[U-Boot] [PATCH 0/8] Blackfin fixes for 2009.05
Add some corner case fixes for some Blackfin peripheral drivers, and add some fixes for anomalies and auditing of others. One or two of the audits aren't strictly fixes (just adding /*...*/ comments(, but it makes my life easier to keep them together.
Graf Yang (1): Blackfin: nand: flush peripheral before polling it
Mike Frysinger (6): Blackfin: update anomaly sheets Blackfin: add workaround for anomaly 05000171 Blackfin: add workaround for anomaly 05000242 Blackfin: add comment about anomaly 05000430 avoidance Blackfin: add check for anomaly 05000362 Blackfin: audit UART for all known anomalies
Todor I Mollov (1): Blackfin: spi: make cs deassert function deterministic
cpu/blackfin/initcode.c | 17 ++++++- cpu/blackfin/serial.c | 21 ++++++++- cpu/blackfin/serial.h | 2 +- drivers/mtd/nand/bfin_nand.c | 1 + drivers/spi/bfin_spi.c | 16 ++++++- include/asm-blackfin/mach-bf527/anomaly.h | 40 ++++++++++++--- include/asm-blackfin/mach-bf533/anomaly.h | 77 +++++++++++++++++++++++----- include/asm-blackfin/mach-bf537/anomaly.h | 67 +++++++++++++------------ include/asm-blackfin/mach-bf548/anomaly.h | 18 ++++--- include/asm-blackfin/mach-bf561/anomaly.h | 17 +++--- 10 files changed, 203 insertions(+), 73 deletions(-)
Blackfin SPI driver was not driving the SPI chip-select high before putting the chip-select signals into tri-state mode. This is probably something that slipped by unnoticed in most designs. If the signals are put directly into a tri-state mode, then the board is relying on the pull-up resistors to pull up the chip-select before the next transaction. Most of the time this is fine, except when you have two transactions that follow each other very closely, such as the flash erase and read status register commands. In this case I was seeing a 500ns separation between the transactions. In my setup, with a 10kOhm pull-up, it would meet timing spec about half the time and resulted in intermittent errors. (A stronger pull up would fix this, but our design is targeted for low power consumption and a 3.3kOhm @ 3.3v is 3.3mW of needless power consumption.) I modified the spi_cs_deactivate() function in bfin_spi.c to drive the chip-selects high before putting them into tri-state. For me, this resulted in a rise time of 5ns instead of the previous rise time of about 1us, and fully satisfied the timing spec of the chip.
Signed-off-by: Todor I Mollov tmollov@ucsd.edu Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/spi/bfin_spi.c | 16 +++++++++++++++- 1 files changed, 15 insertions(+), 1 deletions(-)
diff --git a/drivers/spi/bfin_spi.c b/drivers/spi/bfin_spi.c index bc3394a..bc255cc 100644 --- a/drivers/spi/bfin_spi.c +++ b/drivers/spi/bfin_spi.c @@ -52,6 +52,7 @@ void spi_cs_activate(struct spi_slave *slave) (read_SPI_FLG(bss) & ~((!bss->flg << 8) << slave->cs)) | (1 << slave->cs)); + SSYNC(); debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); }
@@ -59,7 +60,20 @@ __attribute__((weak)) void spi_cs_deactivate(struct spi_slave *slave) { struct bfin_spi_slave *bss = to_bfin_spi_slave(slave); - write_SPI_FLG(bss, read_SPI_FLG(bss) & ~(1 << slave->cs)); + u16 flg; + + /* make sure we force the cs to deassert rather than let the + * pin float back up. otherwise, exact timings may not be + * met some of the time leading to random behavior (ugh). + */ + flg = read_SPI_FLG(bss) | ((!bss->flg << 8) << slave->cs); + write_SPI_FLG(bss, flg); + SSYNC(); + debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); + + flg &= ~(1 << slave->cs); + write_SPI_FLG(bss, flg); + SSYNC(); debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss)); }
Dear Mike Frysinger,
In message 1239004434-13962-2-git-send-email-vapier@gentoo.org you wrote: ...
- SSYNC();
Should this sync not be integral part of the write_SPI_FLG() accessor?
- flg = read_SPI_FLG(bss) | ((!bss->flg << 8) << slave->cs);
- write_SPI_FLG(bss, flg);
- SSYNC();
Ditto here.
- debug("%s: SPI_FLG:%x\n", __func__, read_SPI_FLG(bss));
- flg &= ~(1 << slave->cs);
- SSYNC();
And here.
We need to make sure the data written to the nand flash controller makes it there before we start polling its status register. Otherwise, we may get stale data and return before the controller is actually ready.
Signed-off-by: Graf Yang graf.yang@analog.com Signed-off-by: Mike Frysinger vapier@gentoo.org --- drivers/mtd/nand/bfin_nand.c | 1 + 1 files changed, 1 insertions(+), 0 deletions(-)
diff --git a/drivers/mtd/nand/bfin_nand.c b/drivers/mtd/nand/bfin_nand.c index f6a0835..f134ef1 100644 --- a/drivers/mtd/nand/bfin_nand.c +++ b/drivers/mtd/nand/bfin_nand.c @@ -98,6 +98,7 @@ static void bfin_nfc_read_buf(struct mtd_info *mtd, uint8_t *buf, int len)
/* Contents do not matter */ bfin_write_NFC_DATA_RD(0x0000); + SSYNC();
while (!(bfin_read_NFC_IRQSTAT() & RD_RDY)) if (ctrlc())
SSYNC();
Should such syncing not be integral part of the bfin_write_NFC_DATA_RD() aceessor?
