[U-Boot] [PATCH] xes: Use proper IO access functions
Also fix some minor whitespace oddities while we're cleaning up
Signed-off-by: Peter Tyser ptyser@xes-inc.com --- board/xes/common/fsl_8xxx_clk.c | 6 ++-- board/xes/common/fsl_8xxx_pci.c | 46 +++++++++++++++++----------------- board/xes/xpedite5200/xpedite5200.c | 17 ++++++------- board/xes/xpedite5370/xpedite5370.c | 8 +++--- 4 files changed, 38 insertions(+), 39 deletions(-)
diff --git a/board/xes/common/fsl_8xxx_clk.c b/board/xes/common/fsl_8xxx_clk.c index 0155670..f4a17b7 100644 --- a/board/xes/common/fsl_8xxx_clk.c +++ b/board/xes/common/fsl_8xxx_clk.c @@ -21,6 +21,7 @@ */
#include <common.h> +#include <asm/io.h>
/* * Return SYSCLK input frequency - 50 MHz or 66 MHz depending on POR config @@ -33,9 +34,8 @@ unsigned long get_board_sys_clk(ulong dummy) immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; volatile ccsr_gur_t *gur = &immap->im_gur; #endif - u32 gpporcr = gur->gpporcr;
- if (gpporcr & 0x10000) + if (in_be32(&gur->gpporcr) & 0x10000) return 66666666; else return 50000000; @@ -49,7 +49,7 @@ unsigned long get_board_sys_clk(ulong dummy) unsigned long get_board_ddr_clk(ulong dummy) { volatile ccsr_gur_t *gur = (void *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); - u32 ddr_ratio = ((gur->porpllsr) & 0x00003e00) >> 9; + u32 ddr_ratio = (in_be32(&gur->porpllsr) & 0x00003e00) >> 9;
if (ddr_ratio == 0x7) return get_board_sys_clk(dummy); diff --git a/board/xes/common/fsl_8xxx_pci.c b/board/xes/common/fsl_8xxx_pci.c index 025cc18..5b281f9 100644 --- a/board/xes/common/fsl_8xxx_pci.c +++ b/board/xes/common/fsl_8xxx_pci.c @@ -24,6 +24,7 @@ #include <common.h> #include <pci.h> #include <asm/fsl_pci.h> +#include <asm/io.h> #include <libfdt.h> #include <fdt_support.h>
@@ -182,18 +183,18 @@ void pci_init_board(void) immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; volatile ccsr_gur_t *gur = &immap->im_gur; #endif - uint devdisr = gur->devdisr; - uint io_sel = (gur->pordevsr & MPC8xxx_PORDEVSR_IO_SEL) >> + uint devdisr = in_be32(&gur->devdisr); + uint io_sel = (in_be32(&gur->pordevsr) & MPC8xxx_PORDEVSR_IO_SEL) >> MPC8xxx_PORDEVSR_IO_SEL_SHIFT; - uint host_agent = (gur->porbmsr & MPC8xxx_PORBMSR_HA) >> + uint host_agent = (in_be32(&gur->porbmsr) & MPC8xxx_PORBMSR_HA) >> MPC8xxx_PORBMSR_HA_SHIFT; struct pci_region *r;
#ifdef CONFIG_PCI1 - uint pci_spd_norm = (gur->pordevsr & MPC85xx_PORDEVSR_PCI1_SPD); - uint pci_32 = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_PCI32; - uint pci_arb = gur->pordevsr & MPC85xx_PORDEVSR_PCI1_ARB; - uint pcix = gur->pordevsr & MPC85xx_PORDEVSR_PCI1; + uint pci_spd_norm = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_SPD; + uint pci_32 = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_PCI32; + uint pci_arb = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1_ARB; + uint pcix = in_be32(&gur->pordevsr) & MPC85xx_PORDEVSR_PCI1; uint freq = CONFIG_SYS_CLK_FREQ / 1000 / 1000;
width = 0; /* Silence compiler warning... */ @@ -203,12 +204,11 @@ void pci_init_board(void) host = host_agent_cfg[host_agent].pci_host[0]; r = hose->regions;
- if (!(devdisr & MPC85xx_DEVDISR_PCI1)) { printf("\n PCI1: %d bit %s, %s %d MHz, %s, %s\n", pci_32 ? 32 : 64, pcix ? "PCIX" : "PCI", - pci_spd_norm ? ">=" : "<=", + pci_spd_norm ? ">=" : "<=", pcix ? freq * 2 : freq, host ? "host" : "agent", pci_arb ? "arbiter" : "external-arbiter"); @@ -250,7 +250,7 @@ void pci_init_board(void) } #elif defined CONFIG_MPC8548 /* PCI1 not present on MPC8572 */ - gur->devdisr |= MPC85xx_DEVDISR_PCI1; /* disable */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) | MPC85xx_DEVDISR_PCI1); #endif #ifdef CONFIG_PCIE1 pci = (ccsr_fsl_pci_t *) CONFIG_SYS_PCIE1_ADDR; @@ -262,10 +262,10 @@ void pci_init_board(void) if (width && !(devdisr & MPC8xxx_DEVDISR_PCIE1)) { printf("\n PCIE1 connected as %s (x%d)", host ? "Root Complex" : "End Point", width); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; + if (in_be32(&pci->pme_msg_det)) { + out_be32(&pci->pme_msg_det, 0xffffffff); debug(" with errors. Clearing. Now 0x%08x", - pci->pme_msg_det); + in_be32(&pci->pme_msg_det)); } printf("\n");
