[U-Boot] [PULL] u-boot-usb/master
The following changes since commit 26722335253a9fa384ceb423419254cb00d0def1:
rockchip: puma-rk3399: remove duplicate code (merge artifact) (2017-07-27 14:59:04 +0200)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to b108d8a0de3ddc6fe8aae55bc54e3edc69b4778b:
clk: fix compilation errors for poplar platform (2017-07-28 23:34:46 +0200)
---------------------------------------------------------------- Bin Meng (33): usb: xhci: Remove incorrect comments for struct xhci_container_ctx usb: xhci: Correct command TRB 4th dword initialization usb: xhci: Initialize scratchpad buffer array and scratchpad buffers usb: xhci: Add input slot context in xhci_set_configuration() usb: hub: Update handling connect status/change in usb_scan_port() usb: hub: Send correct wValue to get hub descriptor of a USB 3.0 hub usb: hub: Revise wLength for 'get port status' request usb: hub: Change USB hub descriptor to match USB 3.0 hubs usb: hub: Add 3.0 hub port status mask of 2.0 hub usb: xhci: Change MAX_HC_PORTS to 255
usb: xhci: Get rid of CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS
configs: Remove CONFIG_SYS_USB_XHCI_MAX_ROOT_PORTS in all boards
usb: ehci: Get rid of CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS
configs: Remove CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS in all boards
usb: cmd: Print actual packet size for super speed devices
usb: xhci: Convert CONFIG_USB_XHCI_PCI to Kconfig x86: minnowmax: Add a environment variable for USB power-on delay x86: minnowmax: Enable USB xHCI support usb: xhci-pci: Drop non-DM version of xhci-pci driver usb: xhci-pci: Clean up the driver a little bit usb: hub: Use 'struct usb_hub_device' as hub device's uclass_priv usb: hub: Remove hub_port_reset() usb: hub: Add a new API to test if a hub device is root hub usb: hub: Translate USB 3.0 hub port status into old version usb: hub: Support 'set hub depth' request for USB 3.0 hubs usb: xhci: Change xhci_setup_addressable_virt_dev() signature usb: xhci: Program 'route string' in the input slot context usb: hub: Parse and save TT details from device descriptor dm: usb: Add a new USB controller operation 'update_hub_device' usb: hub: Call usb_update_hub_device() after hub descriptor is fetched usb: xhci: Implement update_hub_device() operation usb: xhci: Correct TT_SLOT and TT_PORT macros usb: xhci: Enable TT to support LS/FS devices behind a HS hub
Jean-Jacques Hiblot (1): phy: add a NO-OP phy driver
Masahiro Yamada (1): usb: add static to local symbols
Patrice Chotard (21): usb: host: xhci-dwc3: Convert driver to DM usb: host: xhci-dwc3: Add dual role mode support from DT drivers: phy: Set phy->dev to NULL when generic_phy_get_by_index() fails drivers: phy: add generic_phy_valid() method usb: host: xhci-dwc3: Add generic PHY support reset: add reset_request() reset: add reset_release_all() clk: add clk_release_all() dm: core: add ofnode_count_phandle_with_args() usb: host: ehci-generic: replace printf() by error() usb: host: ehci-generic: add error path and .remove callback usb: host: ehci-generic: add generic PHY support usb: host: ohci-generic: add CLOCK support usb: host: ohci-generic: add RESET support usb: host: ohci-generic: add generic PHY support dm: phy: add missing #ifdef CONFIG_PHY dm: usb: host: xhci-dwc3: add missing #ifdef CONFIG_DM_USB usb: host: ehci-generic: initialize PHY only when found usb: host: ohci-generic: initialize PHY only when found usb: host: xhci-dxc3: fix compilation warnings clk: fix compilation errors for poplar platform
Patrick Delaunay (4): dfu: allow dfu read on partition greater than 2GB dfu: remove limitation on partition size dfu: factorize transaction cleanup dfu: add common function to initiate transaction
Siva Durga Prasad Paladugu (1): usb: gadget: f_thor: Free the allocated out request buffer
