[PATCH 0/4] nvmem: cell post-processing & U-Boot env MAC support
U-Boot environment variables are stored using ASCII format. One of important entries is "ethaddr" which contains base MAC address.
That NVMEM cell requires some extra processing when reading: 1. ASCII needs translating into binary MAC format 2. Final MAC needs to be calculated depending on cell index
This patchset was originally based on top of layouts implementation which sadly ended up dropped for now. To proceed I rebased it on top of the current NVMEM subsystem code. Michael's patch has applied cleanly and this approach *will not* make U-Boot env transition to layouts any harder so I believe it's fine to take those patches without waiting for layouts updated implementation.
Michael Walle (1): nvmem: core: add per-cell post processing
Rafał Miłecki (3): nvmem: core: allow nvmem_cell_post_process_t callbacks to adjust buffer dt-bindings: nvmem: u-boot,env: add MAC's #nvmem-cell-cells nvmem: u-boot-env: post-process "ethaddr" env variable
.../devicetree/bindings/nvmem/u-boot,env.yaml | 7 +++- drivers/nvmem/Kconfig | 1 + drivers/nvmem/core.c | 38 +++++++++++++++---- drivers/nvmem/imx-ocotp.c | 8 ++-- drivers/nvmem/u-boot-env.c | 25 ++++++++++++ include/linux/nvmem-provider.h | 7 +++- 6 files changed, 71 insertions(+), 15 deletions(-)
Instead of relying on the name the consumer is using for the cell, like it is done for the nvmem .cell_post_process configuration parameter, provide a per-cell post processing hook. This can then be populated by the NVMEM provider (or the NVMEM layout) when adding the cell.
Signed-off-by: Michael Walle michael@walle.cc Signed-off-by: Srinivas Kandagatla srinivas.kandagatla@linaro.org --- drivers/nvmem/core.c | 17 +++++++++++++++++ include/linux/nvmem-provider.h | 3 +++ 2 files changed, 20 insertions(+)
diff --git a/drivers/nvmem/core.c b/drivers/nvmem/core.c index 6783cd8478d7..c5c9a4654241 100644 --- a/drivers/nvmem/core.c +++ b/drivers/nvmem/core.c @@ -52,6 +52,7 @@ struct nvmem_cell_entry { int bytes; int bit_offset; int nbits; + nvmem_cell_post_process_t read_post_process; struct device_node *np; struct nvmem_device *nvmem; struct list_head node; @@ -465,6 +466,7 @@ static int nvmem_cell_info_to_nvmem_cell_entry_nodup(struct nvmem_device *nvmem, cell->offset = info->offset; cell->bytes = info->bytes; cell->name = info->name; + cell->read_post_process = info->read_post_process;
cell->bit_offset = info->bit_offset; cell->nbits = info->nbits; @@ -1429,6 +1431,13 @@ static int __nvmem_cell_read(struct nvmem_device *nvmem, if (cell->bit_offset || cell->nbits) nvmem_shift_read_buffer_in_place(cell, buf);
+ if (cell->read_post_process) { + rc = cell->read_post_process(nvmem->priv, id, index, + cell->offset, buf, cell->bytes); + if (rc) + return rc; + } + if (nvmem->cell_post_process) { rc = nvmem->cell_post_process(nvmem->priv, id, index, cell->offset, buf, cell->bytes); @@ -1537,6 +1546,14 @@ static int __nvmem_cell_entry_write(struct nvmem_cell_entry *cell, void *buf, si (cell->bit_offset == 0 && len != cell->bytes)) return -EINVAL;
+ /* + * Any cells which have a read_post_process hook are read-only because + * we cannot reverse the operation and it might affect other cells, + * too. + */ + if (cell->read_post_process) + return -EINVAL; + if (cell->bit_offset || cell->nbits) { buf = nvmem_cell_prepare_write_buffer(cell, buf, len); if (IS_ERR(buf)) diff --git a/include/linux/nvmem-provider.h b/include/linux/nvmem-provider.h index b3c14ce87a65..f87fd64eee8f 100644 --- a/include/linux/nvmem-provider.h +++ b/include/linux/nvmem-provider.h @@ -54,6 +54,8 @@ struct nvmem_keepout { * @bit_offset: Bit offset if cell is smaller than a byte. * @nbits: Number of bits. * @np: Optional device_node pointer. + * @read_post_process: Callback for optional post processing of cell data + * on reads. */ struct nvmem_cell_info { const char *name; @@ -62,6 +64,7 @@ struct nvmem_cell_info { unsigned int bit_offset; unsigned int nbits; struct device_node *np; + nvmem_cell_post_process_t read_post_process; };
Sometimes reading NVMEM cell value involves some data reformatting. it may require resizing available buffer. Support that.
