[U-Boot] [PATCH] configs: Remove am43xx_evm_ethboot_defconfig
am43xx_evm_ethboot_defconfig is not being actively used and has not been moved to DM or DT. Also, ethboot cannot be tested on AM43xx EVM as such due EVM limitations. Therefore delete it.
Signed-off-by: Vignesh R vigneshr@ti.com --- board/ti/am43xx/MAINTAINERS | 1 - configs/am43xx_evm_ethboot_defconfig | 64 ---------------------------- 2 files changed, 65 deletions(-) delete mode 100644 configs/am43xx_evm_ethboot_defconfig
diff --git a/board/ti/am43xx/MAINTAINERS b/board/ti/am43xx/MAINTAINERS index bf098064bdaf..ab9da22c6427 100644 --- a/board/ti/am43xx/MAINTAINERS +++ b/board/ti/am43xx/MAINTAINERS @@ -4,7 +4,6 @@ S: Maintained F: board/ti/am43xx/ F: include/configs/am43xx_evm.h F: configs/am43xx_evm_defconfig -F: configs/am43xx_evm_ethboot_defconfig F: configs/am43xx_evm_qspiboot_defconfig F: configs/am43xx_evm_usbhost_boot_defconfig F: configs/am43xx_evm_rtconly_defconfig diff --git a/configs/am43xx_evm_ethboot_defconfig b/configs/am43xx_evm_ethboot_defconfig deleted file mode 100644 index c1b32be1907c..000000000000 --- a/configs/am43xx_evm_ethboot_defconfig +++ /dev/null @@ -1,64 +0,0 @@ -CONFIG_ARM=y -CONFIG_ARCH_OMAP2PLUS=y -CONFIG_AM43XX=y -CONFIG_SPL=y -CONFIG_DISTRO_DEFAULTS=y -CONFIG_SYS_EXTRA_OPTIONS="CONS_INDEX=1" -# CONFIG_USE_BOOTCOMMAND is not set -CONFIG_SYS_CONSOLE_INFO_QUIET=y -# CONFIG_MISC_INIT_R is not set -CONFIG_VERSION_VARIABLE=y -# CONFIG_SPL_SYS_MALLOC_SIMPLE is not set -CONFIG_SPL_ETH_SUPPORT=y -CONFIG_SPL_MTD_SUPPORT=y -CONFIG_SPL_NET_SUPPORT=y -CONFIG_SPL_NET_VCI_STRING="AM43xx U-Boot SPL" -CONFIG_SPL_OS_BOOT=y -CONFIG_CMD_SPL=y -CONFIG_CMD_SPL_NAND_OFS=0x00100000 -CONFIG_CMD_SPL_WRITE_SIZE=0x40000 -CONFIG_CMD_ASKENV=y -CONFIG_CMD_EEPROM=y -CONFIG_CMD_DFU=y -# CONFIG_CMD_FLASH is not set -CONFIG_CMD_GPIO=y -CONFIG_CMD_GPT=y -CONFIG_CMD_I2C=y -CONFIG_CMD_MMC=y -CONFIG_CMD_NAND=y -CONFIG_CMD_SF=y -CONFIG_CMD_SPI=y -CONFIG_CMD_USB=y -# CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_EXT4_WRITE=y -CONFIG_CMD_MTDPARTS=y -CONFIG_MTDIDS_DEFAULT="nand0=nand.0" -CONFIG_MTDPARTS_DEFAULT="mtdparts=nand.0:256k(NAND.SPL),256k(NAND.SPL.backup1),256k(NAND.SPL.backup2),256k(NAND.SPL.backup3),512k(NAND.u-boot-spl-os),1m(NAND.u-boot),256k(NAND.u-boot-env),256k(NAND.u-boot-env.backup1),7m(NAND.kernel),-(NAND.file-system)" -CONFIG_ENV_IS_IN_FAT=y -CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y -CONFIG_DFU_MMC=y -CONFIG_DFU_RAM=y -CONFIG_DFU_SF=y -CONFIG_MMC_OMAP_HS=y -CONFIG_NAND=y -CONFIG_SPI_FLASH=y -CONFIG_SPI_FLASH_MACRONIX=y -CONFIG_MII=y -CONFIG_DRIVER_TI_CPSW=y -CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_TI_QSPI=y -CONFIG_USB=y -CONFIG_USB_XHCI_HCD=y -CONFIG_USB_XHCI_DWC3=y -CONFIG_USB_DWC3=y -CONFIG_USB_DWC3_GADGET=y -CONFIG_USB_DWC3_OMAP=y -CONFIG_USB_DWC3_PHY_OMAP=y -CONFIG_OMAP_USB_PHY=y -CONFIG_USB_GADGET=y -CONFIG_USB_GADGET_MANUFACTURER="Texas Instruments" -CONFIG_USB_GADGET_VENDOR_NUM=0x0403 -CONFIG_USB_GADGET_PRODUCT_NUM=0xbd00 -CONFIG_USB_GADGET_DOWNLOAD=y -CONFIG_OF_LIBFDT=y
Signed-off-by: Vignesh R vigneshr@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Vignesh R
