Re: [U-Boot] [PATCH 6/8] OMAP3 beagle Add usbtty configuration
Tom,
From: Tom Rix <Tom.Rix <at> windriver.com> Subject: [PATCH 6/8] OMAP3 beagle Add usbtty configuration Newsgroups: gmane.comp.boot-loaders.u-boot Date: 2009-09-28 16:37:27 GMT (4 weeks, 12 hours and 41 minutes ago)
The primary console of beagle is the serial header.
A secondary console is to use the usbtty. The user can set this manually by doing
setenv stdout usbtty; setenv stdin usbtty; setenv stderr usbtty saveenv
usbtty will be usable by accessing the /dev/ttyACM0 on a linux host.
Signed-off-by: Tom Rix <Tom.Rix <at> windriver.com>
include/configs/omap3_beagle.h | 16 ++++++++++++++++ 1 files changed, 16 insertions(+), 0 deletions(-)
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h index 55eeb94..253cdba 100644 --- a/include/configs/omap3_beagle.h +++ b/include/configs/omap3_beagle.h @@ -98,6 +98,21 @@ #define CONFIG_OMAP3_MMC 1 #define CONFIG_DOS_PARTITION 1
+/* USB */ +#define CONFIG_MUSB_UDC 1 +#define CONFIG_USB_OMAP3 1 +#define CONFIG_TWL4030_USB 1
+/* USB device configuration */ +#define CONFIG_USB_DEVICE 1 +#define CONFIG_USB_TTY 1 +#define CONFIG_SYS_CONSOLE_IS_IN_ENV 1 +/* Change these to suit your needs */ +#define CONFIG_USBD_VENDORID 0x0451 +#define CONFIG_USBD_PRODUCTID 0x5678 +#define CONFIG_USBD_MANUFACTURER "Texas Instruments" +#define CONFIG_USBD_PRODUCT_NAME "Beagle"
We can either define CONFIG_MUSB_UDC or CONFIG_MUSB_HCD (host support), so I think it's better to move host and device specific definitions within CONFIG_MUSB_UDC or CONFIG_MUSB_HCD.
#ifdef CONFIG_USB_OMAP3
#ifdef CONFIG_MUSB_HCD <here define all host specific definitions> #endif
#ifdef CONFIG_MUSB_UDC <here define all device specific definitions> #endif
#endif /* CONFIG_USB_OMAP3 */
This change would make it easier to test Host or device functionalities.
-Ajay
/* commands to include */ #include <config_cmd_default.h>
@@ -164,6 +179,7 @@
#define CONFIG_EXTRA_ENV_SETTINGS \ "loadaddr=0x82000000\0" \
- "usbtty=cdc_acm\0" \ "console=ttyS2,115200n8\0" \ "videomode=1024x768 <at> 60,vxres=1024,vyres=768\0" \ "videospec=omapfb:vram:2M,vram:4M\0" \
-- 1.6.0.6
Gupta, Ajay Kumar wrote:
Tom,
-Ajay
I am not adding host support. Tom
Tom,
-Ajay
Host side controller driver is already available (musb_hcd.c) and can be used by any omap3 platforms.
So I think we can add host config also for all the omap3 platforms which anyways doesn't break device functionality.
I would be submitting USB config patch for omap3_evm by today.
-Ajay
Tom
Gupta, Ajay Kumar
Tom
