[PATCH v2 0/7] ddr: altera: arria10: Convert SDRAM driver to DM
This patchset mainly to covert Arria 10 SDRAM driver to device model and fixes few bugs in driver. It also added RAM size check function to check valid RAM.
v1->v2: - Update Patch[1] commit description - Change debug() to printf() if failed to probe SDRAM driver in SPL. [Patch 2] - Change to use MACRO(n) to calculate register address. [Patch 2] - Call to reset_assert_bulk() if failed in _probe(). [Patch 3] - Change SZ_1G to full SDRAM size in get_ram_size() argument. [Patch 5] - Patch 4, 6 and 7 unchanged.
Ley Foon Tan (7): ddr: altera: arria10: Fix incorrect address for mpu1 ddr: altera: arria10: Move SDRAM driver to DM ddr: altera: arria10: Change to use reset DM function arm: socfpga: arria10: Move sdram_arria10.h to drivers/ddr/altera ddr: altera: arria10: Add RAM size check ddr: altera: arria10: Change %i to %u for printf ddr: altera: arria10: Remove call to dram_init_banksize()
arch/arm/dts/socfpga_arria10-u-boot.dtsi | 8 + .../include/mach/reset_manager_arria10.h | 1 - arch/arm/mach-socfpga/include/mach/sdram.h | 2 +- arch/arm/mach-socfpga/misc_arria10.c | 2 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 7 - arch/arm/mach-socfpga/spl_a10.c | 14 +- drivers/ddr/altera/Kconfig | 4 +- drivers/ddr/altera/sdram_arria10.c | 382 ++++++++++-------- .../ddr/altera}/sdram_arria10.h | 225 ++--------- 9 files changed, 285 insertions(+), 360 deletions(-) rename {arch/arm/mach-socfpga/include/mach => drivers/ddr/altera}/sdram_arria10.h (72%)
SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS is added in SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET() macro already. Remove extra SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS in mpu1 address computation.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com
--- v2: - Update commit description --- drivers/ddr/altera/sdram_arria10.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index 2fd50b7ae550..e0779b810fdc 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -470,7 +470,6 @@ const struct firewall_entry firewall_table[] = { }, { "mpu1", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(mpuregion1addr), SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), ALT_NOC_FW_DDR_SCR_EN_MPUREG1EN_SET_MSK
Convert Arria 10 SDRAM driver to device model.
SPL is changed from calling function in SDRAM driver directly to just probing UCLASS_RAM.
--- v2: - Change debug() to printf() if failed to probe SDRAM driver in SPL. - Change to use MACRO(n) to calculate register address. --- arch/arm/dts/socfpga_arria10-u-boot.dtsi | 8 + .../mach-socfpga/include/mach/sdram_arria10.h | 225 +++--------- arch/arm/mach-socfpga/spl_a10.c | 14 +- drivers/ddr/altera/Kconfig | 4 +- drivers/ddr/altera/sdram_arria10.c | 334 ++++++++++-------- 5 files changed, 251 insertions(+), 334 deletions(-)
diff --git a/arch/arm/dts/socfpga_arria10-u-boot.dtsi b/arch/arm/dts/socfpga_arria10-u-boot.dtsi index 6ff1ea6e5eb7..cb576f5288ea 100644 --- a/arch/arm/dts/socfpga_arria10-u-boot.dtsi +++ b/arch/arm/dts/socfpga_arria10-u-boot.dtsi @@ -133,6 +133,14 @@ u-boot,dm-pre-reloc; };
+&sdr { + reg = <0xffcfa000 0x11C>, + <0xffcfb000 0x180>, + <0xffd12400 0x1030>; + resets = <&rst DDRSCH_RESET>; + u-boot,dm-pre-reloc; +}; + &sysmgr { u-boot,dm-pre-reloc; }; diff --git a/arch/arm/mach-socfpga/include/mach/sdram_arria10.h b/arch/arm/mach-socfpga/include/mach/sdram_arria10.h index 25b82fb28583..f150b51e4f97 100644 --- a/arch/arm/mach-socfpga/include/mach/sdram_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/sdram_arria10.h @@ -6,76 +6,46 @@ #ifndef _SOCFPGA_SDRAM_ARRIA10_H_ #define _SOCFPGA_SDRAM_ARRIA10_H_
-#ifndef __ASSEMBLY__ -int ddr_calibration_sequence(void); - -struct socfpga_ecc_hmc { - u32 ip_rev_id; - u32 _pad_0x4_0x7; - u32 ddrioctrl; - u32 ddrcalstat; - u32 mpr_0beat1; - u32 mpr_1beat1; - u32 mpr_2beat1; - u32 mpr_3beat1; - u32 mpr_4beat1; - u32 mpr_5beat1; - u32 mpr_6beat1; - u32 mpr_7beat1; - u32 mpr_8beat1; - u32 mpr_0beat2; - u32 mpr_1beat2; - u32 mpr_2beat2; - u32 mpr_3beat2; - u32 mpr_4beat2; - u32 mpr_5beat2; - u32 mpr_6beat2; - u32 mpr_7beat2; - u32 mpr_8beat2; - u32 _pad_0x58_0x5f[2]; - u32 auto_precharge; - u32 _pad_0x64_0xff[39]; - u32 eccctrl; - u32 eccctrl2; - u32 _pad_0x108_0x10f[2]; - u32 errinten; - u32 errintens; - u32 errintenr; - u32 intmode; - u32 intstat; - u32 diaginttest; - u32 modstat; - u32 derraddra; - u32 serraddra; - u32 _pad_0x134_0x137; - u32 autowb_corraddr; - u32 serrcntreg; - u32 autowb_drop_cntreg; - u32 _pad_0x144_0x147; - u32 ecc_reg2wreccdatabus; - u32 ecc_rdeccdata2regbus; - u32 ecc_reg2rdeccdatabus; - u32 _pad_0x154_0x15f[3]; - u32 ecc_diagon; - u32 ecc_decstat; - u32 _pad_0x168_0x16f[2]; - u32 ecc_errgenaddr_0; - u32 ecc_errgenaddr_1; - u32 ecc_errgenaddr_2; - u32 ecc_errgenaddr_3; -}; - -struct socfpga_noc_ddr_scheduler { - u32 ddr_t_main_scheduler_id_coreid; - u32 