[U-Boot] [PATCH v4] spl: add support to booting with ATF
ATF(ARM Trusted Firmware) is used by ARM arch64 SoCs, find more infomation about ATF at: https://github.com/ARM-software/arm-trusted-firmware
SPL is considered as BL2 in ATF terminology, it needs to load other parts of ATF binary like BL31, BL32, SCP-BL30, and BL33(U-Boot). And needs to prepare the parameter for BL31 which including entry and image information for all other images. Then the SPL handle PC to BL31 with the parameter, the BL31 will do the rest of work and at last get into U-Boot(BL33).
This patch needs work with patches from Andre for SPL support multi binary in FIT.
The entry point of bl31 and bl33 are still using hard code because we still can not get them from the FIT image information.
Signed-off-by: Kever Yang kever.yang@rock-chips.com ---
Changes in v4: - fix description in Kconfig - add debug log before get into ATF BL31 - remove '_t' postfix for structure define
Changes in v3: - remove no neccessary Macro definition in header file. - rename some Macro with 'ATF_' prefix.
Changes in v2: - Kconfig comment update with Simon's suggestion - including file ordering, - update function comment format, - use 'if' instead of '#ifdef' for bl31_entry - add ATF Kconfig option depend on ARM64
Changes in v1: - license update - split out as separate patch
common/spl/Kconfig | 14 ++++ common/spl/Makefile | 1 + common/spl/spl.c | 5 ++ common/spl/spl_atf.c | 97 +++++++++++++++++++++++++++ include/atf_common.h | 183 +++++++++++++++++++++++++++++++++++++++++++++++++++ include/spl.h | 1 + 6 files changed, 301 insertions(+) create mode 100644 common/spl/spl_atf.c create mode 100644 include/atf_common.h
diff --git a/common/spl/Kconfig b/common/spl/Kconfig index ea6fbb6..90c3c38 100644 --- a/common/spl/Kconfig +++ b/common/spl/Kconfig @@ -688,6 +688,20 @@ config SPL_YMODEM_SUPPORT means of transmitting U-Boot over a serial line for using in SPL, with a checksum to ensure correctness.
+config SPL_ATF_SUPPORT + bool "Support ARM Trusted Firmware" + depends on SPL && ARM64 + help + ATF(ARM Trusted Firmware) is a component for ARM arch64 which which + is loaded by SPL(which is considered as BL2 in ATF terminology). + More detail at: https://github.com/ARM-software/arm-trusted-firmware + +config SPL_ATF_TEXT_BASE + depends on SPL_ATF_SUPPORT + hex "ATF BL31 base address" + help + This is the base address in memory for ATF BL31 text and entry point. + config TPL_ENV_SUPPORT bool "Support an environment" depends on TPL diff --git a/common/spl/Makefile b/common/spl/Makefile index 1933cbd..b3b34d6 100644 --- a/common/spl/Makefile +++ b/common/spl/Makefile @@ -20,6 +20,7 @@ endif obj-$(CONFIG_SPL_UBI) += spl_ubi.o obj-$(CONFIG_SPL_NET_SUPPORT) += spl_net.o obj-$(CONFIG_SPL_MMC_SUPPORT) += spl_mmc.o +obj-$(CONFIG_SPL_ATF_SUPPORT) += spl_atf.o obj-$(CONFIG_SPL_USB_SUPPORT) += spl_usb.o obj-$(CONFIG_SPL_FAT_SUPPORT) += spl_fat.o obj-$(CONFIG_SPL_EXT_SUPPORT) += spl_ext.o diff --git a/common/spl/spl.c b/common/spl/spl.c index a3e73b8..97f1163 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -372,6 +372,11 @@ void board_init_r(gd_t *dummy1, ulong dummy2) gd->malloc_ptr / 1024); #endif
