[PATCH 1/2] mx6sabresd: Fix U-Boot corruption after saving the environment
U-Boot binary has grown in such a way that it goes beyond the reserved area for the environment variables.
Running "saveenv" and rebooting the board causes U-Boot to hang because of this overlap.
Fix this problem by increasing the CONFIG_ENV_OFFSET.
Also, to prevent this same problem to happen in the future, use CONFIG_BOARD_SIZE_LIMIT, which can detect the overlap in build-time.
CONFIG_BOARD_SIZE_LIMIT is calculated as follows:
CONFIG_BOARD_SIZE_LIMIT = CONFIG_ENV_OFFSET - u-boot-img.dtb offset CONFIG_BOARD_SIZE_LIMIT = 0xd000 - 69 * 1024 CONFIG_BOARD_SIZE_LIMIT = 781312
Signed-off-by: Fabio Estevam festevam@denx.de --- configs/mx6sabresd_defconfig | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index a90efe4a7786..f19df607e7ae 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -9,7 +9,7 @@ CONFIG_SPL_LIBGENERIC_SUPPORT=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_SIZE=0x2000 -CONFIG_ENV_OFFSET=0xC0000 +CONFIG_ENV_OFFSET=0xd0000 CONFIG_MX6QDL=y CONFIG_TARGET_MX6SABRESD=y CONFIG_DM_GPIO=y @@ -24,6 +24,8 @@ CONFIG_PCI=y CONFIG_FIT=y CONFIG_SPL_FIT_PRINT=y CONFIG_SPL_LOAD_FIT=y +CONFIG_HAS_BOARD_SIZE_LIMIT=y +CONFIG_BOARD_SIZE_LIMIT=781312 CONFIG_SUPPORT_RAW_INITRD=y CONFIG_USE_BOOTCOMMAND=y CONFIG_BOOTCOMMAND="run findfdt;mmc dev ${mmcdev};if mmc rescan; then if run loadbootscript; then run bootscript; else if run loadimage; then run mmcboot; else run netboot; fi; fi; else run netboot; fi"
Commit 68dcbdd594d4 ("ARM: imx: Add weak default reset_cpu()") caused the 'reset' command in U-Boot to not cause a board reset.
Fix it by switching to the watchdog driver model via sysreset, which is the preferred method for implementing the watchdog reset.
Signed-off-by: Fabio Estevam festevam@denx.de --- arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi | 9 +++++++++ configs/mx6sabresd_defconfig | 3 +++ 2 files changed, 12 insertions(+)
diff --git a/arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi b/arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi index 5c4101b76da2..9e9c4422f00e 100644 --- a/arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi +++ b/arch/arm/dts/imx6qdl-sabresd-u-boot.dtsi @@ -9,6 +9,11 @@ aliases { mmc1 = &usdhc3; }; + wdt-reboot { + compatible = "wdt-reboot"; + wdt = <&wdog2>; + bootph-pre-ram; + }; };
&usdhc3 { @@ -18,3 +23,7 @@ &pinctrl_usdhc3 { bootph-pre-ram; }; + +&wdog2 { + bootph-pre-ram; +}; diff --git a/configs/mx6sabresd_defconfig b/configs/mx6sabresd_defconfig index f19df607e7ae..69685f12eb10 100644 --- a/configs/mx6sabresd_defconfig +++ b/configs/mx6sabresd_defconfig @@ -103,6 +103,8 @@ CONFIG_DM_REGULATOR_FIXED=y CONFIG_DM_REGULATOR_GPIO=y CONFIG_DM_SERIAL=y CONFIG_MXC_UART=y +CONFIG_SYSRESET=y +CONFIG_SYSRESET_WATCHDOG=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_MXC_SPI=y @@ -129,3 +131,4 @@ CONFIG_IMX_HDMI=y CONFIG_SPLASH_SCREEN=y CONFIG_SPLASH_SCREEN_ALIGN=y CONFIG_BMP_16BPP=y +CONFIG_IMX_WATCHDOG=y
I don't like when we have to move the environment like this, can we trim things down instead? Perhaps LTO?
Fabio Estevam