It's required e.g. to provide properly formatted MAC address in case it's stored in a non-binary format (e.g. using ASCII).
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- drivers/nvmem/core.c | 23 ++++++++++++++--------- drivers/nvmem/imx-ocotp.c | 8 ++++---- include/linux/nvmem-provider.h | 4 ++-- 3 files changed, 20 insertions(+), 15 deletions(-)
diff --git a/drivers/nvmem/core.c b/drivers/nvmem/core.c index c5c9a4654241..18fbfbf61ec3 100644 --- a/drivers/nvmem/core.c +++ b/drivers/nvmem/core.c @@ -1418,35 +1418,36 @@ static void nvmem_shift_read_buffer_in_place(struct nvmem_cell_entry *cell, void
static int __nvmem_cell_read(struct nvmem_device *nvmem, struct nvmem_cell_entry *cell, - void *buf, size_t *len, const char *id, int index) + void **buf, size_t *len, const char *id, int index) { + size_t bytes = cell->bytes; int rc;
- rc = nvmem_reg_read(nvmem, cell->offset, buf, cell->bytes); + rc = nvmem_reg_read(nvmem, cell->offset, *buf, bytes);
if (rc) return rc;
/* shift bits in-place */ if (cell->bit_offset || cell->nbits) - nvmem_shift_read_buffer_in_place(cell, buf); + nvmem_shift_read_buffer_in_place(cell, *buf);
if (cell->read_post_process) { rc = cell->read_post_process(nvmem->priv, id, index, - cell->offset, buf, cell->bytes); + cell->offset, buf, &bytes); if (rc) return rc; }
if (nvmem->cell_post_process) { rc = nvmem->cell_post_process(nvmem->priv, id, index, - cell->offset, buf, cell->bytes); + cell->offset, buf, &bytes); if (rc) return rc; }
if (len) - *len = cell->bytes; + *len = bytes;
return 0; } @@ -1464,7 +1465,7 @@ static int __nvmem_cell_read(struct nvmem_device *nvmem, void *nvmem_cell_read(struct nvmem_cell *cell, size_t *len) { struct nvmem_device *nvmem = cell->entry->nvmem; - u8 *buf; + void *buf; int rc;
if (!nvmem) @@ -1474,7 +1475,7 @@ void *nvmem_cell_read(struct nvmem_cell *cell, size_t *len) if (!buf) return ERR_PTR(-ENOMEM);
- rc = __nvmem_cell_read(nvmem, cell->entry, buf, len, cell->id, cell->index); + rc = __nvmem_cell_read(nvmem, cell->entry, &buf, len, cell->id, cell->index); if (rc) { kfree(buf); return ERR_PTR(rc); @@ -1791,11 +1792,15 @@ ssize_t nvmem_device_cell_read(struct nvmem_device *nvmem, if (!nvmem) return -EINVAL;
+ /* Cells with read_post_process hook may realloc buffer we can't allow here */ + if (info->read_post_process) + return -EINVAL; + rc = nvmem_cell_info_to_nvmem_cell_entry_nodup(nvmem, info, &cell); if (rc) return rc;
- rc = __nvmem_cell_read(nvmem, &cell, buf, &len, NULL, 0); + rc = __nvmem_cell_read(nvmem, &cell, &buf, &len, NULL, 0); if (rc) return rc;
diff --git a/drivers/nvmem/imx-ocotp.c b/drivers/nvmem/imx-ocotp.c index e37a82f98ba6..0e0ab27cbfe3 100644 --- a/drivers/nvmem/imx-ocotp.c +++ b/drivers/nvmem/imx-ocotp.c @@ -223,18 +223,18 @@ static int imx_ocotp_read(void *context, unsigned int offset, }
static int imx_ocotp_cell_pp(void *context, const char *id, int index, - unsigned int offset, void *data, size_t bytes) + unsigned int offset, void **data, size_t *bytes) { struct ocotp_priv *priv = context;
/* Deal with some post processing of nvmem cell data */ if (id && !strcmp(id, "mac-address")) { if (priv->params->reverse_mac_address) { - u8 *buf = data; + u8 *buf = *data; int i;