@@ -290,7 +290,7 @@ void pci_init_board(void)
hose->first_busno = first_free_busno; pci_setup_indirect(hose, (int)&pci->cfg_addr, - (int) &pci->cfg_data); + (int)&pci->cfg_data);
fsl_pci_init(hose);
@@ -303,7 +303,7 @@ void pci_init_board(void) hose->first_busno, hose->last_busno); } #else - gur->devdisr |= MPC8xxx_DEVDISR_PCIE1; /* disable */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) | MPC8xxx_DEVDISR_PCIE1); #endif /* CONFIG_PCIE1 */
#ifdef CONFIG_PCIE2 @@ -316,10 +316,10 @@ void pci_init_board(void) if (width && !(devdisr & MPC8xxx_DEVDISR_PCIE2)) { printf("\n PCIE2 connected as %s (x%d)", host ? "Root Complex" : "End Point", width); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; + if (in_be32(&pci->pme_msg_det)) { + out_be32(&pci->pme_msg_det, 0xffffffff); debug(" with errors. Clearing. Now 0x%08x", - pci->pme_msg_det); + in_be32(&pci->pme_msg_det)); } printf("\n");
@@ -357,7 +357,7 @@ void pci_init_board(void) hose->first_busno, hose->last_busno); } #else - gur->devdisr |= MPC8xxx_DEVDISR_PCIE2; /* disable */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) | MPC8xxx_DEVDISR_PCIE2); #endif /* CONFIG_PCIE2 */
#ifdef CONFIG_PCIE3 @@ -370,10 +370,10 @@ void pci_init_board(void) if (width && !(devdisr & MPC8xxx_DEVDISR_PCIE3)) { printf("\n PCIE3 connected as %s (x%d)", host ? "Root Complex" : "End Point", width); - if (pci->pme_msg_det) { - pci->pme_msg_det = 0xffffffff; + if (in_be32(&pci->pme_msg_det)) { + out_be32(&pci->pme_msg_det, 0xffffffff); debug(" with errors. Clearing. Now 0x%08x", - pci->pme_msg_det); + in_be32(&pci->pme_msg_det)); } printf("\n");
@@ -411,7 +411,7 @@ void pci_init_board(void) hose->first_busno, hose->last_busno); } #else - gur->devdisr |= MPC8xxx_DEVDISR_PCIE3; /* disable */ + out_be32(&gur->devdisr, in_be32(&gur->devdisr) | MPC8xxx_DEVDISR_PCIE3); #endif /* CONFIG_PCIE3 */ }
diff --git a/board/xes/xpedite5200/xpedite5200.c b/board/xes/xpedite5200/xpedite5200.c index 77afdbc..7109771 100644 --- a/board/xes/xpedite5200/xpedite5200.c +++ b/board/xes/xpedite5200/xpedite5200.c @@ -40,7 +40,6 @@ int checkboard(void) { volatile ccsr_lbc_t *lbc = (void *)(CONFIG_SYS_MPC85xx_LBC_ADDR); volatile ccsr_local_ecm_t *ecm = (void *)(CONFIG_SYS_MPC85xx_ECM_ADDR); - char *s;
printf("Board: X-ES %s PMC\n", CONFIG_SYS_BOARD_NAME); @@ -56,10 +55,10 @@ int checkboard(void) printf("Cfg %s", s); printf("\n");
- lbc->ltesr = 0xffffffff; /* Clear LBC error interrupts */ - lbc->lteir = 0xffffffff; /* Enable LBC error interrupts */ - ecm->eedr = 0xffffffff; /* Clear ecm errors */ - ecm->eeer = 0xffffffff; /* Enable ecm errors */ + out_be32(&lbc->ltesr, 0xffffffff); /* Clear LBC error IRQs */ + out_be32(&lbc->lteir, 0xffffffff); /* Enable LBC error IRQs */ + out_be32(&ecm->eedr, 0xffffffff); /* Clear ecm errors */ + out_be32(&ecm->eeer, 0xffffffff); /* Enable ecm errors */
return 0; } @@ -79,11 +78,11 @@ static void flash_cs_fixup(void) printf("FLASH: Executed from FLASH%d\n", flash_sel ? 2 : 1);
if (flash_sel) { - lbc->br0 = CONFIG_SYS_BR1_PRELIM; - lbc->or0 = CONFIG_SYS_OR1_PRELIM; + out_be32(&lbc->br0, CONFIG_SYS_BR1_PRELIM); + out_be32(&lbc->or0, CONFIG_SYS_OR1_PRELIM);
- lbc->br1 = CONFIG_SYS_BR0_PRELIM; - lbc->or1 = CONFIG_SYS_OR0_PRELIM; + out_be32(&lbc->br1, CONFIG_SYS_BR0_PRELIM); + out_be32(&lbc->or1, CONFIG_SYS_OR0_PRELIM); } }
diff --git a/board/xes/xpedite5370/xpedite5370.c b/board/xes/xpedite5370/xpedite5370.c index d54c699..48d9fc8 100644 --- a/board/xes/xpedite5370/xpedite5370.c +++ b/board/xes/xpedite5370/xpedite5370.c @@ -71,11 +71,11 @@ static void flash_cs_fixup(void) printf("FLASH: Executed from FLASH%d\n", flash_sel ? 2 : 1);
board/xes/common/fsl_8xxx_clk.c | 6 ++-- board/xes/common/fsl_8xxx_pci.c | 46 ++++++++++++++++ +----------------- board/xes/xpedite5200/xpedite5200.c | 17 ++++++------- board/xes/xpedite5370/xpedite5370.c | 8 +++--- 4 files changed, 38 insertions(+), 39 deletions(-)
Can I get you to respin thus on the 85xx next branch.
thanks
- k
Kumar Gala
Peter Tyser
