[U-Boot] [PATCH 1/3] configs: trats2: enable the max77686 regulator config
Enable the CONFIG_DM_REGULATOR_MAX77686 for using regulator driver.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- configs/trats2_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/trats2_defconfig b/configs/trats2_defconfig index aaa25a9bc7..dab62530e7 100644 --- a/configs/trats2_defconfig +++ b/configs/trats2_defconfig @@ -46,6 +46,8 @@ CONFIG_MMC_SDHCI_SDMA=y CONFIG_MMC_SDHCI_S5P=y CONFIG_DM_PMIC=y CONFIG_DM_PMIC_MAX77686=y +CONFIG_DM_REGULATOR=y +CONFIG_DM_REGULATOR_MAX77686=y CONFIG_USB=y CONFIG_DM_USB=y CONFIG_USB_GADGET=y
max77686 pmic is supporting with max77686.c under pmic/ and regulator/ direnctroy. Remove pmic_max77686.c what didn't use anywhere. Instead, enable CONFIG_DM_REGULATOR_MAX77686 and CONFIG_DM_PMIC_MAX77686.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- drivers/power/pmic/Makefile | 1 - drivers/power/pmic/pmic_max77686.c | 304 ------------------------------------- 2 files changed, 305 deletions(-) delete mode 100644 drivers/power/pmic/pmic_max77686.c
diff --git a/drivers/power/pmic/Makefile b/drivers/power/pmic/Makefile index 7d6c583d34..265b7cb2f6 100644 --- a/drivers/power/pmic/Makefile +++ b/drivers/power/pmic/Makefile @@ -29,7 +29,6 @@ obj-$(CONFIG_POWER_MAX77696) += pmic_max77696.o obj-$(CONFIG_POWER_MAX8998) += pmic_max8998.o obj-$(CONFIG_POWER_MAX8997) += pmic_max8997.o obj-$(CONFIG_POWER_MUIC_MAX8997) += muic_max8997.o -obj-$(CONFIG_POWER_MAX77686) += pmic_max77686.o obj-$(CONFIG_POWER_PFUZE100) += pmic_pfuze100.o obj-$(CONFIG_POWER_PFUZE3000) += pmic_pfuze3000.o obj-$(CONFIG_POWER_TPS65217) += pmic_tps65217.o diff --git a/drivers/power/pmic/pmic_max77686.c b/drivers/power/pmic/pmic_max77686.c deleted file mode 100644 index 8e653316d1..0000000000 --- a/drivers/power/pmic/pmic_max77686.c +++ /dev/null @@ -1,304 +0,0 @@ -/* - * Copyright (C) 2012 Samsung Electronics - * Rajeshwari Shinde rajeshwari.s@samsung.com - * - * SPDX-License-Identifier: GPL-2.0+ - */ - -#include <common.h> -#include <fdtdec.h> -#include <i2c.h> -#include <power/pmic.h> -#include <power/max77686_pmic.h> -#include <errno.h> - -DECLARE_GLOBAL_DATA_PTR; - -static const char max77686_buck_addr[] = { - 0xff, 0x10, 0x12, 0x1c, 0x26, 0x30, 0x32, 0x34, 0x36, 0x38 -}; - -static unsigned int max77686_ldo_volt2hex(int ldo, ulong uV) -{ - unsigned int hex = 0; - - switch (ldo) { - case 1: - case 2: - case 6: - case 7: - case 8: - case 15: - hex = (uV - 800000) / 25000; - break; - default: - hex = (uV - 800000) / 50000; - } - - if (hex >= 0 && hex <= MAX77686_LDO_VOLT_MAX_HEX) - return hex; - - debug("%s: %ld is wrong voltage value for LDO%d\n", __func__, uV, ldo); - return 0; -} - -static int max77686_buck_volt2hex(int buck, ulong uV) -{ - int hex = 0; - - if (buck < 5 || buck > 9) { - debug("%s: buck %d is not supported\n", __func__, buck); - return -EINVAL; - } - - hex = (uV - 750000) / 50000; - - if (hex >= 0 && hex <= MAX77686_BUCK_VOLT_MAX_HEX) - return hex; - - debug("%s: %ld is wrong voltage value for BUCK%d\n", - __func__, uV, buck); - return -EINVAL; -} - -int max77686_set_ldo_voltage(struct pmic *p, int ldo, ulong uV) -{ - unsigned int val, ret, hex, adr; - - if (ldo < 1 || ldo > 26) { - printf("%s: %d is wrong ldo number\n", __func__, ldo); - return -EINVAL; - } - - adr = MAX77686_REG_PMIC_LDO1CTRL1 + ldo - 1; - hex = max77686_ldo_volt2hex(ldo, uV); - - if (!hex) - return -EINVAL; - - ret = pmic_reg_read(p, adr, &val); - if (ret) - return ret; - - val &= ~MAX77686_LDO_VOLT_MASK; - val |= hex; - ret |= pmic_reg_write(p, adr, val); - - return ret; -} - -int max77686_set_buck_voltage(struct pmic *p, int buck, ulong uV) -{ - unsigned int val, adr; - int hex, ret; - - if (buck < 5 || buck > 9) { - printf("%s: %d is an unsupported bucket number\n", - __func__, buck); - return -EINVAL; - } - - adr = max77686_buck_addr[buck] + 1; - hex = max77686_buck_volt2hex(buck, uV); - - if (hex < 0) - return hex; - - ret = pmic_reg_read(p, adr, &val); - if (ret) - return ret; - - val &= ~MAX77686_BUCK_VOLT_MASK; - ret |= pmic_reg_write(p, adr, val | hex); - - return ret; -} - -int max77686_set_ldo_mode(struct pmic *p, int ldo, char opmode) -{ - unsigned int val, ret, adr, mode; - - if (ldo < 1 || 26 < ldo) { - printf("%s: %d is wrong ldo number\n", __func__, ldo); - return -EINVAL; - } - - adr = MAX77686_REG_PMIC_LDO1CTRL1 + ldo - 1; - - /* mode */ - switch (opmode) { - case OPMODE_OFF: - mode = MAX77686_LDO_MODE_OFF; - break; - case OPMODE_STANDBY: - switch (ldo) { - case 2: - case 6: - case 7: - case 8: - case 10: - case 11: - case 12: - case 14: - case 15: - case 16: - mode = MAX77686_LDO_MODE_STANDBY; - break; - default: - mode = 0xff; - } - break; - case OPMODE_LPM: - mode = MAX77686_LDO_MODE_LPM; - break; - case OPMODE_ON: - mode = MAX77686_LDO_MODE_ON; - break; - default: - mode = 0xff; - } - - if (mode == 0xff) { - printf("%s: %d is not supported on LDO%d\n", - __func__, opmode, ldo); - return -ENOTSUPP; - } - - ret = pmic_reg_read(p, adr, &val); - if (ret) - return ret; - - val &= ~MAX77686_LDO_MODE_MASK; - val |= mode; - ret |= pmic_reg_write(p, adr, val); - - return ret; -} - -int max77686_set_buck_mode(struct pmic *p, int buck, char opmode) -{ - unsigned int val, ret, mask, adr, size, mode, mode_shift; - - size = ARRAY_SIZE(max77686_buck_addr); - if (buck >= size) { - printf("%s: %d is wrong buck number\n", __func__, buck); - return -EINVAL; - } - - adr = max77686_buck_addr[buck]; - - /* mask */ - switch (buck) { - case 2: - case 3: - case 4: - mode_shift = MAX77686_BUCK_MODE_SHIFT_2; - break; - default: - mode_shift = MAX77686_BUCK_MODE_SHIFT_1; - } - - mask = MAX77686_BUCK_MODE_MASK << mode_shift; - - /* mode */ - switch (opmode) { - case OPMODE_OFF: - mode = MAX77686_BUCK_MODE_OFF << mode_shift; - break; - case OPMODE_STANDBY: - switch (buck) { - case 1: - case 2: - case 3: - case 4: - mode = MAX77686_BUCK_MODE_STANDBY << mode_shift; - break; - default: - mode = 0xff; - } - break; - case OPMODE_LPM: - switch (buck) { - case 2: - case 3: - case 4: - mode = MAX77686_BUCK_MODE_LPM << mode_shift; - break; - default: - mode = 0xff; - } - break; - case OPMODE_ON: - mode = MAX77686_BUCK_MODE_ON << mode_shift; - break; - default: - mode = 0xff; - } - - if (mode == 0xff) { - printf("%s: %d is not supported on BUCK%d\n", - __func__, opmode, buck); - return -ENOTSUPP; - } - - ret = pmic_reg_read(p, adr, &val); - if (ret) - return ret; - - val &= ~mask; - val |= mode; - ret |= pmic_reg_write(p, adr, val); - - return ret; -} - -int pmic_init(unsigned char bus) -{ - static const char name[] = "MAX77686_PMIC"; - struct pmic *p = pmic_alloc(); -#if CONFIG_IS_ENABLED(OF_CONTROL) - const void *blob = gd->fdt_blob; - int node, parent, tmp; -#endif - - if (!p) { - printf("%s: POWER allocation error!