[U-Boot] [RFC PATCH 0/8] IPv6 support
This series adds basic IPv6 support to U-boot. It is a reboot of my earlier work on this[1]. Technically this is v4 of the series but with the amount of time that has passed, rebasing and running though checkpatch as well as the support for TFTP I've decided to reset the counter back to 1.
Most of this is ported from Allied Telesis' additions to u-boot[2]. (Note that I am employed by Allied Telesis[3]). The hard work was done some time ago by Angga, I've cleaned it up and made some improvements with the hope of getting it accepted upstream.
A few open issues/questions
1) Presumably the majority of the actual V6 code would be included by a config option. How far should I take that? Should the vsprintf code be conditional? I'm also not sure where to draw the line between CONFIG_NET6 and CONFIG_CMD_NET6, CONFIG_NET and CONFIG_CMD_NET look similarly confused.
2) This code parallels net.c and net.h. Should I continue this for the final version or integrate it into net.[ch].
3) rxhand_f currently takes an struct in_addr *. TFTP doesn't use this (I haven't looked at other users). To support V6 this may need to be a new union, a void * with some kind of flag or nothing if no rxhandler actually cares.
Regards, Chris -- [1] - http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/151390 [2] - http://www.alliedtelesis.co.nz/support/gpl/other.html [3] - some of this has been done on work time, other parts have been done in my personal time. Since I'm subscribed to the list using my gmail account I've signed using that.
Chris Packham (8): Initial net6.h lib: vsprintf: add IPv6 compressed format %pI6c lib: net_utils: make string_to_ip stricter lib: net_utils: add string_to_ip6 net: ipv6 support net: TFTP over IPv6 net: IPv6 documentation net: e1000 enable multicast reception
README | 3 + common/Kconfig | 15 ++ common/cmd_net.c | 41 +++++ doc/README.ipv6 | 34 ++++ drivers/net/e1000.c | 5 + include/env_callback.h | 9 + include/env_flags.h | 10 ++ include/net.h | 5 +- include/net6.h | 280 +++++++++++++++++++++++++++++++ lib/net_utils.c | 132 ++++++++++++++- lib/vsprintf.c | 144 +++++++++++++--- net/Kconfig | 5 + net/Makefile | 3 + net/ndisc.c | 269 ++++++++++++++++++++++++++++++ net/ndisc.h | 27 +++ net/net.c | 39 ++++- net/net6.c | 439 +++++++++++++++++++++++++++++++++++++++++++++++++ net/ping6.c | 111 +++++++++++++ net/tftp.c | 37 +++++ 19 files changed, 1583 insertions(+), 25 deletions(-) create mode 100644 doc/README.ipv6 create mode 100644 include/net6.h create mode 100644 net/ndisc.c create mode 100644 net/ndisc.h create mode 100644 net/net6.c create mode 100644 net/ping6.c
The initial net6.h just has the definition of an IPv6 address and IPv6 header. Subsequent changes will build on this.
Signed-off-by: Chris Packham judge.packham@gmail.com --- It may make sense to include this in net.h but for now I haven't done so.
include/net6.h | 48 ++++++++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 48 insertions(+) create mode 100644 include/net6.h
diff --git a/include/net6.h b/include/net6.h new file mode 100644 index 0000000..b622951 --- /dev/null +++ b/include/net6.h @@ -0,0 +1,48 @@ +/** + * Simple IPv6 network layer implementation. + * + * Based and/or adapted from the IPv4 network layer in net.[hc] + * + * (C) Copyright 2013 Allied Telesis Labs NZ + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#ifndef __NET6_H__ +#define __NET6_H__ + +struct in6_addr { + union { + __u8 u6_addr8[16]; + __be16 u6_addr16[8]; + __be32 u6_addr32[4]; + } in6_u; + +#define s6_addr in6_u.u6_addr8 +#define s6_addr16 in6_u.u6_addr16 +#define s6_addr32 in6_u.u6_addr32 +}; + +/** + * struct ipv6hdr - Internet Protocol V6 (IPv6) header. + * + * IPv6 packet header as defined in RFC 2460. + */ +struct ip6_hdr { +#if defined(__LITTLE_ENDIAN_BITFIELD) + __u8 priority:4, + version:4; +#elif defined(__BIG_ENDIAN_BITFIELD) + __u8 version:4, + priority:4; +#else +#error "Please fix <asm/byteorder.h>" +#endif + __u8 flow_lbl[3]; + __be16 payload_len; + __u8 nexthdr; + __u8 hop_limit; + struct in6_addr saddr; + struct in6_addr daddr; +}; + +#endif /* __NET6_H__ */
Hi Chris,
On Mon, Oct 12, 2015 at 2:43 AM, Chris Packham judge.packham@gmail.com wrote:
I think it's good to keep it separate to start.
- Simple IPv6 network layer implementation.
- Based and/or adapted from the IPv4 network layer in net.[hc]
- (C) Copyright 2013 Allied Telesis Labs NZ
+struct in6_addr {
union {
__u8 u6_addr8[16];
} in6_u;
- struct ipv6hdr - Internet Protocol V6 (IPv6) header.
- IPv6 packet header as defined in RFC 2460.
__u8 priority:4,
version:4;
__u8 version:4,
priority:4;
__u8 flow_lbl[3];
__be16 payload_len;
__u8 nexthdr;
__u8 hop_limit;
2.5.3
Add support for "human friendly" IPv6 address representations as specified in http://tools.ietf.org/html/draft-ietf-6man-text-addr-representation-00
This code has been adapted from Linux kernel with minimal modification.
include/net6.h | 13 ++++++ lib/vsprintf.c | 144 +++++++++++++++++++++++++++++++++++++++++++++++++-------- 2 files changed, 137 insertions(+), 20 deletions(-)
diff --git a/include/net6.h b/include/net6.h index b622951..1b82c25 100644 --- a/include/net6.h +++ b/include/net6.h @@ -45,4 +45,17 @@ struct ip6_hdr { struct in6_addr daddr; };
+/* ::ffff:0:0/96 is reserved for v4 mapped addresses */ +static inline int ipv6_addr_v4mapped(const struct in6_addr *a) +{ + return (a->s6_addr32[0] | a->s6_addr32[1] | + (a->s6_addr32[2] ^ htonl(0x0000ffff))) == 0; +} + +/* Intra-Site Automatic Tunnel Addressing Protocol Address */ +static inline int ipv6_addr_is_isatap(const struct in6_addr *a) +{ + return (a->s6_addr32[2] | htonl(0x02000000)) == htonl(0x02005EFE); +} + #endif /* __NET6_H__ */ diff --git a/lib/vsprintf.c b/lib/vsprintf.c index 4c82837..349234a 100644 --- a/lib/vsprintf.c +++ b/lib/vsprintf.c @@ -23,6 +23,7 @@ #endif
#include <div64.h> +#include <net6.h> #define noinline __attribute__((noinline))
unsigned long simple_strtoul(const char *cp, char **endp, @@ -304,6 +305,7 @@ static noinline char *put_dec(char *buf, uint64_t num) #define LEFT 16 /* left justified */ #define SMALL 32 /* Must be 32 == 0x20 */ #define SPECIAL 64 /* 0x */ +#define COMPRESSED 128 /* use compressed format */
#ifdef CONFIG_SYS_VSNPRINTF /* @@ -469,12 +471,108 @@ static char *mac_address_string(char *buf, char *end, u8 *addr, int field_width, flags & ~SPECIAL); }
-static char *ip6_addr_string(char *buf, char *end, u8 *addr, int field_width, - int precision, int flags) +static char *ip4_string(char *p, u8 *addr) +{ + char temp[3]; /* hold each IP quad in reverse order */ + int i, digits; + + for (i = 0; i < 4; i++) { + digits = put_dec_trunc(temp, addr[i]) - temp; + /* reverse the digits in the quad */ + while (digits--) + *p++ = temp[digits]; + if (i != 3) + *p++ = '.'; + } + *p = '\0'; + + return p; +} + +static char *ip6_compressed_string(char *p, u8 *addr) +{ + int i, j, range; + unsigned char zerolength[8]; + int longest = 1; + int colonpos = -1; + u16 word; + u8 hi, lo; + int needcolon = 0; + int useIPv4; + struct in6_addr in6; + + memcpy(&in6, addr, sizeof(struct in6_addr)); + + useIPv4 = ipv6_addr_v4mapped(&in6) || ipv6_addr_is_isatap(&in6); + + memset(zerolength, 0, sizeof(zerolength)); + + if (useIPv4) + range = 6; + else + range = 8; + + /* find position of longest 0 run */ + for (i = 0; i < range; i++) { + for (j = i; j < range; j++) { + if (in6.s6_addr16[j] != 0) + break; + zerolength[i]++; + } + } + for (i = 0; i < range; i++) { + if (zerolength[i] > longest) { + longest = zerolength[i]; + colonpos = i; + } + } + if (longest == 1) /* don't compress a single 0 */ + colonpos = -1; + + /* emit address */ + for (i = 0; i < range; i++) { + if (i == colonpos) { + if (needcolon || i == 0) + *p++ = ':'; + *p++ = ':'; + needcolon = 0; + i += longest - 1; + continue; + } + if (needcolon) { + *p++ = ':'; + needcolon = 0; + } + /* hex u16 without leading 0s */ + word = ntohs(in6.s6_addr16[i]); + hi = word >> 8; + lo = word & 0xff; + if (hi) { + if (hi > 0x0f) + p = pack_hex_byte(p, hi); + else + *p++ = hex_asc_lo(hi); + p = pack_hex_byte(p, lo); + } else if (lo > 0x0f) { + p = pack_hex_byte(p, lo); + } else { + *p++ = hex_asc_lo(lo); + } + needcolon = 1; + } + + if (useIPv4) { + if (needcolon) + *p++ = ':'; + p = ip4_string(p, &in6.s6_addr[12]); + } + *p = '\0'; + + return p; +} + +static char *ip6_string(char *p, u8 *addr, int flags) { - /* (8 * 4 hex digits), 7 colons and trailing zero */ - char ip6_addr[8 * 5]; - char *p = ip6_addr; int i;
for (i = 0; i < 8; i++) { @@ -485,6 +583,19 @@ static char *ip6_addr_string(char *buf, char *end, u8 *addr, int field_width, } *p = '\0';
+ return p; +} + +static char *ip6_addr_string(char *buf, char *end, u8 *addr, int field_width, + int precision, int flags) +{ + char ip6_addr[sizeof("xxxx:xxxx:xxxx:xxxx:xxxx:xxxx:255.255.255.255")]; + + if (flags & COMPRESSED) + ip6_compressed_string(ip6_addr, addr); + else + ip6_string(ip6_addr, addr, flags); + return string(buf, end, ip6_addr, field_width, precision, flags & ~SPECIAL); } @@ -492,21 +603,9 @@ static char *ip6_addr_string(char *buf, char *end, u8 *addr, int field_width, static char *ip4_addr_string(char *buf, char *end, u8 *addr, int field_width, int precision, int flags) { - /* (4 * 3 decimal digits), 3 dots and trailing zero */ - char ip4_addr[4 * 4]; - char temp[3]; /* hold each IP quad in reverse order */ - char *p = ip4_addr; - int i, digits; + char ip4_addr[sizeof("255.255.255.255")];
- for (i = 0; i < 4; i++) { - digits = put_dec_trunc(temp, addr[i]) - temp; - /* reverse the digits in the quad */ - while (digits--) - *p++ = temp[digits]; - if (i != 3) - *p++ = '.'; - } - *p = '\0'; + ip4_string(ip4_addr, addr);
return string(buf, end, ip4_addr, field_width, precision, flags & ~SPECIAL); @@ -526,6 +625,8 @@ static char *ip4_addr_string(char *buf, char *end, u8 *addr, int field_width, * decimal for v4 and colon separated network-order 16 bit hex for v6) * - 'i' [46] for 'raw' IPv4/IPv6 addresses, IPv6 omits the colons, IPv4 is * currently the same + * - 'I6c' for IPv6 addresses printed as specified by + * http://tools.ietf.org/html/rfc5952 * * Note: The difference between 'S' and 'F' is that on ia64 and ppc64 * function pointers are really function descriptors, which contain a @@ -569,9 +670,12 @@ static char *pointer(const char *fmt, char *buf, char *end, void *ptr, flags |= SPECIAL; /* Fallthrough */ case 'I': - if (fmt[1] == '6') + if (fmt[1] == '6') { + if (fmt[2] == 'c') + flags |= COMPRESSED; return ip6_addr_string(buf, end, ptr, field_width, precision, flags); + } if (fmt[1] == '4') return ip4_addr_string(buf, end, ptr, field_width, precision, flags);
Hi Chris,
Seems reasonable to me. It should be behind a #ifdef CONFIG_NET6 check, though.