ddr_t_main_scheduler_id_revisionid; - u32 ddr_t_main_scheduler_ddrconf; - u32 ddr_t_main_scheduler_ddrtiming; - u32 ddr_t_main_scheduler_ddrmode; - u32 ddr_t_main_scheduler_readlatency; - u32 _pad_0x20_0x34[8]; - u32 ddr_t_main_scheduler_activate; - u32 ddr_t_main_scheduler_devtodev; -}; +/* IO48 HMC */ +#define CTRLCFG0 0x28 +#define CTRLCFG1 0x2c +#define DRAMTIMING0 0x50 +#define CALTIMING0 0x7c +#define CALTIMING1 0x80 +#define CALTIMING2 0x84 +#define CALTIMING3 0x88 +#define CALTIMING4 0x8c +#define CALTIMING9 0xa0 +#define DRAMADDRW 0xa8 +#define DRAMSTS 0xec +#define NIOSRESERVE0 0x110 +#define NIOSRESERVE1 0x114 +#define NIOSRESERVE2 0x118 + +/* HMC */ +#define DDRIOCTRL 0x8 +#define DDRCALSTAT 0xc +#define ECCCTRL1 0x100 +#define ECCCTRL2 0x104 + +/* DDR scheduler */ +#define DDRCONF 0x08 +#define DDRTIMING 0x0c +#define DDRMODE 0x10 +#define DDRREADLATENCY 0x14 +#define DDRACTIVATE 0x38 +#define DDRDEVTODEV 0x3c + +/* FW DDR MPU F2S SCR */ +#define FW_DDR_MPU_F2S_SCR_EN 0x00 +#define FW_DDR_MPU_F2S_SCR_MPUR(n) (0x10 + ((n) * 4)) +#define FW_DDR_MPU_F2S_SCR_F2S0(n) (0x20 + ((n) * 4)) +#define FW_DDR_MPU_F2S_SCR_F2S1(n) (0x30 + ((n) * 4)) +#define FW_DDR_MPU_F2S_SCR_F2S2(n) (0x40 + ((n) * 4)) + +/* FW DDR L3 DDR SCR */ +#define FW_DDR_L3_SCR_EN 0x00 +#define FW_DDR_L3_SCR_HPS(n) (0x0c + ((n) * 4))
/* * OCRAM firewall @@ -92,121 +62,6 @@ struct socfpga_noc_fw_ocram { u32 region5; };
-/* for master such as MPU and FPGA */ -struct socfpga_noc_fw_ddr_mpu_fpga2sdram { - u32 enable; - u32 enable_set; - u32 enable_clear; - u32 _pad_0xc_0xf; - u32 mpuregion0addr; - u32 mpuregion1addr; - u32 mpuregion2addr; - u32 mpuregion3addr; - u32 fpga2sdram0region0addr; - u32 fpga2sdram0region1addr; - u32 fpga2sdram0region2addr; - u32 fpga2sdram0region3addr; - u32 fpga2sdram1region0addr; - u32 fpga2sdram1region1addr; - u32 fpga2sdram1region2addr; - u32 fpga2sdram1region3addr; - u32 fpga2sdram2region0addr; - u32 fpga2sdram2region1addr; - u32 fpga2sdram2region2addr; - u32 fpga2sdram2region3addr; -}; - -/* for L3 master */ -struct socfpga_noc_fw_ddr_l3 { - u32 enable; - u32 enable_set; - u32 enable_clear; - u32 hpsregion0addr; - u32 hpsregion1addr; - u32 hpsregion2addr; - u32 hpsregion3addr; - u32 hpsregion4addr; - u32 hpsregion5addr; - u32 hpsregion6addr; - u32 hpsregion7addr; -}; - -struct socfpga_io48_mmr { - u32 dbgcfg0; - u32 dbgcfg1; - u32 dbgcfg2; - u32 dbgcfg3; - u32 dbgcfg4; - u32 dbgcfg5; - u32 dbgcfg6; - u32 reserve0; - u32 reserve1; - u32 reserve2; - u32 ctrlcfg0; - u32 ctrlcfg1; - u32 ctrlcfg2; - u32 ctrlcfg3; - u32 ctrlcfg4; - u32 ctrlcfg5; - u32 ctrlcfg6; - u32 ctrlcfg7; - u32 ctrlcfg8; - u32 ctrlcfg9; - u32 dramtiming0; - u32 dramodt0; - u32 dramodt1; - u32 sbcfg0; - u32 sbcfg1; - u32 sbcfg2; - u32 sbcfg3; - u32 sbcfg4; - u32 sbcfg5; - u32 sbcfg6; - u32 sbcfg7; - u32 caltiming0; - u32 caltiming1; - u32 caltiming2; - u32 caltiming3; - u32 caltiming4; - u32 caltiming5; - u32 caltiming6; - u32 caltiming7; - u32 caltiming8; - u32 caltiming9; - u32 caltiming10; - u32 dramaddrw; - u32 sideband0; - u32 sideband1; - u32 sideband2; - u32 sideband3; - u32 sideband4; - u32 sideband5; - u32 sideband6; - u32 sideband7; - u32 sideband8; - u32 sideband9; - u32 sideband10; - u32 sideband11; - u32 sideband12; - u32 sideband13; - u32 sideband14; - u32 sideband15; - u32 dramsts; - u32 dbgdone; - u32 dbgsignals; - u32 dbgreset; - u32 dbgmatch; - u32 counter0mask; - u32 counter1mask; - u32 counter0match; - u32 counter1match; - u32 niosreserve0; - u32 niosreserve1; - u32 niosreserve2; -}; - -#endif /*__ASSEMBLY__*/ - #define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_MASK 0x1F000000 #define IO48_MMR_CTRLCFG0_DB2_BURST_LENGTH_SHIFT 24 #define IO48_MMR_CTRLCFG0_DB1_BURST_LENGTH_MASK 0x00F80000 diff --git a/arch/arm/mach-socfpga/spl_a10.c b/arch/arm/mach-socfpga/spl_a10.c index b10be3326803..273a89876ecb 100644 --- a/arch/arm/mach-socfpga/spl_a10.c +++ b/arch/arm/mach-socfpga/spl_a10.c @@ -28,6 +28,7 @@ #include <asm/arch/fpga_manager.h> #include <mmc.h> #include <memalign.h> +#include <dm/uclass.h>
#define FPGA_BUFSIZ 16 * 1024
@@ -104,6 +105,8 @@ u32 spl_boot_mode(const u32 boot_device)
void spl_board_init(void) { + int ret; + struct udevice *dev; ALLOC_CACHE_ALIGN_BUFFER(char, buf, FPGA_BUFSIZ);
/* enable console uart printing */ @@ -127,9 +130,16 @@ void spl_board_init(void) fpgamgr_program(buf, FPGA_BUFSIZ, 0); }
+#if CONFIG_IS_ENABLED(ALTERA_SDRAM) /* If the IOSSM/full FPGA is already loaded, start DDR */ - if (is_fpgamgr_early_user_mode() || is_fpgamgr_user_mode()) - ddr_calibration_sequence(); + if (is_fpgamgr_early_user_mode() || is_fpgamgr_user_mode()) { + ret = uclass_get_device(UCLASS_RAM, 0, &dev); + if (ret) { + printf("DRAM init failed: %d\n", ret); + hang(); + } + } +#endif
