[U-Boot-Users] [patch] rtl8139.c: use PCI IO map
Signed-off-by: Lucas Jin lucasjin@gmail.com
--- ./drivers/rtl8139.c.orig 2007-10-12 22:17:52.000000000 +0800 +++ ./drivers/rtl8139.c 2007-10-13 17:34:40.117515408 +0800 @@ -104,8 +104,8 @@ #undef DEBUG_RX
#define currticks() get_timer(0) -#define bus_to_phys(a) pci_mem_to_phys((pci_dev_t)dev->priv, a) -#define phys_to_bus(a) pci_phys_to_mem((pci_dev_t)dev->priv, a) +#define bus_to_phys(a) pci_io_to_phys((pci_dev_t)dev->priv, a) +#define phys_to_bus(a) pci_phys_to_io((pci_dev_t)dev->priv, a)
/* Symbolic offsets to registers. */ enum RTL8139_registers { @@ -213,7 +213,7 @@ if ((devno = pci_find_devices(supported, idx++)) < 0) break;
- pci_read_config_dword(devno, PCI_BASE_ADDRESS_1, &iobase); + pci_read_config_dword(devno, PCI_BASE_ADDRESS_0, &iobase); iobase &= ~0xf;
debug ("rtl8139: REALTEK RTL8139 @0x%x\n", iobase);
-------------- Lucas Jin
Could you please explain which problem this patch is supposed to fix?
The rtl8139 specification says the configuration registers can be accessed through PCI memory mapping or PCI IO mapping.
The u-boot driver uses PCI memory mapping, but it doesn't work, so I changed it to PCI IO mapping.
The driver of rtl8139 in Linux Kernel also uses PCI IO mapping to access the configuration registers.
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de Nearly everyone is in favor of going to heaven but too many are hoping they'll live long enough to see an easing of the entrance requirements. Never appeal to a man's "better nature." he might not have one.
------------------ Thanks Lucas Jin
On my target RTL8139 or its variant works fine without such a change. Why do you think doesn't work? Could you elaborate please?
Do you mean CONFIG_8139TOO_PIO?
thanks,
Shinya
When I used PCI memory mapping to access rtl8139 configuration registers, like MAC0-MAC05, the CPU paniced, as I described in the subject "a problem about rtl8139 driver on sandpoint8245board" I proposed Sep. 30th 2007.
After changing to PCI IO mapping, the problem was solved.
I don't what you mean by CONFIG_8139TOO_PIO, there is not such a define in U-Boot.
thanks,
Shinya
Dear Lucas,
I used RTL8139 driver on MPC8241 board. It works fine. The followings are defined in the configuration file.
/* PCI memory */ #define CFG_IBAT2L (0x80000000 | BATL_PP_10 | BATL_CACHEINHIBIT) #define CFG_IBAT2U (0x80000000 | BATU_BL_256M | BATU_VS | BATU_VP)
#define CFG_DBAT2L CFG_IBAT2L #define CFG_DBAT2U CFG_IBAT2U
/* PCI Stuff */ #define CONFIG_PCI #define CONFIG_PCI_PNP
#define CONFIG_NET_MULTI
#define CONFIG_RTL8139 /* for RTL8139 */ #define KSEG1ADDR(x) ({u32 _x=le32_to_cpu(*(u32 *)(x)); (&_x);}) #define _IO_BASE 0x00000000
The result of pci command are
# pci Scanning PCI devices on bus 0 BusDevFun VendorId DeviceId Device Class Sub-Class _____________________________________________________________ 00.00.00 0x1057 0x0006 Bridge device 0x00 00.0c.00 0x10ec 0x8139 Network controller 0x00 :
# pci header 00.0c.00 vendor ID = 0x10ec device ID = 0x8139 command register = 0x0007 status register = 0x0290 revision ID = 0x20 class code = 0x02 (Network controller) sub class code = 0x00 programming interface = 0x00 cache line = 0x08 latency time = 0x20 header type = 0x00 BIST = 0x00 base address 0 = 0x00000001 base address 1 = 0x80000000 base address 2 = 0x00000000 base address 3 = 0x00000000 base address 4 = 0x00000000 base address 5 = 0x00000000 cardBus CIS pointer = 0x00000000 sub system vendor ID = 0x11ec sub system ID = 0x8139 expansion ROM base address = 0x00000000 interrupt line = 0xff interrupt pin = 0x01 min Grant = 0x20 max Latency = 0x40
Masami Komiya
Masami Komiya Wrote:
Yes, you are right, I didn't configurated my board correctly.
Dear Lucas,
The former developer of my project changed the two defines above to
#define CFG_IBAT2L (0x78000000 | BATL_PP_10 | BATL_CACHEINHIBIT) #define CFG_IBAT2U (0x78000000 | BATU_BL_128K | BATU_VS | BATU_VP)
and I didn't realize that.
Masami Komiya
This SF.net email is sponsored by: Splunk Inc. Still grepping through log files to find problems? Stop. Now Search log events and configuration files using AJAX and a browser. Download your FREE copy of Splunk now >> http://get.splunk.com/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
Sounds more like a problem with PCI setup, than with the driver or the hardware.
-Scott
participants (5)
Lucas Jin
Masami Komiya
Scott Wood
Shinya Kuribayashi