Previously values greater than 255 were implicitly truncated. Add some stricter checking to reject addresses with components >255.
With the input "1234192.168.1.1" the old behaviour would truncate the address to 192.168.1.1. New behaviour rejects the string outright and returns 0.0.0.0, which for the purposes of IP addresses can be considered an error.
lib/net_utils.c | 13 +++++++++++-- 1 file changed, 11 insertions(+), 2 deletions(-)
diff --git a/lib/net_utils.c b/lib/net_utils.c index cfae842..0fca54d 100644 --- a/lib/net_utils.c +++ b/lib/net_utils.c @@ -24,10 +24,19 @@ struct in_addr string_to_ip(const char *s)
for (addr.s_addr = 0, i = 0; i < 4; ++i) { ulong val = s ? simple_strtoul(s, &e, 10) : 0; + if (val > 255) { + addr.s_addr = 0; + return addr; + } addr.s_addr <<= 8; addr.s_addr |= (val & 0xFF); - if (s) { - s = (*e) ? e+1 : e; + if (*e == '.') { + s = e + 1; + } else if (*e == '\0') { + break; + } else { + addr.s_addr = 0; + return addr; } }
Hi Chris,
On Mon, Oct 12, 2015 at 8:43 PM, Chris Packham judge.packham@gmail.com wrote:
if (val > 255) {
addr.s_addr = 0;
return addr;
if (s) {
s = (*e) ? e+1 : e;
if (*e == '.') {
s = e + 1;
break;
} else {
addr.s_addr = 0;
return addr;
One unintended side effect of this is that is breaks parsing of things like 'tftpboot 192.168.1.1:zImage'. I'll fix that in the next round.
-- 2.5.3
string_to_ip6 parses an IPv6 address from a string. Parsing v6 addresses is a bit more complicated than parsing v4 because there are a number of different formats that can be used.
Signed-off-by: Chris Packham judge.packham@gmail.com --- I'm sure the parsing can be better and done in less code with only a single pass but I haven't yet figured it out. The main problem is that "::" can represent a variable number of contiguous "0000:" so when parsing "::" we can't tell how many half words to skip.
include/net6.h | 3 ++ lib/net_utils.c | 119 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 2 files changed, 122 insertions(+)
diff --git a/include/net6.h b/include/net6.h index 1b82c25..a41eb87 100644 --- a/include/net6.h +++ b/include/net6.h @@ -58,4 +58,7 @@ static inline int ipv6_addr_is_isatap(const struct in6_addr *a) return (a->s6_addr32[2] | htonl(0x02000000)) == htonl(0x02005EFE); }
+/* Convert a string to an ipv6 address */ +int string_to_ip6(const char *s, struct in6_addr *addr); + #endif /* __NET6_H__ */ diff --git a/lib/net_utils.c b/lib/net_utils.c index 0fca54d..b0d0364 100644 --- a/lib/net_utils.c +++ b/lib/net_utils.c @@ -11,6 +11,8 @@ */
#include <common.h> +#include <net6.h> +#include <linux/ctype.h>
struct in_addr string_to_ip(const char *s) { @@ -43,3 +45,120 @@ struct in_addr string_to_ip(const char *s) addr.s_addr = htonl(addr.s_addr); return addr; } + +/** + * Parses an struct in6_addr from the given string. IPv6 address parsing is a bit + * more complicated than v4 due to the flexible format and some of the special + * cases (e.g. v4 mapped). + * + * Examples of valid strings: + * 2001:db8::0:1234:1 + * 2001:0db8:0000:0000:0000:0000:1234:0001 + * ::1 + * ::ffff:192.168.1.1 + * + * Examples of invalid strings + * 2001:db8::0::0 (:: can only appear once) + * 2001:db8:192.168.1.1::1 (v4 part can only appear at the end) + * 192.168.1.1 (we don't implicity map v4) + */ +int string_to_ip6(const char *strpt, struct in6_addr *addrpt) +{ + int colon_count = 0; + int found_double_colon = 0; + int xstart = 0; /* first zero (double colon) */ + int len = 7; /* num words the double colon represents */ + int i; + const char *s = strpt; + struct in_addr zero_ip = {.s_addr = 0}; + + if (strpt == NULL) + return -1; + + /* First pass, verify the syntax and locate the double colon */ + for (;;) { + while (isxdigit((int)*s)) + s++; + if (*s == '\0') + break; + if (*s != ':') { + if (*s == '.' && len >= 2) { + struct in_addr v4; + while (s != strpt && *(s - 1) != ':') + --s; + v4 = string_to_ip(s); + if (memcmp(&zero_ip, &v4, + sizeof(struct in_addr) != 0)) { + len -= 2; + break; + } + } + /* This could be a valid address */ + break; + } + if (s == strpt) { + /* The address begins with a colon */ + if (*++s != ':') + /* Must start with a double colon or a number */ + goto out_err; + } else { + s++; + if (found_double_colon) + len--; + else + xstart++; + } + + if (*s == ':') { + if (found_double_colon) + /* Two double colons are not allowed */ + goto out_err; + found_double_colon = 1; + len -= xstart; + s++; + } + + if (++colon_count == 7) + /* Found all colons */ + break; + } + + if (colon_count == 0 || colon_count > 7) + goto out_err; + if (*--s == ':') + len++; + + /* Second pass, read the address */ + s = strpt; + for (i = 0; i < 8; i++) { + int val = 0; + char *end; + + if (found_double_colon && i >= xstart && i < xstart + len) { + addrpt->s6_addr16[i] = 0; + continue; + } + while (*s == ':') + s++; + + if (i == 6 && isdigit((int)*s)) { + struct in_addr v4 = string_to_ip(s); + if (memcmp(&zero_ip, &v4, + sizeof(struct in_addr)) != 0) { + /* Ending with :IPv4-address */ + addrpt->s6_addr32[3] = v4.s_addr; + break; + } + } + + val = simple_strtoul(s, &end, 16); + if (*end != '\0' && *end != ':') + goto out_err; + addrpt->s6_addr16[i] = htons(val); + s = end; + } + return 0; + +out_err: + return -1; +}
Hi Chris,
- Parses an struct in6_addr from the given string. IPv6 address parsing is a bit
- more complicated than v4 due to the flexible format and some of the special
- cases (e.g. v4 mapped).
- Examples of valid strings:
- 2001:db8::0:1234:1
- 2001:0db8:0000:0000:0000:0000:1234:0001
- ::1
- ::ffff:192.168.1.1
- Examples of invalid strings
- 2001:db8::0::0 (:: can only appear once)
- 2001:db8:192.168.1.1::1 (v4 part can only appear at the end)
- 192.168.1.1 (we don't implicity map v4)
int i;
if (strpt == NULL)
return -1;
for (;;) {
s++;
if (*s == '\0')
break;
if (*s != ':') {
struct in_addr v4;
--s;
len -= 2;
break;
break;
if (s == strpt) {
if (*++s != ':')
goto out_err;
} else {
s++;
len--;
else
xstart++;
if (*s == ':') {
goto out_err;
len -= xstart;
s++;
break;
goto out_err;
Above you bail out if colon_count == 7 so how could it be greater here? My guess is you need to use strchr() to check for additional colons in the remaining string.
if (*--s == ':')
len++;
s = strpt;
int val = 0;
char *end;
continue;
while (*s == ':')
s++;
break;
goto out_err;
s = end;
+out_err:
return -1;
I tend to think we can revisit this to make it more concise in the future. Assuming this is functional, it is better to have a solution even if it's not the perfect solution.
Cheers, -Joe
Adds basic support for IPv6. Neighbor discovery and ping6 are the only things supported at the moment.
Helped-by: Hanna Hawa hannah@marvell.com [endian & alignment fixes] Signed-off-by: Chris Packham judge.packham@gmail.com --- Now we have something functional. With this you can do something like 'setenv ipaddr6 3ffe::2' and 'ping6 3ffe::1' should work.
I seem to have a problem that when you send a ping6 for a non-existent address that ends up stuck and the next non-ipv6 net operation tries to resolve it. I suspect this is because the pending neighbor discovery information isn't cleaned up properly, I need to look into that.
The environment variable prefixlength6 is a bit fiddly. No-one uses a netmask6 (it'd mean a lot of ffff:ffff:...) it's almost always done by including the prefix length in the address (e.g. ip addr add 2001:db8::1/64) I'm contemplating adopting that syntax and dropping prefixlength6.
This patch is bigger than I'd like it to be but I'm not sure how to split it up and keep the parts build able.
common/Kconfig | 15 ++ common/cmd_net.c | 28 ++++ include/env_callback.h | 9 ++ include/env_flags.h | 10 ++ include/net.h | 5 +- include/net6.h | 212 ++++++++++++++++++++++++++++ net/Kconfig | 5 + net/Makefile | 3 + net/ndisc.c | 269 +++++++++++++++++++++++++++++++++++ net/ndisc.h | 27 ++++ net/net.c | 36 ++++- net/net6.c | 375 +++++++++++++++++++++++++++++++++++++++++++++++++ net/ping6.c | 111 +++++++++++++++ 13 files changed, 1102 insertions(+), 3 deletions(-) create mode 100644 net/ndisc.c create mode 100644 net/ndisc.h create mode 100644 net/net6.c create mode 100644 net/ping6.c
diff --git a/common/Kconfig b/common/Kconfig index 2c42b8e..c72563d 100644 --- a/common/Kconfig +++ b/common/Kconfig @@ -389,6 +389,15 @@ config CMD_NET bootp - boot image via network using BOOTP/TFTP protocol tftpboot - boot image via network using TFTP protocol
+config CMD_NET6 + bool "ipv6 commands" + select NET + select NET6 + default n + help + IPv6 network commands + tftpboot6 - boot image via network using TFTP protocol + config CMD_TFTPPUT bool "tftp put" help @@ -420,6 +429,12 @@ config CMD_PING help Send ICMP ECHO_REQUEST to network host
+config CMD_PING6 + bool "ping6" + depends on CMD_NET6 + help + Send ICMPv6 ECHO_REQUEST to network host + config CMD_CDP bool "cdp" help diff --git a/common/cmd_net.c b/common/cmd_net.c index b2f3c7b..271f91d 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -11,6 +11,7 @@ #include <common.h> #include <command.h> #include <net.h> +#include <net6.h>
static int netboot_common(enum proto_t, cmd_tbl_t *, int, char * const []);
@@ -284,6 +285,33 @@ U_BOOT_CMD( ); #endif
