[U-Boot] [PATCH v2 10/13] drivers: gpio: add driver for Microchip PIC32 GPIO controller.
PIC32 has ten independently programmable ports and each with multiple pins. These pins can be configured and used as GPIO, if not use by any other peripherals.
Signed-off-by: Purna Chandra Mandal purna.mandal@microchip.com ---
Changes in v2: None
drivers/gpio/Kconfig | 7 ++ drivers/gpio/Makefile | 2 +- drivers/gpio/pic32_gpio.c | 164 ++++++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 172 insertions(+), 1 deletion(-) create mode 100644 drivers/gpio/pic32_gpio.c
diff --git a/drivers/gpio/Kconfig b/drivers/gpio/Kconfig index e60e9fd..13e9a6a 100644 --- a/drivers/gpio/Kconfig +++ b/drivers/gpio/Kconfig @@ -83,4 +83,11 @@ config VYBRID_GPIO help Say yes here to support Vybrid vf610 GPIOs.
+config PIC32_GPIO + bool "Microchip PIC32 GPIO driver" + depends on DM_GPIO + default y if MACH_PIC32 + help + Say yes here to support Microchip PIC32 GPIOs. + endmenu diff --git a/drivers/gpio/Makefile b/drivers/gpio/Makefile index fb4fd25..845a6d4 100644 --- a/drivers/gpio/Makefile +++ b/drivers/gpio/Makefile @@ -46,4 +46,4 @@ obj-$(CONFIG_STM32_GPIO) += stm32_gpio.o obj-$(CONFIG_ZYNQ_GPIO) += zynq_gpio.o obj-$(CONFIG_VYBRID_GPIO) += vybrid_gpio.o obj-$(CONFIG_HIKEY_GPIO) += hi6220_gpio.o - +obj-$(CONFIG_PIC32_GPIO) += pic32_gpio.o diff --git a/drivers/gpio/pic32_gpio.c b/drivers/gpio/pic32_gpio.c new file mode 100644 index 0000000..69e3620 --- /dev/null +++ b/drivers/gpio/pic32_gpio.c @@ -0,0 +1,164 @@ +/* + * Copyright (c) 2015 Microchip Technology Inc + * Purna Chandra Mandal purna.mandal@microchip.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <malloc.h> +#include <asm/io.h> +#include <asm/gpio.h> +#include <linux/compat.h> +#include <dt-bindings/gpio/gpio.h> +#include <mach/pic32.h> + +/* Peripheral Pin Control */ +struct pic32_gpio_regs { + struct pic32_reg_atomic ansel; + struct pic32_reg_atomic tris; + struct pic32_reg_atomic port; + struct pic32_reg_atomic lat; + struct pic32_reg_atomic open_drain; + struct pic32_reg_atomic cnpu; + struct pic32_reg_atomic cnpd; + struct pic32_reg_atomic cncon; +}; + +enum { + MICROCHIP_GPIO_DIR_OUT, + MICROCHIP_GPIO_DIR_IN, + MICROCHIP_GPIOS_PER_BANK = 16, +}; + +struct pic32_gpio_priv { + struct pic32_gpio_regs *regs; + char name[2]; +}; + +static int pic32_gpio_get_value(struct udevice *dev, unsigned offset) +{ + struct pic32_gpio_priv *priv = dev_get_priv(dev); + + return !!(readl(&priv->regs->port.raw) & BIT(offset)); +} + +static int pic32_gpio_set_value(struct udevice *dev, unsigned offset, + int value) +{ + struct pic32_gpio_priv *priv = dev_get_priv(dev); + int mask = BIT(offset); + + if (value) + writel(mask, &priv->regs->port.set); + else + writel(mask, &priv->regs->port.clr); + + return 0; +} + +static int pic32_gpio_direction(struct udevice *dev, unsigned offset) +{ + struct pic32_gpio_priv *priv = dev_get_priv(dev); + + if (readl(&priv->regs->ansel.raw) & BIT(offset)) + return -1; + + if (readl(&priv->regs->tris.raw) & BIT(offset)) + return MICROCHIP_GPIO_DIR_IN; + else + return MICROCHIP_GPIO_DIR_OUT; +} + +static int