[U-Boot] [PATCH] sunxi: Enable fitImage support on OrangePi Zero
Enable modern fitImage format on OrangePi Zero.
Signed-off-by: Marek Vasut marex@denx.de Cc: Maxime Ripard maxime.ripard@bootlin.com Cc: Tom Rini trini@konsulko.com --- configs/orangepi_zero_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/orangepi_zero_defconfig b/configs/orangepi_zero_defconfig index 6afd4a3bfa..b3860659d6 100644 --- a/configs/orangepi_zero_defconfig +++ b/configs/orangepi_zero_defconfig @@ -9,6 +9,8 @@ CONFIG_DRAM_ODT_EN=y CONFIG_SPL_SPI_SUNXI=y CONFIG_DEFAULT_DEVICE_TREE="sun8i-h2-plus-orangepi-zero" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y CONFIG_CONSOLE_MUX=y # CONFIG_CMD_FLASH is not set CONFIG_SUN8I_EMAC=y
What's the point of enabling it on one board out of the ~120 we have?
You'd be better off selecting/implying it at the arch level.
Maxime
I'd better select/imply it everywhere :-) Let's see what Tom has to say about it.
We're already selecting it for a handful of platforms (all our arm64 ones, basically), so it's easy to expand.
Maxime
Submit a patch please ? :)
I'm not that interested in the FIT images in general, so I guess it would be done in a more timely manner if you did it :)
Maxime
Don't tell me you use zImage/uImage in production systems ? :-) btw done
On Thu, May 17, 2018 at 11:13:38PM +0200, Marek Vasut wrote: > Enable modern fitImage format on OrangePi Zero. > > Signed-off-by: Marek Vasut marex@denx.de > Cc: Maxime Ripard maxime.ripard@bootlin.com > Cc: Tom Rini trini@konsulko.com
Well, none of the distros are able to package FIT images, while zImage are the standard. Most of the features are actually pretty useful, but fit images are specific to one particular bootloader, which violates a bunch of abstraction layers in the process.
So, yeah, I'm using zImage because that's what everyone else supports and packages.
btw done
Thanks! Maxime
Maxime Ripard