+#ifdef CONFIG_CMD_PING6 +int do_ping6(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + if (argc < 2) + return -1; + + if (string_to_ip6(argv[1], &net_ping_ip6) != 0) + return CMD_RET_USAGE; + + if (net_loop(PING6) < 0) { + printf("ping6 failed; host %pI6c is not alive\n", + &net_ping_ip6); + return 1; + } + + printf("host %pI6c is alive\n", &net_ping_ip6); + + return 0; +} + +U_BOOT_CMD( + ping6, 2, 1, do_ping6, + "send ICMPv6 ECHO_REQUEST to network host", + "pingAddress" +); +#endif /* CONFIG_CMD_PING6 */ + #if defined(CONFIG_CMD_CDP)
static void cdp_update_env(void) diff --git a/include/env_callback.h b/include/env_callback.h index 90b95b5..9027f3f 100644 --- a/include/env_callback.h +++ b/include/env_callback.h @@ -60,6 +60,14 @@ #define NET_CALLBACKS #endif
+#ifdef CONFIG_NET6 +#define NET6_CALLBACKS \ + "ip6addr:ip6addr," \ + "serverip6:serverip6," \ + "prefixlength6:prefixlength6," +#else +#define NET6_CALLBACKS +#endif /* * This list of callback bindings is static, but may be overridden by defining * a new association in the ".callbacks" environment variable. @@ -68,6 +76,7 @@ ENV_DOT_ESCAPE ENV_FLAGS_VAR ":flags," \ "baudrate:baudrate," \ NET_CALLBACKS \ + NET6_CALLBACKS \ "loadaddr:loadaddr," \ SILENT_CALLBACK \ SPLASHIMAGE_CALLBACK \ diff --git a/include/env_flags.h b/include/env_flags.h index 8823fb9..6e1891d 100644 --- a/include/env_flags.h +++ b/include/env_flags.h @@ -65,6 +65,15 @@ enum env_flags_varaccess { #define NET_FLAGS #endif
+#ifdef CONFIG_CMD_NET6 +#define NET6_FLAGS \ + "ip6addr:s," \ + "serverip6:s," \ + "prefixlength6:d," +#else +#define NET6_FLAGS +#endif + #ifndef CONFIG_ENV_OVERWRITE #define SERIAL_FLAGS "serial#:so," #else @@ -74,6 +83,7 @@ enum env_flags_varaccess { #define ENV_FLAGS_LIST_STATIC \ ETHADDR_FLAGS \ NET_FLAGS \ + NET6_FLAGS \ SERIAL_FLAGS \ CONFIG_ENV_FLAGS_LIST_STATIC
diff --git a/include/net.h b/include/net.h index 3a787cc..4f59609 100644 --- a/include/net.h +++ b/include/net.h @@ -316,6 +316,7 @@ struct vlan_ethernet_hdr { #define VLAN_ETHER_HDR_SIZE (sizeof(struct vlan_ethernet_hdr))
#define PROT_IP 0x0800 /* IP protocol */ +#define PROT_IP6 0x86DD /* IPv6 protocol */ #define PROT_ARP 0x0806 /* IP ARP protocol */ #define PROT_RARP 0x8035 /* IP ARP protocol */ #define PROT_VLAN 0x8100 /* IEEE 802.1q protocol */ @@ -512,8 +513,8 @@ extern ushort net_native_vlan; /* Our Native VLAN */ extern int net_restart_wrap; /* Tried all network devices */
enum proto_t { - BOOTP, RARP, ARP, TFTPGET, DHCP, PING, DNS, NFS, CDP, NETCONS, SNTP, - TFTPSRV, TFTPPUT, LINKLOCAL + BOOTP, RARP, ARP, TFTPGET, DHCP, PING, PING6, DNS, NFS, CDP, NETCONS, + SNTP, TFTPSRV, TFTPPUT, TFTP6, LINKLOCAL };
extern char net_boot_file_name[128];/* Boot File name */ diff --git a/include/net6.h b/include/net6.h index a41eb87..a0374df 100644 --- a/include/net6.h +++ b/include/net6.h @@ -22,6 +22,16 @@ struct in6_addr { #define s6_addr32 in6_u.u6_addr32 };
+#define IN6ADDRSZ sizeof(struct in6_addr) +#define INETHADDRSZ sizeof(net_ethaddr) + +#define IPV6_ADDRSCOPE_INTF 0x01 +#define IPV6_ADDRSCOPE_LINK 0x02 +#define IPV6_ADDRSCOPE_AMDIN 0x04 +#define IPV6_ADDRSCOPE_SITE 0x05 +#define IPV6_ADDRSCOPE_ORG 0x08 +#define IPV6_ADDRSCOPE_GLOBAL 0x0E + /** * struct ipv6hdr - Internet Protocol V6 (IPv6) header. * @@ -45,6 +55,154 @@ struct ip6_hdr { struct in6_addr daddr; };
+#define IP6_HDR_SIZE (sizeof(struct ip6_hdr)) + +/* Handy for static initialisations of struct in6_addr, atlhough the + * c99 '= { 0 }' idiom might work depending on you compiler. */ +#define ZERO_IPV6_ADDR { { { 0x00, 0x00, 0x00, 0x00, \ + 0x00, 0x00, 0x00, 0x00, \ + 0x00, 0x00, 0x00, 0x00, \ + 0x00, 0x00, 0x00, 0x00 } } } + +#define IPV6_LINK_LOCAL_PREFIX 0xfe80 + +struct udp_hdr { + __be16 udp_src; /* UDP source port */ + __be16 udp_dst; /* UDP destination port */ + __be16 udp_len; /* Length of UDP packet */ + __be16 udp_xsum; /* Checksum */ +}; + +#define IP6_UDPHDR_SIZE (sizeof(struct udp_hdr)) + +enum { + __ND_OPT_PREFIX_INFO_END = 0, + ND_OPT_SOURCE_LL_ADDR = 1, + ND_OPT_TARGET_LL_ADDR = 2, + ND_OPT_PREFIX_INFO = 3, + ND_OPT_REDIRECT_HDR = 4, + ND_OPT_MTU = 5, + __ND_OPT_MAX +}; + +/* ICMPv6 */ +#define IPPROTO_ICMPV6 58 +/* hop limit for neighbour discovery packets */ +#define IPV6_NDISC_HOPLIMIT 255 +#define NDISC_TIMEOUT 5000UL +#define NDISC_TIMEOUT_COUNT 3 + +struct icmp6hdr { + __u8 icmp6_type; +#define IPV6_ICMP_ECHO_REQUEST 128 +#define IPV6_ICMP_ECHO_REPLY 129 +#define IPV6_NDISC_ROUTER_SOLICITATION 133 +#define IPV6_NDISC_ROUTER_ADVERTISEMENT 134 +#define IPV6_NDISC_NEIGHBOUR_SOLICITATION 135 +#define IPV6_NDISC_NEIGHBOUR_ADVERTISEMENT 136 +#define IPV6_NDISC_REDIRECT 137 + __u8 icmp6_code; + __be16 icmp6_cksum; + + union { + __be32 un_data32[1]; + __be16 un_data16[2]; + __u8 un_data8[4]; + + struct icmpv6_echo { + __be16 identifier; + __be16 sequence; + } u_echo; + + struct icmpv6_nd_advt { +#if defined(__LITTLE_ENDIAN_BITFIELD) + __be32 reserved:5, + override:1, + solicited:1, + router:1, + reserved2:24; +#elif defined(__BIG_ENDIAN_BITFIELD) + __be32 router:1, + solicited:1, + override:1, + reserved:29; +#else +#error "Please fix <asm/byteorder.h>" +#endif + } u_nd_advt; + + struct icmpv6_nd_ra { + __u8 hop_limit; +#if defined(__LITTLE_ENDIAN_BITFIELD) + __u8 reserved:6, + other:1, + managed:1; + +#elif defined(__BIG_ENDIAN_BITFIELD) + __u8 managed:1, + other:1, + reserved:6; +#else +#error "Please fix <asm/byteorder.h>" +#endif + __be16 rt_lifetime; + } u_nd_ra; + } icmp6_dataun; +#define icmp6_identifier icmp6_dataun.u_echo.identifier +#define icmp6_sequence icmp6_dataun.u_echo.sequence +#define icmp6_pointer icmp6_dataun.un_data32[0] +#define icmp6_mtu icmp6_dataun.un_data32[0] +#define icmp6_unused icmp6_dataun.un_data32[0] +#define icmp6_maxdelay icmp6_dataun.un_data16[0] +#define icmp6_router icmp6_dataun.u_nd_advt.router +#define icmp6_solicited icmp6_dataun.u_nd_advt.solicited +#define icmp6_override icmp6_dataun.u_nd_advt.override +#define icmp6_ndiscreserved icmp6_dataun.u_nd_advt.reserved +#define icmp6_hop_limit icmp6_dataun.u_nd_ra.hop_limit +#define icmp6_addrconf_managed icmp6_dataun.u_nd_ra.managed +#define icmp6_addrconf_other icmp6_dataun.u_nd_ra.other +#define icmp6_rt_lifetime icmp6_dataun.u_nd_ra.rt_lifetime +}; + +struct nd_msg { + struct icmp6hdr icmph; + struct in6_addr target; + __u8 opt[0]; +}; + +struct rs_msg { + struct icmp6hdr icmph; + __u8 opt[0]; +}; + +struct ra_msg { + struct icmp6hdr icmph; + __u32 reachable_time; + __u32 retrans_timer; +}; + +struct echo_msg { + struct icmp6hdr icmph; + __u16 id; + __u16 sequence; +}; + +struct nd_opt_hdr { + __u8 nd_opt_type; + __u8 nd_opt_len; +} __attribute__((__packed__)); + +extern struct in6_addr const net_null_addr_ip6; /* NULL IPv6 address */ +extern struct in6_addr net_gateway6; /* Our gateways IPv6 address */ +extern struct in6_addr net_ip6; /* Our IPv6 addr (0 = unknown) */ +extern struct in6_addr net_link_local_ip6; /* Our link local IPv6 addr */ +extern u_int32_t net_prefix_length; /* Our prefixlength (0 = unknown) */ +extern struct in6_addr net_server_ip6; /* Server IPv6 addr (0 = unknown) */ + +#ifdef CONFIG_CMD_PING +extern struct in6_addr net_ping_ip6; /* the ipv6 address to ping */ +#endif + /* ::ffff:0:0/96 is reserved for v4 mapped addresses */ static inline int ipv6_addr_v4mapped(const struct in6_addr *a) { @@ -61,4 +219,58 @@ static inline int ipv6_addr_is_isatap(const struct in6_addr *a) /* Convert a string to an ipv6 address */ int string_to_ip6(const char *s, struct in6_addr *addr);
+/* check that an IPv6 address is unspecified (zero) */ +int ip6_is_unspecified_addr(struct in6_addr *addr); + +/* check that an IPv6 address is ours */ +int ip6_is_our_addr(struct in6_addr *addr); + +void ip6_make_lladdr(struct in6_addr *lladr, unsigned char const enetaddr[6]); + +void ip6_make_SNMA(struct in6_addr *mcast_addr, struct in6_addr *ip6_addr); + +void ip6_make_mult_ethdstaddr(unsigned char enetaddr[6], + struct in6_addr *mcast_addr); + +/* check if neighbour is in the same subnet as us */ +int ip6_addr_in_subnet(struct in6_addr *our_addr, struct in6_addr *neigh_addr, + __u32 prefix_length); + +unsigned int csum_partial(const unsigned char *buff, int len, unsigned int sum); + +unsigned short int csum_ipv6_magic(struct in6_addr *saddr, + struct in6_addr *daddr, __u16 len, + unsigned short proto, unsigned int csum); + +int ip6_add_hdr(uchar *xip, struct in6_addr *src, struct in6_addr *dest, + int nextheader, int hoplimit, int payload_len); + +/* send a neighbour discovery solicitation message */ +void ip6_NDISC_Request(void); + +/* call back routine when ND timer has gone off */ +void ip6_NDISC_TimeoutCheck(void); + +/* initialises the ND data */ +void ip6_NDISC_init(void); + +/* sends an IPv6 echo request to a host */ +int ping6_send(void); + +/* starts a Ping6 process */ +void ping6_start(void); + +/* handles reception of icmpv6 echo request/reply */ +void ping6_receive(struct ethernet_hdr *et, struct ip6_hdr *ip6, + int len); + +/* handler for incoming IPv6 echo packet */ +void net_ip6_handler(struct ethernet_hdr *et, struct ip6_hdr *ip6, + int len); + +/* copy IPv6 */ +static inline void net_copy_ip6(void *to, void *from) +{ + memcpy((void *)to, from, sizeof(struct in6_addr)); +} #endif /* __NET6_H__ */ diff --git a/net/Kconfig b/net/Kconfig index 77a2f7e..ee198c1 100644 --- a/net/Kconfig +++ b/net/Kconfig @@ -22,4 +22,9 @@ config NETCONSOLE Support the 'nc' input/output device for networked console. See README.NetConsole for details.
