[PATCH 0/2] Move arasan nand driver to driver model
these two patches are moving nand driver to DM and also remove hardcoded base address of nand controller and get it from device tree.
Thanks, Michal
Ashok Reddy Soma (2): mtd: nand: Move arasan nand driver to driver model mtd: nand: Remove hardcoded base address of nand
arch/arm/mach-zynqmp/include/mach/hardware.h | 2 - drivers/mtd/nand/raw/Kconfig | 1 + drivers/mtd/nand/raw/arasan_nfc.c | 364 +++++++++++-------- 3 files changed, 206 insertions(+), 161 deletions(-)
Make changes to arasan nand driver to move it to driver model. Select DM_MTD if arasan nand driver is selected.
Signed-off-by: Ashok Reddy Soma ashok.reddy.soma@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
drivers/mtd/nand/raw/Kconfig | 1 + drivers/mtd/nand/raw/arasan_nfc.c | 52 +++++++++++++++++++++---------- 2 files changed, 37 insertions(+), 16 deletions(-)
diff --git a/drivers/mtd/nand/raw/Kconfig b/drivers/mtd/nand/raw/Kconfig index 16165f883902..ec17653f4149 100644 --- a/drivers/mtd/nand/raw/Kconfig +++ b/drivers/mtd/nand/raw/Kconfig @@ -236,6 +236,7 @@ endif config NAND_ARASAN bool "Configure Arasan Nand" select SYS_NAND_SELF_INIT + select DM_MTD imply CMD_NAND help This enables Nand driver support for Arasan nand flash diff --git a/drivers/mtd/nand/raw/arasan_nfc.c b/drivers/mtd/nand/raw/arasan_nfc.c index 2cd3f64dc63c..c2f7b3a42ee2 100644 --- a/drivers/mtd/nand/raw/arasan_nfc.c +++ b/drivers/mtd/nand/raw/arasan_nfc.c @@ -15,14 +15,19 @@ #include <linux/mtd/nand_ecc.h> #include <asm/arch/hardware.h> #include <asm/arch/sys_proto.h> +#include <dm.h> #include <nand.h>
-struct arasan_nand_info { - void __iomem *nand_base; +struct nand_config { u32 page; bool on_die_ecc_enabled; };
+struct arasan_nand_info { + struct udevice *dev; + struct nand_chip nand_chip; +}; + struct nand_regs { u32 pkt_reg; u32 memadr_reg1; @@ -259,8 +264,6 @@ static u32 buf_index;
static struct nand_ecclayout nand_oob;
-static struct nand_chip nand_chip[CONFIG_SYS_MAX_NAND_DEVICE]; - static void arasan_nand_select_chip(struct mtd_info *mtd, int chip) { u32 reg_val; @@ -323,7 +326,7 @@ static u8 arasan_nand_get_addrcycle(struct mtd_info *mtd) static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) { struct nand_chip *chip = mtd_to_nand(mtd); - struct arasan_nand_info *nand = nand_get_controller_data(chip); + struct nand_config *nand = nand_get_controller_data(chip); u32 reg_val, i, pktsize, pktnum; u32 *bufptr = (u32 *)buf; u32 timeout; @@ -505,7 +508,7 @@ static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, u32 size = mtd->writesize; u32 rdcount = 0; u8 column_addr_cycles; - struct arasan_nand_info *nand = nand_get_controller_data(chip); + struct nand_config *nand = nand_get_controller_data(chip);
if (chip->ecc_step_ds >= ARASAN_NAND_PKTSIZE_1K) pktsize = ARASAN_NAND_PKTSIZE_1K; @@ -1033,7 +1036,7 @@ static void arasan_nand_cmd_function(struct mtd_info *mtd, unsigned int command, { u32 i, ret = 0; struct nand_chip *chip = mtd_to_nand(mtd); - struct arasan_nand_info *nand = nand_get_controller_data(chip); + struct nand_config *nand = nand_get_controller_data(chip);
curr_cmd = NULL; writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, @@ -1088,7 +1091,7 @@ static void arasan_nand_cmd_function(struct mtd_info *mtd, unsigned int command, static void arasan_check_ondie(struct mtd_info *mtd) { struct nand_chip *nand_chip = mtd_to_nand(mtd); - struct arasan_nand_info *nand = nand_get_controller_data(nand_chip); + struct nand_config *nand = nand_get_controller_data(nand_chip); u8 maf_id, dev_id; u8 get_feature[4]; u8 set_feature[4] = {ENABLE_ONDIE_ECC, 0x00, 0x00, 0x00}; @@ -1184,19 +1187,20 @@ static int arasan_nand_ecc_init(struct mtd_info *mtd) return 0; }