+ if (IS_ENABLED(CONFIG_SPL_ATF_SUPPORT)) { + debug("loaded - jumping to U-Boot via ATF BL31.\n"); + bl31_entry(); + } + debug("loaded - jumping to U-Boot...\n"); spl_board_prepare_for_boot(); jump_to_image_no_args(&spl_image); diff --git a/common/spl/spl_atf.c b/common/spl/spl_atf.c new file mode 100644 index 0000000..6e8f928 --- /dev/null +++ b/common/spl/spl_atf.c @@ -0,0 +1,97 @@ +/* + * Reference to the ARM TF Project, + * plat/arm/common/arm_bl2_setup.c + * Portions copyright (c) 2013-2016, ARM Limited and Contributors. All rights + * reserved. + * Copyright (C) 2016 Rockchip Electronic Co.,Ltd + * Written by Kever Yang kever.yang@rock-chips.com + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#include <common.h> +#include <atf_common.h> +#include <errno.h> +#include <spl.h> + +static struct bl2_to_bl31_params_mem bl31_params_mem; +static struct bl31_params *bl2_to_bl31_params; + +/** + * bl2_plat_get_bl31_params() - prepare params for bl31. + * + * This function assigns a pointer to the memory that the platform has kept + * aside to pass platform specific and trusted firmware related information + * to BL31. This memory is allocated by allocating memory to + * bl2_to_bl31_params_mem structure which is a superset of all the + * structure whose information is passed to BL31 + * NOTE: This function should be called only once and should be done + * before generating params to BL31 + * + * @return bl31 params structure pointer + */ +struct bl31_params *bl2_plat_get_bl31_params(void) +{ + struct entry_point_info *bl33_ep_info; + + /* + * Initialise the memory for all the arguments that needs to + * be passed to BL31 + */ + memset(&bl31_params_mem, 0, sizeof(struct bl2_to_bl31_params_mem)); + + /* Assign memory for TF related information */ + bl2_to_bl31_params = &bl31_params_mem.bl31_params; + SET_PARAM_HEAD(bl2_to_bl31_params, ATF_PARAM_BL31, ATF_VERSION_1, 0); + + /* Fill BL31 related information */ + SET_PARAM_HEAD(bl2_to_bl31_params->bl31_image_info, + ATF_PARAM_IMAGE_BINARY, ATF_VERSION_1, 0); + + /* Fill BL32 related information if it exists */ +#ifdef BL32_BASE + bl2_to_bl31_params->bl32_ep_info = &bl31_params_mem.bl32_ep_info; + SET_PARAM_HEAD(bl2_to_bl31_params->bl32_ep_info, ATF_PARAM_EP, + ATF_VERSION_1, 0); + bl2_to_bl31_params->bl32_image_info = &bl31_params_mem.bl32_image_info; + SET_PARAM_HEAD(bl2_to_bl31_params->bl32_image_info, + ATF_PARAM_IMAGE_BINARY, ATF_VERSION_1, 0); +#endif /* BL32_BASE */ + + /* Fill BL33 related information */ + bl2_to_bl31_params->bl33_ep_info = &bl31_params_mem.bl33_ep_info; + bl33_ep_info = &bl31_params_mem.bl33_ep_info; + SET_PARAM_HEAD(bl33_ep_info, ATF_PARAM_EP, ATF_VERSION_1, + ATF_EP_NON_SECURE); + + /* BL33 expects to receive the primary CPU MPID (through x0) */ + bl33_ep_info->args.arg0 = 0xffff & read_mpidr(); + bl33_ep_info->pc = CONFIG_SYS_TEXT_BASE; + bl33_ep_info->spsr = SPSR_64(MODE_EL2, MODE_SP_ELX, + DISABLE_ALL_EXECPTIONS); + + bl2_to_bl31_params->bl33_image_info = &bl31_params_mem.bl33_image_info; + SET_PARAM_HEAD(bl2_to_bl31_params->bl33_image_info, + ATF_PARAM_IMAGE_BINARY, ATF_VERSION_1, 0); + + return bl2_to_bl31_params; +} + +void raw_write_daif(unsigned int daif) +{ + __asm__ __volatile__("msr DAIF, %0\n\t" : : "r" (daif) : "memory"); +} + +void bl31_entry(void) +{ + struct bl31_params *bl31_params; + void (*entry)(struct bl31_params *params, void *plat_params) = NULL; + + bl31_params = bl2_plat_get_bl31_params(); + entry = (void *)CONFIG_SPL_ATF_TEXT_BASE; + + raw_write_daif(SPSR_EXCEPTION_MASK); + dcache_disable(); + + entry(bl31_params, NULL); +} diff --git a/include/atf_common.h b/include/atf_common.h new file mode 100644 index 0000000..8c513e7 --- /dev/null +++ b/include/atf_common.h @@ -0,0 +1,183 @@ +/* + * This is from the ARM TF Project, + * Repository: https://github.com/ARM-software/arm-trusted-firmware.git + * File: include/common/bl_common.h + * Portions copyright (c) 2013-2016, ARM Limited and Contributors. All rights + * reserved. + * Copyright (C) 2016-2017 Rockchip Electronic Co.,Ltd + * + * SPDX-License-Identifier: BSD-3-Clause + */ + +#ifndef __BL_COMMON_H__ +#define __BL_COMMON_H__ + +#define ATF_PARAM_EP 0x01 +#define ATF_PARAM_IMAGE_BINARY 0x02 +#define ATF_PARAM_BL31 0x03 + +#define ATF_VERSION_1 0x01 + +#define ATF_EP_SECURE 0x0 +#define ATF_EP_NON_SECURE 0x1 + +#define SET_PARAM_HEAD(_p, _type, _ver, _attr) do { \ + (_p)->h.type = (uint8_t)(_type); \ + (_p)->h.version = (uint8_t)(_ver); \ + (_p)->h.size = (uint16_t)sizeof(*_p); \ + (_p)->h.attr = (uint32_t)(_attr) ; \ + } while (0) + +#define MODE_RW_SHIFT 0x4 +#define MODE_RW_MASK 0x1 +#define MODE_RW_64 0x0 +#define MODE_RW_32 0x1 + +#define MODE_EL_SHIFT 0x2 +#define MODE_EL_MASK 0x3 +#define MODE_EL3 0x3 +#define MODE_EL2 0x2 +#define MODE_EL1 0x1 +#define MODE_EL0 0x0 + +#define MODE_SP_SHIFT 0x0 +#define MODE_SP_MASK 0x1 +#define MODE_SP_EL0 0x0 +#define MODE_SP_ELX 0x1 + +#define SPSR_DAIF_SHIFT 6 +#define SPSR_DAIF_MASK 0x0f + +#define SPSR_64(el, sp, daif) \ + (MODE_RW_64 << MODE_RW_SHIFT | \ + ((el) & MODE_EL_MASK) << MODE_EL_SHIFT | \ + ((sp) & MODE_SP_MASK) << MODE_SP_SHIFT | \ + ((daif) & SPSR_DAIF_MASK) << SPSR_DAIF_SHIFT) + +#define SPSR_FIQ (1 << 6) +#define SPSR_IRQ (1 << 7) +#define SPSR_SERROR (1 << 8) +#define SPSR_DEBUG (1 << 9) +#define SPSR_EXCEPTION_MASK (SPSR_FIQ | SPSR_IRQ | SPSR_SERROR | SPSR_DEBUG) + +#define DAIF_FIQ_BIT (1<<0) +#define DAIF_IRQ_BIT (1<<1) +#define DAIF_ABT_BIT (1<<2) +#define DAIF_DBG_BIT (1<<3) +#define DISABLE_ALL_EXECPTIONS \ + (DAIF_FIQ_BIT | DAIF_IRQ_BIT | DAIF_ABT_BIT | DAIF_DBG_BIT) + +#ifndef __ASSEMBLY__ + +/******************************************************************************* + * Structure used for telling the next BL how much of a particular type of + * memory is available for its use and how much is already used. + ******************************************************************************/ +struct aapcs64_params { + unsigned long arg0; + unsigned long arg1; + unsigned long arg2; + unsigned long arg3; + unsigned long arg4; + unsigned long arg5; + unsigned long arg6; + unsigned long arg7; +}; + +/*************************************************************************** + * This structure provides version information and the size of the + * structure, attributes for the structure it represents + ***************************************************************************/ +struct param_header { + uint8_t type; /* type of the structure */ + uint8_t version; /* version of this structure */ + uint16_t size; /* size of this structure in bytes */ + uint32_t attr; /* attributes: unused bits SBZ */ +}; + +/***************************************************************************** + * This structure represents the superset of information needed while + * switching exception levels. The only two mechanisms to do so are + * ERET & SMC. Security state is indicated using bit zero of header + * attribute + * NOTE: BL1 expects entrypoint followed by spsr at an offset from the start + * of this structure defined by the macro `ENTRY_POINT_INFO_PC_OFFSET` while + * processing SMC to jump to BL31. + *****************************************************************************/ +struct entry_point_info { + struct param_header h; + uintptr_t pc; + uint32_t spsr; + struct aapcs64_params args; +}; + +/***************************************************************************** + * Image info binary provides information from the image loader that + * can be used by the firmware to manage available trusted RAM. + * More advanced