[U-Boot] [PATCH V3 1/1] arm: at91: reworked meesc board support
Signed-off-by: Daniel Gorsulowski daniel.gorsulowski@esd.eu --- Changes in V2: - Fetched again and created patch against current master
Changes in V3: - None, just resent using 'git send-email'
board/esd/meesc/meesc.c | 20 ++++++++++++++++---- include/configs/meesc.h | 42 ++++++++++++++++++++---------------------- 2 files changed, 36 insertions(+), 26 deletions(-)
diff --git a/board/esd/meesc/meesc.c b/board/esd/meesc/meesc.c index c5994e0..b7f9f90 100644 --- a/board/esd/meesc/meesc.c +++ b/board/esd/meesc/meesc.c @@ -3,7 +3,7 @@ * Stelian Pop stelian@popies.net * Lead Tech Design <www.leadtechdesign.com> * - * (C) Copyright 2009-2011 + * (C) Copyright 2009-2015 * Daniel Gorsulowski daniel.gorsulowski@esd.eu * esd electronic system design gmbh <www.esd.eu> * @@ -28,6 +28,7 @@ DECLARE_GLOBAL_DATA_PTR; * Miscelaneous platform dependent initialisations */
+#ifdef CONFIG_REVISION_TAG static int hw_rev = -1; /* hardware revision */
int get_hw_rev(void) @@ -45,6 +46,7 @@ int get_hw_rev(void)
return hw_rev; } +#endif /* CONFIG_REVISION_TAG */
#ifdef CONFIG_CMD_NAND static void meesc_nand_hw_init(void) @@ -125,12 +127,18 @@ static void meesc_ethercat_hw_init(void)
int dram_init(void) { - gd->ram_size = get_ram_size( - (void *)CONFIG_SYS_SDRAM_BASE, - CONFIG_SYS_SDRAM_SIZE); + /* dram_init must store complete ramsize in gd->ram_size */ + gd->ram_size = get_ram_size((void *)PHYS_SDRAM, + PHYS_SDRAM_SIZE); return 0; }
+void dram_init_banksize(void) +{ + gd->bd->bi_dram[0].start = PHYS_SDRAM; + gd->bd->bi_dram[0].size = PHYS_SDRAM_SIZE; +} + int board_eth_init(bd_t *bis) { int rc = 0; @@ -140,6 +148,7 @@ int board_eth_init(bd_t *bis) return rc; }
+#ifdef CONFIG_DISPLAY_BOARDINFO int checkboard(void) { char str[32]; @@ -173,10 +182,13 @@ int checkboard(void) puts(", serial# "); puts(str); } +#ifdef CONFIG_REVISION_TAG printf("\nHardware-revision: 1.%d\n", get_hw_rev()); +#endif printf("Mach-type: %lu\n", gd->bd->bi_arch_number); return 0; } +#endif /* CONFIG_DISPLAY_BOARDINFO */
#ifdef CONFIG_SERIAL_TAG void get_board_serial(struct tag_serialnr *serialnr) diff --git a/include/configs/meesc.h b/include/configs/meesc.h index 9c53fb4..10a6ce9 100644 --- a/include/configs/meesc.h +++ b/include/configs/meesc.h @@ -3,7 +3,7 @@ * Stelian Pop stelian@popies.net * Lead Tech Design <www.leadtechdesign.com> * - * (C) Copyright 2009-2011 + * (C) Copyright 2009-2015 * Daniel Gorsulowski daniel.gorsulowski@esd.eu * esd electronic system design gmbh <www.esd.eu> * @@ -27,7 +27,7 @@ * Since the linker has to swallow that define, we must use a pure * hex number here! */ -#define CONFIG_SYS_TEXT_BASE 0x20002000 +#define CONFIG_SYS_TEXT_BASE 0x21F00000
