[PATCH V2] net: smc911x: Automatically Update ethaddr with MAC
The ethernet controller can read the MAC from EEPROM and display it, but if ethaddr is not set, the ethernet is still unavailable.
This patch checks will automatically set the MAC address if it has not already been set.
Signed-off-by: Adam Ford aford173@gmail.com --- V2: Fix typo
diff --git a/drivers/net/smc911x.c b/drivers/net/smc911x.c index 09372d7f6b..1fa3667b77 100644 --- a/drivers/net/smc911x.c +++ b/drivers/net/smc911x.c @@ -6,6 +6,7 @@ */
#include <common.h> +#include <env.h> #include <command.h> #include <malloc.h> #include <net.h> @@ -185,6 +186,8 @@ static void smc911x_handle_mac_address(struct smc911x_priv *priv) smc911x_set_mac_csr(priv, ADDRH, addrh);
printf(DRIVERNAME ": MAC %pM\n", m); + if (!env_get("ethaddr")) + env_set("ethaddr", (const char *)m); }
static bool smc911x_read_mac_address(struct smc911x_priv *priv)
V2: Fix typo
Ping. Any chance this can get reviewed?
thank you,
adam
2.17.1
Signed-off-by: Adam Ford aford173@gmail.com Acked-by: Joe Hershberger joe.hershberger@ni.com
Note that this breaks every single setup where smc911x is not primary ethernet. On systems where smc911x is secondary ethernet, you need to set eth1addr and so on, so please do fix that.
Also, this kind of ethXaddr update should happen in the ethernet core instead, drivers shouldn't really modify environment, no ?
Interesting points. So, if smc911x is not the primary ether device, something else will have already set "ethaddr", most likely. We do have both the common case where "ethaddr" (and "eth1addr" and so forth) are set.
Adam, when exactly did you run in to the case where ethaddr wasn't set correctly? Was it on a non-DM_ETH case? To Marek's last point, we do have drivers that set ethaddr/ethXaddr, but that's in the non-DM_ETH case.
Thanks!
The only situation I tested was with DM_ETH since I thought it was going to be a requirement by 2020.07. If ethaddr is already set, it shouldn't override it, but I can see an issue where using the SMC911x as a secondary controller may cause an issue because the driver at this level doesn't know.
It seems like there should be a way to determine if the MAC address is readable so the user doesn't need to enter it manually, but it's probably not at the driver level based on the feedback.
If you want to revert this patch, I won't object. I don't really have time to develop a better one right now.
adam
Thanks!
-- Tom
Well, wait. Did you encounter a case where "ethaddr" was not automatically correctly set? A quick skim of the driver and it looks like it's doing everything needed for the common code to set "ethaddr" correctly from enetaddr the driver probed. Thanks!
it,
have
to
secondary
know.
time
I haven't tried lately, but when booting the Logic PD OMAP3 boards, I was seeing a message displaying the MAC address while simultaneously showing the message that it didn't have an address, so DHCP calls would fail. I could confirm that ethaddr was not set. However, if I manually set the ethaddr to the value dumped by the SMC911x driver, save the environmental variables then reset the board, the ethernet would work. It seemed like the area where the SMC911x displayed the MAC address made sense to update it since it just finished fetching it. so that's why I set up the patch the way it was. I hadn't considered a use case where it wasn't the primary ethernet controller.
adam
-- Tom
it,
> but if ethaddr is not set, the ethernet is still unavailable. > > This patch checks will automatically set the MAC address if it has > not already been set. > > Signed-off-by: Adam Ford aford173@gmail.com > Acked-by: Joe Hershberger joe.hershberger@ni.com
have
to
secondary
know.
time
Unless there is something else broken, the driver does provide a callback to pull ethernet address from the EEPROM already, and that should permit the driver core to set ethXaddr. So can you please debug that, why it is not happening on your board, instead of adding the current workaround ?
On 10/1/20 4:09 PM, Tom Rini wrote: > On Tue, Aug 18, 2020 at 08:19:02AM -0500, Adam Ford wrote: > >> The ethernet controller can read the MAC from EEPROM and display
it,
>> but if ethaddr is not set, the ethernet is still unavailable. >> >> This patch checks will automatically set the MAC address if it has >> not already been set. >> >> Signed-off-by: Adam Ford aford173@gmail.com >> Acked-by: Joe Hershberger joe.hershberger@ni.com > > Applied to u-boot/next, thanks!
have
to
secondary
know.
time
It does sound like something more fundamental is broken in that particular setup if the generic code path in net/net-uclass.c to set "ethaddr"/etc as appropriate is not called. I will revert this for now, as you said. Thanks!
On Thu, Oct 01, 2020 at 07:48:32PM +0200, Marek Vasut wrote: > On 10/1/20 4:09 PM, Tom Rini wrote: >> On Tue, Aug 18, 2020 at 08:19:02AM -0500, Adam Ford wrote: >> >>> The ethernet controller can read the MAC from EEPROM and display
it,
>>> but if ethaddr is not set, the ethernet is still unavailable. >>> >>> This patch checks will automatically set the MAC address if it has >>> not already been set. >>> >>> Signed-off-by: Adam Ford aford173@gmail.com >>> Acked-by: Joe Hershberger joe.hershberger@ni.com >> >> Applied to u-boot/next, thanks! > > Note that this breaks every single setup where smc911x is not primary > ethernet. On systems where smc911x is secondary ethernet, you need to > set eth1addr and so on, so please do fix that. > > Also, this kind of ethXaddr update should happen in the ethernet core > instead, drivers shouldn't really modify environment, no ?
have
to
secondary
know.
time
That's fine, but it would be good to figure out what was broken in that other setup too.
Adam Ford
Joe Hershberger
