[U-Boot] [PATCH] mx6: colibri: fix build due to missing DTB
This fix colibri (imx6) build due to:
Device Tree Source is not correctly specified. Please define 'CONFIG_DEFAULT_DEVICE_TREE' or build with 'DEVICE_TREE=<device_tree>' argument
CONFIG_DEFAULT_DEVICE_TREE is set in default config, but it is not built because the target is missing in dts/Makefile
Signed-off-by: Stefano Babic sbabic@denx.de CC: Marcel Ziswiler marcel.ziswiler@toradex.com ---
I got build error after rebasing on current Tom's master - colibri-imx6.dtb is missing from dts/Makefile.
This is to fix -next on u-boot-imx.
arch/arm/dts/Makefile | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index e67b3bd767..0b39721dbc 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -500,6 +500,9 @@ dtb-$(CONFIG_MX6Q) += \ imx6q-display5.dtb \ imx6q-logicpd.dtb
+dtb-$(CONFIG_TARGET_COLIBRI_IMX6) += \ + imx6-colibri.dtb + dtb-$(CONFIG_MX6QDL) += \ imx6dl-icore.dtb \ imx6dl-icore-mipi.dtb \
I already did send that one:
https://patchwork.ozlabs.org/patch/1064558/
I got build error after rebasing on current Tom's master - colibri- imx6.dtb is missing from dts/Makefile.
- imx6-colibri.dtb
Ouch, shame on me, I could fix it easier.
I have already fixed apalis, I put your to fix colibri. Anyway, I wonder why your board do not set the i.MX6 variant, at least colibri should set MC6DL and apalis MX6Q. This led to use the specific target (as I did) or ARCH_MX6 (as you did), but not CONFIG_MX6QDL as most boards.
Anyway, I will merge this on -next, thanks.
Regards, Stefano
- imx6-colibri.dtb
Marcel Ziswiler
Stefano Babic