if (!is_fpgamgr_user_mode()) fpgamgr_program(buf, FPGA_BUFSIZ, 0); diff --git a/drivers/ddr/altera/Kconfig b/drivers/ddr/altera/Kconfig index 8f590dc5f611..30ee884dcf47 100644 --- a/drivers/ddr/altera/Kconfig +++ b/drivers/ddr/altera/Kconfig @@ -2,7 +2,7 @@ config SPL_ALTERA_SDRAM bool "SoCFPGA DDR SDRAM driver in SPL" depends on SPL depends on TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_ARRIA10 || TARGET_SOCFPGA_STRATIX10 || TARGET_SOCFPGA_AGILEX - select RAM if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_STRATIX10 || TARGET_SOCFPGA_AGILEX - select SPL_RAM if TARGET_SOCFPGA_GEN5 || TARGET_SOCFPGA_STRATIX10 || TARGET_SOCFPGA_AGILEX + select RAM + select SPL_RAM help Enable DDR SDRAM controller for the SoCFPGA devices. diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index e0779b810fdc..5d092f1f3b73 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -5,9 +5,11 @@
#include <common.h> #include <cpu_func.h> +#include <dm.h> #include <errno.h> #include <fdtdec.h> #include <malloc.h> +#include <ram.h> #include <wait_bit.h> #include <watchdog.h> #include <asm/io.h> @@ -19,8 +21,15 @@
DECLARE_GLOBAL_DATA_PTR;
-static void sdram_mmr_init(void); -static u64 sdram_size_calc(void); +struct altera_sdram_priv { + struct ram_info info; +}; + +struct altera_sdram_platdata { + void __iomem *iohmc; + void __iomem *hmc; + void __iomem *ddr_sch; +};
/* FAWBANK - Number of Bank of a given device involved in the FAW period. */ #define ARRIA10_SDR_ACTIVATE_FAWBANK (0x1) @@ -33,27 +42,10 @@ static u64 sdram_size_calc(void); #define DDR_READ_LATENCY_DELAY 40 #define DDR_SIZE_2GB_HEX 0x80000000
-#define IO48_MMR_DRAMSTS 0xFFCFA0EC -#define IO48_MMR_NIOS2_RESERVE0 0xFFCFA110 -#define IO48_MMR_NIOS2_RESERVE1 0xFFCFA114 -#define IO48_MMR_NIOS2_RESERVE2 0xFFCFA118 - #define SEQ2CORE_MASK 0xF #define CORE2SEQ_INT_REQ 0xF #define SEQ2CORE_INT_RESP_BIT 3
-static const struct socfpga_ecc_hmc *socfpga_ecc_hmc_base = - (void *)SOCFPGA_SDR_ADDRESS; -static const struct socfpga_noc_ddr_scheduler *socfpga_noc_ddr_scheduler_base = - (void *)SOCFPGA_SDR_SCHEDULER_ADDRESS; -static const struct socfpga_noc_fw_ddr_mpu_fpga2sdram - *socfpga_noc_fw_ddr_mpu_fpga2sdram_base = - (void *)SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS; -static const struct socfpga_noc_fw_ddr_l3 *socfpga_noc_fw_ddr_l3_base = - (void *)SOCFPGA_SDR_FIREWALL_L3_ADDRESS; -static const struct socfpga_io48_mmr *socfpga_io48_mmr_base = - (void *)SOCFPGA_HMC_MMR_IO48_ADDRESS; - /* The following are the supported configurations */ static u32 ddr_config[] = { /* Chip - Row - Bank - Column Style */ @@ -111,7 +103,7 @@ static int emif_clear(void) SEQ2CORE_MASK, 0, 1000, 0); }
-static int emif_reset(void) +static int emif_reset(struct altera_sdram_platdata *plat) { u32 c2s, s2c; int ret; @@ -120,10 +112,10 @@ static int emif_reset(void) s2c = readl(DDR_REG_SEQ2CORE);
debug("c2s=%08x s2c=%08x nr0=%08x nr1=%08x nr2=%08x dst=%08x\n", - c2s, s2c, readl(IO48_MMR_NIOS2_RESERVE0), - readl(IO48_MMR_NIOS2_RESERVE1), - readl(IO48_MMR_NIOS2_RESERVE2), - readl(IO48_MMR_DRAMSTS)); + c2s, s2c, readl(plat->iohmc + NIOSRESERVE0), + readl(plat->iohmc + NIOSRESERVE1), + readl(plat->iohmc + NIOSRESERVE2), + readl(plat->iohmc + DRAMSTS));
if (s2c & SEQ2CORE_MASK) { ret = emif_clear(); @@ -153,26 +145,27 @@ static int emif_reset(void) debug("emif_reset interrupt cleared\n");
debug("nr0=%08x nr1=%08x nr2=%08x\n", - readl(IO48_MMR_NIOS2_RESERVE0), - readl(IO48_MMR_NIOS2_RESERVE1), - readl(IO48_MMR_NIOS2_RESERVE2)); + readl(plat->iohmc + NIOSRESERVE0), + readl(plat->iohmc + NIOSRESERVE1), + readl(plat->iohmc + NIOSRESERVE2));
return 0; }
-static int ddr_setup(void) +static int ddr_setup(struct altera_sdram_platdata *plat) { int i, ret;
/* Try 32 times to do a calibration */ for (i = 0; i < 32; i++) { mdelay(500); - ret = wait_for_bit_le32(&socfpga_ecc_hmc_base->ddrcalstat, - BIT(0), true, 500, false); + ret = wait_for_bit_le32((const void *)(plat->hmc + + DDRCALSTAT), BIT(0), + true, 500, false); if (!ret) return 0;
- ret = emif_reset(); + ret = emif_reset(plat); if (ret) puts("Error: Failed to reset EMIF\n"); } @@ -181,9 +174,9 @@ static int ddr_setup(void) return -EPERM; }
-static int sdram_is_ecc_enabled(void) +static int sdram_is_ecc_enabled(struct altera_sdram_platdata *plat) { - return !!(readl(&socfpga_ecc_hmc_base->eccctrl) & + return !!(readl(plat->hmc + ECCCTRL1) & ALT_ECC_HMC_OCP_ECCCTL_ECC_EN_SET_MSK); }
@@ -206,18 +199,18 @@ static void sdram_init_ecc_bits(u32 size) }
/* Function to startup the SDRAM*/ -static int sdram_startup(void) +static int sdram_startup(struct altera_sdram_platdata *plat) { /* Release NOC ddr scheduler from reset */ socfpga_reset_deassert_noc_ddr_scheduler();
/* Bringup the DDR (calibration and configuration) */ - return ddr_setup(); + return ddr_setup(plat); }
-static u64 sdram_size_calc(void) +static u64 sdram_size_calc(struct altera_sdram_platdata *plat) { - u32 dramaddrw = readl(&socfpga_io48_mmr_base->dramaddrw); + u32 dramaddrw = readl(plat->iohmc + DRAMADDRW);