firmware image formats can provide additional + * information that enables optimization or greater flexibility in the + * common firmware code + *****************************************************************************/ +struct atf_image_info { + struct param_header h; + uintptr_t image_base; /* physical address of base of image */ + uint32_t image_size; /* bytes read from image file */ +}; + +/***************************************************************************** + * The image descriptor struct definition. + *****************************************************************************/ +struct image_desc { + /* Contains unique image id for the image. */ + unsigned int image_id; + /* + * This member contains Image state information. + * Refer IMAGE_STATE_XXX defined above. + */ + unsigned int state; + uint32_t copied_size; /* image size copied in blocks */ + struct atf_image_info atf_image_info; + struct entry_point_info ep_info; +}; + +/******************************************************************************* + * This structure represents the superset of information that can be passed to + * BL31 e.g. while passing control to it from BL2. The BL32 parameters will be + * populated only if BL2 detects its presence. A pointer to a structure of this + * type should be passed in X0 to BL31's cold boot entrypoint. + * + * Use of this structure and the X0 parameter is not mandatory: the BL31 + * platform code can use other mechanisms to provide the necessary information + * about BL32 and BL33 to the common and SPD code. + * + * BL31 image information is mandatory if this structure is used. If either of + * the optional BL32 and BL33 image information is not provided, this is + * indicated by the respective image_info pointers being zero. + ******************************************************************************/ +struct bl31_params { + struct param_header h; + struct atf_image_info *bl31_image_info; + struct entry_point_info *bl32_ep_info; + struct atf_image_info *bl32_image_info; + struct entry_point_info *bl33_ep_info; + struct atf_image_info *bl33_image_info; +}; + +/******************************************************************************* + * This structure represents the superset of information that is passed to + * BL31, e.g. while passing control to it from BL2, bl31_params + * and other platform specific params + ******************************************************************************/ +struct bl2_to_bl31_params_mem { + struct bl31_params bl31_params; + struct atf_image_info bl31_image_info; + struct atf_image_info bl32_image_info; + struct atf_image_info bl33_image_info; + struct entry_point_info bl33_ep_info; + struct entry_point_info bl32_ep_info; + struct entry_point_info bl31_ep_info; +}; + +#endif /*__ASSEMBLY__*/ + +#endif /* __BL_COMMON_H__ */ diff --git a/include/spl.h b/include/spl.h index 2e5b885..387054d 100644 --- a/include/spl.h +++ b/include/spl.h @@ -268,4 +268,5 @@ int spl_dfu_cmd(int usbctrl, char *dfu_alt_info, char *interface, char *devstr); int spl_mmc_load_image(struct spl_image_info *spl_image, struct spl_boot_device *bootdev);
+void bl31_entry(void); #endif
Am Freitag, 5. Mai 2017, 11:47:45 CEST schrieb Kever Yang:
On a rk3399-firefly Tested-by: Heiko Stuebner heiko@sntech.de
Changes in v4:
Changes in v3:
Changes in v2:
Changes in v1:
- license update
Thanks!
Signed-off-by: Kever Yang kever.yang@rock-chips.com Tested-by: Heiko Stuebner heiko@sntech.de Acked-by: Simon Glass sjg@chromium.org Reviewed-by: Tom Rini trini@konsulko.com
Heiko Stuebner
Kever Yang
