[U-Boot] [PATCH] powerpc/p1022ds: boot from SD card/SPI flash with SPL
This patch introduces SPL to enable a loader stub that runs in the L2 SRAM, after being loaded by the code from the internal on-chip ROM. It loads the final uboot image into DDR, then jump to it to begin execution.
The SPL's size is sizeable, the maximum size must not exceed the size of L2 SRAM.It initializes the DDR through SPD code, and copys final uboot image to DDR. So there are two stage uboot images: * spl_boot, 96KB size. The env variables are copied to offset 96KB. in L2 SRAM, so that ddr spd code can get the interleaving mode setting in env. It loads final uboot image from offset 96KB. * final uboot image, size is variable depends on the functions enabled.
Signed-off-by: Ying Zhang b40530@freescale.com --- README | 24 +++++ arch/powerpc/cpu/mpc85xx/tlb.c | 2 +- arch/powerpc/cpu/mpc85xx/u-boot-spl.lds | 25 +++++ arch/powerpc/cpu/mpc85xx/u-boot.lds | 8 ++ arch/powerpc/cpu/mpc8xxx/law.c | 4 +- board/freescale/common/Makefile | 5 +- board/freescale/common/sdhc_boot.c | 123 +++++++++++++++++++++++++ board/freescale/common/sdhc_boot.h | 29 ++++++ board/freescale/common/spi_boot.c | 96 ++++++++++++++++++++ board/freescale/common/spi_boot.h | 26 ++++++ board/freescale/p1022ds/Makefile | 3 + board/freescale/p1022ds/spl.c | 148 +++++++++++++++++++++++++++++++ board/freescale/p1022ds/tlb.c | 9 ++- common/Makefile | 5 + doc/README.mpc85xx-sd-spi-boot | 82 +++++++++++++++++ include/configs/P1022DS.h | 116 ++++++++++++++++++++---- lib/Makefile | 5 + spl/Makefile | 3 + 18 files changed, 688 insertions(+), 25 deletions(-) create mode 100644 board/freescale/common/sdhc_boot.h create mode 100644 board/freescale/common/spi_boot.c create mode 100644 board/freescale/common/spi_boot.h create mode 100644 board/freescale/p1022ds/spl.c create mode 100644 doc/README.mpc85xx-sd-spi-boot
diff --git a/README b/README index 862bb3e..f974bca 100644 --- a/README +++ b/README @@ -2887,6 +2887,10 @@ FIT uImage format: CONFIG_SPL_INIT_MINIMAL Arch init code should be built for a very small image
+ CONFIG_SPL_INIT_NORMAL + This is relative to MINIMAL, this init code contains some + features that the minimal SPL doesn't contains. + CONFIG_SPL_LIBCOMMON_SUPPORT Support for common/libcommon.o in SPL binary
@@ -2977,6 +2981,21 @@ FIT uImage format: CONFIG_SPL_LIBGENERIC_SUPPORT Support for lib/libgeneric.o in SPL binary
+ CONFIG_SPL_INIT_DDR_SUPPORT + Support for common DDR init in SPL binary + + CONFIG_SPL_HWCONFIG_SUPPORT + Support for configuring hardware via environment in SPL binary + + CONFIG_SPL_ENV_SUPPORT + Support for the environment operating in SPL binary + + CONFIG_SPL_ADDR_MAP_SUPPORT + Support for mutual transformation between virtual addr to CPU bus addr + + CONFIG_SPL_UTILITYLIB_SUPPORT + Support for some common tools in SPL binary, such as: hashtable + CONFIG_SPL_PAD_TO Image offset to which the SPL should be padded before appending the SPL payload. By default, this is defined as @@ -3965,6 +3984,11 @@ Low Level (hardware related) configuration options: that is executed before the actual U-Boot. E.g. when compiling a NAND SPL.
+- CONFIG_SYS_MPC85XX_NO_RESETVEC + Only for 85xx systems. If this variable is specified, the section + .resetvec is not kept and the section .bootpg is placed in the + previous 4k of the .text section. + - CONFIG_ARCH_MAP_SYSMEM Generally U-Boot (and in particular the md command) uses effective address. It is therefore not necessary to regard diff --git a/arch/powerpc/cpu/mpc85xx/tlb.c b/arch/powerpc/cpu/mpc85xx/tlb.c index 0dff37f..d21b324 100644 --- a/arch/powerpc/cpu/mpc85xx/tlb.c +++ b/arch/powerpc/cpu/mpc85xx/tlb.c @@ -55,7 +55,7 @@ void init_tlbs(void) return ; }
-#if !defined(CONFIG_NAND_SPL) && !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_NAND_SPL) && !defined(CONFIG_SPL_BUILD_MINIMAL) void read_tlbcam_entry(int idx, u32 *valid, u32 *tsize, unsigned long *epn, phys_addr_t *rpn) { diff --git a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds index f2b7bff..f1a9ac9 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot-spl.lds @@ -26,6 +26,13 @@ #include "config.h" /* CONFIG_BOARDDIR */
OUTPUT_ARCH(powerpc) +#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC +PHDRS +{ + text PT_LOAD; + bss PT_LOAD; +} +#endif SECTIONS { . = CONFIG_SPL_TEXT_BASE; @@ -53,6 +60,11 @@ SECTIONS } _edata = .;
+ . = .; + __start___ex_table = .; + __ex_table : { *(__ex_table) } + __stop___ex_table = .; + . = ALIGN(8); __init_begin = .; __init_end = .; @@ -68,9 +80,21 @@ SECTIONS #else #error unknown NAND controller #endif + +#ifndef CONFIG_FSL_IFC +#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC + .bootpg ADDR(.text) - 0x1000 : + { + KEEP(*(.bootpg)) + } :text = 0xffff +#endif +#endif + +#ifndef CONFIG_SYS_MPC85XX_NO_RESETVEC .resetvec ADDR(.text) + RESET_VECTOR_OFFSET : { KEEP(*(.resetvec)) } = 0xffff +#endif
