[U-Boot] [PATCH] ppc4xx: Add variable "korat_usbcf" for Korat board
The new environment variable "korat_usbcf" selects the USB port used by the Korat board's CompactFlash controller.
Signed-off-by: Larry Johnson lrj@acm.org --- board/korat/korat.c | 23 ++++++++++++++++++++++- doc/README.korat | 14 ++++++++++++++ 2 files changed, 36 insertions(+), 1 deletions(-)
diff --git a/board/korat/korat.c b/board/korat/korat.c index 5ad75f7..8328ba3 100644 --- a/board/korat/korat.c +++ b/board/korat/korat.c @@ -1,5 +1,5 @@ /* - * (C) Copyright 2007-2008 + * (C) Copyright 2007-2009 * Larry Johnson, lrj@acm.org * * (C) Copyright 2006-2007 @@ -351,6 +351,7 @@ int misc_init_r(void) unsigned long sdr0_pfc1; uint32_t const flash1_size = gd->bd->bi_flashsize - CONFIG_SYS_FLASH0_SIZE; char const *const act = getenv("usbact"); + char const *const usbcf = getenv("korat_usbcf");
/* * Re-do FLASH1 sizing and adjust flash start and offset. @@ -405,6 +406,26 @@ int misc_init_r(void) /* * USB suff... */ + /* + * Select the USB controller on the 440EPx ("ppc") or on the PCI bus + * ("pci") for the CompactFlash. + */ + if (usbcf != NULL && (strcmp(usbcf, "ppc") == 0)) { + /* + * If environment variable "usbcf" is defined and set to "ppc", + * then connect the CompactFlash controller to the PowerPC USB + * port. + */ + printf("Attaching CompactFalsh controller to PPC USB\n"); + out_8((u8 *) CONFIG_SYS_CPLD_BASE + 0x02, + in_8((u8 *) CONFIG_SYS_CPLD_BASE + 0x02) | 0x10); + } else { + if (usbcf != NULL && (strcmp(usbcf, "pci") != 0)) + printf("Warning: "korat_usbcf" is not set to a legal " + "value ("ppc" or "pci")\n"); + + printf("Attaching CompactFalsh controller to PCI USB\n"); + } if (act == NULL || strcmp(act, "hostdev") == 0) { /* SDR Setting */ mfsdr(SDR0_PFC1, sdr0_pfc1); diff --git a/doc/README.korat b/doc/README.korat index 0a59f40..49cd102 100644 --- a/doc/README.korat +++ b/doc/README.korat @@ -49,3 +49,17 @@ creates the upgradable U-Boot but selecting loader file "u-boot-F7FC.lds" and leaving preprocessor symbol "CONFIG_KORAT_PERMANENT" undefined.
2008-02-22, Larry Johnson lrj@acm.org + + + +The CompactFlash(R) controller on the Korat board provides a hi-speed USB +interface. This may be connected to either a dedicated port on the on-board +USB controller, or to a USB port on the PowerPC 440EPx processor. The U-Boot +environment variable "korat_usbcf" can be used to specify which of these two +USB host ports is used for CompactFlash. The valid setting for the variable are +the strings "pci" and "ppc". If the variable defined and set to "ppc", then the +PowerPC USB port is used. In all other cases the on-board USB controller is +used, but if "korat_usbcf" is defined but is set to a string other than the two +valid options, a warning is also issued. + +2009-01-28, Larry Johnson lrj@acm.org
Applied to 4xx/master. Thanks.
Best regards, Stefan
Larry Johnson
Stefan Roese