-static int arasan_nand_init(struct nand_chip *nand_chip, int devnum) +static int arasan_probe(struct udevice *dev) { - struct arasan_nand_info *nand; + struct arasan_nand_info *arasan = dev_get_priv(dev); + struct nand_chip *nand_chip = &arasan->nand_chip; + struct nand_config *nand; struct mtd_info *mtd; int err = -1;
- nand = calloc(1, sizeof(struct arasan_nand_info)); + nand = calloc(1, sizeof(struct nand_config)); if (!nand) { printf("%s: failed to allocate\n", __func__); return err; }
- nand->nand_base = arasan_nand_base; mtd = nand_to_mtd(nand_chip); nand_set_controller_data(nand_chip, nand);
@@ -1253,7 +1257,7 @@ static int arasan_nand_init(struct nand_chip *nand_chip, int devnum) goto fail; }
- if (nand_register(devnum, mtd)) { + if (nand_register(0, mtd)) { printf("Nand Register Fail\n"); goto fail; } @@ -1264,10 +1268,26 @@ fail: return err; }
+static const struct udevice_id arasan_nand_dt_ids[] = { + {.compatible = "arasan,nfc-v3p10",}, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(arasan_nand) = { + .name = "arasan-nand", + .id = UCLASS_MTD, + .of_match = arasan_nand_dt_ids, + .probe = arasan_probe, + .priv_auto_alloc_size = sizeof(struct arasan_nand_info), +}; + void board_nand_init(void) { - struct nand_chip *nand = &nand_chip[0]; + struct udevice *dev; + int ret;
- if (arasan_nand_init(nand, 0)) - puts("NAND init failed\n"); + ret = uclass_get_device_by_driver(UCLASS_MTD, + DM_GET_DRIVER(arasan_nand), &dev); + if (ret && ret != -ENODEV) + pr_err("Failed to initialize %s. (error %d)\n", dev->name, ret); }
Remove hardcoded base address of nand and replace it with the value taken from device tree. Remove base address from header file too.
arch/arm/mach-zynqmp/include/mach/hardware.h | 2 - drivers/mtd/nand/raw/arasan_nfc.c | 322 ++++++++++--------- 2 files changed, 174 insertions(+), 150 deletions(-)
diff --git a/arch/arm/mach-zynqmp/include/mach/hardware.h b/arch/arm/mach-zynqmp/include/mach/hardware.h index a0d776166d02..fd361c5ce8a5 100644 --- a/arch/arm/mach-zynqmp/include/mach/hardware.h +++ b/arch/arm/mach-zynqmp/include/mach/hardware.h @@ -7,8 +7,6 @@ #ifndef _ASM_ARCH_HARDWARE_H #define _ASM_ARCH_HARDWARE_H
-#define ARASAN_NAND_BASEADDR 0xFF100000 - #define ZYNQMP_TCM_BASE_ADDR 0xFFE00000 #define ZYNQMP_TCM_SIZE 0x40000
diff --git a/drivers/mtd/nand/raw/arasan_nfc.c b/drivers/mtd/nand/raw/arasan_nfc.c index c2f7b3a42ee2..d1b1a4263a2e 100644 --- a/drivers/mtd/nand/raw/arasan_nfc.c +++ b/drivers/mtd/nand/raw/arasan_nfc.c @@ -23,8 +23,14 @@ struct nand_config { bool on_die_ecc_enabled; };
+struct nand_drv { + struct nand_regs *reg; + struct nand_config config; +}; + struct arasan_nand_info { struct udevice *dev; + struct nand_drv nand_ctrl; struct nand_chip nand_chip; };
@@ -59,8 +65,6 @@ struct nand_regs { u32 data_if_reg; };
-#define arasan_nand_base ((struct nand_regs __iomem *)ARASAN_NAND_BASEADDR) - struct arasan_nand_command_format { u8 cmd1; u8 cmd2; @@ -266,26 +270,30 @@ static struct nand_ecclayout nand_oob;
static void arasan_nand_select_chip(struct mtd_info *mtd, int chip) { + struct nand_chip *nand_chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(nand_chip); u32 reg_val;
- reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val = readl(&info->reg->memadr_reg2); if (chip == 0) { reg_val &= ~ARASAN_NAND_MEM_ADDR2_CS0_MASK; - writel(reg_val, &arasan_nand_base->memadr_reg2); + writel(reg_val, &info->reg->memadr_reg2); } else if (chip == 1) { reg_val |= ARASAN_NAND_MEM_ADDR2_CS1_MASK; - writel(reg_val, &arasan_nand_base->memadr_reg2); + writel(reg_val, &info->reg->memadr_reg2); } }