- for (i = 0; i < bytes/2; i++) - swap(buf[i], buf[bytes - i - 1]); + for (i = 0; i < *bytes / 2; i++) + swap(buf[i], buf[*bytes - i - 1]); } }
diff --git a/include/linux/nvmem-provider.h b/include/linux/nvmem-provider.h index f87fd64eee8f..9c212f7bb7d1 100644 --- a/include/linux/nvmem-provider.h +++ b/include/linux/nvmem-provider.h @@ -19,8 +19,8 @@ typedef int (*nvmem_reg_read_t)(void *priv, unsigned int offset, typedef int (*nvmem_reg_write_t)(void *priv, unsigned int offset, void *val, size_t bytes); /* used for vendor specific post processing of cell data */ -typedef int (*nvmem_cell_post_process_t)(void *priv, const char *id, int index, - unsigned int offset, void *buf, size_t bytes); +typedef int (*nvmem_cell_post_process_t)(void *priv, const char *id, int index, unsigned int offset, + void **buf, size_t *bytes);
enum nvmem_type { NVMEM_TYPE_UNKNOWN = 0,
- /* Cells with read_post_process hook may realloc buffer we can't allow here */
- if (info->read_post_process)
return -EINVAL;
This should probably go in 1/4 patch. Other than that series looks good to me.
--srini
Hi Srinivas,
srinivas.kandagatla@linaro.org wrote on Thu, 9 Mar 2023 10:12:24 +0000:
return -EINVAL;
FYI patch 1/4 is also carried by the nvmem-layouts series, so it's probably best to keep these 2 patches separated to simplify the merging.
Thanks, Miquèl
On 09/03/2023 10:32, Miquel Raynal wrote:
Hi Srinivas,
return -EINVAL;
that is intermediate thing, but Ideally this change belongs to 1/4 patch, so once I apply these patches then we can always rebase layout series on top of nvmem-next
--srini
Thanks, Miquèl
Hi Srinivas,
srinivas.kandagatla@linaro.org wrote on Thu, 9 Mar 2023 10:53:07 +0000:
Hi Srinivas,
return -EINVAL;
Well, I still don't see the need for this patch because we have no use for it *after* the introduction of layouts. Yes in some cases changing the size of a cell might maybe be needed, but right now the use case is to provide a MAC address, we know beforehand the size of the cell, so there is no need, currently, for this hack.
Whatever. If you want it, just merge it. But *please*, I would like to see these layouts in, so what's the plan?
Thanks, Miquèl
On 09/03/2023 11:23, Miquel Raynal wrote:
Hi Srinivas,
Hi Srinivas,
@@ -1791,11 +1792,15 @@ ssize_t nvmem_device_cell_read(struct nvmem_device *nvmem, if (!nvmem) return -EINVAL; > + /* Cells with read_post_process hook may realloc buffer we can't allow here */
return -EINVAL;
Am confused, should I ignore this series ?
Am on it, you sent v3 just 24hrs ago :-)
--srini
Thanks, Miquèl
Hi Srinivas,
Hi Srinivas,
return -EINVAL;
I'm confused no less.
I think we have 3 different opinions and no agreement on how to proceed.
Rafał (me): NVMEM cells should be registered as they are in the raw format. No size adjustments should happen while registering them. If NVMEM cell requires some read post-processing then its size should be adjusted *while* reading.
Michael: .read_post_process() should be realloc the buffer
Miquel: While registering NVMEM cell its size should be already adjusted to match what .read_post_process() is about to return.