/* * Make sure that the bss segment isn't linked at 0x0, otherwise its @@ -83,5 +107,6 @@ SECTIONS *(.sbss*) *(.bss*) } + . = ALIGN(4); __bss_end = .; } diff --git a/arch/powerpc/cpu/mpc85xx/u-boot.lds b/arch/powerpc/cpu/mpc85xx/u-boot.lds index 0503dce..2643563 100644 --- a/arch/powerpc/cpu/mpc85xx/u-boot.lds +++ b/arch/powerpc/cpu/mpc85xx/u-boot.lds @@ -95,6 +95,13 @@ SECTIONS . = ALIGN(256); __init_end = .;
+#ifdef CONFIG_SYS_MPC85XX_NO_RESETVEC + .bootpg ADDR(.text) - 0x1000 : + { + KEEP(arch/powerpc/cpu/mpc85xx/start.o (.bootpg)) + } :text = 0xffff + . = ADDR(.text) + 0x80000; +#else .bootpg RESET_VECTOR_ADDRESS - 0xffc : { arch/powerpc/cpu/mpc85xx/start.o (.bootpg) @@ -117,6 +124,7 @@ SECTIONS #if (RESET_VECTOR_ADDRESS == 0xfffffffc) . |= 0x10; #endif +#endif
__bss_start = .; .bss (NOLOAD) : diff --git a/arch/powerpc/cpu/mpc8xxx/law.c b/arch/powerpc/cpu/mpc8xxx/law.c index 6f9d568..979c3c2 100644 --- a/arch/powerpc/cpu/mpc8xxx/law.c +++ b/arch/powerpc/cpu/mpc8xxx/law.c @@ -92,7 +92,7 @@ void disable_law(u8 idx) return; }
-#if !defined(CONFIG_NAND_SPL) && !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_NAND_SPL) && !defined(CONFIG_SPL_BUILD_MINIMAL) static int get_law_entry(u8 i, struct law_entry *e) { u32 lawar; @@ -122,7 +122,7 @@ int set_next_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) return idx; }
-#if !defined(CONFIG_NAND_SPL) && !defined(CONFIG_SPL_BUILD) +#if !defined(CONFIG_NAND_SPL) && !defined(CONFIG_SPL_BUILD_MINIMAL) int set_last_law(phys_addr_t addr, enum law_size sz, enum law_trgt_if id) { u32 idx; diff --git a/board/freescale/common/Makefile b/board/freescale/common/Makefile index 72bb56c..7340dfe 100644 --- a/board/freescale/common/Makefile +++ b/board/freescale/common/Makefile @@ -45,6 +45,9 @@ COBJS-$(CONFIG_FSL_SGMII_RISER) += sgmii_riser.o ifndef CONFIG_RAMBOOT_PBL COBJS-$(CONFIG_FSL_FIXED_MMC_LOCATION) += sdhc_boot.o endif +ifdef CONFIG_SPL_BUILD +COBJS-$(CONFIG_SPL_SPI_FLASH_SUPPORT) += spi_boot.o +endif
COBJS-$(CONFIG_MPC8541CDS) += cds_pci_ft.o COBJS-$(CONFIG_MPC8548CDS) += cds_pci_ft.o @@ -52,9 +55,7 @@ COBJS-$(CONFIG_MPC8555CDS) += cds_pci_ft.o
COBJS-$(CONFIG_MPC8536DS) += ics307_clk.o COBJS-$(CONFIG_MPC8572DS) += ics307_clk.o -ifndef CONFIG_SPL_BUILD COBJS-$(CONFIG_P1022DS) += ics307_clk.o -endif COBJS-$(CONFIG_P2020DS) += ics307_clk.o COBJS-$(CONFIG_P3041DS) += ics307_clk.o COBJS-$(CONFIG_P4080DS) += ics307_clk.o diff --git a/board/freescale/common/sdhc_boot.c b/board/freescale/common/sdhc_boot.c index e432318..96b0680 100644 --- a/board/freescale/common/sdhc_boot.c +++ b/board/freescale/common/sdhc_boot.c @@ -24,6 +24,7 @@ #include <mmc.h> #include <malloc.h>
+DECLARE_GLOBAL_DATA_PTR; /* * The environment variables are written to just after the u-boot image * on SDCard, so we must read the MBR to get the start address and code @@ -31,6 +32,9 @@ */ #define ESDHC_BOOT_IMAGE_SIZE 0x48 #define ESDHC_BOOT_IMAGE_ADDR 0x50 +#define ESDHC_BOOT_IMAGE_SIGN 0x55AA +#define ESDHC_BOOT_IMAGE_SIGN_ADDR 0x1FE +#define CONFIG_CFG_DATA_SECTOR 0
int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr) { @@ -61,3 +65,122 @@ int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr)
return 0; } + +#ifdef CONFIG_SPL_BUILD +void mmc_get_env(void) +{ + /* load environment */ + struct mmc *mmc; + int err; + u32 offset; + uint blk_start, blk_cnt, ret; + + mmc_initialize(gd->bd); + /* We register only one device. So, the dev id is always 0 */ + mmc = find_mmc_device(0); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + err = mmc_init(mmc); + if (err) { + puts("spl: mmc init failed!"); + hang(); + } + if (1 == mmc_get_env_addr(mmc, &offset)) + puts("spl: mmc get env error!!\n"); + + blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; + blk_cnt = ALIGN(CONFIG_ENV_SIZE, mmc->read_bl_len) / mmc->read_bl_len; + + ret = mmc->block_dev.block_read(mmc->block_dev.dev, \ + blk_start, blk_cnt, (uchar *)CONFIG_ENV_ADDR); + if (ret != blk_cnt) { + puts("spl: mmc read failed!"); + hang(); + } +} + +/* + * The main entry for mmc booting. It's necessary that SDRAM is already + * configured and available since this code loads the main U-Boot image + * from mmc into SDRAM and starts it from there. + */ +void mmc_copy_image(void) +{ + uint blk_start, blk_cnt, err; + u16 val; + u32 offset, code_len; + u32 blklen; + u8 *tmp_buf; + struct mmc *mmc; + + mmc = find_mmc_device(0); + if (!mmc) { + puts("spl: mmc device not found!!