SSYNC();
on the Blackfin processor, the ssync instruction is a barrier rather than a hard requirement (well, that isnt 100% true, but those edge cases dont apply to peripherals). since the NFC_DATA_RD MMR could be written in such a way to not need the barrier, we dont place ssync's into the MMR defines. especially because the ssync instruction flushes all buffers in the chip, not just the peripherals, so it can be pretty heavy handed. -mike
Acked-by: Scott Wood scottwood@freescale.com
-Scott
Signed-off-by: Mike Frysinger vapier@gentoo.org --- include/asm-blackfin/mach-bf527/anomaly.h | 40 ++++++++++++--- include/asm-blackfin/mach-bf533/anomaly.h | 77 +++++++++++++++++++++++----- include/asm-blackfin/mach-bf537/anomaly.h | 67 +++++++++++++------------ include/asm-blackfin/mach-bf548/anomaly.h | 18 ++++--- include/asm-blackfin/mach-bf561/anomaly.h | 17 +++--- 5 files changed, 150 insertions(+), 69 deletions(-)
diff --git a/include/asm-blackfin/mach-bf527/anomaly.h b/include/asm-blackfin/mach-bf527/anomaly.h index df6808d..0fd7e31 100644 --- a/include/asm-blackfin/mach-bf527/anomaly.h +++ b/include/asm-blackfin/mach-bf527/anomaly.h @@ -6,9 +6,9 @@ * Licensed under the GPL-2 or later. */
-/* This file shoule be up to date with: +/* This file should be up to date with: * - Revision B, 08/12/2008; ADSP-BF526 Blackfin Processor Anomaly List - * - Revision E, 08/18/2008; ADSP-BF527 Blackfin Processor Anomaly List + * - Revision F, 03/03/2009; ADSP-BF527 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ @@ -25,14 +25,16 @@ # define ANOMALY_BF527 0 #endif
-/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ +/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ #define ANOMALY_05000074 (1) /* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ #define ANOMALY_05000119 (1) /* note: brokenness is noted in documentation, not anomaly sheet */ /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) -/* Spurious Hardware Error from an Access in the Shadow of a Conditional Branch */ +/* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) +/* Incorrect Timer Pulse Width in Single-Shot PWM_OUT Mode with External Clock */ +#define ANOMALY_05000254 (1) /* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ #define ANOMALY_05000265 (1) /* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ @@ -41,6 +43,8 @@ #define ANOMALY_05000313 (__SILICON_REVISION__ < 2) /* Incorrect Access of OTP_STATUS During otp_write() Function */ #define ANOMALY_05000328 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) +/* Host DMA Boot Modes Are Not Functional */ +#define ANOMALY_05000330 (__SILICON_REVISION__ < 2) /* Disallowed Configuration Prevents Subsequent Allowed Configuration on Host DMA Port */ #define ANOMALY_05000337 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Ethernet MAC MDIO Reads Do Not Meet IEEE Specification */ @@ -75,8 +79,6 @@ #define ANOMALY_05000380 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* 8-Bit NAND Flash Boot Mode Not Functional */ #define ANOMALY_05000382 (__SILICON_REVISION__ < 2) -/* Host Must Not Read Back During Host DMA Boot */ -#define ANOMALY_05000384 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Boot from OTP Memory Not Functional */ #define ANOMALY_05000385 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* bfrom_SysControl() Firmware Routine Not Functional */ @@ -129,7 +131,7 @@ #define ANOMALY_05000416 (1) /* SPORT0 Ignores External TSCLK0 on PG14 When TMR6 is an Output */ #define ANOMALY_05000417 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) -/* tSFSPE and tHFSPE Do Not Meet Data Sheet Specifications */ +/* PPI Timing Requirements tSFSPE and tHFSPE Do Not Meet Data Sheet Specifications */ #define ANOMALY_05000418 (__SILICON_REVISION__ < 2) /* USB PLL_STABLE Bit May Not Accurately Reflect the USB PLL's Status */ #define ANOMALY_05000420 (__SILICON_REVISION__ < 2) @@ -143,25 +145,46 @@ #define ANOMALY_05000424 (ANOMALY_BF527 && __SILICON_REVISION__ < 2) /* Multichannel SPORT Channel Misalignment Under Specific Configuration */ #define ANOMALY_05000425 (__SILICON_REVISION__ < 2) -/* Speculative Fetches of Indirect-Pointer Instructions Can Cause Spurious Hardware Errors */ +/* Speculative Fetches of Indirect-Pointer Instructions Can Cause False Hardware Errors */ #define ANOMALY_05000426 (1) /* WB_EDGE Bit in NFC_IRQSTAT Incorrectly Reflects Buffer Status Instead of IRQ Status */ #define ANOMALY_05000429 (__SILICON_REVISION__ < 2) /* Software System Reset Corrupts PLL_LOCKCNT Register */ #define ANOMALY_05000430 (ANOMALY_BF527 && __SILICON_REVISION__ > 1) +/* Incorrect Use of Stack in Lockbox Firmware During Authentication */ +#define ANOMALY_05000431 (1) /* bfrom_SysControl() Does Not Clear SIC_IWR1 Before Executing PLL Programming Sequence */ #define ANOMALY_05000432 (ANOMALY_BF526) /* Certain SIC Registers are not Reset After Soft or Core Double Fault Reset */ #define ANOMALY_05000435 ((ANOMALY_BF526 && __SILICON_REVISION__ < 1) || ANOMALY_BF527) +/* Preboot Cannot be Used to Alter the PLL_DIV Register */ +#define ANOMALY_05000439 (1) +/* bfrom_SysControl() Cannot be Used to Write the PLL_DIV Register */ +#define ANOMALY_05000440 (1) +/* OTP Write Accesses Not Supported */ +#define ANOMALY_05000442 (__SILICON_REVISION__ < 1) /* IFLUSH Instruction at End of Hardware Loop Causes Infinite Stall */ #define ANOMALY_05000443 (1) +/* The WURESET Bit in the SYSCR Register is not Functional */ +#define ANOMALY_05000445 (1) +/* BCODE_QUICKBOOT, BCODE_ALLBOOT, and BCODE_FULLBOOT Settings in SYSCR Register Not Functional */ +#define ANOMALY_05000451 (1) +/* Incorrect Default Hysteresis Setting for RESET, NMI, and BMODE Signals */ +#define ANOMALY_05000452 (1) +/* USB Receive Interrupt Is Not Generated in DMA Mode 1 */ +#define ANOMALY_05000456 (1) +/* Host DMA Port Responds to Certain Bus Activity Without HOST_CE Assertion */ +#define ANOMALY_05000457 (1)
