDR4)
ddr_info = (void *)common_info + index->ddr4_index.offset * 4;
- else if (dramtype == DDR3)
ddr_info = (void *)common_info + index->ddr3_index.offset * 4;
- else if (dramtype == LPDDR3)
ddr_info = (void *)common_info + index->lp3_index.offset * 4;
- else if (dramtype == LPDDR4)
ddr_info = (void *)common_info + index->lp4_index.offset * 4;
- else
printascii("unsupported dram type\n");
- return ddr_info;
+static void set_lp4_vref(struct dram_info *dram, struct lp4_info *lp4_info,
u32 freq_mhz, u32 dst_fsp, u32 dramtype)
- u32 ca_vref, dq_vref;
- if (freq_mhz <= LP4_CA_ODT_EN_FREQ(lp4_info->ca_odten_freq))
ca_vref = LP4_CA_VREF(lp4_info->vref_when_odtoff);
- else
ca_vref = LP4_CA_VREF(lp4_info->vref_when_odten);
- if (freq_mhz <= LP4_DQ_ODT_EN_FREQ(lp4_info->dq_odten_freq))
dq_vref = LP4_DQ_VREF(lp4_info->vref_when_odtoff);
- else
dq_vref = LP4_DQ_VREF(lp4_info->vref_when_odten);
- if (dramtype == LPDDR4) {
if (ca_vref < 100)
ca_vref = 100;
if (ca_vref > 420)
ca_vref = 420;
if (ca_vref <= 300)
ca_vref = (0 << 6) | (ca_vref - 100) / 4;
else
ca_vref = (1 << 6) | (ca_vref - 220) / 4;
if (dq_vref < 100)
dq_vref = 100;
if (dq_vref > 420)
dq_vref = 420;
if (dq_vref <= 300)
dq_vref = (0 << 6) | (dq_vref - 100) / 4;
else
dq_vref = (1 << 6) | (dq_vref - 220) / 4;
- } else {
ca_vref = ca_vref * 11 / 6;
if (ca_vref < 150)
ca_vref = 150;
if (ca_vref > 629)
ca_vref = 629;
if (ca_vref <= 449)
ca_vref = (0 << 6) | (ca_vref - 150) / 4;
else
ca_vref = (1 << 6) | (ca_vref - 329) / 4;
if (dq_vref < 150)
dq_vref = 150;
if (dq_vref > 629)
dq_vref = 629;
if (dq_vref <= 449)
dq_vref = (0 << 6) | (dq_vref - 150) / 6;
else
dq_vref = (1 << 6) | (dq_vref - 329) / 6;
- sw_set_req(dram);
- clrsetbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) +
DDR_PCTL2_INIT6,
PCTL2_MR_MASK << PCTL2_LPDDR4_MR12_SHIFT,
ca_vref << PCTL2_LPDDR4_MR12_SHIFT);
DDR_PCTL2_INIT7,
PCTL2_MR_MASK << PCTL2_LPDDR4_MR14_SHIFT,
dq_vref << PCTL2_LPDDR4_MR14_SHIFT);
- sw_set_ack(dram);
+static void set_ds_odt(struct dram_info *dram,
struct rv1126_sdram_params *sdram_params, u32 dst_fsp)
- u32 dramtype = sdram_params->base.dramtype;
- struct ddr2_3_4_lp2_3_info *ddr_info;
- struct lp4_info *lp4_info;
- u32 i, j, tmp;
- const u16 (*p_drv)[2];
- const u16 (*p_odt)[2];
- u32 drv_info, sr_info;
- u32 phy_dq_drv_ohm, phy_clk_drv_ohm, phy_ca_drv_ohm, dram_drv_ohm;
- u32 phy_odt_ohm, dram_odt_ohm;
- u32 lp4_pu_cal, phy_lp4_drv_pd_en;
- u32 phy_odt_up_en, phy_odt_dn_en;
- u32 sr_dq, sr_clk;
- u32 freq = sdram_params->base.ddr_freq;
- u32 mr1_mr3, mr11, mr22, vref_out, vref_inner;
- u32 phy_clk_drv = 0, phy_odt = 0, phy_ca_drv = 0, dram_caodt_ohm = 0;
- u32 phy_dq_drv = 0;
- u32 phy_odt_up = 0, phy_odt_dn = 0;
- ddr_info = get_ddr_drv_odt_info(dramtype);
- lp4_info = (void *)ddr_info;
- if (!ddr_info)
return;
- /* dram odt en freq control phy drv, dram odt and phy sr */
- if (freq <= DRAMODT_EN_FREQ(ddr_info->odten_freq)) {
drv_info = ddr_info->drv_when_odtoff;
dram_odt_ohm = 0;
sr_info = ddr_info->sr_when_odtoff;
phy_lp4_drv_pd_en =
PHY_LP4_DRV_PULLDOWN_EN_ODTOFF(lp4_info->odt_info);
- } else {
drv_info = ddr_info->drv_when_odten;
dram_odt_ohm = ODT_INFO_DRAM_ODT(ddr_info->odt_info);
sr_info = ddr_info->sr_when_odten;
phy_lp4_drv_pd_en =
PHY_LP4_DRV_PULLDOWN_EN_ODTEN(lp4_info->odt_info);
- phy_dq_drv_ohm =
DRV_INFO_PHY_DQ_DRV(drv_info);
- phy_clk_drv_ohm =
DRV_INFO_PHY_CLK_DRV(drv_info);
- phy_ca_drv_ohm =
DRV_INFO_PHY_CA_DRV(drv_info);
- sr_dq = DQ_SR_INFO(sr_info);
- sr_clk = CLK_SR_INFO(sr_info);
- /* phy odt en freq control dram drv and phy odt */
- if (freq <= PHYODT_EN_FREQ(ddr_info->odten_freq)) {
dram_drv_ohm = DRV_INFO_DRAM_DQ_DRV(ddr_info->drv_when_odtoff);
lp4_pu_cal = LP4_DRV_PU_CAL_ODTOFF(lp4_info->odt_info);
phy_odt_ohm = 0;
phy_odt_up_en = 0;
phy_odt_dn_en = 0;
- } else {
dram_drv_ohm =
DRV_INFO_DRAM_DQ_DRV(ddr_info->drv_when_odten);
phy_odt_ohm = ODT_INFO_PHY_ODT(ddr_info->odt_info);
phy_odt_up_en =
ODT_INFO_PULLUP_EN(ddr_info->odt_info);
phy_odt_dn_en =
ODT_INFO_PULLDOWN_EN(ddr_info->odt_info);
lp4_pu_cal = LP4_DRV_PU_CAL_ODTEN(lp4_info->odt_info);
if (phy_odt_ohm) {
phy_odt_up_en = 0;
phy_odt_dn_en = 1;
if (freq <= LP4_CA_ODT_EN_FREQ(lp4_info->ca_odten_freq))
dram_caodt_ohm = 0;
else
dram_caodt_ohm =
ODT_INFO_LP4_CA_ODT(lp4_info->odt_info);
- if (dramtype == DDR3) {
p_drv = d3_phy_drv_2_ohm;
p_odt = d3_phy_odt_2_ohm;
- } else if (dramtype == LPDDR4) {
p_drv = lp4_phy_drv_2_ohm;
p_odt = lp4_phy_odt_2_ohm;
- } else {
p_drv = d4lp3_phy_drv_2_ohm;
p_odt = d4lp3_phy_odt_2_ohm;
- for (i = ARRAY_SIZE(d3_phy_drv_2_ohm) - 1; ; i--) {
if (phy_dq_drv_ohm <= *(*(p_drv + i) + 1)) {
phy_dq_drv = **(p_drv + i);
break;
if (i == 0)
break;
if (phy_clk_drv_ohm <= *(*(p_drv + i) + 1)) {
phy_clk_drv = **(p_drv + i);
break;
if (i == 0)
break;
if (phy_ca_drv_ohm <= *(*(p_drv + i) + 1)) {
phy_ca_drv = **(p_drv + i);
break;
if (i == 0)
break;
- if (!phy_odt_ohm)
phy_odt = 0;
- else
for (i = ARRAY_SIZE(d4lp3_phy_odt_2_ohm) - 1; ; i--) {
if (phy_odt_ohm <= *(*(p_odt + i) + 1)) {
phy_odt = **(p_odt + i);
break;
if (i == 0)
break;
- if (dramtype != LPDDR4) {
if (!phy_odt_ohm || (phy_odt_up_en && phy_odt_dn_en))
vref_inner = 0x80;
else if (phy_odt_up_en)
vref_inner = (2 * dram_drv_ohm + phy_odt_ohm) * 128 /
(dram_drv_ohm + phy_odt_ohm);
else
vref_inner = phy_odt_ohm * 128 /
(phy_odt_ohm + dram_drv_ohm);
if (dramtype != DDR3 && dram_odt_ohm)
vref_out = (2 * phy_dq_drv_ohm + dram_odt_ohm) * 128 /
(phy_dq_drv_ohm + dram_odt_ohm);
else
vref_out = 0x80;
- } else {
/* for lp4 and lp4x*/
if (phy_odt_ohm)
vref_inner =
(PHY_LP4_DQ_VREF(lp4_info->vref_when_odten) *
256) / 1000;
else
vref_inner =
(PHY_LP4_DQ_VREF(lp4_info->vref_when_odtoff) *
256) / 1000;
vref_out = 0x80;
- /* default ZQCALIB bypass mode */
- clrsetbits_le32(PHY_REG(phy_base, 0x100), 0x1f, phy_ca_drv);
- clrsetbits_le32(PHY_REG(phy_base, 0x101), 0x1f, phy_ca_drv);
- clrsetbits_le32(PHY_REG(phy_base, 0x102), 0x1f, phy_clk_drv);
- clrsetbits_le32(PHY_REG(phy_base, 0x103), 0x1f, phy_clk_drv);
clrsetbits_le32(PHY_REG(phy_base, 0x107), 0x1f, phy_clk_drv);
clrsetbits_le32(PHY_REG(phy_base, 0x108), 0x1f, phy_clk_drv);
- } else {
clrsetbits_le32(PHY_REG(phy_base, 0x107), 0x1f, phy_ca_drv);
clrsetbits_le32(PHY_REG(phy_base, 0x108), 0x1f, phy_ca_drv);
- /* clk / cmd slew rate */
- clrsetbits_le32(PHY_REG(phy_base, 0x106), 0x1f, sr_clk);
- phy_lp4_drv_pd_en = (~phy_lp4_drv_pd_en) & 1;
- if (phy_odt_up_en)
phy_odt_up = phy_odt;
- if (phy_odt_dn_en)
phy_odt_dn = phy_odt;
- for (i = 0; i < 4; i++) {
j = 0x110 + i * 0x10;
clrsetbits_le32(PHY_REG(phy_base, j + 1), 0x1f, phy_odt_up);
clrsetbits_le32(PHY_REG(phy_base, j), 0x1f, phy_odt_dn);
clrsetbits_le32(PHY_REG(phy_base, j + 2), 0x1f, phy_dq_drv);
clrsetbits_le32(PHY_REG(phy_base, j + 3), 0x1f, phy_dq_drv);
writel(vref_inner, PHY_REG(phy_base, 0x118 + i * 0x10));
clrsetbits_le32(PHY_REG(phy_base, 0x114 + i * 0x10),
1 << 3, phy_lp4_drv_pd_en << 3);
clrbits_le32(PHY_REG(phy_base, 0x114 + i * 0x10), BIT(5));
/* dq slew rate */
clrsetbits_le32(PHY_REG(phy_base, 0x117 + i * 0x10),
0x1f, sr_dq);
- /* reg_rx_vref_value_update */
- setbits_le32(PHY_REG(phy_base, 0x71), 1 << 5);
- clrbits_le32(PHY_REG(phy_base, 0x71), 1 << 5);
- /* RAM VREF */
- writel(vref_out, PHY_REG(phy_base, 0x105));
- if (dramtype == LPDDR3)
udelay(100);
set_lp4_vref(dram, lp4_info, freq, dst_fsp, dramtype);
- if (dramtype == DDR3 || dramtype == DDR4) {
mr1_mr3 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) +
DDR_PCTL2_INIT3);
mr1_mr3 = mr1_mr3 >> PCTL2_DDR34_MR1_SHIFT & PCTL2_MR_MASK;
- } else {
DDR_PCTL2_INIT4);
mr1_mr3 = mr1_mr3 >> PCTL2_LPDDR234_MR3_SHIFT & PCTL2_MR_MASK;
mr1_mr3 &= ~(DDR3_DS_MASK | DDR3_RTT_NOM_MASK);
if (dram_drv_ohm == 34)
mr1_mr3 |= DDR3_DS_34;
if (dram_odt_ohm == 0)
mr1_mr3 |= DDR3_RTT_NOM_DIS;
else if (dram_odt_ohm <= 40)
mr1_mr3 |= DDR3_RTT_NOM_40;
else if (dram_odt_ohm <= 60)
mr1_mr3 |= DDR3_RTT_NOM_60;
else
mr1_mr3 |= DDR3_RTT_NOM_120;
- } else if (dramtype == DDR4) {
mr1_mr3 &= ~(DDR4_DS_MASK | DDR4_RTT_NOM_MASK);
if (dram_drv_ohm == 48)
mr1_mr3 |= DDR4_DS_48;
mr1_mr3 |= DDR4_RTT_NOM_DIS;
else if (dram_odt_ohm <= 34)
mr1_mr3 |= DDR4_RTT_NOM_34;
mr1_mr3 |= DDR4_RTT_NOM_40;
else if (dram_odt_ohm <= 48)
mr1_mr3 |= DDR4_RTT_NOM_48;
mr1_mr3 |= DDR4_RTT_NOM_60;
else
mr1_mr3 |= DDR4_RTT_NOM_120;
- } else if (dramtype == LPDDR3) {
if (dram_drv_ohm <= 34)
mr1_mr3 |= LPDDR3_DS_34;
else if (dram_drv_ohm <= 40)
mr1_mr3 |= LPDDR3_DS_40;
else if (dram_drv_ohm <= 48)
mr1_mr3 |= LPDDR3_DS_48;
else if (dram_drv_ohm <= 60)
mr1_mr3 |= LPDDR3_DS_60;
else if (dram_drv_ohm <= 80)
mr1_mr3 |= LPDDR3_DS_80;
lp3_odt_value = LPDDR3_ODT_DIS;
lp3_odt_value = LPDDR3_ODT_60;
else if (dram_odt_ohm <= 120)
lp3_odt_value = LPDDR3_ODT_120;
else
lp3_odt_value = LPDDR3_ODT_240;
- } else {/* for lpddr4 and lpddr4x */
/* MR3 for lp4 PU-CAL and PDDS */
mr1_mr3 &= ~(LPDDR4_PDDS_MASK | LPDDR4_PU_CAL_MASK);
mr1_mr3 |= lp4_pu_cal;
tmp = lp4_odt_calc(dram_drv_ohm);
if (!tmp)
tmp = LPDDR4_PDDS_240;
mr1_mr3 |= (tmp << LPDDR4_PDDS_SHIFT);
/* MR11 for lp4 ca odt, dq odt set */
mr11 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) +
DDR_PCTL2_INIT6);
mr11 = mr11 >> PCTL2_LPDDR4_MR11_SHIFT & PCTL2_MR_MASK;
mr11 &= ~(LPDDR4_DQODT_MASK | LPDDR4_CAODT_MASK);
tmp = lp4_odt_calc(dram_odt_ohm);
mr11 |= (tmp << LPDDR4_DQODT_SHIFT);
tmp = lp4_odt_calc(dram_caodt_ohm);
mr11 |= (tmp << LPDDR4_CAODT_SHIFT);
sw_set_req(dram);
DDR_PCTL2_INIT6,
PCTL2_MR_MASK << PCTL2_LPDDR4_MR11_SHIFT,
mr11 << PCTL2_LPDDR4_MR11_SHIFT);
sw_set_ack(dram);
/* MR22 for soc odt/odt-ck/odt-cs/odt-ca */
mr22 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) +
DDR_PCTL2_INIT7);
mr22 = mr22 >> PCTL2_LPDDR4_MR22_SHIFT & PCTL2_MR_MASK;
mr22 &= ~LPDDR4_SOC_ODT_MASK;
tmp = lp4_odt_calc(phy_odt_ohm);
mr22 |= tmp;
mr22 = mr22 |
(LP4_ODTE_CK_EN(lp4_info->cs_drv_ca_odt_info) <<
LPDDR4_ODTE_CK_SHIFT) |
(LP4_ODTE_CS_EN(lp4_info->cs_drv_ca_odt_info) <<
LPDDR4_ODTE_CS_SHIFT) |
(LP4_ODTD_CA_EN(lp4_info->cs_drv_ca_odt_info) <<
LPDDR4_ODTD_CA_SHIFT);
sw_set_req(dram);
DDR_PCTL2_INIT7,
PCTL2_MR_MASK << PCTL2_LPDDR4_MR22_SHIFT,
mr22 << PCTL2_LPDDR4_MR22_SHIFT);
sw_set_ack(dram);
- if (dramtype == DDR4 || dramtype == DDR3) {
sw_set_req(dram);
DDR_PCTL2_INIT3,
PCTL2_MR_MASK << PCTL2_DDR34_MR1_SHIFT,
mr1_mr3 << PCTL2_DDR34_MR1_SHIFT);
sw_set_ack(dram);
- } else {
sw_set_req(dram);
DDR_PCTL2_INIT4,
PCTL2_MR_MASK << PCTL2_LPDDR234_MR3_SHIFT,
mr1_mr3 << PCTL2_LPDDR234_MR3_SHIFT);
sw_set_ack(dram);
+static int sdram_cmd_dq_path_remap(struct dram_info *dram,
(struct sdram_head_info_index_v2 *)common_info;
- struct dq_map_info *map_info;
- map_info = (struct dq_map_info *)((void *)common_info +
index->dq_map_index.offset * 4);
- if (dramtype <= LPDDR4)
writel((map_info->byte_map[dramtype / 4] >>
((dramtype % 4) * 8)) & 0xff,
PHY_REG(phy_base, 0x4f));
+static void phy_cfg(struct dram_info *dram,
- u32 i, dq_map, tmp;
- u32 byte1 = 0, byte0 = 0;
- sdram_cmd_dq_path_remap(dram, sdram_params);
- phy_pll_set(dram, sdram_params->base.ddr_freq * MHZ, 0);
- for (i = 0; sdram_params->phy_regs.phy[i][0] != 0xFFFFFFFF; i++) {
writel(sdram_params->phy_regs.phy[i][1],
phy_base + sdram_params->phy_regs.phy[i][0]);
- clrbits_le32(PHY_REG(phy_base, 0x62), BIT(5));
- dq_map = readl(PHY_REG(phy_base, 0x4f));
if (((dq_map >> (i * 2)) & 0x3) == 0)
byte0 = i;
if (((dq_map >> (i * 2)) & 0x3) == 1)
byte1 = i;
- tmp = readl(PHY_REG(phy_base, 0xf)) & (~PHY_DQ_WIDTH_MASK);
- if (cap_info->bw == 2)
tmp |= 0xf;
- else if (cap_info->bw == 1)
tmp |= ((1 << byte0) | (1 << byte1));
- else
tmp |= (1 << byte0);
- writel(tmp, PHY_REG(phy_base, 0xf));
- /* lpddr4 odt control by phy, enable cs0 odt */
- if (sdram_params->base.dramtype == LPDDR4)
clrsetbits_le32(PHY_REG(phy_base, 0x20), 0x7 << 4,
(1 << 6) | (1 << 4));
- /* for ca training ca vref choose range1 */
- setbits_le32(PHY_REG(phy_base, 0x1e), BIT(6));
- setbits_le32(PHY_REG(phy_base, 0x1f), BIT(6));
- /* for wr training PHY_0x7c[5], choose range0 */
- clrbits_le32(PHY_REG(phy_base, 0x7c), BIT(5));
+static int update_refresh_reg(struct dram_info *dram) +{
- u32 ret;
- ret = readl(pctl_base + DDR_PCTL2_RFSHCTL3) ^ (1 << 1);
- writel(ret, pctl_base + DDR_PCTL2_RFSHCTL3);
- rank = 1: cs0
- rank = 2: cs1
+int read_mr(struct dram_info *dram, u32 rank, u32 mr_num, u32 dramtype) +{
- u32 ret;
- u32 i, temp;
- u32 dqmap;
- if (dramtype == LPDDR2)
dqmap = map_info->lp2_dq0_7_map;
- else
dqmap = map_info->lp3_dq0_7_map;
- pctl_read_mr(pctl_base, rank, mr_num);
- ret = (readl(&dram->ddrgrf->ddr_grf_status[0]) & 0xff);
temp = 0;
for (i = 0; i < 8; i++) {
temp = temp | (((ret >> i) & 0x1) <<
((dqmap >> (i * 4)) & 0xf));
- } else {
temp = (readl(&dram->ddrgrf->ddr_grf_status[1]) & 0xff);
- return temp;
+/* before call this function autorefresh should be disabled */ +void send_a_refresh(struct dram_info *dram) +{
- while (readl(pctl_base + DDR_PCTL2_DBGSTAT) & 0x3)
continue;
- writel(0x3, pctl_base + DDR_PCTL2_DBGCMD);
+static void enter_sr(struct dram_info *dram, u32 en) +{
- if (en) {
setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, PCTL2_SELFREF_SW);
while (1) {
if (((readl(pctl_base + DDR_PCTL2_STAT) &
PCTL2_SELFREF_TYPE_MASK) ==
PCTL2_SELFREF_TYPE_SR_NOT_AUTO) &&
PCTL2_OPERATING_MODE_MASK) ==
PCTL2_OPERATING_MODE_SR))
break;
- } else {
clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, PCTL2_SELFREF_SW);
while ((readl(pctl_base + DDR_PCTL2_STAT) &
PCTL2_OPERATING_MODE_MASK) == PCTL2_OPERATING_MODE_SR)
continue;
+void record_dq_prebit(struct dram_info *dram) +{
- u32 group, i, tmp;
- for (group = 0; group < 4; group++) {
for (i = 0; i < ARRAY_SIZE(dq_sel); i++) {
/* l_loop_invdelaysel */
writel(dq_sel[i][0], PHY_REG(phy_base,
grp_addr[group] + 0x2c));
tmp = readl(PHY_REG(phy_base, grp_addr[group] + 0x2e));
grp_addr[group] + dq_sel[i][1]));
/* r_loop_invdelaysel */
grp_addr[group] + 0x2d));
tmp = readl(PHY_REG(phy_base, grp_addr[group] + 0x2f));
grp_addr[group] + dq_sel[i][2]));
+static void update_dq_rx_prebit(struct dram_info *dram) +{
- clrsetbits_le32(PHY_REG(phy_base, 0x70), BIT(1) | BIT(6) | BIT(4),
BIT(4));
- udelay(1);
- clrbits_le32(PHY_REG(phy_base, 0x70), BIT(4));
+static void update_dq_tx_prebit(struct dram_info *dram) +{
- clrbits_le32(PHY_REG(phy_base, 0x7a), BIT(1));
- setbits_le32(PHY_REG(phy_base, 0x2), BIT(3));
- setbits_le32(PHY_REG(phy_base, 0xc), BIT(6));
- udelay(1);
- clrbits_le32(PHY_REG(phy_base, 0xc), BIT(6));
+static void update_ca_prebit(struct dram_info *dram) +{
- clrbits_le32(PHY_REG(phy_base, 0x25), BIT(2));
- setbits_le32(PHY_REG(phy_base, 0x22), BIT(6));
- udelay(1);
- clrbits_le32(PHY_REG(phy_base, 0x22), BIT(6));
- dir: 0: de-skew = delta_*
- 1: de-skew = reg val - delta_*
- delta_dir: value for differential signal: clk/
- delta_sig: value for single signal: ca/cmd
+static void modify_ca_deskew(struct dram_info *dram, u32 dir, int delta_dif,
int delta_sig, u32 cs, u32 dramtype)
- u32 i, cs_en, tmp;
- u32 dfi_lp_stat = 0;
- if (cs == 0)
cs_en = 1;
- else if (cs == 2)
cs_en = 2;
- else
cs_en = 3;
- if (dramtype == LPDDR4 &&
((readl(PHY_REG(phy_base, 0x60)) & BIT(5)) == 0)) {
dfi_lp_stat = 1;
setbits_le32(PHY_REG(phy_base, 0x60), BIT(5));
- enter_sr(dram, 1);
- for (i = 0; i < 0x20; i++) {
if (dir == DESKEW_MDF_ABS_VAL)
tmp = delta_sig;
else
tmp = readl(PHY_REG(phy_base, 0x150 + i)) +
delta_sig;
writel(tmp, PHY_REG(phy_base, 0x150 + i));
- if (dir == DESKEW_MDF_ABS_VAL)
tmp = delta_dif;
- else
tmp = readl(PHY_REG(phy_base, 0x150 + 0x17)) -
delta_sig + delta_dif;
- writel(tmp, PHY_REG(phy_base, 0x150 + 0x17));
- writel(tmp, PHY_REG(phy_base, 0x150 + 0x18));
writel(tmp, PHY_REG(phy_base, 0x150 + 0x4));
writel(tmp, PHY_REG(phy_base, 0x150 + 0xa));
clrbits_le32(PHY_REG(phy_base, 0x10), cs_en << 6);
update_ca_prebit(dram);
- enter_sr(dram, 0);
- if (dfi_lp_stat)
clrbits_le32(PHY_REG(phy_base, 0x60), BIT(5));
+static u32 get_min_value(struct dram_info *dram, u32 signal, u32 rank) +{
- u32 i, j, offset = 0;
- u32 min = 0x3f;
- u32 byte_en;
- if (signal == SKEW_TX_SIGNAL)
offset = 8;
- if (signal == SKEW_CA_SIGNAL) {
min = MIN(min, readl(PHY_REG(phy_base, 0x150 + i)));
- } else {
byte_en = readl(PHY_REG(phy_base, 0xf)) & 0xf;
for (j = offset; j < offset + rank * 4; j++) {
if (!((byte_en >> (j % 4)) & 1))
continue;
for (i = 0; i < 11; i++)
min = MIN(min,
dqs_dq_skew_adr[j] +
i)));
- return min;
+static u32 low_power_update(struct dram_info *dram, u32 en) +{
- u32 lp_stat = 0;
- if (en) {
setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, en & 0xf);
- } else {
lp_stat = readl(pctl_base + DDR_PCTL2_PWRCTL) & 0xf;
clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 0xf);
- return lp_stat;
- signal:
- delta_dir: value for differential signal: dqs
- delta_sig: value for single signal: dq/dm
+static void modify_dq_deskew(struct dram_info *dram, u32 signal, u32 dir,
int delta_dif, int delta_sig, u32 rank)
- u32 i, j, tmp, offset;
- u32 byte_en;
- byte_en = readl(PHY_REG(phy_base, 0xf)) & 0xf;
- if (signal == SKEW_RX_SIGNAL)
offset = 0;
- else
offset = 8;
- for (j = offset; j < (offset + rank * 4); j++) {
continue;
for (i = 0; i < 0x9; i++) {
tmp = delta_sig;
else
tmp = delta_sig + readl(PHY_REG(phy_base,
i));
writel(tmp, PHY_REG(phy_base, dqs_dq_skew_adr[j] + i));
tmp = delta_dif;
else
tmp = delta_dif + readl(PHY_REG(phy_base,
dqs_dq_skew_adr[j] + 9));
writel(tmp, PHY_REG(phy_base, dqs_dq_skew_adr[j] + 9));
writel(tmp, PHY_REG(phy_base, dqs_dq_skew_adr[j] + 0xa));
update_dq_rx_prebit(dram);
- else
update_dq_tx_prebit(dram);
+static int data_training_rg(struct dram_info *dram, u32 cs, u32 dramtype) +{
- u32 ret;
- u32 dis_auto_zq = 0;
- u32 odt_val_up, odt_val_dn;
- u32 i, j;
- odt_val_dn = readl(PHY_REG(phy_base, 0x110));
- odt_val_up = readl(PHY_REG(phy_base, 0x111));
writel(PHY_DDR4_LPDDR3_RTT_294ohm,
PHY_REG(phy_base, j));
writel(PHY_DDR4_LPDDR3_RTT_DISABLE,
PHY_REG(phy_base, j + 0x1));
- dis_auto_zq = pctl_dis_zqcs_aref(dram->pctl);
- /* use normal read mode for data training */
- clrbits_le32(PHY_REG(phy_base, 0xc), BIT(1));
setbits_le32(PHY_REG(phy_base, 0xc), BIT(1));
- /* choose training cs */
- clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs));
- /* enable gate training */
- clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 1);
- udelay(50);
- ret = readl(PHY_REG(phy_base, 0x91));
- /* disable gate training */
- clrsetbits_le32(PHY_REG(phy_base, 2), 0x33, (0x20 >> cs) | 0);
- clrbits_le32(PHY_REG(phy_base, 2), 0x30);
- pctl_rest_zqcs_aref(dram->pctl, dis_auto_zq);
- ret = (ret & 0x2f) ^ (readl(PHY_REG(phy_base, 0xf)) & 0xf);
writel(odt_val_dn, PHY_REG(phy_base, j));
writel(odt_val_up, PHY_REG(phy_base, j + 0x1));
- return ret;
+static int data_training_wl(struct dram_info *dram, u32 cs, u32 dramtype,
u32 rank)
- u32 tmp;
- u32 cur_fsp;
- u32 timeout_us = 1000;
- clrbits_le32(PHY_REG(phy_base, 0x7a), 0x1);
- cur_fsp = readl(pctl_base + DDR_PCTL2_MSTR2) & 0x3;
- tmp = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + DDR_PCTL2_INIT3) &
0xffff;
- writel(tmp & 0xff, PHY_REG(phy_base, 0x3));
- /* disable another cs's output */
- if ((dramtype == DDR3 || dramtype == DDR4) && rank == 2)
pctl_write_mr(dram->pctl, (cs + 1) & 1, 1, tmp | (1 << 12),
dramtype);
writel(0x40 | ((tmp >> 8) & 0x3f), PHY_REG(phy_base, 0x4));
- else
writel(0x80 | ((tmp >> 8) & 0x3f), PHY_REG(phy_base, 0x4));
- /* choose cs */
- clrsetbits_le32(PHY_REG(phy_base, 2), (0x3 << 6) | (0x3 << 2),
((0x2 >> cs) << 6) | (0 << 2));
- /* enable write leveling */
((0x2 >> cs) << 6) | (1 << 2));
- while (1) {
if ((readl(PHY_REG(phy_base, 0x92)) & 0xf) ==
(readl(PHY_REG(phy_base, 0xf)) & 0xf))
break;
udelay(1);
if (timeout_us-- == 0) {
printascii("error: write leveling timeout\n");
while (1)
- /* disable write leveling */
- clrsetbits_le32(PHY_REG(phy_base, 2), 0x3 << 6, 0 << 6);
- /* enable another cs's output */
pctl_write_mr(dram->pctl, (cs + 1) & 1, 1, tmp & ~(1 << 12),
dramtype);
+char pattern[32] = {
- 0xaa, 0x55, 0xaa, 0x55, 0x55, 0xaa, 0x55, 0xaa,
- 0x55, 0xaa, 0x55, 0xaa, 0xaa, 0x55, 0xaa, 0x55,
- 0x55, 0x55, 0xaa, 0xaa, 0xaa, 0xaa, 0x55, 0x55,
- 0xaa, 0xaa, 0x55, 0x55, 0x55, 0x55, 0xaa, 0xaa
+static int data_training_rd(struct dram_info *dram, u32 cs, u32 dramtype,
u32 mhz)
- u32 trefi_1x, trfc_1x;
- u32 dqs_default;
- u32 cur_fsp;
- u32 vref_inner;
- u32 i;
- vref_inner = readl(PHY_REG(phy_base, 0x128)) & 0xff;
- if (dramtype == DDR3 && vref_inner == 0x80) {
writel(vref_inner - 0xa,
- /* only 1cs a time, 0:cs0 1 cs1 */
- if (cs > 1)
return -1;
- dqs_default = 0xf;
- /* config refresh timing */
- trefi_1x = ((readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) +
DDR_PCTL2_RFSHTMG) >> 16) & 0xfff) * 32;
- trfc_1x = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) +
DDR_PCTL2_RFSHTMG) & 0x3ff;
- /* reg_phy_trefi[7:0] and reg_phy_trefi[13:8] */
- clrsetbits_le32(PHY_REG(phy_base, 0x6e), 0xff, trefi_1x & 0xff);
- clrsetbits_le32(PHY_REG(phy_base, 0x6f), 0x3f, (trefi_1x >> 8) & 0x3f);
- /* reg_phy_trfc */
- clrsetbits_le32(PHY_REG(phy_base, 0x57), 0xff, trfc_1x);
- /* reg_max_refi_cnt */
- clrsetbits_le32(PHY_REG(phy_base, 0x61), 0xf << 4, 0x8 << 4);
- clrsetbits_le32(PHY_REG(phy_base, 0x71), 0x3 << 6, (0x2 >> cs) << 6);
- /* set dq map for ddr4 */
- if (dramtype == DDR4) {
setbits_le32(PHY_REG(phy_base, 0x70), BIT(7));
writel((map_info->ddr4_dq_map[cs * 2] >>
((i % 4) * 8)) & 0xff,
PHY_REG(phy_base, 0x238 + i));
writel((map_info->ddr4_dq_map[cs * 2 + 1] >>
PHY_REG(phy_base, 0x2b8 + i));
- /* cha_l reg_l_rd_train_dqs_default[5:0] */
- clrsetbits_le32(PHY_REG(phy_base, 0x230), 0x3f, dqs_default);
- /* cha_h reg_h_rd_train_dqs_default[5:0] */
- clrsetbits_le32(PHY_REG(phy_base, 0x234), 0x3f, dqs_default);
- /* chb_l reg_l_rd_train_dqs_default[5:0] */
- clrsetbits_le32(PHY_REG(phy_base, 0x2b0), 0x3f, dqs_default);
- /* chb_h reg_h_rd_train_dqs_default[5:0] */
- clrsetbits_le32(PHY_REG(phy_base, 0x2b4), 0x3f, dqs_default);
- /* Choose the read train auto mode */
- clrsetbits_le32(PHY_REG(phy_base, 0x70), 0x3, 0x1);
- /* Enable the auto train of the read train */
- clrsetbits_le32(PHY_REG(phy_base, 0x70), 0x3, 0x3);
- /* Wait the train done. */
- while (1) {
if ((readl(PHY_REG(phy_base, 0x93)) >> 7) & 0x1)
break;
udelay(1);
printascii("error: read training timeout\n");
return -1;
- /* Check the read train state */
- if ((readl(PHY_REG(phy_base, 0x240)) & 0x3) ||
(readl(PHY_REG(phy_base, 0x2c0)) & 0x3)) {
printascii("error: read training error\n");
return -1;
- /* Exit the Read Training by setting */
- clrbits_le32(PHY_REG(phy_base, 0x70), BIT(1));
writel(vref_inner,
+static int data_training_wr(struct dram_info *dram, u32 cs, u32 dramtype,
u32 mhz, u32 dst_fsp)
- u32 cur_fsp;
- u32 mr_tmp, cl, cwl, phy_fsp, offset = 0;
- if (dramtype == LPDDR3 && mhz <= 400) {
phy_fsp = (readl(PHY_REG(phy_base, 0xc)) >> 0x2) & 0x3;
offset = (phy_fsp == 0) ? 0x5 : 0x387 + (phy_fsp - 1) * 3;
cl = readl(PHY_REG(phy_base, offset));
cwl = readl(PHY_REG(phy_base, offset + 2));
clrsetbits_le32(PHY_REG(phy_base, offset), 0x1f, 0x8);
clrsetbits_le32(PHY_REG(phy_base, offset + 2), 0x1f, 0x4);
pctl_write_mr(dram->pctl, 3, 2, 0x6, dramtype);
- /* PHY_0x7b[7:0] reg_train_col_addr[7:0] */
- clrsetbits_le32(PHY_REG(phy_base, 0x7b), 0xff, 0x0);
- /* PHY_0x7c[4:2] reg_train_ba_addr[2:0] */
- clrsetbits_le32(PHY_REG(phy_base, 0x7c), 0x7 << 2, 0x0 << 2);
- /* PHY_0x7c[1:0] reg_train_col_addr[9:8] */
- clrsetbits_le32(PHY_REG(phy_base, 0x7c), 0x3, 0x0);
- /* PHY_0x7d[7:0] reg_train_row_addr[7:0] */
- clrsetbits_le32(PHY_REG(phy_base, 0x7d), 0xff, 0x0);
- /* PHY_0x7e[7:0] reg_train_row_addr[15:8] */
- clrsetbits_le32(PHY_REG(phy_base, 0x7e), 0xff, 0x0);
- /* PHY_0x71[3] wrtrain_check_data_value_random_gen */
- clrbits_le32(PHY_REG(phy_base, 0x71), BIT(3));
- clrsetbits_le32(PHY_REG(phy_base, 0x7c), 0x3 << 6, (0x2 >> cs) << 6);
- /* PHY_0x7a [4] reg_wr_train_dqs_default_bypass */
- /* 0: Use the write-leveling value. */
- /* 1: use reg0x233 0x237 0x2b3 0x2b7 */
- setbits_le32(PHY_REG(phy_base, 0x7a), BIT(4));
- /* PHY_0x7a [0] reg_dq_wr_train_auto */
- setbits_le32(PHY_REG(phy_base, 0x7a), 0x1);
- /* PHY_0x7a [1] reg_dq_wr_train_en */
- setbits_le32(PHY_REG(phy_base, 0x7a), BIT(1));
- send_a_refresh(dram);
- while (1) {
if ((readl(PHY_REG(phy_base, 0x92)) >> 7) & 0x1)
break;
udelay(1);
printascii("error: write training timeout\n");
while (1)
- /* Check the write train state */
- if ((readl(PHY_REG(phy_base, 0x90)) >> 5) & 0x7) {
printascii("error: write training error\n");
return -1;
- /* save LPDDR4 write vref to fsp_param for dfs */
fsp_param[dst_fsp].vref_dq[cs] =
((readl(PHY_REG(phy_base, 0x384)) & 0x3f) +
(readl(PHY_REG(phy_base, 0x385)) & 0x3f)) / 2;
/* add range info */
fsp_param[dst_fsp].vref_dq[cs] |=
((readl(PHY_REG(phy_base, 0x7c)) & BIT(5)) << 1);
clrsetbits_le32(PHY_REG(phy_base, offset), 0x1f, cl);
clrsetbits_le32(PHY_REG(phy_base, offset + 2), 0x1f, cwl);
mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) +
DDR_PCTL2_INIT3);
pctl_write_mr(dram->pctl, 3, 2, mr_tmp & PCTL2_MR_MASK,
dramtype);
+static int data_training(struct dram_info *dram, u32 cs,
struct rv1126_sdram_params *sdram_params, u32 dst_fsp,
u32 training_flag)
- u32 ret = 0;
- if (training_flag == FULL_TRAINING)
training_flag = READ_GATE_TRAINING | WRITE_LEVELING |
WRITE_TRAINING | READ_TRAINING;
- if ((training_flag & WRITE_LEVELING) == WRITE_LEVELING) {
ret = data_training_wl(dram, cs,
sdram_params->base.dramtype,
sdram_params->ch.cap_info.rank);
if (ret != 0)
goto out;
- if ((training_flag & READ_GATE_TRAINING) == READ_GATE_TRAINING) {
ret = data_training_rg(dram, cs,
sdram_params->base.dramtype);
if (ret != 0)
goto out;
- if ((training_flag & READ_TRAINING) == READ_TRAINING) {
ret = data_training_rd(dram, cs,
sdram_params->base.ddr_freq);
if (ret != 0)
goto out;
- if ((training_flag & WRITE_TRAINING) == WRITE_TRAINING) {
ret = data_training_wr(dram, cs,
sdram_params->base.ddr_freq, dst_fsp);
if (ret != 0)
goto out;
+out:
- return ret;
+static int get_wrlvl_val(struct dram_info *dram,
- int i, j, clk_skew;
- u32 lp_stat;
- int ret;
- lp_stat = low_power_update(dram, 0);
- clk_skew = 0x1f;
- modify_ca_deskew(dram, DESKEW_MDF_ABS_VAL, clk_skew, clk_skew, 3,
- ret = data_training(dram, 0, sdram_params, 0, WRITE_LEVELING);
- if (sdram_params->ch.cap_info.rank == 2)
ret |= data_training(dram, 1, sdram_params, 0, WRITE_LEVELING);
- for (j = 0; j < 2; j++)
wrlvl_result[j][i] =
(readl(PHY_REG(phy_base, wrlvl_result_offset[j][i])) & 0x3f) -
clk_skew;
- low_power_update(dram, lp_stat);
- return ret;
+#if defined(CONFIG_CMD_DDR_TEST_TOOL) +static void init_rw_trn_result_struct(struct rw_trn_result *result,
void __iomem *phy_base, u8 cs_num)
- int i;
- result->cs_num = cs_num;
- result->byte_en = readb(PHY_REG(dram_info.phy, 0xf)) &
PHY_DQ_WIDTH_MASK;
- for (i = 0; i < FSP_NUM; i++)
result->fsp_mhz[i] = 0;
+static void save_rw_trn_min_max(void __iomem *phy_base,
struct cs_rw_trn_result *rd_result,
struct cs_rw_trn_result *wr_result,
u8 byte_en)
- u16 phy_ofs;
- u8 dqs;
- u8 dq;
- for (dqs = 0; dqs < BYTE_NUM; dqs++) {
if ((byte_en & BIT(dqs)) == 0)
continue;
/* Channel A or B (low or high 16 bit) */
phy_ofs = dqs < 2 ? 0x230 : 0x2b0;
/* low or high 8 bit */
phy_ofs += (dqs & 0x1) == 0 ? 0 : 0x9;
for (dq = 0; dq < 8; dq++) {
rd_result->dqs[dqs].dq_min[dq] =
readb(PHY_REG(phy_base, phy_ofs + 0x15 + dq));
rd_result->dqs[dqs].dq_max[dq] =
readb(PHY_REG(phy_base, phy_ofs + 0x27 + dq));
wr_result->dqs[dqs].dq_min[dq] =
readb(PHY_REG(phy_base, phy_ofs + 0x3d + dq));
wr_result->dqs[dqs].dq_max[dq] =
readb(PHY_REG(phy_base, phy_ofs + 0x4f + dq));
+static void save_rw_trn_deskew(void __iomem *phy_base,
struct fsp_rw_trn_result *result, u8 cs_num,
int min_val, bool rw)
- u16 phy_ofs;
- u8 cs;
- u8 dq;
- result->min_val = min_val;
- for (cs = 0; cs < cs_num; cs++) {
phy_ofs = cs == 0 ? 0x170 : 0x1a0;
phy_ofs += rw == SKEW_RX_SIGNAL ? 0x1 : 0x17;
result->cs[cs].dqs[0].dq_deskew[dq] =
readb(PHY_REG(phy_base, phy_ofs + dq));
result->cs[cs].dqs[1].dq_deskew[dq] =
readb(PHY_REG(phy_base, phy_ofs + 0xb + dq));
result->cs[cs].dqs[2].dq_deskew[dq] =
readb(PHY_REG(phy_base, phy_ofs + 0x60 + dq));
result->cs[cs].dqs[3].dq_deskew[dq] =
readb(PHY_REG(phy_base, phy_ofs + 0x60 + 0xb + dq));
result->cs[cs].dqs[0].dqs_deskew =
readb(PHY_REG(phy_base, phy_ofs + 0x8));
result->cs[cs].dqs[1].dqs_deskew =
readb(PHY_REG(phy_base, phy_ofs + 0xb + 0x8));
result->cs[cs].dqs[2].dqs_deskew =
readb(PHY_REG(phy_base, phy_ofs + 0x60 + 0x8));
result->cs[cs].dqs[3].dqs_deskew =
readb(PHY_REG(phy_base, phy_ofs + 0x60 + 0xb + 0x8));
+static void save_rw_trn_result_to_ddr(struct rw_trn_result *result) +{
- result->flag = DDR_DQ_EYE_FLAG;
- memcpy((void *)(RW_TRN_RESULT_ADDR), result, sizeof(*result));
+} +#endif
+static int high_freq_training(struct dram_info *dram,
u32 fsp)
- u32 i, j;
- int min_val;
- int dqs_skew, clk_skew, ca_skew;
- u8 byte_en;
- int ret;
- byte_en = readl(PHY_REG(phy_base, 0xf)) & PHY_DQ_WIDTH_MASK;
- dqs_skew = 0;
- for (j = 0; j < sdram_params->ch.cap_info.rank; j++) {
for (i = 0; i < ARRAY_SIZE(wrlvl_result[0]); i++) {
if ((byte_en & BIT(i)) != 0)
dqs_skew += wrlvl_result[j][i];
- dqs_skew = dqs_skew /
(int)(sdram_params->ch.cap_info.rank * (1 << sdram_params->ch.cap_info.bw));
- clk_skew = 0x20 - dqs_skew;
- dqs_skew = 0x20;
min_val = 0xff;
for (i = 0; i < sdram_params->ch.cap_info.bw; i++)
min_val = MIN(wrlvl_result[j][i], min_val);
if (min_val < 0) {
clk_skew = -min_val;
ca_skew = -min_val;
} else {
clk_skew = 0;
ca_skew = 0;
ca_skew = clk_skew - 4;
- } else {
ca_skew = clk_skew;
- modify_ca_deskew(dram, DESKEW_MDF_ABS_VAL, clk_skew, ca_skew, 3,
dramtype);
- writel(wrlvl_result[0][0] + clk_skew, PHY_REG(phy_base, 0x233));
- writel(wrlvl_result[0][1] + clk_skew, PHY_REG(phy_base, 0x237));
- writel(wrlvl_result[0][2] + clk_skew, PHY_REG(phy_base, 0x2b3));
- writel(wrlvl_result[0][3] + clk_skew, PHY_REG(phy_base, 0x2b7));
- ret = data_training(dram, 0, sdram_params, fsp, READ_GATE_TRAINING |
READ_TRAINING | WRITE_TRAINING);
- rw_trn_result.fsp_mhz[fsp] = (u16)sdram_params->base.ddr_freq;
- save_rw_trn_min_max(phy_base, &rw_trn_result.rd_fsp[fsp].cs[0],
&rw_trn_result.wr_fsp[fsp].cs[0],
rw_trn_result.byte_en);
- if (sdram_params->ch.cap_info.rank == 2) {
writel(wrlvl_result[1][0] + clk_skew, PHY_REG(phy_base, 0x233));
writel(wrlvl_result[1][1] + clk_skew, PHY_REG(phy_base, 0x237));
writel(wrlvl_result[1][2] + clk_skew, PHY_REG(phy_base, 0x2b3));
writel(wrlvl_result[1][3] + clk_skew, PHY_REG(phy_base, 0x2b7));
ret |= data_training(dram, 1, sdram_params, fsp,
READ_GATE_TRAINING | READ_TRAINING |
WRITE_TRAINING);
save_rw_trn_min_max(phy_base, &rw_trn_result.rd_fsp[fsp].cs[1],
&rw_trn_result.wr_fsp[fsp].cs[1],
- if (ret)
goto out;
- record_dq_prebit(dram);
- min_val = get_min_value(dram, SKEW_RX_SIGNAL,
sdram_params->ch.cap_info.rank) * -1;
- modify_dq_deskew(dram, SKEW_RX_SIGNAL, DESKEW_MDF_DIFF_VAL,
min_val, min_val, sdram_params->ch.cap_info.rank);
- save_rw_trn_deskew(phy_base, &rw_trn_result.rd_fsp[fsp],
rw_trn_result.cs_num, (u8)(min_val * (-1)),
SKEW_RX_SIGNAL);
- min_val = MIN(get_min_value(dram, SKEW_TX_SIGNAL,
sdram_params->ch.cap_info.rank),
get_min_value(dram, SKEW_CA_SIGNAL,
sdram_params->ch.cap_info.rank)) * -1;
- /* clk = 0, rx all skew -7, tx - min_value */
- modify_ca_deskew(dram, DESKEW_MDF_DIFF_VAL, min_val, min_val, 3,
dramtype);
- modify_dq_deskew(dram, SKEW_TX_SIGNAL, DESKEW_MDF_DIFF_VAL,
- save_rw_trn_deskew(phy_base, &rw_trn_result.wr_fsp[fsp],
SKEW_TX_SIGNAL);
- ret = data_training(dram, 0, sdram_params, 0, READ_GATE_TRAINING);
+out:
- return ret;
+static void set_ddrconfig(struct dram_info *dram, u32 ddrconfig) +{
- writel(ddrconfig, &dram->msch->deviceconf);
- clrsetbits_le32(&dram->grf->noc_con0, 0x3 << 0, 0 << 0);
+static void update_noc_timing(struct dram_info *dram,
- u32 bw, bl;
- bw = 8 << sdram_params->ch.cap_info.bw;
- bl = ((readl(pctl_base + DDR_PCTL2_MSTR) >> 16) & 0xf) * 2;
- /* update the noc timing related to data bus width */
- if ((bw / 8 * bl) <= 16)
sdram_params->ch.noc_timings.ddrmode.b.burstsize = 0;
- else if ((bw / 8 * bl) == 32)
sdram_params->ch.noc_timings.ddrmode.b.burstsize = 1;
- else if ((bw / 8 * bl) == 64)
sdram_params->ch.noc_timings.ddrmode.b.burstsize = 2;
- else
sdram_params->ch.noc_timings.ddrmode.b.burstsize = 3;
- sdram_params->ch.noc_timings.ddrtimingc0.b.burstpenalty =
(bl * bw / 8) > 16 ? (bl / 4) : (16 / (bl * bw / 8)) * bl / 4;
- if (sdram_params->base.dramtype == LPDDR4) {
sdram_params->ch.noc_timings.ddrmode.b.mwrsize =
(bw == 16) ? 0x1 : 0x2;
sdram_params->ch.noc_timings.ddrtimingc0.b.wrtomwr =
3 * sdram_params->ch.noc_timings.ddrtimingc0.b.burstpenalty;
- writel(sdram_params->ch.noc_timings.ddrtiminga0.d32,
&dram->msch->ddrtiminga0);
- writel(sdram_params->ch.noc_timings.ddrtimingb0.d32,
&dram->msch->ddrtimingb0);
- writel(sdram_params->ch.noc_timings.ddrtimingc0.d32,
&dram->msch->ddrtimingc0);
- writel(sdram_params->ch.noc_timings.devtodev0.d32,
&dram->msch->devtodev0);
- writel(sdram_params->ch.noc_timings.ddrmode.d32, &dram->msch->ddrmode);
- writel(sdram_params->ch.noc_timings.ddr4timing.d32,
&dram->msch->ddr4timing);
+static int split_setup(struct dram_info *dram,
- u32 split_size, split_mode;
- u64 cs_cap[2], cap;
- cs_cap[0] = sdram_get_cs_cap(cap_info, 0, dramtype);
- cs_cap[1] = sdram_get_cs_cap(cap_info, 1, dramtype);
- /* only support the larger cap is in low 16bit */
- if (cap_info->cs0_high16bit_row < cap_info->cs0_row) {
cap = cs_cap[0] / (1 << (cap_info->cs0_row -
cap_info->cs0_high16bit_row));
- } else if ((cap_info->cs1_high16bit_row < cap_info->cs1_row) &&
(cap_info->rank == 2)) {
if (!cap_info->cs1_high16bit_row)
cap = cs_cap[0];
else
cap = cs_cap[0] + cs_cap[1] / (1 << (cap_info->cs1_row -
cap_info->cs1_high16bit_row));
- } else {
goto out;
- split_size = (u32)(cap >> 24) & SPLIT_SIZE_MASK;
split_mode = SPLIT_MODE_32_L16_VALID;
- else
split_mode = SPLIT_MODE_16_L8_VALID;
- rk_clrsetreg(&dram->ddrgrf->grf_ddrsplit_con,
(SPLIT_MODE_MASK << SPLIT_MODE_OFFSET) |
(SPLIT_BYPASS_MASK << SPLIT_BYPASS_OFFSET) |
(SPLIT_SIZE_MASK << SPLIT_SIZE_OFFSET),
(split_mode << SPLIT_MODE_OFFSET) |
(0x0 << SPLIT_BYPASS_OFFSET) |
(split_size << SPLIT_SIZE_OFFSET));
- rk_clrsetreg(BUS_SGRF_BASE_ADDR + SGRF_SOC_CON2,
MSCH_AXI_BYPASS_ALL_MASK << MSCH_AXI_BYPASS_ALL_SHIFT,
0x0 << MSCH_AXI_BYPASS_ALL_SHIFT);
+out:
+static void split_bypass(struct dram_info *dram) +{
- if ((readl(&dram->ddrgrf->grf_ddrsplit_con) &
(1 << SPLIT_BYPASS_OFFSET)) != 0)
return;
- /* bypass split */
(0x1 << SPLIT_BYPASS_OFFSET) |
(0x0 << SPLIT_SIZE_OFFSET));
+static void dram_all_config(struct dram_info *dram,
- u32 dram_type = sdram_params->base.dramtype;
- u32 sys_reg2 = 0;
- u32 sys_reg3 = 0;
- u64 cs_cap[2];
- u32 cs_pst;
- set_ddrconfig(dram, cap_info->ddrconfig);
- sdram_org_config(cap_info, &sdram_params->base, &sys_reg2,
&sys_reg3, 0);
- writel(sys_reg2, &dram->pmugrf->os_reg[2]);
- writel(sys_reg3, &dram->pmugrf->os_reg[3]);
- cs_cap[0] = sdram_get_cs_cap(cap_info, 0, dram_type);
- cs_cap[1] = sdram_get_cs_cap(cap_info, 1, dram_type);
- if (cap_info->rank == 2) {
cs_pst = (readl(pctl_base + DDR_PCTL2_ADDRMAP0) & 0x1f) +
6 + 2;
if (cs_pst > 28)
cs_cap[0] = 1llu << cs_pst;
- writel(((((cs_cap[1] >> 20) / 64) & 0xff) << 8) |
(((cs_cap[0] >> 20) / 64) & 0xff),
&dram->msch->devicesize);
- update_noc_timing(dram, sdram_params);
+static void enable_low_power(struct dram_info *dram,
- u32 grf_lp_con;
- writel(0x1f1f0617, &dram->ddrgrf->ddr_grf_con[1]);
grf_lp_con = (0x7 << 16) | (1 << 1);
- else if (sdram_params->base.dramtype == DDR3)
grf_lp_con = (0x7 << 16) | (1 << 0);
- else
grf_lp_con = (0x7 << 16) | (1 << 2);
- /* en lpckdis_en */
- grf_lp_con = grf_lp_con | (0x1 << (9 + 16)) | (0x1 << 9);
- writel(grf_lp_con, &dram->ddrgrf->ddr_grf_lp_con);
- /* enable sr, pd */
- if (dram->pd_idle == 0)
clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 1));
- else
setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 1));
- if (dram->sr_idle == 0)
clrbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 1);
- else
setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, 1);
- setbits_le32(pctl_base + DDR_PCTL2_PWRCTL, (1 << 3));
+static void print_ddr_info(struct rv1126_sdram_params *sdram_params) +{
- u32 split;
- if ((readl(DDR_GRF_BASE_ADDR + DDR_GRF_SPLIT_CON) &
split = 0;
- else
split = readl(DDR_GRF_BASE_ADDR + DDR_GRF_SPLIT_CON) &
SPLIT_SIZE_MASK;
- sdram_print_ddr_info(&sdram_params->ch.cap_info,
&sdram_params->base, split);
+static int sdram_init_(struct dram_info *dram,
struct rv1126_sdram_params *sdram_params, u32 post_init)
- u32 ddr4_vref;
- u32 mr_tmp;
- rkclk_configure_ddr(dram, sdram_params);
- rkclk_ddr_reset(dram, 1, 1, 1, 1);
- udelay(10);
- rkclk_ddr_reset(dram, 1, 1, 1, 0);
- phy_cfg(dram, sdram_params);
- rkclk_ddr_reset(dram, 1, 1, 0, 0);
- phy_pll_set(dram, sdram_params->base.ddr_freq * MHZ, 1);
- rkclk_ddr_reset(dram, 1, 0, 0, 0);
- pctl_cfg(dram->pctl, &sdram_params->pctl_regs,
dram->sr_idle, dram->pd_idle);
- if (sdram_params->ch.cap_info.bw == 2) {
/* 32bit interface use pageclose */
setbits_le32(pctl_base + DDR_PCTL2_SCHED, 1 << 2);
/* pageclose = 1, pageclose_timer = 0 will err in lp4 328MHz */
clrsetbits_le32(pctl_base + DDR_PCTL2_SCHED1, 0xff, 0x1 << 0);
- } else {
clrbits_le32(pctl_base + DDR_PCTL2_SCHED, 1 << 2);
+#ifdef CONFIG_ROCKCHIP_DRAM_EXTENDED_TEMP_SUPPORT
- u32 tmp, trefi;
- tmp = readl(pctl_base + DDR_PCTL2_RFSHTMG);
- trefi = (tmp >> 16) & 0xfff;
- writel((tmp & 0xf000ffff) | (trefi / 2) << 16,
- /* set frequency_mode */
- setbits_le32(pctl_base + DDR_PCTL2_MSTR, 0x1 << 29);
- /* set target_frequency to Frequency 0 */
- clrsetbits_le32(pctl_base + DDR_PCTL2_MSTR2, 0x3, 0);
- set_ds_odt(dram, sdram_params, 0);
- sdram_params->ch.cap_info.ddrconfig = calculate_ddrconfig(sdram_params);
- set_ctl_address_map(dram, sdram_params);
- setbits_le32(pctl_base + DDR_PCTL2_DFIMISC, (1 << 5) | (1 << 4));
- rkclk_ddr_reset(dram, 0, 0, 0, 0);
- while ((readl(pctl_base + DDR_PCTL2_STAT) & 0x7) == 0)
continue;
- if (sdram_params->base.dramtype == LPDDR3) {
pctl_write_mr(dram->pctl, 3, 11, lp3_odt_value, LPDDR3);
- } else if (sdram_params->base.dramtype == LPDDR4) {
mr_tmp = readl(pctl_base + DDR_PCTL2_INIT6);
/* MR11 */
mr_tmp >> PCTL2_LPDDR4_MR11_SHIFT & PCTL2_MR_MASK,
LPDDR4);
/* MR12 */
pctl_write_mr(dram->pctl, 3, 12,
mr_tmp >> PCTL2_LPDDR4_MR12_SHIFT & PCTL2_MR_MASK,
LPDDR4);
mr_tmp = readl(pctl_base + DDR_PCTL2_INIT7);
/* MR22 */
pctl_write_mr(dram->pctl, 3, 22,
mr_tmp >> PCTL2_LPDDR4_MR22_SHIFT & PCTL2_MR_MASK,
LPDDR4);
- if (data_training(dram, 0, sdram_params, 0, READ_GATE_TRAINING) != 0) {
if (post_init != 0)
printascii("DTT cs0 error\n");
return -1;
mr_tmp = read_mr(dram, 1, 14, LPDDR4);
if (mr_tmp != 0x4d)
return -1;
/* MR14 */
pctl_write_mr(dram->pctl, 3, 14,
mr_tmp >> PCTL2_LPDDR4_MR14_SHIFT & PCTL2_MR_MASK,
LPDDR4);
- if (post_init != 0 && sdram_params->ch.cap_info.rank == 2) {
if (data_training(dram, 1, sdram_params, 0,
printascii("DTT cs1 error\n");
return -1;
ddr4_vref = readl(PHY_REG(phy_base, 0x105)) * 39;
pctl_write_vrefdq(dram->pctl, 0x3, ddr4_vref,
- dram_all_config(dram, sdram_params);
- enable_low_power(dram, sdram_params);
+static u64 dram_detect_cap(struct dram_info *dram,
unsigned char channel)
- u32 mr8;
- u32 bktmp;
- u32 coltmp;
- u32 rowtmp;
- u32 cs;
- u32 pwrctl;
- u32 i, dq_map;
- u32 tmp, byte;
- struct sdram_head_info_index_v2 *index = (struct sdram_head_info_index_v2 *)common_info;
- struct dq_map_info *map_info = (struct dq_map_info *)
((void *)common_info + index->dq_map_index.offset * 4);
- cap_info->bw = dram_type == DDR3 ? 0 : 1;
- if (dram_type != LPDDR4) {
if (dram_type != DDR4) {
coltmp = 12;
bktmp = 3;
if (dram_type == LPDDR2)
rowtmp = 15;
else
rowtmp = 16;
if (sdram_detect_col(cap_info, coltmp) != 0)
goto cap_err;
sdram_detect_bank(cap_info, coltmp, bktmp);
if (dram_type != LPDDR3)
sdram_detect_dbw(cap_info, dram_type);
} else {
coltmp = 10;
bktmp = 4;
rowtmp = 17;
cap_info->col = 10;
cap_info->bk = 2;
sdram_detect_bg(cap_info, coltmp);
if (sdram_detect_row(cap_info, coltmp, bktmp, rowtmp) != 0)
goto cap_err;
sdram_detect_row_3_4(cap_info, coltmp, bktmp);
- } else {
cap_info->col = 10;
cap_info->bk = 3;
mr8 = read_mr(dram, 1, 8, dram_type);
cap_info->dbw = ((mr8 >> 6) & 0x3) == 0 ? 1 : 0;
mr8 = (mr8 >> 2) & 0xf;
if (mr8 >= 0 && mr8 <= 6) {
cap_info->cs0_row = 14 + (mr8 + 1) / 2;
} else if (mr8 == 0xc) {
cap_info->cs0_row = 13;
} else {
printascii("Cap ERR: Fail to get cap of LPDDR4/X from MR8\n");
goto cap_err;
if (cap_info->dbw == 0)
cap_info->cs0_row++;
cap_info->row_3_4 = mr8 % 2 == 1 ? 1 : 0;
if (cap_info->cs0_row >= 17) {
printascii("Cap ERR: ");
printascii("RV1126 LPDDR4/X cannot support row >= 17\n");
goto cap_err;