+config NET6 + bool "IPv6 support" + help + Support for IPv6 + endif # if NET diff --git a/net/Makefile b/net/Makefile index e9cc8ad..a85a5c6 100644 --- a/net/Makefile +++ b/net/Makefile @@ -20,3 +20,6 @@ obj-$(CONFIG_CMD_PING) += ping.o obj-$(CONFIG_CMD_RARP) += rarp.o obj-$(CONFIG_CMD_SNTP) += sntp.o obj-$(CONFIG_CMD_NET) += tftp.o +obj-$(CONFIG_CMD_NET6) += net6.o +obj-$(CONFIG_CMD_NET6) += ndisc.o +obj-$(CONFIG_CMD_PING6) += ping6.o diff --git a/net/ndisc.c b/net/ndisc.c new file mode 100644 index 0000000..41883d7 --- /dev/null +++ b/net/ndisc.c @@ -0,0 +1,269 @@ +/* + * net/ndisc.c + * + * (C) Copyright 2013 Allied Telesis Labs NZ + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#define DEBUG +#include <common.h> +#include <net.h> +#include <net6.h> +#include "ndisc.h" + +/* IPv6 destination address of packet waiting for ND */ +struct in6_addr net_nd_sol_packet_ip6 = ZERO_IPV6_ADDR; +/* IPv6 address we are expecting ND advert from */ +struct in6_addr net_nd_rep_packet_ip6 = ZERO_IPV6_ADDR; +/* MAC destination address of packet waiting for ND */ +uchar *net_nd_packet_mac; +/* pointer to packet waiting to be transmitted after ND is resolved */ +uchar *net_nd_tx_packet; +uchar net_nd_packet_buf[PKTSIZE_ALIGN + PKTALIGN]; +/* size of packet waiting to be transmitted */ +int net_nd_tx_packet_size; +/* the timer for ND resolution */ +ulong net_nd_timer_start; +/* the number of requests we have sent so far */ +int net_nd_try; + +#define IP6_NDISC_OPT_SPACE(len) (((len)+2+7)&~7) + +/** + * Insert an iption into a neighbor discovery packet. + * Returns the number of bytes inserted (which may be >= len) + */ +static int +ip6_ndisc_insert_option(struct nd_msg *ndisc, int type, u8 *data, int len) +{ + int space = IP6_NDISC_OPT_SPACE(len); + + ndisc->opt[0] = type; + ndisc->opt[1] = space >> 3; + memcpy(&ndisc->opt[2], data, len); + len += 2; + + /* fill the remainder with 0 */ + if ((space - len) > 0) + memset(&ndisc->opt[len], 0, space - len); + + return space; +} + +/** + * Extract the Ethernet address from a neighbor discovery packet. + * Note that the link layer address could be anything but the only networking + * media that u-boot supports is Ethernet so we assume we're extracting a 6 + * byte Ethernet MAC address. + */ +static void ip6_ndisc_extract_enetaddr(struct nd_msg *ndisc, uchar enetaddr[6]) +{ + memcpy(enetaddr, &ndisc->opt[2], 6); +} + +/** + * Check to see if the neighbor discovery packet has + * the specified option set. + */ +static int ip6_ndisc_has_option(struct ip6_hdr *ip6, __u8 type) +{ + struct nd_msg *ndisc = (struct nd_msg *)(((uchar *)ip6) + IP6_HDR_SIZE); + + if (ip6->payload_len <= sizeof(struct icmp6hdr)) + return 0; + + return ndisc->opt[0] == type; +} + +static void ip6_send_ns(struct in6_addr *neigh_addr) +{ + struct in6_addr dst_adr; + unsigned char enetaddr[6]; + struct nd_msg *msg; + __u16 len; + uchar *pkt; + + debug("sending neighbor solicitation for %pI6c our address %pI6c\n", + neigh_addr, &net_link_local_ip6); + + /* calculate src, dest IPv6 addr and dest Eth addr */ + ip6_make_SNMA(&dst_adr, neigh_addr); + ip6_make_mult_ethdstaddr(enetaddr, &dst_adr); + len = sizeof(struct icmp6hdr) + IN6ADDRSZ + + IP6_NDISC_OPT_SPACE(INETHADDRSZ); + + pkt = (uchar *)net_tx_packet; + pkt += net_set_ether(pkt, enetaddr, PROT_IP6); + pkt += ip6_add_hdr(pkt, &net_link_local_ip6, &dst_adr, IPPROTO_ICMPV6, + IPV6_NDISC_HOPLIMIT, len); + + /* ICMPv6 - NS */ + msg = (struct nd_msg *)pkt; + msg->icmph.icmp6_type = IPV6_NDISC_NEIGHBOUR_SOLICITATION; + msg->icmph.icmp6_code = 0; + memset(&msg->icmph.icmp6_cksum, 0, sizeof(__be16)); + memset(&msg->icmph.icmp6_unused, 0, sizeof(__be32)); + + /* Set the target address and llsaddr option */ + net_copy_ip6(&msg->target, neigh_addr); + ip6_ndisc_insert_option(msg, ND_OPT_SOURCE_LL_ADDR, net_ethaddr, + INETHADDRSZ); + + /* checksum */ + msg->icmph.icmp6_cksum = csum_ipv6_magic(&net_link_local_ip6, &dst_adr, + len, IPPROTO_ICMPV6, + csum_partial((__u8 *)msg, len, 0)); + + pkt += len; + + /* send it! */ + net_send_packet(net_tx_packet, (pkt - net_tx_packet)); +} + +static void +ip6_send_na(uchar *eth_dst_addr, struct in6_addr *neigh_addr, + struct in6_addr *target) +{ + struct nd_msg *msg; + __u16 len; + uchar *pkt; + + debug("sending neighbor advertisement for %pI6c to %pI6c (%pM)\n", + target, neigh_addr, eth_dst_addr); + + len = sizeof(struct icmp6hdr) + IN6ADDRSZ + + IP6_NDISC_OPT_SPACE(INETHADDRSZ); + + pkt = (uchar *)net_tx_packet; + pkt += net_set_ether(pkt, eth_dst_addr, PROT_IP6); + pkt += ip6_add_hdr(pkt, &net_link_local_ip6, neigh_addr, + IPPROTO_ICMPV6, IPV6_NDISC_HOPLIMIT, len); + + /* ICMPv6 - NS */ + msg = (struct nd_msg *)pkt; + msg->icmph.icmp6_type = IPV6_NDISC_NEIGHBOUR_ADVERTISEMENT; + msg->icmph.icmp6_code = 0; + memset(&msg->icmph.icmp6_cksum, 0, sizeof(__be16)); + memset(&msg->icmph.icmp6_unused, 0, sizeof(__be32)); + + /* Set the target address and lltargetaddr option */ + net_copy_ip6(&msg->target, target); + ip6_ndisc_insert_option(msg, ND_OPT_TARGET_LL_ADDR, net_ethaddr, + INETHADDRSZ); + + /* checksum */ + msg->icmph.icmp6_cksum = csum_ipv6_magic(&net_link_local_ip6, + neigh_addr, len, IPPROTO_ICMPV6, + csum_partial((__u8 *)msg, len, 0)); + + pkt += len; + + /* send it! */ + net_send_packet(net_tx_packet, (pkt - net_tx_packet)); +} + +void ip6_NDISC_Request(void) +{ + if (!ip6_addr_in_subnet(&net_ip6, &net_nd_sol_packet_ip6, + net_prefix_length)) { + if (ip6_is_unspecified_addr(&net_gateway6)) { + puts("## Warning: gatewayip6 is needed but not set\n"); + net_nd_rep_packet_ip6 = net_nd_sol_packet_ip6; + } else { + net_nd_rep_packet_ip6 = net_gateway6; + } + } else { + net_nd_rep_packet_ip6 = net_nd_sol_packet_ip6; + } + + ip6_send_ns(&net_nd_rep_packet_ip6); +} + +void ip6_NDISC_TimeoutCheck(void) +{ + ulong t; + + if (ip6_is_unspecified_addr(&net_nd_sol_packet_ip6)) + return; + + t = get_timer(0); + + /* check for NDISC timeout */ + if ((t - net_nd_timer_start) > NDISC_TIMEOUT) { + net_nd_try++; + if (net_nd_try >= NDISC_TIMEOUT_COUNT) { + puts("\nNeighbour discovery retry count exceeded; " + "starting again\n"); + net_nd_try = 0; + net_start_again(); + } else { + net_nd_timer_start = t; + ip6_NDISC_Request(); + } + } +} + +void ip6_NDISC_init(void) +{ + net_nd_packet_mac = NULL; + net_nd_tx_packet = NULL; + net_nd_sol_packet_ip6 = net_null_addr_ip6; + net_nd_rep_packet_ip6 = net_null_addr_ip6; + net_nd_tx_packet = NULL; + + if (!net_nd_tx_packet) { + net_nd_tx_packet = &net_nd_packet_buf[0] + (PKTALIGN - 1); + net_nd_tx_packet -= (ulong)net_nd_tx_packet % PKTALIGN; + net_nd_tx_packet_size = 0; + } +} + +void ndisc_receive(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len) +{ + struct icmp6hdr *icmp = + (struct icmp6hdr *)(((uchar *)ip6) + IP6_HDR_SIZE); + struct nd_msg *ndisc = (struct nd_msg *)icmp; + uchar neigh_eth_addr[6]; + + switch (icmp->icmp6_type) { + case IPV6_NDISC_NEIGHBOUR_SOLICITATION: + debug("received neighbor solicitation for %pI6c from %pI6c\n", + &ndisc->target, &ip6->saddr); + if (ip6_is_our_addr(&ndisc->target) && + ip6_ndisc_has_option(ip6, ND_OPT_SOURCE_LL_ADDR)) { + ip6_ndisc_extract_enetaddr(ndisc, neigh_eth_addr); + ip6_send_na(neigh_eth_addr, &ip6->saddr, + &ndisc->target); + } + break; + + case IPV6_NDISC_NEIGHBOUR_ADVERTISEMENT: + /* are we waiting for a reply ? */ + if (ip6_is_unspecified_addr(&net_nd_sol_packet_ip6)) + break; + + if ((memcmp(&ndisc->target, &net_nd_rep_packet_ip6, + sizeof(struct in6_addr)) == 0) && + ip6_ndisc_has_option(ip6, ND_OPT_TARGET_LL_ADDR)) { + ip6_ndisc_extract_enetaddr(ndisc, neigh_eth_addr); + + /* save address for later use */ + if (net_nd_packet_mac != NULL) + memcpy(net_nd_packet_mac, neigh_eth_addr, 6); + + /* modify header, and transmit it */ + memcpy(((struct ethernet_hdr *)net_nd_tx_packet)->et_dest, + neigh_eth_addr, 6); + net_send_packet(net_nd_tx_packet, + net_nd_tx_packet_size); + + /* no ND request pending now */ + net_nd_sol_packet_ip6 = net_null_addr_ip6; + net_nd_tx_packet_size = 0; + net_nd_packet_mac = NULL; + } + break; + default: + debug("Unexpected ICMPv6 type 0x%x\n", icmp->icmp6_type); + } +} diff --git a/net/ndisc.h b/net/ndisc.h new file mode 100644 index 0000000..7ade0fc --- /dev/null +++ b/net/ndisc.h @@ -0,0 +1,27 @@ +/* + * net/ndisc.h + * + * (C) Copyright 2013 Allied Telesis Labs NZ + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* IPv6 destination address of packet waiting for ND */ +extern struct in6_addr net_nd_sol_packet_ip6; +/* IPv6 address we are expecting ND advert from */ +extern struct in6_addr net_nd_rep_packet_ip6; +/* MAC destination address of packet waiting for ND */ +extern uchar *net_nd_packet_mac; +/* pointer to packet waiting to be transmitted after ND is resolved */ +extern uchar *net_nd_tx_packet; +extern uchar net_nd_packet_buf[PKTSIZE_ALIGN + PKTALIGN]; +/* size of packet waiting to be transmitted */ +extern int net_nd_tx_packet_size; +/* the timer for ND resolution */ +extern ulong net_nd_timer_start; +/* the number of requests we have sent so far */ +extern int net_nd_try; + +void ndisc_receive(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len); +void ip6_NDISC_Request(void); +void ip6_NDISC_TimeoutCheck(void); diff --git a/net/net.c b/net/net.c index a115ce2..349a18e 100644 --- a/net/net.c +++ b/net/net.c @@ -86,6 +86,7 @@ #include <environment.h> #include <errno.h> #include <net.h> +#include <net6.h> #include <net/tftp.h> #if defined(CONFIG_STATUS_LED) #include <miiphy.h> @@ -94,6 +95,7 @@ #include <watchdog.h> #include <linux/compiler.h> #include "arp.h" +#include "ndisc.h" #include "bootp.h" #include "cdp.h" #if defined(CONFIG_CMD_DNS) @@ -311,6 +313,7 @@ static int on_dnsip(const char *name, const char *value, enum env_op op, U_BOOT_ENV_CALLBACK(dnsip, on_dnsip); #endif
+ /* * Check if autoload is enabled. If so, use either NFS or TFTP to download * the boot file. @@ -341,8 +344,12 @@ void net_auto_load(void)
static void net_init_loop(void) { - if (eth_get_dev()) + if (eth_get_dev()) { memcpy(net_ethaddr, eth_get_ethaddr(), 6); +#ifdef CONFIG_CMD_NET6 + ip6_make_lladdr(&net_link_local_ip6, net_ethaddr); +#endif + }
return; } @@ -376,6 +383,9 @@ void net_init(void) (i + 1) * PKTSIZE_ALIGN; } arp_init(); +#ifdef CONFIG_CMD_NET6 + ip6_NDISC_init(); +#endif net_clear_handlers();
/* Only need to setup buffer pointers once. */ @@ -478,6 +488,11 @@ restart: ping_start(); break; #endif +#ifdef CONFIG_CMD_PING6 + case PING6: + ping6_start(); + break; +#endif #if defined(CONFIG_CMD_NFS) case NFS: nfs_start(); @@ -555,6 +570,9 @@ restart: if (ctrlc()) { /* cancel any ARP that may not have completed */ net_arp_wait_packet_ip.s_addr = 0; +#ifdef CONFIG_CMD_NET6 + net_nd_sol_packet_ip6 = net_null_addr_ip6; +#endif
net_cleanup_loop(); eth_halt(); @@ -570,6 +588,9 @@ restart: }
arp_timeout_check(); +#ifdef CONFIG_CMD_NET6 + ip6_NDISC_TimeoutCheck(); +#endif
