Re: [U-Boot] U-boot failed
Dear Zeyad A,
Dear Marek Vasut, I have already done the CC, but the mail was rejected from u-boot mailing list because the message size is too large. So i am not doing it for now and I am sorry for the quoting of my reply. The matter is not so clear for me. Ok, I have done the command in u-boot that you given and the output is,
U-Boot# printenv bootargs ## Error: "bootargs" not defined U-Boot#
Got an error and I don't know why it is!
Well ... define bootargs properly, it should fix your issue. (bootargs == kernel command line, see my previous reply).
On Fri, Jun 8, 2012 at 9:48 AM, Marek Vasut marex@denx.de wrote:
Dear Zeyad A,
Dear Mark, Yeah sure, I'll do the CC and what you mean by 'fix the quote in my mailer'??
When you reply on an email, you usually get the old email you reply to prefixed with these ">" (quotes). And I guess your mailed doesn't do that.
If my u-boot is broken then what will I do?
If it was mainline, you'd simply report a problem and possibly send a patch. If it's a vendor-supplied u-boot, that's problematic. Do you have the sources?
Sorry, I am a little weak in this linux things.
That's ok.
So please just help to do it.. Here I am attaching a screen shot of the kernel loading process. After
the
end there is no response in the terminal, only just blinking the cursor.
No
kernel startup and all...
I see! So the kernel started the decompressor at least. Now, check the following:
In U-Boot, run "printenv bootargs" and see if you pass correct serial port to the kernel (argument "console=<something>"). This is what I can think of from the top of my head. You can adjust it by running "setenv bootargs", then boot as usual. This new bootargs won't be saved, so powercycling the board will get you back to previous state, no damage done. Once you figure out the correct bootargs, run "saveenv" afterwards.
On Fri, Jun 8, 2012 at 6:42 AM, Marek Vasut marex@denx.de wrote:
Dear Zeyad A,
Ok, let's first adjust your posting so it's easier for everyone around
to
read and reply. Firstly please, always CC the u-boot mailing list. Secondly, fix the quoting in your mailer please.
Thank you very much for your reply. Please read the my answers
below..
On Wed, Jun 6, 2012 at 1:52 AM, Marek Vasut marex@denx.de wrote:
Dear Zeyad A,
> Hello, > > Please help me to configure u-boot in my NC600 board.
What's this board? Is it supported mainline? What CPU does it have,
what
version of uboot etc?
My board is the thin-client NC600 board with POLLUX loaded(same as
the device in this link:
https://code.jeffkent.net/trac/nc600/wiki/Hardware/Devices/NC600#no1)
It
has 64 MB of ram and 64 MB of storage space. I had followed the
writings
in this link: https://code.jeffkent.net/trac/nc600
I don't see this being supported by mainline u-boot, right? So what version does your board run? It might be that the u-boot you run is broken too.
> I have reached near > to u-boot, but the kernel is not booting. After the kernel > image
upload
via
> serial boot mode it is giving no response.
Kernel or uboot? Maybe your xyzmodem uploader doesn't work with uboot? Minicom worked for me.
I have done all these in ubuntu 11.04 as per the link. In the terminal
in
ubuntu, i can start the u-boot by ./boot-uboot command and my FTDI
serial
communicator is working fine. All the things are sending to the
board
and
it is entering to u-boot. The commands are working fine in u-boot.
Ok, so you have u-boot running and it's the kernel that doesn't boot? What is the last think you see?
> If the kernel image upload > become complete it is not giving any command line in the u-boot
as
> shown
in
> the guide.
I see ... what terminal emulator do you use to communicate with uboot? btw. uploading via tftp over the ethernet is usually much faster.
I am using ubuntu terminal and it's working good. I tried both tftp upload and direct flash memory upload by plugging the flash in my board's usb port. But in tftp upload the kernel image upload was successful. The led indicator in the board is blinking at the time
of
kernel upload. But after upload, there is not getting any response in the terminal. I can't do any commands in the terminal.
> The memory is not getting flashed.
Why of course, the loady command downloads data to RAM, you have to
flash
it via "nand write" or such command afterwards.
Yes the data is uploading to RAM. After that i can't do any
commands.
This the only problem i have...
Ok, so you're uploading it to RAM, are you sure you don't overwrite u-boot? Check where u-boot is located (run bdinfo) and avoid that location.
> It is again booting the same > old windows CE in the nand boot mode. > > Thanking you, > Regards
Best regards, Marek Vasut
Thanking you