// cap_info->cs0_row = 16;
// cap_info->row_3_4 = 0;
- pwrctl = readl(pctl_base + DDR_PCTL2_PWRCTL);
- writel(0, pctl_base + DDR_PCTL2_PWRCTL);
- if (data_training(dram, 1, sdram_params, 0, READ_GATE_TRAINING) == 0)
cs = 1;
- else
cs = 0;
- cap_info->rank = cs + 1;
- setbits_le32(PHY_REG(phy_base, 0xf), 0xf);
- tmp = data_training_rg(dram, 0, dram_type) & 0xf;
- if (tmp == 0) {
cap_info->bw = 2;
- } else {
if (dram_type == DDR3 || dram_type == DDR4) {
dq_map = 0;
byte = 0;
if ((tmp & BIT(i)) == 0) {
dq_map |= byte << (i * 2);
byte++;
cap_info->bw = byte / 2;
if ((tmp & BIT(i)) != 0) {
byte++;
clrsetbits_le32(&map_info->byte_map[0], 0xff << 24, dq_map << 24);
} else {
byte0 = i;
byte1 = i;
clrsetbits_le32(PHY_REG(phy_base, 0xf), PHY_DQ_WIDTH_MASK,
BIT(byte0) | BIT(byte1));
if (data_training(dram, 0, sdram_params, 0, READ_GATE_TRAINING) == 0)
cap_info->bw = 1;
else
cap_info->bw = 0;
- if (cap_info->bw > 0)
cap_info->dbw = 1;
- writel(pwrctl, pctl_base + DDR_PCTL2_PWRCTL);
- cap_info->cs0_high16bit_row = cap_info->cs0_row;
- if (cs) {
cap_info->cs1_row = cap_info->cs0_row;
cap_info->cs1_high16bit_row = cap_info->cs0_row;
- } else {
cap_info->cs1_row = 0;
cap_info->cs1_high16bit_row = 0;
- if (dram_type == LPDDR3)
+cap_err:
- return -1;
+static int dram_detect_cs1_row(struct dram_info *dram,
- u32 ret = 0;
- void __iomem *test_addr;
- u32 row, bktmp, coltmp, bw;
- u64 cs0_cap;
- u32 byte_mask;
- u32 cs_pst;
- u32 cs_add = 0;
- u32 max_row;
6 + 2;
if (cs_pst < 28)
cs_add = 1;
cs0_cap = 1 << cs_pst;
bktmp = cap_info->bk + 2;
else
bktmp = cap_info->bk + 1;
} else {
bktmp = cap_info->bk;
bw = cap_info->bw;
coltmp = cap_info->col;
if (bw == 2)
byte_mask = 0xFFFF;
else
byte_mask = 0xFF;
max_row = (cs_pst == 31) ? 30 : 31;
max_row = max_row - bktmp - coltmp - bw - cs_add + 1;
row = (cap_info->cs0_row > max_row) ? max_row :
cap_info->cs0_row;
for (; row > 12; row--) {
test_addr = (void __iomem *)(CONFIG_SYS_SDRAM_BASE +
(u32)cs0_cap +
(1ul << (row + bktmp + coltmp +
cs_add + bw - 1ul)));
writel(0, CONFIG_SYS_SDRAM_BASE + (u32)cs0_cap);
writel(PATTERN, test_addr);
if (((readl(test_addr) & byte_mask) ==
(PATTERN & byte_mask)) &&
((readl(CONFIG_SYS_SDRAM_BASE + (u32)cs0_cap) &
byte_mask) == 0)) {
ret = row;
break;
- return ret;
+/* return: 0 = success, other = fail */ +static int sdram_init_detect(struct dram_info *dram,
- u32 ret;
- u32 sys_reg = 0;
- u32 sys_reg3 = 0;
- if (sdram_init_(dram, sdram_params, 0)) {
if (sdram_params->base.dramtype == DDR3) {
((0x1 << 6) | (0x3 << 4) | (0x2 << 2) |
(0x0 << 0)) << 24);
return -1;
} else {
return -1;
- if (sdram_params->base.dramtype == DDR3) {
writel(PATTERN, CONFIG_SYS_SDRAM_BASE);
if (readl(CONFIG_SYS_SDRAM_BASE) != PATTERN)
return -1;
- split_bypass(dram);
- if (dram_detect_cap(dram, sdram_params, 0) != 0)
return -1;
- pctl_remodify_sdram_params(&sdram_params->pctl_regs, cap_info,
- ret = sdram_init_(dram, sdram_params, 1);
- if (ret != 0)
goto out;
- cap_info->cs1_row =
dram_detect_cs1_row(dram, sdram_params, 0);
- if (cap_info->cs1_row) {
sys_reg = readl(&dram->pmugrf->os_reg[2]);
sys_reg3 = readl(&dram->pmugrf->os_reg[3]);
SYS_REG_ENC_CS1_ROW(cap_info->cs1_row,
sys_reg, sys_reg3, 0);
writel(sys_reg, &dram->pmugrf->os_reg[2]);
- sdram_detect_high_row(cap_info, sdram_params->base.dramtype);
- split_setup(dram, sdram_params);
+out:
- return ret;
+struct rv1126_sdram_params *get_default_sdram_config(u32 freq_mhz) +{
- u32 i;
- u32 offset = 0;
- if (!freq_mhz) {
ddr_info = get_ddr_drv_odt_info(sdram_configs[0].base.dramtype);
if (ddr_info)
freq_mhz =
(ddr_info->ddr_freq0_1 >> DDR_FREQ_F0_SHIFT) &
DDR_FREQ_MASK;
else
freq_mhz = 0;
- for (i = 0; i < ARRAY_SIZE(sdram_configs); i++) {
if (sdram_configs[i].base.ddr_freq == 0 ||
freq_mhz < sdram_configs[i].base.ddr_freq)
break;
- offset = i == 0 ? 0 : i - 1;
- return &sdram_configs[offset];
+static const u16 pctl_need_update_reg[] = {
- DDR_PCTL2_RFSHTMG,
- DDR_PCTL2_INIT3,
- DDR_PCTL2_INIT4,
- DDR_PCTL2_INIT6,
- DDR_PCTL2_INIT7,
- DDR_PCTL2_DRAMTMG0,
- DDR_PCTL2_DRAMTMG1,
- DDR_PCTL2_DRAMTMG2,
- DDR_PCTL2_DRAMTMG3,
- DDR_PCTL2_DRAMTMG4,
- DDR_PCTL2_DRAMTMG5,
- DDR_PCTL2_DRAMTMG6,
- DDR_PCTL2_DRAMTMG7,
- DDR_PCTL2_DRAMTMG8,
- DDR_PCTL2_DRAMTMG9,
- DDR_PCTL2_DRAMTMG12,
- DDR_PCTL2_DRAMTMG13,
- DDR_PCTL2_DRAMTMG14,
- DDR_PCTL2_ZQCTL0,
- DDR_PCTL2_DFITMG0,
- DDR_PCTL2_ODTCFG
+static const u16 phy_need_update_reg[] = {
- 0x14,
- 0x18,
- 0x1c
+static void pre_set_rate(struct dram_info *dram,
u32 dst_fsp, u32 dst_fsp_lp4)
- u32 i, j, find;
- u32 phy_offset;
- u32 mr_tmp;
- sw_set_req(dram);
- /* pctl timing update */
- for (i = 0, find = 0; i < ARRAY_SIZE(pctl_need_update_reg); i++) {
for (j = find; sdram_params->pctl_regs.pctl[j][0] != 0xFFFFFFFF;
j++) {
if (sdram_params->pctl_regs.pctl[j][0] ==
pctl_need_update_reg[i]) {
writel(sdram_params->pctl_regs.pctl[j][1],
pctl_need_update_reg[i]);
find = j;
break;
- u32 tmp, trefi;
- tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + DDR_PCTL2_RFSHTMG);
- sw_set_ack(dram);
- /* phy timing update */
- if (dst_fsp == 0)
phy_offset = 0;
- else
phy_offset = PHY_REG(0, 0x387 - 5 + (dst_fsp - 1) * 3);
- /* cl cwl al update */
- for (i = 0, find = 0; i < ARRAY_SIZE(phy_need_update_reg); i++) {
for (j = find; sdram_params->phy_regs.phy[j][0] != 0xFFFFFFFF;
j++) {
if (sdram_params->phy_regs.phy[j][0] ==
phy_need_update_reg[i]) {
writel(sdram_params->phy_regs.phy[j][1],
phy_base + phy_offset +
phy_need_update_reg[i]);
find = j;
break;
- set_ds_odt(dram, sdram_params, dst_fsp);
mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) +
DDR_PCTL2_INIT4);
/* MR13 */
pctl_write_mr(dram->pctl, 3, 13,
((mr_tmp >> PCTL2_LPDDR4_MR13_SHIFT &
PCTL2_MR_MASK) & (~(BIT(7) | BIT(6)))) |
((0x2 << 6) >> dst_fsp_lp4), dramtype);
writel(((mr_tmp >> PCTL2_LPDDR4_MR13_SHIFT &
PHY_REG(phy_base, 0x1b));
/* MR3 */
pctl_write_mr(dram->pctl, 3, 3,
mr_tmp >> PCTL2_LPDDR234_MR3_SHIFT &
PCTL2_MR_MASK,
dramtype);
writel(mr_tmp >> PCTL2_LPDDR234_MR3_SHIFT & PCTL2_MR_MASK,
PHY_REG(phy_base, 0x19));
DDR_PCTL2_INIT3);
/* MR1 */
pctl_write_mr(dram->pctl, 3, 1,
mr_tmp >> PCTL2_LPDDR234_MR1_SHIFT &
PCTL2_MR_MASK,
dramtype);
writel(mr_tmp >> PCTL2_LPDDR234_MR1_SHIFT & PCTL2_MR_MASK,
PHY_REG(phy_base, 0x17));
/* MR2 */
dramtype);
writel(mr_tmp & PCTL2_MR_MASK,
PHY_REG(phy_base, 0x18));
DDR_PCTL2_INIT6);
/* MR11 */
dramtype);
writel(mr_tmp >> PCTL2_LPDDR4_MR11_SHIFT & PCTL2_MR_MASK,
PHY_REG(phy_base, 0x1a));
/* MR12 */
dramtype);
DDR_PCTL2_INIT7);
/* MR22 */
dramtype);
writel(mr_tmp >> PCTL2_LPDDR4_MR22_SHIFT & PCTL2_MR_MASK,
PHY_REG(phy_base, 0x1d));
/* MR14 */
dramtype);
writel(mr_tmp >> PCTL2_LPDDR4_MR14_SHIFT & PCTL2_MR_MASK,
PHY_REG(phy_base, 0x1c));
+static void save_fsp_param(struct dram_info *dram, u32 dst_fsp,
- struct rv1126_fsp_param *p_fsp_param = &fsp_param[dst_fsp];
- u32 temp, temp1;
- ddr_info = get_ddr_drv_odt_info(sdram_params->base.dramtype);
- p_fsp_param->freq_mhz = sdram_params->base.ddr_freq;
p_fsp_param->rd_odt_up_en = 0;
p_fsp_param->rd_odt_down_en = 1;
- } else {
- if (p_fsp_param->rd_odt_up_en)
p_fsp_param->rd_odt = readl(PHY_REG(phy_base, 0x111));
- else if (p_fsp_param->rd_odt_down_en)
p_fsp_param->rd_odt = readl(PHY_REG(phy_base, 0x110));
- else
p_fsp_param->rd_odt = 0;
- p_fsp_param->wr_dq_drv = readl(PHY_REG(phy_base, 0x112));
- p_fsp_param->wr_ca_drv = readl(PHY_REG(phy_base, 0x100));
- p_fsp_param->wr_ckcs_drv = readl(PHY_REG(phy_base, 0x102));
- p_fsp_param->vref_inner = readl(PHY_REG(phy_base, 0x128));
- p_fsp_param->vref_out = readl(PHY_REG(phy_base, 0x105));
temp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) +
DDR_PCTL2_INIT3);
temp = (temp >> PCTL2_DDR34_MR1_SHIFT) & PCTL2_MR_MASK;
p_fsp_param->ds_pdds = temp & DDR3_DS_MASK;
p_fsp_param->dq_odt = temp & DDR3_RTT_NOM_MASK;
p_fsp_param->ca_odt = p_fsp_param->dq_odt;
- } else if (sdram_params->base.dramtype == DDR4) {
DDR_PCTL2_INIT3);
p_fsp_param->ds_pdds = temp & DDR4_DS_MASK;
p_fsp_param->dq_odt = temp & DDR4_RTT_NOM_MASK;
- } else if (sdram_params->base.dramtype == LPDDR3) {
DDR_PCTL2_INIT4);
temp = (temp >> PCTL2_LPDDR234_MR3_SHIFT) & PCTL2_MR_MASK;
p_fsp_param->ds_pdds = temp & 0xf;
p_fsp_param->dq_odt = lp3_odt_value;
DDR_PCTL2_INIT4);
p_fsp_param->ds_pdds = temp & LPDDR4_PDDS_MASK;
DDR_PCTL2_INIT6);
temp = (temp >> PCTL2_LPDDR4_MR11_SHIFT) & PCTL2_MR_MASK;
p_fsp_param->dq_odt = temp & LPDDR4_DQODT_MASK;
p_fsp_param->ca_odt = temp & LPDDR4_CAODT_MASK;
temp = MAX(readl(PHY_REG(phy_base, 0x3ae)),
readl(PHY_REG(phy_base, 0x3ce)));
temp1 = MIN(readl(PHY_REG(phy_base, 0x3be)),
readl(PHY_REG(phy_base, 0x3de)));
p_fsp_param->vref_ca[0] = (temp + temp1) / 2;
temp = MAX(readl(PHY_REG(phy_base, 0x3af)),
readl(PHY_REG(phy_base, 0x3cf)));
temp1 = MIN(readl(PHY_REG(phy_base, 0x3bf)),
readl(PHY_REG(phy_base, 0x3df)));
p_fsp_param->vref_ca[1] = (temp + temp1) / 2;
p_fsp_param->vref_ca[0] |=
(readl(PHY_REG(phy_base, 0x1e)) & BIT(6));
p_fsp_param->vref_ca[1] |=
p_fsp_param->lp4_drv_pd_en = (readl(PHY_REG(phy_base, 0x114)) >>
3) & 0x1;
- p_fsp_param->noc_timings.ddrtiminga0 =
sdram_params->ch.noc_timings.ddrtiminga0;
- p_fsp_param->noc_timings.ddrtimingb0 =
sdram_params->ch.noc_timings.ddrtimingb0;
- p_fsp_param->noc_timings.ddrtimingc0 =
sdram_params->ch.noc_timings.ddrtimingc0;
- p_fsp_param->noc_timings.devtodev0 =
sdram_params->ch.noc_timings.devtodev0;
- p_fsp_param->noc_timings.ddrmode =
sdram_params->ch.noc_timings.ddrmode;
- p_fsp_param->noc_timings.ddr4timing =
sdram_params->ch.noc_timings.ddr4timing;
- p_fsp_param->noc_timings.agingx0 =
sdram_params->ch.noc_timings.agingx0;
- p_fsp_param->noc_timings.aging0 =
sdram_params->ch.noc_timings.aging0;
- p_fsp_param->noc_timings.aging1 =
sdram_params->ch.noc_timings.aging1;
- p_fsp_param->noc_timings.aging2 =
sdram_params->ch.noc_timings.aging2;
- p_fsp_param->noc_timings.aging3 =
sdram_params->ch.noc_timings.aging3;
- p_fsp_param->flag = FSP_FLAG;
+static void copy_fsp_param_to_ddr(void) +{
- memcpy((void *)FSP_PARAM_STORE_ADDR, (void *)&fsp_param,
sizeof(fsp_param));
+static void pctl_modify_trfc(struct ddr_pctl_regs *pctl_regs,
struct sdram_cap_info *cap_info, u32 dram_type,
u32 freq)
- u64 cs0_cap;
- u32 die_cap;
- u32 trfc_ns, trfc4_ns;
- u32 trfc, txsnr;
- u32 txs_abort_fast = 0;
- u32 tmp;
- cs0_cap = sdram_get_cs_cap(cap_info, 0, dram_type);
- die_cap = (u32)(cs0_cap >> (20 + (cap_info->bw - cap_info->dbw)));
- switch (dram_type) {
- case DDR3:
if (die_cap <= DIE_CAP_512MBIT)
trfc_ns = 90;
else if (die_cap <= DIE_CAP_1GBIT)
trfc_ns = 110;
else if (die_cap <= DIE_CAP_2GBIT)
trfc_ns = 160;
else if (die_cap <= DIE_CAP_4GBIT)
trfc_ns = 260;
else
trfc_ns = 350;
txsnr = MAX(5, ((trfc_ns + 10) * freq + 999) / 1000);
break;
- case DDR4:
if (die_cap <= DIE_CAP_2GBIT) {
trfc_ns = 160;
trfc4_ns = 90;
} else if (die_cap <= DIE_CAP_4GBIT) {
trfc_ns = 260;
trfc4_ns = 110;
} else if (die_cap <= DIE_CAP_8GBIT) {
trfc_ns = 350;
trfc4_ns = 160;
} else {
trfc_ns = 550;
trfc4_ns = 260;
txsnr = ((trfc_ns + 10) * freq + 999) / 1000;
txs_abort_fast = ((trfc4_ns + 10) * freq + 999) / 1000;
break;
- case LPDDR3:
trfc_ns = 130;
else
trfc_ns = 210;
txsnr = MAX(2, ((trfc_ns + 10) * freq + 999) / 1000);
break;
- case LPDDR4:
trfc_ns = 130;
trfc_ns = 180;
trfc_ns = 280;
else
trfc_ns = 380;
break;
- default:
return;
- trfc = (trfc_ns * freq + 999) / 1000;
- for (int i = 0; pctl_regs->pctl[i][0] != 0xffffffff; i++) {
switch (pctl_regs->pctl[i][0]) {
case DDR_PCTL2_RFSHTMG:
tmp = pctl_regs->pctl[i][1];
/* t_rfc_min */
tmp &= ~((u32)0x3ff);
tmp |= ((trfc + 1) / 2) & 0x3ff;
pctl_regs->pctl[i][1] = tmp;
break;
case DDR_PCTL2_DRAMTMG8:
/* t_xs_x32 */
tmp &= ~((u32)0x7f);
tmp |= ((txsnr + 63) / 64) & 0x7f;
if (dram_type == DDR4) {
/* t_xs_abort_x32 */
tmp &= ~((u32)(0x7f << 16));
tmp |= (((txs_abort_fast + 63) / 64) & 0x7f) << 16;
/* t_xs_fast_x32 */
tmp &= ~((u32)(0x7f << 24));
tmp |= (((txs_abort_fast + 63) / 64) & 0x7f) << 24;
break;
case DDR_PCTL2_DRAMTMG14:
if (dram_type == LPDDR3 ||
dram_type == LPDDR4) {
/* t_xsr */
tmp &= ~((u32)0xfff);
tmp |= ((txsnr + 1) / 2) & 0xfff;
break;
default:
break;
+void ddr_set_rate(struct dram_info *dram,
u32 freq, u32 cur_freq, u32 dst_fsp,
u32 dst_fsp_lp4, u32 training_en)
- u32 dest_dll_off, cur_init3, dst_init3, cur_fsp, cur_dll_off;
- u32 mr_tmp;
- u32 lp_stat;
- struct rv1126_sdram_params *sdram_params_new;
- void __iomem *pctl_base = dram->pctl;
- sdram_params_new = get_default_sdram_config(freq);
- sdram_params_new->ch.cap_info.rank = sdram_params->ch.cap_info.rank;
- sdram_params_new->ch.cap_info.bw = sdram_params->ch.cap_info.bw;
- pctl_modify_trfc(&sdram_params_new->pctl_regs,
&sdram_params->ch.cap_info, dramtype, freq);
- pre_set_rate(dram, sdram_params_new, dst_fsp, dst_fsp_lp4);
continue;
- dest_dll_off = 0;
- dst_init3 = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) +
DDR_PCTL2_INIT3);
- if ((dramtype == DDR3 && (dst_init3 & 1)) ||
(dramtype == DDR4 && !(dst_init3 & 1)))
dest_dll_off = 1;
- cur_init3 = readl(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) +
DDR_PCTL2_INIT3);
- cur_init3 &= PCTL2_MR_MASK;
- cur_dll_off = 1;
- if ((dramtype == DDR3 && !(cur_init3 & 1)) ||
(dramtype == DDR4 && (cur_init3 & 1)))
cur_dll_off = 0;
- if (!cur_dll_off) {
cur_init3 |= 1;
else
cur_init3 &= ~1;
pctl_write_mr(dram->pctl, 2, 1, cur_init3, dramtype);
- setbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3,
PCTL2_DIS_AUTO_REFRESH);
- update_refresh_reg(dram);
- writel(PMUGRF_CON_DDRPHY_BUFFEREN_MASK |
PMUGRF_CON_DDRPHY_BUFFEREN_EN,
&dram->pmugrf->soc_con[0]);
- sw_set_req(dram);
- clrbits_le32(pctl_base + DDR_PCTL2_DFIMISC,
PCTL2_DFI_INIT_COMPLETE_EN);
- sw_set_ack(dram);
- sw_set_req(dram);
- if ((dramtype == DDR3 || dramtype == DDR4) && dest_dll_off)
setbits_le32(pctl_base + DDR_PCTL2_MSTR, PCTL2_DLL_OFF_MODE);
- else
clrbits_le32(pctl_base + DDR_PCTL2_MSTR, PCTL2_DLL_OFF_MODE);
- setbits_le32(pctl_base + UMCTL2_REGS_FREQ(cur_fsp) + DDR_PCTL2_ZQCTL0,
PCTL2_DIS_SRX_ZQCL);
- setbits_le32(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + DDR_PCTL2_ZQCTL0,
- sw_set_ack(dram);
- writel(DDR_MSCH_EN_MASK | (0x1 << DDR_MSCH_EN_SHIFT),
&dram->cru->clkgate_con[21]);
- writel(CLK_DDR_UPCTL_EN_MASK | ACLK_DDR_UPCTL_EN_MASK |
(0x1 << CLK_DDR_UPCTL_EN_SHIFT) |
(0x1 << ACLK_DDR_UPCTL_EN_SHIFT),
BUS_SGRF_BASE_ADDR + SGRF_SOC_CON12);
- clrbits_le32(PHY_REG(phy_base, 0), ANALOG_DERESET | DIGITAL_DERESET);
- rkclk_set_dpll(dram, freq * MHz / 2);
- phy_pll_set(dram, freq * MHz, 0);
- phy_pll_set(dram, freq * MHz, 1);
- setbits_le32(PHY_REG(phy_base, 0), ANALOG_DERESET | DIGITAL_DERESET);
PMUGRF_CON_DDRPHY_BUFFEREN_DIS,
- writel(DDR_MSCH_EN_MASK | (0x0 << DDR_MSCH_EN_SHIFT),
(0x0 << CLK_DDR_UPCTL_EN_SHIFT) |
(0x0 << ACLK_DDR_UPCTL_EN_SHIFT),
- while ((readl(pctl_base + DDR_PCTL2_DFISTAT) &
PCTL2_DFI_INIT_COMPLETE) != PCTL2_DFI_INIT_COMPLETE)
continue;
- sw_set_req(dram);
- clrsetbits_le32(pctl_base + DDR_PCTL2_MSTR2, 0x3, dst_fsp);
- sw_set_ack(dram);
- clrsetbits_le32(PHY_REG(phy_base, 0xc), 0x3 << 2, dst_fsp << 2);
- mr_tmp = readl(pctl_base + UMCTL2_REGS_FREQ(dst_fsp) + DDR_PCTL2_INIT4);
- if (dramtype == LPDDR3) {
(dst_init3 >> PCTL2_LPDDR234_MR1_SHIFT) &
PCTL2_MR_MASK,
dramtype);
pctl_write_mr(dram->pctl, 3, 2, dst_init3 & PCTL2_MR_MASK,
dramtype);
(mr_tmp >> PCTL2_LPDDR234_MR3_SHIFT) &
PCTL2_MR_MASK,
dramtype);
pctl_write_mr(dram->pctl, 3, 11, lp3_odt_value, dramtype);
- } else if ((dramtype == DDR3) || (dramtype == DDR4)) {
pctl_write_mr(dram->pctl, 3, 1, dst_init3 & PCTL2_MR_MASK,
dramtype);
if (!dest_dll_off) {
pctl_write_mr(dram->pctl, 3, 0,
((dst_init3 >> PCTL2_DDR34_MR0_SHIFT) &
PCTL2_MR_MASK) | DDR3_DLL_RESET,
dramtype);
udelay(2);
(dst_init3 >> PCTL2_DDR34_MR0_SHIFT &
PCTL2_MR_MASK) & (~DDR3_DLL_RESET),
dramtype);
((mr_tmp >> PCTL2_DDR34_MR2_SHIFT) &
PCTL2_MR_MASK), dramtype);
pctl_write_mr(dram->pctl, 3, 3, mr_tmp & PCTL2_MR_MASK,
dramtype);
DDR_PCTL2_INIT6);
pctl_write_mr(dram->pctl, 3, 4,
(mr_tmp >> PCTL2_DDR4_MR4_SHIFT) &
PCTL2_MR_MASK,
dramtype);
pctl_write_mr(dram->pctl, 3, 5,
mr_tmp >> PCTL2_DDR4_MR5_SHIFT &
PCTL2_MR_MASK,
dramtype);
DDR_PCTL2_INIT7);
pctl_write_mr(dram->pctl, 3, 6,
mr_tmp >> PCTL2_DDR4_MR6_SHIFT &
PCTL2_MR_MASK,
dramtype);
PCTL2_MR_MASK) & (~(BIT(7)))) |
dst_fsp_lp4 << 7, dramtype);
- clrbits_le32(pctl_base + DDR_PCTL2_RFSHCTL3,
- /* training */
- high_freq_training(dram, sdram_params_new, dst_fsp);
- save_fsp_param(dram, dst_fsp, sdram_params_new);
+static void ddr_set_rate_for_fsp(struct dram_info *dram,
- u32 f0;
- u32 f1, f2, f3;
- if (!ddr_info)
return;
- f0 = (ddr_info->ddr_freq0_1 >> DDR_FREQ_F0_SHIFT) &
DDR_FREQ_MASK;
- memset((void *)FSP_PARAM_STORE_ADDR, 0, sizeof(fsp_param));
- memset((void *)&fsp_param, 0, sizeof(fsp_param));
- f1 = (ddr_info->ddr_freq0_1 >> DDR_FREQ_F1_SHIFT) &
DDR_FREQ_MASK;
- f2 = (ddr_info->ddr_freq2_3 >> DDR_FREQ_F2_SHIFT) &
DDR_FREQ_MASK;
- f3 = (ddr_info->ddr_freq2_3 >> DDR_FREQ_F3_SHIFT) &
DDR_FREQ_MASK;
- if (get_wrlvl_val(dram, sdram_params))
printascii("get wrlvl value fail\n");
- printascii("change to: ");
- printdec(f1);
- printascii("MHz\n");
- ddr_set_rate(&dram_info, sdram_params, f1,
sdram_params->base.ddr_freq, 1, 1, 1);
- printdec(f2);
- ddr_set_rate(&dram_info, sdram_params, f2, f1, 2, 0, 1);
- printdec(f3);
- ddr_set_rate(&dram_info, sdram_params, f3, f2, 3, 1, 1);
- printdec(f0);
- printascii("MHz(final freq)\n");
- ddr_set_rate(&dram_info, sdram_params, f0, f3, 0, 0, 1);
+int get_uart_config(void) +{
- struct global_info *gbl_info;
- gbl_info = (struct global_info *)((void *)common_info +
index->global_index.offset * 4);
- return gbl_info->uart_info;
+/* return: 0 = success, other = fail */ +static int rv1126_dmc_init(struct udevice *dev) +{
- struct rv1126_sdram_params *sdram_params;
- int ret = 0;
- dram_info.phy = (void *)DDR_PHY_BASE_ADDR;
- dram_info.pctl = (void *)UPCTL2_BASE_ADDR;
- dram_info.grf = (void *)GRF_BASE_ADDR;
- dram_info.cru = (void *)CRU_BASE_ADDR;
- dram_info.msch = (void *)SERVER_MSCH_BASE_ADDR;
- dram_info.ddrgrf = (void *)DDR_GRF_BASE_ADDR;
- dram_info.pmugrf = (void *)PMU_GRF_BASE_ADDR;
- printascii("extended temp support\n");
- if (index->version_info != 2 ||
(index->global_index.size != sizeof(struct global_info) / 4) ||
(index->ddr3_index.size !=
sizeof(struct ddr2_3_4_lp2_3_info) / 4) ||
(index->ddr4_index.size !=
(index->lp3_index.size !=
(index->lp4_index.size != (sizeof(struct lp4_info) / 4)) ||
(index->lp4x_index.size != (sizeof(struct lp4_info) / 4)) ||
index->global_index.offset == 0 ||
index->ddr3_index.offset == 0 ||
index->ddr4_index.offset == 0 ||
index->lp3_index.offset == 0 ||
index->lp4_index.offset == 0 ||
index->lp4x_index.offset == 0) {
printascii("common info error\n");
goto error;
- dram_info.sr_idle = SR_INFO(gbl_info->sr_pd_info);
- dram_info.pd_idle = PD_INFO(gbl_info->sr_pd_info);
- sdram_params = &sdram_configs[0];
- if (sdram_params->base.dramtype == DDR3 ||
if (DDR_2T_INFO(gbl_info->info_2t))
sdram_params->pctl_regs.pctl[0][1] |= 0x1 << 10;
else
sdram_params->pctl_regs.pctl[0][1] &=
~(0x1 << 10);
- ret = sdram_init_detect(&dram_info, sdram_params);
- if (ret) {
sdram_print_dram_type(sdram_params->base.dramtype);
printascii(", ");
printdec(sdram_params->base.ddr_freq);
goto error;
- print_ddr_info(sdram_params);
- init_rw_trn_result_struct(&rw_trn_result, dram_info.phy,
(u8)sdram_params->ch.cap_info.rank);
- ddr_set_rate_for_fsp(&dram_info, sdram_params);
- copy_fsp_param_to_ddr();
- save_rw_trn_result_to_ddr(&rw_trn_result);
- printascii("out\n");
- return ret;
+error:
- printascii("error\n");
- return (-1);
+static int rv1126_dmc_probe(struct udevice *dev) +{ +#if defined(CONFIG_TPL_BUILD) || \
- (!defined(CONFIG_TPL) && defined(CONFIG_SPL_BUILD))
- if (rv1126_dmc_init(dev))
+#else
- struct dram_info *priv = dev_get_priv(dev);
- priv->pmugrf = syscon_get_first_range(ROCKCHIP_SYSCON_PMUGRF);
- debug("%s: grf=%p\n", __func__, priv->pmugrf);
- priv->info.base = CONFIG_SYS_SDRAM_BASE;
- priv->info.size =
rockchip_sdram_size((phys_addr_t)&priv->pmugrf->os_reg[2]);
+static int rv1126_dmc_get_info(struct udevice *dev, struct ram_info *info) +{
- *info = priv->info;
+static struct ram_ops rv1126_dmc_ops = {
- .get_info = rv1126_dmc_get_info,
+static const struct udevice_id rv1126_dmc_ids[] = {
- { .compatible = "rockchip,rv1126-dmc" },
+U_BOOT_DRIVER(dmc_rv1126) = {
- .name = "rockchip_rv1126_dmc",
- .id = UCLASS_RAM,
- .of_match = rv1126_dmc_ids,
- .ops = &rv1126_dmc_ops,
- .probe = rv1126_dmc_probe,
- .priv_auto = sizeof(struct dram_info),
Control the ddr init print messages via RAM_ROCKCHIP_DEBUG instead of printing by default.
This gives an option to configs to enable these prints or not.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - none
drivers/ram/rockchip/sdram_rv1126.c | 38 +++++++++++++++++++---------- 1 file changed, 25 insertions(+), 13 deletions(-)
diff --git a/drivers/ram/rockchip/sdram_rv1126.c b/drivers/ram/rockchip/sdram_rv1126.c index 9b1c34391e..6fe5b0305e 100644 --- a/drivers/ram/rockchip/sdram_rv1126.c +++ b/drivers/ram/rockchip/sdram_rv1126.c @@ -3358,22 +3358,33 @@ static void ddr_set_rate_for_fsp(struct dram_info *dram, if (get_wrlvl_val(dram, sdram_params)) printascii("get wrlvl value fail\n");
- printascii("change to: "); - printdec(f1); - printascii("MHz\n"); + if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) { + printascii("change to: "); + printdec(f1); + printascii("MHz\n"); + } ddr_set_rate(&dram_info, sdram_params, f1, sdram_params->base.ddr_freq, 1, 1, 1); - printascii("change to: "); - printdec(f2); - printascii("MHz\n"); + + if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) { + printascii("change to: "); + printdec(f2); + printascii("MHz\n"); + } ddr_set_rate(&dram_info, sdram_params, f2, f1, 2, 0, 1); - printascii("change to: "); - printdec(f3); - printascii("MHz\n"); + + if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) { + printascii("change to: "); + printdec(f3); + printascii("MHz\n"); + } ddr_set_rate(&dram_info, sdram_params, f3, f2, 3, 1, 1); - printascii("change to: "); - printdec(f0); - printascii("MHz(final freq)\n"); + + if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) { + printascii("change to: "); + printdec(f0); + printascii("MHz(final freq)\n"); + } ddr_set_rate(&dram_info, sdram_params, f0, f3, 0, 0, 1); }
@@ -3465,7 +3476,8 @@ static int rv1126_dmc_init(struct udevice *dev) save_rw_trn_result_to_ddr(&rw_trn_result); #endif
- printascii("out\n"); + if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) + printascii("out\n");
return ret; error:
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
- printdec(f1);
- if (IS_ENABLED(CONFIG_RAM_ROCKCHIP_DEBUG)) {
printdec(f1);
- } ddr_set_rate(&dram_info, sdram_params, f1, sdram_params->base.ddr_freq, 1, 1, 1);
- printdec(f2);
printdec(f2);
- } ddr_set_rate(&dram_info, sdram_params, f2, f1, 2, 0, 1);
- printdec(f3);
printdec(f3);
- } ddr_set_rate(&dram_info, sdram_params, f3, f2, 3, 1, 1);
- printdec(f0);
printdec(f0);
- } ddr_set_rate(&dram_info, sdram_params, f0, f3, 0, 0, 1); }
return ret; error:
Add LPDDR4 detection timings and support for RV1126.
.../sdram-rv1126-lpddr4-detect-1056.inc | 78 +++++++++++++++++++ .../sdram-rv1126-lpddr4-detect-328.inc | 78 +++++++++++++++++++ .../sdram-rv1126-lpddr4-detect-396.inc | 78 +++++++++++++++++++ .../sdram-rv1126-lpddr4-detect-528.inc | 78 +++++++++++++++++++ .../sdram-rv1126-lpddr4-detect-664.inc | 78 +++++++++++++++++++ .../sdram-rv1126-lpddr4-detect-784.inc | 78 +++++++++++++++++++ .../sdram-rv1126-lpddr4-detect-924.inc | 78 +++++++++++++++++++ drivers/ram/rockchip/sdram_rv1126.c | 10 +++ 8 files changed, 556 insertions(+) create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-924.inc
diff --git a/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-1056.inc b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-1056.inc new file mode 100644 index 0000000000..705cbfb5cb --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-1056.inc @@ -0,0 +1,78 @@ +{ + { + { + .rank = 0x1, + .col = 0xB, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x11, + .cs0_high16bit_row = 0x0, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0 + }, + { + {0x41241522}, + {0x15050b07}, + {0x00000602}, + {0x00001111}, + {0x00000054}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 1056, /* clock rate(MHz) */ + .dramtype = LPDDR4, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x81081020}, /* MSTR */ + {0x00000064, 0x00400094}, /* RFSHTMG */ + {0x000000d0, 0x00030409}, /* INIT0 */ + {0x000000d4, 0x00690000}, /* INIT1 */ + {0x000000d8, 0x00000206}, /* INIT2 */ + {0x000000dc, 0x0034001b}, /* INIT3 */ + {0x000000e0, 0x00310000}, /* INIT4 */ + {0x000000e8, 0x00110000}, /* INIT6 */ + {0x000000ec, 0x00000000}, /* INIT7 */ + {0x000000f4, 0x000f033f}, /* RANKCTL */ + {0x00000100, 0x14161217}, /* DRAMTMG0 */ + {0x00000104, 0x00040422}, /* DRAMTMG1 */ + {0x00000108, 0x050a0e0f}, /* DRAMTMG2 */ + {0x0000010c, 0x00808000}, /* DRAMTMG3 */ + {0x00000110, 0x0a04060c}, /* DRAMTMG4 */ + {0x00000114, 0x02040808}, /* DRAMTMG5 */ + {0x00000118, 0x01010005}, /* DRAMTMG6 */ + {0x0000011c, 0x00000401}, /* DRAMTMG7 */ + {0x00000120, 0x00000606}, /* DRAMTMG8 */ + {0x00000130, 0x00020000}, /* DRAMTMG12 */ + {0x00000134, 0x0a100002}, /* DRAMTMG13 */ + {0x00000138, 0x00000098}, /* DRAMTMG14 */ + {0x00000180, 0x02100010}, /* ZQCTL0 */ + {0x00000184, 0x01b00000}, /* ZQCTL1 */ + {0x00000190, 0x07070001}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0b050d3c}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008d}, /* PHYREG01 */ + {0x00000014, 0x00000014}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x0000000a}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-328.inc b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-328.inc new file mode 100644 index 0000000000..3864b0097f --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-328.inc @@ -0,0 +1,78 @@ +{ + { + { + .rank = 0x1, + .col = 0xB, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x11, + .cs0_high16bit_row = 0x0, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0 + }, + { + {0x2f0d060a}, + {0x07020804}, + {0x00000602}, + {0x00001111}, + {0x00000054}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 328, /* clock rate(MHz) */ + .dramtype = LPDDR4, + .num_channels = 1, + .stride = 0, + .odt = 0 + }, + { + { + {0x00000000, 0x81081020}, /* MSTR */ + {0x00000064, 0x0014002e}, /* RFSHTMG */ + {0x000000d0, 0x00020142}, /* INIT0 */ + {0x000000d4, 0x00220000}, /* INIT1 */ + {0x000000d8, 0x00000202}, /* INIT2 */ + {0x000000dc, 0x00240012}, /* INIT3 */ + {0x000000e0, 0x00310000}, /* INIT4 */ + {0x000000e8, 0x00100000}, /* INIT6 */ + {0x000000ec, 0x00000000}, /* INIT7 */ + {0x000000f4, 0x000f033f}, /* RANKCTL */ + {0x00000100, 0x0c070507}, /* DRAMTMG0 */ + {0x00000104, 0x0003040b}, /* DRAMTMG1 */ + {0x00000108, 0x04070c0d}, /* DRAMTMG2 */ + {0x0000010c, 0x00505000}, /* DRAMTMG3 */ + {0x00000110, 0x03040204}, /* DRAMTMG4 */ + {0x00000114, 0x02030303}, /* DRAMTMG5 */ + {0x00000118, 0x01010004}, /* DRAMTMG6 */ + {0x0000011c, 0x00000301}, /* DRAMTMG7 */ + {0x00000120, 0x00000303}, /* DRAMTMG8 */ + {0x00000130, 0x00020000}, /* DRAMTMG12 */ + {0x00000134, 0x00100002}, /* DRAMTMG13 */ + {0x00000138, 0x00000030}, /* DRAMTMG14 */ + {0x00000180, 0x00a40005}, /* ZQCTL0 */ + {0x00000184, 0x00900000}, /* ZQCTL1 */ + {0x00000190, 0x07040000}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0905092c}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008d}, /* PHYREG01 */ + {0x00000014, 0x0000000e}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000008}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-396.inc b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-396.inc new file mode 100644 index 0000000000..9018c3a763 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-396.inc @@ -0,0 +1,78 @@ +{ + { + { + .rank = 0x1, + .col = 0xB, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x11, + .cs0_high16bit_row = 0x0, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0 + }, + { + {0x3110080d}, + {0x08020804}, + {0x00000602}, + {0x00001111}, + {0x00000054}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 396, /* clock rate(MHz) */ + .dramtype = LPDDR4, + .num_channels = 1, + .stride = 0, + .odt = 0 + }, + { + { + {0x00000000, 0x81081020}, /* MSTR */ + {0x00000064, 0x00180038}, /* RFSHTMG */ + {0x000000d0, 0x00020184}, /* INIT0 */ + {0x000000d4, 0x00280000}, /* INIT1 */ + {0x000000d8, 0x00000202}, /* INIT2 */ + {0x000000dc, 0x00240012}, /* INIT3 */ + {0x000000e0, 0x00310000}, /* INIT4 */ + {0x000000e8, 0x00100000}, /* INIT6 */ + {0x000000ec, 0x00000000}, /* INIT7 */ + {0x000000f4, 0x000f033f}, /* RANKCTL */ + {0x00000100, 0x0d080609}, /* DRAMTMG0 */ + {0x00000104, 0x0003040d}, /* DRAMTMG1 */ + {0x00000108, 0x04070c0d}, /* DRAMTMG2 */ + {0x0000010c, 0x00505000}, /* DRAMTMG3 */ + {0x00000110, 0x04040205}, /* DRAMTMG4 */ + {0x00000114, 0x02030303}, /* DRAMTMG5 */ + {0x00000118, 0x01010004}, /* DRAMTMG6 */ + {0x0000011c, 0x00000301}, /* DRAMTMG7 */ + {0x00000120, 0x00000303}, /* DRAMTMG8 */ + {0x00000130, 0x00020000}, /* DRAMTMG12 */ + {0x00000134, 0x00100002}, /* DRAMTMG13 */ + {0x00000138, 0x00000039}, /* DRAMTMG14 */ + {0x00000180, 0x00c60006}, /* ZQCTL0 */ + {0x00000184, 0x00a00000}, /* ZQCTL1 */ + {0x00000190, 0x07040000}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0905092c}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008d}, /* PHYREG01 */ + {0x00000014, 0x0000000e}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000008}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-528.inc b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-528.inc new file mode 100644 index 0000000000..8c8e14c376 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-528.inc @@ -0,0 +1,78 @@ +{ + { + { + .rank = 0x1, + .col = 0xB, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x11, + .cs0_high16bit_row = 0x0, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0 + }, + { + {0x34140b11}, + {0x0b030804}, + {0x00000602}, + {0x00001111}, + {0x00000054}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 528, /* clock rate(MHz) */ + .dramtype = LPDDR4, + .num_channels = 1, + .stride = 0, + .odt = 0 + }, + { + { + {0x00000000, 0x81081020}, /* MSTR */ + {0x00000064, 0x0020004a}, /* RFSHTMG */ + {0x000000d0, 0x00020205}, /* INIT0 */ + {0x000000d4, 0x00350000}, /* INIT1 */ + {0x000000d8, 0x00000203}, /* INIT2 */ + {0x000000dc, 0x00240012}, /* INIT3 */ + {0x000000e0, 0x00310000}, /* INIT4 */ + {0x000000e8, 0x00100000}, /* INIT6 */ + {0x000000ec, 0x00000000}, /* INIT7 */ + {0x000000f4, 0x000f033f}, /* RANKCTL */ + {0x00000100, 0x0e0b090c}, /* DRAMTMG0 */ + {0x00000104, 0x00030412}, /* DRAMTMG1 */ + {0x00000108, 0x04070c0d}, /* DRAMTMG2 */ + {0x0000010c, 0x00505000}, /* DRAMTMG3 */ + {0x00000110, 0x05040306}, /* DRAMTMG4 */ + {0x00000114, 0x02030404}, /* DRAMTMG5 */ + {0x00000118, 0x01010004}, /* DRAMTMG6 */ + {0x0000011c, 0x00000301}, /* DRAMTMG7 */ + {0x00000120, 0x00000404}, /* DRAMTMG8 */ + {0x00000130, 0x00020000}, /* DRAMTMG12 */ + {0x00000134, 0x00100002}, /* DRAMTMG13 */ + {0x00000138, 0x0000004c}, /* DRAMTMG14 */ + {0x00000180, 0x01080008}, /* ZQCTL0 */ + {0x00000184, 0x00e00000}, /* ZQCTL1 */ + {0x00000190, 0x07040000}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0905092c}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008d}, /* PHYREG01 */ + {0x00000014, 0x0000000e}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000008}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-664.inc b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-664.inc new file mode 100644 index 0000000000..f601fe5cb6 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-664.inc @@ -0,0 +1,78 @@ +{ + { + { + .rank = 0x1, + .col = 0xB, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x11, + .cs0_high16bit_row = 0x0, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0 + }, + { + {0x36170d15}, + {0x0d030805}, + {0x00000602}, + {0x00001111}, + {0x00000054}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 664, /* clock rate(MHz) */ + .dramtype = LPDDR4, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x81081020}, /* MSTR */ + {0x00000064, 0x0028005d}, /* RFSHTMG */ + {0x000000d0, 0x0002028a}, /* INIT0 */ + {0x000000d4, 0x00420000}, /* INIT1 */ + {0x000000d8, 0x00000204}, /* INIT2 */ + {0x000000dc, 0x00240012}, /* INIT3 */ + {0x000000e0, 0x00310000}, /* INIT4 */ + {0x000000e8, 0x00110000}, /* INIT6 */ + {0x000000ec, 0x00000000}, /* INIT7 */ + {0x000000f4, 0x000f033f}, /* RANKCTL */ + {0x00000100, 0x0f0e0b0e}, /* DRAMTMG0 */ + {0x00000104, 0x00030415}, /* DRAMTMG1 */ + {0x00000108, 0x04070d0d}, /* DRAMTMG2 */ + {0x0000010c, 0x00505000}, /* DRAMTMG3 */ + {0x00000110, 0x06040407}, /* DRAMTMG4 */ + {0x00000114, 0x02030505}, /* DRAMTMG5 */ + {0x00000118, 0x01010004}, /* DRAMTMG6 */ + {0x0000011c, 0x00000301}, /* DRAMTMG7 */ + {0x00000120, 0x00000404}, /* DRAMTMG8 */ + {0x00000130, 0x00020000}, /* DRAMTMG12 */ + {0x00000134, 0x00100002}, /* DRAMTMG13 */ + {0x00000138, 0x00000060}, /* DRAMTMG14 */ + {0x00000180, 0x014c000a}, /* ZQCTL0 */ + {0x00000184, 0x01100000}, /* ZQCTL1 */ + {0x00000190, 0x07040000}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0a040b28}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008d}, /* PHYREG01 */ + {0x00000014, 0x0000000e}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000008}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-784.inc b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-784.inc new file mode 100644 index 0000000000..b8d9d5f1ce --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-784.inc @@ -0,0 +1,78 @@ +{ + { + { + .rank = 0x1, + .col = 0xB, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x11, + .cs0_high16bit_row = 0x0, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0 + }, + { + {0x391b1019}, + {0x10040805}, + {0x00000602}, + {0x00001111}, + {0x00000054}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 784, /* clock rate(MHz) */ + .dramtype = LPDDR4, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x81081020}, /* MSTR */ + {0x00000064, 0x002f006e}, /* RFSHTMG */ + {0x000000d0, 0x000202ff}, /* INIT0 */ + {0x000000d4, 0x004e0000}, /* INIT1 */ + {0x000000d8, 0x00000204}, /* INIT2 */ + {0x000000dc, 0x00240012}, /* INIT3 */ + {0x000000e0, 0x00310000}, /* INIT4 */ + {0x000000e8, 0x00110000}, /* INIT6 */ + {0x000000ec, 0x00000000}, /* INIT7 */ + {0x000000f4, 0x000f033f}, /* RANKCTL */ + {0x00000100, 0x10100d11}, /* DRAMTMG0 */ + {0x00000104, 0x00030419}, /* DRAMTMG1 */ + {0x00000108, 0x04070c0d}, /* DRAMTMG2 */ + {0x0000010c, 0x00606000}, /* DRAMTMG3 */ + {0x00000110, 0x08040409}, /* DRAMTMG4 */ + {0x00000114, 0x02030606}, /* DRAMTMG5 */ + {0x00000118, 0x01010004}, /* DRAMTMG6 */ + {0x0000011c, 0x00000301}, /* DRAMTMG7 */ + {0x00000120, 0x00000505}, /* DRAMTMG8 */ + {0x00000130, 0x00020000}, /* DRAMTMG12 */ + {0x00000134, 0x00100002}, /* DRAMTMG13 */ + {0x00000138, 0x00000071}, /* DRAMTMG14 */ + {0x00000180, 0x0188000c}, /* ZQCTL0 */ + {0x00000184, 0x01400000}, /* ZQCTL1 */ + {0x00000190, 0x07040000}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0a040b28}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008d}, /* PHYREG01 */ + {0x00000014, 0x0000000e}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x00000008}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-924.inc b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-924.inc new file mode 100644 index 0000000000..a2050f6153 --- /dev/null +++ b/drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-924.inc @@ -0,0 +1,78 @@ +{ + { + { + .rank = 0x1, + .col = 0xB, + .bk = 0x3, + .bw = 0x1, + .dbw = 0x1, + .row_3_4 = 0x0, + .cs0_row = 0x11, + .cs1_row = 0x11, + .cs0_high16bit_row = 0x0, + .cs1_high16bit_row = 0x0, + .ddrconfig = 0 + }, + { + {0x3e20121d}, + {0x12050a07}, + {0x00000602}, + {0x00001111}, + {0x00000054}, + {0x00000000}, + 0x000000ff + } + }, + { + .ddr_freq = 924, /* clock rate(MHz) */ + .dramtype = LPDDR4, + .num_channels = 1, + .stride = 0, + .odt = 1 + }, + { + { + {0x00000000, 0x81081020}, /* MSTR */ + {0x00000064, 0x00380082}, /* RFSHTMG */ + {0x000000d0, 0x00020388}, /* INIT0 */ + {0x000000d4, 0x005c0000}, /* INIT1 */ + {0x000000d8, 0x00000205}, /* INIT2 */ + {0x000000dc, 0x0034001b}, /* INIT3 */ + {0x000000e0, 0x00310000}, /* INIT4 */ + {0x000000e8, 0x00110000}, /* INIT6 */ + {0x000000ec, 0x00000000}, /* INIT7 */ + {0x000000f4, 0x000f033f}, /* RANKCTL */ + {0x00000100, 0x12130f14}, /* DRAMTMG0 */ + {0x00000104, 0x0004041e}, /* DRAMTMG1 */ + {0x00000108, 0x050a0e0f}, /* DRAMTMG2 */ + {0x0000010c, 0x00707000}, /* DRAMTMG3 */ + {0x00000110, 0x0904050a}, /* DRAMTMG4 */ + {0x00000114, 0x02040707}, /* DRAMTMG5 */ + {0x00000118, 0x01010005}, /* DRAMTMG6 */ + {0x0000011c, 0x00000401}, /* DRAMTMG7 */ + {0x00000120, 0x00000606}, /* DRAMTMG8 */ + {0x00000130, 0x00020000}, /* DRAMTMG12 */ + {0x00000134, 0x0a100002}, /* DRAMTMG13 */ + {0x00000138, 0x00000085}, /* DRAMTMG14 */ + {0x00000180, 0x01ce000e}, /* ZQCTL0 */ + {0x00000184, 0x01800000}, /* ZQCTL1 */ + {0x00000190, 0x07070001}, /* DFITMG0 */ + {0x00000198, 0x07000101}, /* DFILPCFG0 */ + {0x000001a0, 0xc0400003}, /* DFIUPD0 */ + {0x00000240, 0x0b050d3c}, /* ODTCFG */ + {0x00000244, 0x00000101}, /* ODTMAP */ + {0x00000250, 0x00001f00}, /* SCHED */ + {0x00000490, 0x00000001}, /* PCTRL_0 */ + {0xffffffff, 0xffffffff} + } + }, + { + { + {0x00000004, 0x0000008d}, /* PHYREG01 */ + {0x00000014, 0x00000014}, /* PHYREG05 */ + {0x00000018, 0x00000000}, /* PHYREG06 */ + {0x0000001c, 0x0000000a}, /* PHYREG07 */ + {0xffffffff, 0xffffffff} + } + } +}, diff --git a/drivers/ram/rockchip/sdram_rv1126.c b/drivers/ram/rockchip/sdram_rv1126.c index 6fe5b0305e..8cd39d9305 100644 --- a/drivers/ram/rockchip/sdram_rv1126.c +++ b/drivers/ram/rockchip/sdram_rv1126.c @@ -68,6 +68,15 @@ struct dram_info { struct dram_info dram_info;
struct rv1126_sdram_params sdram_configs[] = { +#if defined(CONFIG_RAM_ROCKCHIP_LPDDR4) +# include "sdram-rv1126-lpddr4-detect-328.inc" +# include "sdram-rv1126-lpddr4-detect-396.inc" +# include "sdram-rv1126-lpddr4-detect-528.inc" +# include "sdram-rv1126-lpddr4-detect-664.inc" +# include "sdram-rv1126-lpddr4-detect-784.inc" +# include "sdram-rv1126-lpddr4-detect-924.inc" +# include "sdram-rv1126-lpddr4-detect-1056.inc" +#else # include "sdram-rv1126-ddr3-detect-328.inc" # include "sdram-rv1126-ddr3-detect-396.inc" # include "sdram-rv1126-ddr3-detect-528.inc" @@ -75,6 +84,7 @@ struct rv1126_sdram_params sdram_configs[] = { # include "sdram-rv1126-ddr3-detect-784.inc" # include "sdram-rv1126-ddr3-detect-924.inc" # include "sdram-rv1126-ddr3-detect-1056.inc" +#endif };
u32 common_info[] = {
Thanks, - Kever
Changes for v2:
none
.rank = 0x1,
.col = 0xB,
.bk = 0x3,
.bw = 0x1,
.dbw = 0x1,
.row_3_4 = 0x0,
.cs0_row = 0x11,
.cs1_row = 0x11,
.ddrconfig = 0
{0x41241522},
{0x15050b07},
{0x00000602},
{0x00001111},
{0x00000054},
{0x00000000},
0x000000ff
.dramtype = LPDDR4,
.num_channels = 1,
.stride = 0,
.odt = 1
.rank = 0x1,
.col = 0xB,
.bk = 0x3,
.bw = 0x1,
.dbw = 0x1,
.row_3_4 = 0x0,
.cs0_row = 0x11,
.cs1_row = 0x11,
.ddrconfig = 0
{0x2f0d060a},
{0x07020804},
{0x00000602},
{0x00001111},
{0x00000054},
{0x00000000},
0x000000ff
.dramtype = LPDDR4,
.num_channels = 1,
.stride = 0,
.odt = 0
.rank = 0x1,
.col = 0xB,
.bk = 0x3,
.bw = 0x1,
.dbw = 0x1,
.row_3_4 = 0x0,
.cs0_row = 0x11,
.cs1_row = 0x11,
.ddrconfig = 0
{0x3110080d},
{0x08020804},
{0x00000602},
{0x00001111},
{0x00000054},
{0x00000000},
0x000000ff
.dramtype = LPDDR4,
.num_channels = 1,
.stride = 0,
.odt = 0
.rank = 0x1,
.col = 0xB,
.bk = 0x3,
.bw = 0x1,
.dbw = 0x1,
.row_3_4 = 0x0,
.cs0_row = 0x11,
.cs1_row = 0x11,
.ddrconfig = 0
{0x34140b11},
{0x0b030804},
{0x00000602},
{0x00001111},
{0x00000054},
{0x00000000},
0x000000ff
.dramtype = LPDDR4,
.num_channels = 1,
.stride = 0,
.odt = 0
.rank = 0x1,
.col = 0xB,
.bk = 0x3,
.bw = 0x1,
.dbw = 0x1,
.row_3_4 = 0x0,
.cs0_row = 0x11,
.cs1_row = 0x11,
.ddrconfig = 0
{0x36170d15},
{0x0d030805},
{0x00000602},
{0x00001111},
{0x00000054},
{0x00000000},
0x000000ff
.dramtype = LPDDR4,
.num_channels = 1,
.stride = 0,
.odt = 1
.rank = 0x1,
.col = 0xB,
.bk = 0x3,
.bw = 0x1,
.dbw = 0x1,
.row_3_4 = 0x0,
.cs0_row = 0x11,
.cs1_row = 0x11,
.ddrconfig = 0
{0x391b1019},
{0x10040805},
{0x00000602},
{0x00001111},
{0x00000054},
{0x00000000},
0x000000ff
.dramtype = LPDDR4,
.num_channels = 1,
.stride = 0,
.odt = 1
.rank = 0x1,
.col = 0xB,
.bk = 0x3,
.bw = 0x1,
.dbw = 0x1,
.row_3_4 = 0x0,
.cs0_row = 0x11,
.cs1_row = 0x11,
.ddrconfig = 0
{0x3e20121d},
{0x12050a07},
{0x00000602},
{0x00001111},
{0x00000054},
{0x00000000},
0x000000ff
.dramtype = LPDDR4,
.num_channels = 1,
.stride = 0,
.odt = 1
Some pins in rockchip are routed via Top GRF and PMU GRF instead of direct regmap.