/* Anomalies that don't exist on this proc */ #define ANOMALY_05000125 (0) #define ANOMALY_05000158 (0) +#define ANOMALY_05000171 (0) #define ANOMALY_05000183 (0) #define ANOMALY_05000198 (0) +#define ANOMALY_05000227 (0) #define ANOMALY_05000230 (0) +#define ANOMALY_05000242 (0) #define ANOMALY_05000244 (0) #define ANOMALY_05000261 (0) #define ANOMALY_05000263 (0) @@ -174,6 +197,7 @@ #define ANOMALY_05000311 (0) #define ANOMALY_05000312 (0) #define ANOMALY_05000323 (0) +#define ANOMALY_05000362 (1) #define ANOMALY_05000363 (0) #define ANOMALY_05000412 (0) #define ANOMALY_05000447 (0) diff --git a/include/asm-blackfin/mach-bf533/anomaly.h b/include/asm-blackfin/mach-bf533/anomaly.h index 1cf893e..c98747f 100644 --- a/include/asm-blackfin/mach-bf533/anomaly.h +++ b/include/asm-blackfin/mach-bf533/anomaly.h @@ -6,7 +6,7 @@ * Licensed under the GPL-2 or later. */
-/* This file shoule be up to date with: +/* This file should be up to date with: * - Revision E, 09/18/2008; ADSP-BF531/BF532/BF533 Blackfin Processor Anomaly List */
@@ -34,12 +34,12 @@ # define ANOMALY_BF533 0 #endif
-/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot 2 Not Supported */ +/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ #define ANOMALY_05000074 (1) /* UART Line Status Register (UART_LSR) Bits Are Not Updated at the Same Time */ #define ANOMALY_05000099 (__SILICON_REVISION__ < 5) /* Watchpoint Status Register (WPSTAT) Bits Are Set on Every Corresponding Match */ -#define ANOMALY_05000105 (1) +#define ANOMALY_05000105 (__SILICON_REVISION__ > 2) /* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ #define ANOMALY_05000119 (1) /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ @@ -48,7 +48,7 @@ #define ANOMALY_05000158 (__SILICON_REVISION__ < 5) /* PPI Data Lengths Between 8 and 16 Do Not Zero Out Upper Bits */ #define ANOMALY_05000166 (1) -/* Turning Serial Ports on with External Frame Syncs */ +/* Turning SPORTs on while External Frame Sync Is Active May Corrupt Data */ #define ANOMALY_05000167 (1) /* PPI_COUNT Cannot Be Programmed to 0 in General Purpose TX or RX Modes */ #define ANOMALY_05000179 (__SILICON_REVISION__ < 5) @@ -67,9 +67,9 @@ /* Current DMA Address Shows Wrong Value During Carry Fix */ #define ANOMALY_05000199 (__SILICON_REVISION__ < 4) /* SPORT TFS and DT Are Incorrectly Driven During Inactive Channels in Certain Conditions */ -#define ANOMALY_05000200 (__SILICON_REVISION__ < 5) +#define ANOMALY_05000200 (__SILICON_REVISION__ == 3 || __SILICON_REVISION__ == 4) /* Receive Frame Sync Not Ignored During Active Frames in SPORT Multi-Channel Mode */ -#define ANOMALY_05000201 (__SILICON_REVISION__ < 4) +#define ANOMALY_05000201 (__SILICON_REVISION__ == 3) /* Possible Infinite Stall with Specific Dual-DAG Situation */ #define ANOMALY_05000202 (__SILICON_REVISION__ < 5) /* Specific Sequence That Can Cause DMA Error or DMA Stopping */ @@ -104,7 +104,7 @@ #define ANOMALY_05000242 (__SILICON_REVISION__ < 5) /* If I-Cache Is On, CSYNC/SSYNC/IDLE Around Change of Control Causes Failures */ #define ANOMALY_05000244 (__SILICON_REVISION__ < 5) -/* Spurious Hardware Error from an Access in the Shadow of a Conditional Branch */ +/* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) /* Data CPLBs Should Prevent Spurious Hardware Errors */ #define ANOMALY_05000246 (__SILICON_REVISION__ < 5) @@ -137,7 +137,7 @@ /* High I/O Activity Causes Output Voltage of Internal Voltage Regulator (Vddint) to Decrease */ #define ANOMALY_05000270 (__SILICON_REVISION__ < 5) /* Spontaneous Reset of Internal Voltage Regulator */ -#define ANOMALY_05000271 (__SILICON_REVISION__ < 4) +#define ANOMALY_05000271 (__SILICON_REVISION__ == 3) /* Certain Data Cache Writethrough Modes Fail for Vddint <= 0.9V */ #define ANOMALY_05000272 (1) /* Writes to Synchronous SDRAM Memory May Be Lost */ @@ -165,14 +165,14 @@ /* New Feature: Additional PPI Frame Sync Sampling Options (Not Available On Older Silicon) */ #define ANOMALY_05000306 (__SILICON_REVISION__ < 5) /* SCKELOW Bit Does Not Maintain State Through Hibernate */ -#define ANOMALY_05000307 (1) +#define ANOMALY_05000307 (1) /* note: brokenness is noted in documentation, not anomaly sheet */ /* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ #define ANOMALY_05000310 (1) /* Erroneous Flag (GPIO) Pin Operations under Specific Sequences */ #define ANOMALY_05000311 (__SILICON_REVISION__ < 6) /* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ #define ANOMALY_05000312 (__SILICON_REVISION__ < 6) -/* PPI Is Level-Sensitive on First Transfer */ +/* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ #define ANOMALY_05000313 (__SILICON_REVISION__ < 6) /* Killed System MMR Write Completes Erroneously On Next System MMR Access */ #define ANOMALY_05000315 (__SILICON_REVISION__ < 6) @@ -205,12 +205,56 @@ * here to show running on older silicon just isn't feasible. */