-static void arasan_nand_enable_ecc(void) +static void arasan_nand_enable_ecc(struct mtd_info *mtd) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 reg_val;
- reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val = readl(&info->reg->cmd_reg); reg_val |= ARASAN_NAND_CMD_ECC_ON_MASK;
- writel(reg_val, &arasan_nand_base->cmd_reg); + writel(reg_val, &info->reg->cmd_reg); }
static u8 arasan_nand_get_addrcycle(struct mtd_info *mtd) @@ -326,7 +334,8 @@ static u8 arasan_nand_get_addrcycle(struct mtd_info *mtd) static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) { struct nand_chip *chip = mtd_to_nand(mtd); - struct nand_config *nand = nand_get_controller_data(chip); + struct nand_drv *info = nand_get_controller_data(chip); + struct nand_config *nand = &info->config; u32 reg_val, i, pktsize, pktnum; u32 *bufptr = (u32 *)buf; u32 timeout; @@ -343,20 +352,20 @@ static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) else pktnum = size/pktsize;
- reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); reg_val |= ARASAN_NAND_INT_STS_ERR_EN_MASK | ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK; - writel(reg_val, &arasan_nand_base->intsts_enr); + writel(reg_val, &info->reg->intsts_enr);
- reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val = readl(&info->reg->pkt_reg); reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); reg_val |= (pktnum << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | pktsize; - writel(reg_val, &arasan_nand_base->pkt_reg); + writel(reg_val, &info->reg->pkt_reg);
if (!nand->on_die_ecc_enabled) { - arasan_nand_enable_ecc(); + arasan_nand_enable_ecc(mtd); addr_cycles = arasan_nand_get_addrcycle(mtd); if (addr_cycles == ARASAN_NAND_INVALID_ADDR_CYCL) return ERR_ADDR_CYCLE; @@ -364,13 +373,13 @@ static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) writel((NAND_CMD_RNDOUTSTART << ARASAN_NAND_CMD_CMD2_SHIFT) | NAND_CMD_RNDOUT | (addr_cycles << ARASAN_NAND_CMD_ADDR_CYCL_SHIFT), - &arasan_nand_base->ecc_sprcmd_reg); + &info->reg->ecc_sprcmd_reg); } - writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + writel(curr_cmd->pgm, &info->reg->pgm_reg);
while (rdcount < pktnum) { timeout = ARASAN_NAND_POLL_TIMEOUT; - while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK) && timeout) { udelay(1); timeout--; @@ -383,20 +392,20 @@ static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) rdcount++;
if (pktnum == rdcount) { - reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; - writel(reg_val, &arasan_nand_base->intsts_enr); + writel(reg_val, &info->reg->intsts_enr); } else { - reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, - &arasan_nand_base->intsts_enr); + &info->reg->intsts_enr); } - reg_val = readl(&arasan_nand_base->intsts_reg); + reg_val = readl(&info->reg->intsts_reg); writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg);
for (i = 0; i < pktsize/4; i++) - bufptr[i] = readl(&arasan_nand_base->buf_dataport); + bufptr[i] = readl(&info->reg->buf_dataport);
bufptr += pktsize/4; @@ -405,12 +414,12 @@ static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) break;
writel(ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, - &arasan_nand_base->intsts_enr); + &info->reg->intsts_enr); }
- while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { udelay(1); timeout--; @@ -420,21 +429,21 @@ static int arasan_nand_read_page(struct mtd_info *mtd, u8 *buf, u32 size) return -ETIMEDOUT; }
- reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); - reg_val = readl(&arasan_nand_base->intsts_reg); + &info->reg->intsts_enr); + reg_val = readl(&info->reg->intsts_reg); writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg);
