[U-Boot] [PATCH] ppc/p4080: Add Corenet Platform Cache (CPC) registers
Signed-off-by: Becky Bruce beckyb@kernel.crashing.org Signed-off-by: Kumar Gala galak@kernel.crashing.org --- include/asm-ppc/immap_85xx.h | 74 ++++++++++++++++++++++++++++++++++++++++++ 1 files changed, 74 insertions(+), 0 deletions(-)
diff --git a/include/asm-ppc/immap_85xx.h b/include/asm-ppc/immap_85xx.h index 43b3a2c..176a381 100644 --- a/include/asm-ppc/immap_85xx.h +++ b/include/asm-ppc/immap_85xx.h @@ -1562,6 +1562,77 @@ typedef struct par_io { u8 res[8]; } par_io_t;
+#ifdef CONFIG_SYS_FSL_CPC +/* + * Define a single offset that is the start of all the CPC register + * blocks - if there is more than one CPC, we expect these to be + * contiguous 4k regions + */ + +typedef struct cpc_corenet { + u32 cpccsr0; /* Config/status reg */ +#define CPC_CSR0_CE 0x80000000 /* Cache Enable */ +#define CPC_CSR0_PE 0x40000000 /* Enable ECC */ +#define CPC_CSR0_FI 0x00200000 /* Cache Flash Invalidate */ +#define CPC_CSR0_WT 0x00080000 /* Write-through mode */ +#define CPC_CSR0_FL 0x00000800 /* Hardware cache flush */ +#define CPC_CSR0_LFC 0x00000400 /* Cache Lock Flash Clear */ + u32 res1; + u32 cpccfg0; /* Configuration register */ +#define CPC_CFG0_SZ_MASK 0x00003fff +#define CPC_CFG0_SZ_K(x) ((x & CPC_CFG0_SZ_MASK) << 6) +#define CPC_CFG0_NUM_WAYS(x) (((x >> 14) & 0x1f) + 1) +#define CPC_CFG0_LINE_SZ(x) ((((x >> 23) & 0x3) + 1) * 32) + u32 res2; + u32 cpcewcr0; /* External Write reg 0 */ + u32 cpcewabr0; /* External write base reg 0 */ + u32 res3[2]; + u32 cpcewcr1; /* External Write reg 1 */ + u32 cpcewabr1; /* External write base reg 1 */ + u32 res4[54]; + u32 cpcsrcr1; /* SRAM control reg 1 */ +#define CPC_SRCR1_SRBARU_MASK 0x0000ffff +#define CPC_SRCR1_SRBARU(x) (((unsigned long long)x >> 32) \ + & CPC_SRCR1_SRBARU_MASK) + u32 cpcsrcr0; /* SRAM control reg 0 */ +#define CPC_SRCR0_SRBARL_MASK 0xffff8000 +#define CPC_SRCR0_SRBARL(x) (x & CPC_SRCR0_SRBARL_MASK) +#define CPC_SRCR0_INTLVEN 0x00000100 +#define CPC_SRCR0_SRAMSZ_1_WAY 0x00000000 +#define CPC_SRCR0_SRAMSZ_2_WAY 0x00000002 +#define CPC_SRCR0_SRAMSZ_4_WAY 0x00000004 +#define CPC_SRCR0_SRAMSZ_8_WAY 0x00000006 +#define CPC_SRCR0_SRAMSZ_16_WAY 0x00000008 +#define CPC_SRCR0_SRAMSZ_32_WAY 0x0000000a +#define CPC_SRCR0_SRAMEN 0x00000001 + u32 res5[62]; + struct { + u32 id; /* partition ID */ + u32 res; + u32 alloc; /* partition allocation */ + u32 way; /* partition way */ + } partition_regs[16]; + u32 res6[704]; + u32 cpcerrinjhi; /* Error injection high */ + u32 cpcerrinjlo; /* Error injection lo */ + u32 cpcerrinjctl; /* Error injection control */ + u32 res7[5]; + u32 cpccaptdatahi; /* capture data high */ + u32 cpccaptdatalo; /* capture data low */ + u32 cpcaptecc; /* capture ECC */ + u32 res8[5]; + u32 cpcerrdet; /* error detect */ + u32 cpcerrdis; /* error disable */ +#define CPC_ERRDIS_TMHITDIS 0x00000080 /* multi-way hit disable */ + u32 cpcerrinten; /* errir interrupt enable */ + u32 cpcerrattr; /* error attribute */ + u32 cpcerreaddr; /* error extended address */ + u32 cpcerraddr; /* error address */ + u32 cpcerrctl; /* error control */ + u32 res9[105]; /* pad out to 4k */ +} cpc_corenet_t; +#endif /* CONFIG_SYS_FSL_CPC */ + /* Global Utilities Block */ #ifdef CONFIG_FSL_CORENET typedef struct ccsr_gur { @@ -1937,6 +2008,7 @@ enum { #define CONFIG_SYS_FSL_CORENET_CLK_OFFSET 0xE1000 #define CONFIG_SYS_FSL_CORENET_RCPM_OFFSET 0xE2000 #define CONFIG_SYS_FSL_CORENET_SERDES_OFFSET 0xEA000 +#define CONFIG_SYS_FSL_CPC_OFFSET 0x10000 #define CONFIG_SYS_MPC85xx_DMA_OFFSET 0x100000 #define CONFIG_SYS_MPC85xx_ESPI_OFFSET 0x110000 #define CONFIG_SYS_MPC85xx_ESDHC_OFFSET 0x114000 @@ -1974,6 +2046,8 @@ enum { #define CONFIG_SYS_MPC85xx_PIC_OFFSET 0x40000 #define CONFIG_SYS_MPC85xx_GUTS_OFFSET 0xE0000
+#define CONFIG_SYS_FSL_CPC_ADDR \ + (CONFIG_SYS_CCSRBAR + CONFIG_SYS_FSL_CPC_OFFSET) #define CONFIG_SYS_FSL_CORENET_QMAN_ADDR \ (CONFIG_SYS_IMMR + CONFIG_SYS_FSL_CORENET_QMAN_OFFSET) #define CONFIG_SYS_FSL_CORENET_BMAN_ADDR \
applied to 85xx
- k
Dear Kumar Gala,
In message 1260980960-15351-1-git-send-email-galak@kernel.crashing.org you wrote:
- Define a single offset that is the start of all the CPC register
- blocks - if there is more than one CPC, we expect these to be
- contiguous 4k regions
- u32 cpccsr0; /* Config/status reg */
- u32 res1;
- u32 cpccfg0; /* Configuration register */
- u32 res2;
- u32 cpcewcr0; /* External Write reg 0 */
- u32 cpcewabr0; /* External write base reg 0 */
- u32 res3[2];
- u32 cpcewcr1; /* External Write reg 1 */
- u32 cpcewabr1; /* External write base reg 1 */
- u32 res4[54];
- u32 cpcsrcr1; /* SRAM control reg 1 */
- u32 cpcsrcr0; /* SRAM control reg 0 */
- u32 res5[62];
- struct {
u32 res;
- } partition_regs[16];
- u32 res6[704];
- u32 cpcerrinjhi; /* Error injection high */
- u32 cpcerrinjlo; /* Error injection lo */
- u32 cpcerrinjctl; /* Error injection control */
- u32 res7[5];
- u32 cpccaptdatahi; /* capture data high */
- u32 cpccaptdatalo; /* capture data low */
- u32 cpcaptecc; /* capture ECC */
- u32 res8[5];
- u32 cpcerrdet; /* error detect */
- u32 cpcerrdis; /* error disable */
- u32 cpcerrinten; /* errir interrupt enable */
- u32 cpcerrattr; /* error attribute */
- u32 cpcerreaddr; /* error extended address */
- u32 cpcerraddr; /* error address */
- u32 cpcerrctl; /* error control */
- u32 res9[105]; /* pad out to 4k */
I really dislike mixing code (struct declaration) and macro defines. Please do not do this. I understand the intention, but the result is ugly and unreadable.
On Dec 17, 2009, at 3:22 PM, Wolfgang Denk wrote:
Dear Kumar Gala,
- u32 res1;
- u32 res2;
- u32 res3[2];
- u32 res4[54];
- u32 res5[62];
- struct {
u32 res;
- u32 res6[704];
- u32 res7[5];
- u32 res8[5];
Whey you say macro's do you mean the mask #defines as well?
- k
Kumar Gala