+/* Internal voltage regulator can't be modified via register writes */ +#define ANOMALY_05000066 (__SILICON_REVISION__ < 2) /* Watchpoints (Hardware Breakpoints) are not supported */ #define ANOMALY_05000067 (__SILICON_REVISION__ < 3) +/* SDRAM PSSE bit cannot be set again after SDRAM Powerup */ +#define ANOMALY_05000070 (__SILICON_REVISION__ < 2) +/* Writing FIO_DIR can corrupt a programmable flag's data */ +#define ANOMALY_05000079 (__SILICON_REVISION__ < 2) +/* Timer Auto-Baud Mode requires the UART clock to be enabled */ +#define ANOMALY_05000086 (__SILICON_REVISION__ < 2) +/* Internal Clocking Modes on SPORT0 not supported */ +#define ANOMALY_05000088 (__SILICON_REVISION__ < 2) +/* Internal voltage regulator does not wake up from an RTC wakeup */ +#define ANOMALY_05000092 (__SILICON_REVISION__ < 2) +/* The IFLUSH instruction must be preceded by a CSYNC instruction */ +#define ANOMALY_05000093 (__SILICON_REVISION__ < 2) +/* Vectoring to an instruction that is presently being filled into the instruction cache may cause erroneous behavior */ +#define ANOMALY_05000095 (__SILICON_REVISION__ < 2) +/* PREFETCH, FLUSH, and FLUSHINV must be followed by a CSYNC */ +#define ANOMALY_05000096 (__SILICON_REVISION__ < 2) +/* Performance Monitor 0 and 1 are swapped when monitoring memory events */ +#define ANOMALY_05000097 (__SILICON_REVISION__ < 2) +/* 32-bit SPORT DMA will be word reversed */ +#define ANOMALY_05000098 (__SILICON_REVISION__ < 2) +/* Incorrect status in the UART_IIR register */ +#define ANOMALY_05000100 (__SILICON_REVISION__ < 2) +/* Reading X_MODIFY or Y_MODIFY while DMA channel is active */ +#define ANOMALY_05000101 (__SILICON_REVISION__ < 2) +/* Descriptor-based MemDMA may lock up with 32-bit transfers or if transfers span 64KB buffers */ +#define ANOMALY_05000102 (__SILICON_REVISION__ < 2) +/* Incorrect value written to the cycle counters */ +#define ANOMALY_05000103 (__SILICON_REVISION__ < 2) +/* Stores to L1 Data memory incorrect when a specific sequence is followed */ +#define ANOMALY_05000104 (__SILICON_REVISION__ < 2) +/* Programmable Flag (PF3) functionality not supported in all PPI modes */ +#define ANOMALY_05000106 (__SILICON_REVISION__ < 2) +/* Data store can be lost when targeting a cache line fill */ +#define ANOMALY_05000107 (__SILICON_REVISION__ < 2) /* Reserved bits in SYSCFG register not set at power on */ #define ANOMALY_05000109 (__SILICON_REVISION__ < 3) +/* Infinite Core Stall */ +#define ANOMALY_05000114 (__SILICON_REVISION__ < 2) +/* PPI_FSx may glitch when generated by the on chip Timers */ +#define ANOMALY_05000115 (__SILICON_REVISION__ < 2) /* Trace Buffers may record discontinuities into emulation mode and/or exception, NMI, reset handlers */ #define ANOMALY_05000116 (__SILICON_REVISION__ < 3) +/* DTEST registers allow access to Data Cache when DTEST_COMMAND< 14 >= 0 */ +#define ANOMALY_05000117 (__SILICON_REVISION__ < 2) +/* Booting from an 8-bit or 24-bit Addressable SPI device is not supported */ +#define ANOMALY_05000118 (__SILICON_REVISION__ < 2) /* DTEST_COMMAND initiated memory access may be incorrect if data cache or DMA is active */ #define ANOMALY_05000123 (__SILICON_REVISION__ < 3) /* DMA Lock-up at CCLK to SCLK ratios of 4:1, 2:1, or 1:1 */ @@ -222,7 +266,9 @@ /* DMEM_CONTROL is not set on Reset */ #define ANOMALY_05000137 (__SILICON_REVISION__ < 3) /* SPI boot will not complete if there is a zero fill block in the loader file */ -#define ANOMALY_05000138 (__SILICON_REVISION__ < 3) +#define ANOMALY_05000138 (__SILICON_REVISION__ == 2) +/* Timerx_Config must be set for using the PPI in GP output mode with internal Frame Syncs */ +#define ANOMALY_05000139 (__SILICON_REVISION__ < 2) /* Allowing the SPORT RX FIFO to fill will cause an overflow */ #define ANOMALY_05000140 (__SILICON_REVISION__ < 3) /* An Infinite Stall occurs with a particular sequence of consecutive dual dag events */ @@ -237,17 +283,17 @@ #define ANOMALY_05000145 (__SILICON_REVISION__ < 3) /* MDMA may lose the first few words of a descriptor chain */ #define ANOMALY_05000146 (__SILICON_REVISION__ < 3) -/* The source MDMA descriptor may stop with a DMA Error */ +/* Source MDMA descriptor may stop with a DMA Error near beginning of descriptor fetch */ #define ANOMALY_05000147 (__SILICON_REVISION__ < 3) /* When booting from a 16-bit asynchronous memory device, the upper 8-bits of each word must be 0x00 */ #define ANOMALY_05000148 (__SILICON_REVISION__ < 3) /* Frame Delay in SPORT Multichannel Mode */ #define ANOMALY_05000153 (__SILICON_REVISION__ < 3) -/* SPORT TFS signal is active in Multi-channel mode outside of valid channels */ +/* SPORT TFS signal stays active in multichannel mode outside of valid channels */ #define ANOMALY_05000154 (__SILICON_REVISION__ < 3) /* Timer1 can not be used for PWMOUT mode when a certain PPI mode is in use */ #define ANOMALY_05000155 (__SILICON_REVISION__ < 3) -/* A killed 32-bit System MMR write will lead to the next system MMR access thinking it should be 32-bit. */ +/* Killed 32-bit MMR write leads to next system MMR access thinking it should be 32-bit */ #define ANOMALY_05000157 (__SILICON_REVISION__ < 3) /* SPORT transmit data is not gated by external frame sync in certain conditions */ #define ANOMALY_05000163 (__SILICON_REVISION__ < 3) @@ -275,12 +321,15 @@ #define ANOMALY_05000206 (__SILICON_REVISION__ < 3)
/* Anomalies that don't exist on this proc */ +#define ANOMALY_05000171 (0) #define ANOMALY_05000266 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000353 (1) +#define ANOMALY_05000362 (1) #define ANOMALY_05000380 (0) #define ANOMALY_05000386 (1) #define ANOMALY_05000412 (0) +#define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) #define ANOMALY_05000447 (0) diff --git a/include/asm-blackfin/mach-bf537/anomaly.h b/include/asm-blackfin/mach-bf537/anomaly.h index 1bfd80c..b7f1a3f 100644 --- a/include/asm-blackfin/mach-bf537/anomaly.h +++ b/include/asm-blackfin/mach-bf537/anomaly.h @@ -6,7 +6,7 @@ * Licensed under the GPL-2 or later. */