if (!nand->on_die_ecc_enabled) { - if (readl(&arasan_nand_base->intsts_reg) & + if (readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_MUL_BIT_ERR_MASK) { printf("arasan rd_page:sbiterror\n"); return -1; }
- if (readl(&arasan_nand_base->intsts_reg) & + if (readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_ERR_EN_MASK) { mtd->ecc_stats.failed++; printf("arasan rd_page:multibiterror\n"); @@ -458,9 +467,11 @@ static int arasan_nand_read_page_hwecc(struct mtd_info *mtd, return status; }
-static void arasan_nand_fill_tx(const u8 *buf, int len) +static void arasan_nand_fill_tx(struct mtd_info *mtd, const u8 *buf, int len) { - u32 __iomem *nand = &arasan_nand_base->buf_dataport; + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); + u32 __iomem *nand = &info->reg->buf_dataport;
if (((unsigned long)buf & 0x3) != 0) { if (((unsigned long)buf & 0x1) != 0) { @@ -502,13 +513,14 @@ static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, struct nand_chip *chip, const u8 *buf, int oob_required, int page) { + struct nand_drv *info = nand_get_controller_data(chip); + struct nand_config *nand = &info->config; u32 reg_val, i, pktsize, pktnum; const u32 *bufptr = (const u32 *)buf; u32 timeout = ARASAN_NAND_POLL_TIMEOUT; u32 size = mtd->writesize; u32 rdcount = 0; u8 column_addr_cycles; - struct nand_config *nand = nand_get_controller_data(chip);
if (chip->ecc_step_ds >= ARASAN_NAND_PKTSIZE_1K) pktsize = ARASAN_NAND_PKTSIZE_1K; @@ -520,25 +532,25 @@ static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, else pktnum = size/pktsize;
if (!nand->on_die_ecc_enabled) { - arasan_nand_enable_ecc(); + arasan_nand_enable_ecc(mtd); column_addr_cycles = (chip->onfi_params.addr_cycles & ARASAN_NAND_COL_ADDR_CYCL_MASK) >> ARASAN_NAND_COL_ADDR_CYCL_SHIFT; writel((NAND_CMD_RNDIN | (column_addr_cycles << 28)), - &arasan_nand_base->ecc_sprcmd_reg); + &info->reg->ecc_sprcmd_reg); } - writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + writel(curr_cmd->pgm, &info->reg->pgm_reg);
while (rdcount < pktnum) { timeout = ARASAN_NAND_POLL_TIMEOUT; - while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK) && timeout) { udelay(1); timeout--; @@ -552,21 +564,21 @@ static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, rdcount++;
if (pktnum == rdcount) { - reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; - writel(reg_val, &arasan_nand_base->intsts_enr); + writel(reg_val, &info->reg->intsts_enr); } else { - reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, - &arasan_nand_base->intsts_enr); + &info->reg->intsts_enr); }
- reg_val = readl(&arasan_nand_base->intsts_reg); + reg_val = readl(&info->reg->intsts_reg); writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg);
for (i = 0; i < pktsize/4; i++) - writel(bufptr[i], &arasan_nand_base->buf_dataport); + writel(bufptr[i], &info->reg->buf_dataport);
@@ -574,12 +586,12 @@ static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, break;
writel(ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, - &arasan_nand_base->intsts_enr); + &info->reg->intsts_enr); }
- while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { udelay(1); timeout--; @@ -589,12 +601,12 @@ static int arasan_nand_write_page_hwecc(struct mtd_info *mtd, return -ETIMEDOUT; }
if (oob_required) chip->ecc.write_oob(mtd, chip, nand->page); @@ -623,22 +635,25 @@ static int arasan_nand_write_oob(struct mtd_info *mtd, struct nand_chip *chip, return status; }
-static int arasan_nand_reset(struct arasan_nand_command_format *curr_cmd) +static int arasan_nand_reset(struct mtd_info *mtd, + struct arasan_nand_command_format *curr_cmd) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 timeout = ARASAN_NAND_POLL_TIMEOUT; u32 cmd_reg = 0;
writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); - cmd_reg = readl(&arasan_nand_base->cmd_reg); + &info->reg->intsts_enr); + cmd_reg = readl(&info->reg->cmd_reg); cmd_reg &= ~ARASAN_NAND_CMD_CMD12_MASK;
cmd_reg |= curr_cmd->cmd1 | (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); - writel(cmd_reg, &arasan_nand_base->cmd_reg); - writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + writel(cmd_reg, &info->reg->cmd_reg); + writel(curr_cmd->pgm, &info->reg->pgm_reg);
- while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { udelay(1); timeout--; @@ -649,10 +664,10 @@ static int arasan_nand_reset(struct arasan_nand_command_format *curr_cmd) }
writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); + &info->reg->intsts_enr);
writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg);
return 0; } @@ -691,12 +706,14 @@ static u8 arasan_nand_page(struct mtd_info *mtd) static int arasan_nand_send_wrcmd(struct arasan_nand_command_format *curr_cmd, int column, int page_addr, struct mtd_info *mtd) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 reg_val, page; u8 page_val, addr_cycles;
writel(ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, - &arasan_nand_base->intsts_enr); - reg_val = readl(&arasan_nand_base->cmd_reg); + &info->reg->intsts_enr); + reg_val = readl(&info->reg->cmd_reg); reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; reg_val |= curr_cmd->cmd1 | (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); @@ -714,7 +731,7 @@ static int arasan_nand_send_wrcmd(struct arasan_nand_command_format *curr_cmd,
reg_val |= (addr_cycles << ARASAN_NAND_CMD_ADDR_CYCL_SHIFT); - writel(reg_val, &arasan_nand_base->cmd_reg); + writel(reg_val, &info->reg->cmd_reg);
if (page_addr == -1) page_addr = 0; @@ -722,30 +739,32 @@ static int arasan_nand_send_wrcmd(struct arasan_nand_command_format *curr_cmd, page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & ARASAN_NAND_MEM_ADDR1_PAGE_MASK; column &= ARASAN_NAND_MEM_ADDR1_COL_MASK; - writel(page|column, &arasan_nand_base->memadr_reg1); + writel(page | column, &info->reg->memadr_reg1);
- reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val = readl(&info->reg->memadr_reg2); reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); - writel(reg_val, &arasan_nand_base->memadr_reg2); + writel(reg_val, &info->reg->memadr_reg2);
return 0; }
static void arasan_nand_write_buf(struct mtd_info *mtd, const u8 *buf, int len) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 reg_val; u32 timeout = ARASAN_NAND_POLL_TIMEOUT;
reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | len; - writel(reg_val, &arasan_nand_base->pkt_reg); - writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + writel(reg_val, &info->reg->pkt_reg); + writel(curr_cmd->pgm, &info->reg->pgm_reg);
- while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK) && timeout) { udelay(1); timeout--; @@ -754,19 +773,19 @@ static void arasan_nand_write_buf(struct mtd_info *mtd, const u8 *buf, int len) if (!timeout) puts("ERROR:arasan_nand_write_buf timedout:Buff RDY\n");
- reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); reg_val |= ARASAN_NAND_INT_STS_XFR_CMPLT_MASK; - writel(reg_val, &arasan_nand_base->intsts_enr); + writel(reg_val, &info->reg->intsts_enr); writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, - &arasan_nand_base->intsts_enr); - reg_val = readl(&arasan_nand_base->intsts_reg); + &info->reg->intsts_enr); + reg_val = readl(&info->reg->intsts_reg); writel(reg_val | ARASAN_NAND_INT_STS_BUF_WR_RDY_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg);
