[U-Boot] [PATCH 0/2] Add usb eth support
Arndale board has AX88760, which is USB 2.0 Hub & USB 2.0 Ethernet Combo controller, connected to HSIC Phy of USB host controller via USB3503 hub.
This patchset add support for this usb ethernet controllor.
Chander Kashyap (1): exynos5: arndale: Add network support
Inderpal Singh (1): usb: ehci: exynos: set/reset hsic phys
arch/arm/include/asm/arch-exynos/ehci.h | 14 +++++++++ board/samsung/arndale/arndale.c | 23 +++++++++++++++ drivers/usb/host/ehci-exynos.c | 48 +++++++++++++++++++++++++++++++ include/configs/arndale.h | 6 ++++ 4 files changed, 91 insertions(+)
The controller has 3 ports. The port0 is for USB 2.0 Phy, port1 and port2 are for HSIC phys. The usb 2.0 phy is already being setup. This patch sets up the hsic phys.
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org --- arch/arm/include/asm/arch-exynos/ehci.h | 14 +++++++++++ drivers/usb/host/ehci-exynos.c | 39 +++++++++++++++++++++++++++++++ 2 files changed, 53 insertions(+)
diff --git a/arch/arm/include/asm/arch-exynos/ehci.h b/arch/arm/include/asm/arch-exynos/ehci.h index d79f25c..d2d70bd 100644 --- a/arch/arm/include/asm/arch-exynos/ehci.h +++ b/arch/arm/include/asm/arch-exynos/ehci.h @@ -29,6 +29,20 @@ #define EHCICTRL_ENAINCR8 (1 << 27) #define EHCICTRL_ENAINCR16 (1 << 26)
+#define HSIC_CTRL_REFCLKSEL (0x2) +#define HSIC_CTRL_REFCLKSEL_MASK (0x3) +#define HSIC_CTRL_REFCLKSEL_SHIFT (23) + +#define HSIC_CTRL_REFCLKDIV_12 (0x24) +#define HSIC_CTRL_REFCLKDIV_MASK (0x7f) +#define HSIC_CTRL_REFCLKDIV_SHIFT (16) + +#define HSIC_CTRL_SIDDQ (0x1 << 6) +#define HSIC_CTRL_FORCESLEEP (0x1 << 5) +#define HSIC_CTRL_FORCESUSPEND (0x1 << 4) +#define HSIC_CTRL_UTMISWRST (0x1 << 2) +#define HSIC_CTRL_PHYSWRST (0x1 << 0) + /* Register map for PHY control */ struct exynos_usb_phy { unsigned int usbphyctrl0; diff --git a/drivers/usb/host/ehci-exynos.c b/drivers/usb/host/ehci-exynos.c index 155677e..50fbf36 100644 --- a/drivers/usb/host/ehci-exynos.c +++ b/drivers/usb/host/ehci-exynos.c @@ -83,6 +83,8 @@ static int exynos_usb_parse_dt(const void *blob, struct exynos_ehci *exynos) /* Setup the EHCI host controller. */ static void setup_usb_phy(struct exynos_usb_phy *usb) { + u32 hsic_ctrl; + set_usbhost_mode(USB20_PHY_CFG_HOST_LINK_EN);
set_usbhost_phy_ctrl(POWER_USB_HOST_PHY_CTRL_EN); @@ -107,6 +109,32 @@ static void setup_usb_phy(struct exynos_usb_phy *usb) clrbits_le32(&usb->usbphyctrl0, HOST_CTRL0_LINKSWRST | HOST_CTRL0_UTMISWRST); + + /* HSIC Phy Setting */ + hsic_ctrl = (HSIC_CTRL_FORCESUSPEND | + HSIC_CTRL_FORCESLEEP | + HSIC_CTRL_SIDDQ); + + clrbits_le32(&usb->hsicphyctrl1, hsic_ctrl); + clrbits_le32(&usb->hsicphyctrl2, hsic_ctrl); + + hsic_ctrl = (((HSIC_CTRL_REFCLKDIV_12 & HSIC_CTRL_REFCLKDIV_MASK) + << HSIC_CTRL_REFCLKDIV_SHIFT) + | ((HSIC_CTRL_REFCLKSEL & HSIC_CTRL_REFCLKSEL_MASK) + << HSIC_CTRL_REFCLKSEL_SHIFT) + | HSIC_CTRL_UTMISWRST); + + setbits_le32(&usb->hsicphyctrl1, hsic_ctrl); + setbits_le32(&usb->hsicphyctrl2, hsic_ctrl); + + udelay(10); + + clrbits_le32(&usb->hsicphyctrl1, HSIC_CTRL_PHYSWRST | + HSIC_CTRL_UTMISWRST); + + clrbits_le32(&usb->hsicphyctrl2, HSIC_CTRL_PHYSWRST | + HSIC_CTRL_UTMISWRST); + udelay(20);
