[U-Boot] Pull request: u-boot-rockchip/tags/rockchip-for-v2019.07-rc5
Hi Tom,
Please pull some rockchip updates: - new board: rk3328 rock64 - rk3328 SPL support - rk3399 spl/tpl board init cleanup - use environment to get ATF binary for rk3399 - build u-boot.itb target by default for rockchip - rk3399 board init fix after pinctrl patch set merged
Travis: https://travis-ci.org/keveryang/u-boot/builds/550800325
The following changes since commit 5eea874b5e989e62519824ad140aa086432d01ee:
Merge https://gitlab.denx.de/u-boot/custodians/u-boot-x86 (2019-06-22 12:09:33 -0400)
git@gitlab.denx.de:u-boot/custodians/u-boot-rockchip.git tags/rockchip-for-v2019.07-rc5
for you to fetch changes up to 7c7ce3600ae97b08f281a6b61aa4abb0b56b0658:
rockchip: rk3399: Fix enabling boot-on regulators (2019-06-26 21:11:29 +0800)
---------------------------------------------------------------- Jagan Teki (14): Makefile: clean image.map Makefile: clean bl31_*.bin travis.yml: Add pyelftools install entry rockchip: rk3399: Get bl31.elf via BL31 board: puma: Get bl31.bin via BL31 and rk3399m0.bin via PMUM0 Kconfig: Add u-boot.itb BUILD_TARGET for Rockchip board: rk3399: Drop explicit uart enablement in spl_board_init rockchip: rk3399: Support common spl_board_init rockchip: rk3399: spl: Mark printascii into debug rockchip: rk3399: Move u-boot, dm-pre-reloc of uart0, uart2 rockchip: rk3399: Enable SPL_BOARD_INIT rockchip: rk3399: tpl: Add spl_board_init rockchip: rk3399: tpl: Mark printascii into debug rockchip: rk3399: Enable TPL_BOARD_INIT
Kever Yang (3): rockchip: rk3328: add SPL board file support rockchip: rk3328: add SPL support rockchip: Kconfig: enable SPL support for rk3328
Mark Kettenis (1): rockchip: rk3399: Fix enabling boot-on regulators
Matwey V. Kornilov (3): rockchip: dts: rk3328: add rk3328-rock64.dts rockchip: rk3328: add rock64-rk3328_defconfig doc: rockchip: Add note for Pine64 Rock64 board
.travis.yml | 1 + Kconfig | 2 +- Makefile | 3 +- arch/arm/dts/Makefile | 3 +- arch/arm/dts/rk3328-rock64-u-boot.dtsi | 34 +++ arch/arm/dts/rk3328-rock64.dts | 294 +++++++++++++++++++++ arch/arm/dts/rk3399-gru.dtsi | 1 - arch/arm/dts/rk3399-puma.dtsi | 1 - arch/arm/dts/rk3399-u-boot.dtsi | 8 + arch/arm/mach-rockchip/Kconfig | 9 + arch/arm/mach-rockchip/Makefile | 1 + arch/arm/mach-rockchip/make_fit_atf.py | 19 +- arch/arm/mach-rockchip/rk3328-board-spl.c | 59 +++++ arch/arm/mach-rockchip/rk3399-board-spl.c | 65 ++++- arch/arm/mach-rockchip/rk3399-board-tpl.c | 9 +- board/rockchip/evb_rk3328/MAINTAINERS | 6 + board/rockchip/evb_rk3399/evb-rk3399.c | 61 +---- board/theobroma-systems/puma_rk3399/README | 2 +- .../theobroma-systems/puma_rk3399/fit_spl_atf.its | 58 ---- board/theobroma-systems/puma_rk3399/fit_spl_atf.sh | 94 +++++++ board/theobroma-systems/puma_rk3399/puma-rk3399.c | 58 ---- board/vamrs/rock960_rk3399/README | 1 - board/vamrs/rock960_rk3399/rock960-rk3399.c | 31 --- configs/evb-rk3328_defconfig | 7 + configs/puma-rk3399_defconfig | 3 +- configs/rock64-rk3328_defconfig | 91 +++++++ doc/README.rockchip | 44 ++- include/configs/rk3328_common.h | 4 + 28 files changed, 739 insertions(+), 230 deletions(-) create mode 100644 arch/arm/dts/rk3328-rock64-u-boot.dtsi create mode 100644 arch/arm/dts/rk3328-rock64.dts create mode 100644 arch/arm/mach-rockchip/rk3328-board-spl.c delete mode 100644 board/theobroma-systems/puma_rk3399/fit_spl_atf.its create mode 100755 board/theobroma-systems/puma_rk3399/fit_spl_atf.sh create mode 100644 configs/rock64-rk3328_defconfig
On Thu, Jun 27, 2019 at 08:46:39AM +0800, Kever Yang wrote:
Hi Tom,
Use the https URI in request-pull, btw.
That said, are we still looking at replacing make_fit_atf.py with binman? Thanks again!
Kever Yang
