[U-Boot] [PATCH 1/2] ARM: versatile: pass correct machine type for Versatile AB
When U-Boot is configured for Versatile AB, it will still pass the machine ID of Versatile PB to the kernel. After this simple fix the system boots correctly.
Cc: Stefano Babic sbabic@denx.de Cc: Marek Vasut marex@denx.de Signed-off-by: Linus Walleij linus.walleij@linaro.org --- board/armltd/versatile/versatile.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/board/armltd/versatile/versatile.c b/board/armltd/versatile/versatile.c index 30a3b904db4c..4e2d3421d8b1 100644 --- a/board/armltd/versatile/versatile.c +++ b/board/armltd/versatile/versatile.c @@ -52,7 +52,11 @@ int board_early_init_f (void) int board_init (void) { /* arch number of Versatile Board */ +#ifdef CONFIG_ARCH_VERSATILE_AB + gd->bd->bi_arch_number = MACH_TYPE_VERSATILE_AB; +#else gd->bd->bi_arch_number = MACH_TYPE_VERSATILE_PB; +#endif
/* adress of boot parameters */ gd->bd->bi_boot_params = 0x00000100;
Dear Linus Walleij,
- gd->bd->bi_arch_number = MACH_TYPE_VERSATILE_AB;
We should just switch to DT, but I do understand the motivation here. Can you not detect which board it is dynamically to avoid the ifdef?
Otherwise:
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
I will be working on cleanups and DT next, this is just to get a working baseline.
No :-/
Yours, Linus Walleij
On 27/11/2013 10:55, Marek Vasut wrote:
Dear Linus Walleij,
I do not know if it is possible, but if yes, we did not need in the past to introduce CONFIG_ARCH_VERSATILE_AB.
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
The boards are similar enough that they will boot to prompt, but they will register the wrong set of peripherals, and some stuff will not work...
Linus Walleij
Dear Linus Walleij,
+CC Albert, he's the ARM guy. Stefano is the Freescale IMX guy :)
On Wed, Nov 27, 2013 at 11:02 AM, Marek Vasut marex@denx.de wrote:
Dear Linus Walleij,
I just saw in the git log that Stefano had a few commits to these boards...
Hi Linus,
On Wed, 27 Nov 2013 10:33:32 +0100, Linus Walleij linus.walleij@linaro.org wrote:
Applied to u-boot-arm/next, thanks!
Amicalement,
Albert ARIBAUD
Linus Walleij
Stefano Babic