\n"); + hang(); + } + + blklen = mmc->read_bl_len; + tmp_buf = malloc(blklen); + if (!tmp_buf) + return; + memset(tmp_buf, 0, blklen); + + /* + * Read source addr from sd card + */ + err = mmc->block_dev.block_read(0, CONFIG_CFG_DATA_SECTOR, \ + 1, (uchar *)tmp_buf); + if (err != 1) { + free(tmp_buf); + return; + } + + val = *(u16 *)(tmp_buf + ESDHC_BOOT_IMAGE_SIGN_ADDR); + if ((u16)ESDHC_BOOT_IMAGE_SIGN != val) { + free(tmp_buf); + return; + } + + offset = *(u32 *)(tmp_buf + ESDHC_BOOT_IMAGE_ADDR); + offset += CONFIG_SYS_MMC_U_BOOT_OFFS; + /* Get the code size from offset 0x48 */ + code_len = *(u32 *)(tmp_buf + ESDHC_BOOT_IMAGE_SIZE); + code_len -= CONFIG_SYS_MMC_U_BOOT_OFFS; + /* + * Load U-Boot image from mmc into RAM + */ + /* + SDHC card: code offset and length is stored in block units rather + * than a single byte + */ + blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len; + blk_cnt = ALIGN(code_len, mmc->read_bl_len) / mmc->read_bl_len; + + err = mmc->block_dev.block_read(0, blk_start, blk_cnt, + (uchar *)CONFIG_SYS_MMC_U_BOOT_DST); + if (err != blk_cnt) { + free(tmp_buf); + return ; + } +} +void mmc_boot(void) +{ + __attribute__((noreturn)) void (*uboot)(void); + + mmc_copy_image(); + /* + * Jump to U-Boot image + */ + + /* + * Clean d-cache and invalidate i-cache, to + * make sure that no stale data is executed. + */ + flush_cache(CONFIG_SYS_MMC_U_BOOT_DST, CONFIG_SYS_MMC_U_BOOT_SIZE); + uboot = (void *)CONFIG_SYS_MMC_U_BOOT_START; + (*uboot)(); +} +#endif + diff --git a/board/freescale/common/sdhc_boot.h b/board/freescale/common/sdhc_boot.h new file mode 100644 index 0000000..2b5dcb9 --- /dev/null +++ b/board/freescale/common/sdhc_boot.h @@ -0,0 +1,29 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SDHC_BOOT_H_ +#define __SDHC_BOOT_H_ 1 + + +int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr); +void mmc_get_env(void); +void mmc_boot(void); + +#endif /* __SDHC_BOOT_H_ */ + diff --git a/board/freescale/common/spi_boot.c b/board/freescale/common/spi_boot.c new file mode 100644 index 0000000..03f7b21 --- /dev/null +++ b/board/freescale/common/spi_boot.c @@ -0,0 +1,96 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <malloc.h> +#include <spi.h> +#include <spi_flash.h> + +/* + * The environment variables are written to just after the u-boot image + * on SDCard, so we must read the MBR to get the start address and code + * length of the u-boot image, then calculate the address of the env. + */ +#define ESPI_BOOT_IMAGE_SIZE 0x48 +#define ESPI_BOOT_IMAGE_ADDR 0x50 +#define CONFIG_CFG_DATA_SECTOR 0 + +struct spi_flash *flash; + +void spi_get_env(void) +{ + int ret; + + flash = spi_flash_probe(CONFIG_ENV_SPI_BUS, CONFIG_ENV_SPI_CS, + CONFIG_ENV_SPI_MAX_HZ, CONFIG_ENV_SPI_MODE); + if (flash == NULL) { + puts("\nspi_flash_probe failed"); + hang(); + } + ret = spi_flash_read(flash, CONFIG_ENV_OFFSET, CONFIG_ENV_SIZE, \ + (void *)CONFIG_ENV_ADDR); + if (ret) { + puts("\nspi_flash_read failed"); + hang(); + } +} + +/* + * The main entry for SPI booting. It's necessary that SDRAM is already + * configured and available since this code loads the main U-Boot image + * from SPI into SDRAM and starts it from there. + */ +void spi_boot(void) +{ + void (*uboot)(void) __noreturn; + u32 offset, code_len; + u8 *read_buffer; + + /* + * Load U-Boot image from SPI flash into RAM + */ + read_buffer = malloc(flash->page_size); + if (!read_buffer) { + puts("\nmalloc failed"); + hang(); + } + memset(read_buffer, 0, flash->page_size); + spi_flash_read(flash, CONFIG_CFG_DATA_SECTOR, \ + flash->page_size, (void *)read_buffer); + offset = *(u32 *)(read_buffer + ESPI_BOOT_IMAGE_ADDR); + /* Skip spl code */ + offset += CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS; + /* Get the code size from offset 0x48 */ + code_len = *(u32 *)(read_buffer + ESPI_BOOT_IMAGE_SIZE); + /* Skip spl code */ + code_len = code_len - CONFIG_SPL_MAX_SIZE + 8*1024; + spi_flash_read(flash, offset, code_len, \ + (void *)CONFIG_SYS_SPI_FLASH_U_BOOT_DST); + /* + * Jump to U-Boot image + */ + flush_cache(CONFIG_SYS_SPI_FLASH_U_BOOT_DST, \ + CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE); + uboot = (void *) CONFIG_SYS_SPI_FLASH_U_BOOT_START; + (*uboot)(); +} + diff --git a/board/freescale/common/spi_boot.h b/board/freescale/common/spi_boot.h new file mode 100644 index 0000000..125dc84 --- /dev/null +++ b/board/freescale/common/spi_boot.h @@ -0,0 +1,26 @@ +/* Copyright 2011 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __SPI_BOOT_H_ +#define __SPI_BOOT_H_ 1 + +void spi_get_env(void); +void spi_boot(void); + +#endif /* __SPI_BOOT_H_ */ + diff --git a/board/freescale/p1022ds/Makefile b/board/freescale/p1022ds/Makefile index 633161c..5739cf3 100644 --- a/board/freescale/p1022ds/Makefile +++ b/board/freescale/p1022ds/Makefile @@ -25,6 +25,9 @@ COBJS-y += spl_minimal.o tlb.o law.o