I'm really sorry if I got anyone's view wrong.
Hello,
rafal@milecki.pl wrote on Thu, 09 Mar 2023 12:52:37 +0100:
Hi Srinivas,
srinivas.kandagatla@linaro.org wrote on Thu, 9 Mar 2023 10:53:07 >> +0000:
Hi Srinivas,
>>> srinivas.kandagatla@linaro.org wrote on Thu, 9 Mar 2023 10:12:24 >>>> +0000: >>>> On 22/02/2023 17:22, Rafał Miłecki wrote: > @@ -1791,11 +1792,15 @@ ssize_t nvmem_device_cell_read(struct >>>>>> nvmem_device *nvmem, > if (!nvmem) > return -EINVAL; > > + /* Cells with read_post_process hook may realloc buffer we >>>>>> can't allow here */ > + if (info->read_post_process) > + return -EINVAL; This should probably go in 1/4 patch. Other than that series looks >>>>> good to me. >>> FYI patch 1/4 is also carried by the nvmem-layouts series, so it's
probably best to keep these 2 patches separated to simplify the >>>> merging.
that is intermediate thing, but Ideally this change belongs to 1/4 >>> patch, so once I apply these patches then we can always rebase layout >>> series on top of nvmem-next
for it *after* the introduction of layouts. Yes in some cases changing the size of a cell might maybe be needed, but right now the use case >> is to provide a MAC address, we know beforehand the size of the cell, so there is no need, currently, for this hack.
I think this series makes sense and addresses a need. But this issue can also be solved with the layouts. Rafał does not want (I still don't get the reason) to use that solution. Whatever. But if you apply this series, it requires to modify the layouts series, thus postponing it even more. I would prefer to merge that big series first and then merge an update of this patch (which changes in the two layout drivers the cell size argument type).
This implementation only works if you reduce the size of the cell.
While writing this, I am realizing that we would actually expect a check on the nvmem side if the size was enlarged because this would be a bug.
This would be more robust. But if we start with 1, we can improve it later, I don't mind as long as an error is returned in case of misuse.
Sounds like the simplest solution to me and covers all the uses we have to day, but honestly, I won't fight for it.
LGTM.
Yes, sorry for being pushy. I just wanted to highlight that the two series conflict together, but my answer was clumsy. Take the time you need, that's how it's supposed to work anyway.
Thanks, Miquèl
On 2023-03-09 14:10, Miquel Raynal wrote:
Hello,
Hi Srinivas,
srinivas.kandagatla@linaro.org wrote on Thu, 9 Mar 2023 10:53:07 >> +0000: > On 09/03/2023 10:32, Miquel Raynal wrote: Hi Srinivas, >>>> srinivas.kandagatla@linaro.org wrote on Thu, 9 Mar 2023 10:12:24 >>>> +0000: >>>>> On 22/02/2023 17:22, Rafał Miłecki wrote: >> @@ -1791,11 +1792,15 @@ ssize_t nvmem_device_cell_read(struct >>>>>> nvmem_device *nvmem, >> if (!nvmem) >> return -EINVAL; >> > + /* Cells with read_post_process hook may realloc buffer we >>>>>> can't allow here */ >> + if (info->read_post_process) >> + return -EINVAL; > This should probably go in 1/4 patch. Other than that series looks >>>>> good to me. >>>> FYI patch 1/4 is also carried by the nvmem-layouts series, so it's probably best to keep these 2 patches separated to simplify the >>>> merging.
I'm going to argue those are two independent things.
I can add .read_post_process() without making this driver a layout. I can make it layout without adding .read_post_process().
I said multiple time that I AM GOING to convert this driver into a layout.
Which is enough for MAC. And I was asked to use simple solution. I also was asked to support reallocationg which was the reason for my rework.
LGTM.
AFAIR there is a minor conflict caused by the API change that allows reallocations. I decided to rebase my patchwork because Michael claimed it's going to take at least few more weeks to rework layouts patchset.
Now we have layouts patchset ready anyway and I'll have to rebase again. Well, few more wasted hours, shouldn't make much difference.
This is the behavior that I would expect, this is one time thing and cell sizes should be fixed before adding them.