Add support to handle all these routing paths so that the SoC pinctrl drivers will use them accordingly.
Signed-off-by: Jianqun Xu jay.xu@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - none
drivers/pinctrl/rockchip/pinctrl-px30.c | 11 +--- drivers/pinctrl/rockchip/pinctrl-rk3128.c | 11 +--- drivers/pinctrl/rockchip/pinctrl-rk322x.c | 11 +--- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 11 +--- drivers/pinctrl/rockchip/pinctrl-rk3308.c | 11 +--- drivers/pinctrl/rockchip/pinctrl-rk3328.c | 11 +--- drivers/pinctrl/rockchip/pinctrl-rk3399.c | 11 +--- .../pinctrl/rockchip/pinctrl-rockchip-core.c | 45 ++++++++++++-- drivers/pinctrl/rockchip/pinctrl-rockchip.h | 58 ++++++++++++++++++- 9 files changed, 102 insertions(+), 78 deletions(-)
diff --git a/drivers/pinctrl/rockchip/pinctrl-px30.c b/drivers/pinctrl/rockchip/pinctrl-px30.c index 9de29c0b8b..2c35491b24 100644 --- a/drivers/pinctrl/rockchip/pinctrl-px30.c +++ b/drivers/pinctrl/rockchip/pinctrl-px30.c @@ -80,7 +80,7 @@ static int px30_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) struct regmap *regmap; int reg, ret, mask, mux_type; u8 bit; - u32 data, route_reg, route_val; + u32 data;
regmap = (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) ? priv->regmap_pmu : priv->regmap_base; @@ -90,15 +90,6 @@ static int px30_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) reg = bank->iomux[iomux_num].offset; reg += rockchip_get_mux_data(mux_type, pin, &bit, &mask);
- if (bank->route_mask & BIT(pin)) { - if (rockchip_get_mux_route(bank, pin, mux, &route_reg, - &route_val)) { - ret = regmap_write(regmap, route_reg, route_val); - if (ret) - return ret; - } - } - data = (mask << (bit + 16)); data |= (mux & mask) << bit; ret = regmap_write(regmap, reg, data); diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3128.c b/drivers/pinctrl/rockchip/pinctrl-rk3128.c index e6dc1af86e..355c45eb7f 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3128.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3128.c @@ -106,7 +106,7 @@ static int rk3128_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) struct regmap *regmap; int reg, ret, mask, mux_type; u8 bit; - u32 data, route_reg, route_val; + u32 data;
regmap = (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) ? priv->regmap_pmu : priv->regmap_base; @@ -119,15 +119,6 @@ static int rk3128_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) if (bank->recalced_mask & BIT(pin)) rockchip_get_recalced_mux(bank, pin, ®, &bit, &mask);
- if (bank->route_mask & BIT(pin)) { - if (rockchip_get_mux_route(bank, pin, mux, &route_reg, - &route_val)) { - ret = regmap_write(regmap, route_reg, route_val); - if (ret) - return ret; - } - } - data = (mask << (bit + 16)); data |= (mux & mask) << bit; ret = regmap_write(regmap, reg, data); diff --git a/drivers/pinctrl/rockchip/pinctrl-rk322x.c b/drivers/pinctrl/rockchip/pinctrl-rk322x.c index 7c58f40d93..351406da2d 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk322x.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk322x.c @@ -150,7 +150,7 @@ static int rk3228_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) struct regmap *regmap; int reg, ret, mask, mux_type; u8 bit; - u32 data, route_reg, route_val; + u32 data;
regmap = (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) ? priv->regmap_pmu : priv->regmap_base; @@ -160,15 +160,6 @@ static int rk3228_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) reg = bank->iomux[iomux_num].offset; reg += rockchip_get_mux_data(mux_type, pin, &bit, &mask);
- if (bank->route_mask & BIT(pin)) { - if (rockchip_get_mux_route(bank, pin, mux, &route_reg, - &route_val)) { - ret = regmap_write(regmap, route_reg, route_val); - if (ret) - return ret; - } - } - data = (mask << (bit + 16)); data |= (mux & mask) << bit; ret = regmap_write(regmap, reg, data); diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3288.c b/drivers/pinctrl/rockchip/pinctrl-rk3288.c index 5894f47f53..a976b7aeeb 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3288.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3288.c @@ -37,7 +37,7 @@ static int rk3288_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) struct regmap *regmap; int reg, ret, mask, mux_type; u8 bit; - u32 data, route_reg, route_val; + u32 data;
regmap = (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) ? priv->regmap_pmu : priv->regmap_base; @@ -47,15 +47,6 @@ static int rk3288_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) reg = bank->iomux[iomux_num].offset; reg += rockchip_get_mux_data(mux_type, pin, &bit, &mask);
- if (bank->route_mask & BIT(pin)) { - if (rockchip_get_mux_route(bank, pin, mux, &route_reg, - &route_val)) { - ret = regmap_write(regmap, route_reg, route_val); - if (ret) - return ret; - } - } - /* bank0 is special, there are no higher 16 bit writing bits. */ if (bank->bank_num == 0) { regmap_read(regmap, reg, &data); diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3308.c b/drivers/pinctrl/rockchip/pinctrl-rk3308.c index 83186f40f6..f9ac6347ea 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3308.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3308.c @@ -258,7 +258,7 @@ static int rk3308_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) struct regmap *regmap; int reg, ret, mask, mux_type; u8 bit; - u32 data, route_reg, route_val; + u32 data;
regmap = (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) ? priv->regmap_pmu : priv->regmap_base; @@ -271,15 +271,6 @@ static int rk3308_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) if (bank->recalced_mask & BIT(pin)) rockchip_get_recalced_mux(bank, pin, ®, &bit, &mask);
- if (bank->route_mask & BIT(pin)) { - if (rockchip_get_mux_route(bank, pin, mux, &route_reg, - &route_val)) { - ret = regmap_write(regmap, route_reg, route_val); - if (ret) - return ret; - } - } - data = (mask << (bit + 16)); data |= (mux & mask) << bit; ret = regmap_write(regmap, reg, data); diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3328.c b/drivers/pinctrl/rockchip/pinctrl-rk3328.c index 1c3c5986a5..65a7500767 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3328.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3328.c @@ -130,7 +130,7 @@ static int rk3328_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) struct regmap *regmap; int reg, ret, mask, mux_type; u8 bit; - u32 data, route_reg, route_val; + u32 data;
regmap = (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) ? priv->regmap_pmu : priv->regmap_base; @@ -143,15 +143,6 @@ static int rk3328_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) if (bank->recalced_mask & BIT(pin)) rockchip_get_recalced_mux(bank, pin, ®, &bit, &mask);
- if (bank->route_mask & BIT(pin)) { - if (rockchip_get_mux_route(bank, pin, mux, &route_reg, - &route_val)) { - ret = regmap_write(regmap, route_reg, route_val); - if (ret) - return ret; - } - } - data = (mask << (bit + 16)); data |= (mux & mask) << bit; ret = regmap_write(regmap, reg, data); diff --git a/drivers/pinctrl/rockchip/pinctrl-rk3399.c b/drivers/pinctrl/rockchip/pinctrl-rk3399.c index caa92200c6..ae785573ba 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rk3399.c +++ b/drivers/pinctrl/rockchip/pinctrl-rk3399.c @@ -59,7 +59,7 @@ static int rk3399_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) struct regmap *regmap; int reg, ret, mask, mux_type; u8 bit; - u32 data, route_reg, route_val; + u32 data;
regmap = (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) ? priv->regmap_pmu : priv->regmap_base; @@ -69,15 +69,6 @@ static int rk3399_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) reg = bank->iomux[iomux_num].offset; reg += rockchip_get_mux_data(mux_type, pin, &bit, &mask);
- if (bank->route_mask & BIT(pin)) { - if (rockchip_get_mux_route(bank, pin, mux, &route_reg, - &route_val)) { - ret = regmap_write(regmap, route_reg, route_val); - if (ret) - return ret; - } - } - data = (mask << (bit + 16)); data |= (mux & mask) << bit; ret = regmap_write(regmap, reg, data); diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c index 630513ba3a..d9d61fdb72 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip-core.c @@ -62,8 +62,9 @@ void rockchip_get_recalced_mux(struct rockchip_pin_bank *bank, int pin, *bit = data->bit; }
-bool rockchip_get_mux_route(struct rockchip_pin_bank *bank, int pin, - int mux, u32 *reg, u32 *value) +static enum rockchip_pin_route_type +rockchip_get_mux_route(struct rockchip_pin_bank *bank, int pin, + int mux, u32 *reg, u32 *value) { struct rockchip_pinctrl_priv *priv = bank->priv; struct rockchip_pin_ctrl *ctrl = priv->ctrl; @@ -78,12 +79,12 @@ bool rockchip_get_mux_route(struct rockchip_pin_bank *bank, int pin, }
if (i >= ctrl->niomux_routes) - return false; + return ROUTE_TYPE_INVALID;
*reg = data->route_offset; *value = data->route_val;
- return true; + return data->route_type; }
int rockchip_get_mux_data(int mux_type, int pin, u8 *bit, int *mask) @@ -214,8 +215,40 @@ static int rockchip_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) return -ENOTSUPP;
ret = ctrl->set_mux(bank, pin, mux); + if (ret) + return ret;
- return ret; + if (bank->route_mask & BIT(pin)) { + struct regmap *regmap; + u32 route_reg = 0, route_val = 0; + + ret = rockchip_get_mux_route(bank, pin, mux, + &route_reg, &route_val); + switch (ret) { + case ROUTE_TYPE_DEFAULT: + if (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) + regmap = priv->regmap_pmu; + else if (bank->iomux[iomux_num].type & IOMUX_L_SOURCE_PMU) + regmap = (pin % 8 < 4) ? priv->regmap_pmu : priv->regmap_base; + else + regmap = priv->regmap_base; + + regmap_write(regmap, route_reg, route_val); + break; + case ROUTE_TYPE_TOPGRF: + regmap_write(priv->regmap_base, route_reg, route_val); + break; + case ROUTE_TYPE_PMUGRF: + regmap_write(priv->regmap_pmu, route_reg, route_val); + break; + case ROUTE_TYPE_INVALID: + fallthrough; + default: + break; + } + } + + return 0; }
static int rockchip_perpin_drv_list[DRV_TYPE_MAX][8] = { @@ -545,7 +578,7 @@ static struct rockchip_pin_ctrl *rockchip_pinctrl_get_soc_data(struct udevice *d inc = (iom->type & (IOMUX_WIDTH_4BIT | IOMUX_WIDTH_3BIT | IOMUX_8WIDTH_2BIT)) ? 8 : 4; - if (iom->type & IOMUX_SOURCE_PMU) + if ((iom->type & IOMUX_SOURCE_PMU) || (iom->type & IOMUX_L_SOURCE_PMU)) pmu_offs += inc; else grf_offs += inc; diff --git a/drivers/pinctrl/rockchip/pinctrl-rockchip.h b/drivers/pinctrl/rockchip/pinctrl-rockchip.h index d969c20082..8dfaba5c74 100644 --- a/drivers/pinctrl/rockchip/pinctrl-rockchip.h +++ b/drivers/pinctrl/rockchip/pinctrl-rockchip.h @@ -9,6 +9,9 @@ #include <linux/bitops.h> #include <linux/types.h>
+#define RK_GENMASK_VAL(h, l, v) \ + (GENMASK(((h) + 16), ((l) + 16)) | (((v) << (l)) & GENMASK((h), (l)))) + /** * Encode variants of iomux registers into a type variable */ @@ -18,6 +21,7 @@ #define IOMUX_UNROUTED BIT(3) #define IOMUX_WIDTH_3BIT BIT(4) #define IOMUX_8WIDTH_2BIT BIT(5) +#define IOMUX_L_SOURCE_PMU BIT(6)
/** * Defined some common pins constants @@ -62,6 +66,22 @@ enum rockchip_pin_pull_type { PULL_TYPE_MAX };
+/** + * Rockchip pinctrl route type + * + * DEFAULT : Same regmap as pin iomux + * TOPGRF : Mux route setting in topgrf + * PMUGRF : Mux route setting in pmugrf + * INVALID : Nnot need to set mux route + */ +enum rockchip_pin_route_type { + ROUTE_TYPE_DEFAULT = 0, + ROUTE_TYPE_TOPGRF = 1, + ROUTE_TYPE_PMUGRF = 2, + + ROUTE_TYPE_INVALID = -1, +}; + /** * @drv_type: drive strength variant using rockchip_perpin_drv_type * @offset: if initialized to -1 it will be autocalculated, by specifying @@ -126,6 +146,21 @@ struct rockchip_pin_bank { }, \ }
+#define PIN_BANK_IOMUX_FLAGS_OFFSET(id, pins, label, iom0, iom1, iom2, \ + iom3, offset0, offset1, offset2, \ + offset3) \ + { \ + .bank_num = id, \ + .nr_pins = pins, \ + .name = label, \ + .iomux = { \ + { .type = iom0, .offset = offset0 }, \ + { .type = iom1, .offset = offset1 }, \ + { .type = iom2, .offset = offset2 }, \ + { .type = iom3, .offset = offset3 }, \ + }, \ + } + #define PIN_BANK_DRV_FLAGS(id, pins, label, type0, type1, type2, type3) \ { \ .bank_num = id, \ @@ -220,6 +255,25 @@ struct rockchip_pin_bank { .pull_type[3] = pull3, \ }
+#define PIN_BANK_MUX_ROUTE_FLAGS(ID, PIN, FUNC, REG, VAL, FLAG) \ + { \ + .bank_num = ID, \ + .pin = PIN, \ + .func = FUNC, \ + .route_offset = REG, \ + .route_val = VAL, \ + .route_type = FLAG, \ + } + +#define MR_DEFAULT(ID, PIN, FUNC, REG, VAL) \ + PIN_BANK_MUX_ROUTE_FLAGS(ID, PIN, FUNC, REG, VAL, ROUTE_TYPE_DEFAULT) + +#define MR_TOPGRF(ID, PIN, FUNC, REG, VAL) \ + PIN_BANK_MUX_ROUTE_FLAGS(ID, PIN, FUNC, REG, VAL, ROUTE_TYPE_TOPGRF) + +#define MR_PMUGRF(ID, PIN, FUNC, REG, VAL) \ + PIN_BANK_MUX_ROUTE_FLAGS(ID, PIN, FUNC, REG, VAL, ROUTE_TYPE_PMUGRF) + /** * struct rockchip_mux_recalced_data: recalculate a pin iomux data. * @num: bank number. @@ -241,6 +295,7 @@ struct rockchip_mux_recalced_data { * @bank_num: bank number. * @pin: index at register or used to calc index. * @func: the min pin. + * @route_type: the register type. * @route_offset: the max pin. * @route_val: the register offset. */ @@ -248,6 +303,7 @@ struct rockchip_mux_route_data { u8 bank_num; u8 pin; u8 func; + enum rockchip_pin_route_type route_type : 8; u32 route_offset; u32 route_val; }; @@ -289,8 +345,6 @@ extern const struct pinctrl_ops rockchip_pinctrl_ops; int rockchip_pinctrl_probe(struct udevice *dev); void rockchip_get_recalced_mux(struct rockchip_pin_bank *bank, int pin, int *reg, u8 *bit, int *mask); -bool rockchip_get_mux_route(struct rockchip_pin_bank *bank, int pin, - int mux, u32 *reg, u32 *value); int rockchip_get_mux_data(int mux_type, int pin, u8 *bit, int *mask); int rockchip_translate_drive_value(int type, int strength); int rockchip_translate_pull_value(int type, int pull);
Thanks, - Kever
Changes for v2:
none
u32 data;
&route_val)) {
if (ret)
return ret;
u32 data;
&route_val)) {
if (ret)
return ret;
u32 data;
&route_val)) {
if (ret)
return ret;
u32 data;
&route_val)) {
if (ret)
return ret;
u32 data;
&route_val)) {
if (ret)
return ret;
u32 data;
&route_val)) {
if (ret)
return ret;
u32 data;
&route_val)) {
if (ret)
return ret;
{ struct rockchip_pinctrl_priv *priv = bank->priv; struct rockchip_pin_ctrl *ctrl = priv->ctrl;int mux, u32 *reg, u32 *value)
return false;
- return true;
- if (ret)
return ret;
- return ret;
switch (ret) {
else
break;
break;
break;
fallthrough;
default:
break;
return 0; }
- (GENMASK(((h) + 16), ((l) + 16)) | (((v) << (l)) & GENMASK((h), (l))))
- Encode variants of iomux registers into a type variable
- Defined some common pins constants
- Rockchip pinctrl route type
- DEFAULT : Same regmap as pin iomux
- TOPGRF : Mux route setting in topgrf
- PMUGRF : Mux route setting in pmugrf
- INVALID : Nnot need to set mux route
- ROUTE_TYPE_DEFAULT = 0,
- ROUTE_TYPE_TOPGRF = 1,
- ROUTE_TYPE_PMUGRF = 2,
- ROUTE_TYPE_INVALID = -1,
- @drv_type: drive strength variant using rockchip_perpin_drv_type
- @offset: if initialized to -1 it will be autocalculated, by specifying
offset3) \
.bank_num = id, \
.nr_pins = pins, \
.name = label, \
.iomux = { \
- #define PIN_BANK_DRV_FLAGS(id, pins, label, type0, type1, type2, type3) \ { \ .bank_num = id, \
.bank_num = ID, \
.pin = PIN, \
.func = FUNC, \
.route_val = VAL, \
- PIN_BANK_MUX_ROUTE_FLAGS(ID, PIN, FUNC, REG, VAL, ROUTE_TYPE_DEFAULT)
- PIN_BANK_MUX_ROUTE_FLAGS(ID, PIN, FUNC, REG, VAL, ROUTE_TYPE_TOPGRF)
- PIN_BANK_MUX_ROUTE_FLAGS(ID, PIN, FUNC, REG, VAL, ROUTE_TYPE_PMUGRF)
- struct rockchip_mux_recalced_data: recalculate a pin iomux data.
- @num: bank number.
- @bank_num: bank number.
- @pin: index at register or used to calc index.
- @func: the min pin.
- @route_type: the register type.
- @route_offset: the max pin.
- @route_val: the register offset.
- enum rockchip_pin_route_type route_type : 8; u32 route_offset; u32 route_val; };
int rockchip_get_mux_data(int mux_type, int pin, u8 *bit, int *mask); int rockchip_translate_drive_value(int type, int strength); int rockchip_translate_pull_value(int type, int pull);int mux, u32 *reg, u32 *value);
Add pinctrl driver for Rockchip RV1126.
drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl-rv1126.c | 416 ++++++++++++++++++++++ 2 files changed, 417 insertions(+) create mode 100644 drivers/pinctrl/rockchip/pinctrl-rv1126.c
diff --git a/drivers/pinctrl/rockchip/Makefile b/drivers/pinctrl/rockchip/Makefile index 7d03f8101d..9884355473 100644 --- a/drivers/pinctrl/rockchip/Makefile +++ b/drivers/pinctrl/rockchip/Makefile @@ -15,3 +15,4 @@ obj-$(CONFIG_ROCKCHIP_RK3328) += pinctrl-rk3328.o obj-$(CONFIG_ROCKCHIP_RK3368) += pinctrl-rk3368.o obj-$(CONFIG_ROCKCHIP_RK3399) += pinctrl-rk3399.o obj-$(CONFIG_ROCKCHIP_RV1108) += pinctrl-rv1108.o +obj-$(CONFIG_ROCKCHIP_RV1126) += pinctrl-rv1126.o diff --git a/drivers/pinctrl/rockchip/pinctrl-rv1126.c b/drivers/pinctrl/rockchip/pinctrl-rv1126.c new file mode 100644 index 0000000000..eefb8b1776 --- /dev/null +++ b/drivers/pinctrl/rockchip/pinctrl-rv1126.c @@ -0,0 +1,416 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2020 Rockchip Electronics Co., Ltd + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <dm/pinctrl.h> +#include <regmap.h> +#include <syscon.h> +#include <linux/bitops.h> +#include <dt-bindings/pinctrl/rockchip.h> + +#include "pinctrl-rockchip.h" + +static struct rockchip_mux_recalced_data rv1126_mux_recalced_data[] = { + { + .num = 0, + .pin = 20, + .reg = 0x10000, + .bit = 0, + .mask = 0xf + }, + { + .num = 0, + .pin = 21, + .reg = 0x10000, + .bit = 4, + .mask = 0xf + }, + { + .num = 0, + .pin = 22, + .reg = 0x10000, + .bit = 8, + .mask = 0xf + }, + { + .num = 0, + .pin = 23, + .reg = 0x10000, + .bit = 12, + .mask = 0xf + }, +}; + +static struct rockchip_mux_route_data rv1126_mux_route_data[] = { + MR_TOPGRF(RK_GPIO3, RK_PD2, 1, 0x10260, RK_GENMASK_VAL(0, 0, 0)), /* I2S0_MCLK_M0 */ + MR_TOPGRF(RK_GPIO3, RK_PB0, 3, 0x10260, RK_GENMASK_VAL(0, 0, 1)), /* I2S0_MCLK_M1 */ + + MR_TOPGRF(RK_GPIO0, RK_PD4, 4, 0x10260, RK_GENMASK_VAL(3, 2, 0)), /* I2S1_MCLK_M0 */ + MR_TOPGRF(RK_GPIO1, RK_PD5, 2, 0x10260, RK_GENMASK_VAL(3, 2, 1)), /* I2S1_MCLK_M1 */ + MR_TOPGRF(RK_GPIO2, RK_PC7, 6, 0x10260, RK_GENMASK_VAL(3, 2, 2)), /* I2S1_MCLK_M2 */ + + MR_TOPGRF(RK_GPIO1, RK_PD0, 1, 0x10260, RK_GENMASK_VAL(4, 4, 0)), /* I2S2_MCLK_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PB3, 2, 0x10260, RK_GENMASK_VAL(4, 4, 1)), /* I2S2_MCLK_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PD4, 2, 0x10260, RK_GENMASK_VAL(12, 12, 0)), /* PDM_CLK0_M0 */ + MR_TOPGRF(RK_GPIO3, RK_PC0, 3, 0x10260, RK_GENMASK_VAL(12, 12, 1)), /* PDM_CLK0_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PC6, 1, 0x10264, RK_GENMASK_VAL(0, 0, 0)), /* CIF_CLKOUT_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PD1, 3, 0x10264, RK_GENMASK_VAL(0, 0, 1)), /* CIF_CLKOUT_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PA4, 5, 0x10264, RK_GENMASK_VAL(5, 4, 0)), /* I2C3_SCL_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PD4, 7, 0x10264, RK_GENMASK_VAL(5, 4, 1)), /* I2C3_SCL_M1 */ + MR_TOPGRF(RK_GPIO1, RK_PD6, 3, 0x10264, RK_GENMASK_VAL(5, 4, 2)), /* I2C3_SCL_M2 */ + + MR_TOPGRF(RK_GPIO3, RK_PA0, 7, 0x10264, RK_GENMASK_VAL(6, 6, 0)), /* I2C4_SCL_M0 */ + MR_TOPGRF(RK_GPIO4, RK_PA0, 4, 0x10264, RK_GENMASK_VAL(6, 6, 1)), /* I2C4_SCL_M1 */ + + MR_TOPGRF(RK_GPIO2, RK_PA5, 7, 0x10264, RK_GENMASK_VAL(9, 8, 0)), /* I2C5_SCL_M0 */ + MR_TOPGRF(RK_GPIO3, RK_PB0, 5, 0x10264, RK_GENMASK_VAL(9, 8, 1)), /* I2C5_SCL_M1 */ + MR_TOPGRF(RK_GPIO1, RK_PD0, 4, 0x10264, RK_GENMASK_VAL(9, 8, 2)), /* I2C5_SCL_M2 */ + + MR_TOPGRF(RK_GPIO3, RK_PC0, 5, 0x10264, RK_GENMASK_VAL(11, 10, 0)), /* SPI1_CLK_M0 */ + MR_TOPGRF(RK_GPIO1, RK_PC6, 3, 0x10264, RK_GENMASK_VAL(11, 10, 1)), /* SPI1_CLK_M1 */ + MR_TOPGRF(RK_GPIO2, RK_PD5, 6, 0x10264, RK_GENMASK_VAL(11, 10, 2)), /* SPI1_CLK_M2 */ + + MR_TOPGRF(RK_GPIO3, RK_PC0, 2, 0x10264, RK_GENMASK_VAL(12, 12, 0)), /* RGMII_CLK_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PB7, 2, 0x10264, RK_GENMASK_VAL(12, 12, 1)), /* RGMII_CLK_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PA1, 3, 0x10264, RK_GENMASK_VAL(13, 13, 0)), /* CAN_TXD_M0 */ + MR_TOPGRF(RK_GPIO3, RK_PA7, 5, 0x10264, RK_GENMASK_VAL(13, 13, 1)), /* CAN_TXD_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PA4, 6, 0x10268, RK_GENMASK_VAL(0, 0, 0)), /* PWM8_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PD7, 5, 0x10268, RK_GENMASK_VAL(0, 0, 1)), /* PWM8_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PA5, 6, 0x10268, RK_GENMASK_VAL(2, 2, 0)), /* PWM9_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PD6, 5, 0x10268, RK_GENMASK_VAL(2, 2, 1)), /* PWM9_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PA6, 6, 0x10268, RK_GENMASK_VAL(4, 4, 0)), /* PWM10_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PD5, 5, 0x10268, RK_GENMASK_VAL(4, 4, 1)), /* PWM10_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PA7, 6, 0x10268, RK_GENMASK_VAL(6, 6, 0)), /* PWM11_IR_M0 */ + MR_TOPGRF(RK_GPIO3, RK_PA1, 5, 0x10268, RK_GENMASK_VAL(6, 6, 1)), /* PWM11_IR_M1 */ + + MR_TOPGRF(RK_GPIO1, RK_PA5, 3, 0x10268, RK_GENMASK_VAL(8, 8, 0)), /* UART2_TX_M0 */ + MR_TOPGRF(RK_GPIO3, RK_PA2, 1, 0x10268, RK_GENMASK_VAL(8, 8, 1)), /* UART2_TX_M1 */ + + MR_TOPGRF(RK_GPIO3, RK_PC6, 3, 0x10268, RK_GENMASK_VAL(11, 10, 0)), /* UART3_TX_M0 */ + MR_TOPGRF(RK_GPIO1, RK_PA7, 2, 0x10268, RK_GENMASK_VAL(11, 10, 1)), /* UART3_TX_M1 */ + MR_TOPGRF(RK_GPIO3, RK_PA0, 4, 0x10268, RK_GENMASK_VAL(11, 10, 2)), /* UART3_TX_M2 */ + + MR_TOPGRF(RK_GPIO3, RK_PA4, 4, 0x10268, RK_GENMASK_VAL(13, 12, 0)), /* UART4_TX_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PA6, 4, 0x10268, RK_GENMASK_VAL(13, 12, 1)), /* UART4_TX_M1 */ + MR_TOPGRF(RK_GPIO1, RK_PD5, 3, 0x10268, RK_GENMASK_VAL(13, 12, 2)), /* UART4_TX_M2 */ + + MR_TOPGRF(RK_GPIO3, RK_PA6, 4, 0x10268, RK_GENMASK_VAL(15, 14, 0)), /* UART5_TX_M0 */ + MR_TOPGRF(RK_GPIO2, RK_PB0, 4, 0x10268, RK_GENMASK_VAL(15, 14, 1)), /* UART5_TX_M1 */ + MR_TOPGRF(RK_GPIO2, RK_PA0, 3, 0x10268, RK_GENMASK_VAL(15, 14, 2)), /* UART5_TX_M2 */ + + MR_PMUGRF(RK_GPIO0, RK_PB6, 3, 0x0114, RK_GENMASK_VAL(0, 0, 0)), /* PWM0_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PB3, 5, 0x0114, RK_GENMASK_VAL(0, 0, 1)), /* PWM0_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PB7, 3, 0x0114, RK_GENMASK_VAL(2, 2, 0)), /* PWM1_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PB2, 5, 0x0114, RK_GENMASK_VAL(2, 2, 1)), /* PWM1_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PC0, 3, 0x0114, RK_GENMASK_VAL(4, 4, 0)), /* PWM2_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PB1, 5, 0x0114, RK_GENMASK_VAL(4, 4, 1)), /* PWM2_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PC1, 3, 0x0114, RK_GENMASK_VAL(6, 6, 0)), /* PWM3_IR_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PB0, 5, 0x0114, RK_GENMASK_VAL(6, 6, 1)), /* PWM3_IR_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PC2, 3, 0x0114, RK_GENMASK_VAL(8, 8, 0)), /* PWM4_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PA7, 5, 0x0114, RK_GENMASK_VAL(8, 8, 1)), /* PWM4_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PC3, 3, 0x0114, RK_GENMASK_VAL(10, 10, 0)), /* PWM5_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PA6, 5, 0x0114, RK_GENMASK_VAL(10, 10, 1)), /* PWM5_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PB2, 3, 0x0114, RK_GENMASK_VAL(12, 12, 0)), /* PWM6_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PD4, 5, 0x0114, RK_GENMASK_VAL(12, 12, 1)), /* PWM6_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PB1, 3, 0x0114, RK_GENMASK_VAL(14, 14, 0)), /* PWM7_IR_M0 */ + MR_PMUGRF(RK_GPIO3, RK_PA0, 5, 0x0114, RK_GENMASK_VAL(14, 14, 1)), /* PWM7_IR_M1 */ + + MR_PMUGRF(RK_GPIO0, RK_PB0, 1, 0x0118, RK_GENMASK_VAL(1, 0, 0)), /* SPI0_CLK_M0 */ + MR_PMUGRF(RK_GPIO2, RK_PA1, 1, 0x0118, RK_GENMASK_VAL(1, 0, 1)), /* SPI0_CLK_M1 */ + MR_PMUGRF(RK_GPIO2, RK_PB2, 6, 0x0118, RK_GENMASK_VAL(1, 0, 2)), /* SPI0_CLK_M2 */ + + MR_PMUGRF(RK_GPIO0, RK_PB6, 2, 0x0118, RK_GENMASK_VAL(2, 2, 0)), /* UART1_TX_M0 */ + MR_PMUGRF(RK_GPIO1, RK_PD0, 5, 0x0118, RK_GENMASK_VAL(2, 2, 1)), /* UART1_TX_M1 */ + MR_PMUGRF(RK_GPIO0, RK_PC3, 1, 0x0118, RK_GENMASK_VAL(4, 4, 1)), /* I2C2 */ +}; + +static int rv1126_set_mux(struct rockchip_pin_bank *bank, int pin, int mux) +{ + struct rockchip_pinctrl_priv *priv = bank->priv; + int iomux_num = (pin / 8); + struct regmap *regmap; + int reg, ret, mask, mux_type; + u8 bit; + u32 data; + + debug("setting mux of GPIO%d-%d to %d\n", bank->bank_num, pin, mux); + + if (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU) + regmap = priv->regmap_pmu; + else if (bank->iomux[iomux_num].type & IOMUX_L_SOURCE_PMU) + regmap = (pin % 8 < 4) ? priv->regmap_pmu : priv->regmap_base; + else + regmap = priv->regmap_base; + + /* get basic quadrupel of mux registers and the correct reg inside */ + mux_type = bank->iomux[iomux_num].type; + reg = bank->iomux[iomux_num].offset; + if (mux_type & IOMUX_WIDTH_4BIT) { + if ((pin % 8) >= 4) + reg += 0x4; + bit = (pin % 4) * 4; + mask = 0xf; + } else { + bit = (pin % 8) * 2; + mask = 0x3; + } + + if (bank->recalced_mask & BIT(pin)) + rockchip_get_recalced_mux(bank, pin, ®, &bit, &mask); + + data = (mask << (bit + 16)); + data |= (mux & mask) << bit; + ret = regmap_write(regmap, reg, data); + + return ret; +} + +#define RV1126_PULL_PMU_OFFSET 0x40 +#define RV1126_PULL_GRF_GPIO1A0_OFFSET 0x10108 +#define RV1126_PULL_PINS_PER_REG 8 +#define RV1126_PULL_BITS_PER_PIN 2 +#define RV1126_PULL_BANK_STRIDE 16 +#define RV1126_GPIO_C4_D7(p) (p >= 20 && p <= 31) /* GPIO0_C4 ~ GPIO0_D7 */ + +static void rv1126_calc_pull_reg_and_bit(struct rockchip_pin_bank *bank, + int pin_num, struct regmap **regmap, + int *reg, u8 *bit) +{ + struct rockchip_pinctrl_priv *priv = bank->priv; + + /* The first 24 pins of the first bank are located in PMU */ + if (bank->bank_num == 0) { + if (RV1126_GPIO_C4_D7(pin_num)) { + *regmap = priv->regmap_base; + *reg = RV1126_PULL_GRF_GPIO1A0_OFFSET; + *reg -= (((31 - pin_num) / RV1126_PULL_PINS_PER_REG + 1) * 4); + *bit = pin_num % RV1126_PULL_PINS_PER_REG; + *bit *= RV1126_PULL_BITS_PER_PIN; + return; + } + *regmap = priv->regmap_pmu; + *reg = RV1126_PULL_PMU_OFFSET; + } else { + *reg = RV1126_PULL_GRF_GPIO1A0_OFFSET; + *regmap = priv->regmap_base; + *reg += (bank->bank_num - 1) * RV1126_PULL_BANK_STRIDE; + } + + *reg += ((pin_num / RV1126_PULL_PINS_PER_REG) * 4); + *bit = (pin_num % RV1126_PULL_PINS_PER_REG); + *bit *= RV1126_PULL_BITS_PER_PIN; +} + +static int rv1126_set_pull(struct rockchip_pin_bank *bank, + int pin_num, int pull) +{ + struct regmap *regmap; + int reg, ret; + u8 bit, type; + u32 data; + + if (pull == PIN_CONFIG_BIAS_PULL_PIN_DEFAULT) + return -EOPNOTSUPP; + + rv1126_calc_pull_reg_and_bit(bank, pin_num, ®map, ®, &bit); + type = bank->pull_type[pin_num / 8]; + ret = rockchip_translate_pull_value(type, pull); + if (ret < 0) { + debug("unsupported pull setting %d\n", pull); + return ret; + } + + /* enable the write to the equivalent lower bits */ + data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16); + + data |= (ret << bit); + ret = regmap_write(regmap, reg, data); + + return ret; +} + +#define RV1126_DRV_PMU_OFFSET 0x20 +#define RV1126_DRV_GRF_GPIO1A0_OFFSET 0x10090 +#define RV1126_DRV_BITS_PER_PIN 4 +#define RV1126_DRV_PINS_PER_REG 4 +#define RV1126_DRV_BANK_STRIDE 32 + +static void rv1126_calc_drv_reg_and_bit(struct rockchip_pin_bank *bank, + int pin_num, struct regmap **regmap, + int *reg, u8 *bit) +{ + struct rockchip_pinctrl_priv *priv = bank->priv; + + /* The first 24 pins of the first bank are located in PMU */ + if (bank->bank_num == 0) { + if (RV1126_GPIO_C4_D7(pin_num)) { + *regmap = priv->regmap_base; + *reg = RV1126_DRV_GRF_GPIO1A0_OFFSET; + *reg -= (((31 - pin_num) / RV1126_DRV_PINS_PER_REG + 1) * 4); + *reg -= 0x4; + *bit = pin_num % RV1126_DRV_PINS_PER_REG; + *bit *= RV1126_DRV_BITS_PER_PIN; + return; + } + *regmap = priv->regmap_pmu; + *reg = RV1126_DRV_PMU_OFFSET; + } else { + *regmap = priv->regmap_base; + *reg = RV1126_DRV_GRF_GPIO1A0_OFFSET; + *reg += (bank->bank_num - 1) * RV1126_DRV_BANK_STRIDE; + } + + *reg += ((pin_num / RV1126_DRV_PINS_PER_REG) * 4); + *bit = pin_num % RV1126_DRV_PINS_PER_REG; + *bit *= RV1126_DRV_BITS_PER_PIN; +} + +static int rv1126_set_drive(struct rockchip_pin_bank *bank, + int pin_num, int strength) +{ + struct regmap *regmap; + int reg; + u32 data; + u8 bit; + + rv1126_calc_drv_reg_and_bit(bank, pin_num, ®map, ®, &bit); + + /* enable the write to the equivalent lower bits */ + data = ((1 << ROCKCHIP_DRV_BITS_PER_PIN) - 1) << (bit + 16); + data |= (strength << bit); + + return regmap_write(regmap, reg, data); +} + +#define RV1126_SCHMITT_PMU_OFFSET 0x60 +#define RV1126_SCHMITT_GRF_GPIO1A0_OFFSET 0x10188 +#define RV1126_SCHMITT_BANK_STRIDE 16 +#define RV1126_SCHMITT_PINS_PER_GRF_REG 8 +#define RV1126_SCHMITT_PINS_PER_PMU_REG 8 + +static int rv1126_calc_schmitt_reg_and_bit(struct rockchip_pin_bank *bank, + int pin_num, + struct regmap **regmap, + int *reg, u8 *bit) +{ + struct rockchip_pinctrl_priv *priv = bank->priv; + int pins_per_reg; + + if (bank->bank_num == 0) { + if (RV1126_GPIO_C4_D7(pin_num)) { + *regmap = priv->regmap_base; + *reg = RV1126_SCHMITT_GRF_GPIO1A0_OFFSET; + *reg -= (((31 - pin_num) / RV1126_SCHMITT_PINS_PER_GRF_REG + 1) * 4); + *bit = pin_num % RV1126_SCHMITT_PINS_PER_GRF_REG; + return 0; + } + *regmap = priv->regmap_pmu; + *reg = RV1126_SCHMITT_PMU_OFFSET; + pins_per_reg = RV1126_SCHMITT_PINS_PER_PMU_REG; + } else { + *regmap = priv->regmap_base; + *reg = RV1126_SCHMITT_GRF_GPIO1A0_OFFSET; + pins_per_reg = RV1126_SCHMITT_PINS_PER_GRF_REG; + *reg += (bank->bank_num - 1) * RV1126_SCHMITT_BANK_STRIDE; + } + *reg += ((pin_num / pins_per_reg) * 4); + *bit = pin_num % pins_per_reg; + + return 0; +} + +static int rv1126_set_schmitt(struct rockchip_pin_bank *bank, + int pin_num, int enable) +{ + struct regmap *regmap; + int reg; + u8 bit; + u32 data; + + rv1126_calc_schmitt_reg_and_bit(bank, pin_num, ®map, ®, &bit); + /* enable the write to the equivalent lower bits */ + data = BIT(bit + 16) | (enable << bit); + + return regmap_write(regmap, reg, data); +} + +static struct rockchip_pin_bank rv1126_pin_banks[] = { + PIN_BANK_IOMUX_FLAGS(0, 32, "gpio0", + IOMUX_WIDTH_4BIT | IOMUX_SOURCE_PMU, + IOMUX_WIDTH_4BIT | IOMUX_SOURCE_PMU, + IOMUX_WIDTH_4BIT | IOMUX_L_SOURCE_PMU, + IOMUX_WIDTH_4BIT), + PIN_BANK_IOMUX_FLAGS_OFFSET(1, 32, "gpio1", + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT, + 0x10010, 0x10018, 0x10020, 0x10028), + PIN_BANK_IOMUX_FLAGS(2, 32, "gpio2", + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT), + PIN_BANK_IOMUX_FLAGS(3, 32, "gpio3", + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT, + IOMUX_WIDTH_4BIT), + PIN_BANK_IOMUX_FLAGS(4, 2, "gpio4", + IOMUX_WIDTH_4BIT, 0, 0, 0), +}; + +static const struct rockchip_pin_ctrl rv1126_pin_ctrl = { + .pin_banks = rv1126_pin_banks, + .nr_banks = ARRAY_SIZE(rv1126_pin_banks), + .nr_pins = 130, + .grf_mux_offset = 0x10004, /* mux offset from GPIO0_D0 */ + .pmu_mux_offset = 0x0, + .iomux_routes = rv1126_mux_route_data, + .niomux_routes = ARRAY_SIZE(rv1126_mux_route_data), + .iomux_recalced = rv1126_mux_recalced_data, + .niomux_recalced = ARRAY_SIZE(rv1126_mux_recalced_data), + .set_mux = rv1126_set_mux, + .set_pull = rv1126_set_pull, + .set_drive = rv1126_set_drive, + .set_schmitt = rv1126_set_schmitt, +}; + +static const struct udevice_id rv1126_pinctrl_ids[] = { + { + .compatible = "rockchip,rv1126-pinctrl", + .data = (ulong)&rv1126_pin_ctrl + }, + { } +}; + +U_BOOT_DRIVER(pinctrl_rv1126) = { + .name = "rockchip_rv1126_pinctrl", + .id = UCLASS_PINCTRL, + .of_match = rv1126_pinctrl_ids, + .priv_auto = sizeof(struct rockchip_pinctrl_priv), + .ops = &rockchip_pinctrl_ops, +#if !CONFIG_IS_ENABLED(OF_PLATDATA) + .bind = dm_scan_fdt_dev, +#endif + .probe = rockchip_pinctrl_probe, +};
Thanks, - Kever
Changes for v2:
none
- (C) Copyright 2020 Rockchip Electronics Co., Ltd
.num = 0,
.pin = 20,
.reg = 0x10000,
.bit = 0,
.mask = 0xf
.num = 0,
.pin = 21,
.reg = 0x10000,
.bit = 4,
.mask = 0xf
.num = 0,
.pin = 22,
.reg = 0x10000,
.bit = 8,
.mask = 0xf
.num = 0,
.pin = 23,
.reg = 0x10000,
.bit = 12,
.mask = 0xf
- MR_TOPGRF(RK_GPIO3, RK_PD2, 1, 0x10260, RK_GENMASK_VAL(0, 0, 0)), /* I2S0_MCLK_M0 */
- MR_TOPGRF(RK_GPIO3, RK_PB0, 3, 0x10260, RK_GENMASK_VAL(0, 0, 1)), /* I2S0_MCLK_M1 */
- MR_TOPGRF(RK_GPIO0, RK_PD4, 4, 0x10260, RK_GENMASK_VAL(3, 2, 0)), /* I2S1_MCLK_M0 */
- MR_TOPGRF(RK_GPIO1, RK_PD5, 2, 0x10260, RK_GENMASK_VAL(3, 2, 1)), /* I2S1_MCLK_M1 */
- MR_TOPGRF(RK_GPIO2, RK_PC7, 6, 0x10260, RK_GENMASK_VAL(3, 2, 2)), /* I2S1_MCLK_M2 */
- MR_TOPGRF(RK_GPIO1, RK_PD0, 1, 0x10260, RK_GENMASK_VAL(4, 4, 0)), /* I2S2_MCLK_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PB3, 2, 0x10260, RK_GENMASK_VAL(4, 4, 1)), /* I2S2_MCLK_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PD4, 2, 0x10260, RK_GENMASK_VAL(12, 12, 0)), /* PDM_CLK0_M0 */
- MR_TOPGRF(RK_GPIO3, RK_PC0, 3, 0x10260, RK_GENMASK_VAL(12, 12, 1)), /* PDM_CLK0_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PC6, 1, 0x10264, RK_GENMASK_VAL(0, 0, 0)), /* CIF_CLKOUT_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PD1, 3, 0x10264, RK_GENMASK_VAL(0, 0, 1)), /* CIF_CLKOUT_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PA4, 5, 0x10264, RK_GENMASK_VAL(5, 4, 0)), /* I2C3_SCL_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PD4, 7, 0x10264, RK_GENMASK_VAL(5, 4, 1)), /* I2C3_SCL_M1 */
- MR_TOPGRF(RK_GPIO1, RK_PD6, 3, 0x10264, RK_GENMASK_VAL(5, 4, 2)), /* I2C3_SCL_M2 */
- MR_TOPGRF(RK_GPIO3, RK_PA0, 7, 0x10264, RK_GENMASK_VAL(6, 6, 0)), /* I2C4_SCL_M0 */
- MR_TOPGRF(RK_GPIO4, RK_PA0, 4, 0x10264, RK_GENMASK_VAL(6, 6, 1)), /* I2C4_SCL_M1 */
- MR_TOPGRF(RK_GPIO2, RK_PA5, 7, 0x10264, RK_GENMASK_VAL(9, 8, 0)), /* I2C5_SCL_M0 */
- MR_TOPGRF(RK_GPIO3, RK_PB0, 5, 0x10264, RK_GENMASK_VAL(9, 8, 1)), /* I2C5_SCL_M1 */
- MR_TOPGRF(RK_GPIO1, RK_PD0, 4, 0x10264, RK_GENMASK_VAL(9, 8, 2)), /* I2C5_SCL_M2 */
- MR_TOPGRF(RK_GPIO3, RK_PC0, 5, 0x10264, RK_GENMASK_VAL(11, 10, 0)), /* SPI1_CLK_M0 */
- MR_TOPGRF(RK_GPIO1, RK_PC6, 3, 0x10264, RK_GENMASK_VAL(11, 10, 1)), /* SPI1_CLK_M1 */
- MR_TOPGRF(RK_GPIO2, RK_PD5, 6, 0x10264, RK_GENMASK_VAL(11, 10, 2)), /* SPI1_CLK_M2 */
- MR_TOPGRF(RK_GPIO3, RK_PC0, 2, 0x10264, RK_GENMASK_VAL(12, 12, 0)), /* RGMII_CLK_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PB7, 2, 0x10264, RK_GENMASK_VAL(12, 12, 1)), /* RGMII_CLK_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PA1, 3, 0x10264, RK_GENMASK_VAL(13, 13, 0)), /* CAN_TXD_M0 */
- MR_TOPGRF(RK_GPIO3, RK_PA7, 5, 0x10264, RK_GENMASK_VAL(13, 13, 1)), /* CAN_TXD_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PA4, 6, 0x10268, RK_GENMASK_VAL(0, 0, 0)), /* PWM8_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PD7, 5, 0x10268, RK_GENMASK_VAL(0, 0, 1)), /* PWM8_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PA5, 6, 0x10268, RK_GENMASK_VAL(2, 2, 0)), /* PWM9_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PD6, 5, 0x10268, RK_GENMASK_VAL(2, 2, 1)), /* PWM9_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PA6, 6, 0x10268, RK_GENMASK_VAL(4, 4, 0)), /* PWM10_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PD5, 5, 0x10268, RK_GENMASK_VAL(4, 4, 1)), /* PWM10_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PA7, 6, 0x10268, RK_GENMASK_VAL(6, 6, 0)), /* PWM11_IR_M0 */
- MR_TOPGRF(RK_GPIO3, RK_PA1, 5, 0x10268, RK_GENMASK_VAL(6, 6, 1)), /* PWM11_IR_M1 */
- MR_TOPGRF(RK_GPIO1, RK_PA5, 3, 0x10268, RK_GENMASK_VAL(8, 8, 0)), /* UART2_TX_M0 */
- MR_TOPGRF(RK_GPIO3, RK_PA2, 1, 0x10268, RK_GENMASK_VAL(8, 8, 1)), /* UART2_TX_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PC6, 3, 0x10268, RK_GENMASK_VAL(11, 10, 0)), /* UART3_TX_M0 */
- MR_TOPGRF(RK_GPIO1, RK_PA7, 2, 0x10268, RK_GENMASK_VAL(11, 10, 1)), /* UART3_TX_M1 */
- MR_TOPGRF(RK_GPIO3, RK_PA0, 4, 0x10268, RK_GENMASK_VAL(11, 10, 2)), /* UART3_TX_M2 */
- MR_TOPGRF(RK_GPIO3, RK_PA4, 4, 0x10268, RK_GENMASK_VAL(13, 12, 0)), /* UART4_TX_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PA6, 4, 0x10268, RK_GENMASK_VAL(13, 12, 1)), /* UART4_TX_M1 */
- MR_TOPGRF(RK_GPIO1, RK_PD5, 3, 0x10268, RK_GENMASK_VAL(13, 12, 2)), /* UART4_TX_M2 */
- MR_TOPGRF(RK_GPIO3, RK_PA6, 4, 0x10268, RK_GENMASK_VAL(15, 14, 0)), /* UART5_TX_M0 */
- MR_TOPGRF(RK_GPIO2, RK_PB0, 4, 0x10268, RK_GENMASK_VAL(15, 14, 1)), /* UART5_TX_M1 */
- MR_TOPGRF(RK_GPIO2, RK_PA0, 3, 0x10268, RK_GENMASK_VAL(15, 14, 2)), /* UART5_TX_M2 */
- MR_PMUGRF(RK_GPIO0, RK_PB6, 3, 0x0114, RK_GENMASK_VAL(0, 0, 0)), /* PWM0_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PB3, 5, 0x0114, RK_GENMASK_VAL(0, 0, 1)), /* PWM0_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PB7, 3, 0x0114, RK_GENMASK_VAL(2, 2, 0)), /* PWM1_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PB2, 5, 0x0114, RK_GENMASK_VAL(2, 2, 1)), /* PWM1_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PC0, 3, 0x0114, RK_GENMASK_VAL(4, 4, 0)), /* PWM2_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PB1, 5, 0x0114, RK_GENMASK_VAL(4, 4, 1)), /* PWM2_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PC1, 3, 0x0114, RK_GENMASK_VAL(6, 6, 0)), /* PWM3_IR_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PB0, 5, 0x0114, RK_GENMASK_VAL(6, 6, 1)), /* PWM3_IR_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PC2, 3, 0x0114, RK_GENMASK_VAL(8, 8, 0)), /* PWM4_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PA7, 5, 0x0114, RK_GENMASK_VAL(8, 8, 1)), /* PWM4_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PC3, 3, 0x0114, RK_GENMASK_VAL(10, 10, 0)), /* PWM5_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PA6, 5, 0x0114, RK_GENMASK_VAL(10, 10, 1)), /* PWM5_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PB2, 3, 0x0114, RK_GENMASK_VAL(12, 12, 0)), /* PWM6_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PD4, 5, 0x0114, RK_GENMASK_VAL(12, 12, 1)), /* PWM6_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PB1, 3, 0x0114, RK_GENMASK_VAL(14, 14, 0)), /* PWM7_IR_M0 */
- MR_PMUGRF(RK_GPIO3, RK_PA0, 5, 0x0114, RK_GENMASK_VAL(14, 14, 1)), /* PWM7_IR_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PB0, 1, 0x0118, RK_GENMASK_VAL(1, 0, 0)), /* SPI0_CLK_M0 */
- MR_PMUGRF(RK_GPIO2, RK_PA1, 1, 0x0118, RK_GENMASK_VAL(1, 0, 1)), /* SPI0_CLK_M1 */
- MR_PMUGRF(RK_GPIO2, RK_PB2, 6, 0x0118, RK_GENMASK_VAL(1, 0, 2)), /* SPI0_CLK_M2 */
- MR_PMUGRF(RK_GPIO0, RK_PB6, 2, 0x0118, RK_GENMASK_VAL(2, 2, 0)), /* UART1_TX_M0 */
- MR_PMUGRF(RK_GPIO1, RK_PD0, 5, 0x0118, RK_GENMASK_VAL(2, 2, 1)), /* UART1_TX_M1 */
- MR_PMUGRF(RK_GPIO0, RK_PC3, 1, 0x0118, RK_GENMASK_VAL(4, 4, 1)), /* I2C2 */
- struct rockchip_pinctrl_priv *priv = bank->priv;
- int iomux_num = (pin / 8);
- struct regmap *regmap;
- int reg, ret, mask, mux_type;
- u8 bit;
- u32 data;
- debug("setting mux of GPIO%d-%d to %d\n", bank->bank_num, pin, mux);
- if (bank->iomux[iomux_num].type & IOMUX_SOURCE_PMU)
- else if (bank->iomux[iomux_num].type & IOMUX_L_SOURCE_PMU)
- else
- /* get basic quadrupel of mux registers and the correct reg inside */
- mux_type = bank->iomux[iomux_num].type;
- reg = bank->iomux[iomux_num].offset;
- if (mux_type & IOMUX_WIDTH_4BIT) {
if ((pin % 8) >= 4)
reg += 0x4;
mask = 0xf;
- } else {
mask = 0x3;
- if (bank->recalced_mask & BIT(pin))
- data |= (mux & mask) << bit;
- ret = regmap_write(regmap, reg, data);
- return ret;
int *reg, u8 *bit)
- /* The first 24 pins of the first bank are located in PMU */
- if (bank->bank_num == 0) {
return;
- } else {
- *reg += ((pin_num / RV1126_PULL_PINS_PER_REG) * 4);
- *bit = (pin_num % RV1126_PULL_PINS_PER_REG);
- *bit *= RV1126_PULL_BITS_PER_PIN;
- int reg, ret;
- u8 bit, type;
- u32 data;
- if (pull == PIN_CONFIG_BIAS_PULL_PIN_DEFAULT)
return -EOPNOTSUPP;
- rv1126_calc_pull_reg_and_bit(bank, pin_num, ®map, ®, &bit);
- type = bank->pull_type[pin_num / 8];
- ret = rockchip_translate_pull_value(type, pull);
- if (ret < 0) {
return ret;
- /* enable the write to the equivalent lower bits */
- data = ((1 << ROCKCHIP_PULL_BITS_PER_PIN) - 1) << (bit + 16);
- data |= (ret << bit);
- return ret;
int *reg, u8 *bit)
*reg -= 0x4;
return;
- } else {
- *reg += ((pin_num / RV1126_DRV_PINS_PER_REG) * 4);
- *bit = pin_num % RV1126_DRV_PINS_PER_REG;
- *bit *= RV1126_DRV_BITS_PER_PIN;
- int reg;
- u32 data;
- u8 bit;
- rv1126_calc_drv_reg_and_bit(bank, pin_num, ®map, ®, &bit);
- data = ((1 << ROCKCHIP_DRV_BITS_PER_PIN) - 1) << (bit + 16);
- data |= (strength << bit);
- return regmap_write(regmap, reg, data);
int pin_num,
int *reg, u8 *bit)
- int pins_per_reg;
- } else {
- *reg += ((pin_num / pins_per_reg) * 4);
- *bit = pin_num % pins_per_reg;
- int reg;
- u8 bit;
- u32 data;
- rv1126_calc_schmitt_reg_and_bit(bank, pin_num, ®map, ®, &bit);
- data = BIT(bit + 16) | (enable << bit);
- PIN_BANK_IOMUX_FLAGS(0, 32, "gpio0",
IOMUX_WIDTH_4BIT),
- PIN_BANK_IOMUX_FLAGS_OFFSET(1, 32, "gpio1",
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT,
- PIN_BANK_IOMUX_FLAGS(2, 32, "gpio2",
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT),
- PIN_BANK_IOMUX_FLAGS(3, 32, "gpio3",
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT,
IOMUX_WIDTH_4BIT),
- PIN_BANK_IOMUX_FLAGS(4, 2, "gpio4",
- .pin_banks = rv1126_pin_banks,
- .nr_banks = ARRAY_SIZE(rv1126_pin_banks),
- .nr_pins = 130,
- .grf_mux_offset = 0x10004, /* mux offset from GPIO0_D0 */
- .pmu_mux_offset = 0x0,
- .iomux_routes = rv1126_mux_route_data,
- .niomux_routes = ARRAY_SIZE(rv1126_mux_route_data),
- .iomux_recalced = rv1126_mux_recalced_data,
- .niomux_recalced = ARRAY_SIZE(rv1126_mux_recalced_data),
- .set_mux = rv1126_set_mux,
- .set_pull = rv1126_set_pull,
- .set_drive = rv1126_set_drive,
- .set_schmitt = rv1126_set_schmitt,
- .name = "rockchip_rv1126_pinctrl",
- .id = UCLASS_PINCTRL,
- .of_match = rv1126_pinctrl_ids,
- .priv_auto = sizeof(struct rockchip_pinctrl_priv),
- .ops = &rockchip_pinctrl_ops,
- .bind = dm_scan_fdt_dev,
- .probe = rockchip_pinctrl_probe,
Add clock and reset unit header include for rv1126.