- arasan_nand_fill_tx(buf, len); + arasan_nand_fill_tx(mtd, buf, len);
timeout = ARASAN_NAND_POLL_TIMEOUT; - while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { udelay(1); timeout--; @@ -774,24 +793,26 @@ static void arasan_nand_write_buf(struct mtd_info *mtd, const u8 *buf, int len) if (!timeout) puts("ERROR:arasan_nand_write_buf timedout:Xfer CMPLT\n");
- writel(readl(&arasan_nand_base->intsts_enr) | + writel(readl(&info->reg->intsts_enr) | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); - writel(readl(&arasan_nand_base->intsts_reg) | + &info->reg->intsts_enr); + writel(readl(&info->reg->intsts_reg) | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg); }
static int arasan_nand_erase(struct arasan_nand_command_format *curr_cmd, int column, int page_addr, struct mtd_info *mtd) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 reg_val, page; u32 timeout = ARASAN_NAND_POLL_TIMEOUT; u8 row_addr_cycles;
writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); - reg_val = readl(&arasan_nand_base->cmd_reg); + &info->reg->intsts_enr); + reg_val = readl(&info->reg->cmd_reg); reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; reg_val |= curr_cmd->cmd1 | (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); @@ -804,21 +825,21 @@ static int arasan_nand_erase(struct arasan_nand_command_format *curr_cmd, reg_val |= (row_addr_cycles << ARASAN_NAND_CMD_ADDR_CYCL_SHIFT);
page = (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & ARASAN_NAND_MEM_ADDR1_COL_MASK; column = page_addr & ARASAN_NAND_MEM_ADDR1_COL_MASK; writel(column | (page << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT), - &arasan_nand_base->memadr_reg1); + &info->reg->memadr_reg1);
- reg_val = readl(&arasan_nand_base->memadr_reg2); + reg_val = readl(&info->reg->memadr_reg2); reg_val &= ~ARASAN_NAND_MEM_ADDR2_PAGE_MASK; reg_val |= (page_addr >> ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT); - writel(reg_val, &arasan_nand_base->memadr_reg2); - writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); + writel(reg_val, &info->reg->memadr_reg2); + writel(curr_cmd->pgm, &info->reg->pgm_reg);
- while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { udelay(1); timeout--; @@ -828,12 +849,12 @@ static int arasan_nand_erase(struct arasan_nand_command_format *curr_cmd, return -ETIMEDOUT; }
return 0; } @@ -841,13 +862,15 @@ static int arasan_nand_erase(struct arasan_nand_command_format *curr_cmd, static int arasan_nand_read_status(struct arasan_nand_command_format *curr_cmd, int column, int page_addr, struct mtd_info *mtd) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 reg_val; u32 timeout = ARASAN_NAND_POLL_TIMEOUT; u8 addr_cycles;
writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); - reg_val = readl(&arasan_nand_base->cmd_reg); + &info->reg->intsts_enr); + reg_val = readl(&info->reg->cmd_reg); reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; reg_val |= curr_cmd->cmd1 | (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); @@ -860,16 +883,16 @@ static int arasan_nand_read_status(struct arasan_nand_command_format *curr_cmd, reg_val |= (addr_cycles << ARASAN_NAND_CMD_ADDR_CYCL_SHIFT);
- reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val = readl(&info->reg->pkt_reg); reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | 1; - writel(reg_val, &arasan_nand_base->pkt_reg); + writel(reg_val, &info->reg->pkt_reg);
- writel(curr_cmd->pgm, &arasan_nand_base->pgm_reg); - while (!(readl(&arasan_nand_base->intsts_reg) & + writel(curr_cmd->pgm, &info->reg->pgm_reg); + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { udelay(1); timeout--; @@ -880,12 +903,12 @@ static int arasan_nand_read_status(struct arasan_nand_command_format *curr_cmd, return -ETIMEDOUT; }