/* * Check for a timeout, and run the timeout handler @@ -1141,6 +1162,11 @@ void net_process_received_packet(uchar *in_packet, int len) rarp_receive(ip, len); break; #endif +#ifdef CONFIG_CMD_NET6 + case PROT_IP6: + net_ip6_handler(et, (struct ip6_hdr *)ip, len); + break; +#endif case PROT_IP: debug_cond(DEBUG_NET_PKT, "Got IP\n"); /* Before we start poking the header, make sure it is there */ @@ -1295,6 +1321,14 @@ static int net_check_prereq(enum proto_t protocol) } goto common; #endif +#ifdef CONFIG_CMD_PING6 + case PING6: + if (ip6_is_unspecified_addr(&net_ping_ip6)) { + puts("*** ERROR: ping address not given\n"); + return 1; + } + goto common; +#endif #if defined(CONFIG_CMD_SNTP) case SNTP: if (net_ntp_server.s_addr == 0) { diff --git a/net/net6.c b/net/net6.c new file mode 100644 index 0000000..2315704 --- /dev/null +++ b/net/net6.c @@ -0,0 +1,375 @@ +/* + * Simple IPv6 network layer implementation. + * + * Based and/or adapted from the IPv4 network layer in net.[hc] + * + * (C) Copyright 2013 Allied Telesis Labs NZ + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +/* + * General Desription: + * + * The user interface supports commands for TFTP6. + * Also, we support Neighbour discovery internally. Depending on available + * data, these interact as follows: + * + * Neighbour Discovery: + * + * Prerequisites: - own ethernet address + * - own IPv6 address + * - TFTP server IPv6 address + * We want: - TFTP server ethernet address + * Next step: TFTP + * + * TFTP over IPv6: + * + * Prerequisites: - own ethernet address + * - own IPv6 address + * - TFTP server IPv6 address + * - TFTP server ethernet address + * - name of bootfile (if unknown, we use a default name + * derived from our own IPv6 address) + * We want: - load the boot file + * Next step: none + * + */ +#define DEBUG +#include <common.h> +#include <environment.h> +#include <net.h> +#include <net6.h> +#include "ndisc.h" + +/* NULL IPv6 address */ +struct in6_addr const net_null_addr_ip6 = ZERO_IPV6_ADDR; +/* Our gateway's IPv6 address */ +struct in6_addr net_gateway6 = ZERO_IPV6_ADDR; +/* Our IPv6 addr (0 = unknown) */ +struct in6_addr net_ip6 = ZERO_IPV6_ADDR; +/* Our link local IPv6 addr (0 = unknown) */ +struct in6_addr net_link_local_ip6 = ZERO_IPV6_ADDR; +/* set server IPv6 addr (0 = unknown) */ +struct in6_addr net_server_ip6 = ZERO_IPV6_ADDR; +/* The prefix length of our network */ +u_int32_t net_prefix_length; + +static int on_ip6addr(const char *name, const char *value, enum env_op op, + int flags) +{ + if (flags & H_PROGRAMMATIC) + return 0; + + return string_to_ip6(value, &net_ip6); +} + +U_BOOT_ENV_CALLBACK(ip6addr, on_ip6addr); + +static int on_gatewayip6(const char *name, const char *value, enum env_op op, + int flags) +{ + if (flags & H_PROGRAMMATIC) + return 0; + + return string_to_ip6(value, &net_gateway6); +} + +U_BOOT_ENV_CALLBACK(gatewayip6, on_gatewayip6); + +static int on_prefixlength6(const char *name, const char *value, enum env_op op, + int flags) +{ + if (flags & H_PROGRAMMATIC) + return 0; + + net_prefix_length = simple_strtoul(value, NULL, 10); + + return 0; +} + +U_BOOT_ENV_CALLBACK(prefixlength6, on_prefixlength6); + +static int on_serverip6(const char *name, const char *value, enum env_op op, + int flags) +{ + if (flags & H_PROGRAMMATIC) + return 0; + + return string_to_ip6(value, &net_server_ip6); +} + +U_BOOT_ENV_CALLBACK(serverip6, on_serverip6); + +int ip6_is_unspecified_addr(struct in6_addr *addr) +{ + return (addr->s6_addr32[0] | addr->s6_addr32[1] | + addr->s6_addr32[2] | addr->s6_addr32[3]) == 0; +} + +/** + * We have 2 addresses that we should respond to. A link + * local address and a global address. This returns true + * if the specified address matches either of these. + */ +int ip6_is_our_addr(struct in6_addr *addr) +{ + return memcmp(addr, &net_link_local_ip6, sizeof(struct in6_addr)) == 0 || + memcmp(addr, &net_ip6, sizeof(struct in6_addr)) == 0; +} + +void ip6_make_eui(unsigned char eui[8], unsigned char const enetaddr[6]) +{ + memcpy(eui, enetaddr, 3); + memcpy(&eui[5], &enetaddr[3], 3); + eui[3] = 0xFF; + eui[4] = 0xFE; + eui[0] ^= 2; /* "u" bit set to indicate global scope */ +} + +void ip6_make_lladdr(struct in6_addr *lladr, unsigned char const enetaddr[6]) +{ + uchar eui[8]; + + memset(lladr, 0, sizeof(struct in6_addr)); + lladr->s6_addr16[0] = htons(IPV6_LINK_LOCAL_PREFIX); + ip6_make_eui(eui, enetaddr); + memcpy(&lladr->s6_addr[8], eui, 8); +} + +/* + * Given an IPv6 address generate an equivalent Solicited Node Multicast + * Address (SNMA) as described in RFC2461. + */ +void ip6_make_SNMA(struct in6_addr *mcast_addr, struct in6_addr *ip6_addr) +{ + memset(mcast_addr, 0, sizeof(struct in6_addr)); + mcast_addr->s6_addr[0] = 0xff; + mcast_addr->s6_addr[1] = IPV6_ADDRSCOPE_LINK; + mcast_addr->s6_addr[11] = 0x01; + mcast_addr->s6_addr[12] = 0xff; + mcast_addr->s6_addr[13] = ip6_addr->s6_addr[13]; + mcast_addr->s6_addr[14] = ip6_addr->s6_addr[14]; + mcast_addr->s6_addr[15] = ip6_addr->s6_addr[15]; +} + +/* + * Given an IPv6 address generate the multicast MAC address that corresponds to + * it. + */ +void +ip6_make_mult_ethdstaddr(unsigned char enetaddr[6], struct in6_addr *mcast_addr) +{ + enetaddr[0] = 0x33; + enetaddr[1] = 0x33; + memcpy(&enetaddr[2], &mcast_addr->s6_addr[12], 4); +} + +int +ip6_addr_in_subnet(struct in6_addr *our_addr, struct in6_addr *neigh_addr, + __u32 plen) +{ + __be32 *addr_dwords; + __be32 *neigh_dwords; + + addr_dwords = our_addr->s6_addr32; + neigh_dwords = neigh_addr->s6_addr32; + + while (plen > 32) { + if (*addr_dwords++ != *neigh_dwords++) + return 0; + + plen -= 32; + } + + /* Check any remaining bits. */ + if (plen > 0) { + /* parameters are in network byte order. + Does this work on a LE host? */ + if ((*addr_dwords >> (32 - plen)) != + (*neigh_dwords >> (32 - plen))) { + return 0; + } + } + + return 1; +} + +static inline unsigned int csum_fold(unsigned int sum) +{ + sum = (sum & 0xffff) + (sum >> 16); + sum = (sum & 0xffff) + (sum >> 16); + + return ~sum; +} + +static __u32 csum_do_csum(const __u8 *buff, int len) +{ + int odd, count; + unsigned long result = 0; + + if (len <= 0) + goto out; + odd = 1 & (unsigned long)buff; + if (odd) { + result = *buff; + len--; + buff++; + } + count = len >> 1; /* nr of 16-bit words.. */ + if (count) { + if (2 & (unsigned long)buff) { + result += *(unsigned short *)buff; + count--; + len -= 2; + buff += 2; + } + count >>= 1; /* nr of 32-bit words.. */ + if (count) { + unsigned long carry = 0; + do { + unsigned long w = *(unsigned long *)buff; + count--; + buff += 4; + result += carry; + result += w; + carry = (w > result); + } while (count); + result += carry; + result = (result & 0xffff) + (result >> 16); + } + if (len & 2) { + result += *(unsigned short *)buff; + buff += 2; + } + } + if (len & 1) + result += (*buff << 8); + result = ~csum_fold(result); + if (odd) + result = ((result >> 8) & 0xff) | ((result & 0xff) << 8); +out: + return result; +} + +unsigned int csum_partial(const unsigned char *buff, int len, unsigned int sum) +{ + unsigned int result = csum_do_csum(buff, len); + + /* add in old sum, and carry.. */ + result += sum; + /* 16+c bits -> 16 bits */ + result = (result & 0xffff) + (result >> 16); + return result; +} + +unsigned short int +csum_ipv6_magic(struct in6_addr *saddr, struct in6_addr *daddr, + __u16 len, unsigned short proto, unsigned int csum) +{ + int i; + int carry; + __u32 ulen; + __u32 uproto; + unsigned int finalsum; + + for (i = 0; i < 4; i++) { + csum += saddr->s6_addr32[i]; + carry = (csum < saddr->s6_addr32[i]); + csum += carry; + + csum += daddr->s6_addr32[i]; + carry = (csum < daddr->s6_addr32[i]); + csum += carry; + } + + ulen = htonl((__u32)len); + csum += ulen; + carry = (csum < ulen); + csum += carry; + + uproto = htonl(proto); + csum += uproto; + carry = (csum < uproto); + csum += carry; + + finalsum = csum_fold(csum); + if ((finalsum & 0xffff) == 0x0000) + return 0xffff; + else if ((finalsum & 0xffff) == 0xffff) + return 0x0000; + else + return finalsum; +} + +int +ip6_add_hdr(uchar *xip, struct in6_addr *src, struct in6_addr *dest, + int nextheader, int hoplimit, int payload_len) +{ + struct ip6_hdr *ip6 = (struct ip6_hdr *)xip; + + ip6->version = 6; + ip6->priority = 0; + ip6->flow_lbl[0] = 0; + ip6->flow_lbl[1] = 0; + ip6->flow_lbl[2] = 0; + ip6->payload_len = htons(payload_len); + ip6->nexthdr = nextheader; + ip6->hop_limit = hoplimit; + net_copy_ip6(&ip6->saddr, src); + net_copy_ip6(&ip6->daddr, dest); + + return sizeof(struct ip6_hdr); +} + +void net_ip6_handler(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len) +{ + struct in_addr zero_ip = {.s_addr = 0 }; + struct icmp6hdr *icmp; + struct udp_hdr *udp; + __u16 csum; + __u16 hlen; + + if (len < IP6_HDR_SIZE) + return; + + if (ip6->version != 6) + return; + + switch (ip6->nexthdr) { + case IPPROTO_ICMPV6: + icmp = (struct icmp6hdr *)(((uchar *)ip6) + IP6_HDR_SIZE); + csum = icmp->icmp6_cksum; + hlen = ntohs(ip6->payload_len); + icmp->icmp6_cksum = 0; + /* checksum */ + icmp->icmp6_cksum = csum_ipv6_magic(&ip6->saddr, &ip6->daddr, + hlen, IPPROTO_ICMPV6, + csum_partial((__u8 *)icmp, hlen, 0)); + if (icmp->icmp6_cksum != csum) + return; + + switch (icmp->icmp6_type) { +#ifdef CONFIG_CMD_PING6 + case IPV6_ICMP_ECHO_REQUEST: + case IPV6_ICMP_ECHO_REPLY: + ping6_receive(et, ip6, len); + break; +#endif /* CONFIG_CMD_PING6 */ + + case IPV6_NDISC_NEIGHBOUR_SOLICITATION: + case IPV6_NDISC_NEIGHBOUR_ADVERTISEMENT: + ndisc_receive(et, ip6, len); + break; + + default: + return; + break; + } + break; + + default: + return; + break; + } +} diff --git a/net/ping6.c b/net/ping6.c new file mode 100644 index 0000000..aa93dfa --- /dev/null +++ b/net/ping6.c @@ -0,0 +1,111 @@ +/* + * net/ping6.c + * + * (C) Copyright 2013 Allied Telesis Labs NZ + * + * SPDX-License-Identifier: GPL-2.0+ + */ +#define DEBUG +#include <common.h> +#include <net.h> +#include <net6.h> +#include "ndisc.h" + +static ushort seq_no; + +/* the ipv6 address to ping */ +struct in6_addr net_ping_ip6; + +int +ip6_make_ping(uchar *eth_dst_addr, struct in6_addr *neigh_addr, uchar *pkt) +{ + struct echo_msg *msg; + __u16 len; + uchar *pkt_old = pkt; + + len = sizeof(struct echo_msg); + + pkt += net_set_ether(pkt, eth_dst_addr, PROT_IP6); + pkt += ip6_add_hdr(pkt, &net_ip6, neigh_addr, IPPROTO_ICMPV6, + IPV6_NDISC_HOPLIMIT, len); + + /* ICMPv6 - Echo */ + msg = (struct echo_msg *)pkt; + msg->icmph.icmp6_type = IPV6_ICMP_ECHO_REQUEST; + msg->icmph.icmp6_code = 0; + msg->icmph.icmp6_cksum = 0; + msg->icmph.icmp6_identifier = 0; + msg->icmph.icmp6_sequence = htons(seq_no++); + msg->id = msg->icmph.icmp6_identifier; /* these seem redundant */ + msg->sequence = msg->icmph.icmp6_sequence; + + /* checksum */ + msg->icmph.icmp6_cksum = csum_ipv6_magic(&net_ip6, neigh_addr, len, + IPPROTO_ICMPV6, + csum_partial((__u8 *)msg, len, 0)); + + pkt += len; + + return pkt - pkt_old; +} + +int ping6_send(void) +{ + uchar *pkt; + static uchar mac[6]; + + /* always send neighbor solicit */ + + memcpy(mac, net_null_ethaddr, 6); + + net_nd_sol_packet_ip6 = net_ping_ip6; + net_nd_packet_mac = mac; + + pkt = net_nd_tx_packet; + pkt += ip6_make_ping(mac, &net_ping_ip6, pkt); + + /* size of the waiting packet */ + net_nd_tx_packet_size = (pkt - net_nd_tx_packet); + + /* and do the ARP request */ + net_nd_try = 1; + net_nd_timer_start = get_timer(0); + ip6_NDISC_Request(); + return 1; /* waiting */ +} + +static void ping6_timeout(void) +{ + eth_halt(); + net_set_state(NETLOOP_FAIL); /* we did not get the reply */ +} + +void ping6_start(void) +{ + printf("Using %s device\n", eth_get_name()); + net_set_timeout_handler(10000UL, ping6_timeout); + + ping6_send(); +} + +void ping6_receive(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len) +{ + struct icmp6hdr *icmp = + (struct icmp6hdr *)(((uchar *)ip6) + IP6_HDR_SIZE); + struct in6_addr src_ip; + + switch (icmp->icmp6_type) { + case IPV6_ICMP_ECHO_REPLY: + src_ip = ip6->saddr; + if (memcmp(&net_ping_ip6, &src_ip, sizeof(struct in6_addr)) != 0) + return; + net_set_state(NETLOOP_SUCCESS); + break; + case IPV6_ICMP_ECHO_REQUEST: + debug("Got ICMPv6 ECHO REQUEST from %pI6c\n", &ip6->saddr); + /* ignore for now.... */ + break; + default: + debug("Unexpected ICMPv6 type 0x%x\n", icmp->icmp6_type); + } +}
Hi Chris,
It is pretty huge. It's taken me a while to get through it.