/* * since a number of boards are not being listed in linux @@ -56,14 +56,13 @@ #define CONFIG_DISPLAY_CPUINFO /* display cpu info and speed */ #define CONFIG_PREBOOT /* enable preboot variable */
+#define CONFIG_CMD_BOOTZ +#define CONFIG_OF_LIBFDT
/* * Hardware drivers */
-/* required until arch/arm/include/asm/arch-at91/at91sam9263.h is reworked */ -#define ATMEL_PMC_UHP AT91SAM926x_PMC_UHP - /* general purpose I/O */ #define CONFIG_AT91_GPIO
@@ -87,10 +86,17 @@ /* * Command line configuration. */ +#undef CONFIG_CMD_BDI +#undef CONFIG_CMD_FPGA +#undef CONFIG_CMD_LOADS +#undef CONFIG_CMD_IMLS + #define CONFIG_CMD_PING #define CONFIG_CMD_DHCP + +#ifdef CONFIG_SYS_USE_NANDFLASH #define CONFIG_CMD_NAND -#define CONFIG_CMD_USB +#endif
/* LED */ #define CONFIG_AT91_LED @@ -99,9 +105,12 @@ * SDRAM: 1 bank, min 32, max 128 MB * Initialized before u-boot gets started. */ +#define PHYS_SDRAM ATMEL_BASE_CS1 /* 0x20000000 */ +#define PHYS_SDRAM_SIZE 0x02000000 /* 32 MByte */ + #define CONFIG_NR_DRAM_BANKS 1 -#define CONFIG_SYS_SDRAM_BASE 0x20000000 /* ATMEL_BASE_CS1 */ -#define CONFIG_SYS_SDRAM_SIZE 0x02000000 +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_SDRAM_SIZE PHYS_SDRAM_SIZE
#define CONFIG_SYS_MEMTEST_START (CONFIG_SYS_SDRAM_BASE + 0x00100000) #define CONFIG_SYS_MEMTEST_END (CONFIG_SYS_SDRAM_BASE + 0x01E00000) @@ -133,7 +142,7 @@ #ifdef CONFIG_CMD_NAND # define CONFIG_NAND_ATMEL # define CONFIG_SYS_MAX_NAND_DEVICE 1 -# define CONFIG_SYS_NAND_BASE 0x40000000 /* ATMEL_BASE_CS3 */ +# define CONFIG_SYS_NAND_BASE ATMEL_BASE_CS3 /* 0x40000000 */ # define CONFIG_SYS_NAND_DBW_8 # define CONFIG_SYS_NAND_MASK_ALE (1 << 21) # define CONFIG_SYS_NAND_MASK_CLE (1 << 22) @@ -148,19 +157,6 @@ #define CONFIG_NET_RETRY_COUNT 20 #undef CONFIG_RESET_PHY_R
-/* USB */ -#define CONFIG_USB_ATMEL -#define CONFIG_USB_ATMEL_CLK_SEL_PLLB -#define CONFIG_USB_OHCI_NEW -#define CONFIG_DOS_PARTITION -#define CONFIG_SYS_USB_OHCI_CPU_INIT -#define CONFIG_SYS_USB_OHCI_REGS_BASE 0x00a00000 -#define CONFIG_SYS_USB_OHCI_SLOT_NAME "at91sam9263" -#define CONFIG_SYS_USB_OHCI_MAX_ROOT_PORTS 2 - -/* CAN */ -#define CONFIG_AT91_CAN - /* hw-controller addresses */ #define CONFIG_ET1100_BASE 0x70000000
@@ -190,6 +186,8 @@ sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_HUSH_PARSER
/* * Size of malloc() pool
Dear Daniel Gorsulowski,
Daniel Gorsulowski Daniel.Gorsulowski@esd.eu writes:
Changes in V2:
Changes in V3:
applied to u-boot-atmel/master, thanks!
Best regards, Andreas Bießmann
Andreas Bießmann
Daniel Gorsulowski