.../include/asm/arch-rockchip/cru_rv1126.h | 459 ++++++++++++++++++ 1 file changed, 459 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rv1126.h
diff --git a/arch/arm/include/asm/arch-rockchip/cru_rv1126.h b/arch/arm/include/asm/arch-rockchip/cru_rv1126.h new file mode 100644 index 0000000000..49a1f76379 --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/cru_rv1126.h @@ -0,0 +1,459 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2019 Rockchip Electronics Co. Ltd. + * Author: Finley Xiao finley.xiao@rock-chips.com + */ + +#ifndef _ASM_ARCH_CRU_RV1126_H +#define _ASM_ARCH_CRU_RV1126_H + +#define MHz 1000000 +#define KHz 1000 +#define OSC_HZ (24 * MHz) + +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#define APLL_HZ (1008 * MHz) +#else +#define APLL_HZ (816 * MHz) +#endif +#define GPLL_HZ (1188 * MHz) +#define CPLL_HZ (500 * MHz) +#define HPLL_HZ (1400 * MHz) +#define PCLK_PDPMU_HZ (100 * MHz) +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#define ACLK_PDBUS_HZ (396 * MHz) +#else +#define ACLK_PDBUS_HZ (500 * MHz) +#endif +#define HCLK_PDBUS_HZ (200 * MHz) +#define PCLK_PDBUS_HZ (100 * MHz) +#define ACLK_PDPHP_HZ (300 * MHz) +#define HCLK_PDPHP_HZ (200 * MHz) +#define HCLK_PDCORE_HZ (200 * MHz) +#define HCLK_PDAUDIO_HZ (150 * MHz) +#define CLK_OSC0_DIV_HZ (32768) +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) +#define ACLK_PDVI_HZ (297 * MHz) +#define CLK_ISP_HZ (297 * MHz) +#define ACLK_PDISPP_HZ (297 * MHz) +#define CLK_ISPP_HZ (237 * MHz) +#define ACLK_VOP_HZ (300 * MHz) +#define DCLK_VOP_HZ (65 * MHz) +#endif + +/* RV1126 pll id */ +enum rv1126_pll_id { + APLL, + DPLL, + CPLL, + HPLL, + GPLL, + PLL_COUNT, +}; + +struct rv1126_clk_info { + unsigned long id; + char *name; + bool is_cru; +}; + +/* Private data for the clock driver - used by rockchip_get_cru() */ +struct rv1126_pmuclk_priv { + struct rv1126_pmucru *pmucru; + ulong gpll_hz; +}; + +struct rv1126_clk_priv { + struct rv1126_cru *cru; + struct rv1126_grf *grf; + ulong gpll_hz; + ulong cpll_hz; + ulong hpll_hz; + ulong armclk_hz; + ulong armclk_enter_hz; + ulong armclk_init_hz; + bool sync_kernel; + bool set_armclk_rate; +}; + +struct rv1126_pll { + unsigned int con0; + unsigned int con1; + unsigned int con2; + unsigned int con3; + unsigned int con4; + unsigned int con5; + unsigned int con6; + unsigned int reserved0[1]; +}; + +struct rv1126_pmucru { + unsigned int pmu_mode; + unsigned int reserved1[3]; + struct rv1126_pll pll; + unsigned int offsetcal_status; + unsigned int reserved2[51]; + unsigned int pmu_clksel_con[14]; + unsigned int reserved3[18]; + unsigned int pmu_clkgate_con[3]; + unsigned int reserved4[29]; + unsigned int pmu_softrst_con[2]; + unsigned int reserved5[14]; + unsigned int pmu_autocs_con[2]; +}; + +check_member(rv1126_pmucru, pmu_autocs_con[1], 0x244); + +struct rv1126_cru { + struct rv1126_pll pll[4]; + unsigned int offsetcal_status[4]; + unsigned int mode; + unsigned int reserved1[27]; + unsigned int clksel_con[78]; + unsigned int reserved2[18]; + unsigned int clkgate_con[25]; + unsigned int reserved3[7]; + unsigned int softrst_con[15]; + unsigned int reserved4[17]; + unsigned int ssgtbl[32]; + unsigned int glb_cnt_th; + unsigned int glb_rst_st; + unsigned int glb_srst_fst; + unsigned int glb_srst_snd; + unsigned int glb_rst_con; + unsigned int reserved5[11]; + unsigned int sdmmc_con[2]; + unsigned int sdio_con[2]; + unsigned int emmc_con[2]; + unsigned int reserved6[2]; + unsigned int gmac_con; + unsigned int misc[2]; + unsigned int reserved7[45]; + unsigned int autocs_con[26]; +}; + +check_member(rv1126_cru, autocs_con[25], 0x584); + +struct pll_rate_table { + unsigned long rate; + unsigned int fbdiv; + unsigned int postdiv1; + unsigned int refdiv; + unsigned int postdiv2; + unsigned int dsmpd; + unsigned int frac; +}; + +struct cpu_rate_table { + unsigned long rate; + unsigned int aclk_div; + unsigned int pclk_div; +}; + +#define RV1126_PMU_MODE 0x0 +#define RV1126_PMU_PLL_CON(x) ((x) * 0x4 + 0x10) +#define RV1126_PLL_CON(x) ((x) * 0x4) +#define RV1126_MODE_CON 0x90 + +enum { + /* CRU_PMU_CLK_SEL0_CON */ + RTC32K_SEL_SHIFT = 7, + RTC32K_SEL_MASK = 0x3 << RTC32K_SEL_SHIFT, + RTC32K_SEL_PMUPVTM = 0, + RTC32K_SEL_OSC1_32K, + RTC32K_SEL_OSC0_DIV32K, + + /* CRU_PMU_CLK_SEL1_CON */ + PCLK_PDPMU_DIV_SHIFT = 0, + PCLK_PDPMU_DIV_MASK = 0x1f, + + /* CRU_PMU_CLK_SEL2_CON */ + CLK_I2C0_DIV_SHIFT = 0, + CLK_I2C0_DIV_MASK = 0x7f, + + /* CRU_PMU_CLK_SEL3_CON */ + CLK_I2C2_DIV_SHIFT = 0, + CLK_I2C2_DIV_MASK = 0x7f, + + /* CRU_PMU_CLK_SEL6_CON */ + CLK_PWM1_SEL_SHIFT = 15, + CLK_PWM1_SEL_MASK = 1 << CLK_PWM1_SEL_SHIFT, + CLK_PWM1_SEL_XIN24M = 0, + CLK_PWM1_SEL_GPLL, + CLK_PWM1_DIV_SHIFT = 8, + CLK_PWM1_DIV_MASK = 0x7f << CLK_PWM1_DIV_SHIFT, + CLK_PWM0_SEL_SHIFT = 7, + CLK_PWM0_SEL_MASK = 1 << CLK_PWM0_SEL_SHIFT, + CLK_PWM0_SEL_XIN24M = 0, + CLK_PWM0_SEL_GPLL, + CLK_PWM0_DIV_SHIFT = 0, + CLK_PWM0_DIV_MASK = 0x7f, + + /* CRU_PMU_CLK_SEL9_CON */ + CLK_SPI0_SEL_SHIFT = 7, + CLK_SPI0_SEL_MASK = 1 << CLK_SPI0_SEL_SHIFT, + CLK_SPI0_SEL_GPLL = 0, + CLK_SPI0_SEL_XIN24M, + CLK_SPI0_DIV_SHIFT = 0, + CLK_SPI0_DIV_MASK = 0x7f, + + /* CRU_PMU_CLK_SEL13_CON */ + CLK_RTC32K_FRAC_NUMERATOR_SHIFT = 16, + CLK_RTC32K_FRAC_NUMERATOR_MASK = 0xffff << 16, + CLK_RTC32K_FRAC_DENOMINATOR_SHIFT = 0, + CLK_RTC32K_FRAC_DENOMINATOR_MASK = 0xffff, + + /* CRU_CLK_SEL0_CON */ + CORE_HCLK_DIV_SHIFT = 8, + CORE_HCLK_DIV_MASK = 0x1f << CORE_HCLK_DIV_SHIFT, + + /* CRU_CLK_SEL1_CON */ + CORE_ACLK_DIV_SHIFT = 4, + CORE_ACLK_DIV_MASK = 0xf << CORE_ACLK_DIV_SHIFT, + CORE_DBG_DIV_SHIFT = 0, + CORE_DBG_DIV_MASK = 0x7, + + /* CRU_CLK_SEL2_CON */ + HCLK_PDBUS_SEL_SHIFT = 15, + HCLK_PDBUS_SEL_MASK = 1 << HCLK_PDBUS_SEL_SHIFT, + HCLK_PDBUS_SEL_GPLL = 0, + HCLK_PDBUS_SEL_CPLL, + HCLK_PDBUS_DIV_SHIFT = 8, + HCLK_PDBUS_DIV_MASK = 0x1f << HCLK_PDBUS_DIV_SHIFT, + ACLK_PDBUS_SEL_SHIFT = 6, + ACLK_PDBUS_SEL_MASK = 0x3 << ACLK_PDBUS_SEL_SHIFT, + ACLK_PDBUS_SEL_GPLL = 0, + ACLK_PDBUS_SEL_CPLL, + ACLK_PDBUS_SEL_DPLL, + ACLK_PDBUS_DIV_SHIFT = 0, + ACLK_PDBUS_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL3_CON */ + CLK_SCR1_SEL_SHIFT = 15, + CLK_SCR1_SEL_MASK = 1 << CLK_SCR1_SEL_SHIFT, + CLK_SCR1_SEL_GPLL = 0, + CLK_SCR1_SEL_CPLL, + CLK_SCR1_DIV_SHIFT = 8, + CLK_SCR1_DIV_MASK = 0x1f << CLK_SCR1_DIV_SHIFT, + PCLK_PDBUS_SEL_SHIFT = 7, + PCLK_PDBUS_SEL_MASK = 1 << PCLK_PDBUS_SEL_SHIFT, + PCLK_PDBUS_SEL_GPLL = 0, + PCLK_PDBUS_SEL_CPLL, + PCLK_PDBUS_DIV_SHIFT = 0, + PCLK_PDBUS_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL4_CON */ + ACLK_CRYPTO_SEL_SHIFT = 7, + ACLK_CRYPTO_SEL_MASK = 1 << ACLK_CRYPTO_SEL_SHIFT, + ACLK_CRYPTO_SEL_GPLL = 0, + ACLK_CRYPTO_SEL_CPLL, + ACLK_CRYPTO_DIV_SHIFT = 0, + ACLK_CRYPTO_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL5_CON */ + CLK_I2C3_DIV_SHIFT = 8, + CLK_I2C3_DIV_MASK = 0x7f << CLK_I2C3_DIV_SHIFT, + CLK_I2C1_DIV_SHIFT = 0, + CLK_I2C1_DIV_MASK = 0x7f, + + /* CRU_CLK_SEL6_CON */ + CLK_I2C5_DIV_SHIFT = 8, + CLK_I2C5_DIV_MASK = 0x7f << CLK_I2C5_DIV_SHIFT, + CLK_I2C4_DIV_SHIFT = 0, + CLK_I2C4_DIV_MASK = 0x7f, + + /* CRU_CLK_SEL7_CON */ + CLK_CRYPTO_PKA_SEL_SHIFT = 15, + CLK_CRYPTO_PKA_SEL_MASK = 1 << CLK_CRYPTO_PKA_SEL_SHIFT, + CLK_CRYPTO_PKA_SEL_GPLL = 0, + CLK_CRYPTO_PKA_SEL_CPLL, + CLK_CRYPTO_PKA_DIV_SHIFT = 8, + CLK_CRYPTO_PKA_DIV_MASK = 0x1f << CLK_CRYPTO_PKA_DIV_SHIFT, + CLK_CRYPTO_CORE_SEL_SHIFT = 7, + CLK_CRYPTO_CORE_SEL_MASK = 1 << CLK_CRYPTO_CORE_SEL_SHIFT, + CLK_CRYPTO_CORE_SEL_GPLL = 0, + CLK_CRYPTO_CORE_SEL_CPLL, + CLK_CRYPTO_CORE_DIV_SHIFT = 0, + CLK_CRYPTO_CORE_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL8_CON */ + CLK_SPI1_SEL_SHIFT = 8, + CLK_SPI1_SEL_MASK = 1 << CLK_SPI1_SEL_SHIFT, + CLK_SPI1_SEL_GPLL = 0, + CLK_SPI1_SEL_XIN24M, + CLK_SPI1_DIV_SHIFT = 0, + CLK_SPI1_DIV_MASK = 0x7f, + + /* CRU_CLK_SEL9_CON */ + CLK_PWM2_SEL_SHIFT = 15, + CLK_PWM2_SEL_MASK = 1 << CLK_PWM2_SEL_SHIFT, + CLK_PWM2_SEL_XIN24M = 0, + CLK_PWM2_SEL_GPLL, + CLK_PWM2_DIV_SHIFT = 8, + CLK_PWM2_DIV_MASK = 0x7f << CLK_PWM2_DIV_SHIFT, + + /* CRU_CLK_SEL20_CON */ + CLK_SARADC_DIV_SHIFT = 0, + CLK_SARADC_DIV_MASK = 0x7ff, + + /* CRU_CLK_SEL25_CON */ + DCLK_DECOM_SEL_SHIFT = 15, + DCLK_DECOM_SEL_MASK = 1 << DCLK_DECOM_SEL_SHIFT, + DCLK_DECOM_SEL_GPLL = 0, + DCLK_DECOM_SEL_CPLL, + DCLK_DECOM_DIV_SHIFT = 8, + DCLK_DECOM_DIV_MASK = 0x7f << DCLK_DECOM_DIV_SHIFT, + + /* CRU_CLK_SEL26_CON */ + HCLK_PDAUDIO_DIV_SHIFT = 0, + HCLK_PDAUDIO_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL45_CON */ + ACLK_PDVO_SEL_SHIFT = 7, + ACLK_PDVO_SEL_MASK = 1 << ACLK_PDVO_SEL_SHIFT, + ACLK_PDVO_SEL_GPLL = 0, + ACLK_PDVO_SEL_CPLL, + ACLK_PDVO_DIV_SHIFT = 0, + ACLK_PDVO_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL47_CON */ + DCLK_VOP_SEL_SHIFT = 8, + DCLK_VOP_SEL_MASK = 1 << DCLK_VOP_SEL_SHIFT, + DCLK_VOP_SEL_GPLL = 0, + DCLK_VOP_SEL_CPLL, + DCLK_VOP_DIV_SHIFT = 0, + DCLK_VOP_DIV_MASK = 0xff, + +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) + /* CRU_CLK_SEL49_CON */ + ACLK_PDVI_SEL_SHIFT = 6, + ACLK_PDVI_SEL_MASK = 0x3 << ACLK_PDVI_SEL_SHIFT, + ACLK_PDVI_SEL_CPLL = 0, + ACLK_PDVI_SEL_GPLL, + ACLK_PDVI_SEL_HPLL, + ACLK_PDVI_DIV_SHIFT = 0, + ACLK_PDVI_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL50_CON */ + CLK_ISP_SEL_SHIFT = 6, + CLK_ISP_SEL_MASK = 0x3 << CLK_ISP_SEL_SHIFT, + CLK_ISP_SEL_GPLL = 0, + CLK_ISP_SEL_CPLL, + CLK_ISP_SEL_HPLL, + CLK_ISP_DIV_SHIFT = 0, + CLK_ISP_DIV_MASK = 0x1f, +#endif + + /* CRU_CLK_SEL53_CON */ + HCLK_PDPHP_DIV_SHIFT = 8, + HCLK_PDPHP_DIV_MASK = 0x1f << HCLK_PDPHP_DIV_SHIFT, + ACLK_PDPHP_SEL_SHIFT = 7, + ACLK_PDPHP_SEL_MASK = 1 << ACLK_PDPHP_SEL_SHIFT, + ACLK_PDPHP_SEL_GPLL = 0, + ACLK_PDPHP_SEL_CPLL, + ACLK_PDPHP_DIV_SHIFT = 0, + ACLK_PDPHP_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL57_CON */ + EMMC_SEL_SHIFT = 14, + EMMC_SEL_MASK = 0x3 << EMMC_SEL_SHIFT, + EMMC_SEL_GPLL = 0, + EMMC_SEL_CPLL, + EMMC_SEL_XIN24M, + EMMC_DIV_SHIFT = 0, + EMMC_DIV_MASK = 0xff, + + /* CRU_CLK_SEL58_CON */ + SCLK_SFC_SEL_SHIFT = 15, + SCLK_SFC_SEL_MASK = 0x1 << SCLK_SFC_SEL_SHIFT, + SCLK_SFC_SEL_CPLL = 0, + SCLK_SFC_SEL_GPLL, + SCLK_SFC_DIV_SHIFT = 0, + SCLK_SFC_DIV_MASK = 0xff, + + /* CRU_CLK_SEL59_CON */ + CLK_NANDC_SEL_SHIFT = 15, + CLK_NANDC_SEL_MASK = 0x1 << CLK_NANDC_SEL_SHIFT, + CLK_NANDC_SEL_GPLL = 0, + CLK_NANDC_SEL_CPLL, + CLK_NANDC_DIV_SHIFT = 0, + CLK_NANDC_DIV_MASK = 0xff, + + /* CRU_CLK_SEL61_CON */ + CLK_GMAC_OUT_SEL_SHIFT = 15, + CLK_GMAC_OUT_SEL_MASK = 0x1 << CLK_GMAC_OUT_SEL_SHIFT, + CLK_GMAC_OUT_SEL_CPLL = 0, + CLK_GMAC_OUT_SEL_GPLL, + CLK_GMAC_OUT_DIV_SHIFT = 8, + CLK_GMAC_OUT_DIV_MASK = 0x1f << CLK_GMAC_OUT_DIV_SHIFT, + + /* CRU_CLK_SEL63_CON */ + PCLK_GMAC_DIV_SHIFT = 8, + PCLK_GMAC_DIV_MASK = 0x1f << PCLK_GMAC_DIV_SHIFT, + CLK_GMAC_SRC_SEL_SHIFT = 7, + CLK_GMAC_SRC_SEL_MASK = 0x1 << CLK_GMAC_SRC_SEL_SHIFT, + CLK_GMAC_SRC_SEL_CPLL = 0, + CLK_GMAC_SRC_SEL_GPLL, + CLK_GMAC_SRC_DIV_SHIFT = 0, + CLK_GMAC_SRC_DIV_MASK = 0x1f << CLK_GMAC_SRC_DIV_SHIFT, + +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_SPL_KERNEL_BOOT) + /* CRU_CLK_SEL68_CON */ + ACLK_PDISPP_SEL_SHIFT = 6, + ACLK_PDISPP_SEL_MASK = 0x3 << ACLK_PDISPP_SEL_SHIFT, + ACLK_PDISPP_SEL_CPLL = 0, + ACLK_PDISPP_SEL_GPLL, + ACLK_PDISPP_SEL_HPLL, + ACLK_PDISPP_DIV_SHIFT = 0, + ACLK_PDISPP_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL69_CON */ + CLK_ISPP_SEL_SHIFT = 6, + CLK_ISPP_SEL_MASK = 0x3 << CLK_ISPP_SEL_SHIFT, + CLK_ISPP_SEL_CPLL = 0, + CLK_ISPP_SEL_GPLL, + CLK_ISPP_SEL_HPLL, + CLK_ISPP_DIV_SHIFT = 0, + CLK_ISPP_DIV_MASK = 0x1f, + + /* CRU_CLK_SEL73_CON */ + MIPICSI_OUT_SEL_SHIFT = 10, + MIPICSI_OUT_SEL_MASK = 0x3 << MIPICSI_OUT_SEL_SHIFT, + MIPICSI_OUT_SEL_XIN24M = 0, + MIPICSI_OUT_SEL_DIV, + MIPICSI_OUT_SEL_FRACDIV, + MIPICSI_OUT_DIV_SHIFT = 0, + MIPICSI_OUT_DIV_MASK = 0x1f, +#endif + + /* CRU_GMAC_CON */ + GMAC_SRC_M1_SEL_SHIFT = 5, + GMAC_SRC_M1_SEL_MASK = 0x1 << GMAC_SRC_M1_SEL_SHIFT, + GMAC_SRC_M1_SEL_INT = 0, + GMAC_SRC_M1_SEL_EXT, + GMAC_MODE_SEL_SHIFT = 4, + GMAC_MODE_SEL_MASK = 0x1 << GMAC_MODE_SEL_SHIFT, + GMAC_RGMII_MODE = 0, + GMAC_RMII_MODE, + RGMII_CLK_SEL_SHIFT = 2, + RGMII_CLK_SEL_MASK = 0x3 << RGMII_CLK_SEL_SHIFT, + RGMII_CLK_DIV0 = 0, + RGMII_CLK_DIV1, + RGMII_CLK_DIV50, + RGMII_CLK_DIV5, + RMII_CLK_SEL_SHIFT = 1, + RMII_CLK_SEL_MASK = 0x1 << RMII_CLK_SEL_SHIFT, + RMII_CLK_DIV20 = 0, + RMII_CLK_DIV2, + GMAC_SRC_M0_SEL_SHIFT = 0, + GMAC_SRC_M0_SEL_MASK = 0x1, + GMAC_SRC_M0_SEL_INT = 0, + GMAC_SRC_M0_SEL_EXT, + + /* GRF_IOFUNC_CON1 */ + GMAC_SRC_SEL_SHIFT = 12, + GMAC_SRC_SEL_MASK = 1 << GMAC_SRC_SEL_SHIFT, + GMAC_SRC_SEL_M0 = 0, + GMAC_SRC_SEL_M1, +}; +#endif
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
- Copyright (c) 2019 Rockchip Electronics Co. Ltd.
- Author: Finley Xiao finley.xiao@rock-chips.com
- APLL,
- DPLL,
- CPLL,
- HPLL,
- GPLL,
- PLL_COUNT,
- unsigned long id;
- char *name;
- bool is_cru;
- struct rv1126_pmucru *pmucru;
- ulong gpll_hz;
- struct rv1126_cru *cru;
- struct rv1126_grf *grf;
- ulong gpll_hz;
- ulong cpll_hz;
- ulong hpll_hz;
- ulong armclk_hz;
- ulong armclk_enter_hz;
- ulong armclk_init_hz;
- bool sync_kernel;
- bool set_armclk_rate;
- unsigned int con0;
- unsigned int con1;
- unsigned int con2;
- unsigned int con3;
- unsigned int con4;
- unsigned int con5;
- unsigned int con6;
- unsigned int reserved0[1];
- unsigned int pmu_mode;
- unsigned int reserved1[3];
- struct rv1126_pll pll;
- unsigned int offsetcal_status;
- unsigned int reserved2[51];
- unsigned int pmu_clksel_con[14];
- unsigned int reserved3[18];
- unsigned int pmu_clkgate_con[3];
- unsigned int reserved4[29];
- unsigned int pmu_softrst_con[2];
- unsigned int reserved5[14];
- unsigned int pmu_autocs_con[2];
- struct rv1126_pll pll[4];
- unsigned int offsetcal_status[4];
- unsigned int mode;
- unsigned int reserved1[27];
- unsigned int clksel_con[78];
- unsigned int reserved2[18];
- unsigned int clkgate_con[25];
- unsigned int reserved3[7];
- unsigned int softrst_con[15];
- unsigned int reserved4[17];
- unsigned int ssgtbl[32];
- unsigned int glb_cnt_th;
- unsigned int glb_rst_st;
- unsigned int glb_srst_fst;
- unsigned int glb_srst_snd;
- unsigned int glb_rst_con;
- unsigned int reserved5[11];
- unsigned int sdmmc_con[2];
- unsigned int sdio_con[2];
- unsigned int emmc_con[2];
- unsigned int reserved6[2];
- unsigned int gmac_con;
- unsigned int misc[2];
- unsigned int reserved7[45];
- unsigned int autocs_con[26];
- unsigned long rate;
- unsigned int fbdiv;
- unsigned int postdiv1;
- unsigned int refdiv;
- unsigned int postdiv2;
- unsigned int dsmpd;
- unsigned int frac;
- unsigned int aclk_div;
- unsigned int pclk_div;
+enum {
- /* CRU_PMU_CLK_SEL0_CON */
- RTC32K_SEL_SHIFT = 7,
- RTC32K_SEL_MASK = 0x3 << RTC32K_SEL_SHIFT,
- RTC32K_SEL_PMUPVTM = 0,
- RTC32K_SEL_OSC1_32K,
- RTC32K_SEL_OSC0_DIV32K,
- /* CRU_PMU_CLK_SEL1_CON */
- PCLK_PDPMU_DIV_SHIFT = 0,
- PCLK_PDPMU_DIV_MASK = 0x1f,
- /* CRU_PMU_CLK_SEL2_CON */
- CLK_I2C0_DIV_SHIFT = 0,
- CLK_I2C0_DIV_MASK = 0x7f,
- /* CRU_PMU_CLK_SEL3_CON */
- CLK_I2C2_DIV_SHIFT = 0,
- CLK_I2C2_DIV_MASK = 0x7f,
- /* CRU_PMU_CLK_SEL6_CON */
- CLK_PWM1_SEL_SHIFT = 15,
- CLK_PWM1_SEL_MASK = 1 << CLK_PWM1_SEL_SHIFT,
- CLK_PWM1_SEL_XIN24M = 0,
- CLK_PWM1_SEL_GPLL,
- CLK_PWM1_DIV_SHIFT = 8,
- CLK_PWM1_DIV_MASK = 0x7f << CLK_PWM1_DIV_SHIFT,
- CLK_PWM0_SEL_SHIFT = 7,
- CLK_PWM0_SEL_MASK = 1 << CLK_PWM0_SEL_SHIFT,
- CLK_PWM0_SEL_XIN24M = 0,
- CLK_PWM0_SEL_GPLL,
- CLK_PWM0_DIV_SHIFT = 0,
- CLK_PWM0_DIV_MASK = 0x7f,
- /* CRU_PMU_CLK_SEL9_CON */
- CLK_SPI0_SEL_SHIFT = 7,
- CLK_SPI0_SEL_MASK = 1 << CLK_SPI0_SEL_SHIFT,
- CLK_SPI0_SEL_GPLL = 0,
- CLK_SPI0_SEL_XIN24M,
- CLK_SPI0_DIV_SHIFT = 0,
- CLK_SPI0_DIV_MASK = 0x7f,
- /* CRU_PMU_CLK_SEL13_CON */
- CLK_RTC32K_FRAC_NUMERATOR_SHIFT = 16,
- CLK_RTC32K_FRAC_NUMERATOR_MASK = 0xffff << 16,
- CLK_RTC32K_FRAC_DENOMINATOR_SHIFT = 0,
- CLK_RTC32K_FRAC_DENOMINATOR_MASK = 0xffff,
- /* CRU_CLK_SEL0_CON */
- CORE_HCLK_DIV_SHIFT = 8,
- CORE_HCLK_DIV_MASK = 0x1f << CORE_HCLK_DIV_SHIFT,
- /* CRU_CLK_SEL1_CON */
- CORE_ACLK_DIV_SHIFT = 4,
- CORE_ACLK_DIV_MASK = 0xf << CORE_ACLK_DIV_SHIFT,
- CORE_DBG_DIV_SHIFT = 0,
- CORE_DBG_DIV_MASK = 0x7,
- /* CRU_CLK_SEL2_CON */
- HCLK_PDBUS_SEL_SHIFT = 15,
- HCLK_PDBUS_SEL_MASK = 1 << HCLK_PDBUS_SEL_SHIFT,
- HCLK_PDBUS_SEL_GPLL = 0,
- HCLK_PDBUS_SEL_CPLL,
- HCLK_PDBUS_DIV_SHIFT = 8,
- HCLK_PDBUS_DIV_MASK = 0x1f << HCLK_PDBUS_DIV_SHIFT,
- ACLK_PDBUS_SEL_SHIFT = 6,
- ACLK_PDBUS_SEL_MASK = 0x3 << ACLK_PDBUS_SEL_SHIFT,
- ACLK_PDBUS_SEL_GPLL = 0,
- ACLK_PDBUS_SEL_CPLL,
- ACLK_PDBUS_SEL_DPLL,
- ACLK_PDBUS_DIV_SHIFT = 0,
- ACLK_PDBUS_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL3_CON */
- CLK_SCR1_SEL_SHIFT = 15,
- CLK_SCR1_SEL_MASK = 1 << CLK_SCR1_SEL_SHIFT,
- CLK_SCR1_SEL_GPLL = 0,
- CLK_SCR1_SEL_CPLL,
- CLK_SCR1_DIV_SHIFT = 8,
- CLK_SCR1_DIV_MASK = 0x1f << CLK_SCR1_DIV_SHIFT,
- PCLK_PDBUS_SEL_SHIFT = 7,
- PCLK_PDBUS_SEL_MASK = 1 << PCLK_PDBUS_SEL_SHIFT,
- PCLK_PDBUS_SEL_GPLL = 0,
- PCLK_PDBUS_SEL_CPLL,
- PCLK_PDBUS_DIV_SHIFT = 0,
- PCLK_PDBUS_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL4_CON */
- ACLK_CRYPTO_SEL_SHIFT = 7,
- ACLK_CRYPTO_SEL_MASK = 1 << ACLK_CRYPTO_SEL_SHIFT,
- ACLK_CRYPTO_SEL_GPLL = 0,
- ACLK_CRYPTO_SEL_CPLL,
- ACLK_CRYPTO_DIV_SHIFT = 0,
- ACLK_CRYPTO_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL5_CON */
- CLK_I2C3_DIV_SHIFT = 8,
- CLK_I2C3_DIV_MASK = 0x7f << CLK_I2C3_DIV_SHIFT,
- CLK_I2C1_DIV_SHIFT = 0,
- CLK_I2C1_DIV_MASK = 0x7f,
- /* CRU_CLK_SEL6_CON */
- CLK_I2C5_DIV_SHIFT = 8,
- CLK_I2C5_DIV_MASK = 0x7f << CLK_I2C5_DIV_SHIFT,
- CLK_I2C4_DIV_SHIFT = 0,
- CLK_I2C4_DIV_MASK = 0x7f,
- /* CRU_CLK_SEL7_CON */
- CLK_CRYPTO_PKA_SEL_SHIFT = 15,
- CLK_CRYPTO_PKA_SEL_MASK = 1 << CLK_CRYPTO_PKA_SEL_SHIFT,
- CLK_CRYPTO_PKA_SEL_GPLL = 0,
- CLK_CRYPTO_PKA_SEL_CPLL,
- CLK_CRYPTO_PKA_DIV_SHIFT = 8,
- CLK_CRYPTO_PKA_DIV_MASK = 0x1f << CLK_CRYPTO_PKA_DIV_SHIFT,
- CLK_CRYPTO_CORE_SEL_SHIFT = 7,
- CLK_CRYPTO_CORE_SEL_MASK = 1 << CLK_CRYPTO_CORE_SEL_SHIFT,
- CLK_CRYPTO_CORE_SEL_GPLL = 0,
- CLK_CRYPTO_CORE_SEL_CPLL,
- CLK_CRYPTO_CORE_DIV_SHIFT = 0,
- CLK_CRYPTO_CORE_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL8_CON */
- CLK_SPI1_SEL_SHIFT = 8,
- CLK_SPI1_SEL_MASK = 1 << CLK_SPI1_SEL_SHIFT,
- CLK_SPI1_SEL_GPLL = 0,
- CLK_SPI1_SEL_XIN24M,
- CLK_SPI1_DIV_SHIFT = 0,
- CLK_SPI1_DIV_MASK = 0x7f,
- /* CRU_CLK_SEL9_CON */
- CLK_PWM2_SEL_SHIFT = 15,
- CLK_PWM2_SEL_MASK = 1 << CLK_PWM2_SEL_SHIFT,
- CLK_PWM2_SEL_XIN24M = 0,
- CLK_PWM2_SEL_GPLL,
- CLK_PWM2_DIV_SHIFT = 8,
- CLK_PWM2_DIV_MASK = 0x7f << CLK_PWM2_DIV_SHIFT,
- /* CRU_CLK_SEL20_CON */
- CLK_SARADC_DIV_SHIFT = 0,
- CLK_SARADC_DIV_MASK = 0x7ff,
- /* CRU_CLK_SEL25_CON */
- DCLK_DECOM_SEL_SHIFT = 15,
- DCLK_DECOM_SEL_MASK = 1 << DCLK_DECOM_SEL_SHIFT,
- DCLK_DECOM_SEL_GPLL = 0,
- DCLK_DECOM_SEL_CPLL,
- DCLK_DECOM_DIV_SHIFT = 8,
- DCLK_DECOM_DIV_MASK = 0x7f << DCLK_DECOM_DIV_SHIFT,
- /* CRU_CLK_SEL26_CON */
- HCLK_PDAUDIO_DIV_SHIFT = 0,
- HCLK_PDAUDIO_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL45_CON */
- ACLK_PDVO_SEL_SHIFT = 7,
- ACLK_PDVO_SEL_MASK = 1 << ACLK_PDVO_SEL_SHIFT,
- ACLK_PDVO_SEL_GPLL = 0,
- ACLK_PDVO_SEL_CPLL,
- ACLK_PDVO_DIV_SHIFT = 0,
- ACLK_PDVO_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL47_CON */
- DCLK_VOP_SEL_SHIFT = 8,
- DCLK_VOP_SEL_MASK = 1 << DCLK_VOP_SEL_SHIFT,
- DCLK_VOP_SEL_GPLL = 0,
- DCLK_VOP_SEL_CPLL,
- DCLK_VOP_DIV_SHIFT = 0,
- DCLK_VOP_DIV_MASK = 0xff,
- /* CRU_CLK_SEL49_CON */
- ACLK_PDVI_SEL_SHIFT = 6,
- ACLK_PDVI_SEL_MASK = 0x3 << ACLK_PDVI_SEL_SHIFT,
- ACLK_PDVI_SEL_CPLL = 0,
- ACLK_PDVI_SEL_GPLL,
- ACLK_PDVI_SEL_HPLL,
- ACLK_PDVI_DIV_SHIFT = 0,
- ACLK_PDVI_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL50_CON */
- CLK_ISP_SEL_SHIFT = 6,
- CLK_ISP_SEL_MASK = 0x3 << CLK_ISP_SEL_SHIFT,
- CLK_ISP_SEL_GPLL = 0,
- CLK_ISP_SEL_CPLL,
- CLK_ISP_SEL_HPLL,
- CLK_ISP_DIV_SHIFT = 0,
- CLK_ISP_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL53_CON */
- HCLK_PDPHP_DIV_SHIFT = 8,
- HCLK_PDPHP_DIV_MASK = 0x1f << HCLK_PDPHP_DIV_SHIFT,
- ACLK_PDPHP_SEL_SHIFT = 7,
- ACLK_PDPHP_SEL_MASK = 1 << ACLK_PDPHP_SEL_SHIFT,
- ACLK_PDPHP_SEL_GPLL = 0,
- ACLK_PDPHP_SEL_CPLL,
- ACLK_PDPHP_DIV_SHIFT = 0,
- ACLK_PDPHP_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL57_CON */
- EMMC_SEL_SHIFT = 14,
- EMMC_SEL_MASK = 0x3 << EMMC_SEL_SHIFT,
- EMMC_SEL_GPLL = 0,
- EMMC_SEL_CPLL,
- EMMC_SEL_XIN24M,
- EMMC_DIV_SHIFT = 0,
- EMMC_DIV_MASK = 0xff,
- /* CRU_CLK_SEL58_CON */
- SCLK_SFC_SEL_SHIFT = 15,
- SCLK_SFC_SEL_MASK = 0x1 << SCLK_SFC_SEL_SHIFT,
- SCLK_SFC_SEL_CPLL = 0,
- SCLK_SFC_SEL_GPLL,
- SCLK_SFC_DIV_SHIFT = 0,
- SCLK_SFC_DIV_MASK = 0xff,
- /* CRU_CLK_SEL59_CON */
- CLK_NANDC_SEL_SHIFT = 15,
- CLK_NANDC_SEL_MASK = 0x1 << CLK_NANDC_SEL_SHIFT,
- CLK_NANDC_SEL_GPLL = 0,
- CLK_NANDC_SEL_CPLL,
- CLK_NANDC_DIV_SHIFT = 0,
- CLK_NANDC_DIV_MASK = 0xff,
- /* CRU_CLK_SEL61_CON */
- CLK_GMAC_OUT_SEL_SHIFT = 15,
- CLK_GMAC_OUT_SEL_MASK = 0x1 << CLK_GMAC_OUT_SEL_SHIFT,
- CLK_GMAC_OUT_SEL_CPLL = 0,
- CLK_GMAC_OUT_SEL_GPLL,
- CLK_GMAC_OUT_DIV_SHIFT = 8,
- CLK_GMAC_OUT_DIV_MASK = 0x1f << CLK_GMAC_OUT_DIV_SHIFT,
- /* CRU_CLK_SEL63_CON */
- PCLK_GMAC_DIV_SHIFT = 8,
- PCLK_GMAC_DIV_MASK = 0x1f << PCLK_GMAC_DIV_SHIFT,
- CLK_GMAC_SRC_SEL_SHIFT = 7,
- CLK_GMAC_SRC_SEL_MASK = 0x1 << CLK_GMAC_SRC_SEL_SHIFT,
- CLK_GMAC_SRC_SEL_CPLL = 0,
- CLK_GMAC_SRC_SEL_GPLL,
- CLK_GMAC_SRC_DIV_SHIFT = 0,
- CLK_GMAC_SRC_DIV_MASK = 0x1f << CLK_GMAC_SRC_DIV_SHIFT,
- /* CRU_CLK_SEL68_CON */
- ACLK_PDISPP_SEL_SHIFT = 6,
- ACLK_PDISPP_SEL_MASK = 0x3 << ACLK_PDISPP_SEL_SHIFT,
- ACLK_PDISPP_SEL_CPLL = 0,
- ACLK_PDISPP_SEL_GPLL,
- ACLK_PDISPP_SEL_HPLL,
- ACLK_PDISPP_DIV_SHIFT = 0,
- ACLK_PDISPP_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL69_CON */
- CLK_ISPP_SEL_SHIFT = 6,
- CLK_ISPP_SEL_MASK = 0x3 << CLK_ISPP_SEL_SHIFT,
- CLK_ISPP_SEL_CPLL = 0,
- CLK_ISPP_SEL_GPLL,
- CLK_ISPP_SEL_HPLL,
- CLK_ISPP_DIV_SHIFT = 0,
- CLK_ISPP_DIV_MASK = 0x1f,
- /* CRU_CLK_SEL73_CON */
- MIPICSI_OUT_SEL_SHIFT = 10,
- MIPICSI_OUT_SEL_MASK = 0x3 << MIPICSI_OUT_SEL_SHIFT,
- MIPICSI_OUT_SEL_XIN24M = 0,
- MIPICSI_OUT_SEL_DIV,
- MIPICSI_OUT_SEL_FRACDIV,
- MIPICSI_OUT_DIV_SHIFT = 0,
- MIPICSI_OUT_DIV_MASK = 0x1f,
- /* CRU_GMAC_CON */
- GMAC_SRC_M1_SEL_SHIFT = 5,
- GMAC_SRC_M1_SEL_MASK = 0x1 << GMAC_SRC_M1_SEL_SHIFT,
- GMAC_SRC_M1_SEL_INT = 0,
- GMAC_SRC_M1_SEL_EXT,
- GMAC_MODE_SEL_SHIFT = 4,
- GMAC_MODE_SEL_MASK = 0x1 << GMAC_MODE_SEL_SHIFT,
- GMAC_RGMII_MODE = 0,
- GMAC_RMII_MODE,
- RGMII_CLK_SEL_SHIFT = 2,
- RGMII_CLK_SEL_MASK = 0x3 << RGMII_CLK_SEL_SHIFT,
- RGMII_CLK_DIV0 = 0,
- RGMII_CLK_DIV1,
- RGMII_CLK_DIV50,
- RGMII_CLK_DIV5,
- RMII_CLK_SEL_SHIFT = 1,
- RMII_CLK_SEL_MASK = 0x1 << RMII_CLK_SEL_SHIFT,
- RMII_CLK_DIV20 = 0,
- RMII_CLK_DIV2,
- GMAC_SRC_M0_SEL_SHIFT = 0,
- GMAC_SRC_M0_SEL_MASK = 0x1,
- GMAC_SRC_M0_SEL_INT = 0,
- GMAC_SRC_M0_SEL_EXT,
- /* GRF_IOFUNC_CON1 */
- GMAC_SRC_SEL_SHIFT = 12,
- GMAC_SRC_SEL_MASK = 1 << GMAC_SRC_SEL_SHIFT,
- GMAC_SRC_SEL_M0 = 0,
- GMAC_SRC_SEL_M1,
+}; +#endif
Add the dt-bindings header for the Rockchip RV1126, that gets shared between the clock controller and the clock references in the dts.