+config CMD_NET6
select NET
select NET6
default n
help
This is added in the next patch, so should probably move there.
+config CMD_PING6
bool "ping6"
depends on CMD_NET6
help
What makes ping inseparable from the core support?
if (argc < 2)
return -1;
&net_ping_ip6);
return 1;
+U_BOOT_CMD(
"pingAddress"
I like the other nomenclature better as well (included in the address).
- This list of callback bindings is static, but may be overridden by defining
- a new association in the ".callbacks" environment variable.
I think CONFIG_NET6 would be better here.
"ip6addr:s," \
"serverip6:s," \
"prefixlength6:d,"
enum proto_t {
These should be added with the patch that adds the feature (TFTP6 for sure, and probably PING6 when it is a separate patch).
- c99 '= { 0 }' idiom might work depending on you compiler. */
+struct udp_hdr {
UDP is shared between IP and IP6, right? There seems to be no reason to call it IP6_UDPHDR_SIZE. I would go with UDP_HDR_SIZE, but of course that is already defined. Seem like a good candidate to combine with the existing implementation.
Maybe that means that struct ip_udp_hdr goes away or maybe it's cleaner to keep it as well. Have to dive in to know.
+enum {
ND_OPT_MTU = 5,
__ND_OPT_MAX
+struct icmp6hdr {
__u8 icmp6_type;
__u8 icmp6_code;
__be16 icmp6_cksum;
union {
__u8 un_data8[4];
__be16 identifier;
__be16 sequence;
} u_echo;
__be32 reserved:5,
override:1,
solicited:1,
router:1,
reserved2:24;
__be32 router:1,
solicited:1,
override:1,
reserved:29;
} u_nd_advt;
__u8 hop_limit;
__u8 reserved:6,
other:1,
managed:1;
__u8 managed:1,
other:1,
reserved:6;
__be16 rt_lifetime;
} u_nd_ra;
} icmp6_dataun;
+struct nd_msg {
__u8 opt[0];
+struct rs_msg {
__u8 opt[0];
+struct ra_msg {
+struct echo_msg {
__u16 id;
__u16 sequence;
__u8 nd_opt_type;
__u8 nd_opt_len;
int len);
int len);
+config NET6
bool "IPv6 support"
help
Support for IPv6
I'd like to see the stuff that is net core (not a command) start using CONFIG_NET6 instead of CONFIG_CMD_NET6.
- net/ndisc.c
static. The same goes for any others that are not needed outside of this file.
- Insert an iption into a neighbor discovery packet.
iption -> option
- Returns the number of bytes inserted (which may be >= len)
len += 2;
return space;
- Extract the Ethernet address from a neighbor discovery packet.
- Note that the link layer address could be anything but the only networking
- media that u-boot supports is Ethernet so we assume we're extracting a 6
- byte Ethernet MAC address.
- Check to see if the neighbor discovery packet has
- the specified option set.
struct nd_msg *msg;
__u16 len;
uchar *pkt;
/* ICMPv6 - NS */
INETHADDRSZ);
/* checksum */
pkt += len;
/* send it! */
struct nd_msg *msg;
__u16 len;
uchar *pkt;
/* ICMPv6 - NS */
Probably mean to say "ICMPv6 - NA" here, right?
INETHADDRSZ);
/* checksum */
pkt += len;
/* send it! */
Please don't use CamelCase looking stuff. All lower case is usually appropriate.
Is this just assuming that since there is no gateway that the device might be on the local segment even though the address is not on our subnet?
} else {
} else {
Lowercase.
ulong t;
return;
t = get_timer(0);
net_nd_try++;
net_nd_try = 0;
net_start_again();
} else {
Lowercase.
&ndisc->target);
break;
break;
neigh_eth_addr, 6);
break;
default:
- net/ndisc.h
This is not used outside of ndisc.c so remove it from this header.
The same goes for any others in here that are not needed outside.
No need to add white space here.
- Check if autoload is enabled. If so, use either NFS or TFTP to download
- the boot file.
if (eth_get_dev())
} return;
ip6_NDISC_init();
case PING6:
ping6_start();
break;
case PROT_IP6:
break;
case PING6:
return 1;
goto common;
All the ping stuff seems like it could come out into a separate patch.
- General Desription:
- The user interface supports commands for TFTP6.
- Also, we support Neighbour discovery internally. Depending on available
- data, these interact as follows:
- Neighbour Discovery:
- own IPv6 address
Next step: TFTP
- TFTP over IPv6:
- own IPv6 address
Next step: none
int flags)
int flags)
int flags)
int flags)
- We have 2 addresses that we should respond to. A link
- local address and a global address. This returns true
- if the specified address matches either of these.
eui[3] = 0xFF;
eui[4] = 0xFE;
uchar eui[8];
- Given an IPv6 address generate an equivalent Solicited Node Multicast
- Address (SNMA) as described in RFC2461.
Lowercase.
- Given an IPv6 address generate the multicast MAC address that corresponds to
- it.
enetaddr[0] = 0x33;
enetaddr[1] = 0x33;
__u32 plen)
while (plen > 32) {
plen -= 32;
if (plen > 0) {
So is this still an outstanding question? Probably worth testing on a LE target, but it should work I believe.
return 1;
return ~sum;
int odd, count;
if (len <= 0)
goto out;
if (odd) {
result = *buff;
len--;
buff++;
if (count) {
count--;
len -= 2;
buff += 2;
if (count) {
do {
count--;
buff += 4;
result += carry;
result += w;
} while (count);
result += carry;
if (len & 2) {
buff += 2;
if (len & 1)
if (odd)
+out:
return result;
result += sum;
return result;
Please add some comments to this to make it less magic. :)
int i;
int carry;
__u32 ulen;
__u32 uproto;
csum += carry;
csum += carry;
csum += ulen;
csum += carry;
csum += uproto;
csum += carry;
return 0xffff;
return 0x0000;
else
return finalsum;
ip6->version = 6;
ip6->priority = 0;
__u16 csum;
__u16 hlen;
return;
return;
/* checksum */
return;
break;
break;
default:
return;
break;
break;
default:
return;
break;
- net/ping6.c
__u16 len;
/* ICMPv6 - Echo */
/* checksum */
IPPROTO_ICMPV6,
pkt += len;
uchar *pkt;
net_nd_try = 1;
eth_halt();
ping6_send();
return;
break;
break;
default:
2.5.3
Hi Joe,
I've answered a few questions below. I'll address your comments more completely before sending another round next week (or I can sit on it for longer if you want me to give you some breathing room).
On Tue, Nov 3, 2015 at 9:43 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Chris,
Thanks for making the effort to review. I realise it's pretty huge and I'll put some effort into splitting it futher. One obvious thing that could be split out is the new environment variables.
+config CMD_NET6
select NET
select NET6
default n
help
Will do.
+config CMD_PING6
bool "ping6"
depends on CMD_NET6
help
Mainly testing, I can't test the core code without ping. But I can see that from a patch submission point of few splitting it out will make review easier.
if (argc < 2)
return -1;
&net_ping_ip6);
return 1;
+U_BOOT_CMD(
"pingAddress"
I've actually already implemented the code to include the prefixlength in the address and it makes things a lot more usable (the parsing code is a bit more complicated).
"ip6addr:s," \
"serverip6:s," \
"prefixlength6:d,"
enum proto_t {
+struct udp_hdr {
I'll take a look. Maybe I can disentangle "ip" from ip_udp_hdr as an prepatory patch.
+enum {
ND_OPT_MTU = 5,
__ND_OPT_MAX
+struct icmp6hdr {
__u8 icmp6_type;
__u8 icmp6_code;
__be16 icmp6_cksum;
union {
__u8 un_data8[4];
__be16 identifier;
__be16 sequence;
} u_echo;
__be32 reserved:5,
override:1,
solicited:1,
router:1,
reserved2:24;
__be32 router:1,
solicited:1,
override:1,
reserved:29;
} u_nd_advt;
__u8 hop_limit;
__u8 reserved:6,
other:1,
managed:1;
__u8 managed:1,
other:1,
reserved:6;
__be16 rt_lifetime;
} u_nd_ra;
} icmp6_dataun;
+struct nd_msg {
__u8 opt[0];
+struct rs_msg {
__u8 opt[0];
+struct ra_msg {
+struct echo_msg {
__u16 id;
__u16 sequence;
__u8 nd_opt_type;
__u8 nd_opt_len;
int len);
int len);
+config NET6
bool "IPv6 support"
help
Support for IPv6
Understood.
- net/ndisc.c
iption -> option
len += 2;
return space;
struct nd_msg *msg;
__u16 len;
uchar *pkt;
/* ICMPv6 - NS */
INETHADDRSZ);
/* checksum */
pkt += len;
/* send it! */
struct nd_msg *msg;
__u16 len;
uchar *pkt;
/* ICMPv6 - NS */
INETHADDRSZ);
/* checksum */
pkt += len;
/* send it! */
Will fix. The original Allied Telesis implementation was based on a fairly old verison and copied the non-standard net.c which was recently updated to eliminate camelcase.
Also I was wondering about "ip6_ndisc" vs "ndisc". The latter is sorter and kind of fits with "arp" for ipv4 but the difference is that unlike arp, neigbor discovery actually operates over ipv6.
Yeah I might need to add some conditions on the configured address not being the link local one.
} else {
} else {
Lowercase.
Yep will fix all occurences in the next round.
ulong t;
return;
t = get_timer(0);
net_nd_try++;
net_nd_try = 0;
net_start_again();
} else {
Lowercase.
