[U-Boot] [PATCH V2 1/2] ofnode: Replace of_n_addr_cells with of_n_size_cells
The size should be decoded using of_n_size_cells(), make it so.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: New patch --- drivers/core/ofnode.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index a7e1927723..2e68f8e873 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -541,7 +541,7 @@ fdt_addr_t ofnode_get_addr_size(ofnode node, const char *property, if (!prop) return FDT_ADDR_T_NONE; na = of_n_addr_cells(np); - ns = of_n_addr_cells(np); + ns = of_n_size_cells(np); *sizep = of_read_number(prop + na, ns); return of_read_number(prop, na); } else {
Of CONFIG_OF_TRANSLATE is enabled, this function still returns untranslated bogus results. Add the missing translation.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Tom Rini trini@konsulko.com --- V2: - Use np directly - Drop extra of_n_addr_cells --- drivers/core/ofnode.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/drivers/core/ofnode.c b/drivers/core/ofnode.c index 2e68f8e873..f934116ab5 100644 --- a/drivers/core/ofnode.c +++ b/drivers/core/ofnode.c @@ -543,7 +543,11 @@ fdt_addr_t ofnode_get_addr_size(ofnode node, const char *property, na = of_n_addr_cells(np); ns = of_n_size_cells(np); *sizep = of_read_number(prop + na, ns); - return of_read_number(prop, na); + + if (IS_ENABLED(CONFIG_OF_TRANSLATE) && ns > 0) + return of_translate_address(np, prop); + else + return of_read_number(prop, na); } else { return fdtdec_get_addr_size(gd->fdt_blob, ofnode_to_offset(node), property,
Applied to u-boot-dm thanks!
V2: New patch
V2: New patch
sjg@google.com