else
+ifdef CONFIG_SPL_BUILD +COBJS-$(CONFIG_SPL_INIT_NORMAL) += spl.o +endif COBJS-y += $(BOARD).o COBJS-y += ddr.o COBJS-y += law.o diff --git a/board/freescale/p1022ds/spl.c b/board/freescale/p1022ds/spl.c new file mode 100644 index 0000000..32acddc --- /dev/null +++ b/board/freescale/p1022ds/spl.c @@ -0,0 +1,148 @@ +/* + * Copyright 2011 Freescale Semiconductor, Inc. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + * + */ + +#include <common.h> +#include <ns16550.h> +#include <nand.h> +#include <asm/fsl_law.h> +#include <asm/fsl_ddr_sdram.h> +#include <malloc.h> +#ifdef CONFIG_SDCARD +#include <mmc.h> +#include <i2c.h> +#include "../common/sdhc_boot.h" +#endif +#ifdef CONFIG_SPIFLASH +#include <i2c.h> +#include "../common/ngpixis.h" +#include "../common/spi_boot.h" +#endif + +static const u32 sysclk_tbl[] = { + 66666000, 7499900, 83332500, 8999900, + 99999000, 11111000, 12499800, 13333200 +}; + +DECLARE_GLOBAL_DATA_PTR; + +void hang(void) +{ + puts("### ERROR ### Please RESET the board ###\n"); + for (;;) + ; +} + +ulong get_effective_memsize(void) +{ + return CONFIG_SYS_L2_SIZE; +} + +void board_init_f(ulong bootflag) +{ + int px_spd; + u32 plat_ratio, sys_clk, bus_clk; + ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR; + + console_init_f(); + +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + /* Set pmuxcr to allow both i2c1 and i2c2 */ + setbits_be32(&gur->pmuxcr, in_be32(&gur->pmuxcr) | 0x1000); + setbits_be32(&gur->pmuxcr, + in_be32(&gur->pmuxcr) | MPC85xx_PMUXCR_SD_DATA); + +#ifdef CONFIG_SPIFLASH + /* Enable the SPI */ + clrsetbits_8(&pixis->brdcfg0, PIXIS_ELBC_SPI_MASK, PIXIS_SPI); +#endif + /* Read back the register to synchronize the write. */ + in_be32(&gur->pmuxcr); +#endif + + /* initialize selected port with appropriate baud rate */ + px_spd = in_8((unsigned char *)(PIXIS_BASE + PIXIS_SPD)); + sys_clk = sysclk_tbl[px_spd & PIXIS_SPD_SYSCLK_MASK]; + plat_ratio = in_be32(&gur->porpllsr) & MPC85xx_PORPLLSR_PLAT_RATIO; + bus_clk = sys_clk * plat_ratio / 2; + + NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1, + bus_clk / 16 / CONFIG_BAUDRATE); +#ifdef CONFIG_SDCARD + puts("\nSD boot...\n"); +#endif +#ifdef CONFIG_NAND + puts("\nNAND boot...\n"); +#endif +#ifdef CONFIG_SPIFLASH + puts("\nSPI Flash boot...\n"); +#endif + + /* copy code to RAM and jump to it - this should not return */ + /* NOTE - code has to be copied out of NAND buffer before + * other blocks can be read. + */ + relocate_code(CONFIG_SPL_RELOC_STACK, 0, + CONFIG_SPL_RELOC_TEXT_BASE); +} + +void board_init_r(gd_t *gd, ulong dest_addr) +{ +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + /* Pointer is writable since we allocated a register for it */ + gd = (gd_t *)CONFIG_SPL_GD_ADDR; + bd_t *bd; + + memset(gd, 0, sizeof(gd_t)); + bd = (bd_t *)(CONFIG_SPL_GD_ADDR + sizeof(gd_t)); + memset(bd, 0, sizeof(bd_t)); + gd->bd = bd; + bd->bi_memstart = CONFIG_SYS_INIT_L2_ADDR; + bd->bi_memsize = CONFIG_SYS_L2_SIZE; + + probecpu(); + get_clocks(); + mem_malloc_init(CONFIG_SPL_RELOC_MALLOC_ADDR, \ + CONFIG_SPL_RELOC_MALLOC_SIZE); +#ifdef CONFIG_SDCARD + /* load environment */ + mmc_get_env(); +#elif defined(CONFIG_SPIFLASH) + spi_get_env(); +#endif + + gd->env_addr = (ulong)(CONFIG_ENV_ADDR); + gd->env_valid = 1; + + i2c_init(CONFIG_SYS_I2C_SPEED, CONFIG_SYS_I2C_SLAVE); + + gd->ram_size = initdram(0); + puts("Second program loader running in sram...\n"); + +#ifdef CONFIG_SDCARD + mmc_boot(); +#elif defined(CONFIG_SPIFLASH) + spi_boot(); +#endif +#endif /* defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) */ +#ifdef CONFIG_NAND + nand_boot(); +#endif +} diff --git a/board/freescale/p1022ds/tlb.c b/board/freescale/p1022ds/tlb.c index ebf5dd7..402d877 100644 --- a/board/freescale/p1022ds/tlb.c +++ b/board/freescale/p1022ds/tlb.c @@ -74,7 +74,8 @@ struct fsl_e_tlb_entry tlb_table[] = { MAS3_SX|MAS3_SW|MAS3_SR, MAS2_I|MAS2_G, 0, 7, BOOKE_PAGESZ_4K, 1),
-#if defined(CONFIG_SYS_RAMBOOT) || defined(CONFIG_SPL) +#if (defined(CONFIG_SYS_RAMBOOT) || defined(CONFIG_SPL)) && \ + !defined(CONFIG_SPL_COMMON_INIT_DDR) /* **** - eSDHC/eSPI/NAND boot */ SET_TLB_ENTRY(1, CONFIG_SYS_DDR_SDRAM_BASE, CONFIG_SYS_DDR_SDRAM_BASE, MAS3_SX|MAS3_SW|MAS3_SR, 0, @@ -94,6 +95,12 @@ struct fsl_e_tlb_entry tlb_table[] = { 0, 10, BOOKE_PAGESZ_16K, 1), #endif