-/* This file shoule be up to date with: +/* This file should be up to date with: * - Revision D, 09/18/2008; ADSP-BF534/ADSP-BF536/ADSP-BF537 Blackfin Processor Anomaly List */
@@ -36,77 +36,75 @@
/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ #define ANOMALY_05000074 (1) -/* DMA_RUN bit is not valid after a Peripheral Receive Channel DMA stops */ +/* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ #define ANOMALY_05000119 (1) -/* Rx.H cannot be used to access 16-bit System MMR registers */ +/* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) /* Killed 32-bit MMR write leads to next system MMR access thinking it should be 32-bit */ #define ANOMALY_05000157 (__SILICON_REVISION__ < 2) -/* Turning SPORTs on while External Frame Sync Is Active May Corrupt Data */ -#define ANOMALY_05000167 (1) -/* PPI_DELAY not functional in PPI modes with 0 frame syncs */ +/* PPI_DELAY Not Functional in PPI Modes with 0 Frame Syncs */ #define ANOMALY_05000180 (1) /* Instruction Cache Is Not Functional */ #define ANOMALY_05000237 (__SILICON_REVISION__ < 2) -/* If i-cache is on, CSYNC/SSYNC/IDLE around Change of Control causes failures */ +/* If I-Cache Is On, CSYNC/SSYNC/IDLE Around Change of Control Causes Failures */ #define ANOMALY_05000244 (__SILICON_REVISION__ < 3) -/* Spurious Hardware Error from an access in the shadow of a conditional branch */ +/* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) /* CLKIN Buffer Output Enable Reset Behavior Is Changed */ #define ANOMALY_05000247 (1) -/* Incorrect Bit-Shift of Data Word in Multichannel (TDM) mode in certain conditions */ +/* Incorrect Bit Shift of Data Word in Multichannel (TDM) Mode in Certain Conditions */ #define ANOMALY_05000250 (__SILICON_REVISION__ < 3) /* EMAC Tx DMA error after an early frame abort */ #define ANOMALY_05000252 (__SILICON_REVISION__ < 3) -/* Maximum external clock speed for Timers */ +/* Maximum External Clock Speed for Timers */ #define ANOMALY_05000253 (__SILICON_REVISION__ < 3) -/* Incorrect Timer Pulse Width in Single-Shot PWM_OUT mode with external clock */ +/* Incorrect Timer Pulse Width in Single-Shot PWM_OUT Mode with External Clock */ #define ANOMALY_05000254 (__SILICON_REVISION__ > 2) -/* Entering Hibernate Mode with RTC Seconds event interrupt not functional */ +/* Entering Hibernate State with RTC Seconds Interrupt Not Functional */ #define ANOMALY_05000255 (__SILICON_REVISION__ < 3) /* EMAC MDIO input latched on wrong MDC edge */ #define ANOMALY_05000256 (__SILICON_REVISION__ < 3) -/* Interrupt/Exception during short hardware loop may cause bad instruction fetches */ +/* Interrupt/Exception During Short Hardware Loop May Cause Bad Instruction Fetches */ #define ANOMALY_05000257 (__SILICON_REVISION__ < 3) -/* Instruction Cache is corrupted when bits 9 and 12 of the ICPLB Data registers differ */ +/* Instruction Cache Is Corrupted When Bits 9 and 12 of the ICPLB Data Registers Differ */ #define ANOMALY_05000258 (((ANOMALY_BF536 || ANOMALY_BF537) && __SILICON_REVISION__ == 1) || __SILICON_REVISION__ == 2) -/* ICPLB_STATUS MMR register may be corrupted */ +/* ICPLB_STATUS MMR Register May Be Corrupted */ #define ANOMALY_05000260 (__SILICON_REVISION__ == 2) -/* DCPLB_FAULT_ADDR MMR register may be corrupted */ +/* DCPLB_FAULT_ADDR MMR Register May Be Corrupted */ #define ANOMALY_05000261 (__SILICON_REVISION__ < 3) -/* Stores to data cache may be lost */ +/* Stores To Data Cache May Be Lost */ #define ANOMALY_05000262 (__SILICON_REVISION__ < 3) -/* Hardware loop corrupted when taking an ICPLB exception */ +/* Hardware Loop Corrupted When Taking an ICPLB Exception */ #define ANOMALY_05000263 (__SILICON_REVISION__ == 2) -/* CSYNC/SSYNC/IDLE causes infinite stall in second to last instruction in hardware loop */ +/* CSYNC/SSYNC/IDLE Causes Infinite Stall in Penultimate Instruction in Hardware Loop */ #define ANOMALY_05000264 (__SILICON_REVISION__ < 3) -/* Sensitivity to noise with slow input edge rates on external SPORT TX and RX clocks */ +/* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ #define ANOMALY_05000265 (1) /* Memory DMA error when peripheral DMA is running with non-zero DEB_TRAFFIC_PERIOD */ #define ANOMALY_05000268 (__SILICON_REVISION__ < 3) -/* High I/O activity causes output voltage of internal voltage regulator (VDDint) to decrease */ +/* High I/O Activity Causes Output Voltage of Internal Voltage Regulator (Vddint) to Decrease */ #define ANOMALY_05000270 (__SILICON_REVISION__ < 3) -/* Certain data cache write through modes fail for VDDint <=0.9V */ +/* Certain Data Cache Writethrough Modes Fail for Vddint <= 0.9V */ #define ANOMALY_05000272 (1) -/* Writes to Synchronous SDRAM memory may be lost */ +/* Writes to Synchronous SDRAM Memory May Be Lost */ #define ANOMALY_05000273 (__SILICON_REVISION__ < 3) -/* Writes to an I/O data register one SCLK cycle after an edge is detected may clear interrupt */ +/* Writes to an I/O Data Register One SCLK Cycle after an Edge Is Detected May Clear Interrupt */ #define ANOMALY_05000277 (__SILICON_REVISION__ < 3) -/* Disabling Peripherals with DMA running may cause DMA system instability */ +/* Disabling Peripherals with DMA Running May Cause DMA System Instability */ #define ANOMALY_05000278 (((ANOMALY_BF536 || ANOMALY_BF537) && __SILICON_REVISION__ < 3) || (ANOMALY_BF534 && __SILICON_REVISION__ < 2)) /* SPI Master boot mode does not work well with Atmel Data flash