--srini
U-Boot's "ethaddr" environment variable is very often used to store *base* MAC address. It's used as a base for calculating addresses for multiple interfaces. It's done by adding proper values. Actual offsets are picked by manufacturers and vary across devices.
Signed-off-by: Rafał Miłecki rafal@milecki.pl Reviewed-by: Rob Herring robh@kernel.org --- Documentation/devicetree/bindings/nvmem/u-boot,env.yaml | 7 ++++++- 1 file changed, 6 insertions(+), 1 deletion(-)
diff --git a/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml b/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml index cbc5c69fd405..36d97fb87865 100644 --- a/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml +++ b/Documentation/devicetree/bindings/nvmem/u-boot,env.yaml @@ -50,7 +50,11 @@ properties:
ethaddr: type: object - description: Ethernet interface's MAC address + description: Ethernet interfaces base MAC address. + properties: + "#nvmem-cell-cells": + description: The first argument is a MAC address offset. + const: 1
additionalProperties: false
@@ -72,6 +76,7 @@ examples: reg = <0x40000 0x10000>;
mac: ethaddr { + #nvmem-cell-cells = <1>; }; }; };
U-Boot environment variables are stored in ASCII format so "ethaddr" requires parsing into binary to make it work with Ethernet interfaces.
This includes support for indexes to support #nvmem-cell-cells = <1>.
Signed-off-by: Rafał Miłecki rafal@milecki.pl --- drivers/nvmem/Kconfig | 1 + drivers/nvmem/u-boot-env.c | 25 +++++++++++++++++++++++++ 2 files changed, 26 insertions(+)
diff --git a/drivers/nvmem/Kconfig b/drivers/nvmem/Kconfig index 189ea85bd67d..71322ea7cf53 100644 --- a/drivers/nvmem/Kconfig +++ b/drivers/nvmem/Kconfig @@ -346,6 +346,7 @@ config NVMEM_U_BOOT_ENV tristate "U-Boot environment variables support" depends on OF && MTD select CRC32 + select GENERIC_NET_UTILS help U-Boot stores its setup as environment variables. This driver adds support for verifying & exporting such data. It also exposes variables diff --git a/drivers/nvmem/u-boot-env.c b/drivers/nvmem/u-boot-env.c index 29b1d87a3c51..1f5d8aba98bf 100644 --- a/drivers/nvmem/u-boot-env.c +++ b/drivers/nvmem/u-boot-env.c @@ -4,6 +4,8 @@ */
#include <linux/crc32.h> +#include <linux/etherdevice.h> +#include <linux/if_ether.h> #include <linux/mod_devicetable.h> #include <linux/module.h> #include <linux/mtd/mtd.h> @@ -70,6 +72,27 @@ static int u_boot_env_read(void *context, unsigned int offset, void *val, return 0; }
+static int u_boot_env_read_post_process_ethaddr(void *context, const char *id, int index, + unsigned int offset, void **data, size_t *bytes) +{ + u8 mac[ETH_ALEN]; + + if (*bytes != 3 * ETH_ALEN - 1) + return -EINVAL; + + if (!mac_pton(*data, mac)) + return -EINVAL; + + if (index) + eth_addr_add(mac, index); + + /* We need *smaller* buffer so don't bother to krealloc() */ + ether_addr_copy(*data, mac); + *bytes = ETH_ALEN; + + return 0; +} + static int u_boot_env_add_cells(struct u_boot_env *priv, uint8_t *buf, size_t data_offset, size_t data_len) { @@ -101,6 +124,8 @@ static int u_boot_env_add_cells(struct u_boot_env *priv, uint8_t *buf, priv->cells[idx].offset = data_offset + value - data; priv->cells[idx].bytes = strlen(value); priv->cells[idx].np = of_get_child_by_name(dev->of_node, priv->cells[idx].name); + if (!strcmp(var, "ethaddr")) + priv->cells[idx].read_post_process = u_boot_env_read_post_process_ethaddr; }
if (WARN_ON(idx != priv->ncells))
Miquel Raynal
Rafał Miłecki
Rafał Miłecki
Srinivas Kandagatla