+#ifdef CONFIG_SYS_INIT_L2_ADDR + /* *I*G - L2SRAM */ + SET_TLB_ENTRY(1, CONFIG_SYS_INIT_L2_ADDR, CONFIG_SYS_INIT_L2_ADDR_PHYS, + MAS3_SX|MAS3_SW|MAS3_SR, MAS2_G, + 0, 11, BOOKE_PAGESZ_256K, 1) +#endif };
int num_tlb_entries = ARRAY_SIZE(tlb_table); diff --git a/common/Makefile b/common/Makefile index 0e0fff1..bc80414 100644 --- a/common/Makefile +++ b/common/Makefile @@ -225,6 +225,11 @@ COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_common.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_flags.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += env_nowhere.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += miiphyutil.o +COBJS-$(CONFIG_SPL_HWCONFIG_SUPPORT) += hwconfig.o +COBJS-$(CONFIG_SPL_INIT_DDR_SUPPORT) += ddr_spd.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_attr.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_flags.o +COBJS-$(CONFIG_SPL_ENV_SUPPORT) += env_callback.o endif COBJS-$(CONFIG_BOUNCE_BUFFER) += bouncebuf.o COBJS-y += console.o diff --git a/doc/README.mpc85xx-sd-spi-boot b/doc/README.mpc85xx-sd-spi-boot new file mode 100644 index 0000000..79f91fc --- /dev/null +++ b/doc/README.mpc85xx-sd-spi-boot @@ -0,0 +1,82 @@ +---------------------------------------- +Booting from On-Chip ROM (eSDHC or eSPI) +---------------------------------------- + +boot_format is a tool to write SD bootable images to a filesystem and build +SD/SPI images to a binary file for writing later. + +When booting from an SD card/MMC, boot_format puts the configuration file and +the RAM-based U-Boot image on the card. +When booting from an EEPROM, boot_format generates a binary image that is used +to boot from this EEPROM. + +Where to get boot_format: +======================== + +you can browse it online at: +http://git.freescale.com/git/cgit.cgi/ppc/sdk/boot-format.git/ + +Building +======== + +Run the following to build this project + + $ make + +Execution +========= + +boot_format runs under a regular Linux machine and requires a super user mode +to run. Execute boot_format as follows. + +For building SD images by writing directly to a file system on SD media: + + $ boot_format $config u-boot.bin -sd $device + +Where $config is the included config.dat file for your platform and $device +is the target block device for the SD media on your computer. + +For build binary images directly a local file: + + $ boot_format $config u-boot.bin -spi $file + +Where $file is the target file. Also keep in mind the u-boot.bin file needs +to be the u-boot built for your particular platform and target media. + +Hint: To generate a u-boot.bin for a P1022DS booting from SD I would run the +following in the u-boot repository: + + $ make P1022DS_SDCARD + +Configuration Files +=================== + +Below are the configuration files to be used with a particular platform. Keep +in mind that some of these config files are tied to the platforms DDR speed. +Please see the SoC reference manual for more documentation. + +P1022DS config_sram_p1022ds.dat +P2020DS config_sram_p2020ds.dat +P2010DS config_sram_p2020ds.dat +P1020RDB config_ddr2_1g_p1020rdb_533M.dat +P1020RDB config_ddr2_1g_p1020rdb_667M.dat +P2020RDB config_ddr2_1g_p2020rdb_800M.dat +P2020RDB config_ddr2_1g_p2020rdb_667M.dat +P2020RDB config_ddr3_1gb_64bit_p2020rdb_pc.dat +P2010RDB config_ddr3_1gb_64bit_p2020rdb_pc.dat +P1020RDB config_ddr3_1gb_p1_p2_rdb_pc_800M.dat +P1011RDB config_ddr3_1gb_p1_p2_rdb_pc_800M.dat +P1010RDB config_ddr3_1gb_p1010rdb_800M.dat +P1014RDB config_ddr3_1gb_p1014rdb_800M.dat +P1021RDB config_ddr3_1gb_p1_p2_rdb_pc_800M.dat +P1012RDB config_ddr3_1gb_p1_p2_rdb_pc_800M.dat +P1022DS config_ddr3_2gb_p1022ds.dat +P1013DS config_ddr3_2gb_p1022ds.dat +P1024RDB config_ddr3_1gb_p1_p2_rdb_pc_667M.dat +P1013RDB config_ddr3_1gb_p1_p2_rdb_pc_667M.dat +P1025RDB config_ddr3_1gb_p1_p2_rdb_pc_667M.dat +P1016RDB config_ddr3_1gb_p1_p2_rdb_pc_667M.dat +P1020UTM config_ddr3_1gb_p1_p2_rdb_pc_800M.dat +P1020MBG config_ddr3_1gb_p1_p2_rdb_pc_800M.dat +MPC8536DS config_ddr2_512m_mpc8536ds_667M.dat + diff --git a/include/configs/P1022DS.h b/include/configs/P1022DS.h index 15eafd4..dedd060 100644 --- a/include/configs/P1022DS.h +++ b/include/configs/P1022DS.h @@ -19,19 +19,72 @@ #endif