Signed-off-by: Finley Xiao finley.xiao@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - update cru header
.../dt-bindings/clock/rockchip,rv1126-cru.h | 632 ++++++++++++++++++ 1 file changed, 632 insertions(+) create mode 100644 include/dt-bindings/clock/rockchip,rv1126-cru.h
diff --git a/include/dt-bindings/clock/rockchip,rv1126-cru.h b/include/dt-bindings/clock/rockchip,rv1126-cru.h new file mode 100644 index 0000000000..cfba8226de --- /dev/null +++ b/include/dt-bindings/clock/rockchip,rv1126-cru.h @@ -0,0 +1,632 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (c) 2019 Rockchip Electronics Co. Ltd. + * Author: Finley Xiao finley.xiao@rock-chips.com + */ + +#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RV1126_H +#define _DT_BINDINGS_CLK_ROCKCHIP_RV1126_H + +/* pmucru-clocks indices */ + +/* pll clocks */ +#define PLL_GPLL 1 + +/* sclk (special clocks) */ +#define CLK_OSC0_DIV32K 2 +#define CLK_RTC32K 3 +#define CLK_WIFI_DIV 4 +#define CLK_WIFI_OSC0 5 +#define CLK_WIFI 6 +#define CLK_PMU 7 +#define SCLK_UART1_DIV 8 +#define SCLK_UART1_FRACDIV 9 +#define SCLK_UART1_MUX 10 +#define SCLK_UART1 11 +#define CLK_I2C0 12 +#define CLK_I2C2 13 +#define CLK_CAPTURE_PWM0 14 +#define CLK_PWM0 15 +#define CLK_CAPTURE_PWM1 16 +#define CLK_PWM1 17 +#define CLK_SPI0 18 +#define DBCLK_GPIO0 19 +#define CLK_PMUPVTM 20 +#define CLK_CORE_PMUPVTM 21 +#define CLK_REF12M 22 +#define CLK_USBPHY_OTG_REF 23 +#define CLK_USBPHY_HOST_REF 24 +#define CLK_REF24M 25 +#define CLK_MIPIDSIPHY_REF 26 + +/* pclk */ +#define PCLK_PDPMU 30 +#define PCLK_PMU 31 +#define PCLK_UART1 32 +#define PCLK_I2C0 33 +#define PCLK_I2C2 34 +#define PCLK_PWM0 35 +#define PCLK_PWM1 36 +#define PCLK_SPI0 37 +#define PCLK_GPIO0 38 +#define PCLK_PMUSGRF 39 +#define PCLK_PMUGRF 40 +#define PCLK_PMUCRU 41 +#define PCLK_CHIPVEROTP 42 +#define PCLK_PDPMU_NIU 43 +#define PCLK_PMUPVTM 44 +#define PCLK_SCRKEYGEN 45 + +#define CLKPMU_NR_CLKS (PCLK_SCRKEYGEN + 1) + +/* cru-clocks indices */ + +/* pll clocks */ +#define PLL_APLL 1 +#define PLL_DPLL 2 +#define PLL_CPLL 3 +#define PLL_HPLL 4 + +/* sclk (special clocks) */ +#define ARMCLK 5 +#define USB480M 6 +#define CLK_CORE_CPUPVTM 7 +#define CLK_CPUPVTM 8 +#define CLK_SCR1 9 +#define CLK_SCR1_CORE 10 +#define CLK_SCR1_RTC 11 +#define CLK_SCR1_JTAG 12 +#define SCLK_UART0_DIV 13 +#define SCLK_UART0_FRAC 14 +#define SCLK_UART0_MUX 15 +#define SCLK_UART0 16 +#define SCLK_UART2_DIV 17 +#define SCLK_UART2_FRAC 18 +#define SCLK_UART2_MUX 19 +#define SCLK_UART2 20 +#define SCLK_UART3_DIV 21 +#define SCLK_UART3_FRAC 22 +#define SCLK_UART3_MUX 23 +#define SCLK_UART3 24 +#define SCLK_UART4_DIV 25 +#define SCLK_UART4_FRAC 26 +#define SCLK_UART4_MUX 27 +#define SCLK_UART4 28 +#define SCLK_UART5_DIV 29 +#define SCLK_UART5_FRAC 30 +#define SCLK_UART5_MUX 31 +#define SCLK_UART5 32 +#define CLK_I2C1 33 +#define CLK_I2C3 34 +#define CLK_I2C4 35 +#define CLK_I2C5 36 +#define CLK_SPI1 37 +#define CLK_CAPTURE_PWM2 38 +#define CLK_PWM2 39 +#define DBCLK_GPIO1 40 +#define DBCLK_GPIO2 41 +#define DBCLK_GPIO3 42 +#define DBCLK_GPIO4 43 +#define CLK_SARADC 44 +#define CLK_TIMER0 45 +#define CLK_TIMER1 46 +#define CLK_TIMER2 47 +#define CLK_TIMER3 48 +#define CLK_TIMER4 49 +#define CLK_TIMER5 50 +#define CLK_CAN 51 +#define CLK_NPU_TSADC 52 +#define CLK_NPU_TSADCPHY 53 +#define CLK_CPU_TSADC 54 +#define CLK_CPU_TSADCPHY 55 +#define CLK_CRYPTO_CORE 56 +#define CLK_CRYPTO_PKA 57 +#define MCLK_I2S0_TX_DIV 58 +#define MCLK_I2S0_TX_FRACDIV 59 +#define MCLK_I2S0_TX_MUX 60 +#define MCLK_I2S0_TX 61 +#define MCLK_I2S0_RX_DIV 62 +#define MCLK_I2S0_RX_FRACDIV 63 +#define MCLK_I2S0_RX_MUX 64 +#define MCLK_I2S0_RX 65 +#define MCLK_I2S0_TX_OUT2IO 66 +#define MCLK_I2S0_RX_OUT2IO 67 +#define MCLK_I2S1_DIV 68 +#define MCLK_I2S1_FRACDIV 69 +#define MCLK_I2S1_MUX 70 +#define MCLK_I2S1 71 +#define MCLK_I2S1_OUT2IO 72 +#define MCLK_I2S2_DIV 73 +#define MCLK_I2S2_FRACDIV 74 +#define MCLK_I2S2_MUX 75 +#define MCLK_I2S2 76 +#define MCLK_I2S2_OUT2IO 77 +#define MCLK_PDM 78 +#define SCLK_ADUPWM_DIV 79 +#define SCLK_AUDPWM_FRACDIV 80 +#define SCLK_AUDPWM_MUX 81 +#define SCLK_AUDPWM 82 +#define CLK_ACDCDIG_ADC 83 +#define CLK_ACDCDIG_DAC 84 +#define CLK_ACDCDIG_I2C 85 +#define CLK_VENC_CORE 86 +#define CLK_VDEC_CORE 87 +#define CLK_VDEC_CA 88 +#define CLK_VDEC_HEVC_CA 89 +#define CLK_RGA_CORE 90 +#define CLK_IEP_CORE 91 +#define CLK_ISP_DIV 92 +#define CLK_ISP_NP5 93 +#define CLK_ISP_NUX 94 +#define CLK_ISP 95 +#define CLK_CIF_OUT_DIV 96 +#define CLK_CIF_OUT_FRACDIV 97 +#define CLK_CIF_OUT_MUX 98 +#define CLK_CIF_OUT 99 +#define CLK_MIPICSI_OUT_DIV 100 +#define CLK_MIPICSI_OUT_FRACDIV 101 +#define CLK_MIPICSI_OUT_MUX 102 +#define CLK_MIPICSI_OUT 103 +#define CLK_ISPP_DIV 104 +#define CLK_ISPP_NP5 105 +#define CLK_ISPP_NUX 106 +#define CLK_ISPP 107 +#define CLK_SDMMC 108 +#define SCLK_SDMMC_DRV 109 +#define SCLK_SDMMC_SAMPLE 110 +#define CLK_SDIO 111 +#define SCLK_SDIO_DRV 112 +#define SCLK_SDIO_SAMPLE 113 +#define CLK_EMMC 114 +#define SCLK_EMMC_DRV 115 +#define SCLK_EMMC_SAMPLE 116 +#define CLK_NANDC 117 +#define SCLK_SFC 118 +#define CLK_USBHOST_UTMI_OHCI 119 +#define CLK_USBOTG_REF 120 +#define CLK_GMAC_DIV 121 +#define CLK_GMAC_RGMII_M0 122 +#define CLK_GMAC_SRC_M0 123 +#define CLK_GMAC_RGMII_M1 124 +#define CLK_GMAC_SRC_M1 125 +#define CLK_GMAC_SRC 126 +#define CLK_GMAC_REF 127 +#define CLK_GMAC_TX_SRC 128 +#define CLK_GMAC_TX_DIV5 129 +#define CLK_GMAC_TX_DIV50 130 +#define RGMII_MODE_CLK 131 +#define CLK_GMAC_RX_SRC 132 +#define CLK_GMAC_RX_DIV2 133 +#define CLK_GMAC_RX_DIV20 134 +#define RMII_MODE_CLK 135 +#define CLK_GMAC_TX_RX 136 +#define CLK_GMAC_PTPREF 137 +#define CLK_GMAC_ETHERNET_OUT 138 +#define CLK_DDRPHY 139 +#define CLK_DDR_MON 140 +#define TMCLK_DDR_MON 141 +#define CLK_NPU_DIV 142 +#define CLK_NPU_NP5 143 +#define CLK_CORE_NPU 144 +#define CLK_CORE_NPUPVTM 145 +#define CLK_NPUPVTM 146 +#define SCLK_DDRCLK 147 +#define CLK_OTP 148 + +/* dclk */ +#define DCLK_DECOM 150 +#define DCLK_VOP_DIV 151 +#define DCLK_VOP_FRACDIV 152 +#define DCLK_VOP_MUX 153 +#define DCLK_VOP 154 +#define DCLK_CIF 155 +#define DCLK_CIFLITE 156 + +/* aclk */ +#define ACLK_PDBUS 160 +#define ACLK_DMAC 161 +#define ACLK_DCF 162 +#define ACLK_SPINLOCK 163 +#define ACLK_DECOM 164 +#define ACLK_PDCRYPTO 165 +#define ACLK_CRYPTO 166 +#define ACLK_PDVEPU 167 +#define ACLK_VENC 168 +#define ACLK_PDVDEC 169 +#define ACLK_PDJPEG 170 +#define ACLK_VDEC 171 +#define ACLK_JPEG 172 +#define ACLK_PDVO 173 +#define ACLK_RGA 174 +#define ACLK_VOP 175 +#define ACLK_IEP 176 +#define ACLK_PDVI_DIV 177 +#define ACLK_PDVI_NP5 178 +#define ACLK_PDVI 179 +#define ACLK_ISP 180 +#define ACLK_CIF 181 +#define ACLK_CIFLITE 182 +#define ACLK_PDISPP_DIV 183 +#define ACLK_PDISPP_NP5 184 +#define ACLK_PDISPP 185 +#define ACLK_ISPP 186 +#define ACLK_PDPHP 187 +#define ACLK_PDUSB 188 +#define ACLK_USBOTG 189 +#define ACLK_PDGMAC 190 +#define ACLK_GMAC 191 +#define ACLK_PDNPU_DIV 192 +#define ACLK_PDNPU_NP5 193 +#define ACLK_PDNPU 194 +#define ACLK_NPU 195 + +/* hclk */ +#define HCLK_PDCORE_NIU 200 +#define HCLK_PDUSB 201 +#define HCLK_PDCRYPTO 202 +#define HCLK_CRYPTO 203 +#define HCLK_PDAUDIO 204 +#define HCLK_I2S0 205 +#define HCLK_I2S1 206 +#define HCLK_I2S2 207 +#define HCLK_PDM 208 +#define HCLK_AUDPWM 209 +#define HCLK_PDVEPU 210 +#define HCLK_VENC 211 +#define HCLK_PDVDEC 212 +#define HCLK_PDJPEG 213 +#define HCLK_VDEC 214 +#define HCLK_JPEG 215 +#define HCLK_PDVO 216 +#define HCLK_RGA 217 +#define HCLK_VOP 218 +#define HCLK_IEP 219 +#define HCLK_PDVI 220 +#define HCLK_ISP 221 +#define HCLK_CIF 222 +#define HCLK_CIFLITE 223 +#define HCLK_PDISPP 224 +#define HCLK_ISPP 225 +#define HCLK_PDPHP 226 +#define HCLK_PDSDMMC 227 +#define HCLK_SDMMC 228 +#define HCLK_PDSDIO 229 +#define HCLK_SDIO 230 +#define HCLK_PDNVM 231 +#define HCLK_EMMC 232 +#define HCLK_NANDC 233 +#define HCLK_SFC 234 +#define HCLK_SFCXIP 235 +#define HCLK_PDBUS 236 +#define HCLK_USBHOST 237 +#define HCLK_USBHOST_ARB 238 +#define HCLK_PDNPU 239 +#define HCLK_NPU 240 + +/* pclk */ +#define PCLK_CPUPVTM 245 +#define PCLK_PDBUS 246 +#define PCLK_DCF 247 +#define PCLK_WDT 248 +#define PCLK_MAILBOX 249 +#define PCLK_UART0 250 +#define PCLK_UART2 251 +#define PCLK_UART3 252 +#define PCLK_UART4 253 +#define PCLK_UART5 254 +#define PCLK_I2C1 255 +#define PCLK_I2C3 256 +#define PCLK_I2C4 257 +#define PCLK_I2C5 258 +#define PCLK_SPI1 259 +#define PCLK_PWM2 261 +#define PCLK_GPIO1 262 +#define PCLK_GPIO2 263 +#define PCLK_GPIO3 264 +#define PCLK_GPIO4 265 +#define PCLK_SARADC 266 +#define PCLK_TIMER 267 +#define PCLK_DECOM 268 +#define PCLK_CAN 269 +#define PCLK_NPU_TSADC 270 +#define PCLK_CPU_TSADC 271 +#define PCLK_ACDCDIG 272 +#define PCLK_PDVO 273 +#define PCLK_DSIHOST 274 +#define PCLK_PDVI 275 +#define PCLK_CSIHOST 276 +#define PCLK_PDGMAC 277 +#define PCLK_GMAC 278 +#define PCLK_PDDDR 279 +#define PCLK_DDR_MON 280 +#define PCLK_PDNPU 281 +#define PCLK_NPUPVTM 282 +#define PCLK_PDTOP 283 +#define PCLK_TOPCRU 284 +#define PCLK_TOPGRF 285 +#define PCLK_CPUEMADET 286 +#define PCLK_DDRPHY 287 +#define PCLK_DSIPHY 289 +#define PCLK_CSIPHY0 290 +#define PCLK_CSIPHY1 291 +#define PCLK_USBPHY_HOST 292 +#define PCLK_USBPHY_OTG 293 +#define PCLK_OTP 294 + +#define CLK_NR_CLKS (PCLK_OTP + 1) + +/* pmu soft-reset indices */ + +/* pmu_cru_softrst_con0 */ +#define SRST_PDPMU_NIU_P 0 +#define SRST_PMU_SGRF_P 1 +#define SRST_PMU_SGRF_REMAP_P 2 +#define SRST_I2C0_P 3 +#define SRST_I2C0 4 +#define SRST_I2C2_P 7 +#define SRST_I2C2 8 +#define SRST_UART1_P 9 +#define SRST_UART1 10 +#define SRST_PWM0_P 11 +#define SRST_PWM0 12 +#define SRST_PWM1_P 13 +#define SRST_PWM1 14 +#define SRST_DDR_FAIL_SAFE 15 + +/* pmu_cru_softrst_con1 */ +#define SRST_GPIO0_P 17 +#define SRST_GPIO0_DB 18 +#define SRST_SPI0_P 19 +#define SRST_SPI0 20 +#define SRST_PMUGRF_P 21 +#define SRST_CHIPVEROTP_P 22 +#define SRST_PMUPVTM 24 +#define SRST_PMUPVTM_P 25 +#define SRST_PMUCRU_P 30 + +/* soft-reset indices */ + +/* cru_softrst_con0 */ +#define SRST_CORE0_PO 0 +#define SRST_CORE1_PO 1 +#define SRST_CORE2_PO 2 +#define SRST_CORE3_PO 3 +#define SRST_CORE0 4 +#define SRST_CORE1 5 +#define SRST_CORE2 6 +#define SRST_CORE3 7 +#define SRST_CORE0_DBG 8 +#define SRST_CORE1_DBG 9 +#define SRST_CORE2_DBG 10 +#define SRST_CORE3_DBG 11 +#define SRST_NL2 12 +#define SRST_CORE_NIU_A 13 +#define SRST_DBG_DAPLITE_P 14 +#define SRST_DAPLITE_P 15 + +/* cru_softrst_con1 */ +#define SRST_PDBUS_NIU1_A 16 +#define SRST_PDBUS_NIU1_H 17 +#define SRST_PDBUS_NIU1_P 18 +#define SRST_PDBUS_NIU2_A 19 +#define SRST_PDBUS_NIU2_H 20 +#define SRST_PDBUS_NIU3_A 21 +#define SRST_PDBUS_NIU3_H 22 +#define SRST_PDBUS_HOLD_NIU1_A 23 +#define SRST_DBG_NIU_P 24 +#define SRST_PDCORE_NIIU_H 25 +#define SRST_MUC_NIU 26 +#define SRST_DCF_A 29 +#define SRST_DCF_P 30 +#define SRST_SYSTEM_SRAM_A 31 + +/* cru_softrst_con2 */ +#define SRST_I2C1_P 32 +#define SRST_I2C1 33 +#define SRST_I2C3_P 34 +#define SRST_I2C3 35 +#define SRST_I2C4_P 36 +#define SRST_I2C4 37 +#define SRST_I2C5_P 38 +#define SRST_I2C5 39 +#define SRST_SPI1_P 40 +#define SRST_SPI1 41 +#define SRST_MCU_CORE 42 +#define SRST_PWM2_P 44 +#define SRST_PWM2 45 +#define SRST_SPINLOCK_A 46 + +/* cru_softrst_con3 */ +#define SRST_UART0_P 48 +#define SRST_UART0 49 +#define SRST_UART2_P 50 +#define SRST_UART2 51 +#define SRST_UART3_P 52 +#define SRST_UART3 53 +#define SRST_UART4_P 54 +#define SRST_UART4 55 +#define SRST_UART5_P 56 +#define SRST_UART5 57 +#define SRST_WDT_P 58 +#define SRST_SARADC_P 59 +#define SRST_GRF_P 61 +#define SRST_TIMER_P 62 +#define SRST_MAILBOX_P 63 + +/* cru_softrst_con4 */ +#define SRST_TIMER0 64 +#define SRST_TIMER1 65 +#define SRST_TIMER2 66 +#define SRST_TIMER3 67 +#define SRST_TIMER4 68 +#define SRST_TIMER5 69 +#define SRST_INTMUX_P 70 +#define SRST_GPIO1_P 72 +#define SRST_GPIO1_DB 73 +#define SRST_GPIO2_P 74 +#define SRST_GPIO2_DB 75 +#define SRST_GPIO3_P 76 +#define SRST_GPIO3_DB 77 +#define SRST_GPIO4_P 78 +#define SRST_GPIO4_DB 79 + +/* cru_softrst_con5 */ +#define SRST_CAN_P 80 +#define SRST_CAN 81 +#define SRST_DECOM_A 85 +#define SRST_DECOM_P 86 +#define SRST_DECOM_D 87 +#define SRST_PDCRYPTO_NIU_A 88 +#define SRST_PDCRYPTO_NIU_H 89 +#define SRST_CRYPTO_A 90 +#define SRST_CRYPTO_H 91 +#define SRST_CRYPTO_CORE 92 +#define SRST_CRYPTO_PKA 93 +#define SRST_SGRF_P 95 + +/* cru_softrst_con6 */ +#define SRST_PDAUDIO_NIU_H 96 +#define SRST_PDAUDIO_NIU_P 97 +#define SRST_I2S0_H 98 +#define SRST_I2S0_TX_M 99 +#define SRST_I2S0_RX_M 100 +#define SRST_I2S1_H 101 +#define SRST_I2S1_M 102 +#define SRST_I2S2_H 103 +#define SRST_I2S2_M 104 +#define SRST_PDM_H 105 +#define SRST_PDM_M 106 +#define SRST_AUDPWM_H 107 +#define SRST_AUDPWM 108 +#define SRST_ACDCDIG_P 109 +#define SRST_ACDCDIG 110 + +/* cru_softrst_con7 */ +#define SRST_PDVEPU_NIU_A 112 +#define SRST_PDVEPU_NIU_H 113 +#define SRST_VENC_A 114 +#define SRST_VENC_H 115 +#define SRST_VENC_CORE 116 +#define SRST_PDVDEC_NIU_A 117 +#define SRST_PDVDEC_NIU_H 118 +#define SRST_VDEC_A 119 +#define SRST_VDEC_H 120 +#define SRST_VDEC_CORE 121 +#define SRST_VDEC_CA 122 +#define SRST_VDEC_HEVC_CA 123 +#define SRST_PDJPEG_NIU_A 124 +#define SRST_PDJPEG_NIU_H 125 +#define SRST_JPEG_A 126 +#define SRST_JPEG_H 127 + +/* cru_softrst_con8 */ +#define SRST_PDVO_NIU_A 128 +#define SRST_PDVO_NIU_H 129 +#define SRST_PDVO_NIU_P 130 +#define SRST_RGA_A 131 +#define SRST_RGA_H 132 +#define SRST_RGA_CORE 133 +#define SRST_VOP_A 134 +#define SRST_VOP_H 135 +#define SRST_VOP_D 136 +#define SRST_TXBYTEHS_DSIHOST 137 +#define SRST_DSIHOST_P 138 +#define SRST_IEP_A 139 +#define SRST_IEP_H 140 +#define SRST_IEP_CORE 141 +#define SRST_ISP_RX_P 142 + +/* cru_softrst_con9 */ +#define SRST_PDVI_NIU_A 144 +#define SRST_PDVI_NIU_H 145 +#define SRST_PDVI_NIU_P 146 +#define SRST_ISP 147 +#define SRST_CIF_A 148 +#define SRST_CIF_H 149 +#define SRST_CIF_D 150 +#define SRST_CIF_P 151 +#define SRST_CIF_I 152 +#define SRST_CIF_RX_P 153 +#define SRST_PDISPP_NIU_A 154 +#define SRST_PDISPP_NIU_H 155 +#define SRST_ISPP_A 156 +#define SRST_ISPP_H 157 +#define SRST_ISPP 158 +#define SRST_CSIHOST_P 159 + +/* cru_softrst_con10 */ +#define SRST_PDPHPMID_NIU_A 160 +#define SRST_PDPHPMID_NIU_H 161 +#define SRST_PDNVM_NIU_H 163 +#define SRST_SDMMC_H 164 +#define SRST_SDIO_H 165 +#define SRST_EMMC_H 166 +#define SRST_SFC_H 167 +#define SRST_SFCXIP_H 168 +#define SRST_SFC 169 +#define SRST_NANDC_H 170 +#define SRST_NANDC 171 +#define SRST_PDSDMMC_H 173 +#define SRST_PDSDIO_H 174 + +/* cru_softrst_con11 */ +#define SRST_PDUSB_NIU_A 176 +#define SRST_PDUSB_NIU_H 177 +#define SRST_USBHOST_H 178 +#define SRST_USBHOST_ARB_H 179 +#define SRST_USBHOST_UTMI 180 +#define SRST_USBOTG_A 181 +#define SRST_USBPHY_OTG_P 182 +#define SRST_USBPHY_HOST_P 183 +#define SRST_USBPHYPOR_OTG 184 +#define SRST_USBPHYPOR_HOST 185 +#define SRST_PDGMAC_NIU_A 188 +#define SRST_PDGMAC_NIU_P 189 +#define SRST_GMAC_A 190 + +/* cru_softrst_con12 */ +#define SRST_DDR_DFICTL_P 193 +#define SRST_DDR_MON_P 194 +#define SRST_DDR_STANDBY_P 195 +#define SRST_DDR_GRF_P 196 +#define SRST_DDR_MSCH_P 197 +#define SRST_DDR_SPLIT_A 198 +#define SRST_DDR_MSCH 199 +#define SRST_DDR_DFICTL 202 +#define SRST_DDR_STANDBY 203 +#define SRST_NPUMCU_NIU 205 +#define SRST_DDRPHY_P 206 +#define SRST_DDRPHY 207 + +/* cru_softrst_con13 */ +#define SRST_PDNPU_NIU_A 208 +#define SRST_PDNPU_NIU_H 209 +#define SRST_PDNPU_NIU_P 210 +#define SRST_NPU_A 211 +#define SRST_NPU_H 212 +#define SRST_NPU 213 +#define SRST_NPUPVTM_P 214 +#define SRST_NPUPVTM 215 +#define SRST_NPU_TSADC_P 216 +#define SRST_NPU_TSADC 217 +#define SRST_NPU_TSADCPHY 218 +#define SRST_CIFLITE_A 220 +#define SRST_CIFLITE_H 221 +#define SRST_CIFLITE_D 222 +#define SRST_CIFLITE_RX_P 223 + +/* cru_softrst_con14 */ +#define SRST_TOPNIU_P 224 +#define SRST_TOPCRU_P 225 +#define SRST_TOPGRF_P 226 +#define SRST_CPUEMADET_P 227 +#define SRST_CSIPHY0_P 228 +#define SRST_CSIPHY1_P 229 +#define SRST_DSIPHY_P 230 +#define SRST_CPU_TSADC_P 232 +#define SRST_CPU_TSADC 233 +#define SRST_CPU_TSADCPHY 234 +#define SRST_CPUPVTM_P 235 +#define SRST_CPUPVTM 236 + +#endif
Thanks, - Kever
Changes for v2:
update cru header
Add clock driver support for Rockchip RV1126 SoC.
Signed-off-by: Joseph Chen chenjh@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - update cru header
drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rv1126.c | 1889 +++++++++++++++++++++++++++++ 2 files changed, 1890 insertions(+) create mode 100644 drivers/clk/rockchip/clk_rv1126.c
diff --git a/drivers/clk/rockchip/Makefile b/drivers/clk/rockchip/Makefile index a72d8fe58a..f719f4e379 100644 --- a/drivers/clk/rockchip/Makefile +++ b/drivers/clk/rockchip/Makefile @@ -17,3 +17,4 @@ obj-$(CONFIG_ROCKCHIP_RK3368) += clk_rk3368.o obj-$(CONFIG_ROCKCHIP_RK3399) += clk_rk3399.o obj-$(CONFIG_ROCKCHIP_RK3568) += clk_rk3568.o obj-$(CONFIG_ROCKCHIP_RV1108) += clk_rv1108.o +obj-$(CONFIG_ROCKCHIP_RV1126) += clk_rv1126.o diff --git a/drivers/clk/rockchip/clk_rv1126.c b/drivers/clk/rockchip/clk_rv1126.c new file mode 100644 index 0000000000..3ed29364de --- /dev/null +++ b/drivers/clk/rockchip/clk_rv1126.c @@ -0,0 +1,1889 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + * Author: Finley Xiao finley.xiao@rock-chips.com + */ + +#include <common.h> +#include <bitfield.h> +#include <clk-uclass.h> +#include <dm.h> +#include <errno.h> +#include <syscon.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/cru_rv1126.h> +#include <asm/arch-rockchip/grf_rv1126.h> +#include <asm/arch-rockchip/hardware.h> +#include <dm/device-internal.h> +#include <asm/io.h> +#include <dm/lists.h> +#include <dt-bindings/clock/rockchip,rv1126-cru.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define RV1126_CPUCLK_RATE(_rate, _aclk_div, _pclk_div) \ +{ \ + .rate = _rate##U, \ + .aclk_div = _aclk_div, \ + .pclk_div = _pclk_div, \ +} + +#define DIV_TO_RATE(input_rate, div) ((input_rate) / ((div) + 1)) + +static struct rockchip_cpu_rate_table rv1126_cpu_rates[] = { + RV1126_CPUCLK_RATE(1200000000, 1, 5), + RV1126_CPUCLK_RATE(1008000000, 1, 5), + RV1126_CPUCLK_RATE(816000000, 1, 3), + RV1126_CPUCLK_RATE(600000000, 1, 3), + RV1126_CPUCLK_RATE(408000000, 1, 1), +}; + +static struct rockchip_pll_rate_table rv1126_pll_rates[] = { + /* _mhz, _refdiv, _fbdiv, _postdiv1, _postdiv2, _dsmpd, _frac */ + RK3036_PLL_RATE(1600000000, 3, 200, 1, 1, 1, 0), + RK3036_PLL_RATE(1400000000, 3, 350, 2, 1, 1, 0), + RK3036_PLL_RATE(1200000000, 1, 100, 2, 1, 1, 0), + RK3036_PLL_RATE(1188000000, 1, 99, 2, 1, 1, 0), + RK3036_PLL_RATE(1100000000, 3, 275, 2, 1, 1, 0), + RK3036_PLL_RATE(1008000000, 1, 84, 2, 1, 1, 0), + RK3036_PLL_RATE(1000000000, 3, 250, 2, 1, 1, 0), + RK3036_PLL_RATE(816000000, 1, 68, 2, 1, 1, 0), + RK3036_PLL_RATE(800000000, 3, 200, 2, 1, 1, 0), + RK3036_PLL_RATE(600000000, 1, 100, 4, 1, 1, 0), + RK3036_PLL_RATE(594000000, 1, 99, 4, 1, 1, 0), + RK3036_PLL_RATE(500000000, 1, 125, 6, 1, 1, 0), + RK3036_PLL_RATE(200000000, 1, 100, 6, 2, 1, 0), + RK3036_PLL_RATE(100000000, 1, 100, 6, 4, 1, 0), + { /* sentinel */ }, +}; + +static struct rockchip_pll_clock rv1126_pll_clks[] = { + [APLL] = PLL(pll_rk3328, PLL_APLL, RV1126_PLL_CON(0), + RV1126_MODE_CON, 0, 10, 0, rv1126_pll_rates), + [DPLL] = PLL(pll_rk3328, PLL_DPLL, RV1126_PLL_CON(8), + RV1126_MODE_CON, 2, 10, 0, NULL), + [CPLL] = PLL(pll_rk3328, PLL_CPLL, RV1126_PLL_CON(16), + RV1126_MODE_CON, 4, 10, 0, rv1126_pll_rates), + [HPLL] = PLL(pll_rk3328, PLL_HPLL, RV1126_PLL_CON(24), + RV1126_MODE_CON, 6, 10, 0, rv1126_pll_rates), + [GPLL] = PLL(pll_rk3328, PLL_GPLL, RV1126_PMU_PLL_CON(0), + RV1126_PMU_MODE, 0, 10, 0, rv1126_pll_rates), +}; + +static ulong rv1126_gpll_set_rate(struct rv1126_clk_priv *priv, + struct rv1126_pmuclk_priv *pmu_priv, + ulong rate); +/* + * + * rational_best_approximation(31415, 10000, + * (1 << 8) - 1, (1 << 5) - 1, &n, &d); + * + * you may look at given_numerator as a fixed point number, + * with the fractional part size described in given_denominator. + * + * for theoretical background, see: + * http://en.wikipedia.org/wiki/Continued_fraction + */ +static void rational_best_approximation(unsigned long given_numerator, + unsigned long given_denominator, + unsigned long max_numerator, + unsigned long max_denominator, + unsigned long *best_numerator, + unsigned long *best_denominator) +{ + unsigned long n, d, n0, d0, n1, d1; + + n = given_numerator; + d = given_denominator; + n0 = 0; + d1 = 0; + n1 = 1; + d0 = 1; + for (;;) { + unsigned long t, a; + + if (n1 > max_numerator || d1 > max_denominator) { + n1 = n0; + d1 = d0; + break; + } + if (d == 0) + break; + t = d; + a = n / d; + d = n % d; + n = t; + t = n0 + a * n1; + n0 = n1; + n1 = t; + t = d0 + a * d1; + d0 = d1; + d1 = t; + } + *best_numerator = n1; + *best_denominator = d1; +} + +static ulong rv1126_gpll_get_pmuclk(struct rv1126_pmuclk_priv *priv) +{ + return rockchip_pll_get_rate(&rv1126_pll_clks[GPLL], + priv->pmucru, GPLL); +} + +static ulong rv1126_gpll_set_pmuclk(struct rv1126_pmuclk_priv *pmu_priv, ulong rate) +{ + struct udevice *cru_dev; + struct rv1126_clk_priv *priv; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(rockchip_rv1126_cru), + &cru_dev); + if (ret) { + printf("%s: could not find cru device\n", __func__); + return ret; + } + priv = dev_get_priv(cru_dev); + + if (rv1126_gpll_set_rate(priv, pmu_priv, rate)) { + printf("%s: failed to set gpll rate %lu\n", __func__, rate); + return -EINVAL; + } + return 0; +} + +static ulong rv1126_rtc32k_get_pmuclk(struct rv1126_pmuclk_priv *priv) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + unsigned long m, n; + u32 fracdiv; + + fracdiv = readl(&pmucru->pmu_clksel_con[13]); + m = fracdiv & CLK_RTC32K_FRAC_NUMERATOR_MASK; + m >>= CLK_RTC32K_FRAC_NUMERATOR_SHIFT; + n = fracdiv & CLK_RTC32K_FRAC_DENOMINATOR_MASK; + n >>= CLK_RTC32K_FRAC_DENOMINATOR_SHIFT; + + return OSC_HZ * m / n; +} + +static ulong rv1126_rtc32k_set_pmuclk(struct rv1126_pmuclk_priv *priv, + ulong rate) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + unsigned long m, n, val; + + rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK, + RTC32K_SEL_OSC0_DIV32K << RTC32K_SEL_SHIFT); + + rational_best_approximation(rate, OSC_HZ, + GENMASK(16 - 1, 0), + GENMASK(16 - 1, 0), + &m, &n); + val = m << CLK_RTC32K_FRAC_NUMERATOR_SHIFT | n; + writel(val, &pmucru->pmu_clksel_con[13]); + + return rv1126_rtc32k_get_pmuclk(priv); +} + +static ulong rv1126_i2c_get_pmuclk(struct rv1126_pmuclk_priv *priv, + ulong clk_id) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + u32 div, con; + + switch (clk_id) { + case CLK_I2C0: + con = readl(&pmucru->pmu_clksel_con[2]); + div = (con & CLK_I2C0_DIV_MASK) >> CLK_I2C0_DIV_SHIFT; + break; + case CLK_I2C2: + con = readl(&pmucru->pmu_clksel_con[3]); + div = (con & CLK_I2C1_DIV_MASK) >> CLK_I2C1_DIV_SHIFT; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_i2c_set_pmuclk(struct rv1126_pmuclk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + + switch (clk_id) { + case CLK_I2C0: + rk_clrsetreg(&pmucru->pmu_clksel_con[2], CLK_I2C0_DIV_MASK, + (src_clk_div - 1) << CLK_I2C0_DIV_SHIFT); + break; + case CLK_I2C2: + rk_clrsetreg(&pmucru->pmu_clksel_con[3], CLK_I2C2_DIV_MASK, + (src_clk_div - 1) << CLK_I2C2_DIV_SHIFT); + break; + default: + return -ENOENT; + } + + return rv1126_i2c_get_pmuclk(priv, clk_id); +} + +static ulong rv1126_pwm_get_pmuclk(struct rv1126_pmuclk_priv *priv, + ulong clk_id) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + u32 div, sel, con; + + switch (clk_id) { + case CLK_PWM0: + con = readl(&pmucru->pmu_clksel_con[6]); + sel = (con & CLK_PWM0_SEL_MASK) >> CLK_PWM0_SEL_SHIFT; + div = (con & CLK_PWM0_DIV_MASK) >> CLK_PWM0_DIV_SHIFT; + if (sel == CLK_PWM0_SEL_XIN24M) + return OSC_HZ; + break; + case CLK_PWM1: + con = readl(&pmucru->pmu_clksel_con[6]); + sel = (con & CLK_PWM1_SEL_MASK) >> CLK_PWM1_SEL_SHIFT; + div = (con & CLK_PWM1_DIV_MASK) >> CLK_PWM1_DIV_SHIFT; + if (sel == CLK_PWM1_SEL_XIN24M) + return OSC_HZ; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_pwm_set_pmuclk(struct rv1126_pmuclk_priv *priv, + ulong clk_id, ulong rate) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + int src_clk_div; + + switch (clk_id) { + case CLK_PWM0: + if (rate == OSC_HZ) { + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM0_SEL_MASK, + CLK_PWM0_SEL_XIN24M << CLK_PWM0_SEL_SHIFT); + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM0_DIV_MASK, 0); + } else { + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM0_DIV_MASK, + (src_clk_div - 1) << CLK_PWM0_DIV_SHIFT); + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM0_SEL_MASK, + CLK_PWM0_SEL_GPLL << CLK_PWM0_SEL_SHIFT); + } + break; + case CLK_PWM1: + if (rate == OSC_HZ) { + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM1_SEL_MASK, + CLK_PWM1_SEL_XIN24M << CLK_PWM1_SEL_SHIFT); + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM1_DIV_MASK, 0); + } else { + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM1_DIV_MASK, + (src_clk_div - 1) << CLK_PWM1_DIV_SHIFT); + rk_clrsetreg(&pmucru->pmu_clksel_con[6], + CLK_PWM1_SEL_MASK, + CLK_PWM1_SEL_GPLL << CLK_PWM1_SEL_SHIFT); + } + break; + default: + return -ENOENT; + } + + return rv1126_pwm_get_pmuclk(priv, clk_id); +} + +static ulong rv1126_spi_get_pmuclk(struct rv1126_pmuclk_priv *priv) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + u32 div, con; + + con = readl(&pmucru->pmu_clksel_con[9]); + div = (con & CLK_SPI0_DIV_MASK) >> CLK_SPI0_DIV_SHIFT; + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_spi_set_pmuclk(struct rv1126_pmuclk_priv *priv, + ulong rate) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + + rk_clrsetreg(&pmucru->pmu_clksel_con[9], + CLK_SPI0_SEL_MASK | CLK_SPI0_DIV_MASK, + CLK_SPI0_SEL_GPLL << CLK_SPI0_SEL_SHIFT | + (src_clk_div - 1) << CLK_SPI0_DIV_SHIFT); + + return rv1126_spi_get_pmuclk(priv); +} + +static ulong rv1126_pdpmu_get_pmuclk(struct rv1126_pmuclk_priv *priv) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + u32 div, con; + + con = readl(&pmucru->pmu_clksel_con[1]); + div = (con & PCLK_PDPMU_DIV_MASK) >> PCLK_PDPMU_DIV_SHIFT; + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_pdpmu_set_pmuclk(struct rv1126_pmuclk_priv *priv, + ulong rate) +{ + struct rv1126_pmucru *pmucru = priv->pmucru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + + rk_clrsetreg(&pmucru->pmu_clksel_con[1], + PCLK_PDPMU_DIV_MASK, + (src_clk_div - 1) << PCLK_PDPMU_DIV_SHIFT); + + return rv1126_pdpmu_get_pmuclk(priv); +} + +static ulong rv1126_pmuclk_get_rate(struct clk *clk) +{ + struct rv1126_pmuclk_priv *priv = dev_get_priv(clk->dev); + ulong rate = 0; + + if (!priv->gpll_hz) { + printf("%s gpll=%lu\n", __func__, priv->gpll_hz); + return -ENOENT; + } + + debug("%s %ld\n", __func__, clk->id); + switch (clk->id) { + case PLL_GPLL: + rate = rv1126_gpll_get_pmuclk(priv); + break; + case CLK_RTC32K: + rate = rv1126_rtc32k_get_pmuclk(priv); + break; + case CLK_I2C0: + case CLK_I2C2: + rate = rv1126_i2c_get_pmuclk(priv, clk->id); + break; + case CLK_PWM0: + case CLK_PWM1: + rate = rv1126_pwm_get_pmuclk(priv, clk->id); + break; + case CLK_SPI0: + rate = rv1126_spi_get_pmuclk(priv); + break; + case PCLK_PDPMU: + rate = rv1126_pdpmu_get_pmuclk(priv); + break; + default: + debug("%s: Unsupported CLK#%ld\n", __func__, clk->id); + return -ENOENT; + } + + return rate; +} + +static ulong rv1126_pmuclk_set_rate(struct clk *clk, ulong rate) +{ + struct rv1126_pmuclk_priv *priv = dev_get_priv(clk->dev); + ulong ret = 0; + + if (!priv->gpll_hz) { + printf("%s gpll=%lu\n", __func__, priv->gpll_hz); + return -ENOENT; + } + + debug("%s %ld %ld\n", __func__, clk->id, rate); + switch (clk->id) { + case PLL_GPLL: + ret = rv1126_gpll_set_pmuclk(priv, rate); + break; + case CLK_RTC32K: + ret = rv1126_rtc32k_set_pmuclk(priv, rate); + break; + case CLK_I2C0: + case CLK_I2C2: + ret = rv1126_i2c_set_pmuclk(priv, clk->id, rate); + break; + case CLK_PWM0: + case CLK_PWM1: + ret = rv1126_pwm_set_pmuclk(priv, clk->id, rate); + break; + case CLK_SPI0: + ret = rv1126_spi_set_pmuclk(priv, rate); + break; + case PCLK_PDPMU: + ret = rv1126_pdpmu_set_pmuclk(priv, rate); + break; + default: + debug("%s: Unsupported CLK#%ld\n", __func__, clk->id); + return -ENOENT; + } + + return ret; +} + +static int rv1126_rtc32k_set_parent(struct clk *clk, struct clk *parent) +{ + struct rv1126_pmuclk_priv *priv = dev_get_priv(clk->dev); + struct rv1126_pmucru *pmucru = priv->pmucru; + + if (parent->id == CLK_OSC0_DIV32K) + rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK, + RTC32K_SEL_OSC0_DIV32K << RTC32K_SEL_SHIFT); + else + rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK, + RTC32K_SEL_OSC1_32K << RTC32K_SEL_SHIFT); + + return 0; +} + +static int rv1126_pmuclk_set_parent(struct clk *clk, struct clk *parent) +{ + switch (clk->id) { + case CLK_RTC32K: + return rv1126_rtc32k_set_parent(clk, parent); + default: + debug("%s: Unsupported CLK#%ld\n", __func__, clk->id); + return -ENOENT; + } +} + +static struct clk_ops rv1126_pmuclk_ops = { + .get_rate = rv1126_pmuclk_get_rate, + .set_rate = rv1126_pmuclk_set_rate, + .set_parent = rv1126_pmuclk_set_parent, +}; + +static int rv1126_pmuclk_probe(struct udevice *dev) +{ + struct rv1126_pmuclk_priv *priv = dev_get_priv(dev); + + priv->gpll_hz = rv1126_gpll_get_pmuclk(priv); + + return 0; +} + +static int rv1126_pmuclk_of_to_plat(struct udevice *dev) +{ + struct rv1126_pmuclk_priv *priv = dev_get_priv(dev); + + priv->pmucru = dev_read_addr_ptr(dev); + + return 0; +} + +static int rv1126_pmuclk_bind(struct udevice *dev) +{ +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) + int ret; + + ret = offsetof(struct rv1126_pmucru, pmu_softrst_con[0]); + ret = rockchip_reset_bind(dev, ret, 2); + if (ret) + debug("Warning: software reset driver bind faile\n"); +#endif + return 0; +} + +static const struct udevice_id rv1126_pmuclk_ids[] = { + { .compatible = "rockchip,rv1126-pmucru" }, + { } +}; + +U_BOOT_DRIVER(rockchip_rv1126_pmucru) = { + .name = "rockchip_rv1126_pmucru", + .id = UCLASS_CLK, + .of_match = rv1126_pmuclk_ids, + .priv_auto = sizeof(struct rv1126_pmuclk_priv), + .of_to_plat = rv1126_pmuclk_of_to_plat, + .ops = &rv1126_pmuclk_ops, + .bind = rv1126_pmuclk_bind, + .probe = rv1126_pmuclk_probe, +}; + +static int rv1126_armclk_set_clk(struct rv1126_clk_priv *priv, ulong hz) +{ + struct rv1126_cru *cru = priv->cru; + const struct rockchip_cpu_rate_table *rate; + ulong old_rate; + + rate = rockchip_get_cpu_settings(rv1126_cpu_rates, hz); + if (!rate) { + printf("%s unsupported rate\n", __func__); + return -EINVAL; + } + + /* + * set up dependent divisors for DBG and ACLK clocks. + */ + old_rate = rockchip_pll_get_rate(&rv1126_pll_clks[APLL], + priv->cru, APLL); + if (old_rate > hz) { + if (rockchip_pll_set_rate(&rv1126_pll_clks[APLL], + priv->cru, APLL, hz)) + return -EINVAL; + rk_clrsetreg(&cru->clksel_con[1], + CORE_DBG_DIV_MASK | CORE_ACLK_DIV_MASK, + rate->pclk_div << CORE_DBG_DIV_SHIFT | + rate->aclk_div << CORE_ACLK_DIV_SHIFT); + } else if (old_rate < hz) { + rk_clrsetreg(&cru->clksel_con[1], + CORE_DBG_DIV_MASK | CORE_ACLK_DIV_MASK, + rate->pclk_div << CORE_DBG_DIV_SHIFT | + rate->aclk_div << CORE_ACLK_DIV_SHIFT); + if (rockchip_pll_set_rate(&rv1126_pll_clks[APLL], + priv->cru, APLL, hz)) + return -EINVAL; + } + + return 0; +} + +static ulong rv1126_pdcore_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 con, div; + + con = readl(&cru->clksel_con[0]); + div = (con & CORE_HCLK_DIV_MASK) >> CORE_HCLK_DIV_SHIFT; + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_pdcore_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + + rk_clrsetreg(&cru->clksel_con[0], CORE_HCLK_DIV_MASK, + (src_clk_div - 1) << CORE_HCLK_DIV_SHIFT); + + return rv1126_pdcore_get_clk(priv); +} + +static ulong rv1126_pdbus_get_clk(struct rv1126_clk_priv *priv, ulong clk_id) +{ + struct rv1126_cru *cru = priv->cru; + u32 con, div, sel, parent; + + switch (clk_id) { + case ACLK_PDBUS: + con = readl(&cru->clksel_con[2]); + div = (con & ACLK_PDBUS_DIV_MASK) >> ACLK_PDBUS_DIV_SHIFT; + sel = (con & ACLK_PDBUS_SEL_MASK) >> ACLK_PDBUS_SEL_SHIFT; + if (sel == ACLK_PDBUS_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == ACLK_PDBUS_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + break; + case HCLK_PDBUS: + con = readl(&cru->clksel_con[2]); + div = (con & HCLK_PDBUS_DIV_MASK) >> HCLK_PDBUS_DIV_SHIFT; + sel = (con & HCLK_PDBUS_SEL_MASK) >> HCLK_PDBUS_SEL_SHIFT; + if (sel == HCLK_PDBUS_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == HCLK_PDBUS_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + break; + case PCLK_PDBUS: + case PCLK_WDT: + con = readl(&cru->clksel_con[3]); + div = (con & PCLK_PDBUS_DIV_MASK) >> PCLK_PDBUS_DIV_SHIFT; + sel = (con & PCLK_PDBUS_SEL_MASK) >> PCLK_PDBUS_SEL_SHIFT; + if (sel == PCLK_PDBUS_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == PCLK_PDBUS_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_pdbus_set_clk(struct rv1126_clk_priv *priv, ulong clk_id, + ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div, clk_sel; + + switch (clk_id) { + case ACLK_PDBUS: + if (CPLL_HZ % rate) { + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + clk_sel = ACLK_PDBUS_SEL_GPLL; + } else { + src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate); + clk_sel = ACLK_PDBUS_SEL_CPLL; + } + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[2], + ACLK_PDBUS_SEL_MASK | ACLK_PDBUS_DIV_MASK, + clk_sel << ACLK_PDBUS_SEL_SHIFT | + (src_clk_div - 1) << ACLK_PDBUS_DIV_SHIFT); + break; + case HCLK_PDBUS: + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[2], + HCLK_PDBUS_SEL_MASK | HCLK_PDBUS_DIV_MASK, + HCLK_PDBUS_SEL_GPLL << HCLK_PDBUS_SEL_SHIFT | + (src_clk_div - 1) << HCLK_PDBUS_DIV_SHIFT); + break; + case PCLK_PDBUS: + case PCLK_WDT: + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[3], + PCLK_PDBUS_SEL_MASK | PCLK_PDBUS_DIV_MASK, + PCLK_PDBUS_SEL_GPLL << PCLK_PDBUS_SEL_SHIFT | + (src_clk_div - 1) << PCLK_PDBUS_DIV_SHIFT); + break; + + default: + printf("do not support this pdbus freq\n"); + return -EINVAL; + } + + return rv1126_pdbus_get_clk(priv, clk_id); +} + +static ulong rv1126_pdphp_get_clk(struct rv1126_clk_priv *priv, ulong clk_id) +{ + struct rv1126_cru *cru = priv->cru; + u32 con, div, parent; + + switch (clk_id) { + case ACLK_PDPHP: + con = readl(&cru->clksel_con[53]); + div = (con & ACLK_PDPHP_DIV_MASK) >> ACLK_PDPHP_DIV_SHIFT; + parent = priv->gpll_hz; + break; + case HCLK_PDPHP: + con = readl(&cru->clksel_con[53]); + div = (con & HCLK_PDPHP_DIV_MASK) >> HCLK_PDPHP_DIV_SHIFT; + parent = priv->gpll_hz; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_pdphp_set_clk(struct rv1126_clk_priv *priv, ulong clk_id, + ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + + switch (clk_id) { + case ACLK_PDPHP: + rk_clrsetreg(&cru->clksel_con[53], + ACLK_PDPHP_SEL_MASK | ACLK_PDPHP_DIV_MASK, + ACLK_PDPHP_SEL_GPLL << ACLK_PDPHP_SEL_SHIFT | + (src_clk_div - 1) << ACLK_PDPHP_DIV_SHIFT); + break; + case HCLK_PDPHP: + rk_clrsetreg(&cru->clksel_con[53], + HCLK_PDPHP_DIV_MASK, + (src_clk_div - 1) << HCLK_PDPHP_DIV_SHIFT); + break; + default: + printf("do not support this pdphp freq\n"); + return -EINVAL; + } + + return rv1126_pdphp_get_clk(priv, clk_id); +} + +static ulong rv1126_pdaudio_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 con, div; + + con = readl(&cru->clksel_con[26]); + div = (con & HCLK_PDAUDIO_DIV_MASK) >> HCLK_PDAUDIO_DIV_SHIFT; + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_pdaudio_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + + rk_clrsetreg(&cru->clksel_con[26], HCLK_PDAUDIO_DIV_MASK, + (src_clk_div - 1) << HCLK_PDAUDIO_DIV_SHIFT); + + return rv1126_pdaudio_get_clk(priv); +} + +static ulong rv1126_i2c_get_clk(struct rv1126_clk_priv *priv, ulong clk_id) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, con; + + switch (clk_id) { + case CLK_I2C1: + con = readl(&cru->clksel_con[5]); + div = (con & CLK_I2C1_DIV_MASK) >> CLK_I2C1_DIV_SHIFT; + break; + case CLK_I2C3: + con = readl(&cru->clksel_con[5]); + div = (con & CLK_I2C3_DIV_MASK) >> CLK_I2C3_DIV_SHIFT; + break; + case CLK_I2C4: + con = readl(&cru->clksel_con[6]); + div = (con & CLK_I2C4_DIV_MASK) >> CLK_I2C4_DIV_SHIFT; + break; + case CLK_I2C5: + con = readl(&cru->clksel_con[6]); + div = (con & CLK_I2C5_DIV_MASK) >> CLK_I2C5_DIV_SHIFT; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_i2c_set_clk(struct rv1126_clk_priv *priv, ulong clk_id, + ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + + switch (clk_id) { + case CLK_I2C1: + rk_clrsetreg(&cru->clksel_con[5], CLK_I2C1_DIV_MASK, + (src_clk_div - 1) << CLK_I2C1_DIV_SHIFT); + break; + case CLK_I2C3: + rk_clrsetreg(&cru->clksel_con[5], CLK_I2C3_DIV_MASK, + (src_clk_div - 1) << CLK_I2C3_DIV_SHIFT); + break; + case CLK_I2C4: + rk_clrsetreg(&cru->clksel_con[6], CLK_I2C4_DIV_MASK, + (src_clk_div - 1) << CLK_I2C4_DIV_SHIFT); + break; + case CLK_I2C5: + rk_clrsetreg(&cru->clksel_con[6], CLK_I2C5_DIV_MASK, + (src_clk_div - 1) << CLK_I2C5_DIV_SHIFT); + break; + default: + return -ENOENT; + } + + return rv1126_i2c_get_clk(priv, clk_id); +} + +static ulong rv1126_spi_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, con; + + con = readl(&cru->clksel_con[8]); + div = (con & CLK_SPI1_DIV_MASK) >> CLK_SPI1_DIV_SHIFT; + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_spi_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + + rk_clrsetreg(&cru->clksel_con[8], + CLK_SPI1_SEL_MASK | CLK_SPI1_DIV_MASK, + CLK_SPI1_SEL_GPLL << CLK_SPI1_SEL_SHIFT | + (src_clk_div - 1) << CLK_SPI1_DIV_SHIFT); + + return rv1126_spi_get_clk(priv); +} + +static ulong rv1126_pwm_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con; + + con = readl(&cru->clksel_con[9]); + sel = (con & CLK_PWM2_SEL_MASK) >> CLK_PWM2_SEL_SHIFT; + div = (con & CLK_PWM2_DIV_MASK) >> CLK_PWM2_DIV_SHIFT; + if (sel == CLK_PWM2_SEL_XIN24M) + return OSC_HZ; + + return DIV_TO_RATE(priv->gpll_hz, div); +} + +static ulong rv1126_pwm_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + if (rate == OSC_HZ) { + rk_clrsetreg(&cru->clksel_con[9], CLK_PWM2_SEL_MASK, + CLK_PWM2_SEL_XIN24M << CLK_PWM2_SEL_SHIFT); + rk_clrsetreg(&cru->clksel_con[9], CLK_PWM2_DIV_MASK, 0); + } else { + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + rk_clrsetreg(&cru->clksel_con[9], CLK_PWM2_DIV_MASK, + (src_clk_div - 1) << CLK_PWM2_DIV_SHIFT); + rk_clrsetreg(&cru->clksel_con[9], CLK_PWM2_SEL_MASK, + CLK_PWM2_SEL_GPLL << CLK_PWM2_SEL_SHIFT); + } + + return rv1126_pwm_get_clk(priv); +} + +static ulong rv1126_saradc_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, con; + + con = readl(&cru->clksel_con[20]); + div = (con & CLK_SARADC_DIV_MASK) >> CLK_SARADC_DIV_SHIFT; + + return DIV_TO_RATE(OSC_HZ, div); +} + +static ulong rv1126_saradc_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(OSC_HZ, rate); + assert(src_clk_div - 1 <= 2047); + rk_clrsetreg(&cru->clksel_con[20], CLK_SARADC_DIV_MASK, + (src_clk_div - 1) << CLK_SARADC_DIV_SHIFT); + + return rv1126_saradc_get_clk(priv); +} + +static ulong rv1126_crypto_get_clk(struct rv1126_clk_priv *priv, ulong clk_id) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + switch (clk_id) { + case CLK_CRYPTO_CORE: + con = readl(&cru->clksel_con[7]); + div = (con & CLK_CRYPTO_CORE_DIV_MASK) >> CLK_CRYPTO_CORE_DIV_SHIFT; + sel = (con & CLK_CRYPTO_CORE_SEL_MASK) >> CLK_CRYPTO_CORE_SEL_SHIFT; + if (sel == CLK_CRYPTO_CORE_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == CLK_CRYPTO_CORE_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + break; + case CLK_CRYPTO_PKA: + con = readl(&cru->clksel_con[7]); + div = (con & CLK_CRYPTO_PKA_DIV_MASK) >> CLK_CRYPTO_PKA_DIV_SHIFT; + sel = (con & CLK_CRYPTO_PKA_SEL_MASK) >> CLK_CRYPTO_PKA_SEL_SHIFT; + if (sel == CLK_CRYPTO_PKA_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == CLK_CRYPTO_PKA_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + break; + case ACLK_CRYPTO: + con = readl(&cru->clksel_con[4]); + div = (con & ACLK_CRYPTO_DIV_MASK) >> ACLK_CRYPTO_DIV_SHIFT; + sel = (con & ACLK_CRYPTO_SEL_MASK) >> ACLK_CRYPTO_SEL_SHIFT; + if (sel == ACLK_CRYPTO_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == ACLK_CRYPTO_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + break; + default: + return -ENOENT; + } + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_crypto_set_clk(struct rv1126_clk_priv *priv, ulong clk_id, + ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + + switch (clk_id) { + case CLK_CRYPTO_CORE: + rk_clrsetreg(&cru->clksel_con[7], + CLK_CRYPTO_CORE_SEL_MASK | + CLK_CRYPTO_CORE_DIV_MASK, + CLK_CRYPTO_CORE_SEL_GPLL << + CLK_CRYPTO_CORE_SEL_SHIFT | + (src_clk_div - 1) << CLK_CRYPTO_CORE_DIV_SHIFT); + break; + case CLK_CRYPTO_PKA: + rk_clrsetreg(&cru->clksel_con[7], + CLK_CRYPTO_PKA_SEL_MASK | + CLK_CRYPTO_PKA_DIV_MASK, + CLK_CRYPTO_PKA_SEL_GPLL << + CLK_CRYPTO_PKA_SEL_SHIFT | + (src_clk_div - 1) << CLK_CRYPTO_PKA_DIV_SHIFT); + break; + case ACLK_CRYPTO: + rk_clrsetreg(&cru->clksel_con[4], + ACLK_CRYPTO_SEL_MASK | ACLK_CRYPTO_DIV_MASK, + ACLK_CRYPTO_SEL_GPLL << ACLK_CRYPTO_SEL_SHIFT | + (src_clk_div - 1) << ACLK_CRYPTO_DIV_SHIFT); + break; + default: + return -ENOENT; + } + + return rv1126_crypto_get_clk(priv, clk_id); +} + +static ulong rv1126_mmc_get_clk(struct rv1126_clk_priv *priv, ulong clk_id) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, con_id; + + switch (clk_id) { + case HCLK_SDMMC: + case CLK_SDMMC: + con_id = 55; + break; + case HCLK_SDIO: + case CLK_SDIO: + con_id = 56; + break; + case HCLK_EMMC: + case CLK_EMMC: + case SCLK_EMMC_SAMPLE: + con_id = 57; + break; + default: + return -ENOENT; + } + + con = readl(&cru->clksel_con[con_id]); + div = (con & EMMC_DIV_MASK) >> EMMC_DIV_SHIFT; + sel = (con & EMMC_SEL_MASK) >> EMMC_SEL_SHIFT; + if (sel == EMMC_SEL_GPLL) + return DIV_TO_RATE(priv->gpll_hz, div) / 2; + else if (sel == EMMC_SEL_CPLL) + return DIV_TO_RATE(priv->cpll_hz, div) / 2; + else if (sel == EMMC_SEL_XIN24M) + return DIV_TO_RATE(OSC_HZ, div) / 2; + + return -ENOENT; +} + +static ulong rv1126_mmc_set_clk(struct rv1126_clk_priv *priv, ulong clk_id, + ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + u32 con_id; + + switch (clk_id) { + case HCLK_SDMMC: + case CLK_SDMMC: + con_id = 55; + break; + case HCLK_SDIO: + case CLK_SDIO: + con_id = 56; + break; + case HCLK_EMMC: + case CLK_EMMC: + con_id = 57; + break; + default: + return -ENOENT; + } + + /* Select clk_sdmmc/emmc source from GPLL by default */ + /* mmc clock defaulg div 2 internal, need provide double in cru */ + src_clk_div = DIV_ROUND_UP(priv->gpll_hz / 2, rate); + + if (src_clk_div > 127) { + /* use 24MHz source for 400KHz clock */ + src_clk_div = DIV_ROUND_UP(OSC_HZ / 2, rate); + rk_clrsetreg(&cru->clksel_con[con_id], + EMMC_SEL_MASK | EMMC_DIV_MASK, + EMMC_SEL_XIN24M << EMMC_SEL_SHIFT | + (src_clk_div - 1) << EMMC_DIV_SHIFT); + } else { + rk_clrsetreg(&cru->clksel_con[con_id], + EMMC_SEL_MASK | EMMC_DIV_MASK, + EMMC_SEL_GPLL << EMMC_SEL_SHIFT | + (src_clk_div - 1) << EMMC_DIV_SHIFT); + } + + return rv1126_mmc_get_clk(priv, clk_id); +} + +static ulong rv1126_sfc_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[58]); + div = (con & SCLK_SFC_DIV_MASK) >> SCLK_SFC_DIV_SHIFT; + sel = (con & SCLK_SFC_SEL_MASK) >> SCLK_SFC_SEL_SHIFT; + if (sel == SCLK_SFC_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == SCLK_SFC_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_sfc_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + rk_clrsetreg(&cru->clksel_con[58], + SCLK_SFC_SEL_MASK | SCLK_SFC_DIV_MASK, + SCLK_SFC_SEL_GPLL << SCLK_SFC_SEL_SHIFT | + (src_clk_div - 1) << SCLK_SFC_DIV_SHIFT); + + return rv1126_sfc_get_clk(priv); +} + +static ulong rv1126_nand_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[59]); + div = (con & CLK_NANDC_DIV_MASK) >> CLK_NANDC_DIV_SHIFT; + sel = (con & CLK_NANDC_SEL_MASK) >> CLK_NANDC_SEL_SHIFT; + if (sel == CLK_NANDC_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == CLK_NANDC_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_nand_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + rk_clrsetreg(&cru->clksel_con[59], + CLK_NANDC_SEL_MASK | CLK_NANDC_DIV_MASK, + CLK_NANDC_SEL_GPLL << CLK_NANDC_SEL_SHIFT | + (src_clk_div - 1) << CLK_NANDC_DIV_SHIFT); + + return rv1126_nand_get_clk(priv); +} + +static ulong rv1126_aclk_vop_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[45]); + div = (con & ACLK_PDVO_DIV_MASK) >> ACLK_PDVO_DIV_SHIFT; + sel = (con & ACLK_PDVO_SEL_MASK) >> ACLK_PDVO_SEL_SHIFT; + if (sel == ACLK_PDVO_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == ACLK_PDVO_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_aclk_vop_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[45], + ACLK_PDVO_SEL_MASK | ACLK_PDVO_DIV_MASK, + ACLK_PDVO_SEL_GPLL << ACLK_PDVO_SEL_SHIFT | + (src_clk_div - 1) << ACLK_PDVO_DIV_SHIFT); + + return rv1126_aclk_vop_get_clk(priv); +} + +static ulong rv1126_dclk_vop_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[47]); + div = (con & DCLK_VOP_DIV_MASK) >> DCLK_VOP_DIV_SHIFT; + sel = (con & DCLK_VOP_SEL_MASK) >> DCLK_VOP_SEL_SHIFT; + if (sel == DCLK_VOP_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == DCLK_VOP_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_dclk_vop_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + ulong pll_rate, now, best_rate = 0; + u32 i, div, best_div = 0, best_sel = 0; + + for (i = 0; i <= DCLK_VOP_SEL_CPLL; i++) { + switch (i) { + case DCLK_VOP_SEL_GPLL: + pll_rate = priv->gpll_hz; + break; + case DCLK_VOP_SEL_CPLL: + pll_rate = priv->cpll_hz; + break; + default: + printf("do not support this vop pll sel\n"); + return -EINVAL; + } + + div = DIV_ROUND_UP(pll_rate, rate); + if (div > 255) + continue; + now = pll_rate / div; + if (abs(rate - now) < abs(rate - best_rate)) { + best_rate = now; + best_div = div; + best_sel = i; + } + debug("pll_rate=%lu, best_rate=%lu, best_div=%u, best_sel=%u\n", + pll_rate, best_rate, best_div, best_sel); + } + + if (best_rate) { + rk_clrsetreg(&cru->clksel_con[47], + DCLK_VOP_SEL_MASK | DCLK_VOP_DIV_MASK, + best_sel << DCLK_VOP_SEL_SHIFT | + (best_div - 1) << DCLK_VOP_DIV_SHIFT); + } else { + printf("do not support this vop freq %lu\n", rate); + return -EINVAL; + } + + return rv1126_dclk_vop_get_clk(priv); +} + +static ulong rv1126_scr1_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[3]); + div = (con & CLK_SCR1_DIV_MASK) >> CLK_SCR1_DIV_SHIFT; + sel = (con & CLK_SCR1_SEL_MASK) >> CLK_SCR1_SEL_SHIFT; + if (sel == CLK_SCR1_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == CLK_SCR1_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_scr1_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[3], + CLK_SCR1_SEL_MASK | CLK_SCR1_DIV_MASK, + CLK_SCR1_SEL_GPLL << CLK_SCR1_SEL_SHIFT | + (src_clk_div - 1) << CLK_SCR1_DIV_SHIFT); + + return rv1126_scr1_get_clk(priv); +} + +static ulong rv1126_gmac_src_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[63]); + div = (con & CLK_GMAC_SRC_DIV_MASK) >> CLK_GMAC_SRC_DIV_SHIFT; + sel = (con & CLK_GMAC_SRC_SEL_MASK) >> CLK_GMAC_SRC_SEL_SHIFT; + if (sel == CLK_GMAC_SRC_SEL_CPLL) + parent = priv->cpll_hz; + else if (sel == CLK_GMAC_SRC_SEL_GPLL) + parent = priv->gpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_gmac_src_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[63], + CLK_GMAC_SRC_SEL_MASK | CLK_GMAC_SRC_DIV_MASK, + CLK_GMAC_SRC_SEL_CPLL << CLK_GMAC_SRC_SEL_SHIFT | + (src_clk_div - 1) << CLK_GMAC_SRC_DIV_SHIFT); + + return rv1126_gmac_src_get_clk(priv); +} + +static ulong rv1126_gmac_out_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[61]); + div = (con & CLK_GMAC_OUT_DIV_MASK) >> CLK_GMAC_OUT_DIV_SHIFT; + sel = (con & CLK_GMAC_OUT_SEL_MASK) >> CLK_GMAC_OUT_SEL_SHIFT; + if (sel == CLK_GMAC_OUT_SEL_CPLL) + parent = priv->cpll_hz; + else if (sel == CLK_GMAC_OUT_SEL_GPLL) + parent = priv->gpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_gmac_out_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + int src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate); + assert(src_clk_div - 1 <= 31); + rk_clrsetreg(&cru->clksel_con[61], + CLK_GMAC_OUT_SEL_MASK | CLK_GMAC_OUT_DIV_MASK, + CLK_GMAC_OUT_SEL_CPLL << CLK_GMAC_OUT_SEL_SHIFT | + (src_clk_div - 1) << CLK_GMAC_OUT_DIV_SHIFT); + + return rv1126_gmac_out_get_clk(priv); +} + +static ulong rv1126_gmac_tx_rx_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + u32 con, sel, div_sel; + + con = readl(&cru->gmac_con); + sel = (con & GMAC_MODE_SEL_MASK) >> GMAC_MODE_SEL_SHIFT; + + if (sel == GMAC_RGMII_MODE) { + if (rate == 2500000) + div_sel = RGMII_CLK_DIV50; + else if (rate == 25000000) + div_sel = RGMII_CLK_DIV5; + else + div_sel = RGMII_CLK_DIV0; + rk_clrsetreg(&cru->gmac_con, RGMII_CLK_SEL_MASK, + div_sel << RGMII_CLK_SEL_SHIFT); + } else if (sel == GMAC_RMII_MODE) { + if (rate == 2500000) + div_sel = RMII_CLK_DIV20; + else + div_sel = RMII_CLK_DIV2; + rk_clrsetreg(&cru->gmac_con, RMII_CLK_SEL_MASK, + div_sel << RMII_CLK_SEL_SHIFT); + } + + return 0; +} + +static ulong rv1126_pclk_gmac_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, con, parent; + + parent = rv1126_pdphp_get_clk(priv, ACLK_PDPHP); + + con = readl(&cru->clksel_con[63]); + div = (con & PCLK_GMAC_DIV_MASK) >> PCLK_GMAC_DIV_SHIFT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_dclk_decom_get_clk(struct rv1126_clk_priv *priv) +{ + struct rv1126_cru *cru = priv->cru; + u32 div, sel, con, parent; + + con = readl(&cru->clksel_con[25]); + div = (con & DCLK_DECOM_DIV_MASK) >> DCLK_DECOM_DIV_SHIFT; + sel = (con & DCLK_DECOM_SEL_MASK) >> DCLK_DECOM_SEL_SHIFT; + if (sel == DCLK_DECOM_SEL_GPLL) + parent = priv->gpll_hz; + else if (sel == DCLK_DECOM_SEL_CPLL) + parent = priv->cpll_hz; + else + return -ENOENT; + + return DIV_TO_RATE(parent, div); +} + +static ulong rv1126_dclk_decom_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct rv1126_cru *cru = priv->cru; + u32 src_clk_div; + + src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate); + assert(src_clk_div - 1 <= 127); + rk_clrsetreg(&cru->clksel_con[25], + DCLK_DECOM_SEL_MASK | DCLK_DECOM_DIV_MASK, + DCLK_DECOM_SEL_GPLL << DCLK_DECOM_SEL_SHIFT | + (src_clk_div - 1) << DCLK_DECOM_DIV_SHIFT); + + return rv1126_dclk_decom_get_clk(priv); +} + +static ulong rv1126_clk_get_rate(struct clk *clk) +{ + struct rv1126_clk_priv *priv = dev_get_priv(clk->dev); + ulong rate = 0; + + if (!priv->gpll_hz) { + printf("%s gpll=%lu\n", __func__, priv->gpll_hz); + return -ENOENT; + } + + switch (clk->id) { + case PLL_APLL: + case ARMCLK: + rate = rockchip_pll_get_rate(&rv1126_pll_clks[APLL], priv->cru, + APLL); + break; + case PLL_CPLL: + rate = rockchip_pll_get_rate(&rv1126_pll_clks[CPLL], priv->cru, + CPLL); + break; + case PLL_HPLL: + rate = rockchip_pll_get_rate(&rv1126_pll_clks[HPLL], priv->cru, + HPLL); + break; + case PLL_DPLL: + rate = rockchip_pll_get_rate(&rv1126_pll_clks[DPLL], priv->cru, + DPLL); + break; + case HCLK_PDCORE_NIU: + rate = rv1126_pdcore_get_clk(priv); + break; + case ACLK_PDBUS: + case HCLK_PDBUS: + case PCLK_PDBUS: + case PCLK_WDT: + rate = rv1126_pdbus_get_clk(priv, clk->id); + break; + case ACLK_PDPHP: + case HCLK_PDPHP: + rate = rv1126_pdphp_get_clk(priv, clk->id); + break; + case HCLK_PDAUDIO: + rate = rv1126_pdaudio_get_clk(priv); + break; + case CLK_I2C1: + case CLK_I2C3: + case CLK_I2C4: + case CLK_I2C5: + rate = rv1126_i2c_get_clk(priv, clk->id); + break; + case CLK_SPI1: + rate = rv1126_spi_get_clk(priv); + break; + case CLK_PWM2: + rate = rv1126_pwm_get_clk(priv); + break; + case CLK_SARADC: + rate = rv1126_saradc_get_clk(priv); + break; + case CLK_CRYPTO_CORE: + case CLK_CRYPTO_PKA: + case ACLK_CRYPTO: + rate = rv1126_crypto_get_clk(priv, clk->id); + break; + case CLK_SDMMC: + case HCLK_SDMMC: + case CLK_SDIO: + case HCLK_SDIO: + case CLK_EMMC: + case HCLK_EMMC: + case SCLK_EMMC_SAMPLE: + rate = rv1126_mmc_get_clk(priv, clk->id); + break; + case SCLK_SFC: + rate = rv1126_sfc_get_clk(priv); + break; + case CLK_NANDC: + rate = rv1126_nand_get_clk(priv); + break; + case ACLK_PDVO: + case ACLK_VOP: + rate = rv1126_aclk_vop_get_clk(priv); + break; + case DCLK_VOP: + rate = rv1126_dclk_vop_get_clk(priv); + break; + case CLK_SCR1_CORE: + rate = rv1126_scr1_get_clk(priv); + break; + case CLK_GMAC_SRC: + rate = rv1126_gmac_src_get_clk(priv); + break; + case CLK_GMAC_ETHERNET_OUT: + rate = rv1126_gmac_out_get_clk(priv); + break; + case PCLK_GMAC: + rate = rv1126_pclk_gmac_get_clk(priv); + break; + case DCLK_DECOM: + rate = rv1126_dclk_decom_get_clk(priv); + break; + default: + debug("%s: Unsupported CLK#%ld\n", __func__, clk->id); + return -ENOENT; + } + + return rate; +}; + +static ulong rv1126_clk_set_rate(struct clk *clk, ulong rate) +{ + struct rv1126_clk_priv *priv = dev_get_priv(clk->dev); + ulong ret = 0; + + if (!priv->gpll_hz) { + printf("%s gpll=%lu\n", __func__, priv->gpll_hz); + return -ENOENT; + } + + switch (clk->id) { + case PLL_APLL: + case ARMCLK: + if (priv->armclk_hz) + rv1126_armclk_set_clk(priv, rate); + priv->armclk_hz = rate; + break; + case PLL_CPLL: + ret = rockchip_pll_set_rate(&rv1126_pll_clks[CPLL], priv->cru, + CPLL, rate); + break; + case PLL_HPLL: + ret = rockchip_pll_set_rate(&rv1126_pll_clks[HPLL], priv->cru, + HPLL, rate); + break; + case ACLK_PDBUS: + case HCLK_PDBUS: + case PCLK_PDBUS: + case PCLK_WDT: + ret = rv1126_pdbus_set_clk(priv, clk->id, rate); + break; + case ACLK_PDPHP: + case HCLK_PDPHP: + ret = rv1126_pdphp_set_clk(priv, clk->id, rate); + break; + case HCLK_PDCORE_NIU: + ret = rv1126_pdcore_set_clk(priv, rate); + break; + case HCLK_PDAUDIO: + ret = rv1126_pdaudio_set_clk(priv, rate); + break; + case CLK_I2C1: + case CLK_I2C3: + case CLK_I2C4: + case CLK_I2C5: + ret = rv1126_i2c_set_clk(priv, clk->id, rate); + break; + case CLK_SPI1: + ret = rv1126_spi_set_clk(priv, rate); + break; + case CLK_PWM2: + ret = rv1126_pwm_set_clk(priv, rate); + break; + case CLK_SARADC: + ret = rv1126_saradc_set_clk(priv, rate); + break; + case CLK_CRYPTO_CORE: + case CLK_CRYPTO_PKA: + case ACLK_CRYPTO: + ret = rv1126_crypto_set_clk(priv, clk->id, rate); + break; + case CLK_SDMMC: + case HCLK_SDMMC: + case CLK_SDIO: + case HCLK_SDIO: + case CLK_EMMC: + case HCLK_EMMC: + ret = rv1126_mmc_set_clk(priv, clk->id, rate); + break; + case SCLK_SFC: + ret = rv1126_sfc_set_clk(priv, rate); + break; + case CLK_NANDC: + ret = rv1126_nand_set_clk(priv, rate); + break; + case ACLK_PDVO: + case ACLK_VOP: + ret = rv1126_aclk_vop_set_clk(priv, rate); + break; + case DCLK_VOP: + ret = rv1126_dclk_vop_set_clk(priv, rate); + break; + case CLK_SCR1_CORE: + ret = rv1126_scr1_set_clk(priv, rate); + break; + case CLK_GMAC_SRC: + ret = rv1126_gmac_src_set_clk(priv, rate); + break; + case CLK_GMAC_ETHERNET_OUT: + ret = rv1126_gmac_out_set_clk(priv, rate); + break; + case CLK_GMAC_TX_RX: + ret = rv1126_gmac_tx_rx_set_clk(priv, rate); + break; + case DCLK_DECOM: + ret = rv1126_dclk_decom_set_clk(priv, rate); + break; + default: + debug("%s: Unsupported CLK#%ld\n", __func__, clk->id); + return -ENOENT; + } + + return ret; +}; + +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) +static int rv1126_gmac_src_set_parent(struct clk *clk, struct clk *parent) +{ + struct rv1126_clk_priv *priv = dev_get_priv(clk->dev); + struct rv1126_grf *grf = priv->grf; + + if (parent->id == CLK_GMAC_SRC_M0) + rk_clrsetreg(&grf->iofunc_con1, GMAC_SRC_SEL_MASK, + GMAC_SRC_SEL_M0 << GMAC_SRC_SEL_SHIFT); + else if (parent->id == CLK_GMAC_SRC_M1) + rk_clrsetreg(&grf->iofunc_con1, GMAC_SRC_SEL_MASK, + GMAC_SRC_SEL_M1 << GMAC_SRC_SEL_SHIFT); + + return 0; +} + +static int rv1126_gmac_src_m0_set_parent(struct clk *clk, struct clk *parent) +{ + struct rv1126_clk_priv *priv = dev_get_priv(clk->dev); + struct rv1126_cru *cru = priv->cru; + + if (parent->id == CLK_GMAC_DIV) + rk_clrsetreg(&cru->gmac_con, GMAC_SRC_M0_SEL_MASK, + GMAC_SRC_M0_SEL_INT << GMAC_SRC_M0_SEL_SHIFT); + else + rk_clrsetreg(&cru->gmac_con, GMAC_SRC_M0_SEL_MASK, + GMAC_SRC_M0_SEL_EXT << GMAC_SRC_M0_SEL_SHIFT); + + return 0; +} + +static int rv1126_gmac_src_m1_set_parent(struct clk *clk, struct clk *parent) +{ + struct rv1126_clk_priv *priv = dev_get_priv(clk->dev); + struct rv1126_cru *cru = priv->cru; + + if (parent->id == CLK_GMAC_DIV) + rk_clrsetreg(&cru->gmac_con, GMAC_SRC_M1_SEL_MASK, + GMAC_SRC_M1_SEL_INT << GMAC_SRC_M1_SEL_SHIFT); + else + rk_clrsetreg(&cru->gmac_con, GMAC_SRC_M1_SEL_MASK, + GMAC_SRC_M1_SEL_EXT << GMAC_SRC_M1_SEL_SHIFT); + + return 0; +} + +static int rv1126_gmac_tx_rx_set_parent(struct clk *clk, struct clk *parent) +{ + struct rv1126_clk_priv *priv = dev_get_priv(clk->dev); + struct rv1126_cru *cru = priv->cru; + + if (parent->id == RGMII_MODE_CLK) + rk_clrsetreg(&cru->gmac_con, GMAC_MODE_SEL_MASK, + GMAC_RGMII_MODE << GMAC_MODE_SEL_SHIFT); + else + rk_clrsetreg(&cru->gmac_con, GMAC_MODE_SEL_MASK, + GMAC_RMII_MODE << GMAC_MODE_SEL_SHIFT); + + return 0; +} + +static int rv1126_clk_set_parent(struct clk *clk, struct clk *parent) +{ + switch (clk->id) { + case CLK_GMAC_SRC: + return rv1126_gmac_src_set_parent(clk, parent); + case CLK_GMAC_SRC_M0: + return rv1126_gmac_src_m0_set_parent(clk, parent); + case CLK_GMAC_SRC_M1: + return rv1126_gmac_src_m1_set_parent(clk, parent); + case CLK_GMAC_TX_RX: + return rv1126_gmac_tx_rx_set_parent(clk, parent); + default: + return -ENOENT; + } + + return 0; +} +#endif + +static struct clk_ops rv1126_clk_ops = { + .get_rate = rv1126_clk_get_rate, + .set_rate = rv1126_clk_set_rate, +#if CONFIG_IS_ENABLED(OF_CONTROL) && !CONFIG_IS_ENABLED(OF_PLATDATA) + .set_parent = rv1126_clk_set_parent, +#endif +}; + +static ulong rv1126_gpll_set_rate(struct rv1126_clk_priv *priv, + struct rv1126_pmuclk_priv *pmu_priv, + ulong rate) +{ + ulong emmc_rate, sfc_rate, nandc_rate; + bool restore = false; + + if (priv->gpll_hz != OSC_HZ) { + emmc_rate = rv1126_mmc_get_clk(priv, CLK_EMMC); + sfc_rate = rv1126_sfc_get_clk(priv); + nandc_rate = rv1126_nand_get_clk(priv); + debug("%s emmc=%lu, sfc=%lu, nandc=%lu\n", __func__, + emmc_rate, sfc_rate, nandc_rate); + restore = true; + } + + /* + * the child div is big enough for gpll 1188MHz, + * even maskrom has change some clocks. + */ + if (rockchip_pll_set_rate(&rv1126_pll_clks[GPLL], + pmu_priv->pmucru, GPLL, rate)) + return -EINVAL; + pmu_priv->gpll_hz = rate; + priv->gpll_hz = rate; + + if (restore) { + rv1126_mmc_set_clk(priv, CLK_EMMC, emmc_rate); + rv1126_sfc_set_clk(priv, sfc_rate); + rv1126_nand_set_clk(priv, nandc_rate); + } + + return 0; +} + +static int rv1126_gpll_set_clk(struct rv1126_clk_priv *priv, ulong rate) +{ + struct udevice *pmucru_dev; + struct rv1126_pmuclk_priv *pmu_priv; + int ret; + + ret = uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(rockchip_rv1126_pmucru), + &pmucru_dev); + if (ret) { + printf("%s: could not find pmucru device\n", __func__); + return ret; + } + pmu_priv = dev_get_priv(pmucru_dev); + priv->gpll_hz = pmu_priv->gpll_hz; + + if (rv1126_gpll_set_rate(priv, pmu_priv, rate)) { + printf("%s: failed to set gpll rate %lu\n", __func__, rate); + return -EINVAL; + } + + rv1126_pdpmu_set_pmuclk(pmu_priv, PCLK_PDPMU_HZ); + rv1126_rtc32k_set_pmuclk(pmu_priv, CLK_OSC0_DIV_HZ); + + return 0; +} + +static void rv1126_clk_init(struct rv1126_clk_priv *priv) +{ + int ret; + + priv->sync_kernel = false; + if (!priv->armclk_enter_hz) { + priv->armclk_enter_hz = + rockchip_pll_get_rate(&rv1126_pll_clks[APLL], + priv->cru, APLL); + priv->armclk_init_hz = priv->armclk_enter_hz; + } + + if (priv->armclk_init_hz != APLL_HZ) { + ret = rv1126_armclk_set_clk(priv, APLL_HZ); + if (!ret) + priv->armclk_init_hz = APLL_HZ; + } + if (priv->cpll_hz != CPLL_HZ) { + ret = rockchip_pll_set_rate(&rv1126_pll_clks[CPLL], priv->cru, + CPLL, CPLL_HZ); + if (!ret) + priv->cpll_hz = CPLL_HZ; + } + if (priv->hpll_hz != HPLL_HZ) { + ret = rockchip_pll_set_rate(&rv1126_pll_clks[HPLL], priv->cru, + HPLL, HPLL_HZ); + if (!ret) + priv->hpll_hz = HPLL_HZ; + } + if (priv->gpll_hz != GPLL_HZ) + rv1126_gpll_set_clk(priv, GPLL_HZ); + + rv1126_pdbus_set_clk(priv, ACLK_PDBUS, ACLK_PDBUS_HZ); + rv1126_pdbus_set_clk(priv, HCLK_PDBUS, HCLK_PDBUS_HZ); + rv1126_pdbus_set_clk(priv, PCLK_PDBUS, PCLK_PDBUS_HZ); + rv1126_pdphp_set_clk(priv, ACLK_PDPHP, ACLK_PDPHP_HZ); + rv1126_pdphp_set_clk(priv, HCLK_PDPHP, HCLK_PDPHP_HZ); + rv1126_pdcore_set_clk(priv, HCLK_PDCORE_HZ); + rv1126_pdaudio_set_clk(priv, HCLK_PDAUDIO_HZ); +} + +static int rv1126_clk_probe(struct udevice *dev) +{ + struct rv1126_clk_priv *priv = dev_get_priv(dev); + int ret; + + priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF); + if (IS_ERR(priv->grf)) + return PTR_ERR(priv->grf); + + rv1126_clk_init(priv); + + /* Process 'assigned-{clocks/clock-parents/clock-rates}' properties */ + ret = clk_set_defaults(dev, 1); + if (ret) + debug("%s clk_set_defaults failed %d\n", __func__, ret); + else + priv->sync_kernel = true; + + return 0; +} + +static int rv1126_clk_of_to_plat(struct udevice *dev) +{ + struct rv1126_clk_priv *priv = dev_get_priv(dev); + + priv->cru = dev_read_addr_ptr(dev); + + return 0; +} + +static int rv1126_clk_bind(struct udevice *dev) +{ + int ret; + struct udevice *sys_child; + struct sysreset_reg *priv; + + /* The reset driver does not have a device node, so bind it here */ + ret = device_bind_driver(dev, "rockchip_sysreset", "sysreset", + &sys_child); + if (ret) { + debug("Warning: No sysreset driver: ret=%d\n", ret); + } else { + priv = malloc(sizeof(struct sysreset_reg)); + priv->glb_srst_fst_value = offsetof(struct rv1126_cru, + glb_srst_fst); + priv->glb_srst_snd_value = offsetof(struct rv1126_cru, + glb_srst_snd); + dev_set_priv(sys_child, priv); + } + +#if CONFIG_IS_ENABLED(RESET_ROCKCHIP) + ret = offsetof(struct rv1126_cru, softrst_con[0]); + ret = rockchip_reset_bind(dev, ret, 15); + if (ret) + debug("Warning: software reset driver bind faile\n"); +#endif + return 0; +} + +static const struct udevice_id rv1126_clk_ids[] = { + { .compatible = "rockchip,rv1126-cru" }, + { } +}; + +U_BOOT_DRIVER(rockchip_rv1126_cru) = { + .name = "rockchip_rv1126_cru", + .id = UCLASS_CLK, + .of_match = rv1126_clk_ids, + .priv_auto = sizeof(struct rv1126_clk_priv), + .of_to_plat = rv1126_clk_of_to_plat, + .ops = &rv1126_clk_ops, + .bind = rv1126_clk_bind, + .probe = rv1126_clk_probe, +};
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
update cru header
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd.
- Author: Finley Xiao finley.xiao@rock-chips.com
- .rate = _rate##U, \
- .aclk_div = _aclk_div, \
- .pclk_div = _pclk_div, \
- RV1126_CPUCLK_RATE(1200000000, 1, 5),
- RV1126_CPUCLK_RATE(1008000000, 1, 5),
- RV1126_CPUCLK_RATE(816000000, 1, 3),
- RV1126_CPUCLK_RATE(600000000, 1, 3),
- RV1126_CPUCLK_RATE(408000000, 1, 1),
- /* _mhz, _refdiv, _fbdiv, _postdiv1, _postdiv2, _dsmpd, _frac */
- RK3036_PLL_RATE(1600000000, 3, 200, 1, 1, 1, 0),
- RK3036_PLL_RATE(1400000000, 3, 350, 2, 1, 1, 0),
- RK3036_PLL_RATE(1200000000, 1, 100, 2, 1, 1, 0),
- RK3036_PLL_RATE(1188000000, 1, 99, 2, 1, 1, 0),
- RK3036_PLL_RATE(1100000000, 3, 275, 2, 1, 1, 0),
- RK3036_PLL_RATE(1008000000, 1, 84, 2, 1, 1, 0),
- RK3036_PLL_RATE(1000000000, 3, 250, 2, 1, 1, 0),
- RK3036_PLL_RATE(816000000, 1, 68, 2, 1, 1, 0),
- RK3036_PLL_RATE(800000000, 3, 200, 2, 1, 1, 0),
- RK3036_PLL_RATE(600000000, 1, 100, 4, 1, 1, 0),
- RK3036_PLL_RATE(594000000, 1, 99, 4, 1, 1, 0),
- RK3036_PLL_RATE(500000000, 1, 125, 6, 1, 1, 0),
- RK3036_PLL_RATE(200000000, 1, 100, 6, 2, 1, 0),
- RK3036_PLL_RATE(100000000, 1, 100, 6, 4, 1, 0),
- { /* sentinel */ },
- [APLL] = PLL(pll_rk3328, PLL_APLL, RV1126_PLL_CON(0),
- [DPLL] = PLL(pll_rk3328, PLL_DPLL, RV1126_PLL_CON(8),
- [CPLL] = PLL(pll_rk3328, PLL_CPLL, RV1126_PLL_CON(16),
- [HPLL] = PLL(pll_rk3328, PLL_HPLL, RV1126_PLL_CON(24),
- [GPLL] = PLL(pll_rk3328, PLL_GPLL, RV1126_PMU_PLL_CON(0),
ulong rate);
- rational_best_approximation(31415, 10000,
- you may look at given_numerator as a fixed point number,
- with the fractional part size described in given_denominator.
- for theoretical background, see:
- unsigned long n, d, n0, d0, n1, d1;
- n = given_numerator;
- d = given_denominator;
- n0 = 0;
- d1 = 0;
- n1 = 1;
- d0 = 1;
- for (;;) {
unsigned long t, a;
n1 = n0;
d1 = d0;
break;
if (d == 0)
break;
t = d;
a = n / d;
d = n % d;
n = t;
t = n0 + a * n1;
n0 = n1;
n1 = t;
t = d0 + a * d1;
d0 = d1;
d1 = t;
- *best_numerator = n1;
- *best_denominator = d1;
- return rockchip_pll_get_rate(&rv1126_pll_clks[GPLL],
- struct udevice *cru_dev;
- struct rv1126_clk_priv *priv;
- int ret;
- ret = uclass_get_device_by_driver(UCLASS_CLK,
&cru_dev);
- if (ret) {
return ret;
- priv = dev_get_priv(cru_dev);
- if (rv1126_gpll_set_rate(priv, pmu_priv, rate)) {
return -EINVAL;
- struct rv1126_pmucru *pmucru = priv->pmucru;
- unsigned long m, n;
- u32 fracdiv;
- fracdiv = readl(&pmucru->pmu_clksel_con[13]);
- m = fracdiv & CLK_RTC32K_FRAC_NUMERATOR_MASK;
- m >>= CLK_RTC32K_FRAC_NUMERATOR_SHIFT;
- n = fracdiv & CLK_RTC32K_FRAC_DENOMINATOR_MASK;
- n >>= CLK_RTC32K_FRAC_DENOMINATOR_SHIFT;
- return OSC_HZ * m / n;
ulong rate)
- unsigned long m, n, val;
- rk_clrsetreg(&pmucru->pmu_clksel_con[0], RTC32K_SEL_MASK,
- rational_best_approximation(rate, OSC_HZ,
GENMASK(16 - 1, 0),
GENMASK(16 - 1, 0),
&m, &n);
- val = m << CLK_RTC32K_FRAC_NUMERATOR_SHIFT | n;
- writel(val, &pmucru->pmu_clksel_con[13]);
- return rv1126_rtc32k_get_pmuclk(priv);
ulong clk_id)
- u32 div, con;
- switch (clk_id) {
- case CLK_I2C0:
break;
- case CLK_I2C2:
break;
- default:
return -ENOENT;
- return DIV_TO_RATE(priv->gpll_hz, div);
- int src_clk_div;
- src_clk_div = DIV_ROUND_UP(priv->gpll_hz, rate);
- assert(src_clk_div - 1 <= 127);
- switch (clk_id) {
- case CLK_I2C0:
break;
- case CLK_I2C2:
break;
- default:
return -ENOENT;
- return rv1126_i2c_get_pmuclk(priv, clk_id);
ulong clk_id)
- u32 div, sel, con;
- switch (clk_id) {
- case CLK_PWM0:
return OSC_HZ;
break;
- case CLK_PWM1:
return OSC_HZ;
break;
- default:
return -ENOENT;
- int src_clk_div;
- switch (clk_id) {
- case CLK_PWM0:
CLK_PWM0_SEL_MASK,
} else {
CLK_PWM0_DIV_MASK,
CLK_PWM0_SEL_MASK,
break;
- case CLK_PWM1:
CLK_PWM1_SEL_MASK,
} else {
CLK_PWM1_DIV_MASK,
CLK_PWM1_SEL_MASK,
break;
- default:
return -ENOENT;
- return rv1126_pwm_get_pmuclk(priv, clk_id);
- u32 div, con;
- con = readl(&pmucru->pmu_clksel_con[9]);
- div = (con & CLK_SPI0_DIV_MASK) >> CLK_SPI0_DIV_SHIFT;
ulong rate)
- int src_clk_div;
- rk_clrsetreg(&pmucru->pmu_clksel_con[9],
- return rv1126_spi_get_pmuclk(priv);
- u32 div, con;
- con = readl(&pmucru->pmu_clksel_con[1]);
- div = (con & PCLK_PDPMU_DIV_MASK) >> PCLK_PDPMU_DIV_SHIFT;
ulong rate)
- int src_clk_div;
- assert(src_clk_div - 1 <= 31);
- rk_clrsetreg(&pmucru->pmu_clksel_con[1],
- return rv1126_pdpmu_get_pmuclk(priv);
- struct rv1126_pmuclk_priv *priv = dev_get_priv(clk->dev);
- ulong rate = 0;
- if (!priv->gpll_hz) {
return -ENOENT;
- debug("%s %ld\n", __func__, clk->id);
- switch (clk->id) {
- case PLL_GPLL:
break;
- case CLK_RTC32K:
break;
- case CLK_I2C0:
- case CLK_I2C2:
break;
- case CLK_PWM0:
- case CLK_PWM1:
break;
- case CLK_SPI0:
break;
- case PCLK_PDPMU:
break;
- default:
return -ENOENT;
- return rate;
- ulong ret = 0;
return -ENOENT;
- debug("%s %ld %ld\n", __func__, clk->id, rate);
- case PLL_GPLL:
break;
- case CLK_RTC32K:
break;
- case CLK_I2C0:
- case CLK_I2C2:
break;
- case CLK_PWM0:
- case CLK_PWM1:
break;
- case CLK_SPI0:
break;
- case PCLK_PDPMU:
break;
- default:
return -ENOENT;
- return ret;
- if (parent->id == CLK_OSC0_DIV32K)
- else
- case CLK_RTC32K:
- default:
return -ENOENT;
- .get_rate = rv1126_pmuclk_get_rate,
- .set_rate = rv1126_pmuclk_set_rate,
- .set_parent = rv1126_pmuclk_set_parent,
- struct rv1126_pmuclk_priv *priv = dev_get_priv(dev);
- priv->gpll_hz = rv1126_gpll_get_pmuclk(priv);
- priv->pmucru = dev_read_addr_ptr(dev);
- int ret;
- ret = offsetof(struct rv1126_pmucru, pmu_softrst_con[0]);
- ret = rockchip_reset_bind(dev, ret, 2);
- if (ret)
- { .compatible = "rockchip,rv1126-pmucru" },
- .name = "rockchip_rv1126_pmucru",
- .id = UCLASS_CLK,
- .of_match = rv1126_pmuclk_ids,
- .priv_auto = sizeof(struct rv1126_pmuclk_priv),
- .of_to_plat = rv1126_pmuclk_of_to_plat,
- .ops = &rv1126_pmuclk_ops,
- .bind = rv1126_pmuclk_bind,
- .probe = rv1126_pmuclk_probe,
- struct rv1126_cru *cru = priv->cru;
- const struct rockchip_cpu_rate_table *rate;
- ulong old_rate;
- rate = rockchip_get_cpu_settings(rv1126_cpu_rates, hz);
- if (!rate) {
return -EINVAL;
- old_rate = rockchip_pll_get_rate(&rv1126_pll_clks[APLL],
priv->cru, APLL);
- if (old_rate > hz) {
return -EINVAL;
- } else if (old_rate < hz) {
return -EINVAL;
- u32 con, div;
- con = readl(&cru->clksel_con[0]);
- div = (con & CORE_HCLK_DIV_MASK) >> CORE_HCLK_DIV_SHIFT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[0], CORE_HCLK_DIV_MASK,
- return rv1126_pdcore_get_clk(priv);
- u32 con, div, sel, parent;
- switch (clk_id) {
- case ACLK_PDBUS:
else
return -ENOENT;
break;
- case HCLK_PDBUS:
else
return -ENOENT;
break;
- case PCLK_PDBUS:
- case PCLK_WDT:
else
return -ENOENT;
break;
- default:
return -ENOENT;
- return DIV_TO_RATE(parent, div);
ulong rate)
- int src_clk_div, clk_sel;
- switch (clk_id) {
- case ACLK_PDBUS:
} else {
break;
- case HCLK_PDBUS:
break;
- case PCLK_PDBUS:
- case PCLK_WDT:
break;
- default:
return -EINVAL;
- return rv1126_pdbus_get_clk(priv, clk_id);
- u32 con, div, parent;
- switch (clk_id) {
- case ACLK_PDPHP:
break;
- case HCLK_PDPHP:
break;
- default:
return -ENOENT;
ulong rate)
- int src_clk_div;
- switch (clk_id) {
- case ACLK_PDPHP:
break;
- case HCLK_PDPHP:
break;
- default:
return -EINVAL;
- return rv1126_pdphp_get_clk(priv, clk_id);
- u32 con, div;
- con = readl(&cru->clksel_con[26]);
- div = (con & HCLK_PDAUDIO_DIV_MASK) >> HCLK_PDAUDIO_DIV_SHIFT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[26], HCLK_PDAUDIO_DIV_MASK,
- return rv1126_pdaudio_get_clk(priv);
- u32 div, con;
- switch (clk_id) {
- case CLK_I2C1:
break;
- case CLK_I2C3:
break;
- case CLK_I2C4:
break;
- case CLK_I2C5:
break;
- default:
return -ENOENT;
ulong rate)
- int src_clk_div;
- switch (clk_id) {
- case CLK_I2C1:
break;
- case CLK_I2C3:
break;
- case CLK_I2C4:
break;
- case CLK_I2C5:
break;
- default:
return -ENOENT;
- return rv1126_i2c_get_clk(priv, clk_id);
- u32 div, con;
- con = readl(&cru->clksel_con[8]);
- div = (con & CLK_SPI1_DIV_MASK) >> CLK_SPI1_DIV_SHIFT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[8],
- return rv1126_spi_get_clk(priv);
- con = readl(&cru->clksel_con[9]);
- sel = (con & CLK_PWM2_SEL_MASK) >> CLK_PWM2_SEL_SHIFT;
- div = (con & CLK_PWM2_DIV_MASK) >> CLK_PWM2_DIV_SHIFT;
- if (sel == CLK_PWM2_SEL_XIN24M)
return OSC_HZ;
- int src_clk_div;
- if (rate == OSC_HZ) {
- } else {
- return rv1126_pwm_get_clk(priv);
- u32 div, con;
- con = readl(&cru->clksel_con[20]);
- div = (con & CLK_SARADC_DIV_MASK) >> CLK_SARADC_DIV_SHIFT;
- return DIV_TO_RATE(OSC_HZ, div);
- int src_clk_div;
- src_clk_div = DIV_ROUND_UP(OSC_HZ, rate);
- assert(src_clk_div - 1 <= 2047);
- rk_clrsetreg(&cru->clksel_con[20], CLK_SARADC_DIV_MASK,
- return rv1126_saradc_get_clk(priv);
- u32 div, sel, con, parent;
- switch (clk_id) {
- case CLK_CRYPTO_CORE:
else
return -ENOENT;
break;
- case CLK_CRYPTO_PKA:
else
return -ENOENT;
break;
- case ACLK_CRYPTO:
else
return -ENOENT;
break;
- default:
return -ENOENT;
ulong rate)
- int src_clk_div;
- switch (clk_id) {
break;
break;
- case ACLK_CRYPTO:
break;
- default:
return -ENOENT;
- return rv1126_crypto_get_clk(priv, clk_id);
- u32 div, sel, con, con_id;
- switch (clk_id) {
- case HCLK_SDMMC:
- case CLK_SDMMC:
con_id = 55;
break;
- case HCLK_SDIO:
- case CLK_SDIO:
con_id = 56;
break;
- case HCLK_EMMC:
- case CLK_EMMC:
- case SCLK_EMMC_SAMPLE:
con_id = 57;
break;
- default:
return -ENOENT;
- con = readl(&cru->clksel_con[con_id]);
- div = (con & EMMC_DIV_MASK) >> EMMC_DIV_SHIFT;
- sel = (con & EMMC_SEL_MASK) >> EMMC_SEL_SHIFT;
- if (sel == EMMC_SEL_GPLL)
- else if (sel == EMMC_SEL_CPLL)
- else if (sel == EMMC_SEL_XIN24M)
- return -ENOENT;
ulong rate)
- int src_clk_div;
- u32 con_id;
- switch (clk_id) {
- case HCLK_SDMMC:
- case CLK_SDMMC:
con_id = 55;
break;
- case HCLK_SDIO:
- case CLK_SDIO:
con_id = 56;
break;
- case HCLK_EMMC:
- case CLK_EMMC:
con_id = 57;
break;
- default:
return -ENOENT;
- /* Select clk_sdmmc/emmc source from GPLL by default */
- /* mmc clock defaulg div 2 internal, need provide double in cru */
- src_clk_div = DIV_ROUND_UP(priv->gpll_hz / 2, rate);
- if (src_clk_div > 127) {
- } else {
- return rv1126_mmc_get_clk(priv, clk_id);
- con = readl(&cru->clksel_con[58]);
- div = (con & SCLK_SFC_DIV_MASK) >> SCLK_SFC_DIV_SHIFT;
- sel = (con & SCLK_SFC_SEL_MASK) >> SCLK_SFC_SEL_SHIFT;
- if (sel == SCLK_SFC_SEL_GPLL)
- else if (sel == SCLK_SFC_SEL_CPLL)
- else
return -ENOENT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[58],
- return rv1126_sfc_get_clk(priv);
- con = readl(&cru->clksel_con[59]);
- div = (con & CLK_NANDC_DIV_MASK) >> CLK_NANDC_DIV_SHIFT;
- sel = (con & CLK_NANDC_SEL_MASK) >> CLK_NANDC_SEL_SHIFT;
- if (sel == CLK_NANDC_SEL_GPLL)
- else if (sel == CLK_NANDC_SEL_CPLL)
- else
return -ENOENT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[59],
- return rv1126_nand_get_clk(priv);
- con = readl(&cru->clksel_con[45]);
- div = (con & ACLK_PDVO_DIV_MASK) >> ACLK_PDVO_DIV_SHIFT;
- sel = (con & ACLK_PDVO_SEL_MASK) >> ACLK_PDVO_SEL_SHIFT;
- if (sel == ACLK_PDVO_SEL_GPLL)
- else if (sel == ACLK_PDVO_SEL_CPLL)
- else
return -ENOENT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[45],
- return rv1126_aclk_vop_get_clk(priv);
- con = readl(&cru->clksel_con[47]);
- div = (con & DCLK_VOP_DIV_MASK) >> DCLK_VOP_DIV_SHIFT;
- sel = (con & DCLK_VOP_SEL_MASK) >> DCLK_VOP_SEL_SHIFT;
- if (sel == DCLK_VOP_SEL_GPLL)
- else if (sel == DCLK_VOP_SEL_CPLL)
- else
return -ENOENT;
- ulong pll_rate, now, best_rate = 0;
- u32 i, div, best_div = 0, best_sel = 0;
- for (i = 0; i <= DCLK_VOP_SEL_CPLL; i++) {
switch (i) {
break;
break;
default:
return -EINVAL;
if (div > 255)
continue;
best_rate = now;
best_div = div;
best_sel = i;
- if (best_rate) {
- } else {
return -EINVAL;
- return rv1126_dclk_vop_get_clk(priv);
- con = readl(&cru->clksel_con[3]);
- div = (con & CLK_SCR1_DIV_MASK) >> CLK_SCR1_DIV_SHIFT;
- sel = (con & CLK_SCR1_SEL_MASK) >> CLK_SCR1_SEL_SHIFT;
- if (sel == CLK_SCR1_SEL_GPLL)
- else if (sel == CLK_SCR1_SEL_CPLL)
- else
return -ENOENT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[3],
- return rv1126_scr1_get_clk(priv);
- con = readl(&cru->clksel_con[63]);
- div = (con & CLK_GMAC_SRC_DIV_MASK) >> CLK_GMAC_SRC_DIV_SHIFT;
- sel = (con & CLK_GMAC_SRC_SEL_MASK) >> CLK_GMAC_SRC_SEL_SHIFT;
- if (sel == CLK_GMAC_SRC_SEL_CPLL)
- else if (sel == CLK_GMAC_SRC_SEL_GPLL)
- else
return -ENOENT;
- int src_clk_div;
- src_clk_div = DIV_ROUND_UP(priv->cpll_hz, rate);
- rk_clrsetreg(&cru->clksel_con[63],
- return rv1126_gmac_src_get_clk(priv);
- con = readl(&cru->clksel_con[61]);
- div = (con & CLK_GMAC_OUT_DIV_MASK) >> CLK_GMAC_OUT_DIV_SHIFT;
- sel = (con & CLK_GMAC_OUT_SEL_MASK) >> CLK_GMAC_OUT_SEL_SHIFT;
- if (sel == CLK_GMAC_OUT_SEL_CPLL)
- else if (sel == CLK_GMAC_OUT_SEL_GPLL)
- else
return -ENOENT;
- int src_clk_div;
- rk_clrsetreg(&cru->clksel_con[61],
- return rv1126_gmac_out_get_clk(priv);
- u32 con, sel, div_sel;
- con = readl(&cru->gmac_con);
- sel = (con & GMAC_MODE_SEL_MASK) >> GMAC_MODE_SEL_SHIFT;
- if (sel == GMAC_RGMII_MODE) {
else
- } else if (sel == GMAC_RMII_MODE) {
else
- u32 div, con, parent;
- parent = rv1126_pdphp_get_clk(priv, ACLK_PDPHP);
- div = (con & PCLK_GMAC_DIV_MASK) >> PCLK_GMAC_DIV_SHIFT;
- con = readl(&cru->clksel_con[25]);
- div = (con & DCLK_DECOM_DIV_MASK) >> DCLK_DECOM_DIV_SHIFT;
- sel = (con & DCLK_DECOM_SEL_MASK) >> DCLK_DECOM_SEL_SHIFT;
- if (sel == DCLK_DECOM_SEL_GPLL)
- else if (sel == DCLK_DECOM_SEL_CPLL)
- else
return -ENOENT;
- u32 src_clk_div;
- rk_clrsetreg(&cru->clksel_con[25],
- return rv1126_dclk_decom_get_clk(priv);
- struct rv1126_clk_priv *priv = dev_get_priv(clk->dev);
- ulong rate = 0;
return -ENOENT;
- case PLL_APLL:
- case ARMCLK:
APLL);
break;
- case PLL_CPLL:
CPLL);
break;
- case PLL_HPLL:
HPLL);
break;
- case PLL_DPLL:
DPLL);
break;
- case HCLK_PDCORE_NIU:
break;
- case ACLK_PDBUS:
- case HCLK_PDBUS:
- case PCLK_PDBUS:
- case PCLK_WDT:
break;
- case ACLK_PDPHP:
- case HCLK_PDPHP:
break;
- case HCLK_PDAUDIO:
break;
- case CLK_I2C1:
- case CLK_I2C3:
- case CLK_I2C4:
- case CLK_I2C5:
break;
- case CLK_SPI1:
break;
- case CLK_PWM2:
break;
- case CLK_SARADC:
break;
- case ACLK_CRYPTO:
break;
- case CLK_SDMMC:
- case HCLK_SDMMC:
- case CLK_SDIO:
- case HCLK_SDIO:
- case CLK_EMMC:
- case HCLK_EMMC:
break;
- case SCLK_SFC:
break;
- case CLK_NANDC:
break;
- case ACLK_PDVO:
- case ACLK_VOP:
break;
- case DCLK_VOP:
break;
- case CLK_SCR1_CORE:
break;
- case CLK_GMAC_SRC:
break;
- case CLK_GMAC_ETHERNET_OUT:
break;
- case PCLK_GMAC:
break;
- case DCLK_DECOM:
break;
- default:
return -ENOENT;
- return rate;
- ulong ret = 0;
return -ENOENT;
- case PLL_APLL:
- case ARMCLK:
break;
- case PLL_CPLL:
CPLL, rate);
break;
- case PLL_HPLL:
HPLL, rate);
break;
- case ACLK_PDBUS:
- case HCLK_PDBUS:
- case PCLK_PDBUS:
- case PCLK_WDT:
break;
- case ACLK_PDPHP:
- case HCLK_PDPHP:
break;
break;
break;
- case CLK_I2C1:
- case CLK_I2C3:
- case CLK_I2C4:
- case CLK_I2C5:
break;
- case CLK_SPI1:
break;
- case CLK_PWM2:
break;
- case CLK_SARADC:
break;
- case ACLK_CRYPTO:
break;
- case CLK_SDMMC:
- case HCLK_SDMMC:
- case CLK_SDIO:
- case HCLK_SDIO:
- case CLK_EMMC:
- case HCLK_EMMC:
break;
- case SCLK_SFC:
break;
- case CLK_NANDC:
break;
- case ACLK_PDVO:
- case ACLK_VOP:
break;
- case DCLK_VOP:
break;
break;
break;
break;
- case CLK_GMAC_TX_RX:
break;
- case DCLK_DECOM:
break;
- default:
return -ENOENT;
- return ret;
- struct rv1126_grf *grf = priv->grf;
- if (parent->id == CLK_GMAC_SRC_M0)
- else if (parent->id == CLK_GMAC_SRC_M1)
- if (parent->id == CLK_GMAC_DIV)
- else
- else
- if (parent->id == RGMII_MODE_CLK)
- else
- case CLK_GMAC_SRC_M0:
- case CLK_GMAC_SRC_M1:
- default:
return -ENOENT;
+} +#endif
- .get_rate = rv1126_clk_get_rate,
- .set_rate = rv1126_clk_set_rate,
- .set_parent = rv1126_clk_set_parent,
+#endif +};
ulong rate)
- ulong emmc_rate, sfc_rate, nandc_rate;
- bool restore = false;
- if (priv->gpll_hz != OSC_HZ) {
restore = true;
- if (rockchip_pll_set_rate(&rv1126_pll_clks[GPLL],
return -EINVAL;
- pmu_priv->gpll_hz = rate;
- priv->gpll_hz = rate;
- if (restore) {
- struct udevice *pmucru_dev;
- struct rv1126_pmuclk_priv *pmu_priv;
- int ret;
&pmucru_dev);
- if (ret) {
return ret;
- pmu_priv = dev_get_priv(pmucru_dev);
- priv->gpll_hz = pmu_priv->gpll_hz;
return -EINVAL;
- rv1126_pdpmu_set_pmuclk(pmu_priv, PCLK_PDPMU_HZ);
- rv1126_rtc32k_set_pmuclk(pmu_priv, CLK_OSC0_DIV_HZ);
- int ret;
- priv->sync_kernel = false;
- if (!priv->armclk_enter_hz) {
priv->cru, APLL);
- if (priv->armclk_init_hz != APLL_HZ) {
if (!ret)
- if (priv->cpll_hz != CPLL_HZ) {
CPLL, CPLL_HZ);
if (!ret)
- if (priv->hpll_hz != HPLL_HZ) {
HPLL, HPLL_HZ);
if (!ret)
- if (priv->gpll_hz != GPLL_HZ)
- rv1126_pdbus_set_clk(priv, ACLK_PDBUS, ACLK_PDBUS_HZ);
- rv1126_pdbus_set_clk(priv, HCLK_PDBUS, HCLK_PDBUS_HZ);
- rv1126_pdbus_set_clk(priv, PCLK_PDBUS, PCLK_PDBUS_HZ);
- rv1126_pdphp_set_clk(priv, ACLK_PDPHP, ACLK_PDPHP_HZ);
- rv1126_pdphp_set_clk(priv, HCLK_PDPHP, HCLK_PDPHP_HZ);
- rv1126_pdcore_set_clk(priv, HCLK_PDCORE_HZ);
- rv1126_pdaudio_set_clk(priv, HCLK_PDAUDIO_HZ);
- struct rv1126_clk_priv *priv = dev_get_priv(dev);
- int ret;
- priv->grf = syscon_get_first_range(ROCKCHIP_SYSCON_GRF);
- if (IS_ERR(priv->grf))
- rv1126_clk_init(priv);
- /* Process 'assigned-{clocks/clock-parents/clock-rates}' properties */
- ret = clk_set_defaults(dev, 1);
- if (ret)
- else
- priv->cru = dev_read_addr_ptr(dev);
- int ret;
- struct udevice *sys_child;
- struct sysreset_reg *priv;
- /* The reset driver does not have a device node, so bind it here */
- ret = device_bind_driver(dev, "rockchip_sysreset", "sysreset",
&sys_child);
- if (ret) {
- } else {
glb_srst_fst);
glb_srst_snd);
- ret = offsetof(struct rv1126_cru, softrst_con[0]);
- ret = rockchip_reset_bind(dev, ret, 15);
- if (ret)
- { .compatible = "rockchip,rv1126-cru" },
- .name = "rockchip_rv1126_cru",
- .id = UCLASS_CLK,
- .of_match = rv1126_clk_ids,
- .priv_auto = sizeof(struct rv1126_clk_priv),
- .of_to_plat = rv1126_clk_of_to_plat,
- .ops = &rv1126_clk_ops,
- .bind = rv1126_clk_bind,
- .probe = rv1126_clk_probe,
Add power-domain header for RV1126 SoC from description in TRM.