u64 size = BIT(((dramaddrw & IO48_MMR_DRAMADDRW_CFG_CS_ADDR_WIDTH_MASK) >> @@ -233,7 +226,7 @@ static u64 sdram_size_calc(void) IO48_MMR_DRAMADDRW_CFG_ROW_ADDR_WIDTH_SHIFT) + (dramaddrw & IO48_MMR_DRAMADDRW_CFG_COL_ADDR_WIDTH_MASK));
- size *= (2 << (readl(&socfpga_ecc_hmc_base->ddrioctrl) & + size *= (2 << (readl(plat->hmc + DDRIOCTRL) & ALT_ECC_HMC_OCP_DDRIOCTRL_IO_SIZE_MSK));
debug("SDRAM size=%llu\n", size); @@ -242,18 +235,18 @@ static u64 sdram_size_calc(void) }
/* Function to initialize SDRAM MMR and NOC DDR scheduler*/ -static void sdram_mmr_init(void) +static void sdram_mmr_init(struct altera_sdram_platdata *plat) { u32 update_value, io48_value; - u32 ctrlcfg0 = readl(&socfpga_io48_mmr_base->ctrlcfg0); - u32 ctrlcfg1 = readl(&socfpga_io48_mmr_base->ctrlcfg1); - u32 dramaddrw = readl(&socfpga_io48_mmr_base->dramaddrw); - u32 caltim0 = readl(&socfpga_io48_mmr_base->caltiming0); - u32 caltim1 = readl(&socfpga_io48_mmr_base->caltiming1); - u32 caltim2 = readl(&socfpga_io48_mmr_base->caltiming2); - u32 caltim3 = readl(&socfpga_io48_mmr_base->caltiming3); - u32 caltim4 = readl(&socfpga_io48_mmr_base->caltiming4); - u32 caltim9 = readl(&socfpga_io48_mmr_base->caltiming9); + u32 ctrlcfg0 = readl(plat->iohmc + CTRLCFG0); + u32 ctrlcfg1 = readl(plat->iohmc + CTRLCFG1); + u32 dramaddrw = readl(plat->iohmc + DRAMADDRW); + u32 caltim0 = readl(plat->iohmc + CALTIMING0); + u32 caltim1 = readl(plat->iohmc + CALTIMING1); + u32 caltim2 = readl(plat->iohmc + CALTIMING2); + u32 caltim3 = readl(plat->iohmc + CALTIMING3); + u32 caltim4 = readl(plat->iohmc + CALTIMING4); + u32 caltim9 = readl(plat->iohmc + CALTIMING9); u32 ddrioctl;
/* @@ -270,13 +263,13 @@ static void sdram_mmr_init(void) * bit[9:6] = Minor Release # * bit[14:10] = Major Release # */ - if ((readl(&socfpga_io48_mmr_base->niosreserve1) >> 6) & 0x1FF) { - update_value = readl(&socfpga_io48_mmr_base->niosreserve0); + if ((readl(plat->iohmc + NIOSRESERVE1) >> 6) & 0x1FF) { + update_value = readl(plat->iohmc + NIOSRESERVE0); writel(((update_value & 0xFF) >> 5), - &socfpga_ecc_hmc_base->ddrioctrl); + plat->hmc + DDRIOCTRL); }
- ddrioctl = readl(&socfpga_ecc_hmc_base->ddrioctrl); + ddrioctl = readl(plat->hmc + DDRIOCTRL);
/* Set the DDR Configuration [0xFFD12400] */ io48_value = ARRIA_DDR_CONFIG( @@ -297,8 +290,7 @@ static void sdram_mmr_init(void)
update_value = match_ddr_conf(io48_value); if (update_value) - writel(update_value, - &socfpga_noc_ddr_scheduler_base->ddr_t_main_scheduler_ddrconf); + writel(update_value, plat->ddr_sch + DDRCONF);
/* * Configure DDR timing [0xFFD1240C] @@ -360,7 +352,7 @@ static void sdram_mmr_init(void) caltim0_cfg_act_to_rdwr - (ctrlcfg0_cfg_ctrl_burst_len >> 2));
- io48_value = ((((readl(&socfpga_io48_mmr_base->dramtiming0) & + io48_value = ((((readl(plat->iohmc + DRAMTIMING0) & ALT_IO48_DRAMTIME_MEM_READ_LATENCY_MASK) + 2 + 15 + (ctrlcfg0_cfg_ctrl_burst_len >> 1)) >> 1) - /* Up to here was in memory cycles so divide by 2 */ @@ -381,20 +373,18 @@ static void sdram_mmr_init(void) ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_WRTORD_LSB) | (((ddrioctl == 1) ? 1 : 0) << ALT_NOC_MPU_DDR_T_SCHED_DDRTIMING_BWRATIO_LSB)), - &socfpga_noc_ddr_scheduler_base-> - ddr_t_main_scheduler_ddrtiming); + plat->ddr_sch + DDRTIMING);
/* Configure DDR mode [0xFFD12410] [precharge = 0] */ writel(((ddrioctl ? 0 : 1) << ALT_NOC_MPU_DDR_T_SCHED_DDRMOD_BWRATIOEXTENDED_LSB), - &socfpga_noc_ddr_scheduler_base->ddr_t_main_scheduler_ddrmode); + plat->ddr_sch + DDRMODE);
/* Configure the read latency [0xFFD12414] */ - writel(((readl(&socfpga_io48_mmr_base->dramtiming0) & + writel(((readl(plat->iohmc + DRAMTIMING0) & ALT_IO48_DRAMTIME_MEM_READ_LATENCY_MASK) >> 1) + DDR_READ_LATENCY_DELAY, - &socfpga_noc_ddr_scheduler_base-> - ddr_t_main_scheduler_readlatency); + plat->ddr_sch + DDRREADLATENCY);
/* * Configuring timing values concerning activate commands @@ -406,7 +396,7 @@ static void sdram_mmr_init(void) ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAW_LSB) | (ARRIA10_SDR_ACTIVATE_FAWBANK << ALT_NOC_MPU_DDR_T_SCHED_ACTIVATE_FAWBANK_LSB)), - &socfpga_noc_ddr_scheduler_base->ddr_t_main_scheduler_activate); + plat->ddr_sch + DDRACTIVATE);
/* * Configuring timing values concerning device to device data bus @@ -418,26 +408,26 @@ static void sdram_mmr_init(void) ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSRDTOWR_LSB) | (caltim3_cfg_wr_to_rd_dc << ALT_NOC_MPU_DDR_T_SCHED_DEVTODEV_BUSWRTORD_LSB)), - &socfpga_noc_ddr_scheduler_base->ddr_t_main_scheduler_devtodev); + plat->ddr_sch + DDRDEVTODEV);