/* EHCI Ctrl setting */ @@ -120,6 +148,8 @@ static void setup_usb_phy(struct exynos_usb_phy *usb) /* Reset the EHCI host controller. */ static void reset_usb_phy(struct exynos_usb_phy *usb) { + u32 hsic_ctrl; + /* HOST_PHY reset */ setbits_le32(&usb->usbphyctrl0, HOST_CTRL0_PHYSWRST | @@ -128,6 +158,15 @@ static void reset_usb_phy(struct exynos_usb_phy *usb) HOST_CTRL0_FORCESUSPEND | HOST_CTRL0_FORCESLEEP);
+ /* HSIC Phy reset */ + hsic_ctrl = (HSIC_CTRL_FORCESUSPEND | + HSIC_CTRL_FORCESLEEP | + HSIC_CTRL_SIDDQ | + HSIC_CTRL_PHYSWRST); + + setbits_le32(&usb->hsicphyctrl1, hsic_ctrl); + setbits_le32(&usb->hsicphyctrl2, hsic_ctrl); + set_usbhost_phy_ctrl(POWER_USB_HOST_PHY_CTRL_DISABLE); }
This patch implements a board specific board_usb_init function in ehci driver to perform reset sequence for USB3503 hub and enables the relevant config options for network to work.
Signed-off-by: Inderpal Singh inderpal.singh@linaro.org Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- board/samsung/arndale/arndale.c | 23 +++++++++++++++++++++++ drivers/usb/host/ehci-exynos.c | 9 +++++++++ include/configs/arndale.h | 6 ++++++ 3 files changed, 38 insertions(+)
diff --git a/board/samsung/arndale/arndale.c b/board/samsung/arndale/arndale.c index 052fecd..44f20b9 100644 --- a/board/samsung/arndale/arndale.c +++ b/board/samsung/arndale/arndale.c @@ -7,10 +7,23 @@ #include <common.h> #include <asm/arch/pinmux.h> #include <asm/arch/dwmmc.h> +#include <asm/arch/gpio.h> #include <asm/arch/power.h>
DECLARE_GLOBAL_DATA_PTR;
+#ifdef CONFIG_USB_EHCI_EXYNOS +void board_usb_init(int value) +{ + struct exynos5_gpio_part1 *gpio = (struct exynos5_gpio_part1 *) + samsung_get_base_gpio_part1(); + + /* Configure gpios for usb 3503 hub's reset and connect */ + s5p_gpio_direction_output(&gpio->x3, 5, value); + s5p_gpio_direction_output(&gpio->d1, 7, value); +} +#endif + int board_init(void) { gd->bd->bi_boot_params = (PHYS_SDRAM_1 + 0x100UL); @@ -91,6 +104,16 @@ int board_early_init_f(void) } #endif
+#ifdef CONFIG_BOARD_LATE_INIT +int board_late_init(void) +{ +#ifdef CONFIG_PREBOOT + setenv("preboot", CONFIG_PREBOOT); + setenv("usbethaddr", "00:40:5c:26:0a:5b"); +#endif +} +#endif + #ifdef CONFIG_DISPLAY_BOARDINFO int checkboard(void) { diff --git a/drivers/usb/host/ehci-exynos.c b/drivers/usb/host/ehci-exynos.c index 50fbf36..cba450e 100644 --- a/drivers/usb/host/ehci-exynos.c +++ b/drivers/usb/host/ehci-exynos.c @@ -170,6 +170,11 @@ static void reset_usb_phy(struct exynos_usb_phy *usb) set_usbhost_phy_ctrl(POWER_USB_HOST_PHY_CTRL_DISABLE); }
+inline void __board_usb_init(int value) +{ +} +void board_usb_init(int) __attribute__((weak, alias("__board_usb_init"))); + /* * EHCI-initialization * Create the appropriate control structures to manage @@ -189,8 +194,12 @@ int ehci_hcd_init(int index, struct ehci_hccr **hccr, struct ehci_hcor **hcor) ctx->hcd = (struct ehci_hccr *)samsung_get_base_usb_ehci(); #endif
+ board_usb_init(0); + setup_usb_phy(ctx->usb);
+ board_usb_init(1); + *hccr = ctx->hcd; *hcor = (struct ehci_hcor *)((uint32_t) *hccr + HC_LENGTH(ehci_readl(&(*hccr)->cr_capbase))); diff --git a/include/configs/arndale.h b/include/configs/arndale.h index ed44a04..ea24661 100644 --- a/include/configs/arndale.h +++ b/include/configs/arndale.h @@ -116,6 +116,10 @@ #define CONFIG_USB_EHCI_EXYNOS #define CONFIG_USB_STORAGE