#ifdef CONFIG_SDCARD -#define CONFIG_RAMBOOT_SDCARD -#define CONFIG_SYS_RAMBOOT -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_SYS_TEXT_BASE 0x11000000 -#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#define CONFIG_SPL +#define CONFIG_SPL_INIT_NORMAL +#define CONFIG_SPL_INIT_DDR_SUPPORT +#define CONFIG_SPL_HWCONFIG_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SPL_ADDR_MAP_SUPPORT +#endif +#define CONFIG_SPL_UTILITYLIB_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_MMC_SUPPORT +#define CONFIG_SPL_MMC_MINIMAL +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_SYS_TEXT_BASE 0x11001000 +#define CONFIG_SPL_TEXT_BASE 0xf8f81000 +#define CONFIG_SPL_PAD_TO 0x18000 +#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SYS_MMC_U_BOOT_SIZE (512 << 10) +#define CONFIG_SYS_MMC_U_BOOT_DST (0x11000000) +#define CONFIG_SYS_MMC_U_BOOT_START (0x11000000) +#define CONFIG_SYS_MMC_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_MPC85XX_NO_RESETVEC +#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_COMMON_INIT_DDR +#endif #endif
#ifdef CONFIG_SPIFLASH -#define CONFIG_RAMBOOT_SPIFLASH -#define CONFIG_SYS_RAMBOOT -#define CONFIG_SYS_EXTRA_ENV_RELOC -#define CONFIG_SYS_TEXT_BASE 0x11000000 -#define CONFIG_RESET_VECTOR_ADDRESS 0x1107fffc +#define CONFIG_SPL +#define CONFIG_SPL_INIT_NORMAL +#define CONFIG_SPL_INIT_DDR_SUPPORT +#define CONFIG_SPL_HWCONFIG_SUPPORT +#define CONFIG_SPL_ENV_SUPPORT +#ifdef CONFIG_PHYS_64BIT +#define CONFIG_SPL_ADDR_MAP_SUPPORT +#endif +#define CONFIG_SPL_UTILITYLIB_SUPPORT +#define CONFIG_SPL_SERIAL_SUPPORT +#define CONFIG_SPL_SPI_SUPPORT +#define CONFIG_SPL_SPI_FLASH_SUPPORT +#define CONFIG_SPL_SPI_FLASH_MINIMAL +#define CONFIG_SPL_FLUSH_IMAGE +#define CONFIG_SPL_TARGET "u-boot-with-spl.bin" +#define CONFIG_SPL_LIBGENERIC_SUPPORT +#define CONFIG_SPL_LIBCOMMON_SUPPORT +#define CONFIG_SPL_I2C_SUPPORT +#define CONFIG_FSL_LAW /* Use common FSL init code */ +#define CONFIG_SYS_TEXT_BASE 0x11001000 +#define CONFIG_SPL_TEXT_BASE 0xf8f81000 +#define CONFIG_SPL_PAD_TO 0x18000 +#define CONFIG_SPL_MAX_SIZE (96 * 1024) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_SIZE (512 << 10) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_DST (0x11000000) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_START (0x11000000) +#define CONFIG_SYS_SPI_FLASH_U_BOOT_OFFS (96 << 10) +#define CONFIG_SYS_MPC85XX_NO_RESETVEC +#define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot.lds" +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_COMMON_INIT_DDR +#endif #endif
#define CONFIG_NAND_FSL_ELBC @@ -44,7 +97,6 @@ #define CONFIG_SPL_NAND_MINIMAL #define CONFIG_SPL_FLUSH_IMAGE #define CONFIG_SPL_TARGET "u-boot-with-spl.bin" - #define CONFIG_SYS_TEXT_BASE 0x00201000 #define CONFIG_SPL_TEXT_BASE 0xfffff000 #define CONFIG_SPL_MAX_SIZE 0x1000 @@ -55,6 +107,9 @@ #define CONFIG_SYS_NAND_U_BOOT_START 0x00200000 #define CONFIG_SYS_NAND_U_BOOT_OFFS 0 #define CONFIG_SYS_LDSCRIPT "arch/powerpc/cpu/mpc85xx/u-boot-nand.lds" +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SPL_BUILD_MINIMAL +#endif #endif
/* High Level Configuration Options */ @@ -81,7 +136,6 @@ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ #define CONFIG_FSL_PCIE_RESET /* need PCIe reset errata */ #define CONFIG_SYS_PCI_64BIT /* enable 64-bit PCI resources */ - #define CONFIG_ENABLE_36BIT_PHYS
#ifdef CONFIG_PHYS_64BIT @@ -152,9 +206,9 @@ #define CONFIG_SYS_DDR_CLK_CTRL 0x02800000 #define CONFIG_SYS_DDR_CONTROL 0xc7000008 #define CONFIG_SYS_DDR_CONTROL_2 0x24401041 -#define CONFIG_SYS_DDR_TIMING_4 0x00220001 -#define CONFIG_SYS_DDR_TIMING_5 0x02401400 -#define CONFIG_SYS_DDR_ZQ_CONTROL 0x89080600 +#define CONFIG_SYS_DDR_TIMING_4 0x00220001 +#define CONFIG_SYS_DDR_TIMING_5 0x02401400 +#define CONFIG_SYS_DDR_ZQ_CONTROL 0x89080600 #define CONFIG_SYS_DDR_WRLVL_CONTROL 0x8675f608
/* @@ -282,9 +336,10 @@ #define PIXIS_ELBC_SPI_MASK 0xc0 #define PIXIS_SPI 0x80
+ #define CONFIG_SYS_INIT_RAM_LOCK #define CONFIG_SYS_INIT_RAM_ADDR 0xffd00000 /* Initial L1 address */ -#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000 /* Size of used area in RAM */ +#define CONFIG_SYS_INIT_RAM_SIZE 0x00004000
#define CONFIG_SYS_GBL_DATA_OFFSET \ (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) @@ -294,6 +349,26 @@ #define CONFIG_SYS_MALLOC_LEN (10 * 1024 * 1024)
/* + * Config the L2 Cache as L2 SRAM + */ +#if defined(CONFIG_SPL_BUILD) +#if defined(CONFIG_SDCARD) || defined(CONFIG_SPIFLASH) + +#define CONFIG_SYS_INIT_L2_ADDR 0xf8f80000 +#define CONFIG_SYS_INIT_L2_ADDR_PHYS CONFIG_SYS_INIT_L2_ADDR +#define CONFIG_SYS_L2_SIZE (256 << 10) +#define CONFIG_SYS_INIT_L2_END (CONFIG_SYS_INIT_L2_ADDR + CONFIG_SYS_L2_SIZE) +#define CONFIG_SPL_RELOC_TEXT_BASE 0xf8f81000 +#define CONFIG_SPL_RELOC_STACK (CONFIG_SYS_INIT_L2_ADDR + 128 * 1024) +#define CONFIG_SPL_RELOC_STACK_SIZE (32 << 10) +#define CONFIG_SPL_RELOC_MALLOC_ADDR (CONFIG_SYS_INIT_L2_ADDR + 160 * 1024) +#define CONFIG_SPL_RELOC_MALLOC_SIZE (96 << 10) +#define CONFIG_SPL_GD_ADDR (CONFIG_SYS_INIT_L2_ADDR + 112 * 1024) +#endif +#endif + + +/* * Serial Port */ #define CONFIG_CONS_INDEX 1 @@ -301,7 +376,7 @@ #define CONFIG_SYS_NS16550_SERIAL #define CONFIG_SYS_NS16550_REG_SIZE 1 #define CONFIG_SYS_NS16550_CLK get_bus_freq(0) -#ifdef CONFIG_SPL_BUILD +#if defined(CONFIG_SPL_BUILD) && defined(CONFIG_NAND) #define CONFIG_NS16550_MIN_FUNCTIONS #endif