/* Enable or disable the SDRAM ECC */ if (ctrlcfg1 & IO48_MMR_CTRLCFG1_CTRL_ENABLE_ECC) { - setbits_le32(&socfpga_ecc_hmc_base->eccctrl, + setbits_le32(plat->hmc + ECCCTRL1, (ALT_ECC_HMC_OCP_ECCCTL_AWB_CNT_RST_SET_MSK | ALT_ECC_HMC_OCP_ECCCTL_CNT_RST_SET_MSK | ALT_ECC_HMC_OCP_ECCCTL_ECC_EN_SET_MSK)); - clrbits_le32(&socfpga_ecc_hmc_base->eccctrl, + clrbits_le32(plat->hmc + ECCCTRL1, (ALT_ECC_HMC_OCP_ECCCTL_AWB_CNT_RST_SET_MSK | ALT_ECC_HMC_OCP_ECCCTL_CNT_RST_SET_MSK)); - setbits_le32(&socfpga_ecc_hmc_base->eccctrl2, + setbits_le32(plat->hmc + ECCCTRL2, (ALT_ECC_HMC_OCP_ECCCTL2_RMW_EN_SET_MSK | ALT_ECC_HMC_OCP_ECCCTL2_AWB_EN_SET_MSK)); } else { - clrbits_le32(&socfpga_ecc_hmc_base->eccctrl, + clrbits_le32(plat->hmc + ECCCTRL1, (ALT_ECC_HMC_OCP_ECCCTL_AWB_CNT_RST_SET_MSK | ALT_ECC_HMC_OCP_ECCCTL_CNT_RST_SET_MSK | ALT_ECC_HMC_OCP_ECCCTL_ECC_EN_SET_MSK)); - clrbits_le32(&socfpga_ecc_hmc_base->eccctrl2, + clrbits_le32(plat->hmc + ECCCTRL2, (ALT_ECC_HMC_OCP_ECCCTL2_RMW_EN_SET_MSK | ALT_ECC_HMC_OCP_ECCCTL2_AWB_EN_SET_MSK)); } @@ -449,173 +439,156 @@ struct firewall_entry { const u32 en_addr; const u32 en_bit; }; -#define FW_MPU_FPGA_ADDRESS \ - ((const struct socfpga_noc_fw_ddr_mpu_fpga2sdram *)\ - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS)
-#define SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(ADDR) \ - (SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS + \ - offsetof(struct socfpga_noc_fw_ddr_mpu_fpga2sdram, ADDR)) +#define SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(off) \ + (SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS + (off))
-#define SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(ADDR) \ - (SOCFPGA_SDR_FIREWALL_L3_ADDRESS + \ - offsetof(struct socfpga_noc_fw_ddr_l3, ADDR)) +#define SOCFPGA_SDR_FIREWALL_L3_ADDR(off) \ + (SOCFPGA_SDR_FIREWALL_L3_ADDRESS + (off))
const struct firewall_entry firewall_table[] = { { "mpu0", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(mpuregion0addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_MPUR(0)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_MPUREG0EN_SET_MSK }, { "mpu1", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(mpuregion1addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_MPUR(1)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_MPUREG1EN_SET_MSK }, { "mpu2", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(mpuregion2addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_MPUR(2)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_MPUREG2EN_SET_MSK }, { "mpu3", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(mpuregion3addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_MPUR(3)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_MPUREG3EN_SET_MSK }, { "l3-0", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion0addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(0)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG0EN_SET_MSK }, { "l3-1", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion1addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(1)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG1EN_SET_MSK }, { "l3-2", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion2addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(2)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG2EN_SET_MSK }, { "l3-3", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion3addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(3)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG3EN_SET_MSK }, { "l3-4", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion4addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(4)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG4EN_SET_MSK }, { "l3-5", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion5addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(5)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG5EN_SET_MSK }, { "l3-6", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion6addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(6)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG6EN_SET_MSK }, { "l3-7", - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(hpsregion7addr), - SOCFPGA_SDR_FIREWALL_L3_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_HPS(7)), + SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_HPSREG7EN_SET_MSK }, { "fpga2sdram0-0", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram0region0addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S0(0)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG0EN_SET_MSK }, { "fpga2sdram0-1", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram0region1addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S0(1)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG1EN_SET_MSK }, { "fpga2sdram0-2", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram0region2addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S0(2)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG2EN_SET_MSK }, { "fpga2sdram0-3", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram0region3addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S0(3)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR0REG3EN_SET_MSK }, { "fpga2sdram1-0", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram1region0addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S1(0)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG0EN_SET_MSK }, { "fpga2sdram1-1", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram1region1addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S1(1)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG1EN_SET_MSK }, { "fpga2sdram1-2", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram1region2addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S1(2)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG2EN_SET_MSK }, { "fpga2sdram1-3", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram1region3addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S1(3)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR1REG3EN_SET_MSK }, { "fpga2sdram2-0", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram2region0addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S2(0)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG0EN_SET_MSK }, { "fpga2sdram2-1", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram2region1addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S2(1)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG1EN_SET_MSK }, { "fpga2sdram2-2", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram2region2addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S2(2)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG2EN_SET_MSK }, { "fpga2sdram2-3", - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET - (fpga2sdram2region3addr), - SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDRESS_OFFSET(enable), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_F2S2(3)), + SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN), ALT_NOC_FW_DDR_SCR_EN_F2SDR2REG3EN_SET_MSK },
@@ -636,9 +609,8 @@ static int of_sdram_firewall_setup(const void *blob) return -ENXIO;
/* set to default state */ - writel(0, &socfpga_noc_fw_ddr_mpu_fpga2sdram_base->enable); - writel(0, &socfpga_noc_fw_ddr_l3_base->enable); - + writel(0, SOCFPGA_SDR_FIREWALL_MPU_FPGA_ADDR(FW_DDR_MPU_F2S_SCR_EN)); + writel(0, SOCFPGA_SDR_FIREWALL_L3_ADDR(FW_DDR_L3_SCR_EN));
for (i = 0; i < ARRAY_SIZE(firewall_table); i++) { sprintf(name, "%s", firewall_table[i].prop_name); @@ -662,12 +634,12 @@ static int of_sdram_firewall_setup(const void *blob) return 0; }
-int ddr_calibration_sequence(void) +static int ddr_calibration_sequence(struct altera_sdram_platdata *plat) { WATCHDOG_RESET();
/* Check to see if SDRAM cal was success */ - if (sdram_startup()) { + if (sdram_startup(plat)) { puts("DDRCAL: Failed\n"); return -EPERM; } @@ -677,10 +649,10 @@ int ddr_calibration_sequence(void) WATCHDOG_RESET();
/* initialize the MMR register */ - sdram_mmr_init(); + sdram_mmr_init(plat);
/* assigning the SDRAM size */ - u64 size = sdram_size_calc(); + u64 size = sdram_size_calc(plat);
/* * If size is less than zero, this is invalid/weird value from @@ -700,8 +672,80 @@ int ddr_calibration_sequence(void) if (of_sdram_firewall_setup(gd->fdt_blob)) puts("FW: Error Configuring Firewall\n");
- if (sdram_is_ecc_enabled()) + if (sdram_is_ecc_enabled(plat)) sdram_init_ecc_bits(gd->ram_size);
return 0; } + +static int altera_sdram_ofdata_to_platdata(struct udevice *dev) +{ + struct altera_sdram_platdata *plat = dev->platdata; + fdt_addr_t addr; + + addr = dev_read_addr_index(dev, 0); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->iohmc = (void __iomem *)addr; + + addr = dev_read_addr_index(dev, 1); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->hmc = (void __iomem *)addr; + + addr = dev_read_addr_index(dev, 2); + if (addr == FDT_ADDR_T_NONE) + return -EINVAL; + plat->ddr_sch = (void __iomem *)addr; + + return 0; +} + +static int altera_sdram_probe(struct udevice *dev) +{ + struct altera_sdram_priv *priv = dev_get_priv(dev); + + if (ddr_calibration_sequence(dev->platdata) != 0) { + puts("SDRAM init failed.\n"); + goto failed; + } + + priv->info.base = gd->bd->bi_dram[0].start; + priv->info.size = gd->ram_size; + + return 0; + +failed: + return -ENODEV; +} + +static int altera_sdram_get_info(struct udevice *dev, + struct ram_info *info) +{ + struct altera_sdram_priv *priv = dev_get_priv(dev); + + info->base = priv->info.base; + info->size = priv->info.size; + + return 0; +} + +static struct ram_ops altera_sdram_ops = { + .get_info = altera_sdram_get_info, +}; + +static const struct udevice_id altera_sdram_ids[] = { + { .compatible = "altr,sdr-ctl" }, + { /* sentinel */ } +}; + +U_BOOT_DRIVER(altera_sdram) = { + .name = "altr_sdr_ctl", + .id = UCLASS_RAM, + .of_match = altera_sdram_ids, + .ops = &altera_sdram_ops, + .ofdata_to_platdata = altera_sdram_ofdata_to_platdata, + .platdata_auto_alloc_size = sizeof(struct altera_sdram_platdata), + .probe = altera_sdram_probe, + .priv_auto_alloc_size = sizeof(struct altera_sdram_priv), +};
Change to use reset DM function and remove unused socfpga_reset_deassert_noc_ddr_scheduler().