devices */ #define ANOMALY_05000280 (1) -/* False Hardware Error Exception when ISR context is not restored */ +/* False Hardware Error Exception When ISR Context Is Not Restored */ #define ANOMALY_05000281 (__SILICON_REVISION__ < 3) -/* Memory DMA corruption with 32-bit data and traffic control */ +/* Memory DMA Corruption with 32-Bit Data and Traffic Control */ #define ANOMALY_05000282 (__SILICON_REVISION__ < 3) /* System MMR Write Is Stalled Indefinitely When Killed in a Particular Stage */ #define ANOMALY_05000283 (__SILICON_REVISION__ < 3) /* New Feature: EMAC TX DMA Word Alignment (Not Available On Older Silicon) */ #define ANOMALY_05000285 (__SILICON_REVISION__ < 3) -/* SPORTs may receive bad data if FIFOs fill up */ +/* SPORTs May Receive Bad Data If FIFOs Fill Up */ #define ANOMALY_05000288 (__SILICON_REVISION__ < 3) -/* Memory to memory DMA source/destination descriptors must be in same memory space */ +/* Memory-To-Memory DMA Source/Destination Descriptors Must Be in Same Memory Space */ #define ANOMALY_05000301 (1) /* SSYNCs After Writes To CAN/DMA MMR Registers Are Not Always Handled Correctly */ #define ANOMALY_05000304 (__SILICON_REVISION__ < 3) @@ -116,11 +114,11 @@ #define ANOMALY_05000307 (__SILICON_REVISION__ < 3) /* Writing UART_THR while UART clock is disabled sends erroneous start bit */ #define ANOMALY_05000309 (__SILICON_REVISION__ < 3) -/* False hardware errors caused by fetches at the boundary of reserved memory */ +/* False Hardware Errors Caused by Fetches at the Boundary of Reserved Memory */ #define ANOMALY_05000310 (1) -/* Errors when SSYNC, CSYNC, or loads to LT, LB and LC registers are interrupted */ +/* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ #define ANOMALY_05000312 (1) -/* PPI is level sensitive on first transfer */ +/* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ #define ANOMALY_05000313 (1) /* Killed System MMR Write Completes Erroneously On Next System MMR Access */ #define ANOMALY_05000315 (__SILICON_REVISION__ < 3) @@ -160,17 +158,22 @@ /* Anomalies that don't exist on this proc */ #define ANOMALY_05000125 (0) #define ANOMALY_05000158 (0) +#define ANOMALY_05000171 (0) #define ANOMALY_05000183 (0) #define ANOMALY_05000198 (0) +#define ANOMALY_05000227 (0) #define ANOMALY_05000230 (0) +#define ANOMALY_05000242 (0) #define ANOMALY_05000266 (0) #define ANOMALY_05000311 (0) #define ANOMALY_05000323 (0) #define ANOMALY_05000353 (1) +#define ANOMALY_05000362 (1) #define ANOMALY_05000363 (0) #define ANOMALY_05000380 (0) #define ANOMALY_05000386 (1) #define ANOMALY_05000412 (0) +#define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) #define ANOMALY_05000447 (0) diff --git a/include/asm-blackfin/mach-bf548/anomaly.h b/include/asm-blackfin/mach-bf548/anomaly.h index 882e40c..192dd67 100644 --- a/include/asm-blackfin/mach-bf548/anomaly.h +++ b/include/asm-blackfin/mach-bf548/anomaly.h @@ -6,26 +6,26 @@ * Licensed under the GPL-2 or later. */
-/* This file shoule be up to date with: +/* This file should be up to date with: * - Revision H, 01/16/2009; ADSP-BF542/BF544/BF547/BF548/BF549 Blackfin Processor Anomaly List */
#ifndef _MACH_ANOMALY_H_ #define _MACH_ANOMALY_H_
-/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot2 Not Supported */ +/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ #define ANOMALY_05000074 (1) /* DMA_RUN Bit Is Not Valid after a Peripheral Receive Channel DMA Stops */ #define ANOMALY_05000119 (1) /* Rx.H Cannot Be Used to Access 16-bit System MMR Registers */ #define ANOMALY_05000122 (1) -/* Spurious Hardware Error from an Access in the Shadow of a Conditional Branch */ +/* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (1) /* Sensitivity To Noise with Slow Input Edge Rates on External SPORT TX and RX Clocks */ #define ANOMALY_05000265 (1) /* Certain Data Cache Writethrough Modes Fail for Vddint <= 0.9V */ #define ANOMALY_05000272 (1) -/* False Hardware Error Exception when ISR context is not restored */ +/* False Hardware Error Exception When ISR Context Is Not Restored */ #define ANOMALY_05000281 (__SILICON_REVISION__ < 1) /* SSYNCs After Writes To CAN/DMA MMR Registers Are Not Always Handled Correctly */ #define ANOMALY_05000304 (__SILICON_REVISION__ < 1) @@ -59,7 +59,7 @@ #define ANOMALY_05000340 (__SILICON_REVISION__ < 1) /* Boot Host Wait (HWAIT) and Boot Host Wait Alternate (HWAITA) Signals Are Swapped */ #define ANOMALY_05000344 (__SILICON_REVISION__ < 1) -/* USB Calibration Value Is Not Intialized */ +/* USB Calibration Value Is Not Initialized */ #define ANOMALY_05000346 (__SILICON_REVISION__ < 1) /* USB Calibration Value to use */ #define ANOMALY_05000346_value 0x5411 @@ -147,11 +147,11 @@ #define ANOMALY_05000416 (1) /* Multichannel SPORT Channel Misalignment Under Specific Configuration */ #define ANOMALY_05000425 (1) -/* Speculative Fetches of Indirect-Pointer Instructions Can Cause Spurious Hardware Errors */ +/* Speculative Fetches of Indirect-Pointer Instructions Can Cause False Hardware Errors */ #define ANOMALY_05000426 (1) /* CORE_EPPI_PRIO bit and SYS_EPPI_PRIO bit in the HMDMA1_CONTROL register are not functional */ #define ANOMALY_05000427 (__SILICON_REVISION__ < 2) -/* WB_EDGE Bit in NFC_IRQSTAT Incorrectly Behaves as a Buffer Status Bit Instead of an IRQ Status Bit */ +/* WB_EDGE Bit in NFC_IRQSTAT Incorrectly Reflects Buffer Status Instead of IRQ Status */ #define ANOMALY_05000429 (__SILICON_REVISION__ < 2) /* Software System Reset Corrupts PLL_LOCKCNT Register */ #define ANOMALY_05000430 (__SILICON_REVISION__ >= 2) @@ -175,9 +175,12 @@ /* Anomalies that don't exist on this proc */ #define ANOMALY_05000125 (0) #define ANOMALY_05000158 (0) +#define ANOMALY_05000171 (0) #define ANOMALY_05000183 (0) #define ANOMALY_05000198 (0) +#define ANOMALY_05000227 (0) #define ANOMALY_05000230 (0) +#define ANOMALY_05000242 (0) #define ANOMALY_05000244 (0) #define ANOMALY_05000261 (0) #define ANOMALY_05000263 (0) @@ -188,6 +191,7 @@ #define ANOMALY_05000307 (0) #define ANOMALY_05000311 (0) #define ANOMALY_05000323 (0) +#define ANOMALY_05000362 (1) #define ANOMALY_05000363 (0) #define ANOMALY_05000380 (0) #define ANOMALY_05000412 (0) diff --git a/include/asm-blackfin/mach-bf561/anomaly.h b/include/asm-blackfin/mach-bf561/anomaly.h index d0b0b35..e4aa20c 100644 --- a/include/asm-blackfin/mach-bf561/anomaly.h +++ b/include/asm-blackfin/mach-bf561/anomaly.h @@ -6,7 +6,7 @@ * Licensed under the GPL-2 or later. */
-/* This file shoule be up to date with: +/* This file should be up to date with: * - Revision Q, 11/07/2008; ADSP-BF561 Blackfin Processor Anomaly List */
@@ -18,11 +18,11 @@ # error will not work on BF561 silicon version 0.0, 0.1, 0.2, or 0.4 #endif
-/* Multi-Issue Instruction with dsp32shiftimm in slot1 and P-reg Store in slot 2 Not Supported */ +/* Multi-issue instruction with dsp32shiftimm in slot1 and P-reg store in slot 2 not supported */ #define ANOMALY_05000074 (1) /* UART Line Status Register (UART_LSR) Bits Are Not Updated at the Same Time */ #define ANOMALY_05000099 (__SILICON_REVISION__ < 5) -/* Trace Buffers may contain errors in emulation mode and/or exception, NMI, reset handlers */ +/* Trace Buffers may record discontinuities into emulation mode and/or exception, NMI, reset handlers */ #define ANOMALY_05000116 (__SILICON_REVISION__ < 3) /* Testset instructions restricted to 32-bit aligned memory locations */ #define ANOMALY_05000120 (1) @@ -40,7 +40,7 @@ #define ANOMALY_05000136 (__SILICON_REVISION__ < 3) /* Allowing the SPORT RX FIFO to fill will cause an overflow */ #define ANOMALY_05000140 (__SILICON_REVISION__ < 3) -/* Infinite Stall may occur with a particular sequence of consecutive dual dag events */ +/* An Infinite Stall occurs with a particular sequence of consecutive dual dag events */ #define ANOMALY_05000141 (__SILICON_REVISION__ < 3) /* Interrupts may be lost when a programmable input flag is configured to be edge sensitive */ #define ANOMALY_05000142 (__SILICON_REVISION__ < 3) @@ -80,7 +80,7 @@ #define ANOMALY_05000163 (__SILICON_REVISION__ < 3) /* PPI Data Lengths Between 8 and 16 Do Not Zero Out Upper Bits */ #define ANOMALY_05000166 (1) -/* Turning Serial Ports on with External Frame Syncs */ +/* Turning SPORTs on while External Frame Sync Is Active May Corrupt Data */ #define ANOMALY_05000167 (1) /* SDRAM auto-refresh and subsequent Power Ups */ #define ANOMALY_05000168 (__SILICON_REVISION__ < 5) @@ -164,7 +164,7 @@ #define ANOMALY_05000242 (__SILICON_REVISION__ < 5) /* If I-Cache Is On, CSYNC/SSYNC/IDLE Around Change of Control Causes Failures */ #define ANOMALY_05000244 (__SILICON_REVISION__ < 5) -/* Spurious Hardware Error from an Access in the Shadow of a Conditional Branch */ +/* False Hardware Error from an Access in the Shadow of a Conditional Branch */ #define ANOMALY_05000245 (__SILICON_REVISION__ < 5) /* TESTSET operation forces stall on the other core */ #define ANOMALY_05000248 (__SILICON_REVISION__ < 5) @@ -208,7 +208,7 @@ #define ANOMALY_05000275 (__SILICON_REVISION__ > 2) /* Timing Requirements Change for External Frame Sync PPI Modes with Non-Zero PPI_DELAY */ #define ANOMALY_05000276 (__SILICON_REVISION__ < 5) -/* Writes to an I/O data register one SCLK cycle after an edge is detected may clear interrupt */ +/* Writes to an I/O Data Register One SCLK Cycle after an Edge Is Detected May Clear Interrupt */ #define ANOMALY_05000277 (__SILICON_REVISION__ < 3) /* Disabling Peripherals with DMA Running May Cause DMA System Instability */ #define ANOMALY_05000278 (__SILICON_REVISION__ < 5) @@ -232,7 +232,7 @@ #define ANOMALY_05000310 (1) /* Errors When SSYNC, CSYNC, or Loads to LT, LB and LC Registers Are Interrupted */ #define ANOMALY_05000312 (1) -/* PPI Is Level-Sensitive on First Transfer */ +/* PPI Is Level-Sensitive on First Transfer In Single Frame Sync Modes */ #define ANOMALY_05000313 (1) /* Killed System MMR Write Completes Erroneously On Next System MMR Access */ #define ANOMALY_05000315 (1) @@ -285,6 +285,7 @@ #define ANOMALY_05000353 (1) #define ANOMALY_05000380 (0) #define ANOMALY_05000386 (1) +#define ANOMALY_05000430 (0) #define ANOMALY_05000432 (0) #define ANOMALY_05000435 (0) #define ANOMALY_05000447 (0)
DESCRIPTION: The Boot ROM is executed at power up/reset and changes the value of the SICA_IWR registers from their default reset value of 0xFFFF, but does not restore them.
WORKAROUND: User code should not rely on the default value of these registers. Set the desired values explicitly.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 4 ++++ 1 files changed, 4 insertions(+), 0 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index 3120447..d44c6a6 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -356,6 +356,10 @@ void initcode(ADI_BOOT_DATA *bootstruct) #if ANOMALY_05000432 bfin_write_SIC_IWR1(-1); #endif +#if ANOMALY_05000171 + bfin_write_SICA_IWR0(-1); + bfin_write_SICA_IWR1(-1); +#endif } else { serial_putc('G');
DESCRIPTION: If the DF bit is set prior to a hardware reset, the PLL will continue to divide CLKIN by 2 after the hardware reset, but the DF bit itself will be cleared in the PLL_CTL register.