return 0; } @@ -893,14 +916,16 @@ static int arasan_nand_read_status(struct arasan_nand_command_format *curr_cmd, static int arasan_nand_send_rdcmd(struct arasan_nand_command_format *curr_cmd, int column, int page_addr, struct mtd_info *mtd) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 reg_val, addr_cycles, page; u8 page_val;
- reg_val = readl(&arasan_nand_base->cmd_reg); + reg_val = readl(&info->reg->cmd_reg); reg_val &= ~ARASAN_NAND_CMD_CMD12_MASK; reg_val |= curr_cmd->cmd1 | (curr_cmd->cmd2 << ARASAN_NAND_CMD_CMD2_SHIFT); @@ -922,7 +947,7 @@ static int arasan_nand_send_rdcmd(struct arasan_nand_command_format *curr_cmd, return ERR_ADDR_CYCLE;
reg_val |= (addr_cycles << 28); - writel(reg_val, &arasan_nand_base->cmd_reg); + writel(reg_val, &info->reg->cmd_reg);
if (page_addr == -1) page_addr = 0; @@ -930,12 +955,12 @@ static int arasan_nand_send_rdcmd(struct arasan_nand_command_format *curr_cmd, page = (page_addr << ARASAN_NAND_MEM_ADDR1_PAGE_SHIFT) & ARASAN_NAND_MEM_ADDR1_PAGE_MASK; column &= ARASAN_NAND_MEM_ADDR1_COL_MASK; - writel(page | column, &arasan_nand_base->memadr_reg1); + writel(page | column, &info->reg->memadr_reg1);
buf_index = 0;
@@ -944,19 +969,21 @@ static int arasan_nand_send_rdcmd(struct arasan_nand_command_format *curr_cmd,
static void arasan_nand_read_buf(struct mtd_info *mtd, u8 *buf, int size) { + struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 reg_val, i; u32 *bufptr = (u32 *)buf; u32 timeout = ARASAN_NAND_POLL_TIMEOUT;
- reg_val = readl(&arasan_nand_base->pkt_reg); + reg_val = readl(&info->reg->pkt_reg); reg_val &= ~(ARASAN_NAND_PKT_REG_PKT_CNT_MASK | ARASAN_NAND_PKT_REG_PKT_SIZE_MASK); reg_val |= (1 << ARASAN_NAND_PKT_REG_PKT_CNT_SHFT) | size; - writel(reg_val, &arasan_nand_base->pkt_reg); + writel(reg_val, &info->reg->pkt_reg);
- while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK) && timeout) { udelay(1); timeout--; @@ -965,26 +992,26 @@ static void arasan_nand_read_buf(struct mtd_info *mtd, u8 *buf, int size) if (!timeout) puts("ERROR:arasan_nand_read_buf timedout:Buff RDY\n");
writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, - &arasan_nand_base->intsts_enr); - reg_val = readl(&arasan_nand_base->intsts_reg); + &info->reg->intsts_enr); + reg_val = readl(&info->reg->intsts_reg); writel(reg_val | ARASAN_NAND_INT_STS_BUF_RD_RDY_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg);
buf_index = 0; for (i = 0; i < size / 4; i++) - bufptr[i] = readl(&arasan_nand_base->buf_dataport); + bufptr[i] = readl(&info->reg->buf_dataport);
if (size & 0x03) - bufptr[i] = readl(&arasan_nand_base->buf_dataport); + bufptr[i] = readl(&info->reg->buf_dataport);
- while (!(readl(&arasan_nand_base->intsts_reg) & + while (!(readl(&info->reg->intsts_reg) & ARASAN_NAND_INT_STS_XFR_CMPLT_MASK) && timeout) { udelay(1); timeout--; @@ -993,17 +1020,18 @@ static void arasan_nand_read_buf(struct mtd_info *mtd, u8 *buf, int size) if (!timeout) puts("ERROR:arasan_nand_read_buf timedout:Xfer CMPLT\n");
- reg_val = readl(&arasan_nand_base->intsts_enr); + reg_val = readl(&info->reg->intsts_enr); writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); - reg_val = readl(&arasan_nand_base->intsts_reg); + &info->reg->intsts_enr); + reg_val = readl(&info->reg->intsts_reg); writel(reg_val | ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_reg); + &info->reg->intsts_reg); }