--- v2: - Call to reset_assert_bulk() if failed in _probe(). --- .../include/mach/reset_manager_arria10.h | 1 - arch/arm/mach-socfpga/reset_manager_arria10.c | 7 ----- drivers/ddr/altera/sdram_arria10.c | 26 ++++++++++--------- 3 files changed, 14 insertions(+), 20 deletions(-)
diff --git a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h index 22e4eb33de88..a0fad7c1e2fc 100644 --- a/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h +++ b/arch/arm/mach-socfpga/include/mach/reset_manager_arria10.h @@ -9,7 +9,6 @@ #include <dt-bindings/reset/altr,rst-mgr-a10.h>
void socfpga_watchdog_disable(void); -void socfpga_reset_deassert_noc_ddr_scheduler(void); int socfpga_reset_deassert_bridges_handoff(void); void socfpga_reset_deassert_osc1wd0(void); int socfpga_bridges_reset(void); diff --git a/arch/arm/mach-socfpga/reset_manager_arria10.c b/arch/arm/mach-socfpga/reset_manager_arria10.c index aa5299415a74..edfe250ec0bc 100644 --- a/arch/arm/mach-socfpga/reset_manager_arria10.c +++ b/arch/arm/mach-socfpga/reset_manager_arria10.c @@ -62,13 +62,6 @@ void socfpga_watchdog_disable(void) ALT_RSTMGR_PER1MODRST_WD0_SET_MSK); }
-/* Release NOC ddr scheduler from reset */ -void socfpga_reset_deassert_noc_ddr_scheduler(void) -{ - clrbits_le32(socfpga_get_rstmgr_addr() + RSTMGR_A10_BRGMODRST, - ALT_RSTMGR_BRGMODRST_DDRSCH_SET_MSK); -} - static int get_bridge_init_val(const void *blob, int compat_id) { int node; diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index 5d092f1f3b73..3374efaae801 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -10,19 +10,21 @@ #include <fdtdec.h> #include <malloc.h> #include <ram.h> +#include <reset.h> #include <wait_bit.h> #include <watchdog.h> #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> -#include <asm/arch/reset_manager.h> #include <asm/arch/sdram.h> +#include <dm/device_compat.h> #include <linux/kernel.h>
struct altera_sdram_priv { struct ram_info info; + struct reset_ctl_bulk resets; };
struct altera_sdram_platdata { @@ -152,7 +154,7 @@ static int emif_reset(struct altera_sdram_platdata *plat) return 0; }
-static int ddr_setup(struct altera_sdram_platdata *plat) +static int sdram_startup(struct altera_sdram_platdata *plat) { int i, ret;
@@ -198,16 +200,6 @@ static void sdram_init_ecc_bits(u32 size) dcache_disable(); }
-/* Function to startup the SDRAM*/ -static int sdram_startup(struct altera_sdram_platdata *plat) -{ - /* Release NOC ddr scheduler from reset */ - socfpga_reset_deassert_noc_ddr_scheduler(); - - /* Bringup the DDR (calibration and configuration) */ - return ddr_setup(plat); -} - static u64 sdram_size_calc(struct altera_sdram_platdata *plat) { u32 dramaddrw = readl(plat->iohmc + DRAMADDRW); @@ -703,8 +695,17 @@ static int altera_sdram_ofdata_to_platdata(struct udevice *dev)
static int altera_sdram_probe(struct udevice *dev) { + int ret; struct altera_sdram_priv *priv = dev_get_priv(dev);
+ ret = reset_get_bulk(dev, &priv->resets); + if (ret) { + dev_err(dev, "Can't get reset: %d\n", ret); + return -ENODEV; + } + + reset_deassert_bulk(&priv->resets); + if (ddr_calibration_sequence(dev->platdata) != 0) { puts("SDRAM init failed.\n"); goto failed; @@ -716,6 +717,7 @@ static int altera_sdram_probe(struct udevice *dev) return 0;
failed: + reset_assert_bulk(&priv->resets); return -ENODEV; }
Move sdram_arria10.h to drivers/ddr/altera directory. No functionality change.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- arch/arm/mach-socfpga/include/mach/sdram.h | 2 +- arch/arm/mach-socfpga/misc_arria10.c | 2 +- drivers/ddr/altera/sdram_arria10.c | 3 ++- .../include/mach => drivers/ddr/altera}/sdram_arria10.h | 0 4 files changed, 4 insertions(+), 3 deletions(-) rename {arch/arm/mach-socfpga/include/mach => drivers/ddr/altera}/sdram_arria10.h (100%)
diff --git a/arch/arm/mach-socfpga/include/mach/sdram.h b/arch/arm/mach-socfpga/include/mach/sdram.h index 79cb9e6064a2..0a52c1078b5f 100644 --- a/arch/arm/mach-socfpga/include/mach/sdram.h +++ b/arch/arm/mach-socfpga/include/mach/sdram.h @@ -10,7 +10,7 @@ #if defined(CONFIG_TARGET_SOCFPGA_GEN5) #include <asm/arch/sdram_gen5.h> #elif defined(CONFIG_TARGET_SOCFPGA_ARRIA10) -#include <asm/arch/sdram_arria10.h> +#include "../../../../../drivers/ddr/altera/sdram_arria10.h" #endif
#endif diff --git a/arch/arm/mach-socfpga/misc_arria10.c b/arch/arm/mach-socfpga/misc_arria10.c index d56349b7f3ea..1ddffaa0ac55 100644 --- a/arch/arm/mach-socfpga/misc_arria10.c +++ b/arch/arm/mach-socfpga/misc_arria10.c @@ -15,7 +15,7 @@ #include <asm/arch/pinmux.h> #include <asm/arch/reset_manager.h> #include <asm/arch/reset_manager_arria10.h> -#include <asm/arch/sdram_arria10.h> +#include <asm/arch/sdram.h> #include <asm/arch/system_manager.h> #include <asm/arch/nic301.h> #include <asm/io.h> diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index 3374efaae801..6201dc277460 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -16,10 +16,11 @@ #include <asm/io.h> #include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> -#include <asm/arch/sdram.h> #include <dm/device_compat.h> #include <linux/kernel.h>
+#include "sdram_arria10.h" + DECLARE_GLOBAL_DATA_PTR;
struct altera_sdram_priv { diff --git a/arch/arm/mach-socfpga/include/mach/sdram_arria10.h b/drivers/ddr/altera/sdram_arria10.h similarity index 100% rename from arch/arm/mach-socfpga/include/mach/sdram_arria10.h rename to drivers/ddr/altera/sdram_arria10.h
Add call to get_ram_size() function to check memory range for valid RAM.