\n", __func__); - return -ENOMEM; - } - -#if CONFIG_IS_ENABLED(OF_CONTROL) - node = fdtdec_next_compatible(blob, 0, COMPAT_MAXIM_MAX77686_PMIC); - if (node < 0) { - debug("PMIC: No node for PMIC Chip in device tree\n"); - debug("node = %d\n", node); - return -ENODEV; - } - - parent = fdt_parent_offset(blob, node); - if (parent < 0) { - debug("%s: Cannot find node parent\n", __func__); - return -ENODEV; - } - - /* tmp since p->bus is unsigned */ - tmp = i2c_get_bus_num_fdt(parent); - if (tmp < 0) { - debug("%s: Cannot find I2C bus\n", __func__); - return -ENODEV; - } - p->bus = tmp; - p->hw.i2c.addr = fdtdec_get_int(blob, node, "reg", 9); -#else - p->bus = bus; - p->hw.i2c.addr = MAX77686_I2C_ADDR; -#endif - - p->name = name; - p->interface = PMIC_I2C; - p->number_of_regs = MAX77686_NUM_OF_REGS; - p->hw.i2c.tx_num = 1; - - puts("Board PMIC init\n"); - - return 0; -}
On Thu, 25 Jan 2018 16:06:36 +0900 Jaehoon Chung jh80.chung@samsung.com wrote:
- Copyright (C) 2012 Samsung Electronics
- Rajeshwari Shinde rajeshwari.s@samsung.com
- switch (ldo) {
- case 1:
- case 2:
- case 6:
- case 7:
- case 8:
- case 15:
break;
- default:
return hex;
__func__, uV, ldo);
- int hex = 0;
buck);
return -EINVAL;
return hex;
- return -EINVAL;
ldo);
return -EINVAL;
- if (!hex)
return -EINVAL;
- if (ret)
return ret;
- val |= hex;
- return ret;
- int hex, ret;
__func__, buck);
return -EINVAL;
- if (hex < 0)
return hex;
- if (ret)
return ret;
- return ret;
ldo);
return -EINVAL;
- /* mode */
- switch (opmode) {
- case OPMODE_OFF:
break;
switch (ldo) {
case 2:
case 6:
case 7:
case 8:
case 10:
case 11:
case 12:
case 14:
case 15:
case 16:
break;
default:
mode = 0xff;
break;
- case OPMODE_LPM:
break;
- case OPMODE_ON:
break;
- default:
mode = 0xff;
return -ENOTSUPP;
- if (ret)
return ret;
- val |= mode;
- return ret;
buck);
return -EINVAL;
- /* mask */
- switch (buck) {
- case 2:
- case 3:
- case 4:
break;
- default:
- /* mode */
- switch (opmode) {
- case OPMODE_OFF:
break;
switch (buck) {
case 1:
case 2:
case 3:
case 4:
mode_shift;
break;
default:
mode = 0xff;
break;
- case OPMODE_LPM:
switch (buck) {
case 2:
case 3:
case 4:
break;
default:
mode = 0xff;
break;
- case OPMODE_ON:
break;
- default:
mode = 0xff;
return -ENOTSUPP;
- if (ret)
return ret;
- val &= ~mask;
- val |= mode;
- return ret;
-#endif
- if (!p) {
return -ENOMEM;
- if (node < 0) {
tree\n");
return -ENODEV;
- if (parent < 0) {
return -ENODEV;
- if (tmp < 0) {
return -ENODEV;
- p->bus = tmp;
-#else
- p->bus = bus;
-#endif
- p->name = name;
Acked-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Drop the old compatible about max77686.
Signed-off-by: Jaehoon Chung jh80.chung@samsung.com --- lib/fdtdec.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/lib/fdtdec.c b/lib/fdtdec.c index df9d9ae433..58830aa370 100644 --- a/lib/fdtdec.c +++ b/lib/fdtdec.c @@ -48,7 +48,6 @@ static const char * const compat_names[COMPAT_COUNT] = { COMPAT(SAMSUNG_EXYNOS_MIPI_DSI, "samsung,exynos-mipi-dsi"), COMPAT(SAMSUNG_EXYNOS_DWMMC, "samsung,exynos-dwmmc"), COMPAT(SAMSUNG_EXYNOS_MMC, "samsung,exynos-mmc"), - COMPAT(MAXIM_MAX77686_PMIC, "maxim,max77686"), COMPAT(GENERIC_SPI_FLASH, "spi-flash"), COMPAT(MAXIM_98095_CODEC, "maxim,max98095-codec"), COMPAT(SAMSUNG_EXYNOS5_I2C, "samsung,exynos5-hsi2c"),
On Thu, 25 Jan 2018 16:06:35 +0900 Jaehoon Chung jh80.chung@samsung.com wrote:
Reviewed-by: Lukasz Majewski lukma@denx.de
Lukasz Majewski
Jaehoon Chung
Lukasz Majewski