WORKAROUND: Reprogram the PLL with DF cleared if the desire is to not divide CLKIN by 2 after reset.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 2 +- 1 files changed, 1 insertions(+), 1 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index d44c6a6..7f54860 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -401,7 +401,7 @@ void initcode(ADI_BOOT_DATA *bootstruct) /* Only reprogram when needed to avoid triggering unnecessary * PLL relock sequences. */ - if (bfin_read_PLL_CTL() != CONFIG_PLL_CTL_VAL) { + if (ANOMALY_05000242 || bfin_read_PLL_CTL() != CONFIG_PLL_CTL_VAL) { serial_putc('!'); bfin_write_PLL_CTL(CONFIG_PLL_CTL_VAL); asm("idle;");
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 2 ++ 1 files changed, 2 insertions(+), 0 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index 7f54860..062cbb8 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -335,6 +335,7 @@ void initcode(ADI_BOOT_DATA *bootstruct) if (!ANOMALY_05000386) { serial_putc('F');
+ /* Always programming PLL_LOCKCNT avoids Anomaly 05000430 */ ADI_SYSCTRL_VALUES memory_settings; uint32_t actions = SYSCTRL_WRITE | SYSCTRL_PLLCTL | SYSCTRL_PLLDIV | SYSCTRL_LOCKCNT; if (CONFIG_HAS_VR) { @@ -379,6 +380,7 @@ void initcode(ADI_BOOT_DATA *bootstruct)
serial_putc('H');
+ /* Always programming PLL_LOCKCNT avoids Anomaly 05000430 */ bfin_write_PLL_LOCKCNT(CONFIG_PLL_LOCKCNT_VAL);
serial_putc('I');
DESCRIPTION: The column address width settings for banks 2 and 3 are misconnected in the SDRAM controller. Accesses to bank 2 will result in an error if the Column Address Width for bank 3 (EB3CAW ) is not set to be the same as that of bank 2.
WORKAROUND: If using bank 2, make sure that banks 2 and 3 have the same column address width settings in the EBIU_SDBCTL register. This must be the case regardless of whether or not bank 3 is enabled.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/initcode.c | 9 +++++++++ 1 files changed, 9 insertions(+), 0 deletions(-)
diff --git a/cpu/blackfin/initcode.c b/cpu/blackfin/initcode.c index 062cbb8..aba00e0 100644 --- a/cpu/blackfin/initcode.c +++ b/cpu/blackfin/initcode.c @@ -246,6 +246,15 @@ static inline void serial_putc(char c) #endif #endif
+/* Conflicting Column Address Widths Causes SDRAM Errors: + * EB2CAW and EB3CAW must be the same + */ +#if ANOMALY_05000362 +# if ((CONFIG_EBIU_SDBCTL_VAL & 0x30000000) >> 8) != (CONFIG_EBIU_SDBCTL_VAL & 0x00300000) +# error "Anomaly 05000362: EB2CAW and EB3CAW must be the same" +# endif +#endif + BOOTROM_CALLED_FUNC_ATTR void initcode(ADI_BOOT_DATA *bootstruct) {
There is no code change here, just new comments, but this keeps me from having to do another audit from scratch in the future.
Signed-off-by: Mike Frysinger vapier@gentoo.org --- cpu/blackfin/serial.c | 21 ++++++++++++++++++++- cpu/blackfin/serial.h | 2 +- 2 files changed, 21 insertions(+), 2 deletions(-)
diff --git a/cpu/blackfin/serial.c b/cpu/blackfin/serial.c index 3861955..2abda18 100644 --- a/cpu/blackfin/serial.c +++ b/cpu/blackfin/serial.c @@ -24,6 +24,19 @@ * Licensed under the GPL-2 or later. */
+/* Anomaly notes: + * 05000086 - we don't support autobaud + * 05000099 - we only use DR bit, so losing others is not a problem + * 05000100 - we don't use the UART_IIR register + * 05000215 - we poll the uart (no dma/interrupts) + * 05000225 - no workaround possible, but this shouldnt cause errors ... + * 05000230 - we tweak the baud rate calculation slightly + * 05000231 - we always use 1 stop bit + * 05000309 - we always enable the uart before we modify it in anyway + * 05000350 - we always enable the uart regardless of boot mode + * 05000363 - we don't support break signals, so don't generate one + */ + #include <common.h> #include <watchdog.h> #include <asm/blackfin.h> @@ -43,7 +56,9 @@ uint16_t cached_rbr[256]; size_t cache_count;
/* The LSR is read-to-clear on some parts, so we have to make sure status - * bits aren't inadvertently lost when doing various tests. + * bits aren't inadvertently lost when doing various tests. This also + * works around anomaly 05000099 at the same time by keeping a cumulative + * tally of all the status bits. */ static uint16_t uart_lsr_save; static uint16_t uart_lsr_read(void) @@ -59,6 +74,10 @@ static void uart_lsr_clear(void) *pUART_LSR |= -1; } #else +/* When debugging is disabled, we only care about the DR bit, so if other + * bits get set/cleared, we don't really care since we don't read them + * anyways (and thus anomaly 05000099 is irrelevant). + */ static inline uint16_t uart_lsr_read(void) { return *pUART_LSR; } static inline void uart_lsr_clear(void) { *pUART_LSR = -1; } #endif diff --git a/cpu/blackfin/serial.h b/cpu/blackfin/serial.h index ce39148..7b47878 100644 --- a/cpu/blackfin/serial.h +++ b/cpu/blackfin/serial.h @@ -146,7 +146,7 @@ static inline void serial_early_init(void) /* handle portmux crap on different Blackfins */ serial_do_portmux();
- /* Enable UART */ + /* always enable UART -- avoids anomalies 05000309 and 05000350 */ *pUART_GCTL = UCEN;
/* Set LCR to Word Lengh 8-bit word select */
<nitpicking> Note that, according to the updated release schedule, this will be v2009.06 ;-) </nitpicking>
I guess a pull request will follow soon?
err, yeah, i forgot about that
for patch series, i like to let them sit for a day or two before asking for a pull request. inevitably, some one points out something i did wrong. -mike
Yes, of course. I just wanted to be sure.
Mike Frysinger
Scott Wood
