[U-Boot] [PATCH] tegra2: trivially enable 13 mhz crystal frequency
This is needed for upcoming Toradex Colibri T20 upstream support.
Signed-off-by: Lucas Stach dev@lynxeye.de --- arch/arm/cpu/armv7/tegra2/clock.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/arch/arm/cpu/armv7/tegra2/clock.c b/arch/arm/cpu/armv7/tegra2/clock.c index 39376ab..8084631 100644 --- a/arch/arm/cpu/armv7/tegra2/clock.c +++ b/arch/arm/cpu/armv7/tegra2/clock.c @@ -1027,7 +1027,10 @@ void clock_early_init(void) clock_set_rate(CLOCK_ID_CGENERAL, 600, 26, 0, 8); break;
- case CLOCK_OSC_FREQ_13_0: + case CLOCK_OSC_FREQ_13_0: /* OSC is 13Mhz */ + clock_set_rate(CLOCK_ID_PERIPH, 432, 13, 1, 8); + clock_set_rate(CLOCK_ID_CGENERAL, 600, 13, 0, 8); + break; case CLOCK_OSC_FREQ_19_2: default: /*
You probably want to CC the Tegra maintainer, so he notices this patch. I've done so here.
Dear Lucas Stach,
Neat, you're doing support for this board? That'd be great to have :) Keep me in CC, I have one and I'd be glad to review patches. (I hope you noticed the work of antmicro on the tegra/u-boot)
- case CLOCK_OSC_FREQ_13_0: /* OSC is 13Mhz */
case CLOCK_OSC_FREQ_19_2: default: /*break;
Best regards, Marek Vasut
Lucas Stach
Stephen Warren