Signed-off-by: Elaine Zhang zhangqing@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - update filename
.../dt-bindings/power/rockchip,rv1126-power.h | 35 +++++++++++++++++++ 1 file changed, 35 insertions(+) create mode 100644 include/dt-bindings/power/rockchip,rv1126-power.h
diff --git a/include/dt-bindings/power/rockchip,rv1126-power.h b/include/dt-bindings/power/rockchip,rv1126-power.h new file mode 100644 index 0000000000..38a68e000d --- /dev/null +++ b/include/dt-bindings/power/rockchip,rv1126-power.h @@ -0,0 +1,35 @@ +/* SPDX-License-Identifier: GPL-2.0 */ + +#ifndef __DT_BINDINGS_POWER_RV1126_POWER_H__ +#define __DT_BINDINGS_POWER_RV1126_POWER_H__ + +/* VD_CORE */ +#define RV1126_PD_CPU_0 0 +#define RV1126_PD_CPU_1 1 +#define RV1126_PD_CPU_2 2 +#define RV1126_PD_CPU_3 3 +#define RV1126_PD_CORE_ALIVE 4 + +/* VD_PMU */ +#define RV1126_PD_PMU 5 +#define RV1126_PD_PMU_ALIVE 6 + +/* VD_NPU */ +#define RV1126_PD_NPU 7 + +/* VD_VEPU */ +#define RV1126_PD_VEPU 8 + +/* VD_LOGIC */ +#define RV1126_PD_VI 9 +#define RV1126_PD_VO 10 +#define RV1126_PD_ISPP 11 +#define RV1126_PD_VDPU 12 +#define RV1126_PD_CRYPTO 13 +#define RV1126_PD_DDR 14 +#define RV1126_PD_NVM 15 +#define RV1126_PD_SDIO 16 +#define RV1126_PD_USB 17 +#define RV1126_PD_LOGIC_ALIVE 18 + +#endif
Thanks, - Kever
Changes for v2:
update filename
Add GRF header for Rockchip RV1126.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - none
.../include/asm/arch-rockchip/grf_rv1126.h | 251 ++++++++++++++++++ 1 file changed, 251 insertions(+) create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rv1126.h
diff --git a/arch/arm/include/asm/arch-rockchip/grf_rv1126.h b/arch/arm/include/asm/arch-rockchip/grf_rv1126.h new file mode 100644 index 0000000000..4e0488b91a --- /dev/null +++ b/arch/arm/include/asm/arch-rockchip/grf_rv1126.h @@ -0,0 +1,251 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd. + */ + +#ifndef _ASM_ARCH_GRF_RV1126_H +#define _ASM_ARCH_GRF_RV1126_H + +struct rv1126_grf { + unsigned int soc_con0; + unsigned int soc_con1; + unsigned int soc_con2; + unsigned int reserved0[1]; + unsigned int soc_status0; + unsigned int soc_status1; + unsigned int reserved1[2]; + unsigned int cpu_con0; + unsigned int cpu_con1; + unsigned int reserved2[2]; + unsigned int cpu_status0; + unsigned int reserved3[3]; + unsigned int noc_con0; + unsigned int noc_con1; + unsigned int noc_con2; + unsigned int noc_con3; + unsigned int usbhost_con0; + unsigned int usbhost_con1; + unsigned int usbhost_status0; + unsigned int usbotg_con0; + unsigned int usbotg_con1; + unsigned int usbotg_status0; + unsigned int usbotg_status1; + unsigned int usbotg_status2; + unsigned int mac_con0; + unsigned int mac_con1; + unsigned int mac_con2; + unsigned int reserved4[2]; + unsigned int mac_status0; + unsigned int mac_status1; + unsigned int mac_status2; + unsigned int mem_con0; + unsigned int mem_con1; + unsigned int mem_con2; + unsigned int mem_con3; + unsigned int reserved5[(0x100 - 0x09c) / 4 - 1]; + unsigned int tsadc_con0; + unsigned int reserved6[3]; + unsigned int chip_id; + unsigned int reserved7[(0x10000 - 0x110) / 4 - 1]; + unsigned int gpio0c_iomux_h; + unsigned int gpio0d_iomux_l; + unsigned int gpio0d_iomux_h; + unsigned int reserved8[1]; + unsigned int gpio1a_iomux_l; + unsigned int gpio1a_iomux_h; + unsigned int gpio1b_iomux_l; + unsigned int gpio1b_iomux_h; + unsigned int gpio1c_iomux_l; + unsigned int gpio1c_iomux_h; + unsigned int gpio1d_iomux_l; + unsigned int gpio1d_iomux_h; + unsigned int gpio2a_iomux_l; + unsigned int gpio2a_iomux_h; + unsigned int gpio2b_iomux_l; + unsigned int gpio2b_iomux_h; + unsigned int gpio2c_iomux_l; + unsigned int gpio2c_iomux_h; + unsigned int gpio2d_iomux_l; + unsigned int gpio2d_iomux_h; + unsigned int gpio3a_iomux_l; + unsigned int gpio3a_iomux_h; + unsigned int gpio3b_iomux_l; + unsigned int gpio3b_iomux_h; + unsigned int gpio3c_iomux_l; + unsigned int gpio3c_iomux_h; + unsigned int gpio3d_iomux_l; + unsigned int gpio3d_iomux_h; + unsigned int gpio4a_iomux_l; + unsigned int reserved9[3]; + unsigned int gpio0c_ds_h; + unsigned int gpio0d_ds_l; + unsigned int gpio0d_ds_h; + unsigned int reserved10[1]; + unsigned int gpio1a_ds_l; + unsigned int gpio1a_ds_h; + unsigned int gpio1b_ds_l; + unsigned int gpio1b_ds_h; + unsigned int gpio1c_ds_l; + unsigned int gpio1c_ds_h; + unsigned int gpio1d_ds_l; + unsigned int gpio1d_ds_h; + unsigned int gpio2a_ds_l; + unsigned int gpio2a_ds_h; + unsigned int gpio2b_ds_l; + unsigned int gpio2b_ds_h; + unsigned int gpio2c_ds_l; + unsigned int gpio2c_ds_h; + unsigned int gpio2d_ds_l; + unsigned int gpio2d_ds_h; + unsigned int gpio3a_ds_l; + unsigned int gpio3a_ds_h; + unsigned int gpio3b_ds_l; + unsigned int gpio3b_ds_h; + unsigned int gpio3c_ds_l; + unsigned int gpio3c_ds_h; + unsigned int gpio3d_ds_l; + unsigned int gpio3d_ds_h; + unsigned int gpio4a_ds_l; + unsigned int reserved12[3]; + unsigned int gpio0c_p_h; + unsigned int gpio0d_p; + unsigned int gpio1a_p; + unsigned int gpio1b_p; + unsigned int gpio1c_p; + unsigned int gpio1d_p; + unsigned int gpio2a_p; + unsigned int gpio2b_p; + unsigned int gpio2c_p; + unsigned int gpio2d_p; + unsigned int gpio3a_p; + unsigned int gpio3b_p; + unsigned int gpio3c_p; + unsigned int gpio3d_p; + unsigned int gpio4a_p; + unsigned int reserved13[1]; + unsigned int gpio0c_ie_h; + unsigned int gpio0d_ie; + unsigned int gpio1a_ie; + unsigned int gpio1b_ie; + unsigned int gpio1c_ie; + unsigned int gpio1d_ie; + unsigned int gpio2a_ie; + unsigned int gpio2b_ie; + unsigned int gpio2c_ie; + unsigned int gpio2d_ie; + unsigned int gpio3a_ie; + unsigned int gpio3b_ie; + unsigned int gpio3c_ie; + unsigned int gpio3d_ie; + unsigned int gpio4a_ie; + unsigned int reserved14[1]; + unsigned int gpio0c_smt_h; + unsigned int gpio0d_smt; + unsigned int gpio1a_smt; + unsigned int gpio1b_smt; + unsigned int gpio1c_smt; + unsigned int gpio1d_smt; + unsigned int gpio2a_smt; + unsigned int gpio2b_smt; + unsigned int gpio2c_smt; + unsigned int gpio2d_smt; + unsigned int gpio3a_smt; + unsigned int gpio3b_smt; + unsigned int gpio3c_smt; + unsigned int gpio3d_smt; + unsigned int gpio4a_smt; + unsigned int reserved15[(0x10200 - 0x101b8) / 4 - 1]; + unsigned int csiphy0_con; + unsigned int reserved16[1]; + unsigned int csiphy0_status; + unsigned int reserved17[1]; + unsigned int csiphy1_con; + unsigned int reserved18[1]; + unsigned int csiphy1_status; + unsigned int reserved19[1]; + unsigned int dsiphy_con; + unsigned int reserved20[3]; + unsigned int usbphy_con0; + unsigned int usbphy_con1; + unsigned int usbphy_con2; + unsigned int reserved21[3]; + unsigned int usbphy_status; + unsigned int reserved22[1]; + unsigned int cifio_con; + unsigned int sddetflt_con; + unsigned int uart2rx_low_con; + unsigned int reserved23[1]; + unsigned int iofunc_con0; + unsigned int iofunc_con1; + unsigned int iofunc_con2; + unsigned int iofunc_con3; + unsigned int usbphy0_cfg_con; + unsigned int usbphy0_cfg_addrin; + unsigned int usbphy0_cfg_addrout; + unsigned int usbphy0_cfg_dly_con; + unsigned int usbphy1_cfg_con; + unsigned int usbphy1_cfg_addrin; + unsigned int usbphy1_cfg_addrout; + unsigned int usbphy1_cfg_dly_con; + unsigned int reserved24[(0x10300 - 0x1028c) / 4 - 1]; + unsigned int usb_sig_detect_con; + unsigned int usb_sig_detect_status; + unsigned int usb_sig_detect_clr; + unsigned int reserved25[1]; + unsigned int usb_linestate_con; + unsigned int usb_disconnect_con; + unsigned int usb_bvalid_con; + unsigned int usb_id_con; +}; + +check_member(rv1126_grf, usb_id_con, 0x1031c); + +struct rv1126_pmugrf { + unsigned int gpio0a_iomux_l; + unsigned int gpio0a_iomux_h; + unsigned int gpio0b_iomux_l; + unsigned int gpio0b_iomux_h; + unsigned int gpio0c_iomux_l; + unsigned int reserved0[3]; + unsigned int gpio0a_ds_l; + unsigned int gpio0a_ds_h; + unsigned int gpio0b_ds_l; + unsigned int gpio0b_ds_h; + unsigned int gpio0c_ds_l; + unsigned int osc_ds; + unsigned int reserved1[2]; + unsigned int gpio0a_p; + unsigned int gpio0b_p; + unsigned int gpio0c_p_l; + unsigned int reserved2[1]; + unsigned int gpio0a_ie; + unsigned int gpio0b_ie; + unsigned int gpio0c_ie_l; + unsigned int reserved3[1]; + unsigned int gpio0a_smt; + unsigned int gpio0b_smt; + unsigned int gpio0c_smt_l; + unsigned int reserved4[(0x100 - 0x68) / 4 - 1]; + unsigned int soc_con[7]; + unsigned int reserved5[(0x140 - 0x118) / 4 - 1]; + unsigned int io_vsel; + unsigned int io_vret; + unsigned int reserved6[(0x180 - 0x144) / 4 - 1]; + unsigned int pmupvtm_clkdiv; + unsigned int reserved7[(0x200 - 0x180) / 4 - 1]; + unsigned int os_reg[12]; + unsigned int rstfunc_status; + unsigned int rstfunc_clr; + unsigned int reserved8[(0x380 - 0x234) / 4 - 1]; + unsigned int sd_detect_con; + unsigned int reserved9[3]; + unsigned int sd_detect_status; + unsigned int reserved10[3]; + unsigned int sd_detect_clr; + unsigned int reserved11[3]; + unsigned int sd_det_count; +}; + +check_member(rv1126_pmugrf, sd_det_count, 0x3b0); + +#endif
Thanks, - Kever
Changes for v2:
none
- (C) Copyright 2019 Rockchip Electronics Co., Ltd.
- unsigned int soc_con0;
- unsigned int soc_con1;
- unsigned int soc_con2;
- unsigned int reserved0[1];
- unsigned int soc_status0;
- unsigned int soc_status1;
- unsigned int reserved1[2];
- unsigned int cpu_con0;
- unsigned int cpu_con1;
- unsigned int reserved2[2];
- unsigned int cpu_status0;
- unsigned int reserved3[3];
- unsigned int noc_con0;
- unsigned int noc_con1;
- unsigned int noc_con2;
- unsigned int noc_con3;
- unsigned int usbhost_con0;
- unsigned int usbhost_con1;
- unsigned int usbhost_status0;
- unsigned int usbotg_con0;
- unsigned int usbotg_con1;
- unsigned int usbotg_status0;
- unsigned int usbotg_status1;
- unsigned int usbotg_status2;
- unsigned int mac_con0;
- unsigned int mac_con1;
- unsigned int mac_con2;
- unsigned int reserved4[2];
- unsigned int mac_status0;
- unsigned int mac_status1;
- unsigned int mac_status2;
- unsigned int mem_con0;
- unsigned int mem_con1;
- unsigned int mem_con2;
- unsigned int mem_con3;
- unsigned int reserved5[(0x100 - 0x09c) / 4 - 1];
- unsigned int tsadc_con0;
- unsigned int reserved6[3];
- unsigned int chip_id;
- unsigned int reserved7[(0x10000 - 0x110) / 4 - 1];
- unsigned int gpio0c_iomux_h;
- unsigned int gpio0d_iomux_l;
- unsigned int gpio0d_iomux_h;
- unsigned int reserved8[1];
- unsigned int gpio1a_iomux_l;
- unsigned int gpio1a_iomux_h;
- unsigned int gpio1b_iomux_l;
- unsigned int gpio1b_iomux_h;
- unsigned int gpio1c_iomux_l;
- unsigned int gpio1c_iomux_h;
- unsigned int gpio1d_iomux_l;
- unsigned int gpio1d_iomux_h;
- unsigned int gpio2a_iomux_l;
- unsigned int gpio2a_iomux_h;
- unsigned int gpio2b_iomux_l;
- unsigned int gpio2b_iomux_h;
- unsigned int gpio2c_iomux_l;
- unsigned int gpio2c_iomux_h;
- unsigned int gpio2d_iomux_l;
- unsigned int gpio2d_iomux_h;
- unsigned int gpio3a_iomux_l;
- unsigned int gpio3a_iomux_h;
- unsigned int gpio3b_iomux_l;
- unsigned int gpio3b_iomux_h;
- unsigned int gpio3c_iomux_l;
- unsigned int gpio3c_iomux_h;
- unsigned int gpio3d_iomux_l;
- unsigned int gpio3d_iomux_h;
- unsigned int gpio4a_iomux_l;
- unsigned int reserved9[3];
- unsigned int gpio0c_ds_h;
- unsigned int gpio0d_ds_l;
- unsigned int gpio0d_ds_h;
- unsigned int reserved10[1];
- unsigned int gpio1a_ds_l;
- unsigned int gpio1a_ds_h;
- unsigned int gpio1b_ds_l;
- unsigned int gpio1b_ds_h;
- unsigned int gpio1c_ds_l;
- unsigned int gpio1c_ds_h;
- unsigned int gpio1d_ds_l;
- unsigned int gpio1d_ds_h;
- unsigned int gpio2a_ds_l;
- unsigned int gpio2a_ds_h;
- unsigned int gpio2b_ds_l;
- unsigned int gpio2b_ds_h;
- unsigned int gpio2c_ds_l;
- unsigned int gpio2c_ds_h;
- unsigned int gpio2d_ds_l;
- unsigned int gpio2d_ds_h;
- unsigned int gpio3a_ds_l;
- unsigned int gpio3a_ds_h;
- unsigned int gpio3b_ds_l;
- unsigned int gpio3b_ds_h;
- unsigned int gpio3c_ds_l;
- unsigned int gpio3c_ds_h;
- unsigned int gpio3d_ds_l;
- unsigned int gpio3d_ds_h;
- unsigned int gpio4a_ds_l;
- unsigned int reserved12[3];
- unsigned int gpio0c_p_h;
- unsigned int gpio0d_p;
- unsigned int gpio1a_p;
- unsigned int gpio1b_p;
- unsigned int gpio1c_p;
- unsigned int gpio1d_p;
- unsigned int gpio2a_p;
- unsigned int gpio2b_p;
- unsigned int gpio2c_p;
- unsigned int gpio2d_p;
- unsigned int gpio3a_p;
- unsigned int gpio3b_p;
- unsigned int gpio3c_p;
- unsigned int gpio3d_p;
- unsigned int gpio4a_p;
- unsigned int reserved13[1];
- unsigned int gpio0c_ie_h;
- unsigned int gpio0d_ie;
- unsigned int gpio1a_ie;
- unsigned int gpio1b_ie;
- unsigned int gpio1c_ie;
- unsigned int gpio1d_ie;
- unsigned int gpio2a_ie;
- unsigned int gpio2b_ie;
- unsigned int gpio2c_ie;
- unsigned int gpio2d_ie;
- unsigned int gpio3a_ie;
- unsigned int gpio3b_ie;
- unsigned int gpio3c_ie;
- unsigned int gpio3d_ie;
- unsigned int gpio4a_ie;
- unsigned int reserved14[1];
- unsigned int gpio0c_smt_h;
- unsigned int gpio0d_smt;
- unsigned int gpio1a_smt;
- unsigned int gpio1b_smt;
- unsigned int gpio1c_smt;
- unsigned int gpio1d_smt;
- unsigned int gpio2a_smt;
- unsigned int gpio2b_smt;
- unsigned int gpio2c_smt;
- unsigned int gpio2d_smt;
- unsigned int gpio3a_smt;
- unsigned int gpio3b_smt;
- unsigned int gpio3c_smt;
- unsigned int gpio3d_smt;
- unsigned int gpio4a_smt;
- unsigned int reserved15[(0x10200 - 0x101b8) / 4 - 1];
- unsigned int csiphy0_con;
- unsigned int reserved16[1];
- unsigned int csiphy0_status;
- unsigned int reserved17[1];
- unsigned int csiphy1_con;
- unsigned int reserved18[1];
- unsigned int csiphy1_status;
- unsigned int reserved19[1];
- unsigned int dsiphy_con;
- unsigned int reserved20[3];
- unsigned int usbphy_con0;
- unsigned int usbphy_con1;
- unsigned int usbphy_con2;
- unsigned int reserved21[3];
- unsigned int usbphy_status;
- unsigned int reserved22[1];
- unsigned int cifio_con;
- unsigned int sddetflt_con;
- unsigned int uart2rx_low_con;
- unsigned int reserved23[1];
- unsigned int iofunc_con0;
- unsigned int iofunc_con1;
- unsigned int iofunc_con2;
- unsigned int iofunc_con3;
- unsigned int usbphy0_cfg_con;
- unsigned int usbphy0_cfg_addrin;
- unsigned int usbphy0_cfg_addrout;
- unsigned int usbphy0_cfg_dly_con;
- unsigned int usbphy1_cfg_con;
- unsigned int usbphy1_cfg_addrin;
- unsigned int usbphy1_cfg_addrout;
- unsigned int usbphy1_cfg_dly_con;
- unsigned int reserved24[(0x10300 - 0x1028c) / 4 - 1];
- unsigned int usb_sig_detect_con;
- unsigned int usb_sig_detect_status;
- unsigned int usb_sig_detect_clr;
- unsigned int reserved25[1];
- unsigned int usb_linestate_con;
- unsigned int usb_disconnect_con;
- unsigned int usb_bvalid_con;
- unsigned int usb_id_con;
- unsigned int gpio0a_iomux_l;
- unsigned int gpio0a_iomux_h;
- unsigned int gpio0b_iomux_l;
- unsigned int gpio0b_iomux_h;
- unsigned int gpio0c_iomux_l;
- unsigned int reserved0[3];
- unsigned int gpio0a_ds_l;
- unsigned int gpio0a_ds_h;
- unsigned int gpio0b_ds_l;
- unsigned int gpio0b_ds_h;
- unsigned int gpio0c_ds_l;
- unsigned int osc_ds;
- unsigned int gpio0a_p;
- unsigned int gpio0b_p;
- unsigned int gpio0c_p_l;
- unsigned int reserved2[1];
- unsigned int gpio0a_ie;
- unsigned int gpio0b_ie;
- unsigned int gpio0c_ie_l;
- unsigned int reserved3[1];
- unsigned int gpio0a_smt;
- unsigned int gpio0b_smt;
- unsigned int gpio0c_smt_l;
- unsigned int reserved4[(0x100 - 0x68) / 4 - 1];
- unsigned int soc_con[7];
- unsigned int reserved5[(0x140 - 0x118) / 4 - 1];
- unsigned int io_vsel;
- unsigned int io_vret;
- unsigned int reserved6[(0x180 - 0x144) / 4 - 1];
- unsigned int pmupvtm_clkdiv;
- unsigned int reserved7[(0x200 - 0x180) / 4 - 1];
- unsigned int os_reg[12];
- unsigned int rstfunc_status;
- unsigned int rstfunc_clr;
- unsigned int reserved8[(0x380 - 0x234) / 4 - 1];
- unsigned int sd_detect_con;
- unsigned int sd_detect_status;
- unsigned int reserved10[3];
- unsigned int sd_detect_clr;
- unsigned int reserved11[3];
- unsigned int sd_det_count;
Add pinctrl definitions for Rockchip RV1126.
arch/arm/dts/rv1126-pinctrl.dtsi | 302 +++++++++++++++++++++++++++++++ 1 file changed, 302 insertions(+) create mode 100644 arch/arm/dts/rv1126-pinctrl.dtsi
diff --git a/arch/arm/dts/rv1126-pinctrl.dtsi b/arch/arm/dts/rv1126-pinctrl.dtsi new file mode 100644 index 0000000000..93e2885e87 --- /dev/null +++ b/arch/arm/dts/rv1126-pinctrl.dtsi @@ -0,0 +1,302 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include <dt-bindings/pinctrl/rockchip.h> +#include "rockchip-pinconf.dtsi" + +/* + * This file is auto generated by pin2dts tool, please keep these code + * by adding changes at end of this file. + */ +&pinctrl { + emmc { + /omit-if-no-ref/ + emmc_rstnout: emmc-rstnout { + rockchip,pins = + /* emmc_rstn */ + <1 RK_PA3 2 &pcfg_pull_none>; + }; + /omit-if-no-ref/ + emmc_bus8: emmc-bus8 { + rockchip,pins = + /* emmc_d0 */ + <0 RK_PC4 2 &pcfg_pull_up_drv_level_2>, + /* emmc_d1 */ + <0 RK_PC5 2 &pcfg_pull_up_drv_level_2>, + /* emmc_d2 */ + <0 RK_PC6 2 &pcfg_pull_up_drv_level_2>, + /* emmc_d3 */ + <0 RK_PC7 2 &pcfg_pull_up_drv_level_2>, + /* emmc_d4 */ + <0 RK_PD0 2 &pcfg_pull_up_drv_level_2>, + /* emmc_d5 */ + <0 RK_PD1 2 &pcfg_pull_up_drv_level_2>, + /* emmc_d6 */ + <0 RK_PD2 2 &pcfg_pull_up_drv_level_2>, + /* emmc_d7 */ + <0 RK_PD3 2 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + emmc_clk: emmc-clk { + rockchip,pins = + /* emmc_clko */ + <0 RK_PD7 2 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + emmc_cmd: emmc-cmd { + rockchip,pins = + /* emmc_cmd */ + <0 RK_PD5 2 &pcfg_pull_up_drv_level_2>; + }; + }; + i2c0 { + /omit-if-no-ref/ + i2c0_xfer: i2c0-xfer { + rockchip,pins = + /* i2c0_scl */ + <0 RK_PB4 1 &pcfg_pull_none_drv_level_0_smt>, + /* i2c0_sda */ + <0 RK_PB5 1 &pcfg_pull_none_drv_level_0_smt>; + }; + }; + i2c1 { + /omit-if-no-ref/ + i2c1_xfer: i2c1-xfer { + rockchip,pins = + /* i2c1_scl */ + <1 RK_PD3 1 &pcfg_pull_none_drv_level_0_smt>, + /* i2c1_sda */ + <1 RK_PD2 1 &pcfg_pull_none_drv_level_0_smt>; + }; + }; + i2c2 { + /omit-if-no-ref/ + i2c2_xfer: i2c2-xfer { + rockchip,pins = + /* i2c2_scl */ + <0 RK_PC2 1 &pcfg_pull_none_drv_level_0_smt>, + /* i2c2_sda */ + <0 RK_PC3 1 &pcfg_pull_none_drv_level_0_smt>; + }; + }; + i2c3 { + /omit-if-no-ref/ + i2c3m0_xfer: i2c3m0-xfer { + rockchip,pins = + /* i2c3_scl_m0 */ + <3 RK_PA4 5 &pcfg_pull_none_drv_level_0_smt>, + /* i2c3_sda_m0 */ + <3 RK_PA5 5 &pcfg_pull_none_drv_level_0_smt>; + }; + /omit-if-no-ref/ + i2c3m1_xfer: i2c3m1-xfer { + rockchip,pins = + /* i2c3_scl_m1 */ + <2 RK_PD4 7 &pcfg_pull_none_drv_level_0_smt>, + /* i2c3_sda_m1 */ + <2 RK_PD5 7 &pcfg_pull_none_drv_level_0_smt>; + }; + /omit-if-no-ref/ + i2c3m2_xfer: i2c3m2-xfer { + rockchip,pins = + /* i2c3_scl_m2 */ + <1 RK_PD6 3 &pcfg_pull_none_drv_level_0_smt>, + /* i2c3_sda_m2 */ + <1 RK_PD7 3 &pcfg_pull_none_drv_level_0_smt>; + }; + }; + i2c4 { + /omit-if-no-ref/ + i2c4m0_xfer: i2c4m0-xfer { + rockchip,pins = + /* i2c4_scl_m0 */ + <3 RK_PA0 7 &pcfg_pull_none_drv_level_0_smt>, + /* i2c4_sda_m0 */ + <3 RK_PA1 7 &pcfg_pull_none_drv_level_0_smt>; + }; + /omit-if-no-ref/ + i2c4m1_xfer: i2c4m1-xfer { + rockchip,pins = + /* i2c4_scl_m1 */ + <4 RK_PA0 4 &pcfg_pull_none_drv_level_0_smt>, + /* i2c4_sda_m1 */ + <4 RK_PA1 4 &pcfg_pull_none_drv_level_0_smt>; + }; + }; + i2c5 { + /omit-if-no-ref/ + i2c5m0_xfer: i2c5m0-xfer { + rockchip,pins = + /* i2c5_scl_m0 */ + <2 RK_PA5 7 &pcfg_pull_none_drv_level_0_smt>, + /* i2c5_sda_m0 */ + <2 RK_PB3 7 &pcfg_pull_none_drv_level_0_smt>; + }; + /omit-if-no-ref/ + i2c5m1_xfer: i2c5m1-xfer { + rockchip,pins = + /* i2c5_scl_m1 */ + <3 RK_PB0 5 &pcfg_pull_none_drv_level_0_smt>, + /* i2c5_sda_m1 */ + <3 RK_PB1 5 &pcfg_pull_none_drv_level_0_smt>; + }; + /omit-if-no-ref/ + i2c5m2_xfer: i2c5m2-xfer { + rockchip,pins = + /* i2c5_scl_m2 */ + <1 RK_PD0 4 &pcfg_pull_none_drv_level_0_smt>, + /* i2c5_sda_m2 */ + <1 RK_PD1 4 &pcfg_pull_none_drv_level_0_smt>; + }; + }; + sdmmc0 { + /omit-if-no-ref/ + sdmmc0_bus4: sdmmc0-bus4 { + rockchip,pins = + /* sdmmc0_d0 */ + <1 RK_PA4 1 &pcfg_pull_up_drv_level_2>, + /* sdmmc0_d1 */ + <1 RK_PA5 1 &pcfg_pull_up_drv_level_2>, + /* sdmmc0_d2 */ + <1 RK_PA6 1 &pcfg_pull_up_drv_level_2>, + /* sdmmc0_d3 */ + <1 RK_PA7 1 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + sdmmc0_clk: sdmmc0-clk { + rockchip,pins = + /* sdmmc0_clk */ + <1 RK_PB0 1 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + sdmmc0_cmd: sdmmc0-cmd { + rockchip,pins = + /* sdmmc0_cmd */ + <1 RK_PB1 1 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + sdmmc0_det: sdmmc0-det { + rockchip,pins = + <0 RK_PA3 1 &pcfg_pull_none>; + }; + /omit-if-no-ref/ + sdmmc0_pwr: sdmmc0-pwr { + rockchip,pins = + <0 RK_PC0 1 &pcfg_pull_none>; + }; + }; + sdmmc1 { + /omit-if-no-ref/ + sdmmc1_bus4: sdmmc1-bus4 { + rockchip,pins = + /* sdmmc1_d0 */ + <1 RK_PB4 1 &pcfg_pull_up_drv_level_2>, + /* sdmmc1_d1 */ + <1 RK_PB5 1 &pcfg_pull_up_drv_level_2>, + /* sdmmc1_d2 */ + <1 RK_PB6 1 &pcfg_pull_up_drv_level_2>, + /* sdmmc1_d3 */ + <1 RK_PB7 1 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + sdmmc1_clk: sdmmc1-clk { + rockchip,pins = + /* sdmmc1_clk */ + <1 RK_PB2 1 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + sdmmc1_cmd: sdmmc1-cmd { + rockchip,pins = + /* sdmmc1_cmd */ + <1 RK_PB3 1 &pcfg_pull_up_drv_level_2>; + }; + /omit-if-no-ref/ + sdmmc1_det: sdmmc1-det { + rockchip,pins = + <1 RK_PD0 2 &pcfg_pull_none>; + }; + /omit-if-no-ref/ + sdmmc1_pwr: sdmmc1-pwr { + rockchip,pins = + <1 RK_PD1 2 &pcfg_pull_none>; + }; + }; + uart0 { + /omit-if-no-ref/ + uart0_xfer: uart0-xfer { + rockchip,pins = + /* uart0_rx */ + <1 RK_PC2 1 &pcfg_pull_up>, + /* uart0_tx */ + <1 RK_PC3 1 &pcfg_pull_up>; + }; + /omit-if-no-ref/ + uart0_ctsn: uart0-ctsn { + rockchip,pins = + <1 RK_PC1 1 &pcfg_pull_none>; + }; + /omit-if-no-ref/ + uart0_rtsn: uart0-rtsn { + rockchip,pins = + <1 RK_PC0 1 &pcfg_pull_none>; + }; + /omit-if-no-ref/ + uart0_rtsn_gpio: uart0-rts-pin { + rockchip,pins = + <1 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + uart1 { + /omit-if-no-ref/ + uart1m0_xfer: uart1m0-xfer { + rockchip,pins = + /* uart1_rx_m0 */ + <0 RK_PB7 2 &pcfg_pull_up>, + /* uart1_tx_m0 */ + <0 RK_PB6 2 &pcfg_pull_up>; + }; + }; + uart2 { + /omit-if-no-ref/ + uart2m1_xfer: uart2m1-xfer { + rockchip,pins = + /* uart2_rx_m1 */ + <3 RK_PA3 1 &pcfg_pull_up>, + /* uart2_tx_m1 */ + <3 RK_PA2 1 &pcfg_pull_up>; + }; + }; + uart3 { + /omit-if-no-ref/ + uart3m0_xfer: uart3m0-xfer { + rockchip,pins = + /* uart3_rx_m0 */ + <3 RK_PC7 4 &pcfg_pull_up>, + /* uart3_tx_m0 */ + <3 RK_PC6 4 &pcfg_pull_up>; + }; + }; + uart4 { + /omit-if-no-ref/ + uart4m0_xfer: uart4m0-xfer { + rockchip,pins = + /* uart4_rx_m0 */ + <3 RK_PA5 4 &pcfg_pull_up>, + /* uart4_tx_m0 */ + <3 RK_PA4 4 &pcfg_pull_up>; + }; + }; + uart5 { + /omit-if-no-ref/ + uart5m0_xfer: uart5m0-xfer { + rockchip,pins = + /* uart5_rx_m0 */ + <3 RK_PA7 4 &pcfg_pull_up>, + /* uart5_tx_m0 */ + <3 RK_PA6 4 &pcfg_pull_up>; + }; + }; +};
Thanks, - Kever
Changes for v2:
none
- Copyright (c) 2020 Fuzhou Rockchip Electronics Co., Ltd
- This file is auto generated by pin2dts tool, please keep these code
- by adding changes at end of this file.
+&pinctrl {
- emmc {
/omit-if-no-ref/
rockchip,pins =
/* emmc_rstn */
/omit-if-no-ref/
rockchip,pins =
/* emmc_d0 */
/* emmc_d1 */
/* emmc_d2 */
/* emmc_d3 */
/* emmc_d4 */
/* emmc_d5 */
/* emmc_d6 */
/* emmc_d7 */
/omit-if-no-ref/
rockchip,pins =
/* emmc_clko */
/omit-if-no-ref/
rockchip,pins =
/* emmc_cmd */
- i2c0 {
/omit-if-no-ref/
rockchip,pins =
/* i2c0_scl */
/* i2c0_sda */
- i2c1 {
/omit-if-no-ref/
rockchip,pins =
/* i2c1_scl */
/* i2c1_sda */
- i2c2 {
/omit-if-no-ref/
rockchip,pins =
/* i2c2_scl */
/* i2c2_sda */
- i2c3 {
/omit-if-no-ref/
rockchip,pins =
/* i2c3_scl_m0 */
/* i2c3_sda_m0 */
/omit-if-no-ref/
rockchip,pins =
/* i2c3_scl_m1 */
/* i2c3_sda_m1 */
/omit-if-no-ref/
rockchip,pins =
/* i2c3_scl_m2 */
/* i2c3_sda_m2 */
- i2c4 {
/omit-if-no-ref/
rockchip,pins =
/* i2c4_scl_m0 */
/* i2c4_sda_m0 */
/omit-if-no-ref/
rockchip,pins =
/* i2c4_scl_m1 */
/* i2c4_sda_m1 */
- i2c5 {
/omit-if-no-ref/
rockchip,pins =
/* i2c5_scl_m0 */
/* i2c5_sda_m0 */
/omit-if-no-ref/
rockchip,pins =
/* i2c5_scl_m1 */
/* i2c5_sda_m1 */
/omit-if-no-ref/
rockchip,pins =
/* i2c5_scl_m2 */
/* i2c5_sda_m2 */
- sdmmc0 {
/omit-if-no-ref/
rockchip,pins =
/* sdmmc0_d0 */
/* sdmmc0_d1 */
/* sdmmc0_d2 */
/* sdmmc0_d3 */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc0_clk */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc0_cmd */
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
- sdmmc1 {
/omit-if-no-ref/
rockchip,pins =
/* sdmmc1_d0 */
/* sdmmc1_d1 */
/* sdmmc1_d2 */
/* sdmmc1_d3 */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc1_clk */
/omit-if-no-ref/
rockchip,pins =
/* sdmmc1_cmd */
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
- uart0 {
/omit-if-no-ref/
rockchip,pins =
/* uart0_rx */
/* uart0_tx */
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
/omit-if-no-ref/
rockchip,pins =
- uart1 {
/omit-if-no-ref/
rockchip,pins =
/* uart1_rx_m0 */
/* uart1_tx_m0 */
- uart2 {
/omit-if-no-ref/
rockchip,pins =
/* uart2_rx_m1 */
/* uart2_tx_m1 */
- uart3 {
/omit-if-no-ref/
rockchip,pins =
/* uart3_rx_m0 */
/* uart3_tx_m0 */
- uart4 {
/omit-if-no-ref/
rockchip,pins =
/* uart4_rx_m0 */
/* uart4_tx_m0 */
- uart5 {
/omit-if-no-ref/
rockchip,pins =
/* uart5_rx_m0 */
/* uart5_tx_m0 */
RV1126 is a high-performance vision processor SoC for IPC/CVR, especially for AI related application.
It is based on quad-core ARM Cortex-A7 32-bit core which integrates NEON and FPU. There is a 32KB I-cache and 32KB D-cache for each core and 512KB unified L2 cache. It has build-in NPU supports INT8/INT16 hybrid operation and computing power is up to 2.0TOPs.
This patch add basic core dtsi support.
Signed-off-by: Jon Lin jon.lin@rock-chips.com Signed-off-by: Sugar Zhang sugar.zhang@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - update header filename
arch/arm/dts/rv1126.dtsi | 500 +++++++++++++++++++++++++++++++++++++++ 1 file changed, 500 insertions(+) create mode 100644 arch/arm/dts/rv1126.dtsi
diff --git a/arch/arm/dts/rv1126.dtsi b/arch/arm/dts/rv1126.dtsi new file mode 100644 index 0000000000..235bfb126e --- /dev/null +++ b/arch/arm/dts/rv1126.dtsi @@ -0,0 +1,500 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd. + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include <dt-bindings/clock/rockchip,rv1126-cru.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/pinctrl/rockchip.h> +#include <dt-bindings/power/rockchip,rv1126-power.h> +#include <dt-bindings/soc/rockchip,boot-mode.h> + +/ { + #address-cells = <1>; + #size-cells = <1>; + + compatible = "rockchip,rv1126"; + + interrupt-parent = <&gic>; + + aliases { + i2c0 = &i2c0; + i2c1 = &i2c1; + i2c2 = &i2c2; + i2c3 = &i2c3; + i2c4 = &i2c4; + i2c5 = &i2c5; + serial0 = &uart0; + serial1 = &uart1; + serial2 = &uart2; + serial3 = &uart3; + serial4 = &uart4; + serial5 = &uart5; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@f00 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf00>; + clocks = <&cru ARMCLK>; + }; + + cpu1: cpu@f01 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf01>; + clocks = <&cru ARMCLK>; + }; + + cpu2: cpu@f02 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf02>; + clocks = <&cru ARMCLK>; + }; + + cpu3: cpu@f03 { + device_type = "cpu"; + compatible = "arm,cortex-a7"; + reg = <0xf03>; + clocks = <&cru ARMCLK>; + }; + }; + + arm-pmu { + compatible = "arm,cortex-a7-pmu"; + interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; + interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; + }; + + timer { + compatible = "arm,armv7-timer"; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, + <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, + <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, + <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + clock-frequency = <24000000>; + }; + + xin24m: oscillator { + compatible = "fixed-clock"; + clock-frequency = <24000000>; + clock-output-names = "xin24m"; + #clock-cells = <0>; + }; + + grf: syscon@fe000000 { + compatible = "rockchip,rv1126-grf", "syscon", "simple-mfd"; + reg = <0xfe000000 0x20000>; + }; + + pmugrf: syscon@fe020000 { + compatible = "rockchip,rv1126-pmugrf", "syscon", "simple-mfd"; + reg = <0xfe020000 0x1000>; + + pmu_io_domains: io-domains { + compatible = "rockchip,rv1126-pmu-io-voltage-domain"; + status = "disabled"; + }; + }; + + qos_emmc: qos@fe860000 { + compatible = "rockchip,rv1126-qos", "syscon"; + reg = <0xfe860000 0x20>; + }; + + qos_nandc: qos@fe860080 { + compatible = "rockchip,rv1126-qos", "syscon"; + reg = <0xfe860080 0x20>; + }; + + qos_sfc: qos@fe860200 { + compatible = "rockchip,rv1126-qos", "syscon"; + reg = <0xfe860200 0x20>; + }; + + qos_sdio: qos@fe86c000 { + compatible = "rockchip,rv1126-qos", "syscon"; + reg = <0xfe86c000 0x20>; + }; + + gic: interrupt-controller@feff0000 { + compatible = "arm,gic-400"; + interrupt-controller; + #interrupt-cells = <3>; + #address-cells = <0>; + + reg = <0xfeff1000 0x1000>, + <0xfeff2000 0x2000>, + <0xfeff4000 0x2000>, + <0xfeff6000 0x2000>; + interrupts = <GIC_PPI 9 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; + }; + + pmu: power-management@ff3e0000 { + compatible = "rockchip,rv1126-pmu", "syscon", "simple-mfd"; + reg = <0xff3e0000 0x1000>; + + power: power-controller { + compatible = "rockchip,rv1126-power-controller"; + #power-domain-cells = <1>; + #address-cells = <1>; + #size-cells = <0>; + + power-domain@RV1126_PD_NVM { + reg = <RV1126_PD_NVM>; + clocks = <&cru HCLK_EMMC>, + <&cru CLK_EMMC>, + <&cru HCLK_NANDC>, + <&cru CLK_NANDC>, + <&cru HCLK_SFC>, + <&cru HCLK_SFCXIP>, + <&cru SCLK_SFC>; + pm_qos = <&qos_emmc>, + <&qos_nandc>, + <&qos_sfc>; + #power-domain-cells = <0>; + }; + + power-domain@RV1126_PD_SDIO { + reg = <RV1126_PD_SDIO>; + clocks = <&cru HCLK_SDIO>, + <&cru CLK_SDIO>; + pm_qos = <&qos_sdio>; + #power-domain-cells = <0>; + }; + }; + }; + + i2c0: i2c@ff3f0000 { + compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; + reg = <0xff3f0000 0x1000>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pmucru CLK_I2C0>, <&pmucru PCLK_I2C0>; + clock-names = "i2c", "pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c0_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c2: i2c@ff400000 { + compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; + reg = <0xff400000 0x1000>; + interrupts = <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH>; + rockchip,grf = <&pmugrf>; + clocks = <&pmucru CLK_I2C2>, <&pmucru PCLK_I2C2>; + clock-names = "i2c", "pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + dmac: dma-controller@ff4e0000 { + compatible = "arm,pl330", "arm,primecell"; + reg = <0xff4e0000 0x4000>; + interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + arm,pl330-periph-burst; + clocks = <&cru ACLK_DMAC>; + clock-names = "apb_pclk"; + }; + + uart1: serial@ff410000 { + compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; + reg = <0xff410000 0x100>; + interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&pmucru SCLK_UART1>, <&pmucru PCLK_UART1>; + clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac 7>, <&dmac 6>; + pinctrl-names = "default"; + pinctrl-0 = <&uart1m0_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + pmucru: clock-controller@ff480000 { + compatible = "rockchip,rv1126-pmucru"; + reg = <0xff480000 0x1000>; + rockchip,grf = <&grf>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + cru: clock-controller@ff490000 { + compatible = "rockchip,rv1126-cru"; + reg = <0xff490000 0x1000>; + clocks = <&xin24m>; + clock-names = "xin24m"; + rockchip,grf = <&grf>; + #clock-cells = <1>; + #reset-cells = <1>; + }; + + i2c1: i2c@ff510000 { + compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; + reg = <0xff510000 0x1000>; + interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru CLK_I2C1>, <&cru PCLK_I2C1>; + clock-names = "i2c", "pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c3: i2c@ff520000 { + compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; + reg = <0xff520000 0x1000>; + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru CLK_I2C3>, <&cru PCLK_I2C3>; + clock-names = "i2c", "pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c3m0_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c4: i2c@ff530000 { + compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; + reg = <0xff530000 0x1000>; + interrupts = <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru CLK_I2C4>, <&cru PCLK_I2C4>; + clock-names = "i2c", "pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c4m0_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + i2c5: i2c@ff540000 { + compatible = "rockchip,rv1126-i2c", "rockchip,rk3399-i2c"; + reg = <0xff540000 0x1000>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru CLK_I2C5>, <&cru PCLK_I2C5>; + clock-names = "i2c", "pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&i2c5m0_xfer>; + #address-cells = <1>; + #size-cells = <0>; + status = "disabled"; + }; + + uart0: serial@ff560000 { + compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; + reg = <0xff560000 0x100>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; + clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac 5>, <&dmac 4>; + pinctrl-names = "default"; + pinctrl-0 = <&uart0_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart2: serial@ff570000 { + compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; + reg = <0xff570000 0x100>; + interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; + clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac 9>, <&dmac 8>; + pinctrl-names = "default"; + pinctrl-0 = <&uart2m1_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart3: serial@ff580000 { + compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; + reg = <0xff580000 0x100>; + interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; + clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac 11>, <&dmac 10>; + pinctrl-names = "default"; + pinctrl-0 = <&uart3m0_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart4: serial@ff590000 { + compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; + reg = <0xff590000 0x100>; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; + clock-names = "baudclk", "apb_pclk"; + dmas = <&dmac 13>, <&dmac 12>; + pinctrl-names = "default"; + pinctrl-0 = <&uart4m0_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + uart5: serial@ff5a0000 { + compatible = "rockchip,rv1126-uart", "snps,dw-apb-uart"; + reg = <0xff5a0000 0x100>; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <24000000>; + clocks = <&cru SCLK_UART5>, <&cru PCLK_UART5>; + dmas = <&dmac 15>, <&dmac 14>; + clock-names = "baudclk", "apb_pclk"; + pinctrl-names = "default"; + pinctrl-0 = <&uart5m0_xfer>; + reg-shift = <2>; + reg-io-width = <4>; + status = "disabled"; + }; + + saradc: saradc@ff5e0000 { + compatible = "rockchip,rk3399-saradc"; + reg = <0xff5e0000 0x100>; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + #io-channel-cells = <1>; + clocks = <&cru CLK_SARADC>, <&cru PCLK_SARADC>; + clock-names = "saradc", "apb_pclk"; + resets = <&cru SRST_SARADC_P>; + reset-names = "saradc-apb"; + status = "disabled"; + }; + + timer: timer@ff660000 { + compatible = "rockchip,rk3288-timer"; + reg = <0xff660000 0x20>; + interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_TIMER>, <&cru CLK_TIMER0>; + clock-names = "pclk", "timer"; + }; + + emmc: mmc@ffc50000 { + compatible = "rockchip,rv1126-dw-mshc", "rockchip,rk3288-dw-mshc"; + reg = <0xffc50000 0x4000>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_EMMC>, <&cru CLK_EMMC>, + <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + max-frequency = <200000000>; + power-domains = <&power RV1126_PD_NVM>; + status = "disabled"; + }; + + sdmmc: mmc@ffc60000 { + compatible = "rockchip,rv1126-dw-mshc", "rockchip,rk3288-dw-mshc"; + reg = <0xffc60000 0x4000>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_SDMMC>, <&cru CLK_SDMMC>, + <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + max-frequency = <200000000>; + status = "disabled"; + }; + + sdio: mmc@ffc70000 { + compatible = "rockchip,rv1126-dw-mshc", "rockchip,rk3288-dw-mshc"; + reg = <0xffc70000 0x4000>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru HCLK_SDIO>, <&cru CLK_SDIO>, + <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; + clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; + fifo-depth = <0x100>; + max-frequency = <200000000>; + power-domains = <&power RV1126_PD_SDIO>; + status = "disabled"; + }; + + pinctrl: pinctrl { + compatible = "rockchip,rv1126-pinctrl"; + rockchip,grf = <&grf>; + rockchip,pmu = <&pmugrf>; + #address-cells = <1>; + #size-cells = <1>; + ranges; + + gpio0: gpio0@ff460000 { + compatible = "rockchip,gpio-bank"; + reg = <0xff460000 0x100>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&pmucru PCLK_GPIO0>, <&pmucru DBCLK_GPIO0>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio1: gpio1@ff620000 { + compatible = "rockchip,gpio-bank"; + reg = <0xff620000 0x100>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO1>, <&cru DBCLK_GPIO1>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio2: gpio2@ff630000 { + compatible = "rockchip,gpio-bank"; + reg = <0xff630000 0x100>; + interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO2>, <&cru DBCLK_GPIO2>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio3: gpio3@ff640000 { + compatible = "rockchip,gpio-bank"; + reg = <0xff640000 0x100>; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO3>, <&cru DBCLK_GPIO3>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + + gpio4: gpio4@ff650000 { + compatible = "rockchip,gpio-bank"; + reg = <0xff650000 0x100>; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&cru PCLK_GPIO4>, <&cru DBCLK_GPIO4>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; +}; + +#include "rv1126-pinctrl.dtsi"
Hi Jagan,
Does this dtsi already merge in kernel?
Thanks,
- Kever
Changes for v2:
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd.
- #address-cells = <1>;
- #size-cells = <1>;
- compatible = "rockchip,rv1126";
- interrupt-parent = <&gic>;
- aliases {
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
serial5 = &uart5;
- cpus {
#size-cells = <0>;
cpu0: cpu@f00 {
reg = <0xf00>;
cpu1: cpu@f01 {
reg = <0xf01>;
cpu2: cpu@f02 {
reg = <0xf02>;
cpu3: cpu@f03 {
reg = <0xf03>;
- arm-pmu {
- timer {
- xin24m: oscillator {
#clock-cells = <0>;
- grf: syscon@fe000000 {
- pmugrf: syscon@fe020000 {
- qos_emmc: qos@fe860000 {
- qos_nandc: qos@fe860080 {
- qos_sfc: qos@fe860200 {
- qos_sdio: qos@fe86c000 {
- gic: interrupt-controller@feff0000 {
- pmu: power-management@ff3e0000 {
#size-cells = <0>;
<&cru CLK_EMMC>,
<&cru HCLK_NANDC>,
<&cru CLK_NANDC>,
<&cru HCLK_SFC>,
<&cru HCLK_SFCXIP>,
<&cru SCLK_SFC>;
<&qos_nandc>,
<&qos_sfc>;
<&cru CLK_SDIO>;
- i2c0: i2c@ff3f0000 {
#size-cells = <0>;
- i2c2: i2c@ff400000 {
#size-cells = <0>;
- dmac: dma-controller@ff4e0000 {
#dma-cells = <1>;
- uart1: serial@ff410000 {
reg-shift = <2>;
reg-io-width = <4>;
- pmucru: clock-controller@ff480000 {
#clock-cells = <1>;
#reset-cells = <1>;
- cru: clock-controller@ff490000 {
clocks = <&xin24m>;
#clock-cells = <1>;
#reset-cells = <1>;
- i2c1: i2c@ff510000 {
#size-cells = <0>;
- i2c3: i2c@ff520000 {
#size-cells = <0>;
- i2c4: i2c@ff530000 {
#size-cells = <0>;
- i2c5: i2c@ff540000 {
#size-cells = <0>;
- uart0: serial@ff560000 {
reg-shift = <2>;
reg-io-width = <4>;
- uart2: serial@ff570000 {
reg-shift = <2>;
reg-io-width = <4>;
- uart3: serial@ff580000 {
reg-shift = <2>;
reg-io-width = <4>;
- uart4: serial@ff590000 {
reg-shift = <2>;
reg-io-width = <4>;
- uart5: serial@ff5a0000 {
reg-shift = <2>;
reg-io-width = <4>;
- saradc: saradc@ff5e0000 {
- timer: timer@ff660000 {
- emmc: mmc@ffc50000 {
- sdmmc: mmc@ffc60000 {
- sdio: mmc@ffc70000 {
- pinctrl: pinctrl {
#size-cells = <1>;
ranges;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
On Thu, 1 Sept 2022 at 18:46, Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
Nothing yet. If you apply I can send rebased dts version once Heiko is picked or will send it to complete the next version once Linux is merged.
Jagan.
Rockchip RV1126 is a high-performance vision processor SoC for IPC/CVR, especially for AI related application.
