[PATCH] imx8m{m,n}-venice-gw7902: add GSC ADC rail for VDD_5P0
The GW7902-C revision adds an ADC for the VDD_5P0 voltage rail. Add register definitions for it.
Signed-off-by: Tim Harvey tharvey@gateworks.com --- arch/arm/dts/imx8mm-venice-gw7902.dts | 7 +++++++ arch/arm/dts/imx8mn-venice-gw7902.dts | 7 +++++++ 2 files changed, 14 insertions(+)
diff --git a/arch/arm/dts/imx8mm-venice-gw7902.dts b/arch/arm/dts/imx8mm-venice-gw7902.dts index d37ffc050da2..adf521632d63 100644 --- a/arch/arm/dts/imx8mm-venice-gw7902.dts +++ b/arch/arm/dts/imx8mm-venice-gw7902.dts @@ -348,6 +348,13 @@ gw,voltage-divider-ohms = <10000 10000>; };
+ channel@9c { + gw,mode = <2>; + reg = <0x9c>; + label = "vdd_5p0"; + gw,voltage-divider-ohms = <10000 10000>; + }; + channel@a2 { gw,mode = <2>; reg = <0xa2>; diff --git a/arch/arm/dts/imx8mn-venice-gw7902.dts b/arch/arm/dts/imx8mn-venice-gw7902.dts index d3c08e59c542..29897c161b96 100644 --- a/arch/arm/dts/imx8mn-venice-gw7902.dts +++ b/arch/arm/dts/imx8mn-venice-gw7902.dts @@ -347,6 +347,13 @@ gw,voltage-divider-ohms = <10000 10000>; };
Subject: [PATCH] imx8m{m,n}-venice-gw7902: add GSC ADC rail for VDD_5P0
Acked-by: Peng Fan peng.fan@nxp.com
channel@9c {
gw,mode = <2>;
reg = <0x9c>;
label = "vdd_5p0";
channel@9c {
gw,mode = <2>;
reg = <0x9c>;
label = "vdd_5p0";
-- 2.17.1
The GW7902-C revision adds an ADC for the VDD_5P0 voltage rail. Add register definitions for it. Signed-off-by: Tim Harvey tharvey@gateworks.com Acked-by: Peng Fan peng.fan@nxp.com
Best regards, Stefano Babic
Peng Fan
sbabic@denx.de
Tim Harvey
