[PATCH -next] ARM: dts: k3-j7200-common-proc-board-u-boot.dtsi: Fix dtc warnings
Fix following dtc warning by explicitly setting up #size-cells and #address-cells when overriding node in -u-boot.dtsi
arch/arm/dts/k3-j7200-common-proc-board.dtb: Warning (reg_format): /bus@100000/bus@28380000/mcu-navss/ringacc@2b800000:reg: property has invalid length (80 bytes) (#address-cells == 2, #size-cells == 1)
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi index 41ce9fcb59..786cc48050 100644 --- a/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi +++ b/arch/arm/dts/k3-j7200-common-proc-board-u-boot.dtsi @@ -43,6 +43,8 @@
mcu-navss{ u-boot,dm-spl; + #address-cells = <2>; + #size-cells = <2>;
ringacc@2b800000 { reg = <0x0 0x2b800000 0x0 0x400000>,
+Tom
Tom, If you don't mind, can you pull the patch to next directly? This fixed the DT warning on j7200 builds.
Thanks and regards, Lokesh
#size-cells = <2>;
On Mon, Jun 21, 2021 at 05:42:15PM +0530, Lokesh Vutla wrote:
+Tom
OK, will do.
Lokesh Vutla
Vignesh Raghavendra