Add arch core support for it.
arch/arm/include/asm/arch-rv1126/boot0.h | 11 ++++ arch/arm/include/asm/arch-rv1126/gpio.h | 11 ++++ arch/arm/mach-rockchip/Kconfig | 46 ++++++++++++++ arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/rv1126/Kconfig | 43 +++++++++++++ arch/arm/mach-rockchip/rv1126/Makefile | 13 ++++ arch/arm/mach-rockchip/rv1126/clk_rv1126.c | 33 ++++++++++ arch/arm/mach-rockchip/rv1126/rv1126.c | 63 +++++++++++++++++++ arch/arm/mach-rockchip/rv1126/syscon_rv1126.c | 47 ++++++++++++++ common/spl/Kconfig.tpl | 2 +- 10 files changed, 269 insertions(+), 1 deletion(-) create mode 100644 arch/arm/include/asm/arch-rv1126/boot0.h create mode 100644 arch/arm/include/asm/arch-rv1126/gpio.h create mode 100644 arch/arm/mach-rockchip/rv1126/Kconfig create mode 100644 arch/arm/mach-rockchip/rv1126/Makefile create mode 100644 arch/arm/mach-rockchip/rv1126/clk_rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/syscon_rv1126.c
diff --git a/arch/arm/include/asm/arch-rv1126/boot0.h b/arch/arm/include/asm/arch-rv1126/boot0.h new file mode 100644 index 0000000000..2e78b074ad --- /dev/null +++ b/arch/arm/include/asm/arch-rv1126/boot0.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ + +#ifndef __ASM_ARCH_BOOT0_H__ +#define __ASM_ARCH_BOOT0_H__ + +#include <asm/arch-rockchip/boot0.h> + +#endif diff --git a/arch/arm/include/asm/arch-rv1126/gpio.h b/arch/arm/include/asm/arch-rv1126/gpio.h new file mode 100644 index 0000000000..eca79d5159 --- /dev/null +++ b/arch/arm/include/asm/arch-rv1126/gpio.h @@ -0,0 +1,11 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + */ + +#ifndef __ASM_ARCH_GPIO_H__ +#define __ASM_ARCH_GPIO_H__ + +#include <asm/arch-rockchip/gpio.h> + +#endif diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index c561a77e6a..19fa6a4659 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -301,6 +301,51 @@ config ROCKCHIP_RV1108 The Rockchip RV1108 is a ARM-based SoC with a single-core Cortex-A7 and a DSP.
+config ROCKCHIP_RV1126 + bool "Support Rockchip RV1126" + select CPU_V7A + select SKIP_LOWLEVEL_INIT_ONLY + select TPL + select SUPPORT_TPL + select TPL_NEEDS_SEPARATE_STACK + select TPL_ROCKCHIP_BACK_TO_BROM + select SPL + select SUPPORT_SPL + select SPL_STACK_R + select CLK + select FIT + select PINCTRL + select RAM + select ROCKCHIP_SDRAM_COMMON + select REGMAP + select SYSCON + select DM_PMIC + select DM_REGULATOR_FIXED + select DM_RESET + select REGULATOR_RK8XX + select PMIC_RK8XX + select BOARD_LATE_INIT + imply ROCKCHIP_COMMON_BOARD + imply TPL_DM + imply TPL_LIBCOMMON_SUPPORT + imply TPL_LIBGENERIC_SUPPORT + imply TPL_OF_CONTROL + imply TPL_OF_PLATDATA + imply TPL_RAM + imply TPL_ROCKCHIP_COMMON_BOARD + imply TPL_SERIAL + imply SPL_CLK + imply SPL_DM + imply SPL_DRIVERS_MISC + imply SPL_LIBCOMMON_SUPPORT + imply SPL_LIBGENERIC_SUPPORT + imply SPL_OF_CONTROL + imply SPL_RAM + imply SPL_REGMAP + imply SPL_ROCKCHIP_COMMON_BOARD + imply SPL_SERIAL + imply SPL_SYSCON + config ROCKCHIP_USB_UART bool "Route uart output to usb pins" help @@ -448,4 +493,5 @@ source "arch/arm/mach-rockchip/rk3368/Kconfig" source "arch/arm/mach-rockchip/rk3399/Kconfig" source "arch/arm/mach-rockchip/rk3568/Kconfig" source "arch/arm/mach-rockchip/rv1108/Kconfig" +source "arch/arm/mach-rockchip/rv1126/Kconfig" endif diff --git a/arch/arm/mach-rockchip/Makefile b/arch/arm/mach-rockchip/Makefile index 6c1c7b8a10..32138fa723 100644 --- a/arch/arm/mach-rockchip/Makefile +++ b/arch/arm/mach-rockchip/Makefile @@ -45,6 +45,7 @@ obj-$(CONFIG_ROCKCHIP_RK3368) += rk3368/ obj-$(CONFIG_ROCKCHIP_RK3399) += rk3399/ obj-$(CONFIG_ROCKCHIP_RK3568) += rk3568/ obj-$(CONFIG_ROCKCHIP_RV1108) += rv1108/ +obj-$(CONFIG_ROCKCHIP_RV1126) += rv1126/
# Clear out SPL objects, in case this is a TPL build obj-spl-$(CONFIG_TPL_BUILD) = diff --git a/arch/arm/mach-rockchip/rv1126/Kconfig b/arch/arm/mach-rockchip/rv1126/Kconfig new file mode 100644 index 0000000000..86abc4e2fa --- /dev/null +++ b/arch/arm/mach-rockchip/rv1126/Kconfig @@ -0,0 +1,43 @@ +if ROCKCHIP_RV1126 + +config SOC_SPECIFIC_OPTIONS # dummy + def_bool y + select HAS_CUSTOM_SYS_INIT_SP_ADDR + +config ROCKCHIP_BOOT_MODE_REG + default 0xfe020200 + +config ROCKCHIP_STIMER_BASE + default 0xff670020 + +config SYS_SOC + default "rv1126" + +config CUSTOM_SYS_INIT_SP_ADDR + default 0x800000 + +config SPL_STACK + default 0x600000 + +config SPL_STACK_R_ADDR + default 0x800000 + +config TPL_LDSCRIPT + default "arch/arm/mach-rockchip/u-boot-tpl.lds" + +config TPL_STACK + default 0xff718000 + +config TPL_SYS_MALLOC_F_LEN + default 0x2000 + +config TPL_TEXT_BASE + default 0xff701000 + +config SYS_MALLOC_F_LEN + default 0x2000 + +config SYS_TEXT_BASE + default 0x600000 + +endif diff --git a/arch/arm/mach-rockchip/rv1126/Makefile b/arch/arm/mach-rockchip/rv1126/Makefile new file mode 100644 index 0000000000..b2875633db --- /dev/null +++ b/arch/arm/mach-rockchip/rv1126/Makefile @@ -0,0 +1,13 @@ +# +# (C) Copyright 2019 Rockchip Electronics Co., Ltd +# Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += rv1126.o + +ifndef CONFIG_TPL_BUILD +obj-y += clk_rv1126.o +obj-y += syscon_rv1126.o +endif diff --git a/arch/arm/mach-rockchip/rv1126/clk_rv1126.c b/arch/arm/mach-rockchip/rv1126/clk_rv1126.c new file mode 100644 index 0000000000..bd8902718f --- /dev/null +++ b/arch/arm/mach-rockchip/rv1126/clk_rv1126.c @@ -0,0 +1,33 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include <common.h> +#include <dm.h> +#include <syscon.h> +#include <asm/arch-rockchip/clock.h> +#include <asm/arch-rockchip/cru_rv1126.h> +#include <linux/err.h> + +int rockchip_get_clk(struct udevice **devp) +{ + return uclass_get_device_by_driver(UCLASS_CLK, + DM_DRIVER_GET(rockchip_rv1126_cru), devp); +} + +void *rockchip_get_cru(void) +{ + struct rv1126_clk_priv *priv; + struct udevice *dev; + int ret; + + ret = rockchip_get_clk(&dev); + if (ret) + return ERR_PTR(ret); + + priv = dev_get_priv(dev); + + return priv->cru; +} diff --git a/arch/arm/mach-rockchip/rv1126/rv1126.c b/arch/arm/mach-rockchip/rv1126/rv1126.c new file mode 100644 index 0000000000..91554c98b6 --- /dev/null +++ b/arch/arm/mach-rockchip/rv1126/rv1126.c @@ -0,0 +1,63 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (c) 2019 Rockchip Electronics Co., Ltd + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch-rockchip/bootrom.h> +#include <asm/arch-rockchip/hardware.h> +#include <asm/arch-rockchip/grf_rv1126.h> + +#define GRF_BASE 0xFE000000 + +const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { + [BROM_BOOTSOURCE_EMMC] = "/mmc@ffc50000", + [BROM_BOOTSOURCE_SD] = "/mmc@ffc60000", +}; + +/* GRF_GPIO3A_IOMUX_L */ +enum { + GPIO3A3_SHIFT = 12, + GPIO3A3_MASK = GENMASK(14, 12), + GPIO3A3_GPIO = 0, + GPIO3A3_UART2_RX_M1, + GPIO3A3_A7_JTAG_TMS_M1, + + GPIO3A2_SHIFT = 8, + GPIO3A2_MASK = GENMASK(10, 8), + GPIO3A2_GPIO = 0, + GPIO3A2_UART2_TX_M1, + GPIO3A2_A7_JTAG_TCK_M1, +}; + +/* GRF_IOFUNC_CON2 */ +enum { + UART2_IO_SEL_SHIFT = 8, + UART2_IO_SEL_MASK = GENMASK(8, 8), + UART2_IO_SEL_M0 = 0, + UART2_IO_SEL_M1, +}; + +void board_debug_uart_init(void) +{ + static struct rv1126_grf * const grf = (void *)GRF_BASE; + + /* Enable early UART2 channel m1 on the rv1126 */ + rk_clrsetreg(&grf->iofunc_con2, UART2_IO_SEL_MASK, + UART2_IO_SEL_M1 << UART2_IO_SEL_SHIFT); + + /* Switch iomux */ + rk_clrsetreg(&grf->gpio3a_iomux_l, + GPIO3A3_MASK | GPIO3A2_MASK, + GPIO3A3_UART2_RX_M1 << GPIO3A3_SHIFT | + GPIO3A2_UART2_TX_M1 << GPIO3A2_SHIFT); +} + +#ifndef CONFIG_TPL_BUILD +int arch_cpu_init(void) +{ + return 0; +} +#endif diff --git a/arch/arm/mach-rockchip/rv1126/syscon_rv1126.c b/arch/arm/mach-rockchip/rv1126/syscon_rv1126.c new file mode 100644 index 0000000000..599ea66e3d --- /dev/null +++ b/arch/arm/mach-rockchip/rv1126/syscon_rv1126.c @@ -0,0 +1,47 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include <common.h> +#include <dm.h> +#include <log.h> +#include <syscon.h> +#include <asm/arch-rockchip/clock.h> + +static const struct udevice_id rv1126_syscon_ids[] = { + { .compatible = "rockchip,rv1126-grf", .data = ROCKCHIP_SYSCON_GRF }, + { .compatible = "rockchip,rv1126-pmugrf", .data = ROCKCHIP_SYSCON_PMUGRF }, + { } +}; + +U_BOOT_DRIVER(syscon_rv1126) = { + .name = "rv1126_syscon", + .id = UCLASS_SYSCON, + .of_match = rv1126_syscon_ids, +}; + +#if CONFIG_IS_ENABLED(OF_PLATDATA) +static int rv1126_syscon_bind_of_plat(struct udevice *dev) +{ + dev->driver_data = dev->driver->of_match->data; + debug("syscon: %s %d\n", dev->name, (uint)dev->driver_data); + + return 0; +} + +U_BOOT_DRIVER(rockchip_rv1126_pmu) = { + .name = "rockchip_rv1126_pmu", + .id = UCLASS_SYSCON, + .of_match = rv1126_syscon_ids, + .bind = rv1126_syscon_bind_of_plat, +}; + +U_BOOT_DRIVER(rockchip_rv1126_pmugrf) = { + .name = "rockchip_rv1126_pmugrf", + .id = UCLASS_SYSCON, + .of_match = rv1126_syscon_ids + 1, + .bind = rv1126_syscon_bind_of_plat, +}; +#endif diff --git a/common/spl/Kconfig.tpl b/common/spl/Kconfig.tpl index e314b793a2..1874f9db4f 100644 --- a/common/spl/Kconfig.tpl +++ b/common/spl/Kconfig.tpl @@ -132,7 +132,7 @@ config TPL_TEXT_BASE config TPL_MAX_SIZE hex "Maximum size (in bytes) for the TPL stage" default 0x2e000 if ROCKCHIP_RK3399 - default 0x8000 if ROCKCHIP_RK3288 + default 0x8000 if ROCKCHIP_RK3288 || ROCKCHIP_RV1126 default 0x7000 if ROCKCHIP_RK322X || ROCKCHIP_RK3328 || ROCKCHIP_RK3368 default 0x2800 if ROCKCHIP_PX30 default 0x0
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes for v2:
none
- bool "Support Rockchip RV1126"
- select CPU_V7A
- select SKIP_LOWLEVEL_INIT_ONLY
- select TPL
- select SUPPORT_TPL
- select TPL_NEEDS_SEPARATE_STACK
- select TPL_ROCKCHIP_BACK_TO_BROM
- select SPL
- select SUPPORT_SPL
- select SPL_STACK_R
- select CLK
- select FIT
- select PINCTRL
- select RAM
- select ROCKCHIP_SDRAM_COMMON
- select REGMAP
- select SYSCON
- select DM_PMIC
- select DM_REGULATOR_FIXED
- select DM_RESET
- select REGULATOR_RK8XX
- select PMIC_RK8XX
- select BOARD_LATE_INIT
- imply ROCKCHIP_COMMON_BOARD
- imply TPL_DM
- imply TPL_LIBCOMMON_SUPPORT
- imply TPL_LIBGENERIC_SUPPORT
- imply TPL_OF_CONTROL
- imply TPL_OF_PLATDATA
- imply TPL_RAM
- imply TPL_ROCKCHIP_COMMON_BOARD
- imply TPL_SERIAL
- imply SPL_CLK
- imply SPL_DM
- imply SPL_DRIVERS_MISC
- imply SPL_LIBCOMMON_SUPPORT
- imply SPL_LIBGENERIC_SUPPORT
- imply SPL_OF_CONTROL
- imply SPL_RAM
- imply SPL_REGMAP
- imply SPL_ROCKCHIP_COMMON_BOARD
- imply SPL_SERIAL
- imply SPL_SYSCON
- config ROCKCHIP_USB_UART bool "Route uart output to usb pins" help
- def_bool y
- select HAS_CUSTOM_SYS_INIT_SP_ADDR
- default 0xfe020200
- default 0xff670020
+config SYS_SOC
- default "rv1126"
- default 0x800000
+config SPL_STACK
- default 0x600000
- default 0x800000
- default "arch/arm/mach-rockchip/u-boot-tpl.lds"
+config TPL_STACK
default 0xff718000
- default 0x2000
- default 0xff701000
- default 0x2000
- default 0x600000
+obj-y += rv1126.o
- Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd.
- return uclass_get_device_by_driver(UCLASS_CLK,
- struct rv1126_clk_priv *priv;
- struct udevice *dev;
- int ret;
- ret = rockchip_get_clk(&dev);
- if (ret)
- priv = dev_get_priv(dev);
- return priv->cru;
- Copyright (c) 2019 Rockchip Electronics Co., Ltd
- [BROM_BOOTSOURCE_EMMC] = "/mmc@ffc50000",
- [BROM_BOOTSOURCE_SD] = "/mmc@ffc60000",
- GPIO3A3_SHIFT = 12,
- GPIO3A3_MASK = GENMASK(14, 12),
- GPIO3A3_GPIO = 0,
- GPIO3A3_UART2_RX_M1,
- GPIO3A3_A7_JTAG_TMS_M1,
- GPIO3A2_SHIFT = 8,
- GPIO3A2_MASK = GENMASK(10, 8),
- GPIO3A2_GPIO = 0,
- GPIO3A2_UART2_TX_M1,
- GPIO3A2_A7_JTAG_TCK_M1,
- UART2_IO_SEL_SHIFT = 8,
- UART2_IO_SEL_MASK = GENMASK(8, 8),
- UART2_IO_SEL_M0 = 0,
- UART2_IO_SEL_M1,
- static struct rv1126_grf * const grf = (void *)GRF_BASE;
- /* Enable early UART2 channel m1 on the rv1126 */
- rk_clrsetreg(&grf->iofunc_con2, UART2_IO_SEL_MASK,
- /* Switch iomux */
- rk_clrsetreg(&grf->gpio3a_iomux_l,
- { .compatible = "rockchip,rv1126-grf", .data = ROCKCHIP_SYSCON_GRF },
- { .compatible = "rockchip,rv1126-pmugrf", .data = ROCKCHIP_SYSCON_PMUGRF },
- .name = "rv1126_syscon",
- .id = UCLASS_SYSCON,
- .of_match = rv1126_syscon_ids,
- dev->driver_data = dev->driver->of_match->data;
- debug("syscon: %s %d\n", dev->name, (uint)dev->driver_data);
- .name = "rockchip_rv1126_pmu",
- .bind = rv1126_syscon_bind_of_plat,
- .name = "rockchip_rv1126_pmugrf",
- .of_match = rv1126_syscon_ids + 1,
- default 0x8000 if ROCKCHIP_RK3288 || ROCKCHIP_RV1126 default 0x7000 if ROCKCHIP_RK322X || ROCKCHIP_RK3328 || ROCKCHIP_RK3368 default 0x2800 if ROCKCHIP_PX30 default 0x0
Unsecure the dram area so that MMC, USB, and SFC controllers can able to read data from dram.
Signed-off-by: Jason Zhu jason.zhu@rock-chips.com Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - use IS_ENABLED
arch/arm/mach-rockchip/rv1126/rv1126.c | 12 ++++++++++++ 1 file changed, 12 insertions(+)
diff --git a/arch/arm/mach-rockchip/rv1126/rv1126.c b/arch/arm/mach-rockchip/rv1126/rv1126.c index 91554c98b6..b9b898756f 100644 --- a/arch/arm/mach-rockchip/rv1126/rv1126.c +++ b/arch/arm/mach-rockchip/rv1126/rv1126.c @@ -10,6 +10,8 @@ #include <asm/arch-rockchip/hardware.h> #include <asm/arch-rockchip/grf_rv1126.h>
+#define FIREWALL_APB_BASE 0xffa60000 +#define FW_DDR_CON_REG 0x80 #define GRF_BASE 0xFE000000
const char * const boot_devices[BROM_LAST_BOOTSOURCE + 1] = { @@ -58,6 +60,16 @@ void board_debug_uart_init(void) #ifndef CONFIG_TPL_BUILD int arch_cpu_init(void) { + /** + * Set dram area unsecure in spl + * + * usb & mmc & sfc controllers can read data to dram + * since they are unsecure. + * (Note: only secure-world can access this register) + */ + if (IS_ENABLED(CONFIG_SPL_BUILD)) + writel(0, FIREWALL_APB_BASE + FW_DDR_CON_REG); + return 0; } #endif
Thanks, - Kever
Changes for v2:
use IS_ENABLED
- if (IS_ENABLED(CONFIG_SPL_BUILD))
- return 0; } #endif
Add common rv1126 include config.
include/configs/rv1126_common.h | 42 +++++++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+) create mode 100644 include/configs/rv1126_common.h
diff --git a/include/configs/rv1126_common.h b/include/configs/rv1126_common.h new file mode 100644 index 0000000000..6ab5b2ce5f --- /dev/null +++ b/include/configs/rv1126_common.h @@ -0,0 +1,42 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * (C) Copyright 2019 Rockchip Electronics Co., Ltd + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#ifndef __CONFIG_RV1126_COMMON_H +#define __CONFIG_RV1126_COMMON_H + +#include "rockchip-common.h" + +#define CONFIG_SYS_HZ_CLOCK 24000000 + +#define CONFIG_IRAM_BASE 0xff700000 + +#define GICD_BASE 0xfeff1000 +#define GICC_BASE 0xfeff2000 + +#define CONFIG_SYS_SDRAM_BASE 0 +#define SDRAM_MAX_SIZE 0xfd000000 + +#define CONFIG_SYS_MONITOR_LEN (600 * 1024) + +/* memory size > 128MB */ +#define ENV_MEM_LAYOUT_SETTINGS \ + "scriptaddr=0x00000000\0" \ + "pxefile_addr_r=0x00100000\0" \ + "fdt_addr_r=0x08300000\0" \ + "kernel_addr_r=0x02008000\0" \ + "ramdisk_addr_r=0x0a200000\0" + +#include <config_distro_bootcmd.h> +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0x0fffffff\0" \ + "initrd_high=0x0fffffff\0" \ + "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \ + "partitions=" PARTS_DEFAULT \ + ENV_MEM_LAYOUT_SETTINGS \ + ROCKCHIP_DEVICE_SETTINGS \ + BOOTENV + +#endif /* __CONFIG_RV1126_COMMON_H */
Hi Jagan,
This patch should be squash to patch 21/28.
Thanks,
- Kever
Changes for v2:
none
- "scriptaddr=0x00000000\0" \
- "pxefile_addr_r=0x00100000\0" \
- "fdt_addr_r=0x08300000\0" \
- "kernel_addr_r=0x02008000\0" \
- "ramdisk_addr_r=0x0a200000\0"
- "fdt_high=0x0fffffff\0" \
- "initrd_high=0x0fffffff\0" \
- "fdtfile=" CONFIG_DEFAULT_FDT_FILE "\0" \
- "partitions=" PARTS_DEFAULT \
- ENV_MEM_LAYOUT_SETTINGS \
- ROCKCHIP_DEVICE_SETTINGS \
- BOOTENV
Add support for rv1126 package header in mkimage tool.
tools/rkcommon.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/tools/rkcommon.c b/tools/rkcommon.c index 1325aa83cb..f18b6fad95 100644 --- a/tools/rkcommon.c +++ b/tools/rkcommon.c @@ -133,6 +133,7 @@ static struct spl_info spl_infos[] = { { "rk3368", "RK33", 0x8000 - 0x1000, false, RK_HEADER_V1 }, { "rk3399", "RK33", 0x30000 - 0x2000, false, RK_HEADER_V1 }, { "rv1108", "RK11", 0x1800, false, RK_HEADER_V1 }, + { "rv1126", "110B", 0x10000 - 0x1000, false, RK_HEADER_V1 }, { "rk3568", "RK35", 0x14000 - 0x1000, false, RK_HEADER_V2 }, };
Thanks, - Kever
Changes for v2:
none
- { "rv1126", "110B", 0x10000 - 0x1000, false, RK_HEADER_V1 }, { "rk3568", "RK35", 0x14000 - 0x1000, false, RK_HEADER_V2 }, };
Edge Compute Module 0 is a 96boards SoM-CB compute module based on Rockchip RV1126 from Edgeble AI.
General features: - Rockchip RV1126 - 2/4GB LPDDR4 - 16GB eMMC - Fn-link 8223A-SR WiFi/BT
Edge Compute Module 0 needs to mount on top of Edgeble AI Carrier boards for creating complete platform solutions.
Add support for it.
.../rv1126-edgeble-edge-compute-module-0.dtsi | 329 ++++++++++++++++++ 1 file changed, 329 insertions(+) create mode 100644 arch/arm/dts/rv1126-edgeble-edge-compute-module-0.dtsi
diff --git a/arch/arm/dts/rv1126-edgeble-edge-compute-module-0.dtsi b/arch/arm/dts/rv1126-edgeble-edge-compute-module-0.dtsi new file mode 100644 index 0000000000..c98232dd25 --- /dev/null +++ b/arch/arm/dts/rv1126-edgeble-edge-compute-module-0.dtsi @@ -0,0 +1,329 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Rockchip Electronics Co., Ltd. + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +/ { + compatible = "edgeble,edge-compute-module-0", "rockchip,rv1126"; + + aliases { + mmc0 = &emmc; + }; + + vcc5v0_sys: vccsys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vccio_flash: vccio-flash { + compatible = "regulator-fixed"; + enable-active-high; + gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&flash_vol_sel>; + regulator-name = "vccio_flash"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_3v3>; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&rk809 1>; + clock-names = "ext_clock"; + pinctrl-names = "default"; + pinctrl-0 = <&wifi_enable_h>; + reset-gpios = <&gpio1 RK_PD0 GPIO_ACTIVE_LOW>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_arm>; +}; + +&emmc { + bus-width = <8>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk &emmc_rstnout>; + vmmc-supply = <&vcc_3v3>; + vqmmc-supply = <&vccio_flash>; + rockchip,default-sample-phase = <90>; + status = "okay"; +}; + +&i2c0 { + status = "okay"; + clock-frequency = <400000>; + + rk809: pmic@20 { + compatible = "rockchip,rk809"; + reg = <0x20>; + interrupt-parent = <&gpio0>; + interrupts = <RK_PB1 IRQ_TYPE_LEVEL_LOW>; + #clock-cells = <1>; + clock-output-names = "rk808-clkout1", "rk808-clkout2"; + pinctrl-names = "default"; + pinctrl-0 = <&pmic_int_l>; + rockchip,system-power-controller; + wakeup-source; + + vcc1-supply = <&vcc5v0_sys>; + vcc2-supply = <&vcc5v0_sys>; + vcc3-supply = <&vcc5v0_sys>; + vcc4-supply = <&vcc5v0_sys>; + vcc5-supply = <&vcc_buck5>; + vcc6-supply = <&vcc_buck5>; + vcc7-supply = <&vcc5v0_sys>; + vcc8-supply = <&vcc3v3_sys>; + vcc9-supply = <&vcc5v0_sys>; + + regulators { + vdd_npu_vepu: DCDC_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <650000>; + regulator-max-microvolt = <950000>; + regulator-ramp-delay = <6001>; + regulator-initial-mode = <0x2>; + regulator-name = "vdd_npu_vepu"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vdd_arm: DCDC_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <725000>; + regulator-max-microvolt = <1350000>; + regulator-ramp-delay = <6001>; + regulator-initial-mode = <0x2>; + regulator-name = "vdd_arm"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_ddr: DCDC_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-initial-mode = <0x2>; + regulator-name = "vcc_ddr"; + + regulator-state-mem { + regulator-on-in-suspend; + }; + }; + + vcc3v3_sys: DCDC_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-initial-mode = <0x2>; + regulator-name = "vcc3v3_sys"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <3300000>; + }; + }; + + vcc_buck5: DCDC_REG5 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <2200000>; + regulator-max-microvolt = <2200000>; + regulator-name = "vcc_buck5"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <2200000>; + }; + }; + + vcc_0v8: LDO_REG1 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-name = "vcc_0v8"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc1v8_pmu: LDO_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc1v8_pmu"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vdd0v8_pmu: LDO_REG3 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <800000>; + regulator-max-microvolt = <800000>; + regulator-name = "vcc0v8_pmu"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <800000>; + }; + }; + + vcc_1v8: LDO_REG4 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_1v8"; + + regulator-state-mem { + regulator-on-in-suspend; + regulator-suspend-microvolt = <1800000>; + }; + }; + + vcc_dovdd: LDO_REG5 { + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-name = "vcc_dovdd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_dvdd: LDO_REG6 { + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-name = "vcc_dvdd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_avdd: LDO_REG7 { + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + regulator-name = "vcc_avdd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vccio_sd: LDO_REG8 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vccio_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc3v3_sd: LDO_REG9 { + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + regulator-name = "vcc3v3_sd"; + + regulator-state-mem { + regulator-off-in-suspend; + }; + }; + + vcc_5v0: SWITCH_REG1 { + regulator-name = "vcc_5v0"; + }; + + vcc_3v3: SWITCH_REG2 { + regulator-always-on; + regulator-boot-on; + regulator-name = "vcc_3v3"; + }; + }; + }; +}; + +&pinctrl { + flash { + flash_vol_sel: flash-vol-sel { + rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + pmic { + pmic_int_l: pmic-int-l { + rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; + }; + }; + + wifi { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; +}; + +&pmu_io_domains { + pmuio0-supply = <&vcc1v8_pmu>; + pmuio1-supply = <&vcc3v3_sys>; + vccio1-supply = <&vccio_flash>; + vccio2-supply = <&vccio_sd>; + vccio3-supply = <&vcc_1v8>; + vccio4-supply = <&vcc_dovdd>; + vccio5-supply = <&vcc_1v8>; + vccio6-supply = <&vcc_1v8>; + vccio7-supply = <&vcc_dovdd>; + status = "okay"; +}; + +&saradc { + vref-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdio { + #address-cells = <1>; + #size-cells = <0>; + max-frequency = <100000000>; + bus-width = <4>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc1_clk &sdmmc1_cmd &sdmmc1_bus4>; + vmmc-supply = <&vcc3v3_sys>; + vqmmc-supply = <&vcc_1v8>; + rockchip,default-sample-phase = <90>; + sd-uhs-sdr104; + status = "okay"; +};
Hi Jagan,
General features:
- Rockchip RV1126
- 2/4GB LPDDR4
- 16GB eMMC
Add support for it.
I would like to merge this patch after mainline kernel is available.
Thanks, - Kever
Changes for v2:
none
- Copyright (c) 2020 Rockchip Electronics Co., Ltd.
- compatible = "edgeble,edge-compute-module-0", "rockchip,rv1126";
- aliases {
mmc0 = &emmc;
- vcc5v0_sys: vccsys {
regulator-boot-on;
- vccio_flash: vccio-flash {
enable-active-high;
regulator-boot-on;
- sdio_pwrseq: sdio-pwrseq {
+&cpu0 {
- cpu-supply = <&vdd_arm>;
+&emmc {
- bus-width = <8>;
- non-removable;
- pinctrl-names = "default";
- pinctrl-0 = <&emmc_bus8 &emmc_cmd &emmc_clk &emmc_rstnout>;
- vmmc-supply = <&vcc_3v3>;
- vqmmc-supply = <&vccio_flash>;
- rockchip,default-sample-phase = <90>;
- status = "okay";
+&i2c0 {
- status = "okay";
- clock-frequency = <400000>;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_0v8: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG4 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&pinctrl {
- flash {
- pmic {
- wifi {
+&pmu_io_domains {
- pmuio0-supply = <&vcc1v8_pmu>;
- pmuio1-supply = <&vcc3v3_sys>;
- vccio1-supply = <&vccio_flash>;
- vccio2-supply = <&vccio_sd>;
- vccio3-supply = <&vcc_1v8>;
- vccio4-supply = <&vcc_dovdd>;
- vccio5-supply = <&vcc_1v8>;
- vccio6-supply = <&vcc_1v8>;
- vccio7-supply = <&vcc_dovdd>;
- status = "okay";
+&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
+&sdio {
- #size-cells = <0>;
- max-frequency = <100000000>;
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdmmc1_clk &sdmmc1_cmd &sdmmc1_bus4>;
- vmmc-supply = <&vcc3v3_sys>;
- vqmmc-supply = <&vcc_1v8>;
- sd-uhs-sdr104;
- status = "okay";
Edge Compute Module 0 Carrier is an industrial form factor evaluation board from Edgeble AI.
General features: - microSD slot - 2x MIPI CSI2 connectors - MIPI DSI connector - 2x USB Host - 1x USB OTG - Ethernet - mini PCIe - Onboard PoE - RS485, RS232, CAN - Micro Phone array - Speaker - RTC battery slot - 40-pin expansion
Edge Compute Module 0 needs to mount on top of this Carrier board for creating Edge Compute Module 0 Carrier platform.
Add support for it.
Signed-off-by: Jagan Teki jagan@edgeble.ai --- Changes for v2: - none
arch/arm/dts/Makefile | 3 ++ arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts | 38 ++++++++++++++++++++ 2 files changed, 41 insertions(+) create mode 100644 arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7fa275ea7c..2070eb1540 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -170,6 +170,9 @@ dtb-$(CONFIG_ROCKCHIP_RV1108) += \ rv1108-elgin-r1.dtb \ rv1108-evb.dtb
+dtb-$(CONFIG_ROCKCHIP_RV1126) += \ + rv1126-edgeble-ecm0-carrier.dtb + dtb-$(CONFIG_ARCH_S5P4418) += \ s5p4418-nanopi2.dtb
diff --git a/arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts b/arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts new file mode 100644 index 0000000000..150bfb9bd0 --- /dev/null +++ b/arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts @@ -0,0 +1,38 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2020 Rockchip Electronics Co., Ltd. + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +/dts-v1/; +#include "rv1126.dtsi" +#include "rv1126-edgeble-edge-compute-module-0.dtsi" + +/ { + model = "Edgeble AI Edge Compute Module 0 Carrier board"; + compatible = "edgeble,edge-compute-module-0-carrier", + "edgeble,edge-compute-module-0", "rockchip,rv1126"; + + chosen { + stdout-path = "serial2:1500000n8"; + }; +}; + +&sdmmc { + bus-width = <4>; + cap-mmc-highspeed; + cap-sd-highspeed; + card-detect-delay = <200>; + pinctrl-names = "default"; + pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>; + rockchip,default-sample-phase = <90>; + sd-uhs-sdr12; + sd-uhs-sdr25; + sd-uhs-sdr104; + vqmmc-supply = <&vccio_sd>; + status = "okay"; +}; + +&uart2 { + status = "okay"; +};
Hi Jagan,
General features:
- microSD slot
- 2x USB Host
- 1x USB OTG
- Ethernet
- mini PCIe
- Onboard PoE
- RS485, RS232, CAN
- Micro Phone array
- Speaker
- RTC battery slot
- 40-pin expansion
Add support for it.
This patch can squash with previous patch 25/28 ?
Thanks,
- Kever
Changes for v2:
none
- rv1126-edgeble-ecm0-carrier.dtb
- dtb-$(CONFIG_ARCH_S5P4418) += \ s5p4418-nanopi2.dtb
- model = "Edgeble AI Edge Compute Module 0 Carrier board";
- compatible = "edgeble,edge-compute-module-0-carrier",
- chosen {
+&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- card-detect-delay = <200>;
- pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_bus4 &sdmmc0_det>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr104;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
+&uart2 {
- status = "okay";
Add u-boot,dm-spl and u-boot,dm-pre-reloc related properties for Rockchip RV1126 SoC.
Both eMMC and SD boot are tested in Edge Compute Module 0.
arch/arm/dts/rv1126-u-boot.dtsi | 62 +++++++++++++++++++++++++++++++++ 1 file changed, 62 insertions(+) create mode 100644 arch/arm/dts/rv1126-u-boot.dtsi
diff --git a/arch/arm/dts/rv1126-u-boot.dtsi b/arch/arm/dts/rv1126-u-boot.dtsi new file mode 100644 index 0000000000..bc77037760 --- /dev/null +++ b/arch/arm/dts/rv1126-u-boot.dtsi @@ -0,0 +1,62 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include "rockchip-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = \ + "same-as-spl", &emmc, &sdmmc; + }; + + dmc { + compatible = "rockchip,rv1126-dmc"; + u-boot,dm-pre-reloc; + }; +}; + +&gpio0 { + u-boot,dm-spl; +}; + +&gpio1 { + u-boot,dm-spl; +}; + +&grf { + u-boot,dm-spl; +}; + +&pmu { + u-boot,dm-spl; +}; + +&pmugrf { + u-boot,dm-spl; +}; + +&xin24m { + u-boot,dm-spl; +}; + +&cru { + u-boot,dm-spl; +}; + +&pmucru { + u-boot,dm-spl; +}; + +&sdmmc { + u-boot,dm-spl; +}; + +&emmc { + u-boot,dm-spl; +}; + +&uart2 { + u-boot,dm-spl; +};
Thanks, - Kever
Changes for v2:
none
- chosen {
- dmc {
+&gpio0 {
- u-boot,dm-spl;
+&gpio1 {
- u-boot,dm-spl;
+&grf {
- u-boot,dm-spl;
+&pmu {
- u-boot,dm-spl;
+&pmugrf {
- u-boot,dm-spl;
+&xin24m {
- u-boot,dm-spl;
+&cru {
- u-boot,dm-spl;
+&pmucru {
- u-boot,dm-spl;
+&sdmmc {
- u-boot,dm-spl;
+&emmc {
- u-boot,dm-spl;
+&uart2 {
- u-boot,dm-spl;
Add support for it.
.../rv1126-edgeble-ecm0-carrier-u-boot.dtsi | 10 ++++ arch/arm/mach-rockchip/rv1126/Kconfig | 12 ++++ board/edgeble/edge-compute-module-0/Kconfig | 16 ++++++ .../edgeble/edge-compute-module-0/MAINTAINERS | 6 ++ board/edgeble/edge-compute-module-0/Makefile | 7 +++ board/edgeble/edge-compute-module-0/ecm0.c | 4 ++ configs/ecm0-carrier-rv1126_defconfig | 56 +++++++++++++++++++ include/configs/edge-compute-module-0.h | 21 +++++++ 8 files changed, 132 insertions(+) create mode 100644 arch/arm/dts/rv1126-edgeble-ecm0-carrier-u-boot.dtsi create mode 100644 board/edgeble/edge-compute-module-0/Kconfig create mode 100644 board/edgeble/edge-compute-module-0/MAINTAINERS create mode 100644 board/edgeble/edge-compute-module-0/Makefile create mode 100644 board/edgeble/edge-compute-module-0/ecm0.c create mode 100644 configs/ecm0-carrier-rv1126_defconfig create mode 100644 include/configs/edge-compute-module-0.h
diff --git a/arch/arm/dts/rv1126-edgeble-ecm0-carrier-u-boot.dtsi b/arch/arm/dts/rv1126-edgeble-ecm0-carrier-u-boot.dtsi new file mode 100644 index 0000000000..51a1617708 --- /dev/null +++ b/arch/arm/dts/rv1126-edgeble-ecm0-carrier-u-boot.dtsi @@ -0,0 +1,10 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#include "rv1126-u-boot.dtsi" + +&sdio { + status = "disabled"; +}; diff --git a/arch/arm/mach-rockchip/rv1126/Kconfig b/arch/arm/mach-rockchip/rv1126/Kconfig index 86abc4e2fa..3078a97f40 100644 --- a/arch/arm/mach-rockchip/rv1126/Kconfig +++ b/arch/arm/mach-rockchip/rv1126/Kconfig @@ -1,5 +1,15 @@ if ROCKCHIP_RV1126
+config TARGET_RV1126_ECM0 + bool "Edgeble AI Edge Compute Module 0 SoM" + help + Edge Compute Module 0 is a 96boards SoM-CB compute module based + on Rockchip RV1126 from Edgeble AI. + + ECM0-Carrier: + Edge Compute Module 0 needs to mount on top of this Carrier board + for creating Edge Compute Module 0 Carrier platform. + config SOC_SPECIFIC_OPTIONS # dummy def_bool y select HAS_CUSTOM_SYS_INIT_SP_ADDR @@ -40,4 +50,6 @@ config SYS_MALLOC_F_LEN config SYS_TEXT_BASE default 0x600000
+source board/edgeble/edge-compute-module-0/Kconfig + endif diff --git a/board/edgeble/edge-compute-module-0/Kconfig b/board/edgeble/edge-compute-module-0/Kconfig new file mode 100644 index 0000000000..65b2faa10b --- /dev/null +++ b/board/edgeble/edge-compute-module-0/Kconfig @@ -0,0 +1,16 @@ +if TARGET_RV1126_ECM0 + +config SYS_BOARD + default "edge-compute-module-0" + +config SYS_VENDOR + default "edgeble" + +config SYS_CONFIG_NAME + default "edge-compute-module-0" + +config BOARD_SPECIFIC_OPTIONS # dummy + def_bool y + select RAM_ROCKCHIP_LPDDR4 + +endif diff --git a/board/edgeble/edge-compute-module-0/MAINTAINERS b/board/edgeble/edge-compute-module-0/MAINTAINERS new file mode 100644 index 0000000000..f21295cc6c --- /dev/null +++ b/board/edgeble/edge-compute-module-0/MAINTAINERS @@ -0,0 +1,6 @@ +RV1126-ECM0 +M: Jagan Teki jagan@edgeble.ai +S: Maintained +F: board/edgeble-ai/edge-compute-module-0 +F: include/configs/edge-compute-module-0.h +F: configs/ecm0-carrier-rv1126_defconfig diff --git a/board/edgeble/edge-compute-module-0/Makefile b/board/edgeble/edge-compute-module-0/Makefile new file mode 100644 index 0000000000..c42a0b7fba --- /dev/null +++ b/board/edgeble/edge-compute-module-0/Makefile @@ -0,0 +1,7 @@ +# +# Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +obj-y += ecm0.o diff --git a/board/edgeble/edge-compute-module-0/ecm0.c b/board/edgeble/edge-compute-module-0/ecm0.c new file mode 100644 index 0000000000..3d2262ce97 --- /dev/null +++ b/board/edgeble/edge-compute-module-0/ecm0.c @@ -0,0 +1,4 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ diff --git a/configs/ecm0-carrier-rv1126_defconfig b/configs/ecm0-carrier-rv1126_defconfig new file mode 100644 index 0000000000..11cd68fb41 --- /dev/null +++ b/configs/ecm0-carrier-rv1126_defconfig @@ -0,0 +1,56 @@ +CONFIG_ARM=y +CONFIG_SPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_TPL_SKIP_LOWLEVEL_INIT_ONLY=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_SYS_ARCH_TIMER=y +CONFIG_ARCH_ROCKCHIP=y +CONFIG_NR_DRAM_BANKS=1 +CONFIG_DEFAULT_DEVICE_TREE="rv1126-edgeble-ecm0-carrier" +CONFIG_ROCKCHIP_RV1126=y +CONFIG_TARGET_RV1126_ECM0=y +CONFIG_DEBUG_UART_BASE=0xff570000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xe00800 +CONFIG_DEBUG_UART=y +CONFIG_FIT_VERBOSE=y +CONFIG_DEFAULT_FDT_FILE="rv1126-edgeble-ecm0-carrier.dtb" +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_DISPLAY_BOARDINFO_LATE=y +CONFIG_MISC_INIT_R=y +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_NO_BSS_LIMIT=y +# CONFIG_SPL_RAW_IMAGE_SUPPORT is not set +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +# CONFIG_CMD_BOOTD is not set +CONFIG_SYS_BOOTM_LEN=0x4000000 +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_GPT=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_SPL_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_ENV_IS_IN_MMC=y +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_MISC=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_REGULATOR_PWM=y +CONFIG_PWM_ROCKCHIP=y +# CONFIG_RAM_ROCKCHIP_DEBUG is not set +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYSRESET=y +# CONFIG_TPL_SYSRESET is not set +CONFIG_DM_THERMAL=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_LZO=y +CONFIG_ERRNO_STR=y diff --git a/include/configs/edge-compute-module-0.h b/include/configs/edge-compute-module-0.h new file mode 100644 index 0000000000..32f4e3227b --- /dev/null +++ b/include/configs/edge-compute-module-0.h @@ -0,0 +1,21 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (c) 2022 Edgeble AI Technologies Pvt. Ltd. + */ + +#ifndef __EDGE_COMPUTE_MODULE_0_H +#define __EDGE_COMPUTE_MODULE_0_H + +#define ROCKCHIP_DEVICE_SETTINGS \ + "stdout=serial,vidconsole\0" \ + "stderr=serial,vidconsole\0" + +#include <configs/rv1126_common.h> + +#undef BOOT_TARGET_DEVICES + +#define BOOT_TARGET_DEVICES(func) \ + func(MMC, mmc, 0) \ + func(MMC, mmc, 1) + +#endif /* __EDGE_COMPUTE_MODULE_0_H */
General features:
- microSD slot
- 2x USB Host
- 1x USB OTG
- Ethernet
- mini PCIe
- Onboard PoE
- RS485, RS232, CAN
- Micro Phone array
- Speaker
- RTC battery slot
- 40-pin expansion
Add support for it.
Thanks, - Kever
Changes for v2:
none
+&sdio {
- status = "disabled";
- bool "Edgeble AI Edge Compute Module 0 SoM"
- help
ECM0-Carrier:
- config SOC_SPECIFIC_OPTIONS # dummy def_bool y select HAS_CUSTOM_SYS_INIT_SP_ADDR
- endif
+config SYS_BOARD
- default "edge-compute-module-0"
+config SYS_VENDOR
- default "edgeble"
- def_bool y
- select RAM_ROCKCHIP_LPDDR4
- func(MMC, mmc, 0) \
- func(MMC, mmc, 1)
Hi Jagan,
Could you resend this patch set? There are some merge conflict when I try to apply.
For dts related patch, please add the commit number available on mainline kernel,
or else I will merge other patches except dts.
Thanks,
- Kever
This patch series add basic core support for Rockchip RV1126 and boot from eMMC and SD.
Linux support is under review for the same [2] and v1 can be [3].
Tested RV1126 in Edgeble AI Edge Compute Module 0.
Anyone interested, please have a look on this repo [1]
Note: I was little late to push this MW due to some issues, hope these would land as soon as possible.
[1] https://github.com/edgeble/u-boot/commits/ecm0-v4 [2] https://patchwork.kernel.org/project/linux-arm-kernel/cover/20220818124132.1... [3] https://patchwork.ozlabs.org/project/uboot/cover/20220727174050.2214617-1-ja...
Any inputs? Jagan.
Jagan Teki (28): ram: Mark ram-uclass depend on TPL_DM or SPL_DM ram: rockchip: Add common ddr type configs tools: rkcommon: Correct SPL size for px30 ram: rockchip: Compute ddr capacity based on grf split ram: rockchip: Update high row detection for full bw ram: rockchip: Update ddr pctl regs for px30 ram: rockchip: Add rv1126 ddr3 support ram: rockchip: Add rv1126 ddr loader params ram: rockchip: Add rv1126 ddr driver support ram: rockchip: rv1126: Control ddr init prints via DEBUG ram: rockchip: Add rv1126 lpddr4 support pinctrl: rockchip: Add pinctrl route types pinctrl: rockchip: Add rv1126 support arch: rockchip: Add cru header for rv1126 dt-bindings: clk: Add dt-binding header for RV1126 clk: rockchip: Add rv1126 clk support dt-bindings: power: Add power-domain header for rv1126 arm: rockchip: Add grf header for rv1126 ARM: dts: rockchip: Add Rockchip RV1126 pinctrl ARM: dts: rockchip: Add Rockchip RV1126 SoC arm: rockchip: Add RV1126 arch core support arm: rockchip: rv1126: Set dram area unsecure for SPL configs: rockchip: Add rv1126 common config rockchip: mkimage: Add rv1126 support ARM: dts: rockchip: rv1126: Add Edgeble AI Edge Compute Module 0 ARM: dts: rockchip: rv1126: Add Edgeble AI Edge Compute Module 0 Carrier ARM: dts: rockchip: Add rv1126-u-boot.dtsi board: Add Edgeble AI Edge Compute Module 0 Carrier
arch/arm/dts/Makefile | 3 + .../rv1126-edgeble-ecm0-carrier-u-boot.dtsi | 10 + arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts | 38 + .../rv1126-edgeble-edge-compute-module-0.dtsi | 329 ++ arch/arm/dts/rv1126-pinctrl.dtsi | 302 ++ arch/arm/dts/rv1126-u-boot.dtsi | 62 + arch/arm/dts/rv1126.dtsi | 500 +++ .../include/asm/arch-rockchip/cru_rv1126.h | 459 +++ .../asm/arch-rockchip/dram_spec_timing.h | 452 +++ .../include/asm/arch-rockchip/grf_rv1126.h | 251 ++ .../include/asm/arch-rockchip/sdram_common.h | 216 +- .../include/asm/arch-rockchip/sdram_msch.h | 12 + .../asm/arch-rockchip/sdram_pctl_px30.h | 100 +- .../asm/arch-rockchip/sdram_phy_rv1126.h | 93 + .../include/asm/arch-rockchip/sdram_rv1126.h | 420 ++ arch/arm/include/asm/arch-rv1126/boot0.h | 11 + arch/arm/include/asm/arch-rv1126/gpio.h | 11 + arch/arm/mach-rockchip/Kconfig | 46 + arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/rv1126/Kconfig | 55 + arch/arm/mach-rockchip/rv1126/Makefile | 13 + arch/arm/mach-rockchip/rv1126/clk_rv1126.c | 33 + arch/arm/mach-rockchip/rv1126/rv1126.c | 75 + arch/arm/mach-rockchip/rv1126/syscon_rv1126.c | 47 + board/edgeble/edge-compute-module-0/Kconfig | 16 + .../edgeble/edge-compute-module-0/MAINTAINERS | 6 + board/edgeble/edge-compute-module-0/Makefile | 7 + board/edgeble/edge-compute-module-0/ecm0.c | 4 + board/engicam/px30_core/Kconfig | 2 +- common/spl/Kconfig.tpl | 2 +- configs/ecm0-carrier-rv1126_defconfig | 56 + configs/khadas-edge-captain-rk3399_defconfig | 2 +- configs/khadas-edge-rk3399_defconfig | 2 +- configs/khadas-edge-v-rk3399_defconfig | 2 +- configs/leez-rk3399_defconfig | 2 +- configs/nanopi-r4s-rk3399_defconfig | 2 +- configs/pinebook-pro-rk3399_defconfig | 2 +- configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rockpro64-rk3399_defconfig | 2 +- drivers/clk/rockchip/Makefile | 1 + drivers/clk/rockchip/clk_rv1126.c | 1889 +++++++++ drivers/pinctrl/rockchip/Makefile | 1 + drivers/pinctrl/rockchip/pinctrl-px30.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3128.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk322x.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3288.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3308.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3328.c | 11 +- drivers/pinctrl/rockchip/pinctrl-rk3399.c | 11 +- .../pinctrl/rockchip/pinctrl-rockchip-core.c | 45 +- drivers/pinctrl/rockchip/pinctrl-rockchip.h | 58 +- drivers/pinctrl/rockchip/pinctrl-rv1126.c | 416 ++ drivers/ram/Makefile | 2 +- drivers/ram/rockchip/Kconfig | 32 +- drivers/ram/rockchip/Makefile | 1 + .../sdram-rv1126-ddr3-detect-1056.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-328.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-396.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-528.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-664.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-784.inc | 72 + .../rockchip/sdram-rv1126-ddr3-detect-924.inc | 72 + .../rockchip/sdram-rv1126-loader_params.inc | 198 + .../sdram-rv1126-lpddr4-detect-1056.inc | 78 + .../sdram-rv1126-lpddr4-detect-328.inc | 78 + .../sdram-rv1126-lpddr4-detect-396.inc | 78 + .../sdram-rv1126-lpddr4-detect-528.inc | 78 + .../sdram-rv1126-lpddr4-detect-664.inc | 78 + .../sdram-rv1126-lpddr4-detect-784.inc | 78 + .../sdram-rv1126-lpddr4-detect-924.inc | 78 + drivers/ram/rockchip/sdram_common.c | 62 +- drivers/ram/rockchip/sdram_pctl_px30.c | 6 +- drivers/ram/rockchip/sdram_px30.c | 10 +- drivers/ram/rockchip/sdram_rk3328.c | 2 +- drivers/ram/rockchip/sdram_rk3399.c | 8 +- drivers/ram/rockchip/sdram_rv1126.c | 3543 +++++++++++++++++ include/configs/edge-compute-module-0.h | 21 + include/configs/rv1126_common.h | 42 + .../dt-bindings/clock/rockchip,rv1126-cru.h | 632 +++ .../dt-bindings/power/rockchip,rv1126-power.h | 35 + tools/rkcommon.c | 3 +- 84 files changed, 11656 insertions(+), 132 deletions(-) create mode 100644 arch/arm/dts/rv1126-edgeble-ecm0-carrier-u-boot.dtsi create mode 100644 arch/arm/dts/rv1126-edgeble-ecm0-carrier.dts create mode 100644 arch/arm/dts/rv1126-edgeble-edge-compute-module-0.dtsi create mode 100644 arch/arm/dts/rv1126-pinctrl.dtsi create mode 100644 arch/arm/dts/rv1126-u-boot.dtsi create mode 100644 arch/arm/dts/rv1126.dtsi create mode 100644 arch/arm/include/asm/arch-rockchip/cru_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/dram_spec_timing.h create mode 100644 arch/arm/include/asm/arch-rockchip/grf_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_phy_rv1126.h create mode 100644 arch/arm/include/asm/arch-rockchip/sdram_rv1126.h create mode 100644 arch/arm/include/asm/arch-rv1126/boot0.h create mode 100644 arch/arm/include/asm/arch-rv1126/gpio.h create mode 100644 arch/arm/mach-rockchip/rv1126/Kconfig create mode 100644 arch/arm/mach-rockchip/rv1126/Makefile create mode 100644 arch/arm/mach-rockchip/rv1126/clk_rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/rv1126.c create mode 100644 arch/arm/mach-rockchip/rv1126/syscon_rv1126.c create mode 100644 board/edgeble/edge-compute-module-0/Kconfig create mode 100644 board/edgeble/edge-compute-module-0/MAINTAINERS create mode 100644 board/edgeble/edge-compute-module-0/Makefile create mode 100644 board/edgeble/edge-compute-module-0/ecm0.c create mode 100644 configs/ecm0-carrier-rv1126_defconfig create mode 100644 drivers/clk/rockchip/clk_rv1126.c create mode 100644 drivers/pinctrl/rockchip/pinctrl-rv1126.c create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-ddr3-detect-924.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-loader_params.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-1056.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-328.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-396.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-528.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-664.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-784.inc create mode 100644 drivers/ram/rockchip/sdram-rv1126-lpddr4-detect-924.inc create mode 100644 drivers/ram/rockchip/sdram_rv1126.c create mode 100644 include/configs/edge-compute-module-0.h create mode 100644 include/configs/rv1126_common.h create mode 100644 include/dt-bindings/clock/rockchip,rv1126-cru.h create mode 100644 include/dt-bindings/power/rockchip,rv1126-power.h
Hi Kever,
On Mon, 17 Oct 2022 at 18:59, Kever Yang kever.yang@rock-chips.com wrote:
Hi Jagan,
I try to apply.
mainline kernel,
dts files in the Mainline kernel are holding for the next version. Please merge the rest of them. I will wrap and send dts files once I send them to Mainline linux.
Jagan.
Hi Kever,
On Mon, 17 Oct 2022 at 19:03, Jagan Teki jagan@edgeble.ai wrote:
Hi Kever,
Hi Jagan,
I try to apply.
mainline kernel,
Any update on this?
Jagan.
Jagan Teki
Kever Yang