Documentation/devicetree/bindings/phy/no-op.txt | 16 ++++++ arch/arm/include/asm/ehci-omap.h | 4 -- arch/x86/dts/minnowmax.dts | 3 ++ cmd/usb.c | 7 ++- common/usb_hub.c | 249 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++----------- configs/minnowmax_defconfig | 1 + drivers/clk/clk-uclass.c | 27 ++++++++++ drivers/core/of_access.c | 7 +++ drivers/core/ofnode.c | 12 +++++ drivers/dfu/dfu.c | 100 ++++++++++++++++------------------- drivers/dfu/dfu_mmc.c | 20 +++---- drivers/dfu/dfu_nand.c | 6 ++- drivers/dfu/dfu_ram.c | 6 ++- drivers/dfu/dfu_sf.c | 6 ++- drivers/phy/Kconfig | 18 +++++++ drivers/phy/Makefile | 1 + drivers/phy/nop-phy.c | 26 ++++++++++ drivers/phy/phy-uclass.c | 1 + drivers/reset/reset-uclass.c | 34 ++++++++++++ drivers/usb/emul/sandbox_hub.c | 7 ++- drivers/usb/gadget/f_thor.c | 1 + drivers/usb/host/Kconfig | 7 +++ drivers/usb/host/ehci-generic.c | 148 +++++++++++++++++++++++++++++++++++++++++++--------- drivers/usb/host/ehci-hcd.c | 16 +++--- drivers/usb/host/ehci.h | 7 ++- drivers/usb/host/ohci-generic.c | 123 ++++++++++++++++++++++++++++++++++++++++++- drivers/usb/host/usb-uclass.c | 31 +++++++---- drivers/usb/host/xhci-dwc3.c | 91 +++++++++++++++++++++++++++++++- drivers/usb/host/xhci-mem.c | 139 +++++++++++++++++++++++++++++++++++++++++++++++-- drivers/usb/host/xhci-pci.c | 73 +------------------------- drivers/usb/host/xhci-ring.c | 11 +++- drivers/usb/host/xhci.c | 107 ++++++++++++++++++++++++++------------ drivers/usb/host/xhci.h | 31 ++++++----- include/clk.h | 21 ++++++++ include/configs/MPC8572DS.h | 1 - include/configs/am43xx_evm.h | 1 - include/configs/am57xx_evm.h | 1 - include/configs/cl-som-am57x.h | 1 - include/configs/cm_t43.h | 1 - include/configs/cm_t54.h | 1 - include/configs/corvus.h | 3 -- include/configs/dra7xx_evm.h | 1 - include/configs/ds414.h | 1 - include/configs/duovero.h | 2 - include/configs/exynos5-common.h | 3 -- include/configs/ls1012afrdm.h | 1 - include/configs/ls1012aqds.h | 1 - include/configs/ls1012ardb.h | 1 - include/configs/ls1021aiot.h | 1 - include/configs/ls1021aqds.h | 1 - include/configs/ls1021atwr.h | 1 - include/configs/ls1043aqds.h | 1 - include/configs/ls1043ardb.h | 1 - include/configs/ls1046aqds.h | 1 - include/configs/ls1046ardb.h | 1 - include/configs/ls2080aqds.h | 1 - include/configs/ls2080ardb.h | 1 - include/configs/ma5d4evk.h | 1 - include/configs/mcx.h | 1 - include/configs/minnowmax.h | 3 +- include/configs/mvebu_armada-37xx.h | 9 +--- include/configs/mvebu_armada-8k.h | 9 +--- include/configs/mx35pdk.h | 1 - include/configs/odroid.h | 1 - include/configs/omap3_beagle.h | 1 - include/configs/omap3_overo.h | 1 - include/configs/omap4_panda.h | 2 - include/configs/omap5_uevm.h | 1 - include/configs/picosam9g45.h | 3 -- include/configs/poplar.h | 1 - include/configs/rk3328_common.h | 2 - include/configs/rk3399_common.h | 3 -- include/configs/sama5d2_ptc.h | 4 -- include/configs/snapper9g45.h | 3 -- include/configs/sunxi-common.h | 1 - include/configs/tam3517-common.h | 1 - include/configs/tao3530.h | 1 - include/configs/tegra114-common.h | 1 - include/configs/tegra124-common.h | 1 - include/configs/tegra20-common.h | 1 - include/configs/tegra210-common.h | 1 - include/configs/tegra30-common.h | 1 - include/configs/ti_armv7_keystone2.h | 1 - include/configs/uniphier.h | 3 -- include/configs/vinco.h | 6 --- include/configs/x86-common.h | 1 - include/configs/xilinx_zynqmp.h | 2 - include/dfu.h | 4 +- include/dm/of_access.h | 18 +++++++ include/dm/ofnode.h | 17 ++++++ include/dm/read.h | 25 +++++++++ include/generic-phy.h | 53 +++++++++++++++++++ include/reset.h | 27 ++++++++++ include/usb.h | 82 ++++++++++++++++++++--------- include/usb_defs.h | 23 ++++++++- scripts/config_whitelist.txt | 3 -- 96 files changed, 1305 insertions(+), 399 deletions(-) create mode 100644 Documentation/devicetree/bindings/phy/no-op.txt create mode 100644 drivers/phy/nop-phy.c