&ndisc->target);
break;
break;
neigh_eth_addr, 6);
break;
default:
- net/ndisc.h
- the boot file.
if (eth_get_dev())
} return;
ip6_NDISC_init();
case PING6:
ping6_start();
break;
case PROT_IP6:
break;
case PING6:
return 1;
goto common;
Agreed.
- own IPv6 address
Next step: TFTP
- TFTP over IPv6:
- own IPv6 address
Next step: none
int flags)
int flags)
int flags)
int flags)
eui[3] = 0xFF;
eui[4] = 0xFE;
uchar eui[8];
Lowercase.
- it.
enetaddr[0] = 0x33;
enetaddr[1] = 0x33;
__u32 plen)
while (plen > 32) {
plen -= 32;
if (plen > 0) {
I'm actually testing with x86 on QEMU so I think LE is all good. I'll remove the comment.
return 1;
return ~sum;
int odd, count;
if (len <= 0)
goto out;
if (odd) {
result = *buff;
len--;
buff++;
if (count) {
count--;
len -= 2;
buff += 2;
if (count) {
do {
count--;
buff += 4;
result += carry;
result += w;
} while (count);
result += carry;
if (len & 2) {
buff += 2;
if (len & 1)
if (odd)
+out:
return result;
result += sum;
return result;
I think there should be an RFC to describe this. I'll look it up and put anything relevant here.
int i;
int carry;
__u32 ulen;
__u32 uproto;
csum += carry;
csum += carry;
csum += ulen;
csum += carry;
csum += uproto;
csum += carry;
return 0xffff;
return 0x0000;
else
return finalsum;
ip6->version = 6;
ip6->priority = 0;
__u16 csum;
__u16 hlen;
return;
return;
/* checksum */
return;
break;
break;
default:
return;
break;
break;
default:
return;
break;
- net/ping6.c
__u16 len;
/* ICMPv6 - Echo */
/* checksum */
IPPROTO_ICMPV6,
pkt += len;
uchar *pkt;
net_nd_try = 1;
eth_halt();
ping6_send();
return;
break;
break;
default:
2.5.3
Hi Chris,
On Tue, Nov 3, 2015 at 4:11 AM, Chris Packham judge.packham@gmail.com wrote:
Hi Joe,
Feel free to send it when you're ready.
Hi Chris,
Sounds good.
+config CMD_NET6
select NET
select NET6
default n
help
Will do.
+config CMD_PING6
bool "ping6"
depends on CMD_NET6
help
One simple way to prove out the core without ping would maybe be to rebase and switch tftp with ping and make sure that tftp works without ping. Then you at least know you have enough, but you won't know if you left in more than you need.
--8<---- snip ----8<--
Sounds good.
I think it's fine to just use ndisc, since it is not going to be ambiguous, but up to you if you want to change it.
It seems like if your ip is link local you don't want to use the gateway even if you have one configured.
} else {
} else {
__u32 plen)
while (plen > 32) {
plen -= 32;
if (plen > 0) {
Great. Have you done any testing in sandbox? I'd really like to see unit tests go in as part of this series.
return 1;
On Wed, Nov 4, 2015 at 8:41 AM, Joe Hershberger joe.hershberger@gmail.com wrote: <snip>
I'll take a look. For the parsing etc that should be doable. I think I may run into problems with the linux network stack getting in the way for some of the link-local handling. Are there any existing tests for the networking code?
Hi Chris,
<snip>
Yes, there is test/dm/eth.c that does some pinging to test out the Ethernet stack.
Also, sandbox has drivers/net/sandbox-raw.c that allows sandbox to interact with the host network adapter. See board/sandbox/README.sandbox
Cheers, -Joe
Add support for UDP/TFTP over IPv6.
Signed-off-by: Chris Packham judge.packham@gmail.com --- One problem with the [hostIpAddr:]fileName syntax is that IPv6 addresses contains colons. So tftp_start() would be confused by 'tftpboot6 $loadaddr 2001:db8::1:zImage'. It is probably possible to change the parsing to separate the host from the filename by parsing from the end (i.e. use strrchr() instead of strchr()) but then there are error cases that may not be handled correctly (e.g. omitting the filename).
common/cmd_net.c | 13 ++++++++++++ include/net6.h | 4 ++++ net/net.c | 3 +++ net/net6.c | 64 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++ net/tftp.c | 37 ++++++++++++++++++++++++++++++++ 5 files changed, 121 insertions(+)
diff --git a/common/cmd_net.c b/common/cmd_net.c index 271f91d..3541599 100644 --- a/common/cmd_net.c +++ b/common/cmd_net.c @@ -42,6 +42,19 @@ U_BOOT_CMD( "[loadAddress] [[hostIPaddr:]bootfilename]" );
+#ifdef CONFIG_CMD_NET6 +int do_tftpb6(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) +{ + return netboot_common(TFTP6, cmdtp, argc, argv); +} + +U_BOOT_CMD( + tftpboot6, 3, 1, do_tftpb6, + "boot image via network using TFTP protocol", + "[loadAddress] [bootfilename]" +); +#endif + #ifdef CONFIG_CMD_TFTPPUT int do_tftpput(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { diff --git a/include/net6.h b/include/net6.h index a0374df..df6d38e 100644 --- a/include/net6.h +++ b/include/net6.h @@ -264,6 +264,10 @@ void ping6_start(void); void ping6_receive(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len);
+/* Transmit UDP packet using IPv6, performing neighbour discovery if needed */ +int net_send_udp_packet6(uchar *ether, struct in6_addr *dest, + int dport, int sport, int len); + /* handler for incoming IPv6 echo packet */ void net_ip6_handler(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len); diff --git a/net/net.c b/net/net.c index 349a18e..9e682b4 100644 --- a/net/net.c +++ b/net/net.c @@ -454,6 +454,9 @@ restart: #ifdef CONFIG_CMD_TFTPPUT case TFTPPUT: #endif +#ifdef CONFIG_CMD_NET6 + case TFTP6: +#endif /* always use ARP to get server ethernet address */ tftp_start(protocol); break; diff --git a/net/net6.c b/net/net6.c index 2315704..f5e272a 100644 --- a/net/net6.c +++ b/net/net6.c @@ -322,6 +322,50 @@ ip6_add_hdr(uchar *xip, struct in6_addr *src, struct in6_addr *dest, return sizeof(struct ip6_hdr); }
+int +net_send_udp_packet6(uchar *ether, struct in6_addr *dest, int dport, int sport, int len) +{ + uchar *pkt; + struct udp_hdr *udp; + + udp = (struct udp_hdr *)((uchar *)net_tx_packet + net_eth_hdr_size() + IP6_HDR_SIZE); + + udp->udp_dst = htons(dport); + udp->udp_src = htons(sport); + udp->udp_len = htons(len + IP6_UDPHDR_SIZE); + /* checksum */ + udp->udp_xsum = 0; + udp->udp_xsum = csum_ipv6_magic(&net_ip6, dest, len + IP6_UDPHDR_SIZE, + IPPROTO_UDP, csum_partial((__u8 *)udp, len + IP6_UDPHDR_SIZE, 0)); + + /* if MAC address was not discovered yet, save the packet and do neighbour discovery */ + if (memcmp(ether, net_null_ethaddr, 6) == 0) { + net_copy_ip6(&net_nd_sol_packet_ip6, dest); + net_nd_packet_mac = ether; + + pkt = net_nd_tx_packet; + pkt += net_set_ether(pkt, net_nd_packet_mac, PROT_IP6); + pkt += ip6_add_hdr(pkt, &net_ip6, dest, IPPROTO_UDP, 64, len + IP6_UDPHDR_SIZE); + memcpy(pkt, (uchar *)udp, len + IP6_UDPHDR_SIZE); + + /* size of the waiting packet */ + net_nd_tx_packet_size = (pkt - net_nd_tx_packet) + IP6_UDPHDR_SIZE + len; + + /* and do the neighbor solicitation */ + net_nd_try = 1; + net_nd_timer_start = get_timer(0); + ip6_NDISC_Request(); + return 1; /* waiting */ + } + + pkt = (uchar *)net_tx_packet; + pkt += net_set_ether(pkt, ether, PROT_IP6); + pkt += ip6_add_hdr(pkt, &net_ip6, dest, IPPROTO_UDP, 64, len + IP6_UDPHDR_SIZE); + (void) eth_send(net_tx_packet, (pkt - net_tx_packet) + IP6_UDPHDR_SIZE + len); + + return 0; /* transmitted */ +} + void net_ip6_handler(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len) { struct in_addr zero_ip = {.s_addr = 0 }; @@ -368,6 +412,26 @@ void net_ip6_handler(struct ethernet_hdr *et, struct ip6_hdr *ip6, int len) } break;
+ case IPPROTO_UDP: + udp = (struct udp_hdr *)(((uchar *)ip6) + IP6_HDR_SIZE); + csum = udp->udp_xsum; + hlen = ntohs(ip6->payload_len); + udp->udp_xsum = 0; + /* checksum */ + udp->udp_xsum = csum_ipv6_magic(&ip6->saddr, &ip6->daddr, + hlen, IPPROTO_UDP, csum_partial((__u8 *)udp, hlen, 0)); + if (csum != udp->udp_xsum) + return; + + /* IP header OK. Pass the packet to the current handler. */ + net_get_udp_handler()((uchar *)ip6 + IP6_HDR_SIZE + + IP6_UDPHDR_SIZE, + ntohs(udp->udp_dst), + zero_ip, + ntohs(udp->udp_src), + ntohs(udp->udp_len) - 8); + break; + default: return; break; diff --git a/net/tftp.c b/net/tftp.c index 1a51131..1463bf2 100644 --- a/net/tftp.c +++ b/net/tftp.c @@ -10,6 +10,7 @@ #include <command.h> #include <mapmem.h> #include <net.h> +#include <net6.h> #include <net/tftp.h> #include "bootp.h" #ifdef CONFIG_SYS_DIRECT_FLASH_TFTP @@ -94,6 +95,10 @@ static int tftp_put_final_block_sent; #else #define tftp_put_active 0 #endif +#ifdef CONFIG_CMD_NET6 +/* 1 if using IPv6, else 0 */ +static int tftp6_active; +#endif
#define STATE_SEND_RRQ 1 #define STATE_DATA 2 @@ -129,6 +134,8 @@ static char tftp_filename[MAX_LEN]; #else #define TFTP_MTU_BLOCKSIZE 1468 #endif +/* IPv6 adds 20 bytes extra overhead */ +#define TFTP_MTU_BLOCKSIZE6 (TFTP_MTU_BLOCKSIZE - 20)
static unsigned short tftp_block_size = TFTP_BLOCK_SIZE; static unsigned short tftp_block_size_option = TFTP_MTU_BLOCKSIZE; @@ -341,6 +348,11 @@ static void tftp_send(void) * We will always be sending some sort of packet, so * cobble together the packet headers now. */ +#ifdef CONFIG_CMD_NET6 + if (tftp6_active) + pkt = net_tx_packet + net_eth_hdr_size() + IP6_HDR_SIZE + IP6_UDPHDR_SIZE; + else +#endif pkt = net_tx_packet + net_eth_hdr_size() + IP_UDP_HDR_SIZE;
switch (tftp_state) { @@ -440,6 +452,12 @@ static void tftp_send(void) break; }
+#ifdef CONFIG_CMD_NET6 + if (tftp6_active) + net_send_udp_packet6(net_server_ethaddr, &net_server_ip6, + tftp_remote_port, tftp_our_port, len); + else +#endif net_send_udp_packet(net_server_ethaddr, tftp_remote_ip, tftp_remote_port, tftp_our_port, len); } @@ -747,6 +765,16 @@ void tftp_start(enum proto_t protocol) }
printf("Using %s device\n", eth_get_name()); +#ifdef CONFIG_CMD_NET6 + tftp6_active = (protocol == TFTP6); + if (tftp6_active) { + printf("TFTP from server %pI6c; our IP address is %pI6c", + &net_server_ip6, + &net_ip6); + if (tftp_block_size_option > TFTP_MTU_BLOCKSIZE6) + tftp_block_size_option = TFTP_MTU_BLOCKSIZE6; + } else +#endif printf("TFTP %s server %pI4; our IP address is %pI4", #ifdef CONFIG_CMD_TFTPPUT protocol == TFTPPUT ? "to" : "from", @@ -756,6 +784,15 @@ void tftp_start(enum proto_t protocol) &tftp_remote_ip, &net_ip);
/* Check if we need to send across this subnet */ +#ifdef CONFIG_CMD_NET6 + if (tftp6_active) { + if (!ip6_addr_in_subnet(&net_ip6, &net_server_ip6, + net_prefix_length)) { + printf("; sending through gateway %pI6c", + &net_gateway6); + } + } else +#endif if (net_gateway.s_addr && net_netmask.s_addr) { struct in_addr our_net; struct in_addr remote_net;
Hi Chris,
On Mon, Oct 12, 2015 at 2:43 AM, Chris Packham judge.packham@gmail.com wrote:
I think we should just change the filename separator for tftp6. How about ','?