@@ -524,8 +599,9 @@ /* * Environment */ -#ifdef CONFIG_RAMBOOT_SPIFLASH +#ifdef CONFIG_SPIFLASH #define CONFIG_ENV_IS_IN_SPI_FLASH +#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (96 << 10)) #define CONFIG_ENV_SPI_BUS 0 #define CONFIG_ENV_SPI_CS 0 #define CONFIG_ENV_SPI_MAX_HZ 10000000 @@ -533,8 +609,10 @@ #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 -#elif defined(CONFIG_RAMBOOT_SDCARD) +#elif defined(CONFIG_SDCARD) #define CONFIG_ENV_IS_IN_MMC +#define CONFIG_FSL_FIXED_MMC_LOCATION +#define CONFIG_ENV_ADDR (CONFIG_SYS_INIT_L2_ADDR + (96 << 10)) #define CONFIG_ENV_SIZE 0x2000 #define CONFIG_SYS_MMC_ENV_DEV 0 #elif defined(CONFIG_NAND) diff --git a/lib/Makefile b/lib/Makefile index e901cc7..ab12e63 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -66,6 +66,11 @@ endif COBJS-$(CONFIG_SPL_NET_SUPPORT) += errno.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += hashtable.o COBJS-$(CONFIG_SPL_NET_SUPPORT) += net_utils.o +COBJS-$(CONFIG_SPL_ADDR_MAP_SUPPORT) += addr_map.o +COBJS-$(CONFIG_SPL_UTILITYLIB_SUPPORT) += hashtable.o +COBJS-$(CONFIG_SPL_UTILITYLIB_SUPPORT) += display_options.o +COBJS-$(CONFIG_SPL_UTILITYLIB_SUPPORT) += errno.o + endif COBJS-$(CONFIG_BCH) += bch.o COBJS-y += crc32.o diff --git a/spl/Makefile b/spl/Makefile index b5a8de7..3a3b868 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -51,6 +51,9 @@ LIBS-y += arch/powerpc/cpu/mpc8xxx/lib8xxx.o endif ifeq ($(CPU),mpc85xx) LIBS-y += arch/powerpc/cpu/mpc8xxx/lib8xxx.o +ifdef CONFIG_SPL_INIT_DDR_SUPPORT +LIBS-y += arch/powerpc/cpu/mpc8xxx/ddr/libddr.o +endif endif ifeq ($(CPU),mpc86xx) LIBS-y += arch/powerpc/cpu/mpc8xxx/lib8xxx.o
Andy Fleming afleming@gmail.com is the MMC and mpc85xx maintainer; please CC him on these patches.
This patch needs to be broken into several patches that each take care of one logical problem; it's too hard to properly review (and have the right people pay attention to certain parts) in its current state.
Is this on top of the already-posted P1022DS NAND patch? If so, please say so.
some
Why do we need a symbol for this? The only place you use it is already limited to CONFIG_SPL_BUILD and !CONFIG_SPL_INIT_MINIMAL.
Aren't you breaking the existing minimal targets? CONFIG_SPL_BUILD_MINIMAL does not currently exist, and you add it only for P1022DS.
- text PT_LOAD;
- bss PT_LOAD;
+} +#endif
Whitespace.
- .bootpg ADDR(.text) - 0x1000 :
KEEP(*(.bootpg))
- } :text = 0xffff
+#endif +#endif
Get rid of the IFC ifdef -- this should apply equally well to IFC.
Can you make the "no resetvec" stuff a separate patch?
- . = ALIGN(4); __bss_end = .;
This seems unrelated.
- The environment variables are written to just after the u-boot
- on SDCard, so we must read the MBR to get the start address and
return 0; }
- /* load environment */
- struct mmc *mmc;
- int err;
- u32 offset;
- uint blk_start, blk_cnt, ret;
- mmc_initialize(gd->bd);
- /* We register only one device. So, the dev id is always 0 */
- mmc = find_mmc_device(0);
- if (!mmc) {
hang();
- err = mmc_init(mmc);
- if (err) {
hang();
- if (1 == mmc_get_env_addr(mmc, &offset))
Constants go on the right hand side of comparisons.
- val = *(u16 *)(tmp_buf + ESDHC_BOOT_IMAGE_SIGN_ADDR);
- if ((u16)ESDHC_BOOT_IMAGE_SIGN != val) {
free(tmp_buf);
return;
Why do you need this cast?
- offset = *(u32 *)(tmp_buf + ESDHC_BOOT_IMAGE_ADDR);
- offset += CONFIG_SYS_MMC_U_BOOT_OFFS;
- /* Get the code size from offset 0x48 */
- code_len = *(u32 *)(tmp_buf + ESDHC_BOOT_IMAGE_SIZE);
- code_len -= CONFIG_SYS_MMC_U_BOOT_OFFS;
- SDHC card: code offset and length is stored in block units
rather
- than a single byte
/* * U-Boot multiline * comment style is * like this. */
- blk_start = ALIGN(offset, mmc->read_bl_len) / mmc->read_bl_len;
- blk_cnt = ALIGN(code_len, mmc->read_bl_len) / mmc->read_bl_len;
- err = mmc->block_dev.block_read(0, blk_start, blk_cnt,
(uchar
- if (err != blk_cnt) {
free(tmp_buf);
return ;
No space before ;
That return is pointless since you're at the end of the function anyway.
Please put a blank line between functions.
- Copyright 2011 Freescale Semiconductor, Inc.
- MA 02111-1307 USA
Does this stuff really belong in board/freescale? Should probably at least be in arch/powerpc/cpu/mpc85xx, if not more generic.
Don't ifdef includes.
Don't use boards.cfg-defined config symbols outside the board config header, unless they're proper U-Boot config symbols which requires better naming, and documentation in README.