static u8 arasan_nand_read_byte(struct mtd_info *mtd) { struct nand_chip *chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(chip); u32 size; u8 val; struct nand_onfi_params *p; @@ -1019,7 +1047,7 @@ static u8 arasan_nand_read_byte(struct mtd_info *mtd) else if (curr_cmd->cmd1 == NAND_CMD_GET_FEATURES) size = 4; else if (curr_cmd->cmd1 == NAND_CMD_STATUS) - return readb(&arasan_nand_base->flash_sts_reg); + return readb(&info->reg->flash_sts_reg); else size = 8; chip->read_buf(mtd, &buf_data[0], size); @@ -1034,13 +1062,14 @@ static u8 arasan_nand_read_byte(struct mtd_info *mtd) static void arasan_nand_cmd_function(struct mtd_info *mtd, unsigned int command, int column, int page_addr) { - u32 i, ret = 0; struct nand_chip *chip = mtd_to_nand(mtd); - struct nand_config *nand = nand_get_controller_data(chip); + struct nand_drv *info = nand_get_controller_data(chip); + struct nand_config *nand = &info->config; + u32 i, ret = 0;
curr_cmd = NULL; writel(ARASAN_NAND_INT_STS_XFR_CMPLT_MASK, - &arasan_nand_base->intsts_enr); + &info->reg->intsts_enr);
if ((command == NAND_CMD_READOOB) && (mtd->writesize > 512)) { @@ -1063,7 +1092,7 @@ static void arasan_nand_cmd_function(struct mtd_info *mtd, unsigned int command, }
if (curr_cmd->cmd1 == NAND_CMD_RESET) - ret = arasan_nand_reset(curr_cmd); + ret = arasan_nand_reset(mtd, curr_cmd);
if ((curr_cmd->cmd1 == NAND_CMD_READID) || (curr_cmd->cmd1 == NAND_CMD_PARAM) || @@ -1134,9 +1163,10 @@ static void arasan_check_ondie(struct mtd_info *mtd)
static int arasan_nand_ecc_init(struct mtd_info *mtd) { + struct nand_chip *nand_chip = mtd_to_nand(mtd); + struct nand_drv *info = nand_get_controller_data(nand_chip); int found = -1; u32 regval, eccpos_start, i, eccaddr; - struct nand_chip *nand_chip = mtd_to_nand(mtd);
for (i = 0; i < ARRAY_SIZE(ecc_matrix); i++) { if ((ecc_matrix[i].pagesize == mtd->writesize) && @@ -1160,14 +1190,14 @@ static int arasan_nand_ecc_init(struct mtd_info *mtd) regval = eccaddr | (ecc_matrix[found].eccsize << ARASAN_NAND_ECC_SIZE_SHIFT) | (ecc_matrix[found].bch << ARASAN_NAND_ECC_BCH_SHIFT); - writel(regval, &arasan_nand_base->ecc_reg); + writel(regval, &info->reg->ecc_reg);
if (ecc_matrix[found].bch) { - regval = readl(&arasan_nand_base->memadr_reg2); + regval = readl(&info->reg->memadr_reg2); regval &= ~ARASAN_NAND_MEM_ADDR2_BCH_MASK; regval |= (ecc_matrix[found].bchval << ARASAN_NAND_MEM_ADDR2_BCH_SHIFT); - writel(regval, &arasan_nand_base->memadr_reg2); + writel(regval, &info->reg->memadr_reg2); }
nand_oob.eccbytes = ecc_matrix[found].eccsize; @@ -1191,18 +1221,14 @@ static int arasan_probe(struct udevice *dev) { struct arasan_nand_info *arasan = dev_get_priv(dev); struct nand_chip *nand_chip = &arasan->nand_chip; - struct nand_config *nand; + struct nand_drv *info = &arasan->nand_ctrl; + struct nand_config *nand = &info->config; struct mtd_info *mtd; int err = -1;
- nand = calloc(1, sizeof(struct nand_config)); - if (!nand) { - printf("%s: failed to allocate\n", __func__); - return err; - } - + info->reg = (struct nand_regs *)dev_read_addr(dev); mtd = nand_to_mtd(nand_chip); - nand_set_controller_data(nand_chip, nand); + nand_set_controller_data(nand_chip, &arasan->nand_ctrl);
#ifdef CONFIG_SYS_NAND_NO_SUBPAGE_WRITE nand_chip->options |= NAND_NO_SUBPAGE_WRITE; @@ -1218,8 +1244,8 @@ static int arasan_probe(struct udevice *dev) nand_chip->write_buf = arasan_nand_write_buf; nand_chip->bbt_options = NAND_BBT_USE_FLASH;
- writel(0x0, &arasan_nand_base->cmd_reg); - writel(0x0, &arasan_nand_base->pgm_reg); + writel(0x0, &info->reg->cmd_reg); + writel(0x0, &info->reg->pgm_reg);
/* first scan to find the device and get the page size */ if (nand_scan_ident(mtd, CONFIG_SYS_NAND_MAX_CHIPS, NULL)) {
čt 19. 12. 2019 v 16:06 odesílatel Michal Simek michal.simek@xilinx.com napsal:
Thanks, Michal
-- 2.24.0
Applied. M
Michal Simek
Michal Simek