+U_BOOT_CMD(
+); +#endif
case TFTP6:
uchar *pkt;
/* checksum */
udp->udp_xsum = 0;
net_nd_try = 1;
case IPPROTO_UDP:
udp->udp_xsum = 0;
/* checksum */
return;
IP6_UDPHDR_SIZE,
zero_ip,
break;
if (tftp6_active)
else
if (tftp6_active)
else
if (tftp6_active) {
&net_server_ip6,
&net_ip6);
} else
if (tftp6_active) {
&net_gateway6);
} else
+#endif if (net_gateway.s_addr && net_netmask.s_addr) { struct in_addr our_net; struct in_addr remote_net; -- 2.5.3
Hi Chris,
The other strategy that is often used is to use square brackets to separate the address from other data e.g. http://%5B2001:db8::1%5D:8080/. Maybe that is a better (or at least more common) approach.
+U_BOOT_CMD(
+); +#endif
case TFTP6:
uchar *pkt;
/* checksum */
udp->udp_xsum = 0;
net_nd_try = 1;
case IPPROTO_UDP:
udp->udp_xsum = 0;
/* checksum */
return;
IP6_UDPHDR_SIZE,
zero_ip,
break;
if (tftp6_active)
else
if (tftp6_active)
else
if (tftp6_active) {
&net_server_ip6,
&net_ip6);
} else
if (tftp6_active) {
&net_gateway6);
} else
Hi Chris,
Hi Chris,
Sounds good to me - I'm all for going with a common approach.
On Wed, Nov 4, 2015 at 8:43 AM, Joe Hershberger joe.hershberger@gmail.com wrote:
Hi Chris,
Hi Chris,
One wrinkle I've just discovered with this suggestion is the command line help text. Consider the following
=> help tftpboot Usage: tftpboot [loadAddress] [[hostIPaddr:]bootfilename]
Now the IPv6 version if the above syntax is supported => help tftpboot6 Usage: tftpboot6 [loadAddress] [[[hostIP6addr]:]bootfilename]
How do we convey that the address before the bootfilename is optional but if it is specified square brackets are required around the address. In other words
tftpboot6 (valid) tftpboot6 zImage (valid) tftpboot6 2001:db8::1:zImage (invalid) tftpboot6 [2001:db8::1]:zImage (valid)
I still like the square bracket syntax and I'm still planning on implementing it but I thought I'd raise this now to give people a chance to object.
Chris
Have a look at https://www.ietf.org/rfc/rfc2732.txt, might give you some hints.
Kind regards
Angga
-----Original Message----- From: Chris Packham [mailto:judge.packham@gmail.com] Sent: Wednesday, 4 November 2015 9:43 p.m. To: Joe Hershberger Cc: u-boot; Joe Hershberger; jp.tosoni@acksys.fr; Hanna Hawa; Angga Subject: Re: [U-Boot] [RFC PATCH 6/8] net: TFTP over IPv6
Hi Chris,
Hi Chris,
Hi Chris,
Hi Chris,
Hi Chris,
That's unfortunate.
Maybe something like
or
tftpboot6 [loadAddress] [['['hostIP6addr']':]bootfilename]
I don't love either, but does it get the message across?
-Joe
Hi all,
-----Message d'origine----- De : Joe Hershberger [mailto:joe.hershberger@gmail.com] Envoyé : lundi 2 novembre 2015 21:44 À : Chris Packham Cc : u-boot; Joe Hershberger; jp.tosoni@acksys.fr; Hanna Hawa; Angga Objet : Re: [U-Boot] [RFC PATCH 6/8] net: TFTP over IPv6
filename).
How about a '/' to make it look like an URL ? More intuitive maybe.
Hi Jean-Pierre,
On Tue, Nov 3, 2015 at 4:41 AM, Jean-Pierre Tosoni jp.tosoni@acksys.fr wrote:
Hi all,
filename).
That might work, but it also could be part of the path to the file itself. It doesn't seem good to be ambiguous about that or to require 2001:db8::1//kernel.tgz
-Joe
README | 3 +++ doc/README.ipv6 | 34 ++++++++++++++++++++++++++++++++++ 2 files changed, 37 insertions(+) create mode 100644 doc/README.ipv6
diff --git a/README b/README index c22b60b..6118de2 100644 --- a/README +++ b/README @@ -1116,6 +1116,7 @@ The following options need to be configured: CONFIG_CMD_MTDPARTS * MTD partition support CONFIG_CMD_NAND * NAND support CONFIG_CMD_NET bootp, tftpboot, rarpboot + CONFIG_CMD_NET6 * tftpboot6 CONFIG_CMD_NFS NFS support CONFIG_CMD_PCA953X * PCA953x I2C gpio commands CONFIG_CMD_PCA953X_INFO * PCA953x I2C gpio info command @@ -1123,6 +1124,8 @@ The following options need to be configured: CONFIG_CMD_PCMCIA * PCMCIA support CONFIG_CMD_PING * send ICMP ECHO_REQUEST to network host + CONFIG_CMD_PING6 * send ICMPv6 ECHO_REQUEST to network + host CONFIG_CMD_PORTIO * Port I/O CONFIG_CMD_READ * Read raw data from partition CONFIG_CMD_REGINFO * Register dump diff --git a/doc/README.ipv6 b/doc/README.ipv6 new file mode 100644 index 0000000..d4f738f --- /dev/null +++ b/doc/README.ipv6 @@ -0,0 +1,34 @@ +IPv6 Support in U-boot +---------------------- +IPv6 support in U-boot can be considered experimental. The commands +currently supported are tftpboot6 and ping6. + +The following environment variables are used +- ip6addr - IPv6 address of the device +- prefixlength6 - The prefix length of the IPv6 subnet (equivalent to + netmask for IPv4) +- gatewayip6 - IPv6 address of the default gateway +- serverip6 - IPv6 of the tftp server + +Configuration +------------- +The following configuration option needs to be selected to support IPv6. +- CONFIG_CMD_NET6 +Optionally the following can also be selected to enable the ping6 +command. +- CONFIG_CMD_PING6 + +TFTP Server Configuration +------------------------- +At the time of writing U-boot has been tested against tftp-hpa +(https://www.kernel.org/pub/software/network/tftp/) the default Debian +package sets TFTP_ADDRESS=0.0.0.0:69 (in /etc/default/tftpd-hpa) to +support both IPv4 and IPv6 this need to be changed to ':69'. + +Ethernet Driver Requirements +---------------------------- +For IPv6 to operate correctly the Ethernet device needs to support +transmission and reception of L2 multicast packets. Transmission is +usually not a problem. To receive multicast packets the driver needs to +enable promiscuous mode (some devices have the option of just enabling +promiscuous multicast reception).
Hi Chris,
IPv6 neighbor discovery uses various multicast addresses to send the request and receive the response. For neighbor discovery to work properly in U-boot the Ethernet device needs to support joining/leaving various L2 multicast groups or it needs to support multicast/promiscuous mode. For the sake of simplicity the latter approach has been taken. The e1000 hardware has slightly finer grained control in that it is possible to enable support for multicast-promiscuous mode separately from unicast so the extra traffic received is less.
Signed-off-by: Chris Packham judge.packham@gmail.com --- Drivers that support multicast reception have it enabled/disabled with CONFIG_MCAST_TFTP. It wouldn't be too hard to create a separate CONFIG_MCAST that is selected by enabling CONFIG_MCAST_TFTP or CONFIG_NET6.
drivers/net/e1000.c | 5 +++++ 1 file changed, 5 insertions(+)
diff --git a/drivers/net/e1000.c b/drivers/net/e1000.c index 2ba03ed..e5b00a4 100644 --- a/drivers/net/e1000.c +++ b/drivers/net/e1000.c @@ -5090,6 +5090,11 @@ e1000_setup_rctl(struct e1000_hw *hw) rctl &= ~(E1000_RCTL_SZ_4096); rctl |= E1000_RCTL_SZ_2048; rctl &= ~(E1000_RCTL_BSEX | E1000_RCTL_LPE); + +#ifdef CONFIG_CMD_NET6 + rctl |= E1000_RCTL_MPE; +#endif + E1000_WRITE_REG(hw, RCTL, rctl); }
Hi Chris,
Chris,
Thanks for the update. I didn't receive all the patches but well, a couple of comments below.
-----Message d'origine----- De : Chris Packham [mailto:judge.packham@gmail.com] Envoyé : lundi 12 octobre 2015 09:43 À : u-boot@lists.denx.de; Joe Hershberger Cc : jp.tosoni@acksys.fr; hannah@marvell.com; Angga; Chris Packham; Tom Rini; Simon Glass; Masahiro Yamada Objet : [RFC PATCH 0/8] IPv6 support
This series adds basic IPv6 support to U-boot. It is a reboot of my earlier work on this[1]. Technically this is v4 of the series but with the amount of time that has passed, rebasing and running though checkpatch as well as the support for TFTP I've decided to reset the counter back to 1.
Most of this is ported from Allied Telesis' additions to u-boot[2]. (Note that I am employed by Allied Telesis[3]). The hard work was done some time ago by Angga, I've cleaned it up and made some improvements with the hope of getting it accepted upstream.
A few open issues/questions
- Presumably the majority of the actual V6 code would be included by a
config option. How far should I take that? Should the vsprintf code be conditional? I'm also not sure where to draw the line between CONFIG_NET6 and CONFIG_CMD_NET6, CONFIG_NET and CONFIG_CMD_NET look similarly confused.
If possible vsprintf code should be a different conditional since it could be used for other purpose than in IPv6 frames processing; ie. CONFIG_FORMAT_IP6 ?
- This code parallels net.c and net.h. Should I continue this for the
final version or integrate it into net.[ch].
Net.c is already big and most of your changes look independent. I would keep net6.c separate. Maybe in an ideal future, split net.c into net4.c and net.c ?
Regards, Jean-Pierre Tosoni
Hi Chris,
Thanks for all your work on this!
They are, and I'm trying to tease them apart gradually. I'm using the rule of thumb that if it is needed to support network traffic independent of the command line (maybe from a standalone app or some firmware update thing) then use CONFIG_NET, if it's only adding command-line net features, then use CONFIG_CMD_NET. It's mostly confused because in the past only CONFIG_CMD_NET existed to switch all behavior on and off.
continue this for the final version or integrate it into net.[ch].
I think it's good to keep them separate for now. A later refactoring can change that more easily than pulling them apart.
- rxhand_f currently takes an struct in_addr *. TFTP doesn't use this
(I haven't looked at other users). To support V6 this may need to be a new union, a void * with some kind of flag or nothing if no rxhandler actually cares.
I'm OK with removing the parameter and reparsing the packet in the handler if needed. Again, that can be refactored later if it becomes a pain.
Regards, Chris -- [1] - http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/151390 [2] - http://www.alliedtelesis.co.nz/support/gpl/other.html [3] - some of this has been done on work time, other parts have been done in my personal time. Since I'm subscribed to the list using my gmail account I've signed using that.
Chris Packham (8): Initial net6.h lib: vsprintf: add IPv6 compressed format %pI6c lib: net_utils: make string_to_ip stricter lib: net_utils: add string_to_ip6 net: ipv6 support net: TFTP over IPv6 net: IPv6 documentation net: e1000 enable multicast reception
README | 3 + common/Kconfig | 15 ++ common/cmd_net.c | 41 +++++ doc/README.ipv6 | 34 ++++ drivers/net/e1000.c | 5 + include/env_callback.h | 9 + include/env_flags.h | 10 ++ include/net.h | 5 +- include/net6.h | 280 +++++++++++++++++++++++++++++++ lib/net_utils.c | 132 ++++++++++++++- lib/vsprintf.c | 144 +++++++++++++--- net/Kconfig | 5 + net/Makefile | 3 + net/ndisc.c | 269 ++++++++++++++++++++++++++++++ net/ndisc.h | 27 +++ net/net.c | 39 ++++- net/net6.c | 439 +++++++++++++++++++++++++++++++++++++++++++++++++ net/ping6.c | 111 +++++++++++++ net/tftp.c | 37 +++++ 19 files changed, 1583 insertions(+), 25 deletions(-) create mode 100644 doc/README.ipv6 create mode 100644 include/net6.h create mode 100644 net/ndisc.c create mode 100644 net/ndisc.h create mode 100644 net/net6.c create mode 100644 net/ping6.c
-- 2.5.3
Angga
Chris Packham
Jean-Pierre Tosoni
Joe Hershberger