--- v2: - Change SZ_1G to full SDRAM size in get_ram_size() argument. --- drivers/ddr/altera/sdram_arria10.c | 19 ++++++++++++++++++- 1 file changed, 18 insertions(+), 1 deletion(-)
diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index 6201dc277460..3fa34a1ae390 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -8,6 +8,7 @@ #include <dm.h> #include <errno.h> #include <fdtdec.h> +#include <hang.h> #include <malloc.h> #include <ram.h> #include <reset.h> @@ -17,7 +18,7 @@ #include <asm/arch/fpga_manager.h> #include <asm/arch/misc.h> #include <dm/device_compat.h> -#include <linux/kernel.h> +#include <linux/sizes.h>
@@ -671,6 +672,21 @@ static int ddr_calibration_sequence(struct altera_sdram_platdata *plat) return 0; }
+static void sdram_size_check(struct ram_info *ram) +{ + phys_size_t ram_check = 0; + + debug("DDR: Running SDRAM size sanity check\n"); + + ram_check = get_ram_size((void *)(ram->base), ram->size); + if (ram_check != ram->size) { + puts("DDR: SDRAM size check failed!\n"); + hang(); + } + + debug("DDR: SDRAM size check passed!\n"); +} + static int altera_sdram_ofdata_to_platdata(struct udevice *dev) { struct altera_sdram_platdata *plat = dev->platdata; @@ -715,6 +731,7 @@ static int altera_sdram_probe(struct udevice *dev) priv->info.base = gd->bd->bi_dram[0].start; priv->info.size = gd->ram_size;
+ sdram_size_check(&priv->info); return 0;
failed:
Tiny printf doesn't support %i, change to %u.
Reviewed-by: Tom Rini trini@konsulko.com Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- drivers/ddr/altera/sdram_arria10.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index 3fa34a1ae390..e4944ef95183 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -195,7 +195,7 @@ static void sdram_init_ecc_bits(u32 size)
dcache_enable();
- printf("DDRCAL: Scrubbing ECC RAM (%i MiB).\n", size >> 20); + printf("DDRCAL: Scrubbing ECC RAM (%u MiB).\n", size >> 20); memset((void *)0x8000, 0, size - 0x8000); flush_dcache_all(); printf("DDRCAL: Scrubbing ECC RAM done.\n");
dram_init_banksize() is called in board_init_f() boot sequences in Uboot, remove it from SDRAM driver.
Signed-off-by: Ley Foon Tan ley.foon.tan@intel.com --- drivers/ddr/altera/sdram_arria10.c | 3 --- 1 file changed, 3 deletions(-)
diff --git a/drivers/ddr/altera/sdram_arria10.c b/drivers/ddr/altera/sdram_arria10.c index e4944ef95183..27fd393e6fe4 100644 --- a/drivers/ddr/altera/sdram_arria10.c +++ b/drivers/ddr/altera/sdram_arria10.c @@ -660,9 +660,6 @@ static int ddr_calibration_sequence(struct altera_sdram_platdata *plat) else gd->ram_size = (u32)size;
- /* setup the dram info within bd */ - dram_init_banksize(); - if (of_sdram_firewall_setup(gd->fdt_blob)) puts("FW: Error Configuring Firewall\n");
Hi
Need to drop this patch, Found that dcache_enable() needs gd->bd->bi_dram[]. I will send v3.
Thanks.
Regards Ley Foon
Hi
OK, thanks.
-----Original Message----- From: Tan, Ley Foon ley.foon.tan@intel.com Sent: Monday, April 20, 2020 4:46 PM To: u-boot@lists.denx.de Cc: Marek Vasut marex@denx.de; Ley Foon Tan lftan.linux@gmail.com; See, Chin Liang chin.liang.see@intel.com; Simon Goldschmidt simon.k.r.goldschmidt@gmail.com; Chee, Tien Fong tien.fong.chee@intel.com; Tan, Ley Foon ley.foon.tan@intel.com Subject: [PATCH v2 0/7] ddr: altera: arria10: Convert SDRAM driver to DM
v1->v2:
arch/arm/dts/socfpga_arria10-u-boot.dtsi | 8 + .../include/mach/reset_manager_arria10.h | 1 - arch/arm/mach-socfpga/include/mach/sdram.h | 2 +- arch/arm/mach-socfpga/misc_arria10.c | 2 +- arch/arm/mach-socfpga/reset_manager_arria10.c | 7 - arch/arm/mach-socfpga/spl_a10.c | 14 +- drivers/ddr/altera/Kconfig | 4 +- drivers/ddr/altera/sdram_arria10.c | 382 ++++++++++-------- .../ddr/altera}/sdram_arria10.h | 225 ++--------- 9 files changed, 285 insertions(+), 360 deletions(-) rename {arch/arm/mach- socfpga/include/mach => drivers/ddr/altera}/sdram_arria10.h (72%)
-- 2.19.0
Hi
Any further comment on this patchset?
Thanks.
Regards Ley Foon
Ley Foon Tan
Ley Foon Tan
Tan, Ley Foon