pic32_gpio_direction_input(struct udevice *dev, unsigned offset) +{ + struct pic32_gpio_priv *priv = dev_get_priv(dev); + int mask = BIT(offset); + + writel(mask, &priv->regs->ansel.clr); + writel(mask, &priv->regs->tris.set); + + return 0; +} + +static int pic32_gpio_direction_output(struct udevice *dev, + unsigned offset, int value) +{ + struct pic32_gpio_priv *priv = dev_get_priv(dev); + int mask = BIT(offset); + + writel(mask, &priv->regs->ansel.clr); + writel(mask, &priv->regs->tris.clr); + + pic32_gpio_set_value(dev, offset, value); + return 0; +} + +static int pic32_gpio_xlate(struct udevice *dev, struct gpio_desc *desc, + struct fdtdec_phandle_args *args) +{ + desc->offset = args->args[0]; + desc->flags = args->args[1] & GPIO_ACTIVE_LOW ? GPIOD_ACTIVE_LOW : 0; + + return 0; +} + +static int pic32_gpio_probe(struct udevice *dev) +{ + struct gpio_dev_priv *uc_priv = dev_get_uclass_priv(dev); + struct pic32_gpio_priv *priv = dev_get_priv(dev); + char *end; + int bank; + + priv->regs = pic32_ioremap(dev_get_addr(dev)); + uc_priv->gpio_count = MICROCHIP_GPIOS_PER_BANK; + end = strrchr(dev->name, '@'); + bank = trailing_strtoln(dev->name, end); + priv->name[0] = 'A' + bank; + uc_priv->bank_name = priv->name; + + return 0; +} + +static int pic32_gpio_get_function(struct udevice *dev, unsigned offset) +{ + int ret = GPIOF_UNUSED; + + switch (pic32_gpio_direction(dev, offset)) { + case MICROCHIP_GPIO_DIR_OUT: + ret = GPIOF_OUTPUT; + break; + case MICROCHIP_GPIO_DIR_IN: + ret = GPIOF_INPUT; + break; + default: + ret = GPIOF_UNUSED; + break; + } + return ret; +} + +static const struct dm_gpio_ops gpio_pic32_ops = { + .direction_input = pic32_gpio_direction_input, + .direction_output = pic32_gpio_direction_output, + .get_value = pic32_gpio_get_value, + .set_value = pic32_gpio_set_value, + .get_function = pic32_gpio_get_function, + .xlate = pic32_gpio_xlate, +}; + +static const struct udevice_id pic32_gpio_ids[] = { + { .compatible = "microchip,pic32mzda-gpio" }, + { } +}; + +U_BOOT_DRIVER(gpio_pic32) = { + .name = "gpio_pic32", + .id = UCLASS_GPIO, + .of_match = pic32_gpio_ids, + .ops = &gpio_pic32_ops, + .probe = pic32_gpio_probe, + .priv_auto_alloc_size = sizeof(struct pic32_gpio_priv), +};
2016-01-04 15:01 GMT+01:00 Purna Chandra Mandal purna.mandal@microchip.com:
Changes in v2: None
+config PIC32_GPIO
depends on DM_GPIO
help
- Copyright (c) 2015 Microchip Technology Inc
- Purna Chandra Mandal purna.mandal@microchip.com
+enum {
char name[2];
int value)
if (value)
else
return -1;
else
char *end;
int bank;
split this code and check the return value of dev_get_addr for FDT_ADDR_T_NONE like you did in your other drivers.
ret = GPIOF_OUTPUT;
break;
ret = GPIOF_INPUT;
break;
default:
ret = GPIOF_UNUSED;
break;
return ret;
.id = UCLASS_GPIO,
1.8.3.1
Changes in v2: None
+config PIC32_GPIO
depends on DM_GPIO
help
+enum {
char name[2];
int value)
if (value)
else
return -1;
else
char *end;
int bank;
Ack, Will add sanity check.
ret = GPIOF_OUTPUT;
break;
ret = GPIOF_INPUT;
break;
default:
ret = GPIOF_UNUSED;
break;
return ret;
.id = UCLASS_GPIO,
1.8.3.1
Daniel Schwierzeck