+#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 3 +#define CONFIG_USB_HOST_ETHER +#define CONFIG_USB_ETHER_ASIX +#define CONFIG_PREBOOT "usb start" /* MMC SPL */ #define CONFIG_SPL #define COPY_BL2_FNPTR_ADDR 0x02020030 @@ -179,6 +183,8 @@ #define CONFIG_ENV_IS_IN_MMC #define CONFIG_SECURE_BL1_ONLY
+#define CONFIG_BOARD_LATE_INIT + /* Secure FW size configuration */ #ifdef CONFIG_SECURE_BL1_ONLY #define CONFIG_SEC_FW_SIZE (8 << 10) /* 8KB */
- struct exynos5_gpio_part1 *gpio = (struct exynos5_gpio_part1 *)
- /* Configure gpios for usb 3503 hub's reset and connect */
- s5p_gpio_direction_output(&gpio->x3, 5, value);
- s5p_gpio_direction_output(&gpio->d1, 7, value);
+} +#endif
- setenv("preboot", CONFIG_PREBOOT);
- setenv("usbethaddr", "00:40:5c:26:0a:5b");
Why do you need these 'setenv' calls ? This logic seems completely broken. The 'preboot' env variable is set already by defining the CONFIG_PREBOOT and the usbethaddr shall be set by user. [...]
Hi Marek,
Thanks for the review.
+} +#endif
Since arndale is a development board so this was done so that user (developer) does not has to set usbethaddr on every boot. If its redundant then I will remove this in the next version of the patchset.
Thanks, Inder
[...] _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de http://lists.denx.de/mailman/listinfo/u-boot
On Saturday, December 14, 2013 at 03:00:39 PM, Inderpal Singh wrote:
Hi Marek,
+} +#endif
} #endif
Can the user/developer/ ... just run:
=> setenv usbethaddr 00:11:22:33:44:fg => saveenv
on the U-Boot command line?
setenv("preboot", CONFIG_PREBOOT); is broken, the user might want to override this variable, yet you don't allow him to as you always reset it back to default value. If the board not loaded with a valid environment, a default env will be used and if CONFIG_PREBOOT is defined in your include/configs/<board>.h , then the 'preboot' variable will also be set to the default value so no need to set it like so explicitly. You can reset a variable using "env default -f preboot'.
Hi Marek,
ehci
+} +#endif
} #endif
and
redundant
Thanks a lot Marek for the explanation. Will remove this in the next patchset.
Thanks, Inder
Hi Marek,
ehci
+} +#endif
} #endif
and
redundant
Sure, HTH. Sorry I didn't review your patch, next time please at least add me to the CC or add 'usb:' tag to the patch.
Ping..
-- 1.7.9.5
Ping
On 19 November 2013 11:09, Chander Kashyap chander.kashyap@linaro.org wrote:
Ping..
-- 1.7.9.5
-- with warm regards, Chander Kashyap
Dear Marek Vasut,
please check this patchset. This patchset is delegated to you.
http://patchwork.ozlabs.org/patch/284845/ http://patchwork.ozlabs.org/patch/284839/
On 02/12/13 19:21, Chander Kashyap wrote:
Ping
Ping..
-- 1.7.9.5
Thanks, Minkyu Kang.
On Thursday, December 12, 2013 at 09:24:48 AM, Minkyu Kang wrote:
Dear Marek Vasut,
I did check them now. The patches didn't have 'usb:' tag on them nor was I on CC, so I missed them. Thanks for bringing them to my attention.
Best regards, Marek Vasut
participants (5)
Chander Kashyap
Inderpal Singh
Inderpal Singh
Minkyu Kang