+void hang(void) +{
- puts("### ERROR ### Please RESET the board ###\n");
- for (;;)
Whitespace
- return CONFIG_SYS_L2_SIZE;
- int px_spd;
- u32 plat_ratio, sys_clk, bus_clk;
- ccsr_gur_t *gur = (void *)CONFIG_SYS_MPC85xx_GUTS_ADDR;
- console_init_f();
- /* Set pmuxcr to allow both i2c1 and i2c2 */
- setbits_be32(&gur->pmuxcr, in_be32(&gur->pmuxcr) | 0x1000);
- /* Enable the SPI */
- clrsetbits_8(&pixis->brdcfg0, PIXIS_ELBC_SPI_MASK, PIXIS_SPI);
- /* Read back the register to synchronize the write. */
- in_be32(&gur->pmuxcr);
- /* initialize selected port with appropriate baud rate */
- px_spd = in_8((unsigned char *)(PIXIS_BASE + PIXIS_SPD));
- sys_clk = sysclk_tbl[px_spd & PIXIS_SPD_SYSCLK_MASK];
- plat_ratio = in_be32(&gur->porpllsr) &
- bus_clk = sys_clk * plat_ratio / 2;
- NS16550_init((NS16550_t)CONFIG_SYS_NS16550_COM1,
- puts("\nSD boot...\n");
- puts("\nNAND boot...\n");
- puts("\nSPI Flash boot...\n");
Is NAND handled by this file? Isn't this on top of the patch that already adds NAND boot support? I don't see this print being removed from somewhere else.
CONFIG_SPL_ENV_SUPPORT should replace CONFIG_SPL_NET_SUPPORT here (and add it to the boards that already have CONFIG_SPL_NET_SUPPORT). This sort of refactoring needs to be a separate patch, BTW.
Can ddr_spd.o and hwconfig just use their normal CONFIG symbols (i.e. move the existing makefile line out of the !SPL ifdef)? It's getting a bit excessive with all the new SPL symbols.
Maybe one day we can redo it to be a separate config namespace, like I suggested a while ago. :-P It would certainly help with three-stage boot support.
+Building +========
- $ make
- $ boot_format $config u-boot.bin -sd $device
- $ boot_format $config u-boot.bin -spi $file
- $ make P1022DS_SDCARD
s/Hint/Example/ and s/from SD I would run/from SD, run/
As with common/Makefile, Can these just be the normal makefile lines, moved outside the SPL ifdef (and no duplications with CONFIG_SPL_NET_SUPPORT)?
Why isn't this handled as part of lib8xxx.o? We should avoid putting hardware-specific things in generic Makefiles. There ones that are already there should be fixed at some point.
-Scott
This patch needs to be broken into several patches that each take care of one logical problem; it's too hard to properly review (and have the right people pay attention to certain parts) in its current state. [Zhang Ying] It only can be broken to two patches, one for SD boot, another for SPI boot.
Aren't you breaking the existing minimal targets? CONFIG_SPL_BUILD_MINIMAL does not currently exist, and you add it only for P1022DS. [Zhang Ying] Yes, it needs to be added for other existing boards that defines CONFIG_SPL_INIT_MINIMAL. It should include p1_p2_rdb_pc.
This seems unrelated. [Zhang Ying] It is necessary. In the function clear_bss(), the address of bss is on the basis of the __bss_start, and then to four bytes of incremental growth, finally the last stop is based on the address and __bss_end is equal or not.
free(tmp_buf);
return;
Why do you need this cast? [Zhang Ying] The offset 0x1FE of the config data sector should contain the value 0x55AA. If the value in this location doesn't match 0x55AA, it means that the SD/MMC card doesn't contain a valid user code.
rather
(uchar
free(tmp_buf);
return ;
No space before ;
That return is pointless since you're at the end of the function anyway. [Zhang Ying] Ok, I can hang the cpu and print the error information.
- MA 02111-1307 USA
+int mmc_get_env_addr(struct mmc *mmc, u32 *env_addr); void +mmc_get_env(void); void mmc_boot(void);
Does this stuff really belong in board/freescale? Should probably at least be in arch/powerpc/cpu/mpc85xx, if not more generic. [Zhang Ying] Ok, whether we can handle like this: sdhc_boot.c and spi_boot.c will be deleted. All this stuff in the sdhc_boot.c will be moved to drivers/mmc/fsl_esdhc.c, and the functions in the spi_boot.c will be moved to drivers/mmc/fsl_espi.c.
+void hang(void) +{
- for (;;)
Whitespace [Zhang Ying] ?
Can ddr_spd.o and hwconfig just use their normal CONFIG symbols (i.e. move the existing makefile line out of the !SPL ifdef)? It's getting a bit excessive with all the new SPL symbols. [Zhang Ying] If do it, the SPL's size will increase. I fear this will affect the other SPL no CONFIG_SPL_NET_SUPPORT is defined.
+Building +========
- $ make
s/Hint/Example/ and s/from SD I would run/from SD, run/ [Zhang Ying] run bootsd? This is another independent requirement. If we want, we can do it in another project.
As with common/Makefile, Can these just be the normal makefile lines, moved outside the SPL ifdef (and no duplications with CONFIG_SPL_NET_SUPPORT)? [Zhang Ying] Mentioned.
-Scott
You can also separate out logical changes in support of your eventual goal (as it looks like you already started doing with the CONFIG_SPL_ENV_SUPPORT patch and such).
It may be necessary, but I don't see what it has to do with SD/SPI boot other than by chance. Make this a separate patch with a changelog that explains the problem.
free(tmp_buf);
return;
But why do you need to cast ESDHC_BOOT_IMAGE_SIGN to (u16)?
And the other cast probably violates C99 aliasing rules.
License
- MA 02111-1307 USA
Maybe drivers/mmc/fsl_espi_spl.c and such?
+void hang(void) +{
- for (;;)
I'm not sure what I meant here. :-P
Maybe I meant to put this comment elsewhere, or trimmed the wrong context...
0e0fff1..bc80414
Which SPL in particular are you concerned about, that uses common/Makefile at all, and have CONFIG_SPD and/or CONFIG_HWCONFIG? How much will they grow, after gc-sections (mainly all that's left is anonymous strings)?
media.
would
Hmm? I was just fixing up the wording -- change "Hint" to "Example" and change "from SD I would run" to "from SD, run".
That said, yes I would like to see "run bootsd". :-)
-Scott
Why isn't this handled as part of lib8xxx.o? We should avoid putting hardware-specific things in generic Makefiles. There ones that are already there should be fixed at some point. [Zhang Ying] Do you mean that all things of the directory " arch/powerpc/cpu/mpc8xxx/ddr " will be moved to the directory "arch/powerpc/cpu/mpc8xxx/"?
No. I meant that arch/powerpc/cpu/mpc8xxx/Makefile should contain the LIBS addition for the subdirectory, but apparently it doesn't work that way even in non-SPL. So ignore this; it's more of a future makefile cleanup issue.
-Scott
Scott Wood
Zhang Ying-B40530
